  4. ZigBee neue Version 1.6.x
    6.3k
509 Beiträge 61 Kommentatoren 150.3k Aufrufe 62 Beobachtet
  • I io_laurent
    Hallo @arteck & @Asgothian, der Zigbee-Adapter (V 1.6.10, aber auch schon vorher) mit Stick: CC2538+CC2592, Firmware: 20200211 stürzt jedes Mal ab, wenn ich die Device-Firmware-Update-Abfrage mache.
    2022-01-02 18:52:34.592 - info: zigbee.0 (15664) Firmware on '0x00158d0001ff8d86' is newer than latest firmware online.
    2022-01-02 18:52:35.375 - info: zigbee.0 (15664) Firmware on '0x00158d00053d3d3a' is newer than latest firmware online.
    2022-01-02 18:52:35.542 - info: zigbee.0 (15664) Firmware on '0x00158d00032f6021' is newer than latest firmware online.
    2022-01-02 18:52:43.379 - info: zigbee.0 (15664) Failed to check if update available for '0x000b57fffe8d3865' (Device didn't respond to OTA request)
    2022-01-02 18:52:46.580 - info: zigbee.0 (15664) Failed to check if update available for '0x0c4314fffeae490e' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.718 - info: zigbee.0 (15664) Failed to check if update available for '0x000b57fffe936005' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.726 - info: zigbee.0 (15664) Failed to check if update available for '0x000b57fffe8b330a' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.730 - info: zigbee.0 (15664) Failed to check if update available for '0x086bd7fffe5dac50' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.734 - info: zigbee.0 (15664) Failed to check if update available for '0x680ae2fffe8122ca' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.741 - info: zigbee.0 (15664) Failed to check if update available for '0xd0cf5efffee87532' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.746 - info: zigbee.0 (15664) Failed to check if update available for '0x90fd9ffffeff44cf' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.754 - info: zigbee.0 (15664) Failed to check if update available for '0xd0cf5efffe05b6a9' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.759 - info: zigbee.0 (15664) Failed to check if update available for '0x14b457fffe4c09fd' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.766 - info: zigbee.0 (15664) Failed to check if update available for '0x588e81fffe3f19f4' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.811 - info: zigbee.0 (15664) Failed to check if update available for '0x14b457fffe686f38' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.818 - info: zigbee.0 (15664) Failed to check if update available for '0xd0cf5efffe79fa3f' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.819 - info: zigbee.0 (15664) Failed to check if update available for '0xd0cf5efffe72dd53' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.855 - info: zigbee.0 (15664) Failed to check if update available for '0x5c0272fffe7d4784' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.866 - info: zigbee.0 (15664) Failed to check if update available for '0xcc86ecfffef52c71' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.869 - info: zigbee.0 (15664) Failed to check if update available for '0x84fd27fffeae4a2c' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.877 - info: zigbee.0 (15664) Failed to check if update available for '0x90fd9ffffe9c552d' (Device didn't respond to OTA request)
    2022-01-02 18:52:58.906 - error: zigbee.0 (15664) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-01-02 18:52:58.906 - error: zigbee.0 (15664) unhandled promise rejection: Timeout - 62083 - 1 - null - 25 - 1 after 30000ms
    2022-01-02 18:52:58.907 - error: zigbee.0 (15664) Error: Timeout - 62083 - 1 - null - 25 - 1 after 30000ms
    at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    at listOnTimeout (internal/timers.js:557:17)
    at processTimers (internal/timers.js:500:7)
    2022-01-02 18:52:58.908 - error: zigbee.0 (15664) Timeout - 62083 - 1 - null - 25 - 1 after 30000ms
    2022-01-02 18:52:58.918 - info: zigbee.0 (15664) cleaned everything up...
    2022-01-02 18:52:59.161 - info: zigbee.0 (15664) Zigbee: disabling joining new devices.
    2022-01-02 18:52:59.430 - info: zigbee.0 (15664) terminating
    2022-01-02 18:52:59.432 - warn: zigbee.0 (15664) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-01-02 18:53:00.321 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-01-02 18:53:00.328 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 62083 - 1 - null - 25 - 1 after 30000ms
    2022-01-02 18:53:00.329 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    2022-01-02 18:53:00.329 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
    2022-01-02 18:53:00.329 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
    2022-01-02 18:53:00.330 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-01-02 18:53:00.331 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
    2022-01-02 18:53:16.166 - info: admin.0 (723) Adapter rating updated
    2022-01-02 18:53:30.392 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 17489
    2022-01-02 18:53:35.536 - info: zigbee.0 (17489) starting. Version 1.6.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
    2022-01-02 18:53:35.647 - info: zigbee.0 (17489) Starting Zigbee npm ...
    2022-01-02 18:53:36.150 - info: zigbee.0 (17489) Installed Version: ioBroker/ioBroker.zigbee
    2022-01-02 18:53:36.293 - info: zigbee.0 (17489) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
    2022-01-02 18:53:36.299 - info: zigbee.0 (17489) Unable to disable LED, unsupported function.
