  4. Backitup Mount Error Synology NAS
    1.0k
    6.1k
34 Beiträge 6 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • H habi989
    @glasfaser
    das hat leider nichts gebracht. Nun habe ich folgendes Ergebnis:
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backupio/iobroker","dirMinimal":"Backupio/iobroker","user":"backitup","pass":"****"}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2/Backupio/iobroker /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backupio/iobroker","dirMinimal":"Backupio/iobroker","user":"backitup","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.2","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/Backupio/iobroker","dirMinimal":"/backupDir/iobroker","user":"backitup","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backupio/iobroker","dirMinimal":"Backupio/iobroker","user":"backitup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"slaveSuffix":"","hostType":"Single","nameSuffix":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"WhatsApp","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"WhatsApp","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"WhatsApp","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"WhatsApp","type":"message","instance":"whatsapp-cmb.0","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspberrypi 4630 states saved
    [DEBUG] [iobroker] - host.raspberrypi 5267 objects saved
    hat noch jemand eine Idee?
    @habi989 sagte in Backitup Mount Error Synology NAS:
    Passt doch.
      Passt doch.
      @thomas-braun sagte in Backitup Mount Error Synology NAS:
      Passt doch.
        @roddief sagte in Backitup Mount Error Synology NAS:
        Bei mir heisst das Verzeichniss nur Backups auf der Synology und funktioniert mit CIFS und SMB3.0.
        dann ist Backups auch dein Freigabename!
        @habi989
        wie sieht denn deine Freigabe auf der Syno aus?
        habi989
        schrieb am zuletzt editiert von habi989
        Naja also ich habe einen gemeinsamen Ordner erstellt und diesen wie auf den Bildern zu sehen freigegeben.
        Bildschirmfoto 2022-02-01 um 16.23.00.png Bildschirmfoto 2022-02-01 um 16.21.04.png
        Die IP 192.168.178.98 ist logischerweise der IOBroker....
        Das Einzige, was in diesem Ordner auf der NAS jemals erstellt wurde ist ein Ordner namens tmpscripts. dieser ist leer.
        Das wundert mich so. Er sagt completed, aber erstellt wurde auf der NAS nichts...
        • H habi989
          completed ist der Mount, nicht das Backup.
          Also stimmt schon mal die Freigabe
          Dann stell die Instanz auf debug und sieh nach neuen Fehlermeldungen
          H 1 Antwort Letzte Antwort
            habi989
            was ich komisch finde: Ich habe mir ein Tutorial auf Youtube angesehen um es zu vergleichen. Bei dem sieht man dann, wie der Adapter Backitup die Daten hochlädt, also wie viel MB schon hochgeladen wurden.
            Bei mir bleibt es ja bei den States stehen...
            hier mal der Log, nachdem ich es erneut versucht habe:
            Bildschirmfoto 2022-02-01 um 19.53.06.png Bildschirmfoto 2022-02-01 um 19.52.51.png
            • H habi989
              @habi989
              Bitte keine Screenshots, LogFile aus der Konsole posten.
              iobroker logs --watch
              hilft.
              • H habi989
                war schon mal der erste Fehler :-)
                Lesen hätte gereicht. geht schneller als ein Video ansehen.
                @homoran sagte in Backitup Mount Error Synology NAS:
                und dann:
                Wo ist das debug log?
                bitte nicht als Screenshot,, sondern als Text in code-tags.
                  und dann:
                  habi989
                  so jetzt aber :D
                  2022-02-01 18:00:11.207  - info: ical.0 (3551) processing URL: Müllkalender https://calendar.google.com/privat/basic.ics
                  2022-02-01 18:30:10.553  - info: ical.0 (4838) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v14.18.3, js-controller: 3.3.22
                  2022-02-01 18:30:11.121  - info: ical.0 (4838) processing URL: Müllkalender https://calendar.google.com/calendar/ical/privat/basic.ics
                  2022-02-01 18:48:31.475  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2022-02-01 18:48:31.489  - info: backitup.0 (2180) Got terminate signal TERMINATE_YOURSELF
                  2022-02-01 18:48:31.493  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                  2022-02-01 18:48:31.491  - info: backitup.0 (2180) cleaned everything up...
