  4. Crash - no connection to states 0.0.0.0:6370[redis]
59 Beiträge 4 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • S Sirfauntleroy
    2021-12-20 20:19:41.719  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:19:41.725  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:19:41.726  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
    2021-12-20 20:19:41.726  - info: host.raspberrypi ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:19:41.916  - info: host.raspberrypi connected to Objects and States
    2021-12-20 20:19:41.981  - info: host.raspberrypi added notifications configuration of host
    2021-12-20 20:19:42.308  - info: host.raspberrypi 3 instances found
    2021-12-20 20:19:42.318  - info: host.raspberrypi starting 3 instances
    2021-12-20 20:19:42.373  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7465
    2021-12-20 20:19:44.326  - info: admin.0 (7465) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
    2021-12-20 20:19:44.378  - info: admin.0 (7465) requesting all states
    2021-12-20 20:19:44.378  - info: admin.0 (7465) requesting all objects
    2021-12-20 20:19:44.471  - info: admin.0 (7465) received all objects
    2021-12-20 20:19:44.562  - info: admin.0 (7465) http server listening on port 8081
    2021-12-20 20:19:44.563  - info: admin.0 (7465) Use link "http://localhost:8081" to configure.
    2021-12-20 20:19:44.614  - info: admin.0 (7465) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
    2021-12-20 20:19:44.619  - warn: admin.0 (7465) Repository cannot be read
    2021-12-20 20:19:46.383  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7516
    2021-12-20 20:19:47.828  - info: discovery.0 (7516) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.2, js-controller: 3.3.21
    2021-12-20 20:19:50.359  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7532
    2021-12-20 20:19:51.894  - info: backitup.0 (7532) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
    2021-12-20 20:19:51.955  - info: backitup.0 (7532) [iobroker] backup was activated at 02:40 every 1 day(s)
    2021-12-20 20:20:19.503  - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
    2021-12-20 20:24:12.848  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2021-12-20 20:24:12.858  - info: backitup.0 (7532) Got terminate signal TERMINATE_YOURSELF
    2021-12-20 20:24:12.858  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    2021-12-20 20:24:12.859  - info: backitup.0 (7532) cleaned everything up...
    2021-12-20 20:24:12.860  - info: backitup.0 (7532) terminating
    2021-12-20 20:24:12.862  - info: backitup.0 (7532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-12-20 20:24:13.406  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-12-20 20:24:15.919  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7607
    2021-12-20 20:24:17.494  - info: backitup.0 (7607) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
    2021-12-20 20:24:17.558  - info: backitup.0 (7607) [iobroker] backup was activated at 02:40 every 1 day(s)
    2021-12-20 20:25:06.270  - info: host.raspberrypi received SIGTERM
    2021-12-20 20:25:06.272  - info: backitup.0 (7607) cleaned everything up...
    2021-12-20 20:25:06.272  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    2021-12-20 20:25:06.273  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
    2021-12-20 20:25:06.274  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2021-12-20 20:25:06.271  - info: admin.0 (7465) terminating http server on port 8081
    2021-12-20 20:25:06.292  - info: discovery.0 (7516) Got terminate signal TERMINATE_YOURSELF
    2021-12-20 20:25:06.293  - info: backitup.0 (7607) Got terminate signal TERMINATE_YOURSELF
    2021-12-20 20:25:06.291  - info: admin.0 (7465) Got terminate signal TERMINATE_YOURSELF
    2021-12-20 20:25:06.298  - info: backitup.0 (7607) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-12-20 20:25:06.298  - info: discovery.0 (7516) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-12-20 20:25:06.299  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    2021-12-20 20:25:06.301  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
    2021-12-20 20:25:06.301  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    2021-12-20 20:25:06.305  - info: admin.0 (7465) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-12-20 20:25:06.857  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-12-20 20:25:06.875  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-12-20 20:25:06.879  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-12-20 20:25:06.880  - info: host.raspberrypi All instances are stopped.
