  4. Crash - no connection to states 0.0.0.0:6370[redis]
59 Beiträge 4 Kommentatoren 6.0k Aufrufe 3 Beobachtet
    @sirfauntleroy sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
    error: host.ioBroker No connection to databases possible, restart
    Sorry, dann hat @Thomas-Braun wohl doch recht dass es nicht geht, oder da ist noch ein ganz anderer Wurm drin.
    Vielleicht hat @Thomas-Braun noch ne idee - mir gehen dieselben aus :-(
    Sirfauntleroy
    ich spiel jetzt mal das image nochmal neu, installier iobroker neu, installier redis und schau dann mal
      @homoran @Sirfauntleroy
      Was ist denn da jetzt der Status?
      apt policy redis
      iobroker status
      • S Sirfauntleroy
        2021-12-20 20:19:41.719  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:19:41.725  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:19:41.726  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
        2021-12-20 20:19:41.726  - info: host.raspberrypi ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:19:41.916  - info: host.raspberrypi connected to Objects and States
        2021-12-20 20:19:41.981  - info: host.raspberrypi added notifications configuration of host
        2021-12-20 20:19:42.308  - info: host.raspberrypi 3 instances found
        2021-12-20 20:19:42.318  - info: host.raspberrypi starting 3 instances
        2021-12-20 20:19:42.373  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7465
        2021-12-20 20:19:44.326  - info: admin.0 (7465) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 20:19:44.378  - info: admin.0 (7465) requesting all states
        2021-12-20 20:19:44.378  - info: admin.0 (7465) requesting all objects
        2021-12-20 20:19:44.471  - info: admin.0 (7465) received all objects
        2021-12-20 20:19:44.562  - info: admin.0 (7465) http server listening on port 8081
        2021-12-20 20:19:44.563  - info: admin.0 (7465) Use link "http://localhost:8081" to configure.
        2021-12-20 20:19:44.614  - info: admin.0 (7465) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
        2021-12-20 20:19:44.619  - warn: admin.0 (7465) Repository cannot be read
        2021-12-20 20:19:46.383  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7516
        2021-12-20 20:19:47.828  - info: discovery.0 (7516) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 20:19:50.359  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7532
        2021-12-20 20:19:51.894  - info: backitup.0 (7532) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 20:19:51.955  - info: backitup.0 (7532) [iobroker] backup was activated at 02:40 every 1 day(s)
        2021-12-20 20:20:19.503  - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
        2021-12-20 20:24:12.848  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-12-20 20:24:12.858  - info: backitup.0 (7532) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 20:24:12.858  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2021-12-20 20:24:12.859  - info: backitup.0 (7532) cleaned everything up...
        2021-12-20 20:24:12.860  - info: backitup.0 (7532) terminating
        2021-12-20 20:24:12.862  - info: backitup.0 (7532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-12-20 20:24:13.406  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-12-20 20:24:15.919  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7607
        2021-12-20 20:24:17.494  - info: backitup.0 (7607) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 20:24:17.558  - info: backitup.0 (7607) [iobroker] backup was activated at 02:40 every 1 day(s)
        2021-12-20 20:25:06.270  - info: host.raspberrypi received SIGTERM
        2021-12-20 20:25:06.272  - info: backitup.0 (7607) cleaned everything up...
        2021-12-20 20:25:06.272  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
        2021-12-20 20:25:06.273  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
        2021-12-20 20:25:06.274  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-12-20 20:25:06.271  - info: admin.0 (7465) terminating http server on port 8081
        2021-12-20 20:25:06.292  - info: discovery.0 (7516) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 20:25:06.293  - info: backitup.0 (7607) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 20:25:06.291  - info: admin.0 (7465) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 20:25:06.298  - info: backitup.0 (7607) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2021-12-20 20:25:06.298  - info: discovery.0 (7516) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2021-12-20 20:25:06.299  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
        2021-12-20 20:25:06.301  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
        2021-12-20 20:25:06.301  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2021-12-20 20:25:06.305  - info: admin.0 (7465) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2021-12-20 20:25:06.857  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2021-12-20 20:25:06.875  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2021-12-20 20:25:06.879  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2021-12-20 20:25:06.880  - info: host.raspberrypi All instances are stopped.
