  4. Javascript Adapter rot
    5.5k
91 Beiträge 4 Kommentatoren 11.6k Aufrufe 3 Beobachtet
  • ChrisPrefectC ChrisPrefect
    @thomas-braun Habs nochmals mit einem User ausgeführt:
    pi@ioBrokerVM:~$ cd /opt/iobroker
    pi@ioBrokerVM:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
    [sudo] Passwort für pi:
    npm WARN using --force I sure hope you know what you are doing.
    Hat aber nichts geändert.
    @chrisprefect sagte in Javascript Adapter rot:
    wobei?
    hast du danach nochmal iob update -i ausgeführt?
    Was kam denn da diesmal?
    ChrisPrefectC 1 Antwort Letzte Antwort
      wobei?
      ChrisPrefectC Offline
      ChrisPrefect
      pi@ioBrokerVM:/opt/iobroker$ iobroker upgrade iobroker.javascript@latest
      Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
          at parse (<anonymous>)
          at Object.Module._extensions..json (internal/modules/cjs/loader.js:1128:22)
          at Module.load (internal/modules/cjs/loader.js:950:32)
          at Function.Module._load (internal/modules/cjs/loader.js:790:12)
          at Module.require (internal/modules/cjs/loader.js:974:19)
          at require (internal/modules/cjs/helpers.js:93:18)
          at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:368:27)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:276:26
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2623:45)
          at processImmediate (internal/timers.js:466:21)
      pi@ioBrokerVM:/opt/iobroker$ iob update -i
      Used repository: beta
      hash unchanged, use cached sources
      update done
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
      Adapter    "admin"         : 5.2.3    , installed 5.2.3
      Adapter    "alexa2"        : 3.12.0   , installed 3.12.0
      Adapter    "backitup"      : 2.2.3    , installed 2.2.3
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "deconz"        : 1.3.19   , installed 1.3.19
      Adapter    "discovery"     : 2.7.5    , installed 2.7.5
      Adapter    "email"         : 1.0.10   , installed 1.0.10
      Adapter    "find-my-iphone": 0.2.17   , installed 0.2.17
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "geofency"      : 1.0.3    , installed 1.0.3
      Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
      Adapter    "history"       : 1.10.5   , installed 1.10.5
      Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "influxdb"      : 2.4.0    , installed 2.4.0
      Adapter    "info"          : 1.9.16   , installed 1.9.16
      Adapter    "iot"           : 1.8.25   , installed 1.8.25
      Adapter    "iqontrol"      : 1.11.0   , installed 1.11.0
      Adapter    "jarvis"        : 3.0.7    , installed 3.0.7
      Controller "js-controller" : 3.3.22   , installed 3.3.22
      Adapter    "lifx"          : 0.1.1    , installed 0.1.1
      Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
      Adapter    "material"      : 1.1.2    , installed 1.1.2
      Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "modbus"        : 3.4.17   , installed 3.4.17
      Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
      Adapter    "node-red"      : 2.4.1    , installed 2.4.1
      Adapter    "octoprint"     : 2.1.1    , installed 2.1.1
      Adapter    "onvif"         : 0.4.4    , installed 0.4.4
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "proxy"         : 1.2.2    , installed 1.2.2
      Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "samsung"       : 0.2.9    , installed 0.2.9
      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
      Adapter    "shelly"        : 5.0.0    , installed 5.0.0
      Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
      Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
      Adapter    "socketio"      : 3.1.5    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
      Adapter    "statistics"    : 1.0.10   , installed 1.0.10
      Adapter    "stockmarket"   : 0.0.2    , installed 0.0.2
      Adapter    "sureflap"      : 1.0.9    , installed 1.0.9
      Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "tesla-motors"  : 1.0.7    , installed 1.0.7
      Adapter    "tileboard"     : 0.3.1    , installed 0.3.1
      Adapter    "tr-064"        : 4.2.15   , installed 4.2.15
      Adapter    "unifi"         : 0.5.10   , installed 0.5.10
      Adapter    "vis"           : 1.4.6    , installed 1.4.7
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
      Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
      Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
      Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.16   , installed 3.4.16
      Adapter    "windows-control": 0.1.5   , installed 0.1.5
      Adapter    "yahka"         : 0.13.1   , installed 0.13.1
      Adapter    "zigbee"        : 1.6.12   , installed 1.6.12
        Dann warst du zuvor da als root unterwegs?
