  4. Backitup Mount Error Synology NAS
    1.0k
    6.1k
34 Beiträge 6 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • H habi989
    so jetzt aber :D
    2022-02-01 18:00:11.207  - info: ical.0 (3551) processing URL: Müllkalender https://calendar.google.com/privat/basic.ics
    2022-02-01 18:30:10.553  - info: ical.0 (4838) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v14.18.3, js-controller: 3.3.22
    2022-02-01 18:30:11.121  - info: ical.0 (4838) processing URL: Müllkalender https://calendar.google.com/calendar/ical/privat/basic.ics
    2022-02-01 18:48:31.475  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-02-01 18:48:31.489  - info: backitup.0 (2180) Got terminate signal TERMINATE_YOURSELF
    2022-02-01 18:48:31.493  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    2022-02-01 18:48:31.491  - info: backitup.0 (2180) cleaned everything up...
    2022-02-01 18:48:31.493  - info: backitup.0 (2180) terminating
    2022-02-01 18:48:31.495  - info: backitup.0 (2180) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-01 18:48:32.064  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-02-01 18:48:34.569  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 5682
    2022-02-01 18:48:36.217  - info: backitup.0 (5682) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
    2022-02-01 18:48:36.284  - info: backitup.0 (5682) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-02-01 18:49:39.271  - warn: host.raspberrypi-Server Cannot read file ring.0 / doorbell_86292617/livestream86292617_1638876876746.mp4: Array buffer allocation failed
    2022-02-01 18:49:41.569  - error: fullybrowser.0 (2135) States database error: read ECONNRESET
    2022-02-01 18:49:41.561  - error: whatsapp-cmb.0 (2207) States database error: read ECONNRESET
    2022-02-01 18:49:41.578  - error: shelly.0 (2165) States database error: read ECONNRESET
    2022-02-01 18:49:41.579  - error: sonos.0 (2108) States database error: read ECONNRESET
    2022-02-01 18:49:41.582  - error: shelly.0 (2165) Objects database error: read ECONNRESET
    2022-02-01 18:49:41.588  - error: web.0 (2082) States database error: read ECONNRESET
    2022-02-01 18:49:41.590  - error: alexa2.0 (2006) States database error: read ECONNRESET
    2022-02-01 18:49:41.595  - error: trashschedule.0 (2150) States database error: read ECONNRESET
    2022-02-01 18:49:41.575  - error: backitup.0 (5682) States database error: read ECONNRESET
    2022-02-01 18:49:41.629  - info: trashschedule.0 (2150) cleaned everything up...
    2022-02-01 18:49:41.631  - info: backitup.0 (5682) cleaned everything up...
    2022-02-01 18:49:41.634  - info: fullybrowser.0 (2135) cleaned everything up...
    2022-02-01 18:49:41.615  - error: ping.0 (1958) States database error: read ECONNRESET
    2022-02-01 18:49:41.583  - error: discovery.0 (2056) States database error: read ECONNRESET
    2022-02-01 18:49:41.612  - error: javascript.0 (1947) States database error: read ECONNRESET
    2022-02-01 18:49:41.609  - error: admin.0 (1881) States database error: read ECONNRESET
    2022-02-01 18:49:41.622  - info: sonos.0 (2108) terminating
    2022-02-01 18:49:41.642  - error: javascript.0 (1947) Objects database error: read ECONNRESET
    2022-02-01 18:49:41.653  - info: web.0 (2082) terminated http server on port 8082
    2022-02-01 18:49:41.643  - info: shelly.0 (2165) Closing Adapter
    2022-02-01 18:49:41.655  - info: admin.0 (1881) terminating http server on port 8081
    2022-02-01 18:49:41.651  - info: javascript.0 (1947) Stop script script.js.Eigene_Skripte.Batterie_Laden
    2022-02-01 18:49:43.134  - info: alexa2.0 (2006) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.136  - info: trashschedule.0 (2150) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.137  - info: backitup.0 (5682) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.140  - info: fullybrowser.0 (2135) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.140  - info: whatsapp-cmb.0 (2207) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.146  - info: ping.0 (1958) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.152  - info: javascript.0 (1947) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.156  - info: web.0 (2082) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.157  - info: sonos.0 (2108) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.159  - info: discovery.0 (2056) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.161  - info: shelly.0 (2165) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:43.163  - info: admin.0 (1881) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-02-01 18:49:46.590  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.593  - error: shelly.0 (2165) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.601  - warn: alexa2.0 (2006) get state error: DB closed
    2022-02-01 18:49:46.602  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.604  - warn: web.0 (2082) get state error: DB closed
    2022-02-01 18:49:46.611  - error: whatsapp-cmb.0 (2207) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.658  - warn: discovery.0 (2056) get state error: DB closed
    2022-02-01 18:49:46.680  - error: backitup.0 (5682) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.669  - error: ping.0 (1958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.675  - error: admin.0 (1881) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.689  - error: trashschedule.0 (2150) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.592  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.608  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.610  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.611  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.613  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.614  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.616  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.624  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.630  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.635  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.640  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.641  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.643  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.644  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.645  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.646  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.648  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.649  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.686  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.687  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.688  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.689  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.690  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.706  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.707  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.708  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.709  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.710  - warn: fullybrowser.0 (2135) get state error: DB closed
