  3. Cloud Dienste
  4. TV Samsung mit IR Befehl einschalten
    2.6k
    4.6k
    4.0k
50 Beiträge 4 Kommentatoren 9.2k Aufrufe
  • J Offline
    jwedenig
    ok, ich werde mal Bausteine suchen, danke derweilen
    • Alex1808A Offline
      Alex1808A Offline
      Alex1808
      @jwedenig:
      ok, ich werde mal Bausteine suchen, danke derweilen `
      code zum importieren (nur url und Objekt ändern)
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on" id="kP.1v7I*Y3`mx!|fPKt-" x="144" y="65"><field name="OID">javascript.0.Allelichter</field>
      <statement name="STATEMENT"><block type="controls_if" id="0je}1|dt-k.8sBx_{r%0"><mutation elseif="1"></mutation>
          <value name="IF0"><block type="logic_compare" id="qgLyDNe!uWIo*TnXfwsM"><field name="OP">EQ</field>
              <value name="A"><block type="get_value" id="X0u8bqAa:X^kr=J:6z.T"><field name="ATTR">val</field>
                  <field name="OID">javascript.0.Allelichter</field></block></value>
              <value name="B"><block type="logic_boolean" id="|g%N`w]gK`O5jvDQ{V[k"><field name="BOOL">TRUE</field></block></value></block></value>
          <statement name="DO0"><block type="request" id="VG%ff?9s3K{Jab]N(vd."><mutation with_statement="false"></mutation>
              <field name="WITH_STATEMENT">FALSE</field>
              <field name="LOG">log</field>
              <value name="URL"><shadow type="text" id="`fo7-[Yc1WHMyzmV8oz+"><field name="TEXT">http://192.168.2.223/command?code=123456789</field></shadow></value></block></statement>
          <value name="IF1"><block type="logic_compare" id="mVeK0pY]*Ro-I+rK(.,R"><field name="OP">EQ</field>
              <value name="A"><block type="get_value" id="pR/W(4*UiIscBSwT})ve"><field name="ATTR">val</field>
              <value name="B"><block type="logic_boolean" id="L8IC.b2t],!_u4tEqit*"><field name="BOOL">FALSE</field></block></value></block></value>
          <statement name="DO1"><block type="request" id="{ifS/pBBZQI~2A[a3E=D"><mutation with_statement="false"></mutation>
              <value name="URL"><shadow type="text" id="f4Ps7cHhU;[Q}}IB~5qu"><field name="TEXT">http://192.168.2.223/command?code=987654321</field></shadow></value></block></statement></block></statement></block></xml>
       filename="Screenshot at März 15 11-27-06.png" index="0">~~
      • J Offline
        jwedenig
        super, danke, ich adaptiert mal, kann man gleich im Blockly ausführen?
        • Alex1808A Offline
          Alex1808A Offline
          Alex1808
          @jwedenig:
          super, danke, ich adaptiert mal, kann man gleich im Blockly ausführen? `
          nach dem Änderungen, natürlich ;)
          • J Offline
            jwedenig
            ich weiss nur nicht wo?
            • J Offline
              jwedenig
              Leider tut sich nix:
              • J Offline
                jwedenig
                wenn es "Blöcke prüfen" ist dann kommt zwar OK, aber nichts passiert!
                • Alex1808A Offline
                  Alex1808A Offline
                  Alex1808
                  @jwedenig:
                  ich weiss nur nicht wo? `
                  entweder über vis als ein taster oder gehe zu variable und ändere die als Objekt, dann wird es möglich direkt ein Zustand zu zuweisen
                  vis
                  ! filename="Screenshot at März 15 11-46-09.png" index="0">~~
                  direct
                  ! filename="Screenshot at März 15 11-39-21.png" index="1">~~
                  ! filename="Screenshot at März 15 11-40-11.png" index="2">~~
                  • J Offline
                    jwedenig
                    hey, super, wieder einen Schritt weiter, wenn ich bei Objekte "true" schreibe geht der Fernseher an, hurra!
                    Jetzt muss ich nur schauen,ob es auch mit Alexa geht, mal schauen!
                    Danke jedenfalls einmal, wenn ich wieder was brauche, darf ich mich über diesen Thread melden?
                    Liebe Grüße
                    Jürgen
                    • Alex1808A Offline
                      Alex1808A Offline
                      Alex1808
                      @jwedenig:
                      Liebe Grüße
                      Jürgen `
                      Ich denke schon :)
                      Mit freundlichen Grüßen
                      Alex
                      • J Offline
                        jwedenig
                        Da bin ich wieder:
                        Hast Du eine Idee, was ich bezüglich Input Anwahl meines TVs falsch mache?
                        Habe 2 Screenshots!
                        Liebe Grüße Jürgen
                        • Alex1808A Offline
                          Alex1808A Offline
                          Alex1808
                          @jwedenig:
                          Da bin ich wieder:
                          Habe 2 Screenshots!
                          Liebe Grüße Jürgen `
                          Was ist das? Ich sehe bei Samsung Adapter kein "Input selector". Was Input.Sourse angeht da glaube ich wird mit text nicht gearbeitet, sonder 0/1 b.w. false/true
                          ! filename="Screenshot at März 15 16-32-38.png" index="0">~~
                          • Y Offline
                            Y Offline
                            ykuendig
                            @jwedenig:
                            Habe 2 Screenshots! `
                            genau dort kann Alex's Theorie bestätigt werden.
                            Du musst den Samsung.0.Input.HDMI2 auf TRUE setzten
                            Gruss Yves
                            • J Offline
                              jwedenig
                              Meinst Du so?
                              • Y Offline
                                Y Offline
                                ykuendig
                                So ungefähr. ABER ich gebe hier theoretische Tipps.
                                Ich habe kein Apple, kein TV, kein CIA-Samsung super duper Dingens :lol:
                                Aber im Ernst ich meine JA , aber wissen tue ich das nicht.
                                Gruss Yves
                                • J Offline
                                  jwedenig
                                  ok, sobald ich zu Hause bin, spätestens Morgen, werd ichs versuchen und berichte dann.
                                  Danke Liebe Grüße
                                  Jürgen
                                  • J Offline
                                    jwedenig
                                    Leider funktioniert die Input Wahl von meinem Samsung TV nicht so.
                                    Noch eine Idee?
                                    Liebe Grüße Jürgen
                                    • J Offline
                                      jwedenig
                                      Hier noch mal eine Übersicht:
                                      • Alex1808A Offline
                                        Alex1808A Offline
                                        Alex1808
                                        @jwedenig:
                                        Noch eine Idee?
                                        Versuche mit Input.HDMI, ob es da was passiert.. Nicht alle Fernsehen können Direct über HDMI2, HDMI3 und s.w. geschaltet werden.
                                        • J Offline
                                          jwedenig
                                          Ja, wenn ich es so mache schaltet er auf hdmi2 um, nur wie wähle ich jetzt andere Inputs an? z.B. wieder zurück auf Tv Input wenn "false"?
