  4. Zufallsgesteuerte Lampe
    5.5k
43 Beiträge 8 Kommentatoren 6.6k Aufrufe 8 Beobachtet
  • D Dragon
    Habe es einfach fix nachgebaut...
      <variables>
        <variable id="3wfh1q0Y%)oWzNS3z05I">cnt</variable>
        <variable type="interval" id="Intervall">Intervall</variable>
      </variables>
      <block type="astro" id="B(R9I]6b#hfxw5+Q#1t%" x="-62" y="38">
        <field name="TYPE">sunrise</field>
        <field name="OFFSET">0</field>
        <statement name="STATEMENT">
          <block type="timeouts_clearinterval" id="^qo0.eRIR}F%mD_H(V[l">
            <field name="NAME">Intervall</field>
          </block>
        </statement>
        <next>
          <block type="astro" id="zqF{-`,gtQC!sKjmAOdD">
            <field name="TYPE">sunset</field>
              <block type="controls_if" id="9,X]gkj%/sV;OUBt/Us(">
                <value name="IF0">
                  <block type="logic_negate" id=".25J:qS?|;G71+YCJfcD">
                    <value name="BOOL">
                      <block type="get_value" id="VR!iGZx4;d]3vxlmRMl,">
                        <field name="OID">javascript.0.EigeneDatenpunkte.Person_anwesend</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="procedures_callnoreturn" id="z?:T8x8md;7aEI}zneO+">
                    <mutation name="ZufallLicht"></mutation>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
              <block type="on_ext" id="}~ZMD9[{xrsRJGY#FAF0">
                <value name="OID0">
                  <shadow type="field_oid" id="E*HX]_ht%B}{bt--!`y`">
                    <field name="oid">javascript.0.EigeneDatenpunkte.Person_anwesend</field>
                  </shadow>
                </value>
                  <block type="controls_if" id="%3AV$Q@uVu=3!,)*)h`L">
                    <value name="IF0">
                      <block type="on_source" id="Mz`X)+Vv+=8Al2)c0=uz">
                      </block>
                    </value>
                      <block type="timeouts_clearinterval" id="|Nu5^Y?o)wqe;9;O]I}6">
                      </block>
                    </statement>
                    <value name="IF1">
                      <block type="time_compare_ex" id="8nW;cKjt*m*.~rpnB]}W">
                        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                        <field name="USE_ACTUAL_TIME">TRUE</field>
                        <field name="OPTION">not between</field>
                        <value name="START_TIME">
                          <shadow type="text" id="k=u8nlP2f|?@d%0g@yB~">
                            <field name="TEXT">12:00</field>
                          </shadow>
                          <block type="time_astro" id="GkfGvq68bEH-/=ff,.[X">
                          </block>
                        </value>
                        <value name="END_TIME">
                          <shadow type="text" id=";[HSbpaytMYNoww^,Lb0">
                            <field name="TEXT">18:00</field>
                          </shadow>
                          <block type="time_astro" id="Lk`AG]vW|5H5x3ET#qUi">
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO1">
                      <block type="procedures_callnoreturn" id="wM}2T}bME):eulf(HUQR">
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="procedures_defnoreturn" id="1}JoNwFetn#r.CU39RtM" x="463" y="13">
        <field name="NAME">ZufallLicht</field>
        <statement name="STACK">
          <block type="variables_set" id="U{8oI;E.s-(_J0F.w:=B">
            <field name="VAR" id="3wfh1q0Y%)oWzNS3z05I">cnt</field>
            <value name="VALUE">
              <block type="math_random_int" id="x:^cNx~}gNdOFNC,~04K">
                <value name="FROM">
                  <shadow type="math_number" id="E=ZW}7A,#Z|(2R;oQN,q">
                    <field name="NUM">1</field>
                  </shadow>
                </value>
                <value name="TO">
                  <shadow type="math_number" id="zJ,Xa=ns/3(qoI:F)J72">
                    <field name="NUM">100</field>
                  </shadow>
                </value>
              </block>
            </value>
            <next>
              <block type="timeouts_setinterval" id="{(_qCRR:vF=x-P9ZOBgz">
                <field name="INTERVAL">1</field>
                <field name="UNIT">min</field>
