  4. Backit-UP Problem kein Backup möglich
    6.8k
36 Beiträge 3 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • T TinoNikol
    Aber kein Backup!
    @tinonikol
    iobroker update -i
    • T TinoNikol
      Aber kein Backup!
      TinoNikol
      @Thomas-Braun
      Aber Zigbee Backup speichert er!?
      • T TinoNikol
        @Thomas-Braun
        @tinonikol
        iobroker update -i
        Komplett zeigen!
          @tinonikol
          iobroker update -i
          Komplett zeigen!
          TinoNikol
          pi@raspberrypi:~ $ iobroker update -i
          Used repository: stable
          hash unchanged, use cached sources
          update done
          Adapter    "admin"         : 5.2.3    , installed 5.2.3
          Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
          Adapter    "backitup"      : 2.2.3    , installed 2.2.3
          Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
          Adapter    "devices"       : 1.0.9    , installed 1.0.9
          Adapter    "discovery"     : 2.7.3    , installed 2.7.3
          Adapter    "fb-checkpresence": 1.1.12  , installed 1.1.12
          Adapter    "flot"          : 1.10.7   , installed 1.10.7
          Adapter    "followthesun"  : 0.3.8    , installed 0.3.8
          Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
          Adapter    "ham"           : 4.0.2    , installed 4.0.2
          Adapter    "history"       : 1.9.14   , installed 1.9.14
          Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
          Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
          Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Adapter    "iot"           : 1.8.24   , installed 1.8.24
          Adapter    "javascript"    : 5.2.13   , installed 5.2.13
          Controller "js-controller" : 3.3.22   , installed 3.3.22
          Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
          Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
          Adapter    "nina"          : 0.0.25   , installed 0.0.25
          Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
          Adapter    "shelly"        : 4.0.7    , installed 4.0.8
          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          Adapter    "socketio"      : 3.1.4    , installed 3.1.5
          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          Adapter    "tuya"          : 3.6.14   , installed 3.6.14
          Adapter    "vis"           : 1.4.5    , installed 1.4.5
          Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
          Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
          Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
          Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
          Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
          Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
          Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
          Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
          Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
          Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
          Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
          Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
          Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
          Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
          Adapter    "web"           : 3.4.9    , installed 3.4.9
          Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
          • T TinoNikol
            update done
            GlasfaserG Offline
            GlasfaserG Offline
            @tinonikol
            Zeige mal , was er so hat in :
            du -hs /opt/iobroker/iobroker-data/*
            • GlasfaserG Glasfaser
              @tinonikol
              TinoNikol
              @glasfaser said in Backit-UP Problem kein Backup möglich:
              pi@raspberrypi:~ $ du -hs /opt/iobroker/iobroker-data/*
              104M    /opt/iobroker/iobroker-data/backup-objects
              9.0M    /opt/iobroker/iobroker-data/eufy-security.0
              8.0K    /opt/iobroker/iobroker-data/eufy-security.1
              5.9G    /opt/iobroker/iobroker-data/files
              28K     /opt/iobroker/iobroker-data/ham_0
              16K     /opt/iobroker/iobroker-data/history
              8.0K    /opt/iobroker/iobroker-data/iobroker.json
              8.0K    /opt/iobroker/iobroker-data/lgtv_0
              4.0K    /opt/iobroker/iobroker-data/notifications.json
              12M     /opt/iobroker/iobroker-data/objects.json
              12M     /opt/iobroker/iobroker-data/objects.json.bak
              1.7M    /opt/iobroker/iobroker-data/states.json
              1.7M    /opt/iobroker/iobroker-data/states.json.bak
              0       /opt/iobroker/iobroker-data/states.json.broken
              4.0K    /opt/iobroker/iobroker-data/synology_0
              1.3M    /opt/iobroker/iobroker-data/Tino
              27M     /opt/iobroker/iobroker-data/Tino-History
              12K     /opt/iobroker/iobroker-data/tmp
              72K     /opt/iobroker/iobroker-data/tuya_0
              92K     /opt/iobroker/iobroker-data/zigbee_0
              GlasfaserG T 2 Antworten Letzte Antwort
              • T TinoNikol
                GlasfaserG Offline
                GlasfaserG Offline
                @tinonikol sagte in Backit-UP Problem kein Backup möglich:
                Puuh der ist aber groß
                vergleich zu meinem
                401M    /opt/iobroker/iobroker-data/files
                Was speicherst du in files
                • T TinoNikol
                  TinoNikol
                  schrieb am zuletzt editiert von TinoNikol
                  @Glasfaser
                  Aber warum???
