  4. Backitup Mount Error Synology NAS
    1.0k
    6.1k
34 Beiträge 6 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • H habi989
    ach jetzt habe ich kapiert was du mir sagen wolltest. So habe es auf debug gestellt. so wie ich das sehe findet er kein backup?
    2022-02-02 13:56:53.835  - debug: backitup.0 (22002) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-02-02 13:56:53.934  - debug: backitup.0 (22002) Objects client ready ... initialize now
    2022-02-02 13:56:53.937  - debug: backitup.0 (22002) Objects create System PubSub Client
    2022-02-02 13:56:53.939  - debug: backitup.0 (22002) Objects create User PubSub Client
    2022-02-02 13:56:53.941  - debug: backitup.0 (22002) Objects client initialize lua scripts
    2022-02-02 13:56:53.956  - debug: backitup.0 (22002) Objects connected to redis: 127.0.0.1:9001
    2022-02-02 13:56:53.965  - debug: backitup.0 (22002) objectDB connected
    2022-02-02 13:56:53.967  - debug: backitup.0 (22002) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-02-02 13:56:53.976  - debug: backitup.0 (22002) States create System PubSub Client
    2022-02-02 13:56:53.978  - debug: backitup.0 (22002) States create User PubSub Client
    2022-02-02 13:56:53.988  - debug: backitup.0 (22002) States connected to redis: 127.0.0.1:9000
    2022-02-02 13:56:53.989  - debug: backitup.0 (22002) statesDB connected
    2022-02-02 13:56:54.283  - debug: backitup.0 (22002) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-02 13:56:54.495  - info: backitup.0 (22002) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.3, js-controller: 3.3.22
    2022-02-02 13:56:54.540  - debug: backitup.0 (22002) Backitup has recognized a linux system
    2022-02-02 13:56:54.646  - debug: backitup.0 (22002) [iobroker] 10 40 02 */1 * *
    2022-02-02 13:56:54.668  - debug: backitup.0 (22002) noserverino option: true
    2022-02-02 13:56:54.669  - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2Backupio/iobroker /opt/iobroker/backups"
    2022-02-02 13:56:54.745  - debug: backitup.0 (22002) first mount attempt with smb option failed. try next mount attempt without smb option ...
    2022-02-02 13:56:54.746  - debug: backitup.0 (22002) cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.2Backupio/iobroker /opt/iobroker/backups"
    2022-02-02 13:56:54.833  - debug: backitup.0 (22002) mount successfully completed
    2022-02-02 13:56:56.843  - debug: backitup.0 (22002) No backup file was found
    2022-02-02 13:57:04.585  - debug: backitup.0 (22002) mount activ... umount in 2 Seconds!!
    2022-02-02 13:57:06.685  - debug: backitup.0 (22002) umount successfully completed
    @habi989 sagte in Backitup Mount Error Synology NAS:
    was hast du denn gemacht, damit er danach sucht?
    Hast du dazu noch eine Antwort?
    @homoran sagte in Backitup Mount Error Synology NAS:
    Dabei habe ich eine Zeile gesehen, die mich stutzig macht:
    warn: host.raspberrypi-Server Cannot read file ring.0 / doorbell_86292617/livestream86292617_1638876876746.mp4:
    hast du etwa tausende MB an Videos im Backup?
    • H habi989
      ja die Video der Ring werden auf der sd karte abgelegt... etwa 20gb ohne jetzt genau nachzusehen...
      GlasfaserG Offline
      GlasfaserG Offline
      @habi989
      Zeige mal die Ausgabe von :
      du -hs /opt/iobroker/iobroker-data/files/*
      H 1 Antwort Letzte Antwort
      • H habi989
        Da fehlt ein /
        Zeigmal die Pfad in den Einstellungen für das NAS.
        Ist das eine FritzBox da?
        Die 20GB Hollywood-Filme dürften dir das Genick brechen, wenn die Backup-Pfad liegen.
