  4. Test Alpha Homekit-Controller 0.0.x
260 Beiträge 27 Kommentatoren 62.5k Aufrufe 24 Beobachtet
  • StrathColeS StrathCole
    @apollon77 sagte in Test Alpha Homekit-Controller 0.0.x:
    @strathcole ppuuhhh da antwortet das device nicht so wie es sollte beim pairen.
    Kannst du es mir Apple Home App Pairen?
    Habe keinerlei iOS Geräte. Daher kann ich so etwas leider nicht testen.
    Ansonsten musst du mit mehr debug machen wie es hier im thread weiter oben steht --> https://forum.iobroker.net/post/720099
    .0","callback":{"message":{"deviceId":"BLE-XXXXXXXXX","pin":"xxxx-xxxx"},"id":226,"ack":false,"time":1639987045204},"_id":6119781})
      hap-controller:gatt-connection connect peripheral +16s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Write for characteristic 0000004f0000100080000026bb765291 0003000d00 +4s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Received data for characteristic 0000004f0000100080000026bb765291 0200000300010101 +59ms
      hap-controller:gatt-connection disconnect peripheral +1ms
      hap-controller:gatt-connection Peripheral disconnected +15ms
    2021-12-20 08:57:28.894  - debug: homekit-controller.0 (7491) BLE-XXXXXXXXX Start Homekit Device Client initialization
      hap-controller:gatt-connection connect peripheral +20ms
      hap-controller:tlv Add 1 bytes for tag 6: 01 +23s
      hap-controller:tlv Add 1 bytes for tag 0: 00 +1ms
      hap-controller:tlv Add 6 bytes for tag 1: 060101000100 +1ms
      hap-controller:tlv Add 1 bytes for tag 9: 01 +1ms
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Write for characteristic 0000004c0000100080000026bb765291 0002000b000b000106060101000100090101 +3s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Received data for characteristic 0000004c0000100080000026bb765291 0200009d0101ff06010203ff9c87f60bd1cf8502b3b4 +2s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Received data for characteristic 0000004c0000100080000026bb765291  +45ms
      hap-controller:tlv Read 255 bytes for tag 1: 06010203ff9c87f60bd1cf8502b3b4 +2s
      hap-controller:tlv Read 1 bytes for tag 6: 02 +1ms
      hap-controller:tlv Read 255 bytes for tag 3: 9c87f60bd1cf8502b3b4 +1ms
    2021-12-20 08:57:33.303  - debug: homekit-controller.0 (7491) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-XXXXXXXXX because of error undefined (undefined): M2: Missing salt"}
    2021-12-20 08:57:33.305  - debug: homekit-controller.0 (7491) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
    Vom Device:
      "type": "folder",
      "common": {
        "name": "Nuki_324566 (BLE-XXXXXXXXX)"
      "native": {
        "serviceType": "BLE",
        "id": "BLE-XXXXXXXXX",
        "lastService": {
          "name": "Nuki_xxxxxxx",
          "CoID": 76,
          "TY": 6,
          "AIL": 49,
          "SF": 1,
          "DeviceID": "yyyyyyyyyyyy",
          "ACID": 6,
          "GSN": 1,
          "CN": 2,
          "CV": 2,
          "c#": 2,
          "id": "XXXXXXXXX",
          "ci": 6,
          "availableToPair": true
      "from": "system.adapter.homekit-controller.0",
      "user": "system.user.admin",
      "ts": 1639986435029,
      "_id": "homekit-controller.0.BLE-XXXXXXXXX",
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
    #106
    @strathcole PS: Also wnen das Log wirklich so ist dann ist es ... ja ... so das die Nuki nicht nach Apple Home Spec antwortet. Es fehlt der "Salt" in den Daten die das Gerät auf die erste Pair Anfrage zurückgibt.
