Backitup Mount Error Synology NAS
so jetzt aber :D2022-02-01 18:00:11.207 - info: ical.0 (3551) processing URL: Müllkalender https://calendar.google.com/privat/basic.ics 2022-02-01 18:30:10.553 - info: ical.0 (4838) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v14.18.3, js-controller: 3.3.22 2022-02-01 18:30:11.121 - info: ical.0 (4838) processing URL: Müllkalender https://calendar.google.com/calendar/ical/privat/basic.ics 2022-02-01 18:48:31.475 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true) 2022-02-01 18:48:31.489 - info: backitup.0 (2180) Got terminate signal TERMINATE_YOURSELF 2022-02-01 18:48:31.493 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal 2022-02-01 18:48:31.491 - info: backitup.0 (2180) cleaned everything up... 2022-02-01 18:48:31.493 - info: backitup.0 (2180) terminating 2022-02-01 18:48:31.495 - info: backitup.0 (2180) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2022-02-01 18:48:32.064 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2022-02-01 18:48:34.569 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 5682 2022-02-01 18:48:36.217 - info: backitup.0 (5682) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-01 18:48:36.284 - info: backitup.0 (5682) [iobroker] backup was activated at 02:40 every 1 day(s) 2022-02-01 18:49:39.271 - warn: host.raspberrypi-Server Cannot read file ring.0 / doorbell_86292617/livestream86292617_1638876876746.mp4: Array buffer allocation failed 2022-02-01 18:49:41.569 - error: fullybrowser.0 (2135) States database error: read ECONNRESET 2022-02-01 18:49:41.561 - error: whatsapp-cmb.0 (2207) States database error: read ECONNRESET 2022-02-01 18:49:41.578 - error: shelly.0 (2165) States database error: read ECONNRESET 2022-02-01 18:49:41.579 - error: sonos.0 (2108) States database error: read ECONNRESET 2022-02-01 18:49:41.582 - error: shelly.0 (2165) Objects database error: read ECONNRESET 2022-02-01 18:49:41.588 - error: web.0 (2082) States database error: read ECONNRESET 2022-02-01 18:49:41.590 - error: alexa2.0 (2006) States database error: read ECONNRESET 2022-02-01 18:49:41.595 - error: trashschedule.0 (2150) States database error: read ECONNRESET 2022-02-01 18:49:41.575 - error: backitup.0 (5682) States database error: read ECONNRESET 2022-02-01 18:49:41.629 - info: trashschedule.0 (2150) cleaned everything up... 2022-02-01 18:49:41.631 - info: backitup.0 (5682) cleaned everything up... 2022-02-01 18:49:41.634 - info: fullybrowser.0 (2135) cleaned everything up... 2022-02-01 18:49:41.615 - error: ping.0 (1958) States database error: read ECONNRESET 2022-02-01 18:49:41.583 - error: discovery.0 (2056) States database error: read ECONNRESET 2022-02-01 18:49:41.612 - error: javascript.0 (1947) States database error: read ECONNRESET 2022-02-01 18:49:41.609 - error: admin.0 (1881) States database error: read ECONNRESET 2022-02-01 18:49:41.622 - info: sonos.0 (2108) terminating 2022-02-01 18:49:41.642 - error: javascript.0 (1947) Objects database error: read ECONNRESET 2022-02-01 18:49:41.653 - info: web.0 (2082) terminated http server on port 8082 2022-02-01 18:49:41.643 - info: shelly.0 (2165) Closing Adapter 2022-02-01 18:49:41.655 - info: admin.0 (1881) terminating http server on port 8081 2022-02-01 18:49:41.651 - info: javascript.0 (1947) Stop script script.js.Eigene_Skripte.Batterie_Laden 2022-02-01 18:49:43.134 - info: alexa2.0 (2006) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.136 - info: trashschedule.0 (2150) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.137 - info: backitup.0 (5682) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.140 - info: fullybrowser.0 (2135) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.140 - info: whatsapp-cmb.0 (2207) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.146 - info: ping.0 (1958) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.152 - info: javascript.0 (1947) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.156 - info: web.0 (2082) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.157 - info: sonos.0 (2108) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.159 - info: discovery.0 (2056) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.161 - info: shelly.0 (2165) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:43.163 - info: admin.0 (1881) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-01 18:49:46.590 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.593 - error: shelly.0 (2165) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.601 - warn: alexa2.0 (2006) get state error: DB closed 2022-02-01 18:49:46.602 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.604 - warn: web.0 (2082) get state error: DB closed 2022-02-01 18:49:46.611 - error: whatsapp-cmb.0 (2207) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.658 - warn: discovery.0 (2056) get state error: DB closed 2022-02-01 18:49:46.680 - error: backitup.0 (5682) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.669 - error: ping.0 (1958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.675 - error: admin.0 (1881) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.689 - error: trashschedule.0 (2150) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.592 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.608 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.610 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.611 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.613 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.614 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.616 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.624 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.630 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.635 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.640 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.641 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.643 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.644 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.645 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.646 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.648 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.649 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.686 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.687 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.688 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.688 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.689 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.690 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.690 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.706 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.707 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.707 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.708 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.708 