  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • K Kusi
    @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
    npm i iobroker.js-controller@4.0.3
    kusi@ioBroker:~$ npm i iobroker.js-controller@4.0.3
    > iobroker.js-controller@4.0.3 preinstall /home/kusi/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.15
    > iobroker.js-controller@4.0.3 install /home/kusi/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 14 objects to Redis Sets
    object system.licenses created
    object _design/system updated
      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----***-----END RSA PRIVATE KEY-----\r\n",
      "defaultPublic": "-----BEGIN CERTIFICATE-----***-----END CERTIFICATE-----\r\n"
    Update certificate defaultPrivate
    The object "system.certificates" was updated successfully.
    Update certificate defaultPublic
    Renamed repository "default to "stable"
    Renamed repository "latest to "beta"
    States DB type migrated from "file" to "jsonl"
    Objects DB type migrated from "file" to "jsonl"
     Could not read notifications.json: /home/kusi/iobroker-data/notifications.json: ENOENT: no such file or directory, open '/home/kusi/iobroker-data/notifications.json'
    ioBroker configuration updated
    npm WARN saveError ENOENT: no such file or directory, open '/home/kusi/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/home/kusi/package.json'
    npm WARN kusi No description
    npm WARN kusi No repository field.
    npm WARN kusi No README data
    npm WARN kusi No license field.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@4.0.3
    added 73 packages from 29 contributors, updated 2 packages and audited 708 packages in 22.432s
    24 packages are looking for funding
      run `npm fund` for details
    found 55 vulnerabilities (15 low, 7 moderate, 33 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    "RSA Private Key" und "Certificate" habe ich entfernt. Denke dass dies okay ist?
    Meldung auf den Status:
    kusi@ioBroker:~$ iobroker status
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    @kusi Ok, in welchem verzeichnis haste das denn ausgeführt? Sollte /opt/iobroker sein :-)
    • K Kusi
        throw err;
        requireStack: []
      @kusi
      Als Beta-Tester sollte man nicht in
      kusi@ioBroker:~$
      stehen, wenn man seine Installation repariert.
      • apollon77A apollon77
        Kusi
        @Thomas-Braun
        Daran lag es tatsächlich. Dass dies eine Rolle spielt, habe ich ehrlich gesagt nicht gewusst...
        • K Kusi
          @Thomas-Braun
          @kusi Tut es. Und das sollte eigentlich Beta-Tester-Grundwissen sein.
          Jetzt hast du das im Home (mit ~ abgekürzt) des Users kusi installiert
            Kusi
            @thomas-braun sagte in js-controller 4.0 jetzt im BETA/LATEST!:
            Vielen Dank für deine und @apollon77 ´s Hilfe.
            Ich muss zugestehen dass ich das Beta-Tester-Grundwissen (noch) nicht habe.
            Warum ich die Beta-Version installiert habe, dafür gibt es keinen intelligenten Grund, eher aus Blödsinn. Neugier.
            Soll ich etwas löschen?
            Ein Backup der kompletten VM, sowie ioBroker habe ich natürlich gemacht.
            • K Kusi
              @kusi DU solltest in deinem Home jetzt ein node_modules haben und ggf paar Extra Files ... kannste löschen
                Kusi
                schrieb am zuletzt editiert von Kusi
                Ja, habe ich, wobei ich ein Teil schon vorher hatte, da ich node_modules für die Neeo-Remote installieren musste.
                Soll ich den kompletten Inhalt von /home/kusi löschen und nötigenfalls meine node_module neu installieren?
                • K Kusi
                  @kusi Wie du magst. SOnst hast da halt mehr drin. Aber ja besser aufäumen
                  F K 2 Antworten Letzte Antwort
                    F Online
                    F Online
                    fastfoot
                    @apollon77 auch hier etwas holpriges Upgrade auf einem brandneuen System (Docker mit latest-v6 image).
                    • Grundsetup in der GUI
                    • iob fix zum Sicherstellen dass die folgenden Fehler nicht von evtl. vorh. Fehlern kommen
                    • iob update && iob upgrade self bringt gleichen Fehler wie hier
                    • nach erfolgreichem npm i iobroker.js-controller@4.0.3 gibts beim Neustart einen permission Fehler, Admin startet nicht
                    • nach iob fix läuft es nun fehlerfrei
                    Gratulation zum Release!
                    • apollon77A Offline
                      Danke arbeite bereits am relevanten Fix. Das Problem ist genau das eine was wir vorher nicht testen konnten :-) 4.0.4 kommt heute Abend noch.
