  4. Backit-UP Problem kein Backup möglich
    6.7k
36 Beiträge 3 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • T TinoNikol
    @thomas-braun said in Backit-UP Problem kein Backup möglich:
    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    v12.22.9
    @tinonikol
    Komplette Ein- und Ausgaben.
      @tinonikol
      TinoNikol
      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && wh                                oami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nod                                ejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.9
      v12.22.9
      6.14.15
      pi
      /home/pi
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      nodejs:
        Installed: 12.22.9-deb-1nodesource1
        Candidate: 12.22.9-deb-1nodesource1
        Version table:
       *** 12.22.9-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u1 500
      • T TinoNikol
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v12.22.9
        v12.22.9
        6.14.15
        pi
        /home/pi
        nodejs:
          Version table:
        @tinonikol
        iobroker update -i
        Und spring auf node14.
          @tinonikol
          iobroker update -i
          TinoNikol
          Geht auch nicht!
          pi@raspberrypi:~ $ node -v
          v14.18.3
          T Thomas BraunT 2 Antworten Letzte Antwort
          • T TinoNikol
            Geht auch nicht!
            v14.18.3
            TinoNikol
            @Thomas-Braun
            pi@raspberrypi:~ $ iob backup
            host.raspberrypi 7509 states saved
            host.raspberrypi 8657 objects saved
            internal/buffer.js:958
                super(bufferOrLength, byteOffset, length);
            RangeError: Array buffer allocation failed
                at arrayBufferConstructor_DoNotInitialize (<anonymous>)
                at new Uint8Array (<anonymous>)
                at new FastBuffer (internal/buffer.js:958:5)
                at fromArrayLike (buffer.js:505:10)
                at fromObject (buffer.js:513:12)
                at Function.from (buffer.js:322:15)
                at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemServerRedis.js:452:60)
                at RedisHandler.emit (events.js:400:28)
                at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js:100:37)
                at processImmediate (internal/timers.js:464:21)
            • T TinoNikol
              Geht auch nicht!
              v14.18.3
              @tinonikol sagte in Backit-UP Problem kein Backup möglich:
              Geht auch nicht!
              Ist keine Fehlermeldung.
              iobroker update -i
                Geht auch nicht!
                iobroker update -i
                TinoNikol
                Aber kein Backup!
                Thomas BraunT T 2 Antworten Letzte Antwort
                • T TinoNikol
                  Aber kein Backup!
                  @tinonikol
                  iobroker update -i
                  • T TinoNikol
                    Aber kein Backup!
                    TinoNikol
                    @Thomas-Braun
                    Aber Zigbee Backup speichert er!?
                    • T TinoNikol
                      @Thomas-Braun
                      @tinonikol
                      iobroker update -i
                      Komplett zeigen!
                        @tinonikol
                        iobroker update -i
                        Komplett zeigen!
                        TinoNikol
                        pi@raspberrypi:~ $ iobroker update -i
                        Used repository: stable
                        hash unchanged, use cached sources
                        update done
                        Adapter    "admin"         : 5.2.3    , installed 5.2.3
                        Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                        Adapter    "backitup"      : 2.2.3    , installed 2.2.3
                        Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
                        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                        Adapter    "devices"       : 1.0.9    , installed 1.0.9
                        Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                        Adapter    "fb-checkpresence": 1.1.12  , installed 1.1.12
                        Adapter    "flot"          : 1.10.7   , installed 1.10.7
                        Adapter    "followthesun"  : 0.3.8    , installed 0.3.8
                        Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
                        Adapter    "ham"           : 4.0.2    , installed 4.0.2
                        Adapter    "history"       : 1.9.14   , installed 1.9.14
                        Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                        Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
                        Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                        Adapter    "info"          : 1.9.8    , installed 1.9.8
                        Adapter    "iot"           : 1.8.24   , installed 1.8.24
                        Adapter    "javascript"    : 5.2.13   , installed 5.2.13
                        Controller "js-controller" : 3.3.22   , installed 3.3.22
                        Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
                        Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
                        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                        Adapter    "nina"          : 0.0.25   , installed 0.0.25
                        Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                        Adapter    "shelly"        : 4.0.7    , installed 4.0.8
                        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                        Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                        Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                        Adapter    "tuya"          : 3.6.14   , installed 3.6.14
                        Adapter    "vis"           : 1.4.5    , installed 1.4.5
