  4. JavaScript
  5. E3DC Hauskraftwerk steuern
3.6k Beiträge 73 Kommentatoren 2.1m Aufrufe 64 Beobachtet
  • C Offline
    ChrisChros
    #1140
    @ArnoD hatte heute pünktlich um 00:00 Uhr ein paar Meldungen im Log stehen.
    2022-01-01 00:00:00.675 - error: javascript.0 (674) script.js.common.E3_DC.E3DC_Control_Prognose: Error: EACCES: permission denied, open '/home/pi/E3DC-Control/HistoryPV_Leistung.json'
    2022-01-01 00:00:00.676 - error: javascript.0 (674) at Object.openSync (fs.js:497:3)
    2022-01-01 00:00:00.676 - error: javascript.0 (674) at writeFileSync (fs.js:1528:35)
    2022-01-01 00:00:00.676 - error: javascript.0 (674) at ProtectFs.writeFileSync (/opt/iobroker/node_modules/iobroker.javascript/lib/protectFs.js:30:37)
    2022-01-01 00:00:00.677 - error: javascript.0 (674) at ReadFileContext.callback (script.js.common.E3_DC.E3DC_Control_Prognose:850:21)
    2022-01-01 00:00:00.677 - error: javascript.0 (674) at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:281:13)
    2022-01-01 00:00:00.841 - error: host.raspberrypi Caught by controller[0]: Error: EACCES: permission denied, open '/home/pi/E3DC-Control/HistoryPV_Leistung.json'
    2022-01-01 00:00:00.857 - error: host.raspberrypi Caught by controller[0]: at Object.openSync (fs.js:497:3)
    2022-01-01 00:00:00.857 - error: host.raspberrypi Caught by controller[0]: at writeFileSync (fs.js:1528:35)
    2022-01-01 00:00:00.858 - error: host.raspberrypi Caught by controller[0]: at ProtectFs.writeFileSync (/opt/iobroker/node_modules/iobroker.javascript/lib/protectFs.js:30:37)
    2022-01-01 00:00:00.859 - error: host.raspberrypi Caught by controller[0]: at ReadFileContext.callback (script.js.common.E3_DC.E3DC_Control_Prognose:851:21)
    2022-01-01 00:00:00.859 - error: host.raspberrypi Caught by controller[0]: at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:281:13)
    2022-01-01 00:00:00.860 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Vermutlich nur ein Berechtigungsproblem. Wie kann ich das beheben?
    sudo chmod 775 HistoryPV_Leistung.json
    ist das der Richtige Weg?
    • C ChrisChros
      ArnoD
      #1141
      @chrischros
      Der User iobroker benötigt Lese und Schreibrechte auf die Datei.
      Entweder die Datei in dem Verzeichnis "/home/iobroker/" erstellen oder die Rechte für User iobroker entsprechend setzen.
      sudo chmod 776 HistoryPV_Leistung.json
      C 1 Antwort Letzte Antwort
      • A ArnoD
        @chrischros
        ChrisChros
        #1142
        @arnod Danke für den Tip.
        Würde auch folgender Befehl funktionieren?
        sudo chgrp iobroker /home/pi/E3DC-Control/
        in der Grupper iobroker sind sowohl der User pi als auch iobroker drin, sollte also auch klappen.
        kann ich den Zugriff von dem Skrip noch einmal manuell auslösen um zu testen ob es funktioniert?
        • C ChrisChros
          ArnoD
          #1143
          @chrischros sagte in E3DC Hauskraftwerk steuern:
          chgrp
          Du kannst es testen indem du im Script die Zeile
          writelog();
          einträgst.
          Aber nicht vergessen das nach dem Test wieder zu löschen ;-)
          • A ArnoD
            chgrp
            writelog();
            einträgst.
            ChrisChros
            #1144
            @arnod said in E3DC Hauskraftwerk steuern:
            writelog();
            Muss das in diesen Teil rein?
            // materialdesing JSON Chart Werte speichern
            async function makeJson(){
                let chart = {}
                let values1 = [], values2 = [], values3 = [], values4 = [], axisLabels = [];
                let akkPV_Leistung, akkProgFore, akkProgProp, akkProgAuto;
            • C ChrisChros
              writelog();
                  let chart = {}
              ArnoD
              #1145
              @chrischros
              nein, mit writelog(); wird die Funktion "writelog" aufgerufen. Diese Zeile muss außerhalb der Funktion im Hauptteil vom Script eingefügt werden.
              z.B. so:
              //**************************************** Function Bereich *****************************************
              writelog();
              async function main()
                  //Prognosen in kWh umrechen
                  await Prognosen_kWh_Berechnen();
                  // Diagramm aktualisieren
                  await makeJson();
                  // Einstellungen 1-5 je nach Überschuss PV Leistung Wetterprognose und Bewölkung anwählen
                  Einstellung(await Ueberschuss_Prozent());
              Danach speichern und das Skript wird automatisch neu gestartet und die Funktion wird einmal aufgerufen.
              • A ArnoD
                @chrischros
                z.B. so:
                writelog();
                    await makeJson();
                ChrisChros
                #1146
                @arnod Danke für die Hilfe.
                mit meinen geänderten Zugriffsrechten für die Gruppe iobroker hatte es leider nicht funktioniert.
                Habe dann die Datei händisch angelegt und die rechte vergeben wie du weiter oben geschrieben hattest, jetzt funktioniert es.
                Danke.