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        @apollon77 Was konnte denn im Vorfeld nicht getestet werden?
                        • FeuersturmF Feuersturm
                          @feuersturm "iob upgrade self" ... Das tickt minimal anders wie ein direkter npm Install
                            Kusi
                            erledigt, vielen Dank...
                            Müssen die Befehle
                            iobroker update
                            iobroker upgrade self
                            immer im obigen Verzeichnis ausgeführt werden?
                            • E Offline
                              e-i-k-e
                              schrieb am zuletzt editiert von e-i-k-e
                              Master/Slave System, redis/redis, node 14.19.0
                              Ich habe testweiße nur den Master auf 4.0.3 hochgezogen, der Rest läuft auf 3.3.22.
                              Alle Adapter sind grün.
                              Erhalte nur lediglich folgendes im log:
                              zigbee.0	2022-02-06 00:09:40.269	warn	(135012) A 60a423fffe7ddd1d 0x60a423fffe7ddd1d
                              cloud.0	2022-02-06 00:09:36.145	error	(135399) Cannot activate admin.2 for cloud, because authentication is enabled. Please create extra instance for cloud
                              host.ioBroker-Rock	2022-02-06 00:09:05.905	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                              cloud.0	2022-02-06 00:09:05.794	error	(135399) Cannot activate admin.2 for cloud, because authentication is enabled. Please create extra instance for cloud
                              sainlogic.0	2022-02-06 00:09:02.426	warn	(135440) slow connection to objects DB. Still waiting ...
                              daswetter.0	2022-02-06 00:09:00.082	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_4.symbol_value2: DB closed]
                              daswetter.0	2022-02-06 00:09:00.080	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_4.symbol_desc2: DB closed]
                              daswetter.0	2022-02-06 00:09:00.079	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_4.day_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.078	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_4.day_name: DB closed]
                              daswetter.0	2022-02-06 00:09:00.077	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_4: DB closed]
                              daswetter.0	2022-02-06 00:09:00.076	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.windchill_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.074	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.snowline_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.073	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.clouds_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.072	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.pressure_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.068	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.humidity_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.066	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.rain_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.064	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.windgusts_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.062	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.windIconURL: DB closed]
                              daswetter.0	2022-02-06 00:09:00.061	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.wind_value: DB closed]
                              daswetter.0	2022-02-06 00:09:00.059	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.wind_dir: DB closed]
                              daswetter.0	2022-02-06 00:09:00.058	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.wind_symbol: DB closed]
                              daswetter.0	2022-02-06 00:09:00.056	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.wind_symbolB: DB closed]
                              daswetter.0	2022-02-06 00:09:00.052	error	(135237) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.iconURL: DB closed]
                              daswetter.0	2022-02-06 00:09:00.038	error	(135237) exception in await insertIntoList [Error: DB closed]
                              daswetter.0	2022-02-06 00:09:00.037	warn	(135237) Could not perform strict object check of state daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8.symbol_value: Connection is closed.
                              daswetter.0	2022-02-06 00:08:59.926	error	(135237) exception in await insertIntoList [Error: DB closed]
                              discovergy.0	2022-02-06 00:08:59.820	error	(135380) State type : printedFullSerialNumber unknown, send this information to the developer ==> printedFullSerialNumber : "1ESYxxxxx"
                              dwd.0	2022-02-06 00:08:59.548	warn	(135429) slow connection to objects DB. Still waiting ...
                              daswetter.0	2022-02-06 00:08:59.375	warn	(135237) Terminated (UNKNOWN_ERROR): Without reason
                              daswetter.0	2022-02-06 00:08:59.369	error	(135237) force terminate
                              device-reminder.0	2022-02-06 00:08:54.654	warn	(135418) slow connection to objects DB. Still waiting ...
                              cloud.0	2022-02-06 00:08:47.181	warn	(135399) slow connection to objects DB. Still waiting ...
                              discovergy.0	2022-02-06 00:08:41.292	warn	(135380) slow connection to objects DB. Still waiting ...
                              shuttercontrol.0	2022-02-06 00:08:37.694	warn	(135323) This object will not be created in future versions. Please report this to the developer.
                              shuttercontrol.0	2022-02-06 00:08:37.693	warn	(135323) Object shuttercontrol.0.info.Azimut is invalid: Default value has to be type "number" but received type "string"
                              shuttercontrol.0	2022-02-06 00:08:37.596	warn	(135323) This object will not be created in future versions. Please report this to the developer.
