  4. Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0
    6.3k
46 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
    @fraso
    So ganz ist mir noch nicht klar womit du da unterwegs bist.
    Bitte mal
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    ausführen.
    fraso
    @thomas-braun sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
    pi@iobroker-pi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/node
    /usr/bin/npm
    pi@iobroker-pi:~ $
    • F fraso
      /usr/bin/node
      /usr/bin/npm
      pi@iobroker-pi:~ $
      @fraso
      Und dann noch mal das von davor.
      F 1 Antwort Letzte Antwort
        @fraso
        fraso
        pi@iobroker-pi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v12.22.7
        v12.22.7
        6.14.15
        Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://repos.influxdata.com/debian stretch InRelease
        Hit:4 https://packages.grafana.com/enterprise/deb stable InRelease
        Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
        Fetched 15.0 kB in 2s (7,647 B/s)
        Reading package lists... Done
        Building dependency tree
        1 package can be upgraded. Run 'apt list --upgradable' to see it.
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
        Hit:4 https://repos.influxdata.com/debian stretch InRelease
        nodejs:
          Installed: 12.22.7-deb-1nodesource1
          Candidate: 12.22.8-deb-1nodesource1
          Version table:
             12.22.8-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         *** 12.22.7-deb-1nodesource1 100
             10.24.0~dfsg-1~deb10u1 500
        pi@iobroker-pi:~ $
        • F fraso
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.7
          v12.22.7
          6.14.15
          nodejs:
            Version table:
          pi@iobroker-pi:~ $
          @fraso
          Bitte mal das System updaten.
          Bei influx und grafana sind die auch falschen Repos angelegt.
            @fraso
            fraso
            Darf ich fragen was genau ich machen soll?
            Das Standard Update Rasperry?
            sudo apt-get upgrade ?
            sudo apt-get dist-upgrade ?
            Danke.
            • F fraso
              Danke.
              @fraso
              Das zum einen, zum anderen Stretch durch Buster ersetzen bei influx und bei grafana auf die oss-Version gehen.
              Hat aber mit deinem Problem nicht direkt zu tun, ist aber dennoch falsch.
                @fraso
                fraso
                Habe ich gemacht.
                Die Info mit Stretch durch Buster ersetzen bei influx und bei grafana auf die oss Version gehen... how to?
                1 Update nodejs (12.22.8-deb-1nodesource1)
                0 Upgrade
                • F fraso
                  Habe ich gemacht.
                  0 Upgrade
                  @fraso
                  Bitte nochmal auf den jeweiligen Projektseiten schauen. Da gibt es jeweils entsprechende Befehlszeilen.
                  • F Offline
                    fraso
                    @thomas-braun mache ich. kannst du mich auf die Projektseiten schubsen?
                    • F fraso
                      @fraso
                      Wie bist du denn an die falschen Links gekommen?
                      https://grafana.com/docs/grafana/latest/installation/debian/
                      Influx:
                      In der
                      /etc/apt/sources.list.d/influxdb.list
                      stretch durch buster ersetzen
                        @fraso
                        Influx:
                        In der
                        fraso
                        pi@iobroker-pi:~ $ sudo apt-get remove --auto-remove grafana-enterprise
                        The following packages will be REMOVED:
                          grafana-enterprise
                        0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                        After this operation, 258 MB disk space will be freed.
                        Do you want to continue? [Y/n] Y
                        (Reading database ... 67759 files and directories currently installed.)
                        Removing grafana-enterprise (8.3.3) ...
                        pi@iobroker-pi:~ $ sudo apt-get install -y apt-transport-https
                        apt-transport-https is already the newest version (1.8.2.3).
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        pi@iobroker-pi:~ $ sudo apt-get install -y software-properties-common wget
                        software-properties-common is already the newest version (0.96.20.2-2).
                        wget is already the newest version (1.20.1-1.1).
                        pi@iobroker-pi:~ $ wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                        OK
                        pi@iobroker-pi:~ $ sudo apt-get update
                        pi@iobroker-pi:~ $ sudo apt-get install grafana
                        The following NEW packages will be installed:
                          grafana
                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 41.3 MB of archives.
                        After this operation, 120 MB of additional disk space will be used.
                        Get:1 https://packages.grafana.com/enterprise/deb stable/main armhf grafana armhf 7.0.0 [41.3 MB]
                        Fetched 41.3 MB in 6s (6,691 kB/s)
                        Selecting previously unselected package grafana.
                        (Reading database ... 61681 files and directories currently installed.)
                        Preparing to unpack .../grafana_7.0.0_armhf.deb ...
                        Unpacking grafana (7.0.0) ...
                        Setting up grafana (7.0.0) ...
                        Installing new version of config file /etc/default/grafana-server ...
                        Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
                        ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                         sudo /bin/systemctl daemon-reload
                         sudo /bin/systemctl enable grafana-server
                        ### You can start grafana-server by executing
                         sudo /bin/systemctl start grafana-server
                        Processing triggers for systemd (241-7~deb10u8+rpi1) ...
                        pi@iobroker-pi:~ $
                        • F fraso
                            grafana-enterprise
                          OK
                            grafana
                          pi@iobroker-pi:~ $
                          fraso
                          @fraso so richtig gemacht?
                          • F fraso
                            fraso
                            @fraso sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
                            mmm... jetzt hab ich beide drauf :(
                            • F fraso
                              fraso
                              ... ich habe dann PURGE gemacht:
                              • Thomas BraunT Online
                                @fraso
                                sudo apt update
                                apt policy grafana grafana-enterprise
                                  @fraso
                                  sudo apt update
                                  fraso
                                  @thomas-braun danke. habe nur noch die 7.0.0 drauf. nehme an das ist die oss. jetzt lese ich mich gerade durch das stretch->buster zeug durch.
                                  • F fraso
                                    fraso
                                    @fraso und das hat alles mit Alexa2 zu tun das das nicht geht?
                                    • F fraso
                                      @fraso
                                      Nein. Hab ich doch schon geschrieben. Ist aber dennoch falsch und kann an anderer Stelle für Probleme sorgen.
                                      Die OSS-Version ist übrigens 8.3.3 Stand heute.
                                        @fraso
                                        fraso
                                        @thomas-braun BUSTER - korrekt?
                                        pi@iobroker-pi:~ $ cat /etc/os-release
                                        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                        NAME="Raspbian GNU/Linux"
                                        VERSION_ID="10"
                                        VERSION="10 (buster)"
                                        VERSION_CODENAME=buster
                                        ID=raspbian
                                        ID_LIKE=debian
                                        HOME_URL="http://www.raspbian.org/"
                                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                        pi@iobroker-pi:~ $
                                        • F fraso
                                          VERSION_ID="10"
                                          ID=raspbian
                                          ID_LIKE=debian
                                          pi@iobroker-pi:~ $
                                          @fraso
                                          Ja. Deswegen sollst du ja auch das Repository von stretch auf buster umstellen.
                                          Grafana ist jetzt umgestellt?