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.709 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.709 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.710 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.710 - warn: fullybrowser.0 (2135) get state error: DB closed 2022-02-01 18:49:46.617 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.619 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.621 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.622 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.623 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.625 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.636 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.637 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.639 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.640 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.666 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.667 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.668 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.668 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.669 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.670 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.670 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.671 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.671 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.672 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.673 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.673 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.674 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.674 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.675 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.675 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.687 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.688 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.689 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.689 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.690 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.690 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.716 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.717 - warn: sonos.0 (2108) get state error: DB closed 2022-02-01 18:49:46.726 - error: javascript.0 (1947) Objects database error: connect ECONNREFUSED 127.0.0.1:9001 2022-02-01 18:49:46.719 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.720 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.721 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.729 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.729 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.730 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.731 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.732 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.732 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.733 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.734 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.734 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.735 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.736 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.767 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.767 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.768 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.769 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.770 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.770 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.771 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.772 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.772 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.773 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.774 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.774 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.775 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.775 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.801 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.801 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.802 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.803 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.804 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.804 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:46.805 - warn: backitup.0 (5682) get state error: DB closed 2022-02-01 18:49:51.731 - error: backitup.0 (5682) Cannot find view "system" for search "script" : Connection is closed. 2022-02-01 18:51:23.411 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6157 2022-02-01 18:51:25.254 - info: backitup.0 (6157) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-01 18:51:25.323 - info: backitup.0 (6157) [iobroker] backup was activated at 02:40 every 1 day(s) -
@habi989 sagte in Backitup Mount Error Synology NAS:
so jetzt aber
was ist das?
Hat mein Tablet lahmgelegt.
Seitenweise info, warn und error die nix mit dem backitup zu tun haben, aber kein backitup debugHi, sorry das walnatürlich nicht meine Absicht.
Ich habe das Log nun gesäubert und alle anderen Warnungen etc. herausgelöscht. Hier nun was der Backitup Adapter meldet.
2022-02-02 09:49:41.089 - error: host.raspberrypi uncaught exception: Array buffer allocation failed 2022-02-02 09:49:42.635 - error: backitup.0 (25330) States database error: read ECONNRESET 2022-02-02 09:49:42.660 - info: backitup.0 (25330) cleaned everything up... 2022-02-02 09:49:42.635 - error: backitup.0 (25330) States database error: read ECONNRESET 2022-02-02 09:49:42.660 - info: backitup.0 (25330) cleaned everything up... 2022-02-02 09:49:44.171 - info: backitup.0 (25330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-02 09:49:44.171 - info: backitup.0 (25330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-02 09:49:47.653 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.655 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.657 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.660 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.663 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.664 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.667 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.669 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.670 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.672 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.674 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.676 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.677 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.679 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.680 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.681 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.683 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.699 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.707 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.708 