  4. [Gelöst] Brauche mal Hilfe iobroker schreibt zu viele in log
    1.0k
    6.1k
15 Beiträge 3 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • R Rattenfänger
    Ich habe ein problem wo ich nicht weiter weiß
    iobroker schreibt so viel in den log rein das mir meine vm am abstürzen ist nach einigen stunden
    villeicht kann mir jemand helfen das problem zu lösen bitte habt nachsicht bin recht neu dabei was iobroker betrifft und muss noch viel lernen
    warn: javascript.0
    2022-01-24 09:23:50.185 - warn: javascript.0 (1226) You are assigning a number to the state "0_userdata.0.Growbox.Co2" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2022-01-24 09:23:50.188 - warn: javascript.0 (1226) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1439:20)
    2022-01-24 09:23:50.188 - warn: javascript.0 (1226) at script.js.Fridgegrow:7:7
    2022-01-24 09:23:50.188 - warn: javascript.0 (1226) at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
    2022-01-24 09:23:50.188 - warn: javascript.0 (1226) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    2022-01-24 09:23:50.188 - warn: javascript.0 (1226) at Request.emit (events.js:314:20)
    2022-01-24 09:23:50.188 - warn: javascript.0 (1226) at Request.EventEmitter.emit (domain.js:483:12)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at Request.emit (events.js:314:20)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at Request.EventEmitter.emit (domain.js:483:12)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at Object.onceWrapper (events.js:420:28)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at IncomingMessage.emit (events.js:326:22)
    2022-01-24 09:23:50.189 - warn: javascript.0 (1226) at IncomingMessage.EventEmitter.emit (domain.js:483:12)
    2022-01-24 09:23:50.190 - warn: javascript.0 (1226) at endReadableNT (_stream_readable.js:1241:12)
    2022-01-24 09:23:50.190 - warn: javascript.0 (1226) at processTicksAndRejections (internal/process/task_queues.js:84:21)
    2022-01-24 09:23:50.190 - warn: javascript.0 (1226) You are assigning a number to the state "0_userdata.0.Growbox.Luftfeuchtigkeit" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    info: influxdb.0
    2022-01-24 09:23:55.328 - warn: influxdb.0 (1575) Error on writePoint("{"value":64.4814224243164,"time":"2022-01-24T09:23:49.656Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"engine: error writing WAL entry: write /data/influxdb/wal/telegraf/autogen/40/_00009.wal: no space left on device"}
    / "{\"error\":\"engine: error writing WAL entry: write /data/influxdb/wal/telegraf/autogen/40/_00009.wal: no space left on device\"}\n"
    2022-01-24 09:23:55.329 - info: influxdb.0 (1575) Add point that had error for 0_userdata.0.Growbox.Luftfeuchtigkeit to buffer again, error-count=1
    2022-01-24 09:23:55.336 - warn: influxdb.0 (1575) Error on writePoint("{"value":64.4814224243164,"time":"2022-01-24T09:23:49.656Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"engine: error writing WAL entry: write /data/influxdb/wal/telegraf/autogen/40/_00009.wal: no space left on device"}
    2022-01-24 09:23:55.336 - info: influxdb.0 (1575) Add point that had error for 0_userdata.0.Growbox.Luftfeuchtigkeit to buffer again, error-count=2
    2022-01-24 09:23:55.341 - warn: influxdb.0 (1575) Error on writePoint("{"value":64.4814224243164,"time":"2022-01-24T09:23:49.656Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"engine: error writing WAL entry: write /data/influxdb/wal/telegraf/autogen/40/_00009.wal: no space left on device"}
    2022-01-24 09:23:55.341 - info: influxdb.0 (1575) Add point that had error for 0_userdata.0.Growbox.Luftfeuchtigkeit to buffer again, error-count=3
    2022-01-24 09:23:55.346 - warn: influxdb.0 (1575) Error on writePoint("{"value":64.4814224243164,"time":"2022-01-24T09:23:49.656Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"engine: error writing WAL entry: write /data/influxdb/wal/telegraf/autogen/40/_00009.wal: no space left on device"}
    2022-01-24 09:23:55.347 - info: influxdb.0 (1575) Add point that had error for 0_userdata.0.Growbox.Luftfeuchtigkeit to buffer again, error-count=4
    2022-01-24 09:23:55.351 - warn: influxdb.0 (1575) Error on writePoint("{"value":64.4814224243164,"time":"2022-01-24T09:23:49.656Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"engine: error writing WAL entry: write /data/influxdb/wal/telegraf/autogen/40/_00009.wal: no space left on device"}
    2022-01-24 09:23:55.352 - info: influxdb.0 (1575) Add point that had error for 0_userdata.0.Growbox.Luftfeuchtigkeit to buffer again, error-count=5
    ich bedanke mich schon mal im vorraus
    HomoranH Offline
    HomoranH Offline
    @rattenfänger sagte in Brauche mal Hilfe iobroker schreibt zu viele in log:
    Ich fürchte du verwechselst da Ursache und Wirkung.
    die VM stürzt wahrscheinlich ab, weil da was falsch läuft.