    2021-12-20 20:25:06.943  - info: host.raspberrypi terminated
    2021-12-20 20:26:08.968  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:26:08.974  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:26:08.975  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:26:08.975  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:26:38.995  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:26:39.008  - info: host.ioBroker iobroker _restart
    2021-12-20 20:26:39.700  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:26:39.920  - info: host.ioBroker received SIGTERM
    2021-12-20 20:26:39.936  - info: host.ioBroker iobroker exit null
    2021-12-20 20:26:39.943  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:26:39.944  - info: host.ioBroker terminated
    2021-12-20 20:26:41.052  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:26:41.057  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:26:41.058  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:26:41.058  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:27:11.078  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:27:11.091  - info: host.ioBroker iobroker _restart
    2021-12-20 20:27:11.787  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:27:12.007  - info: host.ioBroker received SIGTERM
    2021-12-20 20:27:12.018  - info: host.ioBroker iobroker exit null
    2021-12-20 20:27:12.029  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:27:12.030  - info: host.ioBroker terminated
    2021-12-20 20:27:13.128  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:27:13.134  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:27:13.135  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:27:13.135  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:27:43.152  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:27:43.164  - info: host.ioBroker iobroker _restart
    2021-12-20 20:27:43.859  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:27:44.079  - info: host.ioBroker received SIGTERM
    2021-12-20 20:27:44.089  - info: host.ioBroker iobroker exit null
    2021-12-20 20:27:44.098  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:27:44.099  - info: host.ioBroker terminated
    2021-12-20 20:27:45.208  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:27:45.214  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:27:45.215  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:27:45.215  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:28:15.235  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:28:15.248  - info: host.ioBroker iobroker _restart
    2021-12-20 20:28:15.944  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:28:16.165  - info: host.ioBroker received SIGTERM
    2021-12-20 20:28:16.178  - info: host.ioBroker iobroker exit null
    2021-12-20 20:28:16.186  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:28:16.187  - info: host.ioBroker terminated
    2021-12-20 20:28:17.285  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:28:17.291  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:28:17.292  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:28:17.292  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:28:47.312  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:28:47.325  - info: host.ioBroker iobroker _restart
    2021-12-20 20:28:48.026  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:28:48.247  - info: host.ioBroker received SIGTERM
    2021-12-20 20:28:48.256  - info: host.ioBroker iobroker exit null
    2021-12-20 20:28:48.268  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:28:48.270  - info: host.ioBroker terminated
    2021-12-20 20:28:49.376  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:28:49.382  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:28:49.383  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:28:49.383  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:29:19.404  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:29:19.416  - info: host.ioBroker iobroker _restart
    2021-12-20 20:29:20.115  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:29:20.336  - info: host.ioBroker received SIGTERM
    2021-12-20 20:29:20.347  - info: host.ioBroker iobroker exit null
    2021-12-20 20:29:20.358  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:29:20.359  - info: host.ioBroker terminated
    2021-12-20 20:29:21.475  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:29:21.481  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:29:21.481  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:29:21.482  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:29:51.502  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:29:51.515  - info: host.ioBroker iobroker _restart
    2021-12-20 20:29:52.209  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:29:52.432  - info: host.ioBroker received SIGTERM
    2021-12-20 20:29:52.445  - info: host.ioBroker iobroker exit null
    2021-12-20 20:29:52.453  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:29:52.455  - info: host.ioBroker terminated
    2021-12-20 20:29:53.564  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:29:53.570  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:29:53.571  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:29:53.571  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:30:23.592  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:30:23.604  - info: host.ioBroker iobroker _restart
    2021-12-20 20:30:24.303  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:30:24.524  - info: host.ioBroker received SIGTERM
    2021-12-20 20:30:24.535  - info: host.ioBroker iobroker exit null
    2021-12-20 20:30:24.546  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:30:24.547  - info: host.ioBroker terminated
    2021-12-20 20:30:25.657  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:30:25.663  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:30:25.663  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:30:25.664  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:30:50.256  - info: host.ioBroker received SIGTERM
    2021-12-20 20:30:50.278  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:30:50.280  - info: host.ioBroker terminated
    2021-12-20 20:32:12.562  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:32:12.568  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:32:12.569  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:32:12.569  - info: host.ioBroker ip addresses:
    2021-12-20 20:33:26.192  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:33:26.205  - info: host.ioBroker iobroker _restart
    2021-12-20 20:33:27.056  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:33:28.603  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:33:28.609  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:33:28.609  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:33:28.610  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:33:58.630  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:33:58.643  - info: host.ioBroker iobroker _restart
    2021-12-20 20:33:59.332  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:33:59.553  - info: host.ioBroker received SIGTERM
    2021-12-20 20:33:59.561  - info: host.ioBroker iobroker exit null
    2021-12-20 20:33:59.574  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:33:59.575  - info: host.ioBroker terminated
    2021-12-20 20:34:00.686  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:34:00.692  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:34:00.692  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:34:00.693  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:34:30.709  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:34:30.721  - info: host.ioBroker iobroker _restart
    2021-12-20 20:34:31.420  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:34:31.641  - info: host.ioBroker received SIGTERM
    2021-12-20 20:34:31.649  - info: host.ioBroker iobroker exit null
    2021-12-20 20:34:31.662  - warn: host.ioBroker get state error: Connection is closed.