                        Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                        Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                        Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                        Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                        Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                        Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
                        Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
                        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                        Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                        Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                        Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                        Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                        Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
                        Adapter    "web"           : 3.4.9    , installed 3.4.9
                        Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
                        • T TinoNikol
                          update done
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @tinonikol
                          Zeige mal , was er so hat in :
                          du -hs /opt/iobroker/iobroker-data/*
                          • GlasfaserG Glasfaser
                            @tinonikol
                            TinoNikol
                            @glasfaser said in Backit-UP Problem kein Backup möglich:
                            pi@raspberrypi:~ $ du -hs /opt/iobroker/iobroker-data/*
                            104M    /opt/iobroker/iobroker-data/backup-objects
                            9.0M    /opt/iobroker/iobroker-data/eufy-security.0
                            8.0K    /opt/iobroker/iobroker-data/eufy-security.1
                            5.9G    /opt/iobroker/iobroker-data/files
                            28K     /opt/iobroker/iobroker-data/ham_0
                            16K     /opt/iobroker/iobroker-data/history
                            8.0K    /opt/iobroker/iobroker-data/iobroker.json
                            8.0K    /opt/iobroker/iobroker-data/lgtv_0
                            4.0K    /opt/iobroker/iobroker-data/notifications.json
                            12M     /opt/iobroker/iobroker-data/objects.json
                            12M     /opt/iobroker/iobroker-data/objects.json.bak
                            1.7M    /opt/iobroker/iobroker-data/states.json
                            1.7M    /opt/iobroker/iobroker-data/states.json.bak
                            0       /opt/iobroker/iobroker-data/states.json.broken
                            4.0K    /opt/iobroker/iobroker-data/synology_0
                            1.3M    /opt/iobroker/iobroker-data/Tino
                            27M     /opt/iobroker/iobroker-data/Tino-History
                            12K     /opt/iobroker/iobroker-data/tmp
                            72K     /opt/iobroker/iobroker-data/tuya_0
                            92K     /opt/iobroker/iobroker-data/zigbee_0
                            GlasfaserG T 2 Antworten Letzte Antwort
                            • T TinoNikol
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Puuh der ist aber groß
                              vergleich zu meinem
                              401M    /opt/iobroker/iobroker-data/files
                              Was speicherst du in files
                              • T TinoNikol
                                TinoNikol
                                schrieb am zuletzt editiert von TinoNikol
                                @Glasfaser
                                Aber warum???
                                • T TinoNikol
                                  @Glasfaser
                                  Aber warum???
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @tinonikol
                                  du -hs /opt/iobroker/iobroker-data/files/*
                                    @tinonikol
                                    TinoNikol
                                    pi@raspberrypi:~ $ du -hs /opt/iobroker/iobroker-data/files/*
                                    252K    /opt/iobroker/iobroker-data/files/admin.admin
                                    1.2M    /opt/iobroker/iobroker-data/files/alexa2.admin
                                    368K    /opt/iobroker/iobroker-data/files/backitup.admin
                                    48K     /opt/iobroker/iobroker-data/files/broadlink2.admin
                                    52K     /opt/iobroker/iobroker-data/files/calendar.admin
                                    384K    /opt/iobroker/iobroker-data/files/cloud.admin
                                    47M     /opt/iobroker/iobroker-data/files/devices.admin
                                    640K    /opt/iobroker/iobroker-data/files/discovery.admin
                                    100K    /opt/iobroker/iobroker-data/files/dwd.admin
                                    12K     /opt/iobroker/iobroker-data/files/eufy-security.0
                                    56K     /opt/iobroker/iobroker-data/files/eufy-security.admin
                                    912K    /opt/iobroker/iobroker-data/files/fb-checkpresence.admin
                                    1.4M    /opt/iobroker/iobroker-data/files/flot
                                    12K     /opt/iobroker/iobroker-data/files/flot.admin
                                    112K    /opt/iobroker/iobroker-data/files/followthesun.admin
                                    676K    /opt/iobroker/iobroker-data/files/fullcalendar.admin
                                    28K     /opt/iobroker/iobroker-data/files/fullybrowser.admin
                                    2.3M    /opt/iobroker/iobroker-data/files/ham.admin
                                    208K    /opt/iobroker/iobroker-data/files/history.admin
                                    88K     /opt/iobroker/iobroker-data/files/ical.admin