                  <block type="math_change" id="wvPH.|%4x-sOPwaVxnA9">
                    <value name="DELTA">
                      <shadow type="math_number" id="){;`g8Z_N#54*-yUn8Br">
                        <field name="NUM">-1</field>
                      </shadow>
                    </value>
                    <next>
                      <block type="controls_if" id="mz^_Tl.0x#*zNMmwutkc">
                        <value name="IF0">
                          <block type="logic_compare" id="`O=P*PWlqtEn|PNb.Q,q">
                            <field name="OP">LTE</field>
                            <value name="A">
                              <block type="variables_get" id="bqF5QD|~|,n1$Q`sfB|(">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="PM-6)A`h@Ez0k_on35bn">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="toggle" id="N$Qd]T]5OGpMm.$HM7$A">
                            <next>
                              <block type="variables_set" id="/gXrXw6D^yKHI){{8m4r">
                                  <block type="math_random_int" id="p$DDu0aGm~@V+]bLQkm+">
                                    <value name="FROM">
                                      <shadow type="math_number" id="I_NJz`G/3BV@!wAziy7P">
                                      </shadow>
                                    </value>
                                    <value name="TO">
                                      <shadow type="math_number" id="I-`+q/NA;NRNe_JU@cA$">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    gluecksmann
    @dragon
    Bekomme eine Fehlermeldung wenn ich es importieren will...
    paul53P S G 3 Antworten Letzte Antwort
    • G gluecksmann
      @dragon
      @gluecksmann sagte: Bekomme eine Fehlermeldung wenn ich es importieren will...
      Ich nicht. Muss also am Markieren des zu kopierenden Bereiches liegen.
      G 1 Antwort Letzte Antwort
      • G gluecksmann
        @dragon
        smarthome2020
        @gluecksmann
        Bei mir geht das Reinkopieren auch.
        Danke für das Blockly
          gluecksmann
          Was kann man denn da falsch machen... markiere das alles, kopiere es, und sage dann im Blockly Blöcke importieren
          • G gluecksmann
            da ich noch nen Zwischenstecker über habe, dachte ich daran durch eine Zufallsgesteuerte Lampe etwas Anwesenheit vorzutäuschen...sollte man mal nicht da sein...
            Natürlich nur wenn es dunkel ist... wie realisiere ich das EINFACH?
            David G.D Online
            David G.D Online
            David G.
            @gluecksmann
            So mache ich es.
            Falls mal noch ein paar Lampen bei kommen.
            30min vor Sonnenuntergang wird eine zufällige Zeit (Spanne vorgegeben) ermittelt wann die Simulation beginnt.
            Wenn es dann los geht, werden die Lampen in willkürlicher Reihenfolge in zufälligen Abständen
            (auch hier ist die Spanne vorgegeben) eingeschaltet.
            • G gluecksmann
              @dragon
              gluecksmann
              schrieb am zuletzt editiert von gluecksmann
              @gluecksmann
              jetzt hat der Import funktioniert ...was macht der Datenpunkt anwesenheit? wird das geprüft ob wer da ist?
              • G gluecksmann
                @gluecksmann
                @gluecksmann sagte: was macht der Datenpunkt anwesenheit? wird das geprüft ob wer da ist?
                Ja, wenn jemand anwesend ist, braucht es keine Anwesenheitssimulation.
                  David G.D Online
                  David G.D Online
                  David G.
                  Außer man ist zu faul zum Licht einschalten.
                  Hab die immer am laufen 🤣.
                  Haben abends eigentlich nur kleine Lichter an die es gemütlich machen. Da geht das ^^.
                  Fügt sich gut in unsern Alltag ein 😁.
                  • David G.D David G.
                    Meister MopperM Offline
                    Meister Mopper
                    Im Fall, dass alle Lampen beim Start der Automation aus sind, schalten alle Lampen immer gleich, also an oder aus.
                    Es wäre ja noch genialer, wenn die Lampen zufällig an oder aus gingen, so dass von außen wirklich der Eindruck entsteht, dass Leben im Haus ist.