    2021-12-20 20:34:31.663  - info: host.ioBroker terminated
    2021-12-20 20:34:32.759  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:34:32.765  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:34:32.765  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:34:32.766  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:34:34.301  - info: host.ioBroker-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 0.0.0.0:9000
    2021-12-20 20:35:02.786  - error: host.ioBroker No connection to databases possible, restart
    2021-12-20 20:35:02.790  - info: host.ioBroker iobroker _restart
    2021-12-20 20:35:03.515  - info: host.ioBroker iobroker Starting node restart.js
    2021-12-20 20:35:03.743  - info: host.ioBroker received SIGTERM
    2021-12-20 20:35:03.752  - info: host.ioBroker iobroker exit null
    2021-12-20 20:35:03.762  - info: host.ioBroker terminated
    2021-12-20 20:35:05.230  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:35:05.237  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:35:05.237  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:35:05.238  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::83dc:394c:a7a1:9592
    2021-12-20 20:35:06.909  - info: host.ioBroker connected to Objects and States
    2021-12-20 20:35:07.132  - info: host.ioBroker added notifications configuration of host
    2021-12-20 20:35:07.994  - info: host.ioBroker Delete host system.host.raspberrypi
    2021-12-20 20:35:08.152  - info: host.ioBroker 76 instances found
    2021-12-20 20:35:08.223  - warn: host.ioBroker does not start any instances on this host
    2021-12-20 20:38:31.272  - info: host.ioBroker received SIGTERM
    2021-12-20 20:38:31.433  - info: host.ioBroker terminated
    2021-12-20 20:38:39.634  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-20 20:38:39.640  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-20 20:38:39.641  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
    2021-12-20 20:38:39.641  - info: host.ioBroker ip addresses:
    2021-12-20 20:38:41.808  - info: host.ioBroker connected to Objects and States
    2021-12-20 20:38:42.028  - info: host.ioBroker added notifications configuration of host
    2021-12-20 20:38:42.796  - info: host.ioBroker 76 instances found
    2021-12-20 20:38:42.842  - warn: host.ioBroker does not start any instances on this host
    Hab doch noch was gesehen:
    @sirfauntleroy sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
    kann es aber nicht zuordnen
      @homoran @Sirfauntleroy
      Was ist denn da jetzt der Status?
      apt policy redis
      iobroker status
      Sirfauntleroy
      sorry beschreib grad die SD neu.
      unter iobroker status
      kam nur die gleiche meldung wie zuvor
      Objects type: file
      States  type: file
      • S Sirfauntleroy
        Objects type: file
        States  type: file
        Thomas BraunT Offline
        @sirfauntleroy Dann installiert vor dem rückspielen des Backups redis.
          @Thomas-Braun
          bis hierhin sah es noch gut aus
          Wo kommt da der SIGTERM auf einmal her
          S F 2 Antworten Letzte Antwort
            @Thomas-Braun
            Sirfauntleroy
            gute Frage
            bekommt er den durch den "iob fix"?
            • S Sirfauntleroy
              gute Frage
              @sirfauntleroy
              Möglich. Vor dem fix stoppt man den iobroker ja. Das wird dann wohl per SIGTERM passieren.
                @Thomas-Braun
                F Online
                F Online
                fastfoot
                @homoran sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                später heisst der host iobroker, die instanzen laufen auf einen anderen hostnamen, deshalb die Meldung host.ioBroker does not start any instances on this host. ein iob host this sollte das bereinigen
                  @sirfauntleroy
                  @thomas-braun sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                  passt, aber dass er dann nach dem Fixer nicht mehr hochkommt ist schon seltsam
                  • F fastfoot
                    @fastfoot sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                    DANKE!!!
                    Schon wieder mal nicht gesehen - gestern erst
                    F 1 Antwort Letzte Antwort
                      DANKE!!!