          ChrisPrefect
          schrieb am zuletzt editiert von ChrisPrefect
          @thomas-braun ja. Als user bekomme ich sonst zu oft Fehlermeldungen wenn wieder irgend was root Berechtigungen braucht. Das stresst mich dann zu oft.
            update done
            immer noch
              immer noch
              und jetzt hast du das System zu sehr gestresst
              Wahrscheinlich sind die Rechte durch die nutzung von root verbogen
              iobroker stop
              iobroker fix
              iobroker start
              als USER
                Und mich stressen Systeme, die von Leuten, die selbst ernannt 'keine Ahnung haben' mit dem root kaputt gefummelt werden.
                Ich bin dann raus.
                  Ich bin dann raus.
                  ChrisPrefect
                  @thomas-braun Ich musste erst rumfummeln nachdem das System nicht mehr ging.
                    iobroker stop
                    iobroker fix
                    iobroker start
                    als USER
                    ChrisPrefect
                    @homoran Also das Cache-Löschen geht beim zweiten Mal sehr schnell, das heisst beim ersten Mal wurde viel gelöscht.
                    Habe nochmals rebootet, den Fixer laufen lassen und nochmals update gemacht.
                    Der Javascript-Adapter ist aber noch immer auf der Version .18 und rot.
                      @chrisprefect
                      NEIN. mit dem root muss man nie rumfummenln. Gerade nicht ohne Ahnung was man da überhaupt fummelt.
                        @chrisprefect
                        ChrisPrefect
                        @thomas-braun Kann sein. Das ist aber nicht das Problem.
                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        -1
                          Ich behaupte das Gegenteil.
                            woher weisst du das?
                            Arbeiten mit dem Root verbiegt Rechte, mit denen der user iobroker dann nicht mehr arbeiten darf
                              was sagt denn jetzt iob update -i??
                              und vorher nichts anderes!!!
                                ChrisPrefect
                                @homoran weil das System nach dem Update von ioBroker nicht mehr ging und ich mich erst dann per ssh eingeloggt habe.
                                  ChrisPrefect
                                  update done
                                    und vorher noch nie???
                                      update done
                                      @chrisprefect
                                      immer noch cached sources - die müssten weg sein!!
                                      dann stell mal das Repo auf stable und mach den Befehl nochmal
                                        @chrisprefect
                                        ChrisPrefect
                                        pi@ioBrokerVM:/opt/iobroker$ cd /opt/iobroker
                                        Used repository: stable
                                        hash changed or no sources cached => force download of new sources
                                        update done
                                        Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
                                        Adapter    "backitup"      : 2.2.2    , installed 2.2.3
                                        Adapter    "discovery"     : 2.7.3    , installed 2.7.5
                                        Adapter    "history"       : 1.9.14   , installed 1.10.5
                                        Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
                                        Adapter    "info"          : 1.9.8    , installed 1.9.16
                                        Adapter    "iot"           : 1.8.24   , installed 1.8.25
                                        Adapter    "iqontrol"      : 1.8.2    , installed 1.11.0
                                        Adapter    "jarvis"        : 2.2.1    , installed 3.0.7
                                        Adapter    "material"      : 1.0.4    , installed 1.1.2
                                        Adapter    "modbus"        : 3.4.14   , installed 3.4.17
                                        Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
                                        Adapter    "octoprint"     : 2.1.0    , installed 2.1.1
                                        Adapter    "shelly"        : 4.0.7    , installed 5.0.0
                                        Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
                                        Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                                        Adapter    "sonoff"        : 2.4.5    , installed 2.4.7
                                        Adapter    "statistics"    : 1.0.9    , installed 1.0.10
                                        Adapter    "tesla-motors"  : 0.5.2    , installed 1.0.7
                                        Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
                                        Adapter    "vis"           : 1.4.5    , installed 1.4.7
                                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
                                        Adapter    "web"           : 3.4.9    , installed 3.4.16
                                        Adapter    "zigbee"        : 1.6.6    , installed 1.6.12
                                          update done
                                          @chrisprefect schon besser.
                                          Aber
                                          Hast du mal npm-Befehle außerhalb von /opt/iobroker ausgeführt?
                                          zum Beispiel im home vom Root?
