  4. zigbee Adapter nach Update keine Verbindung
23 Beiträge 5 Kommentatoren 3.1k Aufrufe 6 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    schrieb am zuletzt editiert von Kusselin
    Hallo ZUsammen,
    ich habe vorgestern ein stable Update vom Zigbee gemacht....nun sehe ich das dieser nicht mehr verbimdet. es kommt diese Meldung. Könnt Ihr mir bitte helfen was das bedeutet....:
    zigbee.0
    	2021-12-20 07:06:37.965	error	Error herdsman start
    zigbee.0
    	2021-12-20 07:06:37.965	error	Failed to start Zigbee
    zigbee.0
    	2021-12-20 07:06:37.964	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    	2021-12-20 07:06:22.617	error	Error herdsman start
    zigbee.0
    	2021-12-20 07:06:22.616	error	Failed to start Zigbee
    zigbee.0
    	2021-12-20 07:06:22.616	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    host.iobroker-live
    	2021-12-20 07:05:47.049	error	instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    zigbee.0
    	2021-12-20 07:05:27.925	error	Cannot read property 'error' of undefined
    zigbee.0
    	2021-12-20 07:05:27.925	error	TypeError: Cannot read property 'error' of undefined at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:764:26) at Zigbee.emit (events.js:314:20) at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22) at Object.onceWrapper (events.js:421:26) at process.emit (events.js:314:20)
    zigbee.0
    	2021-12-20 07:05:27.923	error	unhandled promise rejection: Cannot read property 'error' of undefined
    zigbee.0
    	2021-12-20 07:05:27.922	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker-live
    	2021-12-20 07:04:56.556	error	instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    zigbee.0
    	2021-12-20 07:04:55.954	error	zigbee.0 already running
    zigbee.0
    	2021-12-20 07:04:32.812	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0
    	2021-12-20 07:05:41.673	info	Installed Version: iobroker.zigbee@1.6.6
    zigbee.0
    	2021-12-20 07:05:41.449	info	Starting Zigbee npm ...
    zigbee.0
    	2021-12-20 07:05:41.409	info	starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.21
    zigbee.0
    	2021-12-20 07:05:40.048	warn	Got terminate signal. Checking desired PID: 8019 vs own PID 8003
    zigbee.0
    	2021-12-20 07:05:40.042	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    	2021-12-20 07:05:40.041	info	terminating
    zigbee.0
    	2021-12-20 07:05:40.040	warn	Failed to stop zigbee during startup
    zigbee.0
    	2021-12-20 07:05:39.867	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2021-12-20 07:05:39.865	info	cleaned everything up...
    zigbee.0
    	2021-12-20 07:05:39.864	warn	Got terminate signal. Checking desired PID: 0 vs own PID 8003
    host.iobroker-live
    	2021-12-20 07:05:39.888	info	instance system.adapter.zigbee.0 started with pid 8019
    host.iobroker-live
    	2021-12-20 07:05:38.859	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker-live
    	2021-12-20 07:05:38.859	info	instance system.adapter.zigbee.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    zigbee.0
    	2021-12-20 07:05:31.528	info	Installed Version: iobroker.zigbee@1.6.6
    zigbee.0
    	2021-12-20 07:05:31.333	info	Starting Zigbee npm ...
    zigbee.0
    	2021-12-20 07:05:31.275	info	starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.21
    host.iobroker-live
    	2021-12-20 07:05:29.941	info	instance system.adapter.zigbee.0 started with pid 8003
    host.iobroker-live
    	2021-12-20 07:05:28.643	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0
    	2021-12-20 07:05:28.442	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0
    	2021-12-20 07:05:28.437	info	Installed Version: iobroker.zigbee@1.6.6
    zigbee.0
    	2021-12-20 07:05:28.205	info	Starting Zigbee npm ...
    zigbee.0
    	2021-12-20 07:05:28.147	info	starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.21
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    host.iobroker-live
    	2021-12-20 07:05:27.921	info	stopInstance system.adapter.zigbee.0 killing pid 7
    Weiter habe nicht darauf geachtet welche Version ich vor dem Update hatte. Ev kann könnt Ihr mir bitte auch sagen auf welche version ich zurückgehen soll?
    Ich dachte immer im stable kann ich beruhigend updaten ....falsch gedacht.
    Gruss
    • XenonX Offline
      XenonX Offline
      Xenon
      Forum Testing Developer
      adapter stoppen, stick abziehen, kurz warten, wieder anstecken, adapter wieder starten
      wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
      • KusselinK Kusselin
        Hallo ZUsammen,
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker-live
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker-live
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker-live
        host.iobroker-live
        host.iobroker-live
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker-live
        host.iobroker-live
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker-live
        Gruss
        Thomas BraunT Offline
        @kusselin
        Oder Rechner mal sauber rebooten.
        Verwendete Hardware? Firmware derselben? Verwendeter device Link im Adapter?