        2021-12-20 20:25:06.943  - info: host.raspberrypi terminated
        2021-12-20 20:26:08.968  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:26:08.974  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:26:08.975  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:26:08.975  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:26:38.995  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:26:39.008  - info: host.ioBroker iobroker _restart
        2021-12-20 20:26:39.700  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:26:39.920  - info: host.ioBroker received SIGTERM
        2021-12-20 20:26:39.936  - info: host.ioBroker iobroker exit null
        2021-12-20 20:26:39.943  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:26:39.944  - info: host.ioBroker terminated
        2021-12-20 20:26:41.052  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:26:41.057  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:26:41.058  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:26:41.058  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:27:11.078  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:27:11.091  - info: host.ioBroker iobroker _restart
        2021-12-20 20:27:11.787  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:27:12.007  - info: host.ioBroker received SIGTERM
        2021-12-20 20:27:12.018  - info: host.ioBroker iobroker exit null
        2021-12-20 20:27:12.029  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:27:12.030  - info: host.ioBroker terminated
        2021-12-20 20:27:13.128  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:27:13.134  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:27:13.135  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:27:13.135  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:27:43.152  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:27:43.164  - info: host.ioBroker iobroker _restart
        2021-12-20 20:27:43.859  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:27:44.079  - info: host.ioBroker received SIGTERM
        2021-12-20 20:27:44.089  - info: host.ioBroker iobroker exit null
        2021-12-20 20:27:44.098  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:27:44.099  - info: host.ioBroker terminated
        2021-12-20 20:27:45.208  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:27:45.214  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:27:45.215  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:27:45.215  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:28:15.235  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:28:15.248  - info: host.ioBroker iobroker _restart
        2021-12-20 20:28:15.944  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:28:16.165  - info: host.ioBroker received SIGTERM
        2021-12-20 20:28:16.178  - info: host.ioBroker iobroker exit null
        2021-12-20 20:28:16.186  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:28:16.187  - info: host.ioBroker terminated
        2021-12-20 20:28:17.285  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:28:17.291  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:28:17.292  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:28:17.292  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:28:47.312  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:28:47.325  - info: host.ioBroker iobroker _restart
        2021-12-20 20:28:48.026  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:28:48.247  - info: host.ioBroker received SIGTERM
        2021-12-20 20:28:48.256  - info: host.ioBroker iobroker exit null
        2021-12-20 20:28:48.268  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:28:48.270  - info: host.ioBroker terminated
        2021-12-20 20:28:49.376  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:28:49.382  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:28:49.383  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:28:49.383  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:29:19.404  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:29:19.416  - info: host.ioBroker iobroker _restart
        2021-12-20 20:29:20.115  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:29:20.336  - info: host.ioBroker received SIGTERM
        2021-12-20 20:29:20.347  - info: host.ioBroker iobroker exit null
        2021-12-20 20:29:20.358  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:29:20.359  - info: host.ioBroker terminated
        2021-12-20 20:29:21.475  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:29:21.481  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:29:21.481  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:29:21.482  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:29:51.502  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:29:51.515  - info: host.ioBroker iobroker _restart
        2021-12-20 20:29:52.209  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:29:52.432  - info: host.ioBroker received SIGTERM
        2021-12-20 20:29:52.445  - info: host.ioBroker iobroker exit null
        2021-12-20 20:29:52.453  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:29:52.455  - info: host.ioBroker terminated
        2021-12-20 20:29:53.564  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:29:53.570  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:29:53.571  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:29:53.571  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:30:23.592  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:30:23.604  - info: host.ioBroker iobroker _restart
        2021-12-20 20:30:24.303  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:30:24.524  - info: host.ioBroker received SIGTERM