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.709 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.710 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.711 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.712 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.713 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.716 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.718 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.720 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.721 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.653 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.655 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.657 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.660 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.663 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.664 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.667 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.669 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.670 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.672 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.674 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.676 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.677 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.679 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.680 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.681 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.683 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.699 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.707 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.708 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.709 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.710 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.711 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.712 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.713 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.716 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.718 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.720 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.721 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:50:53.250 - error: backitup.0 (10769) backitup.0 already running 2022-02-02 09:50:53.255 - warn: backitup.0 (10769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-02-02 09:50:53.250 - error: backitup.0 (10769) backitup.0 already running 2022-02-02 09:50:53.255 - warn: backitup.0 (10769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-02-02 09:51:25.869 - info: backitup.0 (10871) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-02 09:51:25.933 - info: backitup.0 (10871) [iobroker] backup was activated at 02:40 every 1 day(s) 2022-02-02 09:51:25.869 - info: backitup.0 (10871) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-02 09:51:25.933 - info: backitup.0 (10871) [iobroker] backup was activated at 02:40 every 1 day(s) -
2022-02-02 09:49:41.089 - error: host.raspberrypi uncaught exception: Array buffer allocation failed 2022-02-02 09:49:42.635 - error: backitup.0 (25330) States database error: read ECONNRESET 2022-02-02 09:49:42.660 - info: backitup.0 (25330) cleaned everything up... 2022-02-02 09:49:42.635 - error: backitup.0 (25330) States database error: read ECONNRESET 2022-02-02 09:49:42.660 - info: backitup.0 (25330) cleaned everything up... 2022-02-02 09:49:44.171 - info: backitup.0 (25330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-02 09:49:44.171 - info: backitup.0 (25330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2022-02-02 09:49:47.653 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.655 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.657 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.660 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.663 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.664 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.667 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.669 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.670 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.672 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.674 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.676 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.677 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.679 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.680 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.681 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.683 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.699 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.707 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.708 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.709 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.710 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.711 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.712 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.713 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.716 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.718 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.720 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.721 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.653 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.655 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.657 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.660 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.663 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.664 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.667 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.669 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.670 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.672 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.674 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.676 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.677 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.679 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.680 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.681 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.683 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.698 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.699 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.707 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.708 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.709 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.710 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.711 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.712 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.713 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.716 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.717 