    Von daher müsste man echt versuchen ob es mit Apple Home geht. Wenn ja muss man ggf experimentieren. Wenn Apple home auch nicht tut musst du dich an den Nuki Support wenden. Ggf mal schauen ob es Firmware updates gibt?
    • luup smartL Offline
      luup smartL Offline
      luup smart
      #107
      Hallo @apollon77 ,
      ich habe ein Problem mit meinem Eve Degree und Eve Thermo.
      Der Adapter findet die Geräte und man hat auch die Auswahl sie zu identifizieren oder zu pairen. Leider kommt bei beiden Geräten immer eine Fehlermeldung.
      hier die Fehlermeldung beim identifizieren:
      und die Fehlermeldung die ich beim pairen bekomme:
      Hier wäre auch mal ein debug log, in dem ich versuche zu identifizieren und zu pairen.
      Siehst du vielleicht an was es liegen könnte?
      2021-12-20 21:32:40.373 - info: host.raspberrypi "system.adapter.homekit-controller.0" enabled
      2021-12-20 21:32:40.543 - info: host.raspberrypi instance system.adapter.homekit-controller.0 started with pid 7772
      2021-12-20 21:32:41.792 - debug: homekit-controller.0 (7772) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-12-20 21:32:41.860 - debug: homekit-controller.0 (7772) Objects client ready ... initialize now
      2021-12-20 21:32:41.864 - debug: homekit-controller.0 (7772) Objects create System PubSub Client
      2021-12-20 21:32:41.867 - debug: homekit-controller.0 (7772) Objects create User PubSub Client
      2021-12-20 21:32:41.869 - debug: homekit-controller.0 (7772) Objects client initialize lua scripts
      2021-12-20 21:32:41.951 - debug: homekit-controller.0 (7772) Objects connected to redis: 127.0.0.1:9001
      2021-12-20 21:32:41.955 - silly: homekit-controller.0 (7772) redis psubscribe cfg.o.system.user.*
      2021-12-20 21:32:41.962 - debug: homekit-controller.0 (7772) objectDB connected
      2021-12-20 21:32:41.976 - debug: homekit-controller.0 (7772) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-12-20 21:32:42.034 - debug: homekit-controller.0 (7772) States create System PubSub Client
      2021-12-20 21:32:42.036 - debug: homekit-controller.0 (7772) States create User PubSub Client
      2021-12-20 21:32:42.065 - debug: homekit-controller.0 (7772) States connected to redis: 127.0.0.1:9000
      2021-12-20 21:32:42.066 - debug: homekit-controller.0 (7772) statesDB connected
      2021-12-20 21:32:42.350 - debug: homekit-controller.0 (7772) Plugin sentry Initialize Plugin (enabled=true)
      2021-12-20 21:32:42.898 - info: homekit-controller.0 (7772) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:32:43.131 - silly: homekit-controller.0 (7772) States system redis pmessage system.adapter.homekit-controller.0.logLevel/system.adapter.homekit-controller.0.logLevel:{"val":"silly","ack":true,"ts":1640032363116,"q":0,"from":"system.adapter.homekit-controller.0","lc":1639997736189}
      2021-12-20 21:32:43.168 - debug: homekit-controller.0 (7772) Init 3 known devices without discovery ...
