  4. jarvis v3.0.0 - just another remarkable vis
    6.5k
4.5k Beiträge 254 Kommentatoren 3.1m Aufrufe 209 Beobachtet
  • sigi234S sigi234
    @zefau sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
    @sigi234 sagte in jarvis v3.0.0 - just another remarkable vis:
    Hallo, gibt es schon einen V 3.0.0 Beitrag?
    Dieser hier.
    Bekomme noch immer diese Warn:
    jarvis.0
    2021-12-28 11:13:27.453	warn	alias.0.Geschirrspüler.BSH_Common_Command_PauseProgram is not a valid state
    jarvis.0
    2021-12-28 11:13:27.452	warn	alias.0.Geschirrspüler.BSH_Common_Command_ResumeProgram is not a valid state
    jarvis.0
    2021-12-28 11:13:27.452	warn	alias.0.Geschirrspüler.BSH_Common_Command_StopProgram is not a valid state
    jarvis.0
    2021-12-28 11:13:27.452	warn	http://192.168.178.20:8082/vis.0/yamaha-rx-v481.png is not a valid state
    jarvis.0
    2021-12-28 11:13:27.452	warn	tr-064.0.phonebook.number is not a valid state
    jarvis.0
    2021-12-28 11:13:27.451	warn	tr-064.0.phonebook.name is not a valid state
    jarvis.0
    2021-12-28 11:13:27.451	warn	tr-064.0.phonebook.image is not a valid state
    jarvis.0
    2021-12-28 11:13:27.450	warn	.ACTUAL is not a valid state
    jarvis.0
    jarvis.0
    2021-12-28 11:13:27.449	warn	.ACTUAL is not a valid state
    jarvis.0
    2021-12-28 11:13:27.448	warn	.ACTUAL is not a valid state
    jarvis.0
    jarvis.0
    2021-12-28 11:13:27.447	warn	.ACTUAL is not a valid state
    jarvis.0
    jarvis.0
    2021-12-28 11:13:27.447	warn	hue.0.Philips_hue.Alle.scene_nachtlicht is not a valid state
    jarvis.0
    2021-12-28 11:13:27.447	warn	hue.0.Philips_hue.Alle.scene_gedimmt is not a valid state
    jarvis.0
    2021-12-28 11:13:27.446	warn	hue.0.Philips_hue.Alle.scene_hell is not a valid state
    jarvis.0
    2021-12-28 11:13:27.445	warn	hue.0.Philips_hue.Alle.scene_frühlingsblüten is not a valid state
    jarvis.0
    2021-12-28 11:13:27.444	warn	hue.0.Philips_hue.Alle.scene_nordlichter is not a valid state
    jarvis.0
    2021-12-28 11:13:25.928	warn	hue.0.Philips_hue.Alle.scene_tropendämmerung is not a valid state
    jarvis.0
    2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_sonnenuntergang_savanne is not a valid state
    jarvis.0
    2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_energie_tanken is not a valid state
    jarvis.0
    2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_konzentrieren is not a valid state
    jarvis.0
    2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_lesen is not a valid state
    jarvis.0
    2021-12-28 11:13:25.927	warn	hue.0.Philips_hue.Alle.scene_entspannen is not a valid state
    jarvis.0
    2021-12-28 11:13:25.718	warn	hue.0.Philips_hue.Büro.scene_nachtlicht is not a valid state
    jarvis.0
    2021-12-28 11:13:25.704	warn	hue.0.Philips_hue.Büro.scene_frühlingsblüten is not a valid state
    jarvis.0
    2021-12-28 11:13:25.695	warn	hue.0.Philips_hue.Büro.scene_nordlichter is not a valid state
    jarvis.0
    2021-12-28 11:13:25.655	warn	hue.0.Philips_hue.Büro.scene_tropendämmerung is not a valid state
    jarvis.0
    2021-12-28 11:13:25.655	warn	hue.0.Philips_hue.Büro.scene_sonnenuntergang_savanne is not a valid state
    jarvis.0
    2021-12-28 11:13:25.655	warn	hue.0.Philips_hue.Büro.scene_energie_tanken is not a valid state
    jarvis.0
    2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Büro.scene_konzentrieren is not a valid state
    jarvis.0
    2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Büro.scene_lesen is not a valid state
    jarvis.0
    2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Büro.scene_entspannen is not a valid state
    jarvis.0
    2021-12-28 11:13:25.654	warn	hue.0.Philips_hue.Küche.scene_scene_storagescene_ is not a valid state
    jarvis.0
    2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_bewegung is not a valid state
    jarvis.0
    2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_scene_recoveryscene_ is not a valid state
    jarvis.0
    2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_nachtlicht is not a valid state
    jarvis.0
    2021-12-28 11:13:25.653	warn	hue.0.Philips_hue.Küche.scene_energie_tanken is not a valid state
