  4. Backit-UP Problem kein Backup möglich
    6.7k
36 Beiträge 3 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • T TinoNikol
    @Thomas-Braun
    Aber Zigbee Backup speichert er!?
    @tinonikol
    iobroker update -i
    Komplett zeigen!
      @tinonikol
      iobroker update -i
      Komplett zeigen!
      TinoNikol
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: stable
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.2.3    , installed 5.2.3
      Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
      Adapter    "backitup"      : 2.2.3    , installed 2.2.3
      Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "discovery"     : 2.7.3    , installed 2.7.3
      Adapter    "fb-checkpresence": 1.1.12  , installed 1.1.12
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "followthesun"  : 0.3.8    , installed 0.3.8
      Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
      Adapter    "ham"           : 4.0.2    , installed 4.0.2
      Adapter    "history"       : 1.9.14   , installed 1.9.14
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.24   , installed 1.8.24
      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
      Controller "js-controller" : 3.3.22   , installed 3.3.22
      Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
      Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "nina"          : 0.0.25   , installed 0.0.25
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "shelly"        : 4.0.7    , installed 4.0.8
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.5
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "tuya"          : 3.6.14   , installed 3.6.14
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
      Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
      • T TinoNikol
        update done
        GlasfaserG Offline
        GlasfaserG Offline
        @tinonikol
        Zeige mal , was er so hat in :
        du -hs /opt/iobroker/iobroker-data/*
        • GlasfaserG Glasfaser
          @tinonikol
          TinoNikol
          @glasfaser said in Backit-UP Problem kein Backup möglich:
          pi@raspberrypi:~ $ du -hs /opt/iobroker/iobroker-data/*
          104M    /opt/iobroker/iobroker-data/backup-objects
          9.0M    /opt/iobroker/iobroker-data/eufy-security.0
          8.0K    /opt/iobroker/iobroker-data/eufy-security.1
          5.9G    /opt/iobroker/iobroker-data/files
          28K     /opt/iobroker/iobroker-data/ham_0
          16K     /opt/iobroker/iobroker-data/history
          8.0K    /opt/iobroker/iobroker-data/iobroker.json
          8.0K    /opt/iobroker/iobroker-data/lgtv_0
          4.0K    /opt/iobroker/iobroker-data/notifications.json
          12M     /opt/iobroker/iobroker-data/objects.json
          12M     /opt/iobroker/iobroker-data/objects.json.bak
          1.7M    /opt/iobroker/iobroker-data/states.json
          1.7M    /opt/iobroker/iobroker-data/states.json.bak
          0       /opt/iobroker/iobroker-data/states.json.broken
          4.0K    /opt/iobroker/iobroker-data/synology_0
          1.3M    /opt/iobroker/iobroker-data/Tino
          27M     /opt/iobroker/iobroker-data/Tino-History
          12K     /opt/iobroker/iobroker-data/tmp
          72K     /opt/iobroker/iobroker-data/tuya_0
          92K     /opt/iobroker/iobroker-data/zigbee_0
          GlasfaserG T 2 Antworten Letzte Antwort
          • T TinoNikol
            GlasfaserG Offline
            GlasfaserG Offline
            @tinonikol sagte in Backit-UP Problem kein Backup möglich:
            Puuh der ist aber groß
            vergleich zu meinem
            401M    /opt/iobroker/iobroker-data/files
            Was speicherst du in files
            • T TinoNikol
              TinoNikol
              schrieb am zuletzt editiert von TinoNikol
              @Glasfaser
              Aber warum???
              • T TinoNikol
                @Glasfaser
                Aber warum???
                GlasfaserG Offline
                GlasfaserG Offline
                @tinonikol
                du -hs /opt/iobroker/iobroker-data/files/*
                  @tinonikol
                  TinoNikol
                  pi@raspberrypi:~ $ du -hs /opt/iobroker/iobroker-data/files/*
                  252K    /opt/iobroker/iobroker-data/files/admin.admin
                  1.2M    /opt/iobroker/iobroker-data/files/alexa2.admin
                  368K    /opt/iobroker/iobroker-data/files/backitup.admin
                  48K     /opt/iobroker/iobroker-data/files/broadlink2.admin
                  52K     /opt/iobroker/iobroker-data/files/calendar.admin
                  384K    /opt/iobroker/iobroker-data/files/cloud.admin
                  47M     /opt/iobroker/iobroker-data/files/devices.admin
                  640K    /opt/iobroker/iobroker-data/files/discovery.admin
                  100K    /opt/iobroker/iobroker-data/files/dwd.admin
                  12K     /opt/iobroker/iobroker-data/files/eufy-security.0
                  56K     /opt/iobroker/iobroker-data/files/eufy-security.admin
                  912K    /opt/iobroker/iobroker-data/files/fb-checkpresence.admin
                  1.4M    /opt/iobroker/iobroker-data/files/flot
                  12K     /opt/iobroker/iobroker-data/files/flot.admin
                  112K    /opt/iobroker/iobroker-data/files/followthesun.admin
                  676K    /opt/iobroker/iobroker-data/files/fullcalendar.admin
                  28K     /opt/iobroker/iobroker-data/files/fullybrowser.admin
                  2.3M    /opt/iobroker/iobroker-data/files/ham.admin