                    Hat jemand eine Idee, wie man das realisieren könnte?
                    Proxmox und HA ...
                    Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                      David G.D Online
                      David G.D Online
                      David G.
                      @meister-mopper
                      Mein Post (3-4 Beiträge) weiter oben.
                      Mehr Zufall geht denke nicht.
                      Zum ausschalten habe ich leicht angepasst (eigener Datenpunkt zum de- aktivieren und anderen Trigger und eigene Funktion) das selbe Skript.
                      Bei den Lampen die berücksichtigt werden habe ich eine Funktion unter den Objekten vergeben nach denen das Skript sucht.
                        @meister-mopper
                        Meister Mopper
                        @david-g
                        Die Logik Deines Scripts erschließt sich mir leider noch nicht. Wo befinden sich im Script die zu schaltenden Lampen?
                        Proxmox und HA ...
                          @david-g
                          David G.D Online
                          David G.D Online
                          David G.
                          @meister-mopper
                          Im "id vom selektor".
                          Musst unter den Objekten im Iobroker eine Funktion vergeben (vorher anlegen).
                          Im Beispiel "abend_auto_an".
                          Die nimmt das Skript dann alle.
                          Ist leichter als alles im Skript zu pflegen.
                            @meister-mopper
                            Meister Mopper
                            @david-g sagte in Zufallsgesteuerte Lampe:
                            Genau das kenne/verstehe ich nicht. Wie macht man das konkret?
                            Proxmox und HA ...
                              David G.D Online
                              David G.D Online
                              David G.
                              @meister-mopper
                              Hier eine Funktion anlegen
                              Und hier vergeben
                              EDIT:
                              Vergeben kannst du die Funktionen auch im ersten Bild schon.
                              EDIT 2:
                              Nutze ich für recht viel die Funktion.
                              Kann man auch im Trigger verwenden.
                              Hab zB eine Funktion für die Alarmanlage.
                              So kann ich alle Kontakte überwachen ohne jeden in Blockly aufzunehmen.
                              • Meister MopperM Offline
                                Meister Mopper
                                schrieb am zuletzt editiert von Meister Mopper
                                @david-g
                                Ah ok, mit aliases habe ich bisher noch nichts gemacht. Bei den Aufzählungen habe ich einige Lampen unter FuncLight.
                                Die will ich aber nicht alle in eine Zufallsschaltung einbeziehen.
                                Danke, da muss ich mich erst noch reinfuchsen. Das liest sich sehr interessant.
                                Proxmox und HA ...
                                  @david-g
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  @meister-mopper
                                  Alias braucht man da für nicht. Geht mit jedem Datenpunkt.
                                  Datenpunkte können auch mehrere Funktionen zugeordnet sein.
                                  In FuncLight habe ich alle Lampen. Die Lampen die bei der Simulation angehen sollen zusätzlich noch die entsprechende Funktion.
                                  Manche Lampen haben bei mir funclight, abend_auto_an, abend_auto_aus und noch eine für Lampen die eingeschaltet werden sollen wenn die Alarmanlage auslöst.
                                    @meister-mopper
                                    Meister Mopper
                                    @david-g
                                    Super, dass man sie in verschiedene Funktionen einbinden kann, wusste ich nicht. Das eröffnet ja ungeahnte Möglichkeiten!
                                    Proxmox und HA ...
                                      @david-g
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      @meister-mopper
                                      Oh ja, als @paul53 mir das mal gezeigt hat hab ich selbiges gedacht.
                                      Mittlerweile auch echt viel drüber am laufen.
                                      Finde eben auch praktisch, dass man es als Trigger und in einem Skript verwenden kann.
                                      Meister MopperM 2 Antworten Letzte Antwort
                                        @meister-mopper
                                        Meister Mopper
                                        @david-g
                                        Na dann mal in die Hände gespuckt. Danke Dir nochmal 😀
                                        Proxmox und HA ...
                                          @meister-mopper
                                          Meister Mopper
                                          @david-g
                                          Dieses Element ist bei mir nicht vorhanden
                                          Ich habe nur das
                                          Proxmox und HA ...