                  2022-02-01 18:48:31.493  - info: backitup.0 (2180) terminating
                  2022-02-01 18:48:31.495  - info: backitup.0 (2180) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-02-01 18:48:32.064  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-02-01 18:48:34.569  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 5682
                  2022-02-01 18:48:36.217  - info: backitup.0 (5682) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
                  2022-02-01 18:48:36.284  - info: backitup.0 (5682) [iobroker] backup was activated at 02:40 every 1 day(s)
                  2022-02-01 18:49:39.271  - warn: host.raspberrypi-Server Cannot read file ring.0 / doorbell_86292617/livestream86292617_1638876876746.mp4: Array buffer allocation failed
                  2022-02-01 18:49:41.569  - error: fullybrowser.0 (2135) States database error: read ECONNRESET
                  2022-02-01 18:49:41.561  - error: whatsapp-cmb.0 (2207) States database error: read ECONNRESET
                  2022-02-01 18:49:41.578  - error: shelly.0 (2165) States database error: read ECONNRESET
                  2022-02-01 18:49:41.579  - error: sonos.0 (2108) States database error: read ECONNRESET
                  2022-02-01 18:49:41.582  - error: shelly.0 (2165) Objects database error: read ECONNRESET
                  2022-02-01 18:49:41.588  - error: web.0 (2082) States database error: read ECONNRESET
                  2022-02-01 18:49:41.590  - error: alexa2.0 (2006) States database error: read ECONNRESET
                  2022-02-01 18:49:41.595  - error: trashschedule.0 (2150) States database error: read ECONNRESET
                  2022-02-01 18:49:41.575  - error: backitup.0 (5682) States database error: read ECONNRESET
                  2022-02-01 18:49:41.629  - info: trashschedule.0 (2150) cleaned everything up...
                  2022-02-01 18:49:41.631  - info: backitup.0 (5682) cleaned everything up...
                  2022-02-01 18:49:41.634  - info: fullybrowser.0 (2135) cleaned everything up...
                  2022-02-01 18:49:41.615  - error: ping.0 (1958) States database error: read ECONNRESET
                  2022-02-01 18:49:41.583  - error: discovery.0 (2056) States database error: read ECONNRESET
                  2022-02-01 18:49:41.612  - error: javascript.0 (1947) States database error: read ECONNRESET
                  2022-02-01 18:49:41.609  - error: admin.0 (1881) States database error: read ECONNRESET
                  2022-02-01 18:49:41.622  - info: sonos.0 (2108) terminating
                  2022-02-01 18:49:41.642  - error: javascript.0 (1947) Objects database error: read ECONNRESET
                  2022-02-01 18:49:41.653  - info: web.0 (2082) terminated http server on port 8082
                  2022-02-01 18:49:41.643  - info: shelly.0 (2165) Closing Adapter
                  2022-02-01 18:49:41.655  - info: admin.0 (1881) terminating http server on port 8081
                  2022-02-01 18:49:41.651  - info: javascript.0 (1947) Stop script script.js.Eigene_Skripte.Batterie_Laden
                  2022-02-01 18:49:43.134  - info: alexa2.0 (2006) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.136  - info: trashschedule.0 (2150) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.137  - info: backitup.0 (5682) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.140  - info: fullybrowser.0 (2135) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.140  - info: whatsapp-cmb.0 (2207) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.146  - info: ping.0 (1958) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.152  - info: javascript.0 (1947) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.156  - info: web.0 (2082) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.157  - info: sonos.0 (2108) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.159  - info: discovery.0 (2056) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.161  - info: shelly.0 (2165) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:43.163  - info: admin.0 (1881) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2022-02-01 18:49:46.590  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.593  - error: shelly.0 (2165) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.601  - warn: alexa2.0 (2006) get state error: DB closed
                  2022-02-01 18:49:46.602  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.604  - warn: web.0 (2082) get state error: DB closed
                  2022-02-01 18:49:46.611  - error: whatsapp-cmb.0 (2207) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.658  - warn: discovery.0 (2056) get state error: DB closed
                  2022-02-01 18:49:46.680  - error: backitup.0 (5682) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.669  - error: ping.0 (1958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.675  - error: admin.0 (1881) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.689  - error: trashschedule.0 (2150) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.592  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.608  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.610  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.611  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.613  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.614  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.616  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.624  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.630  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.635  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.640  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.641  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.643  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.644  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.645  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.646  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.648  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.649  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.686  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.687  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.688  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.689  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.690  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.706  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.707  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.708  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.709  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.710  - warn: fullybrowser.0 (2135) get state error: DB closed
                  2022-02-01 18:49:46.617  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.619  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.621  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.622  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.623  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.625  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.636  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.637  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.639  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.640  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.666  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.667  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.668  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.669  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.670  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.671  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.672  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.673  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.674  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.675  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.687  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.688  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.689  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.690  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.716  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.717  - warn: sonos.0 (2108) get state error: DB closed
                  2022-02-01 18:49:46.726  - error: javascript.0 (1947) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2022-02-01 18:49:46.719  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.720  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.721  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.729  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.730  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.731  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.732  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.733  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.734  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.735  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.736  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.767  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.768  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.769  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.770  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.771  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.772  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.773  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.774  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.775  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.801  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.802  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.803  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.804  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:46.805  - warn: backitup.0 (5682) get state error: DB closed
                  2022-02-01 18:49:51.731  - error: backitup.0 (5682) Cannot find view "system" for search "script" : Connection is closed.