                • C Offline
                  ChrisChros
                  #1147
                  Hallo @ArnoD
                  Hatte heute das erste mal folgende Warnung bei mir im Log stehen:
                  2022-01-11 18:29:41.244 - warn: javascript.0 (1700) State "javascript.0.scriptEnabled.common.E3_DC.Eigenverbrauch___Autarkie" has no existing object, this might lead to an error in future versions
                  Zuvor hatte ich den Jacascript Adapter aktualisiert. Die Warnung ist mir in der Vergangenheit nie aufgefallen.
                  Wo wird denn das Objekt bei dir verwendet im Skript?
                  • C ChrisChros
                    Hallo @ArnoD
                    ArnoD
                    #1148
                    @chrischros
                    Bin mir nicht sicher, ob das Script von mir ist.
                    Schau mal, ob du ein Script findest, das Eigenverbrauch___Autarkie heißt oder welches Script den Pfad "javascript.0.scriptEnabled.common.E3_DC.Eigenverbrauch___Autarkie" verwendet.
                    • A ArnoD
                      @chrischros
                      ChrisChros
                      #1149
                      @arnod
                      Das ist ja das Merkwürdige, ich habe kein Skript das so heißt und ich finde in den Skripten keinen Hinweis das der oben genannte Pfad verwendet wird.
                      • C ChrisChros
                        @arnod
                        ArnoD
                        #1150
                        @chrischros
                        Ich würde mal alle Scripts stoppen und dann eins nach dem anderen starten und im LOG prüfen ob der Fehler auftritt, dann weißt du zumindest welches Script den Fehler verursacht.
                        • A ArnoD
                          @chrischros
                          ChrisChros
                          #1151
                          @arnod hab ich schon gemacht, ohne Ergebnis, Fehler ist bisher nicht mehr aufgetreten.
                          Werde es weiter beobachten
                            ArnoD
                            #1152
                            @Matis
                            Mit dem nächsten Update P10_2022_02 wird auch die Modbus Schnittstelle erweitert V1.90 und dann werden auch die Wechselrichter Daten übertragen.
                            M S 3 Antworten Letzte Antwort
                            • A ArnoD
                              @Matis
                              M Online
                              M Online
                              Matis
                              #1153
                              @arnod
                              Danke für den Hinweis, hab mir auch schnell das Modbus Handbuch und die Release Notes geladen.
                              Da bin ich ja mal gespannt, wann der Update auf meiner Kiste landet.
                              Hast du das schon abgetippt? Kannst du den Modbus Extrakt aus IoBroker dann evtl. nicht als Bild sondern als Text posten? Wäre sehr nett, cut and paste ist doch viel einfacher :)
                              • A ArnoD
                                @Matis
                                stevie77
                                #1154
                                @arnod Hi Arno, du hast also schon reingesehen?! Betrifft es NUR die Zusatzwechselrichterdaten oder gibt es auch Änderungen bzw. Erweiterungen, die relevant/interessant wären, wenn man den Zusatzwechselrichter nicht hat?
                                • M Matis
                                  @arnod
                                  ArnoD
                                  #1155
                                  @matis
                                  Habe das bereits auf Github abgelegt.
                                  Einfach "Modbus_E3DC_Import_V1.90_2022-01-28" herunterladen.
                                  Aber erst importieren, wenn das Update erfolgt ist.
                                  GitHub
                                  • S stevie77
                                    ArnoD
                                    #1156
                                    @stevie77
                                    Mann kann sich die Modbus Anleitung bereits aus dem E3DC Portal herunterladen.
                                    Es werden anscheinend der interne Wechselrichter und die Zusatzwechselrichter angezeigt.
                                    Da das ganze erst jetzt ausgerollt wird und ich das Update noch nicht habe, weiß ich noch nicht, ob das alles funktioniert.
                                    • A ArnoD
                                      @matis
                                      GitHub
                                      M Online
                                      M Online
                                      Matis
                                      #1157
                                      @arnod Danke!
                                        ArnoD
                                        #1158
                                        Neue Wallbox Version 0.3.5 hochgeladen.
                                        Änderungen:
                                        Version: 0.3.5 Über Modbusregister 400 ist eine ODER Verknüpfung mit Eingang EN möglich und die Eingänge EN und ML müssen dann nicht mehr deaktiviert werden.
                                        Version: 0.3.4 Fehler behoben, dass bei Schlüsselstellung 0 die Wallbox deaktiviert wurde.
                                        Um den Schlüsselschalter im Script verwenden zu können, muss die Standardfunktion von Eingang EN und ML deaktiviert werden.
                                        Version: 0.3.3 Lademodus 1 und 2 optimiert.
                                        Ladeleistung Wallbox wird jetzt auch im Lademodus 1 und 2 möglichst konstant gehalten.
                                        Parameter Ladeschwelle E3DC-Control wird beim Lademodus 1 jetzt auch berücksichtigt (manuell oder automatisch möglich).
                                        • V Offline
                                          V Offline
                                          valbuz
                                          #1159
                                          Hallo
                                          Habe seit kurzem mittels Modbus auch mein E3DC System ausgelesen.
                                          Gerne würde ich meine Datenpunkte in kWh angeben.
                                          Wie habt Ihr dies gemacht? Mittels Skript? in NodeRed?
                                          Habe den Thread mal durchgelesen aber keinen Hinweis gefunden.
                                          Wie löst Ihr dies? Sodass die Anzeige in der Vis korrekt angezeigt wird.
                                          Pat
                                          2xProxmox auf NUC
                                          E3DC 13kWh Speicher via RCSP an ioBroker
