  4. Test Withings v0.0.x
    6.8k
554 Beiträge 53 Kommentatoren 167.4k Aufrufe 47 Beobachtet
  • R robson
    @tombox vielen Dank für den Adapter! Habe ihn gerade installiert, bekomme beim Start aber folgende Fehlermeldungen im Debug-Modus ausgegeben:
    host.ioBroker-RasPi4
    2022-01-06 21:02:06.263	error	instance system.adapter.withings.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-01-06 21:02:06.263	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2022-01-06 21:02:06.263	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2022-01-06 21:02:06.263	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/json-bigint/index.js:1:22)
    2022-01-06 21:02:06.262	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2022-01-06 21:02:06.262	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2022-01-06 21:02:06.262	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2022-01-06 21:02:06.262	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2022-01-06 21:02:06.262	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2022-01-06 21:02:06.262	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
    2022-01-06 21:02:06.261	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
    2022-01-06 21:02:06.261	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2022-01-06 21:02:06.261	error	Caught by controller[0]: length
    2022-01-06 21:02:06.260	error	Caught by controller[0]: /opt/iobroker/node_modules/json-bigint/lib/stringify.js:214
    2022-01-06 21:02:05.411	info	instance system.adapter.withings.0 started with pid 20078
    Installation und Einrichtung über https://account.withings.com/partner/dashboard_oauth2 liefen ohne Probleme.
    tombox
    @robson spontan fällt mir auch nichts ein außer node und js-controller zu aktualisieren
    • R Offline
      robson
      @thomas-braun sagte in Test Withings v0.0.x:
      @robson
      Unabhängig vom 'Problem' würde ich auch die empfohlene und für ioBroker vorgesehene V14 springen.
      Und den Indianer auch gleich auf Stand bringen.
      @tombox sagte in Test Withings v0.0.x:
      Freunde, das wars :) Node ist jetzt auf v14.x und der Adapter läuft.
      Ich teste in den kommenden Tagen mal fleißig und berichte.
      • R robson
        @robson
        @robson
        'Kontrolle':
        which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        iobroker update -i
        R 1 Antwort Letzte Antwort
          @robson
          'Kontrolle':
          iobroker update -i
          robson
          Es passt. Node steht auf 14.18.2 und NPM auf 6.14.15.
          Danke noch mal.
          • R robson
            Danke noch mal.
            @robson
            Bitte die komplette Ausgabe zeigen.
              @robson
              robson
              Wieso möchtest du das so genau wissen? Aber ich habe nichts zu verbergen:
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.18.2
              v14.18.2
              6.14.15
              pi
              OK:1 https://deb.nodesource.com/node_14.x buster InRelease
              OK:2 http://archive.raspberrypi.org/debian buster InRelease
              OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Alle Pakete sind aktuell.
              nodejs:
                Installiert:           14.18.2-deb-1nodesource1
                Installationskandidat: 14.18.2-deb-1nodesource1
                Versionstabelle:
               *** 14.18.2-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                   10.24.0~dfsg-1~deb10u1 500
              • R robson
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.18.2
                v14.18.2
                6.14.15
                pi
                nodejs:
                  Versionstabelle:
                @robson sagte in Test Withings v0.0.x:
                Weil hier schon mehr als einmal jemand behauptet hat:
                Jaja, alles richtig installiert! Natürlich!
                Und bei Rückfrage war dann doch alles krumm im System.
                Aber bist entlassen, passt alles. :-D
                • S Stadtschloss
                  @tombox Wow! Vielen Dank für den Adapter. Der Login und die Daten holen hat problemlos geklappt :)
                  Eine Frage zum sleepSummary. Dort befinden sich die Tage als Ordner. Die Ordnernamen verstehe ich jedoch nicht (Zahlenkombination anscheint die ID). Hättest du dafür eine Beschreibung?
                  Hier wäre eine Ordnerstruktur gut, die immer gleich bleibt. Also zum Beispiel. Heute, Minus Erster Tag, Minus 2 Tag etc..
                  robson
                  @stadtschloss sagte in Test Withings v0.0.x:
                  Ich weiß nicht, ob es bei mir bereits die von @tombox angesprochenen Änderungen sind, aber die Schlafdaten meines Aura Sensor V2 werden wie folgt dargestellt:
                  Die gelb markierte ID, ist die Nummer, die bei dir die Ordnernamen darstellt.
                  • R Offline
                    robson
                    @tombox Was ich aktuell noch vermisse, ist der Status, den mein Sleep Sensor ausgibt. True = im Bett, False = nicht im Bett.