    2022-01-02 18:53:36.308 - info: zigbee.0 (17489) --> transmitPower : normal
    2022-01-02 18:53:36.321 - info: zigbee.0 (17489) Currently 82 devices are joined:
    2022-01-02 18:53:36.507 - info: zigbee.0 (17489) 0x000b57fffe51d835 (addr 24687): LED1536G5 - IKEA TRADFRI LED bulb E12/E14 400 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.517 - info: zigbee.0 (17489) 0xd0cf5efffebaaf8d (addr 36836): LED1536G5 - IKEA TRADFRI LED bulb E12/E14 400 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.520 - info: zigbee.0 (17489) 0x000b57fffea6dfb5 (addr 46840): LED1536G5 - IKEA TRADFRI LED bulb E12/E14 400 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.522 - info: zigbee.0 (17489) 0xbc33acfffe7973c1 (addr 34124): E1757 - IKEA FYRTUR roller blind (EndDevice)
    2022-01-02 18:53:36.524 - info: zigbee.0 (17489) 0xd0cf5efffe2a007f (addr 59265): LED1624G9 - IKEA TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white (Router)
    2022-01-02 18:53:36.527 - info: zigbee.0 (17489) 0x680ae2fffe32313e (addr 63180): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    2022-01-02 18:53:36.529 - info: zigbee.0 (17489) 0x00124b00231edba5 (addr 28772): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.530 - info: zigbee.0 (17489) 0x7cb03eaa00b1f8a3 (addr 5206): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-01-02 18:53:36.533 - info: zigbee.0 (17489) 0x000b57fffe936005 (addr 51861): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.534 - info: zigbee.0 (17489) 0xd0cf5efffee87532 (addr 33862): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    2022-01-02 18:53:36.536 - info: zigbee.0 (17489) 0x000b57fffe8b330a (addr 58157): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.538 - info: zigbee.0 (17489) 0x7cb03eaa00abdaa1 (addr 37577): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
    2022-01-02 18:53:36.539 - info: zigbee.0 (17489) 0x7cb03eaa0a0970fc (addr 14265): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-01-02 18:53:36.541 - info: zigbee.0 (17489) 0x00158d00045c012f (addr 51266): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-01-02 18:53:36.543 - info: zigbee.0 (17489) 0x7cb03eaa0a000bf0 (addr 22892): 4052899926110 - OSRAM Flex RGBW (Router)
    2022-01-02 18:53:36.545 - info: zigbee.0 (17489) 0xd0cf5efffe79fa3f (addr 32539): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-01-02 18:53:36.546 - info: zigbee.0 (17489) 0x90fd9ffffe9c552d (addr 33618): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    2022-01-02 18:53:36.547 - info: zigbee.0 (17489) 0x7cb03eaa0a08996c (addr 26534): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-01-02 18:53:36.549 - info: zigbee.0 (17489) 0xd0cf5efffe72dd53 (addr 45443): E1926 - IKEA KADRILJ roller blind (EndDevice)
    2022-01-02 18:53:36.550 - info: zigbee.0 (17489) 0x00158d00045c2786 (addr 48516): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.552 - info: zigbee.0 (17489) 0x086bd7fffe5dac50 (addr 35742): E1766 - IKEA TRADFRI open/close remote (EndDevice)
    2022-01-02 18:53:36.554 - info: zigbee.0 (17489) 0x7cb03eaa00aba5a6 (addr 46422): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
    2022-01-02 18:53:36.556 - info: zigbee.0 (17489) 0x7cb03eaa0a00080b (addr 34044): 4052899926110 - OSRAM Flex RGBW (Router)
    2022-01-02 18:53:36.558 - info: zigbee.0 (17489) 0x00158d00053fd28a (addr 61124): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-01-02 18:53:36.560 - info: zigbee.0 (17489) 0xec1bbdfffed2d259 (addr 48226): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
    2022-01-02 18:53:36.564 - info: zigbee.0 (17489) 0x00158d00054d2abb (addr 28360): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.572 - info: zigbee.0 (17489) 0x00124b0022609212 (addr 44438): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
    2022-01-02 18:53:36.574 - info: zigbee.0 (17489) 0x680ae2fffe8122ca (addr 10976): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    2022-01-02 18:53:36.575 - info: zigbee.0 (17489) 0xbc33acfffe3635a6 (addr 46571): HG06335 - Lidl Silvercrest smart motion sensor (EndDevice)
    2022-01-02 18:53:36.577 - info: zigbee.0 (17489) 0x90fd9ffffeff44cf (addr 12102): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    2022-01-02 18:53:36.578 - info: zigbee.0 (17489) 0x00158d00045cb8db (addr 26405): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.580 - info: zigbee.0 (17489) 0x84fd27fffeae4a2c (addr 2796): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    2022-01-02 18:53:36.582 - info: zigbee.0 (17489) 0x84fd27fffe2a271c (addr 3523): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.584 - info: zigbee.0 (17489) 0x7cb03eaa0a088f46 (addr 24005): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-01-02 18:53:36.585 - info: zigbee.0 (17489) 0xd0cf5efffe05b6a9 (addr 33807): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    2022-01-02 18:53:36.587 - info: zigbee.0 (17489) 0x14b457fffe4c09fd (addr 29182): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    2022-01-02 18:53:36.589 - info: zigbee.0 (17489) 0x00158d0001fe6328 (addr 11063): 404001 - Müller Licht LED bulb E27 806 lumen, dimmable (Router)
    2022-01-02 18:53:36.591 - info: zigbee.0 (17489) 0x588e81fffe3f19f4 (addr 36322): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    2022-01-02 18:53:36.592 - info: zigbee.0 (17489) 0x000b57fffe8d3865 (addr 53643): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    2022-01-02 18:53:36.594 - info: zigbee.0 (17489) 0x00158d00032cf7ae (addr 25048): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