                  • T TinoNikol
                    @Glasfaser
                    Aber warum???
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @tinonikol
                    du -hs /opt/iobroker/iobroker-data/files/*
                      @tinonikol
                      TinoNikol
                      pi@raspberrypi:~ $ du -hs /opt/iobroker/iobroker-data/files/*
                      252K    /opt/iobroker/iobroker-data/files/admin.admin
                      1.2M    /opt/iobroker/iobroker-data/files/alexa2.admin
                      368K    /opt/iobroker/iobroker-data/files/backitup.admin
                      48K     /opt/iobroker/iobroker-data/files/broadlink2.admin
                      52K     /opt/iobroker/iobroker-data/files/calendar.admin
                      384K    /opt/iobroker/iobroker-data/files/cloud.admin
                      47M     /opt/iobroker/iobroker-data/files/devices.admin
                      640K    /opt/iobroker/iobroker-data/files/discovery.admin
                      100K    /opt/iobroker/iobroker-data/files/dwd.admin
                      12K     /opt/iobroker/iobroker-data/files/eufy-security.0
                      56K     /opt/iobroker/iobroker-data/files/eufy-security.admin
                      912K    /opt/iobroker/iobroker-data/files/fb-checkpresence.admin
                      1.4M    /opt/iobroker/iobroker-data/files/flot
                      12K     /opt/iobroker/iobroker-data/files/flot.admin
                      112K    /opt/iobroker/iobroker-data/files/followthesun.admin
                      676K    /opt/iobroker/iobroker-data/files/fullcalendar.admin
                      28K     /opt/iobroker/iobroker-data/files/fullybrowser.admin
                      2.3M    /opt/iobroker/iobroker-data/files/ham.admin
                      208K    /opt/iobroker/iobroker-data/files/history.admin
                      88K     /opt/iobroker/iobroker-data/files/ical.admin
                      6.2M    /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png
                      20K     /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png.admin
                      6.4M    /opt/iobroker/iobroker-data/files/icons-mfd-png
                      16K     /opt/iobroker/iobroker-data/files/icons-mfd-png.admin
                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                      28K     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png.admin
                      6.8M    /opt/iobroker/iobroker-data/files/icons-ultimate-png
                      20K     /opt/iobroker/iobroker-data/files/icons-ultimate-png.admin
                      2.8M    /opt/iobroker/iobroker-data/files/info.admin
                      6.3M    /opt/iobroker/iobroker-data/files/iot.admin
                      173M    /opt/iobroker/iobroker-data/files/javascript.admin
                      36K     /opt/iobroker/iobroker-data/files/lgtv.admin
                      340K    /opt/iobroker/iobroker-data/files/mihome-vacuum.admin
                      2.3M    /opt/iobroker/iobroker-data/files/mobile
                      20K     /opt/iobroker/iobroker-data/files/mobile.admin
                      112K    /opt/iobroker/iobroker-data/files/mqtt.admin
                      72K     /opt/iobroker/iobroker-data/files/mqtt-client.admin
                      104K    /opt/iobroker/iobroker-data/files/nina.admin
                      48K     /opt/iobroker/iobroker-data/files/openweathermap.admin
                      5.5G    /opt/iobroker/iobroker-data/files/ring.0
                      40K     /opt/iobroker/iobroker-data/files/ring.admin
                      60K     /opt/iobroker/iobroker-data/files/rpi2.admin
                      44K     /opt/iobroker/iobroker-data/files/rtspstream.admin
                      76K     /opt/iobroker/iobroker-data/files/senec.admin