                      F Online
                      F Online
                      fastfoot
                      DANKE!!!
                      sieht man auch an list instances, die zeigen noch auf raspberrypi
                      • F fastfoot
                        DANKE!!!
                        ja, die Spalte blende ich immer irgendwie aus 😳 :-(
                          Sirfauntleroy
                          das Fenster bleibt jetzt so, bis alles wiederhergestellt ist?
                          einfach mal so laufen lassen. ... kommen da zwischen drin neue Zeilen, dass man sieht, das was passiert?
                          • S Sirfauntleroy
                            iobroker logs --watch zeigt dir die Aktivitäten
                            • S Sirfauntleroy
                              @sirfauntleroy
                              Konsole auf, per
                              den Fortgang beobachten
                                @sirfauntleroy
                                Konsole auf, per
                                Sirfauntleroy
                                will nicht ungeduldig sein, aber ist es normal, dass der Start des Backup-Resores nicht im log steht?
                                2021-12-20 21:04:34.397  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
                                2021-12-20 21:04:34.403  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-12-20 21:04:34.404  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
                                2021-12-20 21:04:34.404  - info: host.raspberrypi ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
                                2021-12-20 21:04:34.601  - info: host.raspberrypi connected to Objects and States
                                2021-12-20 21:04:34.667  - info: host.raspberrypi added notifications configuration of host
                                2021-12-20 21:04:34.987  - info: host.raspberrypi 3 instances found
                                2021-12-20 21:04:34.999  - info: host.raspberrypi starting 3 instances
                                2021-12-20 21:04:35.052  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7454
                                2021-12-20 21:04:37.005  - info: admin.0 (7454) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
                                2021-12-20 21:04:37.054  - info: admin.0 (7454) requesting all states
                                2021-12-20 21:04:37.055  - info: admin.0 (7454) requesting all objects
                                2021-12-20 21:04:37.135  - info: admin.0 (7454) received all objects
                                2021-12-20 21:04:37.231  - info: admin.0 (7454) http server listening on port 8081
                                2021-12-20 21:04:37.231  - info: admin.0 (7454) Use link "http://localhost:8081" to configure.
                                2021-12-20 21:04:37.268  - info: admin.0 (7454) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
                                2021-12-20 21:04:37.274  - warn: admin.0 (7454) Repository cannot be read
                                2021-12-20 21:04:39.056  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7505
                                2021-12-20 21:04:40.515  - info: discovery.0 (7505) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.2, js-controller: 3.3.21
                                2021-12-20 21:04:43.039  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7520
                                2021-12-20 21:04:44.601  - info: backitup.0 (7520) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                2021-12-20 21:04:44.662  - info: backitup.0 (7520) [iobroker] backup was activated at 02:40 every 1 day(s)
                                2021-12-20 21:05:13.492  - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
                                2021-12-20 21:07:29.728  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2021-12-20 21:07:29.743  - info: backitup.0 (7520) Got terminate signal TERMINATE_YOURSELF
                                2021-12-20 21:07:29.744  - info: backitup.0 (7520) cleaned everything up...
                                2021-12-20 21:07:29.745  - info: backitup.0 (7520) terminating
                                2021-12-20 21:07:29.746  - info: backitup.0 (7520) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-12-20 21:07:29.752  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                2021-12-20 21:07:30.293  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-12-20 21:07:32.829  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7933
                                2021-12-20 21:07:34.369  - info: backitup.0 (7933) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                2021-12-20 21:07:34.432  - info: backitup.0 (7933) [iobroker] backup was activated at 02:40 every 1 day(s)
                                2021-12-20 21:08:09.386  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2021-12-20 21:08:09.398  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                2021-12-20 21:08:09.398  - info: backitup.0 (7933) Got terminate signal TERMINATE_YOURSELF
                                2021-12-20 21:08:09.401  - info: backitup.0 (7933) cleaned everything up...
                                2021-12-20 21:08:09.402  - info: backitup.0 (7933) terminating
                                2021-12-20 21:08:09.405  - info: backitup.0 (7933) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-12-20 21:08:09.993  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-12-20 21:08:12.439  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7984
                                2021-12-20 21:08:14.006  - info: backitup.0 (7984) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                2021-12-20 21:08:14.074  - info: backitup.0 (7984) [iobroker] backup was activated at 02:40 every 1 day(s)
                                2021-12-20 21:09:05.300  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2021-12-20 21:09:05.316  - info: backitup.0 (7984) Got terminate signal TERMINATE_YOURSELF
                                2021-12-20 21:09:05.320  - info: backitup.0 (7984) cleaned everything up...
