  4. GELÖST-Backitup auf Raspi verbindet sich nicht mit Synology
153 Beiträge 7 Kommentatoren 13.0k Aufrufe 6 Beobachtet
  • G gdow1895
    @glasfaser Hier nochmal der Log
    2021-12-27 16:15:43.426 - info: host.raspberrypi4-iob stopInstance system.adapter.backitup.0 (force=false, process=true)
    2021-12-27 16:15:43.473 - info: backitup.0 (29372) Got terminate signal TERMINATE_YOURSELF
    2021-12-27 16:15:43.474 - info: host.raspberrypi4-iob stopInstance system.adapter.backitup.0 send kill signal
    2021-12-27 16:15:43.475 - info: backitup.0 (29372) cleaned everything up...
    2021-12-27 16:15:43.477 - info: backitup.0 (29372) terminating
    2021-12-27 16:15:43.479 - debug: backitup.0 (29372) Plugin sentry destroyed
    2021-12-27 16:15:43.480 - info: backitup.0 (29372) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-12-27 16:15:44.065 - info: host.raspberrypi4-iob instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-12-27 16:15:46.546 - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 5018
    2021-12-27 16:15:47.701 - debug: backitup.0 (5018) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-12-27 16:15:47.742 - debug: backitup.0 (5018) Objects client ready ... initialize now
    2021-12-27 16:15:47.749 - debug: backitup.0 (5018) Objects create System PubSub Client
    2021-12-27 16:15:47.752 - debug: backitup.0 (5018) Objects create User PubSub Client
    2021-12-27 16:15:47.754 - debug: backitup.0 (5018) Objects client initialize lua scripts
    2021-12-27 16:15:47.786 - debug: backitup.0 (5018) Objects connected to redis: 127.0.0.1:9001
    2021-12-27 16:15:47.796 - debug: backitup.0 (5018) objectDB connected
    2021-12-27 16:15:47.799 - debug: backitup.0 (5018) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-12-27 16:15:47.807 - debug: backitup.0 (5018) States create System PubSub Client
    2021-12-27 16:15:47.809 - debug: backitup.0 (5018) States create User PubSub Client
    2021-12-27 16:15:47.817 - debug: backitup.0 (5018) States connected to redis: 127.0.0.1:9000
    2021-12-27 16:15:47.818 - debug: backitup.0 (5018) statesDB connected
    2021-12-27 16:15:48.123 - debug: backitup.0 (5018) Plugin sentry Initialize Plugin (enabled=true)
    2021-12-27 16:15:48.372 - info: backitup.0 (5018) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.22
    2021-12-27 16:15:48.651 - debug: backitup.0 (5018) Backitup has recognized a linux system
    2021-12-27 16:15:48.684 - info: backitup.0 (5018) [iobroker] backup was activated at 02:40 every 1 day(s)
    2021-12-27 16:15:48.788 - debug: backitup.0 (5018) [iobroker] 10 40 02 */1 * *
    2021-12-27 16:15:48.788 - info: backitup.0 (5018) [ccu] backup was activated at 01:30 every 3 day(s)
    2021-12-27 16:15:48.800 - debug: backitup.0 (5018) [ccu] 10 30 01 */3 * *
    2021-12-27 16:15:48.811 - debug: backitup.0 (5018) noserverino option: false
    2021-12-27 16:15:48.812 - debug: backitup.0 (5018) cifs-mount command: "sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.56Backups/ioBroker /opt/iobroker/backups"
    2021-12-27 16:15:55.110 - debug: backitup.0 (5018) first mount attempt with smb option failed. try next mount attempt without smb option ...
    2021-12-27 16:15:55.111 - debug: backitup.0 (5018) cifs-mount command: "sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56Backups/ioBroker /opt/iobroker/backups"
    2021-12-27 16:16:01.358 - error: backitup.0 (5018) Error: Command failed: sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.56/Backups/ioBroker /opt/iobroker/backups
    Unable to find suitable address.
