  4. iobroker funktioniert nicht js:638
27 Beiträge 3 Kommentatoren 2.9k Aufrufe 2 Beobachtet
    @calli236
    Keine Screenshots. Textausgabe in CodeTags hier rein.
    calli236
    Achso tut mir leid
    pi@raspberrypi:~ $ iobroker is running on this host
    internal/modules/cjs/loader.js:638
    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    at startup (internal/bootstrap/node.js:283:19)
    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    pi@raspberrypi:~ $
    BBTownB 1 Antwort Letzte Antwort
    • C calli236
      Achso tut mir leid
      throw err;
      pi@raspberrypi:~ $
      BBTownB Offline
      BBTownB Offline
      BBTown
      @calli236
      Log-Files und Codes gehören in "Code-Tags"
      C 1 Antwort Letzte Antwort
      • BBTownB BBTown
        @calli236
        calli236
        @bbtown
        throw err;
        pi@raspberrypi:~ $```
        code_text
        • C calli236
          @bbtown
          throw err;
          code_text
          Thomas BraunT Offline
          @calli236
          dmesg -T | grep -i ext4
          cd /opt/iobroker
          iobroker stop
          sudo -H -u iobroker npm install iobroker.js-controller
          iobroker restart
          C 2 Antworten Letzte Antwort
            @calli236
            cd /opt/iobroker
            iobroker stop
            iobroker restart
            calli236
            @thomas-braun das kam nach dem ersten befehl
            pi@raspberrypi:~ $ dmesg -T | grep -i ext4
            [Mi Nov 24 11:12:30 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:9C:84:64 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bc543526-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            [Mi Nov 24 11:12:31 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Mi Nov 24 11:12:31 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mi Nov 24 11:12:33 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            pi@raspberrypi:~ $
            • C calli236
              pi@raspberrypi:~ $
              @calli236
              Passt. Dann installier es nochmal (s.o.).
                @calli236
                cd /opt/iobroker
                iobroker stop
                iobroker restart
                calli236
                jetzt gehts vielen Dank :)
                  @calli236
                  calli236
                  eine frage hätte ich noch wie aktualisiere ich den iobroker weil bei mir ist der immernoch auf version v10.24.1 obwohl ich schon mehrfach auf 14 aktualisiert habe
                  • C calli236
                    @calli236
                    Du meinst vermutlich nodeJS.
                    Schau in meiner Signatur, da steht's drin.
                      @calli236
                      calli236
                      @thomas-braun hallo ich mal wieder glaube hab es jetzt geschafft alles zu zerstören
                      pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                      npm WARN checkPermissions Missing write access to /home/pi/node_modules/iobroker   .js-controller
                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                      npm WARN pi No description
                      npm WARN pi No repository field.
                      npm WARN pi No README data
                      npm WARN pi No license field.
                      npm ERR! code EACCES
                      npm ERR! syscall access
                      npm ERR! path /home/pi/node_modules/iobroker.js-controller
                      npm ERR! errno -13
                      npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/iobroke   r.js-controller'
                      npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/iobro   ker.js-controller'] {
                      npm ERR!   errno: -13,
                      npm ERR!   code: 'EACCES',
                      npm ERR!   syscall: 'access',
                      npm ERR!   path: '/home/pi/node_modules/iobroker.js-controller'
                      npm ERR! }
                      npm ERR!
                      npm ERR! The operation was rejected by your operating system.
                      npm ERR! It is likely you do not have the permissions to access this file as the    current user
                      npm ERR!
                      npm ERR! If you believe this might be a permissions issue, please double-check t   he
                      npm ERR! permissions of the file and its containing directories, or try running
                      npm ERR! the command again as root/Administrator.
                      npm ERR!     /home/iobroker/.npm/_logs/2021-12-28T17_12_15_621Z-debug.log
                      pi@raspberrypi:~ $
                      • C calli236
                        npm ERR! errno -13
                        npm ERR! }
                        npm ERR!
                        npm ERR!
                        pi@raspberrypi:~ $
                        @calli236
                        Du solltest auch alles eingeben...
                        cd /opt/iobroker
                        iobroker stop
                        iobroker restart
                        Ist dein nodeJS denn nun senkrecht?
                          @calli236
                          cd /opt/iobroker
                          iobroker stop
                          iobroker restart
                          calli236
                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                          > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                          > node lib/preinstallCheck.js
                          NPM version: 6.14.15
                          > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
                          > node iobroker.js setup first
                          object _design/custom updated
                          object _design/system updated
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          + iobroker.js-controller@3.3.22
                          updated 1 package in 29.502s
                          23 packages are looking for funding
                            run `npm fund` for details
                             │      New major version of npm available! 6.14.15 → 8.3.0      │
                             │   Changelog: https://github.com/npm/cli/releases/tag/v8.3.0   │
                             │               Run npm install -g npm to update!               │
                          code_text
                          • C calli236
                            code_text
                            @calli236
                            Und Finger weg von dem npm-Update, das da empfohlen wird.
                            Läuft jetzt wieder alles?
                              @calli236
                              calli236
                              @thomas-braun ne kann keine verbindung herstellen hab bei ebay einen conbee stick bestellt wo neu und funktionsfähig daberi stand hatte den reingesteckt und seid dem geht nichts mehr
                              • C calli236
                                @calli236 sagte in iobroker funktioniert nicht js:638:
                                Heißt konkret?
                                  Heißt konkret?
                                  calli236
                                  @thomas-braun wenn ich im browser die ip adresse eingebe steht da die seite ist nicht erreichbar
                                  • C calli236
                                    @calli236
                                    Bitte leserlich schreiben, Groß/Kleinschreibung und Satzzeichen sind kein Luxus, soviel Zeit sollte sein.
                                    iobroker status
                                    iobroker list adapters
                                    iobroker list instances
                                    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                                      @calli236
                                      iobroker status
                                      calli236
                                      schrieb am zuletzt editiert von calli236
                                      @thomas-braun das kam beim Ersten
                                      pi@raspberrypi:~ $ iobroker status
                                      iobroker is not running on this host.
                                      Objects type: file
                                      States  type: file
                                      dann das !
                                      system.adapter.admin                   : admin          - v5.2.3
                                      system.adapter.discovery               : discovery      - v2.7.3
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $ iobroker list instances
                                        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      • C calli236
                                        Objects type: file
                                        States  type: file
                                        dann das !
                                        pi@raspberrypi:~ $
                                        + instance is alive
                                        @calli236
                                        Und der Rest? Und bitte komplette Ein- wie Ausgaben posten, ich rate ungern auf welches Kommando das nun die Ausgabe sein soll.
                                        • C calli236
                                          Objects type: file
                                          States  type: file
                                          dann das !
                                          pi@raspberrypi:~ $
                                          + instance is alive
                                          @calli236
                                          iobroker start
                                          iobroker start admin