    2022-01-02 18:53:36.596 - info: zigbee.0 (17489) 0x84fd27fffe240b6a (addr 45676): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.597 - info: zigbee.0 (17489) 0x00124b00231e5eaf (addr 18923): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.599 - info: zigbee.0 (17489) 0x14b457fffe686f38 (addr 21069): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    2022-01-02 18:53:36.601 - info: zigbee.0 (17489) 0x04cf8cdf3c7b0867 (addr 29596): ZNCZ04LM - Xiaomi Mi power plug ZigBee EU (Router)
    2022-01-02 18:53:36.602 - info: zigbee.0 (17489) 0x04cf8cdf3c7b22cb (addr 14181): ZNCZ04LM - Xiaomi Mi power plug ZigBee EU (Router)
    2022-01-02 18:53:36.604 - info: zigbee.0 (17489) 0xec1bbdfffea215f2 (addr 30127): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
    2022-01-02 18:53:36.606 - info: zigbee.0 (17489) 0x00158d00053d3d3a (addr 25047): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    2022-01-02 18:53:36.607 - info: zigbee.0 (17489) 0x00158d00045c9f87 (addr 8018): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-01-02 18:53:36.612 - info: zigbee.0 (17489) 0x588e81fffebccb84 (addr 27284): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
    2022-01-02 18:53:36.614 - info: zigbee.0 (17489) 0x00158d0004aaf2ae (addr 38970): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.616 - info: zigbee.0 (17489) 0x00158d00032f6021 (addr 32414): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    2022-01-02 18:53:36.617 - info: zigbee.0 (17489) 0x00158d00053fdd4b (addr 54352): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.619 - info: zigbee.0 (17489) 0xccccccfffee3f411 (addr 41338): 07048L - Immax NEO SMART plug (Router)
    2022-01-02 18:53:36.621 - info: zigbee.0 (17489) 0xccccccfffed72681 (addr 7336): 07048L - Immax NEO SMART plug (Router)
    2022-01-02 18:53:36.622 - info: zigbee.0 (17489) 0xccccccfffee1ccbd (addr 36504): 07048L - Immax NEO SMART plug (Router)
    2022-01-02 18:53:36.625 - info: zigbee.0 (17489) 0xec1bbdfffed4f60d (addr 41160): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
    2022-01-02 18:53:36.628 - info: zigbee.0 (17489) 0x00158d0001ff8d86 (addr 53983): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    2022-01-02 18:53:36.631 - info: zigbee.0 (17489) 0x00158d00045bd149 (addr 29366): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-01-02 18:53:36.632 - info: zigbee.0 (17489) 0x00158d00045bd118 (addr 37959): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-01-02 18:53:36.635 - info: zigbee.0 (17489) 0x00124b0022607ebf (addr 2440): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
    2022-01-02 18:53:36.637 - info: zigbee.0 (17489) 0x00158d00054cf0aa (addr 36924): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.639 - info: zigbee.0 (17489) 0x00124b00234c8662 (addr 24375): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
    2022-01-02 18:53:36.641 - info: zigbee.0 (17489) 0x00158d00054b2e77 (addr 2835): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2022-01-02 18:53:36.649 - info: zigbee.0 (17489) 0x00124b0023204129 (addr 20156): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.651 - info: zigbee.0 (17489) 0x00124b0023201c1f (addr 44384): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.653 - info: zigbee.0 (17489) 0x00124b00231e4057 (addr 18171): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.655 - info: zigbee.0 (17489) 0x00124b00231e925b (addr 28998): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.658 - info: zigbee.0 (17489) 0x00124b0022fddaf9 (addr 17078): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.660 - info: zigbee.0 (17489) 0x00124b00232047a4 (addr 50856): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.661 - info: zigbee.0 (17489) 0xbc33acfffe76bf0c (addr 30130): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-01-02 18:53:36.663 - info: zigbee.0 (17489) 0x00124b00231ed90a (addr 34312): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.665 - info: zigbee.0 (17489) 0x00124b00231eb59b (addr 61876): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
    2022-01-02 18:53:36.667 - info: zigbee.0 (17489) 0x00124b00231e98e8 (addr 52494): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2022-01-02 18:53:36.668 - info: zigbee.0 (17489) 0x5c0272fffe7d4784 (addr 53096): E1766 - IKEA TRADFRI open/close remote (EndDevice)
    2022-01-02 18:53:36.670 - info: zigbee.0 (17489) 0xbc33acfffe980c1e (addr 25975): T2011 - IKEA Osvalla panel round (Router)
    2022-01-02 18:53:36.671 - info: zigbee.0 (17489) 0xcc86ecfffef52c71 (addr 58103): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    2022-01-02 18:53:36.673 - info: zigbee.0 (17489) 0x00124b0023966252 (addr 29431): SNZB-04 - SONOFF Contact sensor (EndDevice)
    2022-01-02 18:53:36.675 - info: zigbee.0 (17489) 0x84fd27fffe1a62d9 (addr 51800): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
    2022-01-02 18:53:36.676 - info: zigbee.0 (17489) 0x0c4314fffeae490e (addr 4134): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    2022-01-02 18:53:36.678 - info: zigbee.0 (17489) 0xb4e3f9fffe739e30 (addr 20130): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
    2022-01-02 18:53:36.679 - info: zigbee.0 (17489) 0x00124b002396b11e (addr 14384): SNZB-04 - SONOFF Contact sensor (EndDevice)
    2022-01-02 18:53:36.681 - info: zigbee.0 (17489) 0x0c4314fffef676d9 (addr 62083): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
    2022-01-02 18:53:36.682 - info: zigbee.0 (17489) Zigbee started
    Fehler ist reproduzierbar und immer an der gleichen Stelle nach Device 0x90fd9ffffe9c552d
    Kann da bitte jemand helfen? Würde gerne die Firmware meiner Ikea-Geräte updaten.
    Kann ich auch eine Firmware-Update-Anfrage von einem einzelnen Gerät machen oder immer nur von allen?