      2021-12-20 21:32:43.170 - info: homekit-controller.0 (7772) BLE-D0:90:C0:FA:26:0A (Eve Degree CE8E) found without pairing data but available for pairing: Create basic objects
      2021-12-20 21:32:43.171 - debug: homekit-controller.0 (7772) Service: {"name":"Eve Degree CE8E","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"d0:90:c0:fa:26:0a","ACID":10,"GSN":9,"CN":3,"CV":2,"c#":3,"id":"d0:90:c0:fa:26:0a","ci":10,"availableToPair":true}
      2021-12-20 21:32:43.193 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.info.connection:{"val":false,"ack":true,"ts":1640032363175,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639996763128}
      2021-12-20 21:32:43.197 - debug: homekit-controller.0 (7772) state homekit-controller.0.info.connection changed: false (ack = true)
      2021-12-20 21:32:43.248 - debug: homekit-controller.0 (7772) Discovered IP device up: E3:51:E1:BD:E4:9B/Philips hue - 2237EF
      2021-12-20 21:32:43.249 - debug: homekit-controller.0 (7772) IP-E3:51:E1:BD:E4:9B Discovered IP device: {"name":"Philips hue - 2237EF","address":"192.168.178.77","port":8080,"c#":32,"ff":1,"id":"E3:51:E1:BD:E4:9B","md":"BSB002","pv":"1.1","s#":307,"sf":0,"ci":2,"availableToPair":false}
      2021-12-20 21:32:43.249 - info: homekit-controller.0 (7772) IP-E3:51:E1:BD:E4:9B (Philips hue - 2237EF) found without known pairing data and already paired: ignoring
      2021-12-20 21:32:43.306 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.connectionType:{"val":"BLE","ack":true,"ts":1640032363304,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997024319}
      2021-12-20 21:32:43.307 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.connectionType changed: BLE (ack = true)
      2021-12-20 21:32:43.318 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.id:{"val":"d0:90:c0:fa:26:0a","ack":true,"ts":1640032363315,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997024340}
      2021-12-20 21:32:43.320 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.id changed: d0:90:c0:fa:26:0a (ack = true)
      2021-12-20 21:32:43.351 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.connected:{"val":false,"ack":true,"ts":1640032363348,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997024348}
      2021-12-20 21:32:43.353 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.connected changed: false (ack = true)
      2021-12-20 21:32:43.372 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-D0:90:C0:FA:26:0A.admin.isPaired:{"val":false,"ack":true,"ts":1640032363370,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997024359}
      2021-12-20 21:32:43.374 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-D0:90:C0:FA:26:0A.admin.isPaired changed: false (ack = true)
      2021-12-20 21:32:43.389 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.lastDiscovered:{"val":1640032363173,"ack":true,"ts":1640032363386,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1640032363386}
      2021-12-20 21:32:43.390 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-D0:90:C0:FA:26:0A.info.lastDiscovered changed: 1640032363173 (ack = true)
      2021-12-20 21:32:43.403 - info: homekit-controller.0 (7772) BLE-51:E5:E1:EE:94:26 (Eve Degree CE8E) found without pairing data but available for pairing: Create basic objects
      2021-12-20 21:32:43.403 - debug: homekit-controller.0 (7772) Service: {"name":"Eve Degree CE8E","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"51:e5:e1:ee:94:26","ACID":10,"GSN":4,"CN":3,"CV":2,"c#":3,"id":"51:e5:e1:ee:94:26","ci":10,"availableToPair":true}
      2021-12-20 21:32:43.444 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connectionType:{"val":"BLE","ack":true,"ts":1640032363441,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204892}
      2021-12-20 21:32:43.446 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connectionType changed: BLE (ack = true)
      2021-12-20 21:32:43.506 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.id:{"val":"51:e5:e1:ee:94:26","ack":true,"ts":1640032363504,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204923}
      2021-12-20 21:32:43.508 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.id changed: 51:e5:e1:ee:94:26 (ack = true)
      2021-12-20 21:32:43.518 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connected:{"val":false,"ack":true,"ts":1640032363516,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204935}