        • KusselinK Offline
          KusselinK Offline
          Kusselin
          Habe nur das Update stable am Donnerstag gemacht.. hat einwandfrei funktioniert.. habe iobroker auf container procmox am Laufen auf NUC
          Kann das durch das Update kommen?
          Danke euch schon mal..probiers heite abend aus
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @kusselin
            Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) = diese Meldung bedeutet das es dem Adapter nicht gelingt mit dem Zigbee Stick zu reden. Daher die Fragen
            • Was für einen Stick hast du ?
            • Kannst Du den Stick einmal abziehen und wieder anstecken ? Geht der Adapter dann ?
            A.
            KusselinK 1 Antwort Letzte Antwort
            • AsgothianA Asgothian
              @kusselin
              A.
              KusselinK Offline
              KusselinK Offline
              Kusselin
              @asgothian stick ist CC2531 und ich bin grad auf Arbeit..heute abend dann
                @kusselin sagte in zigbee Adapter nach Update keine Verbindung:
                stick ist CC2531
                Schmeiß raus das Ding. Oder bring zumindest die vermutlich alte Firmware auf Stand.
                  stick ist CC2531
                  KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  @thomas-braun du bist gut...bin froh wenns läuft....da brauch man ja spezielles gerät um die soft aufzuspielen..habe ich nicht...
                  kannst du ein fertigen stick empfehlen?
                  wie verhält sich das dann wenn ich einen neuen Stick anschließe? Muss ich da alles neu pairen?
                  XenonX Thomas BraunT 2 Antworten Letzte Antwort
                    XenonX Offline
                    XenonX Offline
                    Xenon
                    @kusselin ich kann dir das TI CC26X2R1 wärmstens empfehlen.
                    Nein, du brauchst beim coordinator Wechsel nichts neu anlernen, solange du beim zigbee Adapter bleibst
                      @kusselin
                      Hier im Forum gibt es Sticks, ich glaube von @dimaiv
                      Ich selber habe den im Einsatz:
                      https://slae.sh/projects/cc2652/
                        @kusselin
                        KusselinK Offline
                        KusselinK Offline
                        Kusselin
                        @thomas-braun wo bekomme ich den her fertig? muss ich mich da an den dimaiv wenden?
                        Gruss und danke
                        • XenonX Xenon
                          KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          @xenon sagte in zigbee Adapter nach Update keine Verbindung:
                          hast du ein Link wo ich den am besten kaufen könnte und muss der Stick noch bespielt werden?
                          Sorry...weiss das halt nicht, deshalb die Fragen.
                          XenonX 1 Antwort Letzte Antwort
                            XenonX Offline
                            XenonX Offline
                            Xenon
                            @kusselin bei zb mouser.de ist der Versand ab 50€ kostenfrei. Ja, man muss die Software noch aufspielen, wird aber per usb kabel gemacht. Auf youtube gibt es dazu sonst auch Anleitungen. Oder du meldest dich zb auf dem ioBroker discord mal ;)
                            • KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              Habe den Proxmox Container gestopped den Stick raus......gewartet...wieder rein den Proxmox Container gestartet udn dann wars wieder gut...danke Euch
                              • KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                Passt das so von der Verkettung und Verbindung?
                                  XenonX Offline
                                  XenonX Offline
                                  Xenon
                                  Da hast du keinen Einfluss drauf, das mesh organisiert sich selber.
                                  Und ganz ehrlich? So lange es läuft, es ist doch völlig egal welcher sensor über welchen Router sendet 🙂
                                  • XenonX Xenon
                                    KusselinK Offline
                                    KusselinK Offline
                                    Kusselin
                                    @xenon Hi xenon...der Adapter ist zwar wieder auf grün wie geschrieben aber die BWM funzen net.....Motion bad heute morgen nicht eingesetzt und auch der Motion Küche nicht eingesetzt...
                                    Bin dann in die Scripte udn habe diese nochmal gestoppt und gestartet.......jetzt mal abwarten....unter Objekte sind aber die Motions auf true....
                                    Was kann ich noch machen? Prüfen?
                                    Gruss
                                    crunchipC XenonX 2 Antworten Letzte Antwort
                                      Gruss
                                      crunchipC Offline
                                      crunchipC Offline
                                      @kusselin prüfen ob BWM auslöst, ggf neu pairen
                                        Gruss
                                        XenonX Offline
                                        XenonX Offline
                                        Xenon
                                        @kusselin bekommst du denn die veränderten Werte rein oder nicht?
                                        Wenn ja -> skripte überprüfen
                                        Wenn nein -> bwm mal löschen und neu pairen. Eventuell zu weit weg vom nächsten Router oder vom coordinator?
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          @crunchip sagte in zigbee Adapter nach Update keine Verbindung:
                                          o.k. danke Meister :-) Aber das Bild passt schon oben mit den verknüpfungen?