    2022-02-01 18:49:46.617  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.619  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.621  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.622  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.623  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.625  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.636  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.637  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.639  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.640  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.666  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.667  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.668  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.669  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.670  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.671  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.672  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.673  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.674  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.675  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.687  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.688  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.689  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.690  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.716  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.717  - warn: sonos.0 (2108) get state error: DB closed
    2022-02-01 18:49:46.726  - error: javascript.0 (1947) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-02-01 18:49:46.719  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.720  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.721  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.729  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.730  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.731  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.732  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.733  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.734  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.735  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.736  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.767  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.768  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.769  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.770  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.771  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.772  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.773  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.774  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.775  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.801  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.802  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.803  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.804  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:46.805  - warn: backitup.0 (5682) get state error: DB closed
    2022-02-01 18:49:51.731  - error: backitup.0 (5682) Cannot find view "system" for search "script" : Connection is closed.
    2022-02-01 18:51:23.411  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6157
    2022-02-01 18:51:25.254  - info: backitup.0 (6157) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
    2022-02-01 18:51:25.323  - info: backitup.0 (6157) [iobroker] backup was activated at 02:40 every 1 day(s)
    @habi989
    iobroker status
    • H habi989
      so jetzt aber :D
      @habi989 sagte in Backitup Mount Error Synology NAS:
      so jetzt aber
      was ist das?
      Hat mein Tablet lahmgelegt.
      Seitenweise info, warn und error die nix mit dem backitup zu tun haben, aber kein backitup debug
      H 1 Antwort Letzte Antwort
        so jetzt aber
        was ist das?
        habi989
        Hi, sorry das walnatürlich nicht meine Absicht.
        Ich habe das Log nun gesäubert und alle anderen Warnungen etc. herausgelöscht. Hier nun was der Backitup Adapter meldet.
        2022-02-02 09:49:41.089  - error: host.raspberrypi uncaught exception: Array buffer allocation failed
        2022-02-02 09:49:42.635  - error: backitup.0 (25330) States database error: read ECONNRESET
        2022-02-02 09:49:42.660  - info: backitup.0 (25330) cleaned everything up...
        2022-02-02 09:49:44.171  - info: backitup.0 (25330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-02-02 09:49:47.653  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.655  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.657  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.660  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.663  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.664  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.667  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.669  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.670  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.672  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.674  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.676  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.677  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.679  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.680  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.681  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.683  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.698  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.699  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.707  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.708  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.709  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.710  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.711  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.712  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.713  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.716  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.717  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.718  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.719  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.720  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:49:47.721  - warn: backitup.0 (25330) get state error: DB closed
        2022-02-02 09:50:53.250  - error: backitup.0 (10769) backitup.0 already running
        2022-02-02 09:50:53.255  - warn: backitup.0 (10769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-02-02 09:51:25.869  - info: backitup.0 (10871) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
        2022-02-02 09:51:25.933  - info: backitup.0 (10871) [iobroker] backup was activated at 02:40 every 1 day(s)
        • H habi989
          das ist immer noch kein debug-log!
          hast du die Instanz auch auf Logstufe debug gestellt?
          Bin mal am PC und habe deinen letzten Riesen-log mal etwas gekürzt.
          Dabei habe ich eine Zeile gesehen, die mich stutzig macht:
          hast du etwa tausende MB an Videos im Backup?
          H 2 Antworten Letzte Antwort
            habi989
            ach jetzt habe ich kapiert was du mir sagen wolltest. So habe es auf debug gestellt. so wie ich das sehe findet er kein backup?