                      288K    /opt/iobroker/iobroker-data/files/shelly.admin
                      56K     /opt/iobroker/iobroker-data/files/simple-api.admin
                      44K     /opt/iobroker/iobroker-data/files/siro.admin
                      44K     /opt/iobroker/iobroker-data/files/socketio.admin
                      56K     /opt/iobroker/iobroker-data/files/synology.0
                      160K    /opt/iobroker/iobroker-data/files/synology.admin
                      204K    /opt/iobroker/iobroker-data/files/telegram.admin
                      76K     /opt/iobroker/iobroker-data/files/tr-064.admin
                      68K     /opt/iobroker/iobroker-data/files/tuya.admin
                      26M     /opt/iobroker/iobroker-data/files/vis
                      16M     /opt/iobroker/iobroker-data/files/vis.0
                      48K     /opt/iobroker/iobroker-data/files/vis.admin
                      20K     /opt/iobroker/iobroker-data/files/vis-bars.admin
                      12K     /opt/iobroker/iobroker-data/files/vis-canvas-gauges.admin
                      28K     /opt/iobroker/iobroker-data/files/vis-colorpicker.admin
                      16K     /opt/iobroker/iobroker-data/files/vis-fancyswitch.admin
                      12K     /opt/iobroker/iobroker-data/files/vis-history.admin
                      24K     /opt/iobroker/iobroker-data/files/vis-hqwidgets.admin
                      12M     /opt/iobroker/iobroker-data/files/vis-icontwo
                      156K    /opt/iobroker/iobroker-data/files/vis-icontwo.admin
                      3.7M    /opt/iobroker/iobroker-data/files/vis-inventwo.admin
                      12K     /opt/iobroker/iobroker-data/files/vis-jqui-mfd.admin
                      24K     /opt/iobroker/iobroker-data/files/vis-justgage.admin
                      16K     /opt/iobroker/iobroker-data/files/vis-lcars.admin
                      52K     /opt/iobroker/iobroker-data/files/vis-map.admin
                      36K     /opt/iobroker/iobroker-data/files/vis-metro.admin
                      68K     /opt/iobroker/iobroker-data/files/vis-players.admin
                      20K     /opt/iobroker/iobroker-data/files/vis-plumb.admin
                      24K     /opt/iobroker/iobroker-data/files/vis-rgraph.admin
                      20K     /opt/iobroker/iobroker-data/files/vis-timeandweather.admin
                      32K     /opt/iobroker/iobroker-data/files/vis-weather.admin
                      56K     /opt/iobroker/iobroker-data/files/weatherunderground.admin
                      7.9M    /opt/iobroker/iobroker-data/files/web
                      22M     /opt/iobroker/iobroker-data/files/web.admin
                      88K     /opt/iobroker/iobroker-data/files/whatsapp-cmb.admin
                      7.2M    /opt/iobroker/iobroker-data/files/zigbee.admin
                      • T TinoNikol
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Da ist er Übeltäter , vom Ring Adapter kommt das
                          TinoNikol
                          @glasfaser
                          Es geht du bist mein Persönlicher HELD !!!!
                          • T TinoNikol
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @tinonikol
                            Was mich wundert , du hast gar nicht den Adapter Ring installiert !?
                              @tinonikol
                              TinoNikol
                              @glasfaser
                              Ja nicht mehr machte nur Ärger
                              • T TinoNikol
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @tinonikol
                                Ok ... hat mich schon gewundert , dann hast du aber noch mehr Leichen im Keller ;)
                                Dann setzte den Thread auf [gelöst]