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.718 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.719 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.720 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:49:47.721 - warn: backitup.0 (25330) get state error: DB closed 2022-02-02 09:50:53.250 - error: backitup.0 (10769) backitup.0 already running 2022-02-02 09:50:53.255 - warn: backitup.0 (10769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-02-02 09:50:53.250 - error: backitup.0 (10769) backitup.0 already running 2022-02-02 09:50:53.255 - warn: backitup.0 (10769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-02-02 09:51:25.869 - info: backitup.0 (10871) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-02 09:51:25.933 - info: backitup.0 (10871) [iobroker] backup was activated at 02:40 every 1 day(s) 2022-02-02 09:51:25.869 - info: backitup.0 (10871) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-02 09:51:25.933 - info: backitup.0 (10871) [iobroker] backup was activated at 02:40 every 1 day(s)@habi989 sagte in Backitup Mount Error Synology NAS:
das ist immer noch kein debug-log!
hast du die Instanz auch auf Logstufe debug gestellt?Bin mal am PC und habe deinen letzten Riesen-log mal etwas gekürzt.
Dabei habe ich eine Zeile gesehen, die mich stutzig macht:
hast du etwa tausende MB an Videos im Backup?
ach jetzt habe ich kapiert was du mir sagen wolltest. So habe es auf debug gestellt. so wie ich das sehe findet er kein backup?
2022-02-02 13:56:53.835 - debug: backitup.0 (22002) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-02 13:56:53.934 - debug: backitup.0 (22002) Objects client ready ... initialize now 2022-02-02 13:56:53.937 - debug: backitup.0 (22002) Objects create System PubSub Client 2022-02-02 13:56:53.939 - debug: backitup.0 (22002) Objects create User PubSub Client 2022-02-02 13:56:53.941 - debug: backitup.0 (22002) Objects client initialize lua scripts 2022-02-02 13:56:53.956 - debug: backitup.0 (22002) Objects connected to redis: 127.0.0.1:9001 2022-02-02 13:56:53.965 - debug: backitup.0 (22002) objectDB connected 2022-02-02 13:56:53.967 - debug: backitup.0 (22002) Redis States: Use Redis connection: 127.0.0.1:9000 2022-02-02 13:56:53.976 - debug: backitup.0 (22002) States create System PubSub Client 2022-02-02 13:56:53.978 - debug: backitup.0 (22002) States create User PubSub Client 2022-02-02 13:56:53.988 - debug: backitup.0 (22002) States connected to redis: 127.0.0.1:9000 2022-02-02 13:56:53.989 - debug: backitup.0 (22002) statesDB connected 2022-02-02 13:56:54.283 - debug: backitup.0 (22002) Plugin sentry Initialize Plugin (enabled=true) 2022-02-02 13:56:54.495 - info: backitup.0 (22002) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-02 13:56:54.540 - debug: backitup.0 (22002) Backitup has recognized a linux system 2022-02-02 13:56:54.646 - debug: backitup.0 (22002) [iobroker] 10 40 02 */1 * * 2022-02-02 13:56:54.668 - debug: backitup.0 (22002) noserverino option: true 2022-02-02 13:56:54.669 - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2Backupio/iobroker /opt/iobroker/backups" 2022-02-02 13:56:54.745 - debug: backitup.0 (22002) first mount attempt with smb option failed. try next mount attempt without smb option ... 2022-02-02 13:56:54.746 - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.2Backupio/iobroker /opt/iobroker/backups" 2022-02-02 13:56:54.833 - debug: backitup.0 (22002) mount successfully completed 2022-02-02 13:56:56.843 - debug: backitup.0 (22002) No backup file was found 2022-02-02 13:56:56.843 - debug: backitup.0 (22002) No backup file was found 2022-02-02 13:57:04.585 - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!! 2022-02-02 13:57:04.585 - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!! 2022-02-02 13:57:06.685 - debug: backitup.0 (22002) umount successfully completed 2022-02-02 13:57:06.685 - debug: backitup.0 (22002) umount successfully completed -
2022-02-02 13:56:53.835 - debug: backitup.0 (22002) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-02 13:56:53.934 - debug: backitup.0 (22002) Objects client ready ... initialize now 2022-02-02 13:56:53.937 - debug: backitup.0 (22002) Objects create System PubSub Client 2022-02-02 13:56:53.939 - debug: backitup.0 (22002) Objects create User PubSub Client 2022-02-02 13:56:53.941 - debug: backitup.0 (22002) Objects client initialize lua scripts 2022-02-02 13:56:53.956 - debug: backitup.0 (22002) Objects connected to redis: 127.0.0.1:9001 2022-02-02 13:56:53.965 - debug: backitup.0 (22002) objectDB connected 2022-02-02 13:56:53.967 - debug: backitup.0 (22002) Redis States: Use Redis connection: 127.0.0.1:9000 2022-02-02 13:56:53.976 - debug: backitup.0 (22002) States create System PubSub Client 2022-02-02 13:56:53.978 - debug: backitup.0 (22002) States create User PubSub Client 2022-02-02 13:56:53.988 - debug: backitup.0 (22002) States connected to redis: 127.0.0.1:9000 2022-02-02 13:56:53.989 - debug: backitup.0 (22002) statesDB connected 2022-02-02 13:56:54.283 - debug: backitup.0 (22002) Plugin sentry Initialize Plugin (enabled=true) 2022-02-02 13:56:54.495 - info: backitup.0 (22002) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22 2022-02-02 13:56:54.540 - debug: backitup.0 (22002) Backitup has recognized a linux system 2022-02-02 13:56:54.646 - debug: backitup.0 (22002) [iobroker] 10 40 02 */1 * * 2022-02-02 13:56:54.668 - debug: backitup.0 (22002) noserverino option: true 2022-02-02 13:56:54.669 - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2Backupio/iobroker /opt/iobroker/backups" 2022-02-02 13:56:54.745 - debug: backitup.0 (22002) first mount attempt with smb option failed. try next mount attempt without smb option ... 2022-02-02 13:56:54.746 - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.2Backupio/iobroker /opt/iobroker/backups" 2022-02-02 13:56:54.833 - debug: backitup.0 (22002) mount successfully completed 2022-02-02 13:56:56.843 - debug: backitup.0 (22002) No backup file was found 2022-02-02 13:56:56.843 - debug: backitup.0 (22002) No backup file was found 2022-02-02 13:57:04.585 - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!! 2022-02-02 13:57:04.585 - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!! 2022-02-02 13:57:06.685 - debug: backitup.0 (22002) umount successfully completed 2022-02-02 13:57:06.685 - debug: backitup.0 (22002) umount successfully completed@habi989 sagte in Backitup Mount Error Synology NAS:
was hast du denn gemacht, damit er danach sucht?
Hast du dazu noch eine Antwort?
@homoran sagte in Backitup Mount Error Synology NAS:
@habi989 sagte in Backitup Mount Error Synology NAS:warn: host.raspberrypi-Server Cannot read file ring.0 / doorbell_86292617/livestream86292617_1638876876746.mp4:
ja die Video der Ring werden auf der sd karte abgelegt... etwa 20gb ohne jetzt genau nachzusehen...
Da fehlt ein /
Zeigmal die Pfad in den Einstellungen für das NAS.
