  4. Backit-UP Problem kein Backup möglich
    6.7k
36 Beiträge 3 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • T TinoNikol
    pi@raspberrypi:~ $ iobroker status
    Objects type: file
    States  type: file
    @tinonikol
    free -ht --mega
      @tinonikol
      free -ht --mega
      TinoNikol
      @thomas-braun said in Backit-UP Problem kein Backup möglich:
      free -ht --mega
      pi@raspberrypi:~ $ free -ht --mega
      Mem:           3.8G        1.0G        2.5G        8.0M        272M        3.0G
      Swap:           99M          0B         99M
      Total:         3.9G        1.0G        2.6G
      pi@raspberrypi:~ $
      • T TinoNikol
        free -ht --mega
        Swap:           99M          0B         99M
        pi@raspberrypi:~ $
        @tinonikol
        which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          @tinonikol
          TinoNikol
          pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.4
          v12.22.4
          6.14.14
          pi
          /home/pi
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
          Reading package lists... Done
          Building dependency tree
          85 packages can be upgraded. Run 'apt list --upgradable' to see them.
          nodejs:
            Installed: 12.22.4-1nodesource1
            Candidate: 12.22.9-deb-1nodesource1
            Version table:
               12.22.9-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
           *** 12.22.4-1nodesource1 100
               10.24.0~dfsg-1~deb10u1 500
          • T TinoNikol
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.4
            v12.22.4
            6.14.14
            pi
            /home/pi
            nodejs:
              Version table:
            @tinonikol
            iobroker stop
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            Ich würde aber danach auf nodeJS 14 springen.
              @tinonikol
              iobroker stop
              sudo apt update
              sudo reboot
              TinoNikol
              sudo reboot
              pi@raspberrypi:~ $ iob backup
              host.raspberrypi 7509 states saved
              host.raspberrypi 8657 objects saved
              internal/buffer.js:950
              class FastBuffer extends Uint8Array {}
              RangeError: Array buffer allocation failed
                  at arrayBufferConstructor_DoNotInitialize (<anonymous>)
                  at new Uint8Array (<anonymous>)
                  at new FastBuffer (internal/buffer.js:950:1)
                  at fromArrayLike (buffer.js:501:10)
                  at fromObject (buffer.js:509:12)
                  at Function.from (buffer.js:318:15)
                  at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemServerRedis.js:452:60)
                  at RedisHandler.emit (events.js:314:20)
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js:100:37)
                  at processImmediate (internal/timers.js:461:21)
              Selbes Problem
              • T TinoNikol
                sudo reboot
                Selbes Problem
                @tinonikol
                node14 installiert?
                  @tinonikol
                  node14 installiert?
                  TinoNikol
                  v12.22.9
                  • T TinoNikol
                    v12.22.9
                    @tinonikol
                    Komplette Ein- und Ausgaben.
                      @tinonikol
                      TinoNikol
                      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && wh                                oami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nod                                ejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.9
                      v12.22.9
                      6.14.15
                      pi
                      /home/pi
                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      All packages are up to date.
                      nodejs:
                        Installed: 12.22.9-deb-1nodesource1
                        Version table:
                       *** 12.22.9-deb-1nodesource1 500
                      • T TinoNikol
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v12.22.9
                        v12.22.9
                        6.14.15
                        pi
                        /home/pi
                        nodejs:
                          Version table:
                        @tinonikol
                        iobroker update -i
                        Und spring auf node14.
                          @tinonikol
                          iobroker update -i
                          TinoNikol
                          Geht auch nicht!
                          pi@raspberrypi:~ $ node -v
                          v14.18.3
                          T Thomas BraunT 2 Antworten Letzte Antwort
                          • T TinoNikol
                            Geht auch nicht!
                            v14.18.3
                            TinoNikol
                            @Thomas-Braun
                            internal/buffer.js:958
                                super(bufferOrLength, byteOffset, length);
                                at new FastBuffer (internal/buffer.js:958:5)
                                at fromArrayLike (buffer.js:505:10)
                                at fromObject (buffer.js:513:12)
                                at Function.from (buffer.js:322:15)
                                at RedisHandler.emit (events.js:400:28)
                                at processImmediate (internal/timers.js:464:21)
                            • T TinoNikol
                              Geht auch nicht!
                              v14.18.3
                              @tinonikol sagte in Backit-UP Problem kein Backup möglich:
                              Geht auch nicht!
                              Ist keine Fehlermeldung.
                              iobroker update -i
                                Geht auch nicht!
                                iobroker update -i
                                TinoNikol
                                Aber kein Backup!
                                Thomas BraunT T 2 Antworten Letzte Antwort
                                • T TinoNikol
                                  Aber kein Backup!
                                  @tinonikol
                                  iobroker update -i
                                  • T TinoNikol
                                    Aber kein Backup!
                                    TinoNikol
                                    @Thomas-Braun
                                    Aber Zigbee Backup speichert er!?
                                    • T TinoNikol
                                      @Thomas-Braun
                                      @tinonikol
                                      iobroker update -i
                                      Komplett zeigen!
                                        @tinonikol
                                        iobroker update -i
                                        Komplett zeigen!
                                        TinoNikol
                                        pi@raspberrypi:~ $ iobroker update -i
                                        Used repository: stable
                                        hash unchanged, use cached sources
                                        update done
                                        Adapter    "admin"         : 5.2.3    , installed 5.2.3
                                        Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                                        Adapter    "backitup"      : 2.2.3    , installed 2.2.3
                                        Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
                                        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                                        Adapter    "devices"       : 1.0.9    , installed 1.0.9
                                        Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                                        Adapter    "fb-checkpresence": 1.1.12  , installed 1.1.12
                                        Adapter    "flot"          : 1.10.7   , installed 1.10.7
                                        Adapter    "followthesun"  : 0.3.8    , installed 0.3.8
                                        Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
                                        Adapter    "ham"           : 4.0.2    , installed 4.0.2
                                        Adapter    "history"       : 1.9.14   , installed 1.9.14
                                        Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                                        Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
                                        Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                                        Adapter    "info"          : 1.9.8    , installed 1.9.8
                                        Adapter    "iot"           : 1.8.24   , installed 1.8.24
                                        Adapter    "javascript"    : 5.2.13   , installed 5.2.13
                                        Controller "js-controller" : 3.3.22   , installed 3.3.22
                                        Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
                                        Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
                                        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                                        Adapter    "nina"          : 0.0.25   , installed 0.0.25
                                        Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                                        Adapter    "shelly"        : 4.0.7    , installed 4.0.8
                                        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                                        Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                                        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                                        Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                                        Adapter    "tuya"          : 3.6.14   , installed 3.6.14
                                        Adapter    "vis"           : 1.4.5    , installed 1.4.5
                                        Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                                        Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                                        Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                                        Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                                        Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                                        Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
                                        Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
                                        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                                        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                                        Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                                        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                                        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                                        Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                                        Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                                        Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                                        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                                        Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
                                        Adapter    "web"           : 3.4.9    , installed 3.4.9
                                        Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
                                        • T TinoNikol
                                          update done
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @tinonikol
                                          Zeige mal , was er so hat in :
                                          du -hs /opt/iobroker/iobroker-data/*