                  2022-02-01 18:51:23.411  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6157
                  2022-02-01 18:51:25.254  - info: backitup.0 (6157) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
                  2022-02-01 18:51:25.323  - info: backitup.0 (6157) [iobroker] backup was activated at 02:40 every 1 day(s)
                  • H habi989
                    so jetzt aber :D
                    @habi989
                    iobroker status
                    • H habi989
                      so jetzt aber :D
                      so jetzt aber
                      was ist das?
                      Hat mein Tablet lahmgelegt.
                      Seitenweise info, warn und error die nix mit dem backitup zu tun haben, aber kein backitup debug
                        so jetzt aber
                        was ist das?
                        habi989
                        Hi, sorry das walnatürlich nicht meine Absicht.
                        Ich habe das Log nun gesäubert und alle anderen Warnungen etc. herausgelöscht. Hier nun was der Backitup Adapter meldet.
                        2022-02-02 09:49:41.089  - error: host.raspberrypi uncaught exception: Array buffer allocation failed
                        2022-02-02 09:49:42.635  - error: backitup.0 (25330) States database error: read ECONNRESET
                        2022-02-02 09:49:42.660  - info: backitup.0 (25330) cleaned everything up...
                        2022-02-02 09:49:44.171  - info: backitup.0 (25330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2022-02-02 09:49:47.653  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.655  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.657  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.660  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.663  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.664  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.667  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.669  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.670  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.672  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.674  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.676  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.677  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.679  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.680  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.681  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.683  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.698  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.699  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.707  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.708  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.709  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.710  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.711  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.712  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.713  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.716  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.717  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.718  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.719  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.720  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:49:47.721  - warn: backitup.0 (25330) get state error: DB closed
                        2022-02-02 09:50:53.250  - error: backitup.0 (10769) backitup.0 already running
                        2022-02-02 09:50:53.255  - warn: backitup.0 (10769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2022-02-02 09:51:25.869  - info: backitup.0 (10871) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
                        2022-02-02 09:51:25.933  - info: backitup.0 (10871) [iobroker] backup was activated at 02:40 every 1 day(s)
                        • H habi989
                          das ist immer noch kein debug-log!
                          hast du die Instanz auch auf Logstufe debug gestellt?
                          Bin mal am PC und habe deinen letzten Riesen-log mal etwas gekürzt.
                          Dabei habe ich eine Zeile gesehen, die mich stutzig macht:
                          hast du etwa tausende MB an Videos im Backup?
                          H 2 Antworten Letzte Antwort
                            habi989
                            ach jetzt habe ich kapiert was du mir sagen wolltest. So habe es auf debug gestellt. so wie ich das sehe findet er kein backup?
                            2022-02-02 13:56:53.835  - debug: backitup.0 (22002) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2022-02-02 13:56:53.934  - debug: backitup.0 (22002) Objects client ready ... initialize now
                            2022-02-02 13:56:53.937  - debug: backitup.0 (22002) Objects create System PubSub Client
                            2022-02-02 13:56:53.939  - debug: backitup.0 (22002) Objects create User PubSub Client
                            2022-02-02 13:56:53.941  - debug: backitup.0 (22002) Objects client initialize lua scripts
                            2022-02-02 13:56:53.956  - debug: backitup.0 (22002) Objects connected to redis: 127.0.0.1:9001
                            2022-02-02 13:56:53.965  - debug: backitup.0 (22002) objectDB connected
                            2022-02-02 13:56:53.967  - debug: backitup.0 (22002) Redis States: Use Redis connection: 127.0.0.1:9000
                            2022-02-02 13:56:53.976  - debug: backitup.0 (22002) States create System PubSub Client
                            2022-02-02 13:56:53.978  - debug: backitup.0 (22002) States create User PubSub Client
                            2022-02-02 13:56:53.988  - debug: backitup.0 (22002) States connected to redis: 127.0.0.1:9000
                            2022-02-02 13:56:53.989  - debug: backitup.0 (22002) statesDB connected
                            2022-02-02 13:56:54.283  - debug: backitup.0 (22002) Plugin sentry Initialize Plugin (enabled=true)
                            2022-02-02 13:56:54.495  - info: backitup.0 (22002) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
                            2022-02-02 13:56:54.540  - debug: backitup.0 (22002) Backitup has recognized a linux system
                            2022-02-02 13:56:54.646  - debug: backitup.0 (22002) [iobroker] 10 40 02 */1 * *
                            2022-02-02 13:56:54.668  - debug: backitup.0 (22002) noserverino option: true
                            2022-02-02 13:56:54.669  - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2Backupio/iobroker /opt/iobroker/backups"
                            2022-02-02 13:56:54.745  - debug: backitup.0 (22002) first mount attempt with smb option failed. try next mount attempt without smb option ...