    jarvis.0
    2021-12-28 11:13:25.652	warn	hue.0.Philips_hue.Küche.scene_hell is not a valid state
    jarvis.0
    2021-12-28 11:13:25.652	warn	hue.0.Philips_hue.Küche.scene_lesen is not a valid state
    jarvis.0
    2021-12-28 11:13:25.652	warn	hue.0.Philips_hue.Küche.scene_gedimmt_küche is not a valid state
    jarvis.0
    2021-12-28 11:13:25.647	warn	hue.0.Philips_hue.Küche.scene_entspannen is not a valid state
    jarvis.0
    2021-12-28 11:13:25.242	warn	hue.0.Philips_hue.Küche.scene_konzentrieren_küche is not a valid state
    jarvis.0
    2021-12-28 11:13:25.224	warn	hue.0.Philips_hue.Küche.scene_frühlingsblüten is not a valid state
    jarvis.0
    2021-12-28 11:13:25.223	warn	hue.0.Philips_hue.Küche.scene_sonnenuntergang_savanne is not a valid state
    jarvis.0
    2021-12-28 11:13:25.191	warn	hue.0.Philips_hue.Küche.scene_tropendämmerung is not a valid state
    jarvis.0
    2021-12-28 11:13:25.173	warn	hue.0.Philips_hue.Bad_Room.scene_gedimmt_bad is not a valid state
    jarvis.0
    2021-12-28 11:13:25.169	warn	hue.0.Philips_hue.Bad_Room.scene_hell_bad is not a valid state
    jarvis.0
    2021-12-28 11:13:25.162	warn	hue.0.Philips_hue.Bad_Room.scene_nachtlicht_bad is not a valid state
    jarvis.0
    2021-12-28 11:13:25.065	warn	http://192.168.178.20:8082/vis.0/VU_analog.gif is not a valid state
    Edit:
    Erledigt
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    #402
    @sigi234 sind keine validen Datenpunkte, also der Wert ist null. Ggf. sind das nur Trigger, die du aber bei der Datenpunkt-Anzeige drin hast?
    sigi234S S 2 Antworten Letzte Antwort
    • P Penny2912
      @mcu Leider hat der upload auf der Konsole auch nichts gebracht
      Die Konsole von Chrome sieht so aus: Screenshot 2021-12-27 175648.png
      Und so sieht die Jarvis Konfiguration aus: Konfiguration_JARVIS-v3.png
      Ich würde jetzt nochmal zurück auf die 2.2.5 gehen mit einem iobroker restore weil ich mir unsicher bin ob meine Daten noch da sind 😆 .
      ZefauZ Offline
      ZefauZ Offline
      Zefau
      #403
      @penny2912 sagte in jarvis v3.0.0 - just another remarkable vis:
      Ich würde jetzt nochmal zurück auf die 2.2.5 gehen mit einem iobroker restore weil ich mir unsicher bin ob meine Daten noch da sind .
      Deine Daten sind scheinbar kaputt. v3 versucht immer wieder zu konvertieren und scheint in einem Loop zu laufen.
      Was steht denn nach der v3 Installation und dem initialen Aufruf von v3 in den Datenpunkten jarvis.0.devices, jarvis.0.layout bzw. jarvis.0.widgets bei dir drin?
      P 2 Antworten Letzte Antwort
      • ZefauZ Zefau
        sigi234S Online
        sigi234S Online
        #404
        @zefau sagte in jarvis v3.0.0 - just another remarkable vis:
        Beispiel DP:
          "_id": "hue.0.Philips_hue.Alle.scene_nachtlicht",
          "type": "state",
          "common": {
            "type": "boolean",
            "name": "Scene Nachtlicht",
            "role": "button"
          "native": {
            "id": "VCwp7y9FqRQfcNJ",
            "group": "7"
          "from": "system.adapter.hue.0",
          "user": "system.user.admin",
          "ts": 1628695253837,
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        • sigi234S sigi234
          Beispiel DP:
            "type": "state",
            "common": {
              "type": "boolean",
              "role": "button"
            "native": {
              "group": "7"
            "acl": {
              "object": 1636,
              "state": 1636,
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          schrieb am zuletzt editiert von Zefau
          #405
          Beispiel DP:
          Ich mein den Datenpunkt in jarvis im Gerät bzw. den Datenpunkt in ioBroker - nicht das Objekt.
          • ZefauZ Zefau
            Beispiel DP:
            sigi234S Online
            sigi234S Online
            #406
            Beispiel DP:
            Ok, im Objekt steh (null) drinnen, ev. darum?
            • M MCU
              @andré-müller
              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/notifications/reolink-motioneye
              Falls noch andere Infos für andere mit rein sollen, dann evtl jetzt mitteilen. Danke.