        2021-12-20 20:30:24.535  - info: host.ioBroker iobroker exit null
        2021-12-20 20:30:24.546  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:30:24.547  - info: host.ioBroker terminated
        2021-12-20 20:30:25.657  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:30:25.663  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:30:25.663  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:30:25.664  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:30:50.256  - info: host.ioBroker received SIGTERM
        2021-12-20 20:30:50.278  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:30:50.280  - info: host.ioBroker terminated
        2021-12-20 20:32:12.562  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:32:12.568  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:32:12.569  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:32:12.569  - info: host.ioBroker ip addresses:
        2021-12-20 20:33:26.192  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:33:26.205  - info: host.ioBroker iobroker _restart
        2021-12-20 20:33:27.056  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:33:28.603  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:33:28.609  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:33:28.609  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:33:28.610  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:33:58.630  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:33:58.643  - info: host.ioBroker iobroker _restart
        2021-12-20 20:33:59.332  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:33:59.553  - info: host.ioBroker received SIGTERM
        2021-12-20 20:33:59.561  - info: host.ioBroker iobroker exit null
        2021-12-20 20:33:59.574  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:33:59.575  - info: host.ioBroker terminated
        2021-12-20 20:34:00.686  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:34:00.692  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:34:00.692  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:34:00.693  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:34:30.709  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:34:30.721  - info: host.ioBroker iobroker _restart
        2021-12-20 20:34:31.420  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:34:31.641  - info: host.ioBroker received SIGTERM
        2021-12-20 20:34:31.649  - info: host.ioBroker iobroker exit null
        2021-12-20 20:34:31.662  - warn: host.ioBroker get state error: Connection is closed.
        2021-12-20 20:34:31.663  - info: host.ioBroker terminated
        2021-12-20 20:34:32.759  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:34:32.765  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:34:32.765  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:34:32.766  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:34:34.301  - info: host.ioBroker-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 0.0.0.0:9000
        2021-12-20 20:35:02.786  - error: host.ioBroker No connection to databases possible, restart
        2021-12-20 20:35:02.790  - info: host.ioBroker iobroker _restart
        2021-12-20 20:35:03.515  - info: host.ioBroker iobroker Starting node restart.js
        2021-12-20 20:35:03.743  - info: host.ioBroker received SIGTERM
        2021-12-20 20:35:03.752  - info: host.ioBroker iobroker exit null
        2021-12-20 20:35:03.762  - info: host.ioBroker terminated
        2021-12-20 20:35:05.230  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:35:05.237  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:35:05.237  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:35:05.238  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
        2021-12-20 20:35:06.909  - info: host.ioBroker connected to Objects and States
        2021-12-20 20:35:07.132  - info: host.ioBroker added notifications configuration of host
        2021-12-20 20:35:07.994  - info: host.ioBroker Delete host system.host.raspberrypi
        2021-12-20 20:35:08.152  - info: host.ioBroker 76 instances found
        2021-12-20 20:35:08.223  - warn: host.ioBroker does not start any instances on this host
        2021-12-20 20:38:31.272  - info: host.ioBroker received SIGTERM
        2021-12-20 20:38:31.433  - info: host.ioBroker terminated
        2021-12-20 20:38:39.634  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 20:38:39.640  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 20:38:39.641  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 20:38:39.641  - info: host.ioBroker ip addresses:
        2021-12-20 20:38:41.808  - info: host.ioBroker connected to Objects and States
        2021-12-20 20:38:42.028  - info: host.ioBroker added notifications configuration of host
        2021-12-20 20:38:42.796  - info: host.ioBroker 76 instances found
        2021-12-20 20:38:42.842  - warn: host.ioBroker does not start any instances on this host
        Hab doch noch was gesehen:
        kann es aber nicht zuordnen
          apt policy redis
          iobroker status
          Sirfauntleroy
          sorry beschreib grad die SD neu.
          unter iobroker status
          kam nur die gleiche meldung wie zuvor
          Objects type: file
          States  type: file
          • S Sirfauntleroy
            Objects type: file
            States  type: file
            @sirfauntleroy Dann installiert vor dem rückspielen des Backups redis.
              @Thomas-Braun
              bis hierhin sah es noch gut aus
              Wo kommt da der SIGTERM auf einmal her
              S F 2 Antworten Letzte Antwort
                @Thomas-Braun
                Sirfauntleroy
                gute Frage
                bekommt er den durch den "iob fix"?