            2022-02-02 13:56:53.835  - debug: backitup.0 (22002) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2022-02-02 13:56:53.934  - debug: backitup.0 (22002) Objects client ready ... initialize now
            2022-02-02 13:56:53.937  - debug: backitup.0 (22002) Objects create System PubSub Client
            2022-02-02 13:56:53.939  - debug: backitup.0 (22002) Objects create User PubSub Client
            2022-02-02 13:56:53.941  - debug: backitup.0 (22002) Objects client initialize lua scripts
            2022-02-02 13:56:53.956  - debug: backitup.0 (22002) Objects connected to redis: 127.0.0.1:9001
            2022-02-02 13:56:53.965  - debug: backitup.0 (22002) objectDB connected
            2022-02-02 13:56:53.967  - debug: backitup.0 (22002) Redis States: Use Redis connection: 127.0.0.1:9000
            2022-02-02 13:56:53.976  - debug: backitup.0 (22002) States create System PubSub Client
            2022-02-02 13:56:53.978  - debug: backitup.0 (22002) States create User PubSub Client
            2022-02-02 13:56:53.988  - debug: backitup.0 (22002) States connected to redis: 127.0.0.1:9000
            2022-02-02 13:56:53.989  - debug: backitup.0 (22002) statesDB connected
            2022-02-02 13:56:54.283  - debug: backitup.0 (22002) Plugin sentry Initialize Plugin (enabled=true)
            2022-02-02 13:56:54.495  - info: backitup.0 (22002) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
            2022-02-02 13:56:54.540  - debug: backitup.0 (22002) Backitup has recognized a linux system
            2022-02-02 13:56:54.646  - debug: backitup.0 (22002) [iobroker] 10 40 02 */1 * *
            2022-02-02 13:56:54.668  - debug: backitup.0 (22002) noserverino option: true
            2022-02-02 13:56:54.669  - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2Backupio/iobroker /opt/iobroker/backups"
            2022-02-02 13:56:54.745  - debug: backitup.0 (22002) first mount attempt with smb option failed. try next mount attempt without smb option ...
            2022-02-02 13:56:54.746  - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.2Backupio/iobroker /opt/iobroker/backups"
            2022-02-02 13:56:54.833  - debug: backitup.0 (22002) mount successfully completed
            2022-02-02 13:56:56.843  - debug: backitup.0 (22002) No backup file was found
            2022-02-02 13:57:04.585  - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!!
            2022-02-02 13:57:06.685  - debug: backitup.0 (22002) umount successfully completed
              habi989
              ja die Video der Ring werden auf der sd karte abgelegt... etwa 20gb ohne jetzt genau nachzusehen...
              • H habi989
                was hast du denn gemacht, damit er danach sucht?
                Hast du dazu noch eine Antwort?
                @homoran sagte in Backitup Mount Error Synology NAS:
                • H habi989
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @habi989
                  Zeige mal die Ausgabe von :
                  du -hs /opt/iobroker/iobroker-data/files/*
                  • H habi989
                    Da fehlt ein /
                    Zeigmal die Pfad in den Einstellungen für das NAS.
                    Ist das eine FritzBox da?
                    Die 20GB Hollywood-Filme dürften dir das Genick brechen, wenn die Backup-Pfad liegen.