              M0nk3y
              schrieb am zuletzt editiert von M0nk3y
              #407
              @mcu sagte in jarvis v3.0.0 - just another remarkable vis:
              @andré-müller
              Vielleicht sollten wir da "Reolink" als Kamerahersteller rausnehmen.
              Bei der Lösung von motionEye wird die Kamera (beliebige Hersteller) eingebunden. motionEye nimmt dann bspw. bei Bewegung auf ein NAS auf und hat auch die Mötlichkeit per Webstream das Videobild im LAN zu verteilen - letzteres ist hier im Einsatz.
              M 2 Antworten Letzte Antwort
              • sigi234S sigi234
                Beispiel DP:
                ZefauZ Offline
                ZefauZ Offline
                Zefau
                #408
                Ja, sag ich ja. null ist kein valider Datenpunkt für die Anzeige und i.d.R. nur ein Trigger. Nimm es aus der Datenpunkt-Anzeige raus.
                • ZefauZ Zefau
                  sigi234S Online
                  sigi234S Online
                  #409
                  Einfach löschen?
                  • sigi234S sigi234
                    Einfach löschen?
                    ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    #410
                    Einfach löschen?
                    Jo, einfach raus nehmen. Sollte mit dem Importer auch nicht mehr passieren, dass das rein rutscht. Das Gerät hast du wahrscheinlich nicht selbst erstellt?
                    • ZefauZ Zefau
                      Einfach löschen?
                      sigi234S Online
                      sigi234S Online
                      #411
                      Nein , war einfach da als Import.
                        M0nk3y
                        #412
                        Ich benötige mal bitte ein Tipp für die Müllvisualisierung. Ich habe in der 2.2er Version ein Screenshot einer solchen Darstellung gesehen:
                        Womit mag das realisiert worden sein? Ist das Bild bei jedem Gerät zugeordnet? Wie/Wo wird das Bild hinterlegt?
                        • M M0nk3y
                          Algie
                          #413
                          @m0nk3y Hallo, dass wurde mit dem Adapter "Trashschedule" und VIS gemacht und per iFrame in Jarvis eingebunden.
                            M0nk3y
                            #414
                            @algie Danke!
                            • ZefauZ Zefau
                              Penny2912
                              #415
                              @zefau Also ich bin ja per Backup zurück auf die 2.2.5 und habe dort dann die 3.0.0 drüber installiert. Beim ersten Aufruf von Jarvis v3 ist er in eine Art Loop gekommen und hat die VIS immer wieder neu geladen. Das ist solange passiert bis ich den Tab geschlossen habe. Anschließend habe ich die VIS wieder aufgerufen und dann kam die Einsteiger Tour. Die habe ich mit "Skip" übersprungen und dann war wieder das alte Bild zu sehen: Nur die leeren Container in ihrer richtigen Spalte, aber keine Widgets und keine Daten darin enthalten.
                              Die Datenpunkte sehen so aus: Datenpunkte.png
                              Oder brauchst Du den gesamten Inhalt?
                              Danke schon mal!
                              P 1 Antwort Letzte Antwort
                              • M M0nk3y
                                @andré-müller
                                M Online
                                M Online
                                MCU
                                #416
                                @m0nk3y Kann momentan keine Änderungen eingeben. Hardware Defekt. Mach ich dann in ein paar Tagen.
                                • M MCU
                                  M0nk3y
                                  #417
                                  @mcu Alles gut - na dann viel Erfolg bei der Reparatur!
                                  • H HansWurst 0
                                    @zefau genau das habe ich gemacht. Nach der Neuinstallation von v2 wird mir aber angezeigt, dass ich v3 installiert hätte. Daher muss ich denke ich die v3-Dateien manuell entfernen, oder?
                                    HansWurst 0
                                    schrieb am zuletzt editiert von HansWurst 0
                                    #418
                                    @hanswurst-0 sagte in jarvis v3.0.0 - just another remarkable vis:
                                    @zefau Ok das mit dem Deinstallieren hat nun geklappt, das war mein Fehler. Aber nach Neuinstallation von v2 und dann manuell v3 (beide Installationen ohne Fehler) bekomme ich den gleichen Fehler wie vorher. Die Instanz des Adapters läuft, aber ohne Verbindung zum Host:
                                    Wenn ich versuche Jarvis zu öffnen, bekomme ich den auch schon von anderen Usern bekannten Timeout:
                                    Eine Idee, woran das liegen könnte?
                                    • H HansWurst 0
                                      ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      #419
                                      @hanswurst-0 Fehler im ioBroker Log? Die Instanz startet ja schon nicht.
                                      H 1 Antwort Letzte Antwort
                                      • ZefauZ Zefau
                                        HansWurst 0
                                        #420
                                        @zefau Das sind die Fehler im Log:
                                        ZefauZ 2 Antworten Letzte Antwort
                                        • H HansWurst 0
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #421
                                          @hanswurst-0 ok, da muss ich wohl ran
