  4. Test Alpha Homekit-Controller 0.0.x
260 Beiträge 27 Kommentatoren 62.5k Aufrufe 24 Beobachtet
  • StrathColeS StrathCole
    @apollon77 sagte in Test Alpha Homekit-Controller 0.0.x:
    @strathcole ppuuhhh da antwortet das device nicht so wie es sollte beim pairen.
    Kannst du es mir Apple Home App Pairen?
    Habe keinerlei iOS Geräte. Daher kann ich so etwas leider nicht testen.
    Ansonsten musst du mit mehr debug machen wie es hier im thread weiter oben steht --> https://forum.iobroker.net/post/720099
    .0","callback":{"message":{"deviceId":"BLE-XXXXXXXXX","pin":"xxxx-xxxx"},"id":226,"ack":false,"time":1639987045204},"_id":6119781})
      hap-controller:gatt-connection connect peripheral +16s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Write for characteristic 0000004f0000100080000026bb765291 0003000d00 +4s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Received data for characteristic 0000004f0000100080000026bb765291 0200000300010101 +59ms
      hap-controller:gatt-connection disconnect peripheral +1ms
      hap-controller:gatt-connection Peripheral disconnected +15ms
    2021-12-20 08:57:28.894  - debug: homekit-controller.0 (7491) BLE-XXXXXXXXX Start Homekit Device Client initialization
      hap-controller:gatt-connection connect peripheral +20ms
      hap-controller:tlv Add 1 bytes for tag 6: 01 +23s
      hap-controller:tlv Add 1 bytes for tag 0: 00 +1ms
      hap-controller:tlv Add 6 bytes for tag 1: 060101000100 +1ms
      hap-controller:tlv Add 1 bytes for tag 9: 01 +1ms
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Write for characteristic 0000004c0000100080000026bb765291 0002000b000b000106060101000100090101 +3s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Received data for characteristic 0000004c0000100080000026bb765291 0200009d0101ff06010203ff9c87f60bd1cf8502b3b4 +2s
      hap-controller:gatt-connection XXXXXXXXX/XXXXXXXXX Received data for characteristic 0000004c0000100080000026bb765291  +45ms
      hap-controller:tlv Read 255 bytes for tag 1: 06010203ff9c87f60bd1cf8502b3b4 +2s
      hap-controller:tlv Read 1 bytes for tag 6: 02 +1ms
      hap-controller:tlv Read 255 bytes for tag 3: 9c87f60bd1cf8502b3b4 +1ms
    2021-12-20 08:57:33.303  - debug: homekit-controller.0 (7491) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-XXXXXXXXX because of error undefined (undefined): M2: Missing salt"}
    2021-12-20 08:57:33.305  - debug: homekit-controller.0 (7491) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
    Vom Device:
      "type": "folder",
      "common": {
        "name": "Nuki_324566 (BLE-XXXXXXXXX)"
      "native": {
        "serviceType": "BLE",
        "id": "BLE-XXXXXXXXX",
        "lastService": {
          "name": "Nuki_xxxxxxx",
          "CoID": 76,
          "TY": 6,
          "AIL": 49,
          "SF": 1,
          "DeviceID": "yyyyyyyyyyyy",
          "ACID": 6,
          "GSN": 1,
          "CN": 2,
          "CV": 2,
          "c#": 2,
          "id": "XXXXXXXXX",
          "ci": 6,
          "availableToPair": true
      "from": "system.adapter.homekit-controller.0",
      "user": "system.user.admin",
      "ts": 1639986435029,
      "_id": "homekit-controller.0.BLE-XXXXXXXXX",
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
    #112
    @strathcole Dduuuuuu ... weil ich grad mit nem anderen user dran bin: Wie hast Du denn die PIN eingegeben? Mit oder Ohne Bindestriche? Falls ohne Bindestriche ... mach mal mit XXX-XX-XXX?