Ist das eine FritzBox da?Die 20GB Hollywood-Filme dürften dir das Genick brechen, wenn die Backup-Pfad liegen.
pi@raspberrypi:/opt/iobroker $ du -hs /opt/iobroker/iobroker-data/files/* 252K /opt/iobroker/iobroker-data/files/admin.admin 1.2M /opt/iobroker/iobroker-data/files/alexa2.admin 368K /opt/iobroker/iobroker-data/files/backitup.admin 4.9M /opt/iobroker/iobroker-data/files/daswetter.admin 640K /opt/iobroker/iobroker-data/files/discovery.admin 100K /opt/iobroker/iobroker-data/files/dwd.admin 28K /opt/iobroker/iobroker-data/files/fullybrowser.admin 52K /opt/iobroker/iobroker-data/files/gruenbeck.admin 88K /opt/iobroker/iobroker-data/files/ical.admin 20M /opt/iobroker/iobroker-data/files/icons-icons8 12K /opt/iobroker/iobroker-data/files/icons-icons8.admin 16K /opt/iobroker/iobroker-data/files/icons-mfd-png.admin 6.8M /opt/iobroker/iobroker-data/files/icons-ultimate-png 20K /opt/iobroker/iobroker-data/files/icons-ultimate-png.admin 27M /opt/iobroker/iobroker-data/files/javascript.admin 124K /opt/iobroker/iobroker-data/files/ping.admin 5.1G /opt/iobroker/iobroker-data/files/ring.0 40K /opt/iobroker/iobroker-data/files/ring.admin 204K /opt/iobroker/iobroker-data/files/shelly.admin 48K /opt/iobroker/iobroker-data/files/sonos.admin 176K /opt/iobroker/iobroker-data/files/synology.admin 76K /opt/iobroker/iobroker-data/files/tr-064.admin 216K /opt/iobroker/iobroker-data/files/trashschedule.admin 15M /opt/iobroker/iobroker-data/files/vis 8.8M /opt/iobroker/iobroker-data/files/vis.0 48K /opt/iobroker/iobroker-data/files/vis.admin 24K /opt/iobroker/iobroker-data/files/vis-hqwidgets.admin 12K /opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin 36K /opt/iobroker/iobroker-data/files/vis-metro.admin 68K /opt/iobroker/iobroker-data/files/vis-players.admin 20K /opt/iobroker/iobroker-data/files/vis-timeandweather.admin 36K /opt/iobroker/iobroker-data/files/vis-weather.admin 7.9M /opt/iobroker/iobroker-data/files/web 9.4M /opt/iobroker/iobroker-data/files/web.admin 88K /opt/iobroker/iobroker-data/files/whatsapp-cmb.admin -
Da fehlt ein /
@habi989
Ja, für die Optik: Setz da ein / an den Anfang.
Und wenn das NAS nicht gerade direkt auf der FritzBox läuft nimm den Haken bei 'noserverino' raus. -
5 GiG Videos. Da bleibt das Backup hängen
kann ich das irgendwo konfigurieren, damit das einfach nicht mit in das Backup genommen wird?
In backitup Adapter kann man nichts ausschließen, da musst Du schon selber per Script aufräumen und/oder archivieren. Vlt kann auch der ring Adapter altes Zeugs weglöschen?
@ostfrieseunterwegs sagte in Backitup Mount Error Synology NAS:
ich glaube auch nicht, dass @habi989 das meinte. Sondern eher, ob man im Klingling-Adapter einen anderen Speicherpfad für die Videos einstellen kann (wie z.B. /home/iobroker), der nicht gesichert wird.
okay, ich versuche gerade die Dateien in dem Verzeichnis zu löschen: Hierzu eine Frage:
Das Verzeichnis ist das folgende
/opt/iobroker/iobroker-data/ring_0/snapshot
ich möchte alle Dateien mit der Endung .mp4 löschen.
Kann mir jemand sagen, welchen Befehl ich dazu eingeben muss?
find /opt/iobroker/iobroker-data/ring_0/snapshot -exec rm *.mp4
wäre das richtig?
wäre das richtig?
sudo -u iobroker rm /opt/iobroker/iobroker-data/ring_0/snapshot/*.mp4 -
sudo -u iobroker rm /opt/iobroker/iobroker-data/ring_0/snapshot/*.mp4@thomas-braun @Homoran @Glasfaser
So, nachdem ich nun den Ordner mit den Videos gelöscht habe, hat das Backup auf die NAS endlich funktioniert!
Ich danke euch für eure Hilfe und Geduld!! Vielen, vielen Dank und einen schönen Abend!