                                    6.2M    /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png
                                    20K     /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png.admin
                                    6.4M    /opt/iobroker/iobroker-data/files/icons-mfd-png
                                    16K     /opt/iobroker/iobroker-data/files/icons-mfd-png.admin
                                    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                    28K     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png.admin
                                    6.8M    /opt/iobroker/iobroker-data/files/icons-ultimate-png
                                    20K     /opt/iobroker/iobroker-data/files/icons-ultimate-png.admin
                                    2.8M    /opt/iobroker/iobroker-data/files/info.admin
                                    6.3M    /opt/iobroker/iobroker-data/files/iot.admin
                                    173M    /opt/iobroker/iobroker-data/files/javascript.admin
                                    36K     /opt/iobroker/iobroker-data/files/lgtv.admin
                                    340K    /opt/iobroker/iobroker-data/files/mihome-vacuum.admin
                                    2.3M    /opt/iobroker/iobroker-data/files/mobile
                                    20K     /opt/iobroker/iobroker-data/files/mobile.admin
                                    112K    /opt/iobroker/iobroker-data/files/mqtt.admin
                                    72K     /opt/iobroker/iobroker-data/files/mqtt-client.admin
                                    104K    /opt/iobroker/iobroker-data/files/nina.admin
                                    48K     /opt/iobroker/iobroker-data/files/openweathermap.admin
                                    5.5G    /opt/iobroker/iobroker-data/files/ring.0
                                    40K     /opt/iobroker/iobroker-data/files/ring.admin
                                    60K     /opt/iobroker/iobroker-data/files/rpi2.admin
                                    44K     /opt/iobroker/iobroker-data/files/rtspstream.admin
                                    76K     /opt/iobroker/iobroker-data/files/senec.admin
                                    288K    /opt/iobroker/iobroker-data/files/shelly.admin
                                    56K     /opt/iobroker/iobroker-data/files/simple-api.admin
                                    44K     /opt/iobroker/iobroker-data/files/siro.admin
                                    44K     /opt/iobroker/iobroker-data/files/socketio.admin
                                    56K     /opt/iobroker/iobroker-data/files/synology.0
                                    160K    /opt/iobroker/iobroker-data/files/synology.admin
                                    204K    /opt/iobroker/iobroker-data/files/telegram.admin
                                    76K     /opt/iobroker/iobroker-data/files/tr-064.admin
                                    68K     /opt/iobroker/iobroker-data/files/tuya.admin
                                    26M     /opt/iobroker/iobroker-data/files/vis
                                    16M     /opt/iobroker/iobroker-data/files/vis.0
                                    48K     /opt/iobroker/iobroker-data/files/vis.admin
                                    20K     /opt/iobroker/iobroker-data/files/vis-bars.admin
                                    12K     /opt/iobroker/iobroker-data/files/vis-canvas-gauges.admin
                                    28K     /opt/iobroker/iobroker-data/files/vis-colorpicker.admin
                                    16K     /opt/iobroker/iobroker-data/files/vis-fancyswitch.admin
                                    12K     /opt/iobroker/iobroker-data/files/vis-history.admin
                                    24K     /opt/iobroker/iobroker-data/files/vis-hqwidgets.admin
                                    12M     /opt/iobroker/iobroker-data/files/vis-icontwo
                                    156K    /opt/iobroker/iobroker-data/files/vis-icontwo.admin
                                    3.7M    /opt/iobroker/iobroker-data/files/vis-inventwo.admin
                                    12K     /opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin
                                    24K     /opt/iobroker/iobroker-data/files/vis-justgage.admin
                                    16K     /opt/iobroker/iobroker-data/files/vis-lcars.admin
                                    52K     /opt/iobroker/iobroker-data/files/vis-map.admin
                                    36K     /opt/iobroker/iobroker-data/files/vis-metro.admin
                                    68K     /opt/iobroker/iobroker-data/files/vis-players.admin
                                    20K     /opt/iobroker/iobroker-data/files/vis-plumb.admin
                                    24K     /opt/iobroker/iobroker-data/files/vis-rgraph.admin
                                    20K     /opt/iobroker/iobroker-data/files/vis-timeandweather.admin
                                    32K     /opt/iobroker/iobroker-data/files/vis-weather.admin
                                    56K     /opt/iobroker/iobroker-data/files/weatherunderground.admin
                                    7.9M    /opt/iobroker/iobroker-data/files/web
                                    22M     /opt/iobroker/iobroker-data/files/web.admin
                                    88K     /opt/iobroker/iobroker-data/files/whatsapp-cmb.admin
                                    7.2M    /opt/iobroker/iobroker-data/files/zigbee.admin
                                    • T TinoNikol
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Da ist er Übeltäter , vom Ring Adapter kommt das
                                        TinoNikol
                                        @glasfaser
                                        Es geht du bist mein Persönlicher HELD !!!!
                                        • T TinoNikol
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @tinonikol
                                          Was mich wundert , du hast gar nicht den Adapter Ring installiert !?