                • S Sirfauntleroy
                  gute Frage
                  @sirfauntleroy
                  Möglich. Vor dem fix stoppt man den iobroker ja. Das wird dann wohl per SIGTERM passieren.
                    @Thomas-Braun
                    F Online
                    F Online
                    fastfoot
                    @homoran sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                    später heisst der host iobroker, die instanzen laufen auf einen anderen hostnamen, deshalb die Meldung host.ioBroker does not start any instances on this host. ein iob host this sollte das bereinigen
                      @sirfauntleroy
                      @thomas-braun sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                      passt, aber dass er dann nach dem Fixer nicht mehr hochkommt ist schon seltsam
                      • F fastfoot
                        @fastfoot sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                        DANKE!!!
                        Schon wieder mal nicht gesehen - gestern erst
                        F 1 Antwort Letzte Antwort
                          DANKE!!!
                          F Online
                          F Online
                          fastfoot
                          DANKE!!!
                          sieht man auch an list instances, die zeigen noch auf raspberrypi
                          • F fastfoot
                            DANKE!!!
                            ja, die Spalte blende ich immer irgendwie aus 😳 :-(
                              Sirfauntleroy
                              das Fenster bleibt jetzt so, bis alles wiederhergestellt ist?
                              einfach mal so laufen lassen. ... kommen da zwischen drin neue Zeilen, dass man sieht, das was passiert?
                              • S Sirfauntleroy
                                iobroker logs --watch zeigt dir die Aktivitäten
                                • S Sirfauntleroy
                                  @sirfauntleroy
                                  Konsole auf, per
                                  den Fortgang beobachten
                                    @sirfauntleroy
                                    Konsole auf, per
                                    Sirfauntleroy
                                    will nicht ungeduldig sein, aber ist es normal, dass der Start des Backup-Resores nicht im log steht?
                                    2021-12-20 21:04:34.397  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
                                    2021-12-20 21:04:34.403  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                    2021-12-20 21:04:34.404  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
                                    2021-12-20 21:04:34.404  - info: host.raspberrypi ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
                                    2021-12-20 21:04:34.601  - info: host.raspberrypi connected to Objects and States
                                    2021-12-20 21:04:34.667  - info: host.raspberrypi added notifications configuration of host
                                    2021-12-20 21:04:34.987  - info: host.raspberrypi 3 instances found
                                    2021-12-20 21:04:34.999  - info: host.raspberrypi starting 3 instances
                                    2021-12-20 21:04:35.052  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7454
                                    2021-12-20 21:04:37.005  - info: admin.0 (7454) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-20 21:04:37.054  - info: admin.0 (7454) requesting all states
                                    2021-12-20 21:04:37.055  - info: admin.0 (7454) requesting all objects
                                    2021-12-20 21:04:37.135  - info: admin.0 (7454) received all objects
                                    2021-12-20 21:04:37.231  - info: admin.0 (7454) http server listening on port 8081
                                    2021-12-20 21:04:37.231  - info: admin.0 (7454) Use link "http://localhost:8081" to configure.
                                    2021-12-20 21:04:37.268  - info: admin.0 (7454) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
                                    2021-12-20 21:04:37.274  - warn: admin.0 (7454) Repository cannot be read
                                    2021-12-20 21:04:39.056  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7505
                                    2021-12-20 21:04:40.515  - info: discovery.0 (7505) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-20 21:04:43.039  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7520
                                    2021-12-20 21:04:44.601  - info: backitup.0 (7520) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-20 21:04:44.662  - info: backitup.0 (7520) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2021-12-20 21:05:13.492  - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
                                    2021-12-20 21:07:29.728  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2021-12-20 21:07:29.743  - info: backitup.0 (7520) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-20 21:07:29.744  - info: backitup.0 (7520) cleaned everything up...