      2021-12-20 21:32:43.521 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connected changed: false (ack = true)
      2021-12-20 21:32:43.535 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.admin.isPaired:{"val":false,"ack":true,"ts":1640032363533,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204947}
      2021-12-20 21:32:43.537 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.admin.isPaired changed: false (ack = true)
      2021-12-20 21:32:43.596 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.lastDiscovered:{"val":1640032363404,"ack":true,"ts":1640032363594,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1640032363594}
      2021-12-20 21:32:43.597 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.lastDiscovered changed: 1640032363404 (ack = true)
      2021-12-20 21:32:43.617 - info: homekit-controller.0 (7772) BLE-BD:1D:5A:A0:4B:BD (Eve Thermo 4A8B) found without pairing data but available for pairing: Create basic objects
      2021-12-20 21:32:43.618 - debug: homekit-controller.0 (7772) Service: {"name":"Eve Thermo 4A8B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"bd:1d:5a:a0:4b:bd","ACID":9,"GSN":2,"CN":5,"CV":2,"c#":5,"id":"bd:1d:5a:a0:4b:bd","ci":9,"availableToPair":true}
      2021-12-20 21:32:43.650 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connectionType:{"val":"BLE","ack":true,"ts":1640032363648,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999277985}
      2021-12-20 21:32:43.653 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connectionType changed: BLE (ack = true)
      2021-12-20 21:32:43.671 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.id:{"val":"bd:1d:5a:a0:4b:bd","ack":true,"ts":1640032363669,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999278008}
      2021-12-20 21:32:43.672 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.id changed: bd:1d:5a:a0:4b:bd (ack = true)
      2021-12-20 21:32:43.726 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connected:{"val":false,"ack":true,"ts":1640032363724,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999278041}
      2021-12-20 21:32:43.728 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connected changed: false (ack = true)
      2021-12-20 21:32:43.750 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.admin.isPaired:{"val":false,"ack":true,"ts":1640032363748,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999278076}
      2021-12-20 21:32:43.752 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.admin.isPaired changed: false (ack = true)
      2021-12-20 21:32:43.770 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.lastDiscovered:{"val":1640032363618,"ack":true,"ts":1640032363766,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1640032363766}
      2021-12-20 21:32:43.774 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.lastDiscovered changed: 1640032363618 (ack = true)
      2021-12-20 21:32:45.307 - debug: homekit-controller.0 (7772) Discovered BLE device up: 51:e5:e1:ee:94:26/Eve
      2021-12-20 21:32:45.308 - debug: homekit-controller.0 (7772) BLE-51:E5:E1:EE:94:26 Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"51:e5:e1:ee:94:26","ACID":10,"GSN":4,"CN":3,"CV":2,"c#":3,"id":"51:e5:e1:ee:94:26","ci":10,"availableToPair":true}
      2021-12-20 21:32:45.309 - info: homekit-controller.0 (7772) BLE-51:E5:E1:EE:94:26 (Eve) found without pairing data but available for pairing: Create basic objects
      2021-12-20 21:32:45.310 - debug: homekit-controller.0 (7772) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"51:e5:e1:ee:94:26","ACID":10,"GSN":4,"CN":3,"CV":2,"c#":3,"id":"51:e5:e1:ee:94:26","ci":10,"availableToPair":true}
      2021-12-20 21:32:45.857 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connectionType:{"val":"BLE","ack":true,"ts":1640032365847,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204892}
      2021-12-20 21:32:45.859 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connectionType changed: BLE (ack = true)
      2021-12-20 21:32:45.952 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.id:{"val":"51:e5:e1:ee:94:26","ack":true,"ts":1640032365950,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204923}
      2021-12-20 21:32:45.955 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.id changed: 51:e5:e1:ee:94:26 (ack = true)