    UUUUNDDDD: Bring mal das Schloss in den Pairing Modus bevor du es versuchst!!! Der andere User hatte den Fehler mit "No salt " auch als das gerät NICHT im Pairing Modus war. Falls du als nächstes nen fehler bekommst das er die PairingMethod nicht ermitteln kann -> GitHub version versuchen
    StrathColeS 1 Antwort Letzte Antwort
    • apollon77A apollon77
      StrathColeS Offline
      StrathColeS Offline
      StrathCole
      #113
      @apollon77 Danke fürs weiter Untersuchen.
      Die PIN-Varianten habe ich alle durch. XXXXXXXX, XXXX-XXXX und XXX-XX-XXX
      Allerdings kommt jetzt mit der Github-Variante eine ganz neue Meldung:
      Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-XX:XX:XX:XX:XX because of error undefined (undefined): pair-setup characteristic not found"}
      SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
      apollon77A 2 Antworten Letzte Antwort
        #114
        @strathcole mit oder ohne das Gerät im
        Pair Modus zu haben? Also mach mal so wie vorher auch.
          #115
          @strathcole ANsonsten nochmal neu GitHub bitte :-) (Manuell adapter nach Update neu starten)
            StrathColeS Offline
            StrathColeS Offline
            StrathCole
            schrieb am zuletzt editiert von StrathCole
            #116
            Habe beides versucht. Mit und ohne pair modus. Selbes Ergebnis (siehe unten).
            Leider weiterhin Cannot pair with device BLE-XXX because of error undefined (undefined): pair-setup characteristic not found.
            Beim zweiten Versuch ohne Pairing-Modus kam dann wieder "Salt not found" und beim dritten Versuch (mit Pairing-Modus) dann nur noch: Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-XXX because of error undefined (undefined): undefined"}. Wenn dieser Fehler kommt (also undefined), dauert es aber auch ziemlich lange, so als würde er dann in einen Timeout rennen. Zwischen Start Homekit Device Client initialization und dem Fehler liegen fast genau 20 Sekunden jedes Mal. Wärend beim "Missing Salt" der Fehler schon nach 2 Sekunden kommt.
              StrathColeS Offline
              StrathColeS Offline
              StrathCole
              #117
              @apollon77 Nachtrag dazu: Die 20 Sekunden scheinen der Zeitraum zu sein, nach dem dann das Nuki den Pairing-Modus wieder abschaltet. Dann gehen die LED wieder aus und gleichzeitig kommt dann die Fehlermeldung. Und ohne den Modus kommt wie gesagt immer das mit Missing Salt.
              Es scheinen 30 Sekunden zu sein, nicht 20. Denke mal, der Unterschied sind die Sekunden, die ich brauche vom Pairing-Modus an bis Pin-Eingabe.
              hap-controller:gatt-connection Peripheral disconnected +30s
              Log von Pair-Modus aktivieren über PIN-Eingabe bis Fehlermeldung habe ich gemailt.
              • apollon77A Offline
                #118
                Ja soweit war ich mit dem anderen user auch. Es scheint so als ob der "Pairing Modus" eher dafür ist das Nuki mit seiner Bridge zu Pairen und gar nicht für HomeKit :-) Scheinbar ist Homekit Pairing in dem Zeitraum aus - was den oben genannten Fehler erklärt.
                Es ist auch so - zumindestens im test - das sich das Nuki auch gar nicht mit Apple Home direkt Pairen lässt, sondern das ganze nur über die Nuki App geht, wo es dann danach in Apple Home ist - also die Nuki App pusht das Gerät zu Apple Home .... Das könnte es erklären warum es mit dem Adapter nicht geht. Da wären wir dann aber soweit raus :-(
                StrathColeS 2 Antworten Letzte Antwort
                  StrathColeS Offline
                  StrathColeS Offline
                  StrathCole
                  #119
                  @apollon77 also in der Nuki Anleitung steht nur, dass man in der Home App den QR scannen soll und das dann angeblich geht. Aber wie gesagt, steht mir leider kein iOS Gerät zur Verfügung. Nutzen alle Android.
