  4. Javascript Adapter rot
    5.5k
91 Beiträge 4 Kommentatoren 11.6k Aufrufe 3 Beobachtet
    Genau deswegen... Das /home vom root hat da eigentlich nix zu suchen...
    ChrisPrefectC Offline
    ChrisPrefect
    @thomas-braun Habs nochmals mit einem User ausgeführt:
    pi@ioBrokerVM:~$ cd /opt/iobroker
    pi@ioBrokerVM:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
    [sudo] Passwort für pi:
    npm WARN using --force I sure hope you know what you are doing.
    Hat aber nichts geändert.
    • ChrisPrefectC ChrisPrefect
      @chrisprefect sagte in Javascript Adapter rot:
      wobei?
      hast du danach nochmal iob update -i ausgeführt?
      Was kam denn da diesmal?
      ChrisPrefectC 1 Antwort Letzte Antwort
        wobei?
        ChrisPrefect
        pi@ioBrokerVM:/opt/iobroker$ iobroker upgrade iobroker.javascript@latest
        Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
            at parse (<anonymous>)
            at Object.Module._extensions..json (internal/modules/cjs/loader.js:1128:22)
            at Module.load (internal/modules/cjs/loader.js:950:32)
            at Function.Module._load (internal/modules/cjs/loader.js:790:12)
            at Module.require (internal/modules/cjs/loader.js:974:19)
            at require (internal/modules/cjs/helpers.js:93:18)
            at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:368:27)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:276:26
            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2623:45)
            at processImmediate (internal/timers.js:466:21)
        pi@ioBrokerVM:/opt/iobroker$ iob update -i
        Used repository: beta
        hash unchanged, use cached sources
        update done
        Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
        Adapter    "admin"         : 5.2.3    , installed 5.2.3
        Adapter    "alexa2"        : 3.12.0   , installed 3.12.0
        Adapter    "backitup"      : 2.2.3    , installed 2.2.3
        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
        Adapter    "deconz"        : 1.3.19   , installed 1.3.19
        Adapter    "discovery"     : 2.7.5    , installed 2.7.5
        Adapter    "email"         : 1.0.10   , installed 1.0.10
        Adapter    "find-my-iphone": 0.2.17   , installed 0.2.17
        Adapter    "flot"          : 1.10.7   , installed 1.10.7
        Adapter    "geofency"      : 1.0.3    , installed 1.0.3
        Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
        Adapter    "history"       : 1.10.5   , installed 1.10.5
        Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
        Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
        Adapter    "influxdb"      : 2.4.0    , installed 2.4.0
        Adapter    "info"          : 1.9.16   , installed 1.9.16
        Adapter    "iot"           : 1.8.25   , installed 1.8.25
        Adapter    "iqontrol"      : 1.11.0   , installed 1.11.0
        Adapter    "jarvis"        : 3.0.7    , installed 3.0.7
        Controller "js-controller" : 3.3.22   , installed 3.3.22
        Adapter    "lifx"          : 0.1.1    , installed 0.1.1
        Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
        Adapter    "material"      : 1.1.2    , installed 1.1.2
        Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
        Adapter    "modbus"        : 3.4.17   , installed 3.4.17
        Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
        Adapter    "node-red"      : 2.4.1    , installed 2.4.1
        Adapter    "octoprint"     : 2.1.1    , installed 2.1.1
        Adapter    "onvif"         : 0.4.4    , installed 0.4.4
        Adapter    "ping"          : 1.5.0    , installed 1.5.0
        Adapter    "proxy"         : 1.2.2    , installed 1.2.2
        Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
        Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
        Adapter    "samsung"       : 0.2.9    , installed 0.2.9
        Adapter    "scenes"        : 2.3.8    , installed 2.3.8
        Adapter    "shelly"        : 5.0.0    , installed 5.0.0
        Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
        Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
        Adapter    "socketio"      : 3.1.5    , installed 3.1.5
        Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
        Adapter    "statistics"    : 1.0.10   , installed 1.0.10
        Adapter    "stockmarket"   : 0.0.2    , installed 0.0.2
        Adapter    "sureflap"      : 1.0.9    , installed 1.0.9
        Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
        Adapter    "tesla-motors"  : 1.0.7    , installed 1.0.7
        Adapter    "tileboard"     : 0.3.1    , installed 0.3.1
        Adapter    "tr-064"        : 4.2.15   , installed 4.2.15
        Adapter    "unifi"         : 0.5.10   , installed 0.5.10
        Adapter    "vis"           : 1.4.6    , installed 1.4.7
        Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
        Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
        Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
        Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
        Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
        Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
        Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
        Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
        Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
        Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
        Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
        Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
        Adapter    "web"           : 3.4.16   , installed 3.4.16
        Adapter    "windows-control": 0.1.5   , installed 0.1.5
        Adapter    "yahka"         : 0.13.1   , installed 0.13.1
        Adapter    "zigbee"        : 1.6.12   , installed 1.6.12
          Dann warst du zuvor da als root unterwegs?