      2021-12-20 21:32:45.969 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connected:{"val":false,"ack":true,"ts":1640032365967,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204935}
      2021-12-20 21:32:45.971 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.connected changed: false (ack = true)
      2021-12-20 21:32:45.990 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.admin.isPaired:{"val":false,"ack":true,"ts":1640032365987,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639997204947}
      2021-12-20 21:32:45.992 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.admin.isPaired changed: false (ack = true)
      2021-12-20 21:32:46.011 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.lastDiscovered:{"val":1640032365311,"ack":true,"ts":1640032366009,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1640032366009}
      2021-12-20 21:32:46.012 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-51:E5:E1:EE:94:26.info.lastDiscovered changed: 1640032365311 (ack = true)
      2021-12-20 21:32:46.049 - debug: homekit-controller.0 (7772) Discovered BLE device up: bd:1d:5a:a0:4b:bd/Eve Thermo 4A8B
      2021-12-20 21:32:46.049 - debug: homekit-controller.0 (7772) BLE-BD:1D:5A:A0:4B:BD Discovered BLE device: {"name":"Eve Thermo 4A8B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"bd:1d:5a:a0:4b:bd","ACID":9,"GSN":2,"CN":5,"CV":2,"c#":5,"id":"bd:1d:5a:a0:4b:bd","ci":9,"availableToPair":true}
      2021-12-20 21:32:46.050 - info: homekit-controller.0 (7772) BLE-BD:1D:5A:A0:4B:BD (Eve Thermo 4A8B) found without pairing data but available for pairing: Create basic objects
      2021-12-20 21:32:46.051 - debug: homekit-controller.0 (7772) Service: {"name":"Eve Thermo 4A8B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"bd:1d:5a:a0:4b:bd","ACID":9,"GSN":2,"CN":5,"CV":2,"c#":5,"id":"bd:1d:5a:a0:4b:bd","ci":9,"availableToPair":true}
      2021-12-20 21:32:46.119 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connectionType:{"val":"BLE","ack":true,"ts":1640032366116,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999277985}
      2021-12-20 21:32:46.121 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connectionType changed: BLE (ack = true)
      2021-12-20 21:32:46.134 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.id:{"val":"bd:1d:5a:a0:4b:bd","ack":true,"ts":1640032366132,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999278008}
      2021-12-20 21:32:46.136 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.id changed: bd:1d:5a:a0:4b:bd (ack = true)
      2021-12-20 21:32:46.186 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connected:{"val":false,"ack":true,"ts":1640032366184,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999278041}
      2021-12-20 21:32:46.187 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.connected changed: false (ack = true)
      2021-12-20 21:32:46.202 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.admin.isPaired:{"val":false,"ack":true,"ts":1640032366200,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1639999278076}
      2021-12-20 21:32:46.204 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.admin.isPaired changed: false (ack = true)
      2021-12-20 21:32:46.223 - silly: homekit-controller.0 (7772) States user redis pmessage homekit-controller.0.*/homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.lastDiscovered:{"val":1640032366052,"ack":true,"ts":1640032366221,"q":0,"from":"system.adapter.homekit-controller.0","user":"system.user.admin","lc":1640032366221}
      2021-12-20 21:32:46.225 - debug: homekit-controller.0 (7772) state homekit-controller.0.BLE-BD:1D:5A:A0:4B:BD.info.lastDiscovered changed: 1640032366052 (ack = true)
      2021-12-20 21:32:46.884 - silly: homekit-controller.0 (7772) States system redis pmessage io.messagebox.system.adapter.homekit-controller.0/io.messagebox.system.adapter.homekit-controller.0:{"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":323,"ack":false,"time":1640032366881},"_id":26091375}
      2021-12-20 21:32:46.886 - debug: homekit-controller.0 (7772) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":323,"ack":false,"time":1640032366881},"_id":26091375})