    Vielen Dank für Hilfe!
    arteckA Offline
    arteckA Offline
    arteck
    #208
    @io_laurent sagte in ZigBee neue Version 1.6.x:
    zigbee-herdsman
    mal eben auf die schnelle .. lösche den mal mach die Updates und dann füge den neu hinzu.
    das problem liegt nicht bei uns .. sondern bei herdsman.. muss ich mal schauen warum der knallt. da wird was nicht abgefangen
    I 1 Antwort Letzte Antwort
    • L Offline
      LPTR
      #209
      bei mir läuft ein Conbee II Stick am RaPi4.
      Seit einiger Zeit tritt folgender Fehler auf. Ich habe bis jetzt kein Muster erkannt, wann es passiert. In dem angefügten Errorlog tritt der Fehler direkt nach dem Neustart erneut auf.
      Da ich hier noch recht neu bin... Bin ich damit hier richtig?
      2022-01-03 12:18:23.559 - error: zigbee.0 (12507) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-01-03 12:18:23.560 - error: zigbee.0 (12507) unhandled promise rejection: Offset is outside the bounds of the DataView
      2022-01-03 12:18:23.655 - error: zigbee.0 (12507) RangeError: Offset is outside the bounds of the DataView
      at DataView.getUint32 ()
      at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33)
      at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32)
      at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59)
      at Driver. (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59)
      at Driver.emit (events.js:400:28)
      at Driver.emit (domain.js:475:12)
      at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14)
      at Parser.emit (events.js:400:28)
      at Parser.emit (domain.js:475:12)
      2022-01-03 12:18:23.656 - error: zigbee.0 (12507) Offset is outside the bounds of the DataView
      2022-01-03 12:18:23.675 - info: zigbee.0 (12507) cleaned everything up...
      2022-01-03 12:18:23.723 - warn: zigbee.0 (12507) ELEVATED publishToState: message received '{"available":false}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:18:23.724 - warn: zigbee.0 (12507) ELEVATED publishToState: value generated 'false' from device 00178801001d4e75 for 'Available'
      2022-01-03 12:18:23.724 - warn: zigbee.0 (12507) ELEVATED publishToState: message received '{"linkquality":0}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:18:23.724 - warn: zigbee.0 (12507) ELEVATED publishToState: value generated '0' from device 00178801001d4e75 for 'Link quality'
      2022-01-03 12:18:23.724 - info: zigbee.0 (12507) Zigbee: disabling joining new devices.
      2022-01-03 12:18:23.876 - info: zigbee.0 (12507) terminating
      2022-01-03 12:18:23.878 - warn: zigbee.0 (12507) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-01-03 12:18:24.610 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2022-01-03 12:18:24.611 - error: host.IoBroker Caught by controller[1]: RangeError: Offset is outside the bounds of the DataView
      2022-01-03 12:18:24.611 - error: host.IoBroker Caught by controller[1]: at DataView.getUint32 ()
      2022-01-03 12:18:24.611 - error: host.IoBroker Caught by controller[1]: at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33)
      2022-01-03 12:18:24.611 - error: host.IoBroker Caught by controller[1]: at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32)
      2022-01-03 12:18:24.612 - error: host.IoBroker Caught by controller[1]: at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59)
      2022-01-03 12:18:24.612 - error: host.IoBroker Caught by controller[1]: at Driver. (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59)
      2022-01-03 12:18:24.612 - error: host.IoBroker Caught by controller[1]: at Driver.emit (events.js:400:28)
      2022-01-03 12:18:24.612 - error: host.IoBroker Caught by controller[1]: at Driver.emit (domain.js:475:12)
      2022-01-03 12:18:24.612 - error: host.IoBroker Caught by controller[1]: at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14)
      2022-01-03 12:18:24.612 - error: host.IoBroker Caught by controller[1]: at Parser.emit (events.js:400:28)
      2022-01-03 12:18:24.613 - error: host.IoBroker Caught by controller[1]: at Parser.emit (domain.js:475:12)
      2022-01-03 12:18:24.613 - error: host.IoBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-01-03 12:18:24.613 - info: host.IoBroker Restart adapter system.adapter.zigbee.0 because enabled
      2022-01-03 12:18:54.659 - info: host.IoBroker instance system.adapter.zigbee.0 started with pid 14193
      2022-01-03 12:18:57.476 - info: zigbee.0 (14193) starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
      2022-01-03 12:18:57.598 - info: zigbee.0 (14193) Starting Zigbee npm ...
      2022-01-03 12:18:57.600 - warn: zigbee.0 (14193) 4 extensions initialized
      2022-01-03 12:18:57.601 - warn: zigbee.0 (14193) extension DeviceAvailability
      2022-01-03 12:18:57.601 - warn: zigbee.0 (14193) extension DeviceConfigure
      2022-01-03 12:18:57.601 - warn: zigbee.0 (14193) extension DeviceEvent
      2022-01-03 12:18:57.602 - warn: zigbee.0 (14193) extension DelayedAction
      2022-01-03 12:18:58.061 - info: zigbee.0 (14193) Installed Version: ioBroker/ioBroker.zigbee
      2022-01-03 12:18:58.103 - info: zigbee.0 (14193) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
      2022-01-03 12:18:58.124 - info: zigbee.0 (14193) Unable to disable LED, unsupported function.
      2022-01-03 12:18:58.131 - info: zigbee.0 (14193) --> transmitPower : normal
      2022-01-03 12:18:58.273 - info: zigbee.0 (14193) Unable to set transmit power, unsupported function.