                            2022-02-02 13:56:54.746  - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.2Backupio/iobroker /opt/iobroker/backups"
                            2022-02-02 13:56:54.833  - debug: backitup.0 (22002) mount successfully completed
                            2022-02-02 13:56:56.843  - debug: backitup.0 (22002) No backup file was found
                            2022-02-02 13:57:04.585  - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!!
                            2022-02-02 13:57:06.685  - debug: backitup.0 (22002) umount successfully completed
                              habi989
                              ja die Video der Ring werden auf der sd karte abgelegt... etwa 20gb ohne jetzt genau nachzusehen...
                              • H habi989
                                was hast du denn gemacht, damit er danach sucht?
                                Hast du dazu noch eine Antwort?
                                • H habi989
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @habi989
                                  Zeige mal die Ausgabe von :
                                  du -hs /opt/iobroker/iobroker-data/files/*
                                  • H habi989
                                    Da fehlt ein /
                                    Zeigmal die Pfad in den Einstellungen für das NAS.
                                    Ist das eine FritzBox da?
                                    Die 20GB Hollywood-Filme dürften dir das Genick brechen, wenn die Backup-Pfad liegen.
                                    • GlasfaserG Glasfaser
                                      @habi989
                                      habi989
                                      @glasfaser
                                      pi@raspberrypi:/opt/iobroker $ du -hs /opt/iobroker/iobroker-data/files/*
                                      252K	/opt/iobroker/iobroker-data/files/admin.admin
                                      1.2M	/opt/iobroker/iobroker-data/files/alexa2.admin
                                      368K	/opt/iobroker/iobroker-data/files/backitup.admin
                                      4.9M	/opt/iobroker/iobroker-data/files/daswetter.admin
                                      640K	/opt/iobroker/iobroker-data/files/discovery.admin
                                      100K	/opt/iobroker/iobroker-data/files/dwd.admin
                                      28K	/opt/iobroker/iobroker-data/files/fullybrowser.admin
                                      52K	/opt/iobroker/iobroker-data/files/gruenbeck.admin
                                      88K	/opt/iobroker/iobroker-data/files/ical.admin
                                      20M	/opt/iobroker/iobroker-data/files/icons-icons8
                                      12K	/opt/iobroker/iobroker-data/files/icons-icons8.admin
                                      16K	/opt/iobroker/iobroker-data/files/icons-mfd-png.admin
                                      6.8M	/opt/iobroker/iobroker-data/files/icons-ultimate-png
                                      20K	/opt/iobroker/iobroker-data/files/icons-ultimate-png.admin
                                      27M	/opt/iobroker/iobroker-data/files/javascript.admin
                                      124K	/opt/iobroker/iobroker-data/files/ping.admin
                                      5.1G	/opt/iobroker/iobroker-data/files/ring.0
                                      40K	/opt/iobroker/iobroker-data/files/ring.admin
                                      204K	/opt/iobroker/iobroker-data/files/shelly.admin
                                      48K	/opt/iobroker/iobroker-data/files/sonos.admin
                                      176K	/opt/iobroker/iobroker-data/files/synology.admin
                                      76K	/opt/iobroker/iobroker-data/files/tr-064.admin
                                      216K	/opt/iobroker/iobroker-data/files/trashschedule.admin
                                      15M	/opt/iobroker/iobroker-data/files/vis
                                      8.8M	/opt/iobroker/iobroker-data/files/vis.0
                                      48K	/opt/iobroker/iobroker-data/files/vis.admin
                                      24K	/opt/iobroker/iobroker-data/files/vis-hqwidgets.admin
                                      12K	/opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin
                                      36K	/opt/iobroker/iobroker-data/files/vis-metro.admin
                                      68K	/opt/iobroker/iobroker-data/files/vis-players.admin
                                      20K	/opt/iobroker/iobroker-data/files/vis-timeandweather.admin
                                      36K	/opt/iobroker/iobroker-data/files/vis-weather.admin
                                      7.9M	/opt/iobroker/iobroker-data/files/web
                                      9.4M	/opt/iobroker/iobroker-data/files/web.admin
                                      88K	/opt/iobroker/iobroker-data/files/whatsapp-cmb.admin
                                        Da fehlt ein /
                                        habi989
                                        meinst du diese Pfade?
                                        • H habi989
                                          @habi989
                                          Ja, für die Optik: Setz da ein / an den Anfang.
                                          Und wenn das NAS nicht gerade direkt auf der FritzBox läuft nimm den Haken bei 'noserverino' raus.