      2021-12-20 21:32:46.888 - debug: homekit-controller.0 (7772) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-D0:90:C0:FA:26:0A","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree CE8E","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-51:E5:E1:EE:94:26","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-BD:1D:5A:A0:4B:BD","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Thermo 4A8B","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-E3:51:E1:BD:E4:9B","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Philips hue - 2237EF","discoveredCategory":"Bridge","pairedWithThisInstance":false}]}
      2021-12-20 21:32:46.890 - debug: homekit-controller.0 (7772) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
      2021-12-20 21:32:58.260 - silly: homekit-controller.0 (7772) States system redis pmessage io.messagebox.system.adapter.homekit-controller.0/io.messagebox.system.adapter.homekit-controller.0:{"command":"identify","message":{"deviceId":"BLE-D0:90:C0:FA:26:0A"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-D0:90:C0:FA:26:0A"},"id":324,"ack":false,"time":1640032378257},"_id":26091376}
      2021-12-20 21:32:58.262 - debug: homekit-controller.0 (7772) Message identify received: {"command":"identify","message":{"deviceId":"BLE-D0:90:C0:FA:26:0A"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-D0:90:C0:FA:26:0A"},"id":324,"ack":false,"time":1640032378257},"_id":26091376})
      2021-12-20 21:32:58.263 - debug: homekit-controller.0 (7772) Device BLE-D0:90:C0:FA:26:0A: Identify triggered
      2021-12-20 21:32:58.270 - debug: homekit-controller.0 (7772) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-D0:90:C0:FA:26:0A because of error undefined: Cannot read property 'state' of undefined"}
      2021-12-20 21:32:58.271 - debug: homekit-controller.0 (7772) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
      2021-12-20 21:33:03.495 - silly: homekit-controller.0 (7772) States system redis pmessage io.messagebox.system.adapter.homekit-controller.0/io.messagebox.system.adapter.homekit-controller.0:{"command":"identify","message":{"deviceId":"BLE-51:E5:E1:EE:94:26"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-51:E5:E1:EE:94:26"},"id":326,"ack":false,"time":1640032383492},"_id":26091378}
      2021-12-20 21:33:03.497 - debug: homekit-controller.0 (7772) Message identify received: {"command":"identify","message":{"deviceId":"BLE-51:E5:E1:EE:94:26"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-51:E5:E1:EE:94:26"},"id":326,"ack":false,"time":1640032383492},"_id":26091378})
      2021-12-20 21:33:03.498 - debug: homekit-controller.0 (7772) Device BLE-51:E5:E1:EE:94:26: Identify triggered
      2021-12-20 21:33:06.195 - debug: homekit-controller.0 (7772) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-51:E5:E1:EE:94:26 because of error undefined: undefined"}
      2021-12-20 21:33:06.196 - debug: homekit-controller.0 (7772) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
      2021-12-20 21:33:17.701 - silly: homekit-controller.0 (7772) States system redis pmessage io.messagebox.system.adapter.homekit-controller.0/io.messagebox.system.adapter.homekit-controller.0:{"command":"identify","message":{"deviceId":"BLE-BD:1D:5A:A0:4B:BD"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BD:1D:5A:A0:4B:BD"},"id":327,"ack":false,"time":1640032397698},"_id":26091379}
      2021-12-20 21:33:17.702 - debug: homekit-controller.0 (7772) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BD:1D:5A:A0:4B:BD"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BD:1D:5A:A0:4B:BD"},"id":327,"ack":false,"time":1640032397698},"_id":26091379})
      2021-12-20 21:33:17.703 - debug: homekit-controller.0 (7772) Device BLE-BD:1D:5A:A0:4B:BD: Identify triggered
      2021-12-20 21:33:19.811 - debug: homekit-controller.0 (7772) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-BD:1D:5A:A0:4B:BD because of error undefined: undefined"}
      2021-12-20 21:33:19.813 - debug: homekit-controller.0 (7772) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
      2021-12-20 21:33:40.333 - silly: homekit-controller.0 (7772) States system redis pmessage io.messagebox.system.adapter.homekit-controller.0/io.messagebox.system.adapter.homekit-controller.0:{"command":"pairDevice","message":{"deviceId":"BLE-51:E5:E1:EE:94:26","pin":"343-86-912 "},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-51:E5:E1:EE:94:26","pin":"343-86-912 "},"id":328,"ack":false,"time":1640032420331},"_id":26091380}
      2021-12-20 21:33:40.335 - debug: homekit-controller.0 (7772) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-51:E5:E1:EE:94:26","pin":"343-86-912 "},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-51:E5:E1:EE:94:26","pin":"343-86-912 "},"id":328,"ack":false,"time":1640032420331},"_id":26091380})