                  208K    /opt/iobroker/iobroker-data/files/history.admin
                  88K     /opt/iobroker/iobroker-data/files/ical.admin
                  6.2M    /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png
                  20K     /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png.admin
                  6.4M    /opt/iobroker/iobroker-data/files/icons-mfd-png
                  16K     /opt/iobroker/iobroker-data/files/icons-mfd-png.admin
                  78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                  28K     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png.admin
                  6.8M    /opt/iobroker/iobroker-data/files/icons-ultimate-png
                  20K     /opt/iobroker/iobroker-data/files/icons-ultimate-png.admin
                  2.8M    /opt/iobroker/iobroker-data/files/info.admin
                  6.3M    /opt/iobroker/iobroker-data/files/iot.admin
                  173M    /opt/iobroker/iobroker-data/files/javascript.admin
                  36K     /opt/iobroker/iobroker-data/files/lgtv.admin
                  340K    /opt/iobroker/iobroker-data/files/mihome-vacuum.admin
                  2.3M    /opt/iobroker/iobroker-data/files/mobile
                  20K     /opt/iobroker/iobroker-data/files/mobile.admin
                  112K    /opt/iobroker/iobroker-data/files/mqtt.admin
                  72K     /opt/iobroker/iobroker-data/files/mqtt-client.admin
                  104K    /opt/iobroker/iobroker-data/files/nina.admin
                  48K     /opt/iobroker/iobroker-data/files/openweathermap.admin
                  5.5G    /opt/iobroker/iobroker-data/files/ring.0
                  40K     /opt/iobroker/iobroker-data/files/ring.admin
                  60K     /opt/iobroker/iobroker-data/files/rpi2.admin
                  44K     /opt/iobroker/iobroker-data/files/rtspstream.admin
                  76K     /opt/iobroker/iobroker-data/files/senec.admin
                  288K    /opt/iobroker/iobroker-data/files/shelly.admin
                  56K     /opt/iobroker/iobroker-data/files/simple-api.admin
                  44K     /opt/iobroker/iobroker-data/files/siro.admin
                  44K     /opt/iobroker/iobroker-data/files/socketio.admin
                  56K     /opt/iobroker/iobroker-data/files/synology.0
                  160K    /opt/iobroker/iobroker-data/files/synology.admin
                  204K    /opt/iobroker/iobroker-data/files/telegram.admin
                  76K     /opt/iobroker/iobroker-data/files/tr-064.admin
                  68K     /opt/iobroker/iobroker-data/files/tuya.admin
                  26M     /opt/iobroker/iobroker-data/files/vis
                  16M     /opt/iobroker/iobroker-data/files/vis.0
                  48K     /opt/iobroker/iobroker-data/files/vis.admin
                  20K     /opt/iobroker/iobroker-data/files/vis-bars.admin
                  12K     /opt/iobroker/iobroker-data/files/vis-canvas-gauges.admin
                  28K     /opt/iobroker/iobroker-data/files/vis-colorpicker.admin
                  16K     /opt/iobroker/iobroker-data/files/vis-fancyswitch.admin
                  12K     /opt/iobroker/iobroker-data/files/vis-history.admin
                  24K     /opt/iobroker/iobroker-data/files/vis-hqwidgets.admin
                  12M     /opt/iobroker/iobroker-data/files/vis-icontwo
                  156K    /opt/iobroker/iobroker-data/files/vis-icontwo.admin
                  3.7M    /opt/iobroker/iobroker-data/files/vis-inventwo.admin
                  12K     /opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin
                  24K     /opt/iobroker/iobroker-data/files/vis-justgage.admin
                  16K     /opt/iobroker/iobroker-data/files/vis-lcars.admin
                  52K     /opt/iobroker/iobroker-data/files/vis-map.admin
                  36K     /opt/iobroker/iobroker-data/files/vis-metro.admin
                  68K     /opt/iobroker/iobroker-data/files/vis-players.admin
                  20K     /opt/iobroker/iobroker-data/files/vis-plumb.admin
                  24K     /opt/iobroker/iobroker-data/files/vis-rgraph.admin
                  20K     /opt/iobroker/iobroker-data/files/vis-timeandweather.admin
                  32K     /opt/iobroker/iobroker-data/files/vis-weather.admin
                  56K     /opt/iobroker/iobroker-data/files/weatherunderground.admin
                  7.9M    /opt/iobroker/iobroker-data/files/web
                  22M     /opt/iobroker/iobroker-data/files/web.admin
                  88K     /opt/iobroker/iobroker-data/files/whatsapp-cmb.admin
                  7.2M    /opt/iobroker/iobroker-data/files/zigbee.admin
                  • T TinoNikol
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Da ist er Übeltäter , vom Ring Adapter kommt das
                      TinoNikol
                      @glasfaser
                      Es geht du bist mein Persönlicher HELD !!!!
                      • T TinoNikol
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @tinonikol
                        Was mich wundert , du hast gar nicht den Adapter Ring installiert !?
                          @tinonikol
                          TinoNikol
                          @glasfaser
                          Ja nicht mehr machte nur Ärger
                          • T TinoNikol
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @tinonikol
                            Ok ... hat mich schon gewundert , dann hast du aber noch mehr Leichen im Keller ;)
                            Dann setzte den Thread auf [gelöst]