            ChrisPrefect
            schrieb am zuletzt editiert von ChrisPrefect
            @thomas-braun ja. Als user bekomme ich sonst zu oft Fehlermeldungen wenn wieder irgend was root Berechtigungen braucht. Das stresst mich dann zu oft.
              update done
              immer noch
                immer noch
                und jetzt hast du das System zu sehr gestresst
                Wahrscheinlich sind die Rechte durch die nutzung von root verbogen
                iobroker stop
                iobroker fix
                iobroker start
                als USER
                  Und mich stressen Systeme, die von Leuten, die selbst ernannt 'keine Ahnung haben' mit dem root kaputt gefummelt werden.
                  Ich bin dann raus.
                    Ich bin dann raus.
                    ChrisPrefect
                    @thomas-braun Ich musste erst rumfummeln nachdem das System nicht mehr ging.
                      iobroker stop
                      iobroker fix
                      iobroker start
                      als USER
                      ChrisPrefect
                      @homoran Also das Cache-Löschen geht beim zweiten Mal sehr schnell, das heisst beim ersten Mal wurde viel gelöscht.
                      Habe nochmals rebootet, den Fixer laufen lassen und nochmals update gemacht.
                      Der Javascript-Adapter ist aber noch immer auf der Version .18 und rot.
                        @chrisprefect
                        NEIN. mit dem root muss man nie rumfummenln. Gerade nicht ohne Ahnung was man da überhaupt fummelt.
                          @chrisprefect
                          ChrisPrefect
                          @thomas-braun Kann sein. Das ist aber nicht das Problem.
                          Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                          -1
                            Ich behaupte das Gegenteil.
                              woher weisst du das?
                              Arbeiten mit dem Root verbiegt Rechte, mit denen der user iobroker dann nicht mehr arbeiten darf
                                was sagt denn jetzt iob update -i??
                                und vorher nichts anderes!!!
                                  ChrisPrefect
                                  @homoran weil das System nach dem Update von ioBroker nicht mehr ging und ich mich erst dann per ssh eingeloggt habe.
                                    ChrisPrefect
                                    update done
                                      und vorher noch nie???
                                        update done
                                        @chrisprefect
                                        immer noch cached sources - die müssten weg sein!!
                                        dann stell mal das Repo auf stable und mach den Befehl nochmal
                                          @chrisprefect
                                          ChrisPrefect
                                          pi@ioBrokerVM:/opt/iobroker$ cd /opt/iobroker
                                          Used repository: stable
                                          hash changed or no sources cached => force download of new sources
                                          update done
                                          Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
                                          Adapter    "backitup"      : 2.2.2    , installed 2.2.3
                                          Adapter    "discovery"     : 2.7.3    , installed 2.7.5
                                          Adapter    "history"       : 1.9.14   , installed 1.10.5
                                          Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
                                          Adapter    "info"          : 1.9.8    , installed 1.9.16
                                          Adapter    "iot"           : 1.8.24   , installed 1.8.25
                                          Adapter    "iqontrol"      : 1.8.2    , installed 1.11.0
                                          Adapter    "jarvis"        : 2.2.1    , installed 3.0.7
                                          Adapter    "material"      : 1.0.4    , installed 1.1.2
                                          Adapter    "modbus"        : 3.4.14   , installed 3.4.17
                                          Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
                                          Adapter    "octoprint"     : 2.1.0    , installed 2.1.1
                                          Adapter    "shelly"        : 4.0.7    , installed 5.0.0
                                          Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
                                          Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                                          Adapter    "sonoff"        : 2.4.5    , installed 2.4.7
                                          Adapter    "statistics"    : 1.0.9    , installed 1.0.10
                                          Adapter    "tesla-motors"  : 0.5.2    , installed 1.0.7
                                          Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
                                          Adapter    "vis"           : 1.4.5    , installed 1.4.7
                                          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
                                          Adapter    "web"           : 3.4.9    , installed 3.4.16
                                          Adapter    "zigbee"        : 1.6.6    , installed 1.6.12