      2021-12-20 21:33:43.349 - debug: homekit-controller.0 (7772) Response to Command pairDevice: {"success":false,"error":"Cannot retrieve BLE PairMethod for device BLE-51:E5:E1:EE:94:26 because of error undefined: undefined"}
      2021-12-20 21:33:43.350 - debug: homekit-controller.0 (7772) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
      • luup smartL luup smart
        Hallo @apollon77 ,
        #108
        @luup-smart Ok, also Beim Degree oben ging Identify und nur pair hat gesponnen :-(
        Dann bitte ebenso fr die identifies die nicht gehen ein "mehr Debug" ala https://forum.iobroker.net/post/720099
        luup smartL 1 Antwort Letzte Antwort
        • apollon77A apollon77
          luup smartL Offline
          luup smartL Offline
          luup smart
          #109
          @apollon77 Okay, hier wäre der log. :)
          Debug_shell_homekit-controller
            #110
            @luup-smart
            hap-controller:gatt-connection connect peripheral +0ms
            hap-controller:gatt-connection disconnect peripheral +3s
            hap-controller:gatt-connection Peripheral disconnected +50ms
            Der Adapter bekommt keine verbindung. Ist das BLE Device frei und nicht von jemand anderem Belegt wie radar2 oder so?
            Aufgabe von "rfkill"?
              @luup-smart
              luup smartL Offline
              luup smartL Offline
              luup smart
              #111
              @apollon77 Das BLE Device sollte frei sein. Also ich hab keine andern Adapter die BLE verwenden.
              pi@raspberrypi:~ $ rfkill
              ID TYPE      DEVICE      SOFT      HARD
               0 wlan      phy0   unblocked unblocked
               1 bluetooth hci0   unblocked unblocked
                Vom Device:
                  "type": "folder",
                  "common": {
                  "native": {
                    "lastService": {
                      "CoID": 76,
                      "TY": 6,
                      "AIL": 49,
                      "SF": 1,
                      "ACID": 6,
                      "GSN": 1,
                      "CN": 2,
                      "CV": 2,
                      "c#": 2,
                      "id": "XXXXXXXXX",
                      "ci": 6,
                  "acl": {
                    "object": 1636,
                #112
                @strathcole Dduuuuuu ... weil ich grad mit nem anderen user dran bin: Wie hast Du denn die PIN eingegeben? Mit oder Ohne Bindestriche? Falls ohne Bindestriche ... mach mal mit XXX-XX-XXX?
                UUUUNDDDD: Bring mal das Schloss in den Pairing Modus bevor du es versuchst!!! Der andere User hatte den Fehler mit "No salt " auch als das gerät NICHT im Pairing Modus war. Falls du als nächstes nen fehler bekommst das er die PairingMethod nicht ermitteln kann -> GitHub version versuchen
                StrathColeS 1 Antwort Letzte Antwort
                  StrathColeS Offline
                  StrathColeS Offline
                  StrathCole
                  #113
                  @apollon77 Danke fürs weiter Untersuchen.
                  Die PIN-Varianten habe ich alle durch. XXXXXXXX, XXXX-XXXX und XXX-XX-XXX
                  Allerdings kommt jetzt mit der Github-Variante eine ganz neue Meldung:
                  Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-XX:XX:XX:XX:XX because of error undefined (undefined): pair-setup characteristic not found"}
                  SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
                  apollon77A 2 Antworten Letzte Antwort
                    #114
                    @strathcole mit oder ohne das Gerät im
                    Pair Modus zu haben? Also mach mal so wie vorher auch.
                      #115
                      @strathcole ANsonsten nochmal neu GitHub bitte :-) (Manuell adapter nach Update neu starten)
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        schrieb am zuletzt editiert von StrathCole
                        #116
                        Habe beides versucht. Mit und ohne pair modus. Selbes Ergebnis (siehe unten).
                        Leider weiterhin Cannot pair with device BLE-XXX because of error undefined (undefined): pair-setup characteristic not found.