      2022-01-03 12:18:58.277 - info: zigbee.0 (14193) Currently 15 devices are joined:
      2022-01-03 12:18:58.311 - info: zigbee.0 (14193) 0x0c4314fffebb6700 (addr 87): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      2022-01-03 12:18:58.320 - info: zigbee.0 (14193) 0x7cb03eaa00af62ae (addr 60543): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
      2022-01-03 12:18:58.322 - info: zigbee.0 (14193) 0x0c4314fffe9fb24f (addr 41183): HK-LN-DIM-A - LED Trading ZigBee AC phase-cut dimmer (Router)
      2022-01-03 12:18:58.323 - info: zigbee.0 (14193) 0x9035eafffe541a44 (addr 48403): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      2022-01-03 12:18:58.325 - info: zigbee.0 (14193) 0x00158d00038f2829 (addr 52396): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      2022-01-03 12:18:58.326 - info: zigbee.0 (14193) 0x7cb03eaa00aad7d2 (addr 28111): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
      2022-01-03 12:18:58.328 - info: zigbee.0 (14193) 0x001788010b09bf25 (addr 33715): 9290012607 - Philips Hue motion sensor (EndDevice)
      2022-01-03 12:18:58.330 - info: zigbee.0 (14193) 0xf0d1b8000013bb00 (addr 4998): AC10787 - OSRAM SMART+ classic E27 TW (Router)
      2022-01-03 12:18:58.332 - info: zigbee.0 (14193) 0xf0d1b8000013bb09 (addr 34023): AC10787 - OSRAM SMART+ classic E27 TW (Router)
      2022-01-03 12:18:58.334 - info: zigbee.0 (14193) 0x00178801001d4e75 (addr 48483): 7099860PH - Philips LivingColors Aura (Router)
      2022-01-03 12:18:58.336 - info: zigbee.0 (14193) 0xa4c138a3b0ecbf0f (addr 62727): QS-Zigbee-C01 - Lonsonho Curtain/blind motor controller (Router)
      2022-01-03 12:18:58.337 - info: zigbee.0 (14193) 0x00124b00246da98e (addr 18194): SNZB-04 - SONOFF Contact sensor (EndDevice)
      2022-01-03 12:18:58.339 - info: zigbee.0 (14193) 0xa4c138f3c3bf4c3e (addr 36863): QS-Zigbee-C01 - Lonsonho Curtain/blind motor controller (Router)
      2022-01-03 12:18:58.340 - info: zigbee.0 (14193) 0x00124b00246e84ef (addr 15587): SNZB-04 - SONOFF Contact sensor (EndDevice)
      2022-01-03 12:18:58.341 - info: zigbee.0 (14193) 0x00124b0024c3061c (addr 64339): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      2022-01-03 12:18:58.342 - warn: zigbee.0 (14193) config :{"port":"/dev/ttyACM0","panID":"6754","extPanID":"DDDDDDDDDDDDDDDD","channel":"11","disableLed":false,"precfgkey":"01030507090B0D0F00020406080A0C0D","countDown":"255","adapterType":"deconz","debugHerdsman":true,"disablePing":false,"external":"","transmitPower":"0","extPanIdFix":true,"startWithInconsistent":false}
      2022-01-03 12:18:58.343 - info: zigbee.0 (14193) Zigbee started
      2022-01-03 12:18:58.402 - info: zigbee.0 (14193) debug devices set to ["00178801001d4e75"]
      2022-01-03 12:18:59.353 - warn: zigbee.0 (14193) ELEVATED publishToState: message received '{"available":true}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:18:59.354 - warn: zigbee.0 (14193) ELEVATED publishToState: value generated 'true' from device 00178801001d4e75 for 'Available'
      2022-01-03 12:18:59.354 - warn: zigbee.0 (14193) ELEVATED publishToState: message received '{"linkquality":10}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:18:59.355 - warn: zigbee.0 (14193) ELEVATED publishToState: value generated '10' from device 00178801001d4e75 for 'Link quality'
      2022-01-03 12:19:00.220 - warn: zigbee.0 (14193) ELEVATED publishToState: message received '{"linkquality":252}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:19:00.221 - warn: zigbee.0 (14193) ELEVATED publishToState: value generated '252' from device 00178801001d4e75 for 'Link quality'
      2022-01-03 12:19:00.233 - warn: zigbee.0 (14193) ELEVATED publishToState: message received '{"state":"OFF"}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:19:00.234 - warn: zigbee.0 (14193) ELEVATED publishToState: value generated 'false' from device 00178801001d4e75 for 'Switch state'
      2022-01-03 12:19:50.121 - error: zigbee.0 (14193) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-01-03 12:19:50.123 - error: zigbee.0 (14193) unhandled promise rejection: Offset is outside the bounds of the DataView
      2022-01-03 12:19:50.304 - error: zigbee.0 (14193) RangeError: Offset is outside the bounds of the DataView
      2022-01-03 12:19:50.304 - error: zigbee.0 (14193) Offset is outside the bounds of the DataView
      2022-01-03 12:19:50.328 - info: zigbee.0 (14193) cleaned everything up...
      2022-01-03 12:19:50.385 - warn: zigbee.0 (14193) ELEVATED publishToState: message received '{"available":false}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:19:50.385 - warn: zigbee.0 (14193) ELEVATED publishToState: value generated 'false' from device 00178801001d4e75 for 'Available'
      2022-01-03 12:19:50.386 - warn: zigbee.0 (14193) ELEVATED publishToState: message received '{"linkquality":0}' from device 00178801001d4e75 type '7099860PH'
      2022-01-03 12:19:50.386 - warn: zigbee.0 (14193) ELEVATED publishToState: value generated '0' from device 00178801001d4e75 for 'Link quality'
      2022-01-03 12:19:50.387 - info: zigbee.0 (14193) Zigbee: disabling joining new devices.