    Und das steht im log.
    Bitte die relevanten Teile davon in code-tags posten.
    Eine .txt Datei kann und will ich am Handy nicht öffnen
    R 1 Antwort Letzte Antwort
      Rattenfänger
      @homoran hab das ganze mal edit
      • R Rattenfänger
        warn: javascript.0
        info: influxdb.0
        HomoranH Offline
        HomoranH Offline
        @Rattenfänger
        Du liest das log aber auch mal zum Zeitvertreib?
        dann stürzt er natürlich auch ab
          @Rattenfänger
          Rattenfänger
          kann ich im iobroker den speicher ort ändern ?
          • R Rattenfänger
            warn: javascript.0
            info: influxdb.0
            HomoranH Offline
            HomoranH Offline
            warn: javascript.0
            und da lese ich dir mal vor:
              warn: javascript.0
              Rattenfänger
              @homoran das mit please fix your code habe ich schon geändert
              • R Rattenfänger
                HomoranH Offline
                HomoranH Offline
                wer, wie, was???
                was sagt df -h?
                  wer, wie, was???
                  was sagt df -h?
                  Rattenfänger
                  root@iobroker:~# df -h
                  Filesystem                         Size  Used Avail Use% Mounted on
                  udev                               1,9G     0  1,9G   0% /dev
                  tmpfs                              393M  1,2M  392M   1% /run
                  /dev/mapper/ubuntu--vg-ubuntu--lv   12G  9,8G  1,2G  90% /
                  tmpfs                              2,0G  4,0K  2,0G   1% /dev/shm
                  tmpfs                              5,0M     0  5,0M   0% /run/lock
                  tmpfs                              2,0G     0  2,0G   0% /sys/fs/cgroup
                  /dev/loop0                          56M   56M     0 100% /snap/core18/2253
                  /dev/loop1                          56M   56M     0 100% /snap/core18/2284
                  /dev/loop2                          62M   62M     0 100% /snap/core20/1270
                  /dev/loop3                          68M   68M     0 100% /snap/lxd/21835
                  /dev/sda2                          976M  208M  702M  23% /boot
                  /dev/loop4                          44M   44M     0 100% /snap/snapd/14295
                  /dev/loop5                          33M   33M     0 100% /snap/snapd/12704
                  /dev/sda1                          511M  5,3M  506M   2% /boot/efi
                  /dev/loop6                          71M   71M     0 100% /snap/lxd/21029
                  tmpfs                              393M     0  393M   0% /run/user/0
                  • R Rattenfänger
                    HomoranH Offline
                    HomoranH Offline
                    @rattenfänger Was ist das denn für eine Installation???
                      Rattenfänger
                      @homoran ubuntu server 20
                      root@iobroker:~# lsblk
                      ,NAME                      MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
                      loop0                       7:0    0 55,5M  1 loop /snap/core18/2253
                      loop1                       7:1    0 55,5M  1 loop /snap/core18/2284
                      loop2                       7:2    0 61,9M  1 loop /snap/core20/1270
                      loop3                       7:3    0 67,2M  1 loop /snap/lxd/21835
                      loop4                       7:4    0 43,3M  1 loop /snap/snapd/14295
                      loop5                       7:5    0 32,3M  1 loop /snap/snapd/12704
                      loop6                       7:6    0 70,3M  1 loop /snap/lxd/21029
                      sda                         8:0    0  300G  0 disk
                      ├─sda1                      8:1    0  512M  0 part /boot/efi
                      ├─sda2                      8:2    0    1G  0 part /boot
                      └─sda3                      8:3    0 23,5G  0 part
                        └─ubuntu--vg-ubuntu--lv 253:0    0 11,8G  0 lvm  /
                      sr0                        11:0    1  1,2G  0 rom
                      • R Rattenfänger
                        crunchipC Offline
                        crunchipC Offline
                        @rattenfänger Dann solltest du dein Speicherplatzproblem beheben.
                        https://wiki.ubuntuusers.de/Logical Volume Manager/
                          Rattenfänger
                          @crunchip fehler ist behoben
                          Vielen Lieben dank für die hilfe an euch zwei
                          • R Rattenfänger
                            crunchipC Offline
                            crunchipC Offline
                            @rattenfänger gibst du uns auch noch die Lösung kund?
                            Desweiteren kannst du im ersten Beitrag editieren und ein [gelöst] davor schreiben
                              Rattenfänger
                              @crunchip
                              ich musste unter objekte den wert von string in number wechseln und iobroker einmal neustarten seit dem hat der kein fehler meh ins log geschrieben
                              dazu habe ich dann die platte vergrößert