        • GlasfaserG Glasfaser
          @habi989
          habi989
          @glasfaser
          pi@raspberrypi:/opt/iobroker $ du -hs /opt/iobroker/iobroker-data/files/*
          252K	/opt/iobroker/iobroker-data/files/admin.admin
          1.2M	/opt/iobroker/iobroker-data/files/alexa2.admin
          368K	/opt/iobroker/iobroker-data/files/backitup.admin
          4.9M	/opt/iobroker/iobroker-data/files/daswetter.admin
          640K	/opt/iobroker/iobroker-data/files/discovery.admin
          100K	/opt/iobroker/iobroker-data/files/dwd.admin
          28K	/opt/iobroker/iobroker-data/files/fullybrowser.admin
          52K	/opt/iobroker/iobroker-data/files/gruenbeck.admin
          88K	/opt/iobroker/iobroker-data/files/ical.admin
          20M	/opt/iobroker/iobroker-data/files/icons-icons8
          12K	/opt/iobroker/iobroker-data/files/icons-icons8.admin
          16K	/opt/iobroker/iobroker-data/files/icons-mfd-png.admin
          6.8M	/opt/iobroker/iobroker-data/files/icons-ultimate-png
          20K	/opt/iobroker/iobroker-data/files/icons-ultimate-png.admin
          27M	/opt/iobroker/iobroker-data/files/javascript.admin
          124K	/opt/iobroker/iobroker-data/files/ping.admin
          5.1G	/opt/iobroker/iobroker-data/files/ring.0
          40K	/opt/iobroker/iobroker-data/files/ring.admin
          204K	/opt/iobroker/iobroker-data/files/shelly.admin
          48K	/opt/iobroker/iobroker-data/files/sonos.admin
          176K	/opt/iobroker/iobroker-data/files/synology.admin
          76K	/opt/iobroker/iobroker-data/files/tr-064.admin
          216K	/opt/iobroker/iobroker-data/files/trashschedule.admin
          15M	/opt/iobroker/iobroker-data/files/vis
          8.8M	/opt/iobroker/iobroker-data/files/vis.0
          48K	/opt/iobroker/iobroker-data/files/vis.admin
          24K	/opt/iobroker/iobroker-data/files/vis-hqwidgets.admin
          12K	/opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin
          36K	/opt/iobroker/iobroker-data/files/vis-metro.admin
          68K	/opt/iobroker/iobroker-data/files/vis-players.admin
          20K	/opt/iobroker/iobroker-data/files/vis-timeandweather.admin
          36K	/opt/iobroker/iobroker-data/files/vis-weather.admin
          7.9M	/opt/iobroker/iobroker-data/files/web
          9.4M	/opt/iobroker/iobroker-data/files/web.admin
          88K	/opt/iobroker/iobroker-data/files/whatsapp-cmb.admin
            Da fehlt ein /
            habi989
            meinst du diese Pfade?
            • H habi989
              @habi989
              Ja, für die Optik: Setz da ein / an den Anfang.
              Und wenn das NAS nicht gerade direkt auf der FritzBox läuft nimm den Haken bei 'noserverino' raus.
              • H habi989
                @glasfaser
                5 GiG Videos. Da bleibt das Backup hängen
                  habi989
                  kann ich das irgendwo konfigurieren, damit das einfach nicht mit in das Backup genommen wird?
                  HomoranH OstfrieseUnterwegsO 2 Antworten Letzte Antwort
                  • H habi989
                    keine Ahnung, ich nutze klingling nicht
                    • H habi989
                      OstfrieseUnterwegsO Offline
                      OstfrieseUnterwegs
                      In backitup Adapter kann man nichts ausschließen, da musst Du schon selber per Script aufräumen und/oder archivieren. Vlt kann auch der ring Adapter altes Zeugs weglöschen?
                      • OstfrieseUnterwegsO OstfrieseUnterwegs
                        @ostfrieseunterwegs sagte in Backitup Mount Error Synology NAS:
                        ich glaube auch nicht, dass @habi989 das meinte. Sondern eher, ob man im Klingling-Adapter einen anderen Speicherpfad für die Videos einstellen kann (wie z.B. /home/iobroker), der nicht gesichert wird.
                          habi989
                          okay, ich versuche gerade die Dateien in dem Verzeichnis zu löschen: Hierzu eine Frage:
                          Das Verzeichnis ist das folgende
                          /opt/iobroker/iobroker-data/ring_0/snapshot
                          ich möchte alle Dateien mit der Endung .mp4 löschen.
                          Kann mir jemand sagen, welchen Befehl ich dazu eingeben muss?
                          find /opt/iobroker/iobroker-data/ring_0/snapshot -exec rm *.mp4
                          wäre das richtig?
                          • H habi989
                            wäre das richtig?
                            sudo -u iobroker rm /opt/iobroker/iobroker-data/ring_0/snapshot/*.mp4
                              habi989
                              @thomas-braun @Homoran @Glasfaser
                              So, nachdem ich nun den Ordner mit den Videos gelöscht habe, hat das Backup auf die NAS endlich funktioniert!
                              Ich danke euch für eure Hilfe und Geduld!! Vielen, vielen Dank und einen schönen Abend!
                              • H habi989
                                klar doch - der Ballast von 5GB war ja weg.
                                ein übliches Backup liegt max. im niedrigen 2stelligen MB-Bereich