      2022-01-03 12:19:50.580 - info: zigbee.0 (14193) terminating
      2022-01-03 12:19:50.582 - warn: zigbee.0 (14193) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-01-03 12:19:51.309 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2022-01-03 12:19:51.309 - error: host.IoBroker Caught by controller[1]: RangeError: Offset is outside the bounds of the DataView
      2022-01-03 12:19:51.309 - error: host.IoBroker Caught by controller[1]: at DataView.getUint32 ()
      2022-01-03 12:19:51.309 - error: host.IoBroker Caught by controller[1]: at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33)
      2022-01-03 12:19:51.310 - error: host.IoBroker Caught by controller[1]: at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32)
      2022-01-03 12:19:51.310 - error: host.IoBroker Caught by controller[1]: at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59)
      2022-01-03 12:19:51.310 - error: host.IoBroker Caught by controller[1]: at Driver. (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59)
      2022-01-03 12:19:51.310 - error: host.IoBroker Caught by controller[1]: at Driver.emit (events.js:400:28)
      2022-01-03 12:19:51.310 - error: host.IoBroker Caught by controller[1]: at Driver.emit (domain.js:475:12)
      2022-01-03 12:19:51.310 - error: host.IoBroker Caught by controller[1]: at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14)
      2022-01-03 12:19:51.311 - error: host.IoBroker Caught by controller[1]: at Parser.emit (events.js:400:28)
      2022-01-03 12:19:51.311 - error: host.IoBroker Caught by controller[1]: at Parser.emit (domain.js:475:12)
      2022-01-03 12:19:51.311 - error: host.IoBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-01-03 12:19:51.311 - info: host.IoBroker Restart adapter system.adapter.zigbee.0 because enabled
      2022-01-03 12:20:21.345 - info: host.IoBroker instance system.adapter.zigbee.0 started with pid 14210
      2022-01-03 12:20:24.269 - info: zigbee.0 (14210) starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
      2022-01-03 12:20:24.399 - info: zigbee.0 (14210) Starting Zigbee npm ...
      2022-01-03 12:20:24.401 - warn: zigbee.0 (14210) 4 extensions initialized
      2022-01-03 12:20:24.402 - warn: zigbee.0 (14210) extension DeviceAvailability
      2022-01-03 12:20:24.402 - warn: zigbee.0 (14210) extension DeviceConfigure
      2022-01-03 12:20:24.403 - warn: zigbee.0 (14210) extension DeviceEvent
      2022-01-03 12:20:24.403 - warn: zigbee.0 (14210) extension DelayedAction
      2022-01-03 12:20:24.836 - info: zigbee.0 (14210) Installed Version: ioBroker/ioBroker.zigbee
      2022-01-03 12:20:24.880 - info: zigbee.0 (14210) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
      2022-01-03 12:20:24.901 - info: zigbee.0 (14210) Unable to disable LED, unsupported function.
      2022-01-03 12:20:24.909 - info: zigbee.0 (14210) --> transmitPower : normal
      2022-01-03 12:20:25.049 - info: zigbee.0 (14210) Unable to set transmit power, unsupported function.
      2022-01-03 12:20:25.054 - info: zigbee.0 (14210) Currently 15 devices are joined:
      2022-01-03 12:20:25.098 - info: zigbee.0 (14210) 0x0c4314fffebb6700 (addr 87): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      2022-01-03 12:20:25.104 - info: zigbee.0 (14210) 0x7cb03eaa00af62ae (addr 60543): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
      2022-01-03 12:20:25.106 - info: zigbee.0 (14210) 0x0c4314fffe9fb24f (addr 41183): HK-LN-DIM-A - LED Trading ZigBee AC phase-cut dimmer (Router)
      2022-01-03 12:20:25.107 - info: zigbee.0 (14210) 0x9035eafffe541a44 (addr 48403): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      2022-01-03 12:20:25.109 - info: zigbee.0 (14210) 0x00158d00038f2829 (addr 52396): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      2022-01-03 12:20:25.110 - info: zigbee.0 (14210) 0x7cb03eaa00aad7d2 (addr 28111): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
      2022-01-03 12:20:25.113 - info: zigbee.0 (14210) 0x001788010b09bf25 (addr 33715): 9290012607 - Philips Hue motion sensor (EndDevice)
      2022-01-03 12:20:25.114 - info: zigbee.0 (14210) 0xf0d1b8000013bb00 (addr 4998): AC10787 - OSRAM SMART+ classic E27 TW (Router)
      2022-01-03 12:20:25.116 - info: zigbee.0 (14210) 0xf0d1b8000013bb09 (addr 34023): AC10787 - OSRAM SMART+ classic E27 TW (Router)
      2022-01-03 12:20:25.118 - info: zigbee.0 (14210) 0x00178801001d4e75 (addr 48483): 7099860PH - Philips LivingColors Aura (Router)
      2022-01-03 12:20:25.120 - info: zigbee.0 (14210) 0xa4c138a3b0ecbf0f (addr 62727): QS-Zigbee-C01 - Lonsonho Curtain/blind motor controller (Router)
      2022-01-03 12:20:25.121 - info: zigbee.0 (14210) 0x00124b00246da98e (addr 18194): SNZB-04 - SONOFF Contact sensor (EndDevice)
      2022-01-03 12:20:25.123 - info: zigbee.0 (14210) 0xa4c138f3c3bf4c3e (addr 36863): QS-Zigbee-C01 - Lonsonho Curtain/blind motor controller (Router)
      2022-01-03 12:20:25.124 - info: zigbee.0 (14210) 0x00124b00246e84ef (addr 15587): SNZB-04 - SONOFF Contact sensor (EndDevice)
      2022-01-03 12:20:25.126 - info: zigbee.0 (14210) 0x00124b0024c3061c (addr 64339): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      2022-01-03 12:20:25.127 - warn: zigbee.0 (14210) config :{"port":"/dev/ttyACM0","panID":"6754","extPanID":"DDDDDDDDDDDDDDDD","channel":"11","disableLed":false,"precfgkey":"01030507090B0D0F00020406080A0C0D","countDown":"255","adapterType":"deconz","debugHerdsman":true,"disablePing":false,"external":"","transmitPower":"0","extPanIdFix":true,"startWithInconsistent":false}
      2022-01-03 12:20:25.127 - info: zigbee.0 (14210) Zigbee started
      2022-01-03 12:20:25.181 - info: zigbee.0 (14210) debug devices set to ["00178801001d4e75"]
      • L LPTR
        #210
        @lptr sagte in ZigBee neue Version 1.6.x:
        "port":"/dev/ttyACM0","extPanID":"DDDDDDDDDDDDDDDD"
        Die Empfehlungen gehen dahin beim Port den Link aus /dev/serial/by-id zu nehmen und bei der extPanID einen anderen Hex-Wert als DDDDDDDDDDDDDDDD einzustellen.