    2021-12-27 16:16:03.372 - debug: backitup.0 (5018) detect backup file 1 from cifs: iobroker_2021_12_11-19_52_28_backupiobroker.tar.gz
    2021-12-27 16:16:03.373 - debug: backitup.0 (5018) detect backup file 2 from cifs: iobroker_2021_12_11-23_48_27_backupiobroker.tar.gz
    2021-12-27 16:16:03.374 - debug: backitup.0 (5018) detect backup file 3 from cifs: iobroker_2021_12_12-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.374 - debug: backitup.0 (5018) detect backup file 4 from cifs: iobroker_2021_12_13-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.375 - debug: backitup.0 (5018) detect backup file 5 from cifs: iobroker_2021_12_14-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.375 - debug: backitup.0 (5018) detect backup file 6 from cifs: iobroker_2021_12_15-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.376 - debug: backitup.0 (5018) detect backup file 7 from cifs: iobroker_2021_12_16-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.376 - debug: backitup.0 (5018) detect backup file 8 from cifs: iobroker_2021_12_17-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.377 - debug: backitup.0 (5018) detect backup file 9 from cifs: iobroker_2021_12_18-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.377 - debug: backitup.0 (5018) detect backup file 10 from cifs: iobroker_2021_12_19-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.378 - debug: backitup.0 (5018) detect backup file 11 from cifs: iobroker_2021_12_20-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.378 - debug: backitup.0 (5018) detect backup file 12 from cifs: iobroker_2021_12_21-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.379 - debug: backitup.0 (5018) detect backup file 13 from cifs: iobroker_2021_12_22-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.379 - debug: backitup.0 (5018) detect backup file 14 from cifs: iobroker_2021_12_23-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.380 - debug: backitup.0 (5018) detect backup file 15 from cifs: iobroker_2021_12_24-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.380 - debug: backitup.0 (5018) detect backup file 16 from cifs: iobroker_2021_12_25-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.380 - debug: backitup.0 (5018) detect backup file 17 from cifs: iobroker_2021_12_26-02_40_10_backupiobroker.tar.gz
    2021-12-27 16:16:03.381 - debug: backitup.0 (5018) detect backup file 18 from cifs: iobroker_2021_12_26-16_20_21_backupiobroker.tar.gz
    2021-12-27 16:16:03.381 - debug: backitup.0 (5018) detect backup file 19 from cifs: iobroker_2021_12_26-16_22_08_backupiobroker.tar.gz
    2021-12-27 16:16:03.382 - debug: backitup.0 (5018) detect backup file 20 from cifs: iobroker_2021_12_26-18_35_28_backupiobroker.tar.gz
    2021-12-27 16:16:03.382 - debug: backitup.0 (5018) detect backup file 21 from cifs: iobroker_2021_12_26-19_10_03_backupiobroker.tar.gz
    2021-12-27 16:16:03.383 - debug: backitup.0 (5018) detect backup file 22 from cifs: iobroker_2021_12_27-09_08_15_backupiobroker.tar.gz
    2021-12-27 16:16:03.383 - debug: backitup.0 (5018) detect backup file 23 from cifs: iobroker_2021_12_27-11_20_25_backupiobroker.tar.gz
    2021-12-27 16:16:03.385 - debug: backitup.0 (5018) detect last backup file: iobroker_2021_12_27-11_20_25_backupiobroker.tar.gz
    @Glasfaser
    mich stört:
    @gdow1895 sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
      aber ich kann über den Finder (MacBook-User) auf den Ordner zugreifen
      das meinte ich
      und da gibst du dann in etwa ein: 192.168.17856/Backup/ioBroker?
      Musst du Passwort und user eingeben?
      gdow1895
      @homoran Wird halt ganz normal im Netzwerk angezeigt und dann muss ich mich mit einem Benutzer anmelden. Siehe "Verbunden als "Guido""
      • G gdow1895
        und klappt das auch als backupuser?
        G 1 Antwort Letzte Antwort
          gdow1895
          @homoran sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
          Ja, klappt auch mit dem backupuser...
          • G gdow1895
            dann dürfte synoseitig alles i.O. sein und wir müssen uns auf den Raspi konzentrieren
            hast du da mal einfach rebootet?