                    StrathColeS Offline
                    StrathColeS Offline
                    StrathCole
                    #120
                    @apollon77 ach ja, ich habe übrigens ein Nuki 3.0 pro. Nur falls das relevant ist.
                      #121
                      @strathcole sagte in Test Alpha Homekit-Controller 0.0.x:
                      Naja der andere user hat es so halt auch nicht hinbekommen sondern nur über die Nuki App
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        #122
                        @apollon77 Na gut, dann … warte ich einfach mal, bis mir irgendwann irgendwer unterkommt, der hier mit einem iPhone reinschneit 😆
                          #123
                          @strathcole Naja das it der andere User, aber kommen auch nicht so wirklich weiter bis auf die Details die ich oben schon gesagt hab
                            Minta79
                            #124
                            Ich nutze seit gestern den Adapter in Version 0.3.3. Leider steht die Instanz nach kurzer Zeit immer auf "Nicht Verbunden mit Gerät oder Dienst". Ich habe einen Onvis-Türkontakt per Bluetooth verbunden. Hat jemand einen Tipp für mich, was das Problem sein könnte?
                            • M Minta79
                              #125
                              @minta79 Was sagt das Log? Ggf mal bitte Loglevel auf Debug und laufen lassen und dann zeigen wenn es "offline" geht
                                Minta79
                                #126
                                @apollon77 Hier ein Auszug aus dem Log im Debug Modus:
                                Sobald der Schritt "Scheduled Characteristic update started ..." kommt, geht der Status der Instanz von grün auf gelb und es funktioniert nicht mehr. Muss dann die Instanz neu starten. Das geht aber nur ein paar Minuten gut. Es erscheint dann immer der Fehler "data polling failed: undefined"
                                • M Minta79
                                  #127
                                  @minta79 Bist Du sicher das dsas BLE Device nicht noch von anderen Adapetrn oder Prozessen genutzt wird? dieser "unknown connecztion identifier 0x2" heisst nach erstem Googlen wohl das die Verbindung unterbrochen wurde auf dem Host ...
                                  Mich würde ja mal ein etwas längeres Log passieren ob es sich irgendwann wieder gibt - oder ist da wirklich schluss?
                                    Minta79
                                    #128
                                    @apollon77 Ich wüsste nicht, in welchem Adapter es noch verwendet werden sollte. Der Zustand bleibt leider so. Stand jetzt über nen Tag in dem Zustand. Im Log wiederholt es sich dann...
                                    • M Minta79
                                      #129
                                      @minta79 Hm, kann nur raten ... ist irgendwas auf dem Bluetooth level. Da müssmer jetzt mal ganz tief reingehen
                                      • Bitte sicherstellen das alles aktuell ist ... apt update && apt dist-upgrade
                                      • Bitte auch mal sudo hciconfig hci0 reset versuchen
                                      • Was sagt uname -a ? ALao welcher Kernel (ggf nach Updates und nach einem Reboot)
                                      • Was sagt lsusb?
                                      • Was für ein gert ist es? Raspi3 oder was?
                                      Dann wäre cool wenn du in einer Shell mal sudo hcidump -t -x >log.txt laufen lassen kannst und dann den Adapter startest.... Dann das log.txt File mal hochladen zusammen mit dem iobroker debug log
                                      EDIT: Den Adapter starten am besten wie hier --> https://forum.iobroker.net/post/720099 beschrieben in einem zweiten Shell Fenster ... dann die Shell Ausgaben
                                      • P Offline
                                        pql
                                        #130
                                        laut Readme unterstützt der Controller keine Thread Devices... Bezieht sich das auch auf Eve Geräte die mittlerweile als "based on Thread" betitelt sind? Oder sollen diese funktionieren?
                                        • P pql
                                          #131
                                          @pql eve ist meines Wissens thread UND Ble Bzw wlan. Ich kenne bisher kein „exklusiv thread“ gerät auf dem Markt. Von daher sollte es dennoch gehen. Musst halt schauen was das Gerät in Summe so kann
                                          P 1 Antwort Letzte Antwort