        L 1 Antwort Letzte Antwort
          LPTR
          #211
          Vielen Dank für den Tipp
          Uff... Alles neu pairen?
          So ist das, wenn man am Start alles einfach so lässt wie gegeben.
          ich werde es mal angehen.
          • L LPTR
            #212
            Deswegen stehen neben den Einträgen auch entsprechende Hinweise. Sollte man halt beim Einrichten mal lesen und auch umsetzen.
              LPTR
              #213
              Ich bekenne mich schuldig zwar gelesen zu haben, aber da keine Nachbarn es als 'steht ja was drin, keiner wird stören' bewertet zu haben. Aller Anfang ist schwer...
              • L LPTR
                #214
                @lptr
                Und bevor du gleich sagst: Alles geändert, der Fehler ist aber noch da!
                Das steht auch nicht zu erwarten. Eine gesunde Grundkonfiguration macht aber das Leben im weiteren leichter.
                  @lptr
                  LPTR
                  #215
                  Habe Dich schon verstanden, dass es eine Empfehlung ist, die helfen 'könnte'.
                  Wenn etwas zu optimieren ist bin ich immer gerne bereit meinen 'Mist' aus der Vergangenheit aufzuräumen.
                  • L LPTR
                    #216
                    @lptr
                    Was mir dann auch noch auffällt:
                    Ist die Zeitzone richtig gesetzt oder ist der Log-Eintrag wirklich von vor 3 Stunden?
                      @lptr
                      LPTR
                      schrieb am zuletzt editiert von LPTR
                      #217
                      Zeitzone ist richtig. Es war heute Mittag das letzte Mal.
                      Ich beobachte das schon gut 2 Wochen. Wollte ein Muster erkennen.
                      Edit:
                      Doch kein neu pairen notwendig?
                      Alles ist erreichbar.
                      • arteckA arteck
                        zigbee-herdsman
                        I Offline
                        I Offline
                        io_laurent
                        schrieb am zuletzt editiert von io_laurent
                        #218
                        @arteck sagte in ZigBee neue Version 1.6.x:
                        zigbee-herdsman
                        Vielen Dank!
                        Hab ich gemacht, dann hängt sich der Adapter an nem Schalter auf, dann habe ich den rausgeworfen, dann hängt er sich bei nem Kontaktsensor auf,...
                        Ich habe jetzt vier Geräte gelöscht und der Adapter hängt sich immer noch auf. Ich will jetzt nicht nach und nach Geräte löschen, da ich inzwischen 85 Stück habe. Ich weiß ja nicht, ob's erst klappt, wenn ich noch drei Lampen im Netz hab😉
                        Die Möglichkeit, von einem einzelnen Gerät die Firmware-Update-Abfrage zu machen gibt es nicht, oder?
                        Der Adapter findet nämlich grundsätzlich die Firmware-Updates z.B. von Lampen, die lassen sich dann aber nicht updaten, da der Adapter vorher abschmiert und damit der update-Button am Gerät auch wieder weg ist.
                        Wäre es viel Aufwand, die Firmware-Abfrage eines einzelnen Gerätes in den Adapter einzubauen?
                        Vielen Dank!
                        • mickymM Offline
                          mickymM Offline
                          mickym
                          #219
                          gelöscht
                          • B Online
                            B Online
                            BigMike71
                            schrieb am zuletzt editiert von BigMike71
                            #220
                            habe heute von 1.6.10 auf die 1.6.11 geupdatet und bekomme diese warn Meldungen
                            im Log:
                            2022-01-07 13:24:46.458 - warn: zigbee.0 (3343) 4 extensions initialized
                            2022-01-07 13:24:46.459 - warn: zigbee.0 (3343) extension DeviceAvailability
                            2022-01-07 13:24:46.460 - warn: zigbee.0 (3343) extension DeviceConfigure
                            2022-01-07 13:24:46.461 - warn: zigbee.0 (3343) extension DeviceEvent
                            2022-01-07 13:24:46.461 - warn: zigbee.0 (3343) extension DelayedAction
                            2022-01-07 13:24:47.562 - warn: zigbee.0 (3343) config :{"port":"/dev/ttyUSB0","panID":"3369","extPanID":"0123456789ABCDEF","channel":"11","disableLed":true,"precfgkey":"B1090507090C0D0F00020406080B0C0D","countDown":"90","adapterType":"zstack","debugHerdsman":false,"disablePing":false,"external":"","startWithInconsistent":false,"transmitPower":"0","extPanIdFix":true}
                            2022-01-07 13:24:47.562 - info: zigbee.0 (3343) Zigbee started
                            ist da was falsch? hatte ich vorher nicht, direkt nach dem manuellen updaten...