                    Ich habe mir mal die API-Beschreibung bei Withings angeschaut. Kann es sein, dass dies der "sleep state" ist? Den finde ich nämlich aktuell in meinen Objekten nicht.
                    Hintergrund: über diesen Status steuere ich aktuell Aktivierung/Deaktivierung des Hüllschutzes im Haus. MeineAbfrage läuft aktuell über IFTTT. Das ist aber leider fehleranfällig und träge.
                    • R robson
                      tombox
                      @robson Gut dass das funktioniert hat ist nur die frage ob das oberste element immer das aktuellste ist und ist die frage ob der andere endpunkt auch relevant ist
                      "Provides the sleep measures for the night of the user, with the details of each phase of their sleep cycle."
                      • R robson
                        tombox
                        @robson Ich habe mal den sleep get endpoint hinzugefügt aber keine ahnung wie daten aussehen die da rausfallen
                        • T tombox
                          robson
                          Das aktuellste Element (die letzte Nacht) ist immer der letzte Eintrag. Bei mir aktuell #29. Ich gehe davon aus, dass die Daten nach einem Monat überschrieben werden. Da ich bereits 29 Elemente habe, kann ich in ein paar Tagen berichten.
                          • R robson
                            tombox
                            @robson Ich hole die letzten 30 Tage ist die Frage ob das sinnvoll ist
                            • T tombox
                              robson
                              Ich schaue mir das mal an. Einen Boolean State für den Status des Sleep Sensors hast du nicht noch zufällig irgendwo gefunden, den ich nutzen könnte?
                              Der Sleep Get Endpoint scheint etwas anderes zu sein.
                              • T tombox
                                robson
                                Zum Testen sicherlich. Wäre später vllt eine Überlegung wert, dies konfigurierbar zu machen.
                                • R robson
                                  tombox
                                  @robson Wie gesagt ich habe kein Gerät ich benötige noch ein Account mit Geräten
                                  • T tombox
                                    DocGame
                                    @tombox Leider bleibt der Adapter rot. Die Tokens usw. stimmen. An was könnte das liegen?
                                    host.iobroker	2022-01-06 22:29:47.137	error	instance system.adapter.withings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    host.iobroker	2022-01-06 22:29:47.137	error	Caught by controller[0]: at Withings.onReady (/opt/iobroker/node_modules/iobroker.withings/main.js:62:9)
                                    host.iobroker	2022-01-06 22:29:47.137	error	Caught by controller[0]: at Withings.login (/opt/iobroker/node_modules/iobroker.withings/main.js:134:22)
                                    host.iobroker	2022-01-06 22:29:47.137	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                    host.iobroker	2022-01-06 22:29:47.137	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.withings/main.js:155:77
                                    host.iobroker	2022-01-06 22:29:47.137	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
                                    host.iobroker	2022-01-06 22:29:47.137	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
                                    withings.0	2022-01-06 22:29:46.521	warn	(29954) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    withings.0	2022-01-06 22:29:46.521	info	(29954) terminating
                                    withings.0	2022-01-06 22:29:46.509	error	(29954) Cannot read property 'split' of undefined
                                    withings.0	2022-01-06 22:29:46.509	error	(29954) TypeError: Cannot read property 'split' of undefined at /opt/iobroker/node_modules/iobroker.withings/main.js:155:77 at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                    withings.0	2022-01-06 22:29:46.507	error	(29954) unhandled promise rejection: Cannot read property 'split' of undefined
                                    withings.0	2022-01-06 22:29:46.507	error	(29954) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    meross.0	2022-01-06 22:29:46.026	warn	(11554) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout / undefined
                                    withings.0	2022-01-06 22:29:45.204	info	(29954) starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.withings, node: v14.17.0, js-controller: 3.3.22
                                    host.iobroker	2022-01-06 22:29:44.491	info	instance system.adapter.withings.0 started with pid 29954
                                    • D DocGame
                                      tombox
                                      @docgame vielleicht auch mehrere nutzer im account? nochmal neu installieren?
                                      • T tombox
                                        DocGame
                                        @tombox hatte meine Frau als "Gast" drin. Habe sie gelöscht (den Account 😊 ), die Adapterinstanz gelöscht und eine neue angelegt.
                                        Immer noch das gleiche.
                                        Muss jetzt mal ins Bett. Wenn du keinen Tip hast könnte ich dir morgen mal meine Accountdaten zukommen lassen.
                                        • D DocGame
                                          tombox
                                          @docgame ja schick mir einfach via pn