            • G gdow1895
              GlasfaserG Offline
              GlasfaserG Offline
              Die frage wäre warum ist der Pfad direkt nach der IP ohne / dahinter ... ich kann es nicht simulieren
                gdow1895
                @homoran Nicht nur einfach, auch mehrfach. Habe auch "ioBroker stop -> ioBroker fix -> sudo reboot " ausgeführt. Ebenfalls mehrfach. Danach angeblich alles i.O.
                • G gdow1895
                  @gdow1895
                  Hab's jetzt nicht alles gelesen, aber die cifs-utils sind schon installiert, oder?
                  sudo apt update
                  apt policy cifs-utils
                  • GlasfaserG Glasfaser
                    @glasfaser sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
                    Mist! Hab ich nicht gesehen
                    Ich nutze allerdings den Hostnamen der Syno, aber auch keinen / dahinter in der Konfig und auch keinen vor dem Pfad
                      @gdow1895
                      sudo apt update
                      @thomas-braun sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
                      haben wir zumindest nicht geprüft
                        gdow1895
                        @homoran CIFS-Utils sind installiert
                        pi@raspberrypi4-iob:~ $ sudo apt-get install cifs-utils
                        cifs-utils ist schon die neueste Version (2:6.8-2).
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                        Im Adapter hat der Pfad kein führendes "/". Ist aber auch egal ob mit oder ohne. Es kommt immer das gleiche Ergebnis raus. Selbst wenn ich "volume1/" voranstelle.
                        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                        • G gdow1895
                          @gdow1895
                          Ich möchte aber nicht den Installationsvorgang sehen, sondern die Ausgaben auf die obigen beiden Befehle.
                          • G gdow1895
                            GlasfaserG Offline
                            GlasfaserG Offline
                            volume1/
                            gehört auch da nicht rein .
                            so bei mir ...
                            ,vers=3.0 //192.168.178.11/Sicherheit/Homematic/IoBrocker_auf_Synology/Backitup /opt/iobroker/backups"
                              @gdow1895
                              gdow1895
                              @thomas-braun Bitteschön
                              pi@raspberrypi4-iob:~ $ sudo apt update
                              OK:1 http://archive.raspberrypi.org/debian buster InRelease
                              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                              OK:3 http://phoscon.de/apt/deconz buster InRelease
                              OK:4 https://repos.influxdata.com/debian buster InRelease
                              OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                              OK:6 https://deb.nodesource.com/node_14.x buster InRelease
                              Es wurden 15,0 kB in 7 s geholt (2.244 B/s).
                              Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                              pi@raspberrypi4-iob:~ $ apt policy cifs-utils
                              cifs-utils:
                                Installiert:           2:6.8-2
                                Installationskandidat: 2:6.8-2
                                Versionstabelle:
                               *** 2:6.8-2 500
                              • G gdow1895
                                cifs-utils:
                                  Versionstabelle:
                                 *** 2:6.8-2 500
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @gdow1895
                                Welche DSM 6 Version hast du . Syn mal rebootet.
                                  @gdow1895
                                  gdow1895
                                  @glasfaser Synology rebootet gerade. Letzter reboot war vor 15 Tagen. Waren im Urlaub und da habe ich die komplett ausgeschaltet (muss ja nicht durchlaufen).
                                  Version:
                                  • G gdow1895
                                    Version:
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @gdow1895
                                    Ausgabe von :
                                    cat /proc/filesystems|grep cifs
                                      @gdow1895
                                      Ausgabe von :
                                      gdow1895
                                      Synology ist rebootet, hat aber nix geändert.
                                      pi@raspberrypi4-iob:~ $ sudo cat /proc/filesystems|grep cifs
                                      nodev	cifs
                                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                      • G gdow1895
                                        nodev	cifs
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @gdow1895
                                        Warum sudo , habe ich nicht geschrieben !?
                                          @gdow1895
                                          gdow1895
                                          schrieb am zuletzt editiert von gdow1895
                                          #66
                                          @glasfaser Ohne kommt das gleiche raus: "nodev cifs"
                                          Oder muss ich das im ioBroker ausführen? Mit cd /opt/iobroker?