                                2021-12-20 21:09:05.322  - info: backitup.0 (7984) terminating
                                2021-12-20 21:09:05.325  - info: backitup.0 (7984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-12-20 21:09:05.358  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                2021-12-20 21:09:05.861  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-12-20 21:09:08.399  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 8013
                                2021-12-20 21:09:09.926  - info: backitup.0 (8013) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
                                2021-12-20 21:09:09.989  - info: backitup.0 (8013) [iobroker] backup was activated at 02:40 every 1 day(s)
                                • S Sirfauntleroy
                                  Sirfauntleroy
                                  Fand die datei nicht.. nochmal ausgewählt: und es tut sich was
                                  2021-12-20 21:18:40.643  - info: admin.0 (7454) terminating http server on port 8081
                                  2021-12-20 21:18:40.642  - info: host.raspberrypi received SIGTERM
                                  2021-12-20 21:18:40.653  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
                                  2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
                                  2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                  2021-12-20 21:18:40.671  - info: admin.0 (7454) Got terminate signal TERMINATE_YOURSELF
                                  2021-12-20 21:18:40.672  - info: discovery.0 (7505) Got terminate signal TERMINATE_YOURSELF
                                  2021-12-20 21:18:40.673  - info: backitup.0 (8013) Got terminate signal TERMINATE_YOURSELF
                                  2021-12-20 21:18:40.677  - info: discovery.0 (7505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-12-20 21:18:40.677  - info: backitup.0 (8013) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-12-20 21:18:40.679  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
                                  2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
                                  2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                  2021-12-20 21:18:40.689  - info: admin.0 (7454) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-12-20 21:18:41.240  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-12-20 21:18:41.258  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-12-20 21:18:41.261  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-12-20 21:18:41.262  - info: host.raspberrypi All instances are stopped.
                                  2021-12-20 21:18:41.285  - info: host.raspberrypi terminated
                                  2021-12-20 21:18:40.641  - info: backitup.0 (8013) cleaned everything up...
                                  2021-12-20 21:19:43.964  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
                                  2021-12-20 21:19:43.970  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                  2021-12-20 21:19:43.971  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
                                  2021-12-20 21:19:43.972  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
                                  2021-12-20 21:19:45.163  - info: host.ioBroker connected to Objects and States
                                  2021-12-20 21:19:45.191  - info: host.ioBroker added notifications configuration of host
                                  2021-12-20 21:19:45.688  - info: host.ioBroker Delete host system.host.raspberrypi
                                  2021-12-20 21:19:45.836  - info: host.ioBroker 76 instances found
                                  2021-12-20 21:19:45.897  - warn: host.ioBroker does not start any instances on this host
                                  Thomas BraunT F 2 Antworten Letzte Antwort
                                  • S Sirfauntleroy
                                    @sirfauntleroy
                                    Du hast die Lokalisierung / lokale Zeitzone nicht angepasst .
                                    • S Sirfauntleroy
                                      F Online
                                      F Online
                                      fastfoot
                                      @sirfauntleroy da ist immer noch der hostname falschiob stop, iob host this, iob start. Gestern hiess es noch dass backitup das macht :-)
                                      S HomoranH 2 Antworten Letzte Antwort
                                      • F fastfoot
                                        Sirfauntleroy
                                        @fastfoot
                                        jetzt rattert im log so einiges durch..
                                        geduldig abwarten...
                                        • S Sirfauntleroy
                                          @fastfoot
                                          Sirfauntleroy
                                          Das Backup ist durchgelaufen.
                                          nun folgendes Problem ...
                                          Error: Cannot find module '../encodings'
                                          Require stack:
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/types/json.js
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/index.js
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js
                                          - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/index.js
                                          - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
                                          - /opt/iobroker/node_modules/iobroker.admin/main.js
                                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                              at Module.require (internal/modules/cjs/loader.js:974:19)
                                              at require (internal/modules/cjs/helpers.js:93:18)
                                              at Object.getCodec (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:65:27)
                                              at Object.getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:127:23)
                                              at getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:45:18)
                                              at readStream (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:180:15)
                                              at getRawBody (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:108:12)
                                              at read (/opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js:77:3)