                                    2021-12-20 21:07:29.745  - info: backitup.0 (7520) terminating
                                    2021-12-20 21:07:29.746  - info: backitup.0 (7520) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-20 21:07:29.752  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                    2021-12-20 21:07:30.293  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-12-20 21:07:32.829  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7933
                                    2021-12-20 21:07:34.369  - info: backitup.0 (7933) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-20 21:07:34.432  - info: backitup.0 (7933) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2021-12-20 21:08:09.386  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2021-12-20 21:08:09.398  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                    2021-12-20 21:08:09.398  - info: backitup.0 (7933) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-20 21:08:09.401  - info: backitup.0 (7933) cleaned everything up...
                                    2021-12-20 21:08:09.402  - info: backitup.0 (7933) terminating
                                    2021-12-20 21:08:09.405  - info: backitup.0 (7933) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-20 21:08:09.993  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-12-20 21:08:12.439  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7984
                                    2021-12-20 21:08:14.006  - info: backitup.0 (7984) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-20 21:08:14.074  - info: backitup.0 (7984) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2021-12-20 21:09:05.300  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2021-12-20 21:09:05.316  - info: backitup.0 (7984) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-20 21:09:05.320  - info: backitup.0 (7984) cleaned everything up...
                                    2021-12-20 21:09:05.322  - info: backitup.0 (7984) terminating
                                    2021-12-20 21:09:05.325  - info: backitup.0 (7984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-20 21:09:05.358  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                    2021-12-20 21:09:05.861  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-12-20 21:09:08.399  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 8013
                                    2021-12-20 21:09:09.926  - info: backitup.0 (8013) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-20 21:09:09.989  - info: backitup.0 (8013) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    • S Sirfauntleroy
                                      Sirfauntleroy
                                      Fand die datei nicht.. nochmal ausgewählt: und es tut sich was
                                      2021-12-20 21:18:40.643  - info: admin.0 (7454) terminating http server on port 8081
                                      2021-12-20 21:18:40.642  - info: host.raspberrypi received SIGTERM
                                      2021-12-20 21:18:40.653  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
                                      2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
                                      2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                      2021-12-20 21:18:40.671  - info: admin.0 (7454) Got terminate signal TERMINATE_YOURSELF
                                      2021-12-20 21:18:40.672  - info: discovery.0 (7505) Got terminate signal TERMINATE_YOURSELF
                                      2021-12-20 21:18:40.673  - info: backitup.0 (8013) Got terminate signal TERMINATE_YOURSELF
                                      2021-12-20 21:18:40.677  - info: discovery.0 (7505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      2021-12-20 21:18:40.677  - info: backitup.0 (8013) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      2021-12-20 21:18:40.679  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
                                      2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
                                      2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                      2021-12-20 21:18:40.689  - info: admin.0 (7454) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      2021-12-20 21:18:41.240  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                      2021-12-20 21:18:41.258  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                      2021-12-20 21:18:41.261  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                      2021-12-20 21:18:41.262  - info: host.raspberrypi All instances are stopped.
                                      2021-12-20 21:18:41.285  - info: host.raspberrypi terminated
                                      2021-12-20 21:18:40.641  - info: backitup.0 (8013) cleaned everything up...
                                      2021-12-20 21:19:43.964  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
                                      2021-12-20 21:19:43.970  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                      2021-12-20 21:19:43.971  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
                                      2021-12-20 21:19:43.972  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
                                      2021-12-20 21:19:45.163  - info: host.ioBroker connected to Objects and States
                                      2021-12-20 21:19:45.191  - info: host.ioBroker added notifications configuration of host
                                      2021-12-20 21:19:45.688  - info: host.ioBroker Delete host system.host.raspberrypi
                                      2021-12-20 21:19:45.836  - info: host.ioBroker 76 instances found
                                      2021-12-20 21:19:45.897  - warn: host.ioBroker does not start any instances on this host
                                      Thomas BraunT F 2 Antworten Letzte Antwort
                                      • S Sirfauntleroy
                                        @sirfauntleroy
                                        Du hast die Lokalisierung / lokale Zeitzone nicht angepasst .
                                        • S Sirfauntleroy
                                          F Online
                                          F Online
                                          fastfoot
                                          @sirfauntleroy da ist immer noch der hostname falschiob stop, iob host this, iob start. Gestern hiess es noch dass backitup das macht :-)
                                          S HomoranH 2 Antworten Letzte Antwort