                              shuttercontrol.0	2022-02-06 00:08:37.595	warn	(135323) Object shuttercontrol.0.info.Elevation is invalid: Default value has to be type "number" but received type "string"
                              discovergy.0	2022-02-06 00:08:59.820	error	(135380) State type : printedFullSerialNumber unknown, send this information to the developer ==> printedFullSerialNumber : "1ESYxxxxxxx"
                              yamaha.0	2022-02-06 00:07:17.065	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:17.065	warn	(135059) Object yamaha.0.powerAllZones is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.996	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.996	warn	(135059) Object yamaha.0.zone4 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.945	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.944	warn	(135059) Object yamaha.0.zone3 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.908	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.907	warn	(135059) Object yamaha.0.zone2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.879	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.879	warn	(135059) Object yamaha.0.zone1 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.492	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.491	warn	(135059) Object yamaha.0.pureDirect is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.436	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.436	warn	(135059) Object yamaha.0.hdmiOut2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.341	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.341	warn	(135059) Object yamaha.0.hdmiOut1 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.261	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.260	warn	(135059) Object yamaha.0.Commands.partyModeVolumeDown is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.168	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.167	warn	(135059) Object yamaha.0.Commands.partyModeVolumeUp is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:16.100	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:16.099	warn	(135059) Object yamaha.0.partyMode is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.988	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.987	warn	(135059) Object yamaha.0.adaptiveDRC is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.871	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.870	warn	(135059) Object yamaha.0.extraBass is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.753	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.753	warn	(135059) Object yamaha.0.YPAOVolume is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.685	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.685	warn	(135059) Object yamaha.0.Commands.skip is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.621	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.618	warn	(135059) Object yamaha.0.Commands.rewind is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.587	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.587	warn	(135059) Object yamaha.0.Commands.skip is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.543	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.541	warn	(135059) Object yamaha.0.Commands.pause is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.495	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.492	warn	(135059) Object yamaha.0.Commands.stop is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.448	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.447	warn	(135059) Object yamaha.0.refresh is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.398	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.397	warn	(135059) Object yamaha.0.power is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.356	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.356	warn	(135059) Object yamaha.0.mute is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                              yamaha.0	2022-02-06 00:07:15.129	warn	(135059) This object will not be created in future versions. Please report this to the developer.
                              yamaha.0	2022-02-06 00:07:15.128	warn	(135059) Object yamaha.0.Commands.toggleMute is invalid: Default value has to be type "boolean" but received type "number"
                              zigbee.0	2022-02-06 00:07:05.605	warn	(135012) DeviceAvailability:Failed to ping 0xa4c138b854f91e6c TS130F
                              synology.0	2022-02-06 00:07:02.580	warn	(135023) This object will not be created in future versions. Please report this to the developer.
                              synology.0	2022-02-06 00:07:02.579	warn	(135023) Object synology.0.SurveillanceStation.getSnapshotCamera is invalid: Default value has to be type "string" but received type "number"
                              • K Kusi
                                Müssen die Befehle
                                iobroker update
                                @kusi Das ist egal. "iobroker" executable regelt das
                                • E e-i-k-e
                                  @e-i-k-e Naja, die "dasWetter DB Closed" sollten beim beenden gekommen sein und liegen am Adapter, genau so wie die anderen Logs ... Checke bitte oben die FAQ und öffne ggf Adapter-Issues
                                  E 1 Antwort Letzte Antwort
                                    e-i-k-e
                                    @apollon77
                                    Okay.
                                    Was bedeutet die Warnung "slow connection to objects DB. Still waiting ..." ?
                                    • E e-i-k-e
                                      @apollon77
                                      Okay.
                                      @e-i-k-e Das heisst das ein Adapterprozess länger als 5s gebraucht hat um sich mit der DB zu verbinden. Das kann bei schwächeren Systemen und ggf höherer last wie beim Starten von alles mal vorkommen
                                        e-i-k-e
                                        @apollon77
                                        Läuft auf einem Intel NUC, aber die Systemlast war beim Start natürlich etwas höher.
                                        Der Netzwerktraffic hat sich mit dem neuen Controller (ab ca. 0 Uhr) deutlich verändert.
                                        • E e-i-k-e
                                          @apollon77
                                          @e-i-k-e Ja das kann mal passieren mit dem Slow Connect. Wenn alles tut ist doch alles ok :-)