                        Beim zweiten Versuch ohne Pairing-Modus kam dann wieder "Salt not found" und beim dritten Versuch (mit Pairing-Modus) dann nur noch: Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-XXX because of error undefined (undefined): undefined"}. Wenn dieser Fehler kommt (also undefined), dauert es aber auch ziemlich lange, so als würde er dann in einen Timeout rennen. Zwischen Start Homekit Device Client initialization und dem Fehler liegen fast genau 20 Sekunden jedes Mal. Wärend beim "Missing Salt" der Fehler schon nach 2 Sekunden kommt.
                          StrathColeS Offline
                          StrathColeS Offline
                          StrathCole
                          #117
                          @apollon77 Nachtrag dazu: Die 20 Sekunden scheinen der Zeitraum zu sein, nach dem dann das Nuki den Pairing-Modus wieder abschaltet. Dann gehen die LED wieder aus und gleichzeitig kommt dann die Fehlermeldung. Und ohne den Modus kommt wie gesagt immer das mit Missing Salt.
                          Es scheinen 30 Sekunden zu sein, nicht 20. Denke mal, der Unterschied sind die Sekunden, die ich brauche vom Pairing-Modus an bis Pin-Eingabe.
                          hap-controller:gatt-connection Peripheral disconnected +30s
                          Log von Pair-Modus aktivieren über PIN-Eingabe bis Fehlermeldung habe ich gemailt.
                          • apollon77A Offline
                            #118
                            Ja soweit war ich mit dem anderen user auch. Es scheint so als ob der "Pairing Modus" eher dafür ist das Nuki mit seiner Bridge zu Pairen und gar nicht für HomeKit :-) Scheinbar ist Homekit Pairing in dem Zeitraum aus - was den oben genannten Fehler erklärt.
                            Es ist auch so - zumindestens im test - das sich das Nuki auch gar nicht mit Apple Home direkt Pairen lässt, sondern das ganze nur über die Nuki App geht, wo es dann danach in Apple Home ist - also die Nuki App pusht das Gerät zu Apple Home .... Das könnte es erklären warum es mit dem Adapter nicht geht. Da wären wir dann aber soweit raus :-(
                            StrathColeS 2 Antworten Letzte Antwort
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #119
                              @apollon77 also in der Nuki Anleitung steht nur, dass man in der Home App den QR scannen soll und das dann angeblich geht. Aber wie gesagt, steht mir leider kein iOS Gerät zur Verfügung. Nutzen alle Android.
                                StrathColeS Offline
                                StrathColeS Offline
                                StrathCole
                                #120
                                @apollon77 ach ja, ich habe übrigens ein Nuki 3.0 pro. Nur falls das relevant ist.
                                  #121
                                  @strathcole sagte in Test Alpha Homekit-Controller 0.0.x:
                                  Naja der andere user hat es so halt auch nicht hinbekommen sondern nur über die Nuki App
                                    StrathColeS Offline
                                    StrathColeS Offline
                                    StrathCole
                                    #122
                                    @apollon77 Na gut, dann … warte ich einfach mal, bis mir irgendwann irgendwer unterkommt, der hier mit einem iPhone reinschneit 😆
                                      #123
                                      @strathcole Naja das it der andere User, aber kommen auch nicht so wirklich weiter bis auf die Details die ich oben schon gesagt hab
                                        Minta79
                                        #124
                                        Ich nutze seit gestern den Adapter in Version 0.3.3. Leider steht die Instanz nach kurzer Zeit immer auf "Nicht Verbunden mit Gerät oder Dienst". Ich habe einen Onvis-Türkontakt per Bluetooth verbunden. Hat jemand einen Tipp für mich, was das Problem sein könnte?
                                        • M Minta79
                                          #125
                                          @minta79 Was sagt das Log? Ggf mal bitte Loglevel auf Debug und laufen lassen und dann zeigen wenn es "offline" geht