                    • GlasfaserG Glasfaser
                      @habi989
                      habi989
                      @glasfaser
                      pi@raspberrypi:/opt/iobroker $ du -hs /opt/iobroker/iobroker-data/files/*
                      252K	/opt/iobroker/iobroker-data/files/admin.admin
                      1.2M	/opt/iobroker/iobroker-data/files/alexa2.admin
                      368K	/opt/iobroker/iobroker-data/files/backitup.admin
                      4.9M	/opt/iobroker/iobroker-data/files/daswetter.admin
                      640K	/opt/iobroker/iobroker-data/files/discovery.admin
                      100K	/opt/iobroker/iobroker-data/files/dwd.admin
                      28K	/opt/iobroker/iobroker-data/files/fullybrowser.admin
                      52K	/opt/iobroker/iobroker-data/files/gruenbeck.admin
                      88K	/opt/iobroker/iobroker-data/files/ical.admin
                      20M	/opt/iobroker/iobroker-data/files/icons-icons8
                      12K	/opt/iobroker/iobroker-data/files/icons-icons8.admin
                      16K	/opt/iobroker/iobroker-data/files/icons-mfd-png.admin
                      6.8M	/opt/iobroker/iobroker-data/files/icons-ultimate-png
                      20K	/opt/iobroker/iobroker-data/files/icons-ultimate-png.admin
                      27M	/opt/iobroker/iobroker-data/files/javascript.admin
                      124K	/opt/iobroker/iobroker-data/files/ping.admin
                      5.1G	/opt/iobroker/iobroker-data/files/ring.0
                      40K	/opt/iobroker/iobroker-data/files/ring.admin
                      204K	/opt/iobroker/iobroker-data/files/shelly.admin
                      48K	/opt/iobroker/iobroker-data/files/sonos.admin
                      176K	/opt/iobroker/iobroker-data/files/synology.admin
                      76K	/opt/iobroker/iobroker-data/files/tr-064.admin
                      216K	/opt/iobroker/iobroker-data/files/trashschedule.admin
                      15M	/opt/iobroker/iobroker-data/files/vis
                      8.8M	/opt/iobroker/iobroker-data/files/vis.0
                      48K	/opt/iobroker/iobroker-data/files/vis.admin
                      24K	/opt/iobroker/iobroker-data/files/vis-hqwidgets.admin
                      12K	/opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin
                      36K	/opt/iobroker/iobroker-data/files/vis-metro.admin
                      68K	/opt/iobroker/iobroker-data/files/vis-players.admin
                      20K	/opt/iobroker/iobroker-data/files/vis-timeandweather.admin
                      36K	/opt/iobroker/iobroker-data/files/vis-weather.admin
                      7.9M	/opt/iobroker/iobroker-data/files/web
                      9.4M	/opt/iobroker/iobroker-data/files/web.admin
                      88K	/opt/iobroker/iobroker-data/files/whatsapp-cmb.admin
                        Da fehlt ein /
                        habi989
                        meinst du diese Pfade?
                        • H habi989
                          @habi989
                          Ja, für die Optik: Setz da ein / an den Anfang.
                          Und wenn das NAS nicht gerade direkt auf der FritzBox läuft nimm den Haken bei 'noserverino' raus.
                          • H habi989
                            @glasfaser
                            5 GiG Videos. Da bleibt das Backup hängen
                              habi989
                              kann ich das irgendwo konfigurieren, damit das einfach nicht mit in das Backup genommen wird?
                              HomoranH OstfrieseUnterwegsO 2 Antworten Letzte Antwort
                              • H habi989
                                keine Ahnung, ich nutze klingling nicht
                                • H habi989
                                  OstfrieseUnterwegsO Offline
                                  OstfrieseUnterwegs
                                  In backitup Adapter kann man nichts ausschließen, da musst Du schon selber per Script aufräumen und/oder archivieren. Vlt kann auch der ring Adapter altes Zeugs weglöschen?
                                  • OstfrieseUnterwegsO OstfrieseUnterwegs
                                    @ostfrieseunterwegs sagte in Backitup Mount Error Synology NAS:
                                    ich glaube auch nicht, dass @habi989 das meinte. Sondern eher, ob man im Klingling-Adapter einen anderen Speicherpfad für die Videos einstellen kann (wie z.B. /home/iobroker), der nicht gesichert wird.
                                      habi989
                                      okay, ich versuche gerade die Dateien in dem Verzeichnis zu löschen: Hierzu eine Frage:
                                      Das Verzeichnis ist das folgende
                                      /opt/iobroker/iobroker-data/ring_0/snapshot
                                      ich möchte alle Dateien mit der Endung .mp4 löschen.
                                      Kann mir jemand sagen, welchen Befehl ich dazu eingeben muss?
                                      find /opt/iobroker/iobroker-data/ring_0/snapshot -exec rm *.mp4
                                      wäre das richtig?
                                      • H habi989
                                        wäre das richtig?
                                        sudo -u iobroker rm /opt/iobroker/iobroker-data/ring_0/snapshot/*.mp4
                                          habi989
                                          @thomas-braun @Homoran @Glasfaser
                                          So, nachdem ich nun den Ordner mit den Videos gelöscht habe, hat das Backup auf die NAS endlich funktioniert!
                                          Ich danke euch für eure Hilfe und Geduld!! Vielen, vielen Dank und einen schönen Abend!