                            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                            • B BigMike71
                              im Log:
                              #221
                              @bigmike71 sagte in ZigBee neue Version 1.6.x:
                              Den würde ich auf den Link aus
                              /dev/serial/by-id/
                              setzen. Ansonsten nix wildes.
                              • B BigMike71
                                im Log:
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #222
                                im Log:
                                Nein, das ist (noch) normal. Wenn ein bestimmter Effekt vollständig weg ist sind auch die Meldungen wieder weg.
                                A.
                                • AsgothianA Asgothian
                                  im Log:
                                  A.
                                  DocGame
                                  #223
                                  @asgothian Ich habe hier seit einem halben Jahr einen 6 fach Taster von Zemismart(ZM-RM02). Als ich ihn nach zig Versuchen nicht angelernt bekam (war noch nicht im Herdsman) ist er in den Schrank gewandert.
                                  Letzte Woche wurde er durch ein Update aufgenommen. Habe ihn gleich wieder angelernt und er war sofort da. Keine Fehlermeldungen im Log.
                                  Jetzt kommt das merkwürdige:
                                  Er zeigt immer eine Empfangssignal von 10 (auch nach Stunden). Sobald ich eine Taste drücke (egal welche) geht der Empfang für ca. 2 Sec. auf 158 (Ist Realistisch, da ich direkt neben meinem cc1352p-2 sitze) dann geht er wieder auf 10 zurück. Das alleine wäre schon ein melkwürdiges Verhalten. Schlimmer ist das kein Wert im Datenpunkt ankommt (auch nicht in der Kachelübersicht). Hat jemand schon ein ähnliches Verhalten bei einem Gerät beobachtet?
                                  AsgothianA NewanN 2 Antworten Letzte Antwort
                                  • D DocGame
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #224
                                    @docgame
                                    Ich kenne dieses Gera4t nicht. Interessant wäre:
                                    • welche Zigbee Version läuft bei Dir ?
                                    • was passiert wenn du 0c4314fffe6000b1 in den Datenpunkt zigbee.0.info.debugmessages einträgst (kein Neustart des Adapters erforderlich). Interessant sind Warn-Meldungen mit dem Schlüsselword "ELEVATED"
                                    NewanN 1 Antwort Letzte Antwort
                                    • D DocGame
                                      NewanN Offline
                                      NewanN Offline
                                      Newan
                                      #225
                                      @docgame Setze mal die IEEE ohne doe 0x in das zigbee.0.info.debugmessages object.
                                      Danach sollten alle Events im Log gepostet werden als warning. HAb ein ähnliches verhalten mit meinen Busch Jäger Schalter und hab da auch eine mögliche Lösung gefunden
                                        @docgame
                                        NewanN Offline
                                        NewanN Offline
                                        Newan
                                        #226
                                        @asgothian
                                        Kannst du mir auch einen Tipp geben wie ich den Converter erstelle für den Bug hier
                                        https://github.com/ioBroker/ioBroker.zigbee/issues/1238
                                        zigbee.0
                                        2022-01-07 23:38:42.814	error	No converter available for '6735/6736/6737' with key 'rm01_row_2'
                                        zigbee.0
                                        2022-01-07 23:38:42.810	warn	ELEVATED Change state 'rm01_row_2' at device 0xd85def11a10049ce type '6735/6736/6737'
                                        zigbee.0
                                        2022-01-07 23:38:42.804	warn	ELEVATED: User stateChange zigbee.0.d85def11a10049ce.rm01_row_2 {"val":true,"ack":false,"ts":1641595122802,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1641595122802}
                                        zigbee.0
                                        2022-01-07 23:38:42.798	warn	SetState_typed called without type
                                        • NewanN Newan
                                          @asgothian
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          DocGame
                                          schrieb am zuletzt editiert von DocGame
                                          #227
                                          @newan @Asgothian Habe ihn nochmal gelöscht, neu angelernt die IEEE in zigbee.0.info.debugmessages eingetragen und 3 verschiedene Tasten gedrückt.
                                          Er bringt nur ein "announced itself" je Tastendruck:
                                          zigbee.0	2022-01-08 00:02:08.187	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
                                          zigbee.0	2022-01-08 00:01:56.514	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
                                          zigbee.0	2022-01-08 00:01:52.805	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
                                          zigbee.0	2022-01-08 00:01:07.074	info	(27496) Zigbee: stop joining
                                          zigbee.0	2022-01-08 00:00:34.039	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
                                          zigbee.0	2022-01-08 00:00:28.240	info	(27496) Device '0x0c4314fffe6000b1' is supported, identified as: Zemismart Smart 6 key scene switch (ZM-RM02)
                                          zigbee.0	2022-01-08 00:00:28.240	info	(27496) Successfully interviewed '0x0c4314fffe6000b1', device has succesfully been paired
                                          zigbee.0	2022-01-08 00:00:27.008	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
                                          zigbee.0	2022-01-08 00:00:26.790	info	(27496) Starting interview of '0x0c4314fffe6000b1'
                                          zigbee.0	2022-01-08 00:00:05.806	info	(27496) Zigbee: allowing new devices to join.
                                          Nachtrag: Zigbee-Adapter ist der aktuelle aus Github (1.6.11 -- im Moment 16 Std. online)
