  4. Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0
    6.3k
46 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • F fraso
    @thomas-braun mache ich. kannst du mich auf die Projektseiten schubsen?
    @fraso
    Wie bist du denn an die falschen Links gekommen?
    https://grafana.com/docs/grafana/latest/installation/debian/
    Influx:
    In der
    /etc/apt/sources.list.d/influxdb.list
    stretch durch buster ersetzen
    F 1 Antwort Letzte Antwort
      @fraso
      Influx:
      In der
      fraso
      pi@iobroker-pi:~ $ sudo apt-get remove --auto-remove grafana-enterprise
      Reading package lists... Done
      Building dependency tree
      The following packages will be REMOVED:
        grafana-enterprise
      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      After this operation, 258 MB disk space will be freed.
      Do you want to continue? [Y/n] Y
      (Reading database ... 67759 files and directories currently installed.)
      Removing grafana-enterprise (8.3.3) ...
      pi@iobroker-pi:~ $ sudo apt-get install -y apt-transport-https
      apt-transport-https is already the newest version (1.8.2.3).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@iobroker-pi:~ $ sudo apt-get install -y software-properties-common wget
      software-properties-common is already the newest version (0.96.20.2-2).
      wget is already the newest version (1.20.1-1.1).
      pi@iobroker-pi:~ $ wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
      OK
      pi@iobroker-pi:~ $ sudo apt-get update
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
      Hit:4 https://repos.influxdata.com/debian stretch InRelease
      Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
      pi@iobroker-pi:~ $ sudo apt-get install grafana
      The following NEW packages will be installed:
        grafana
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 41.3 MB of archives.
      After this operation, 120 MB of additional disk space will be used.
      Get:1 https://packages.grafana.com/enterprise/deb stable/main armhf grafana armhf 7.0.0 [41.3 MB]
      Fetched 41.3 MB in 6s (6,691 kB/s)
      Selecting previously unselected package grafana.
      (Reading database ... 61681 files and directories currently installed.)
      Preparing to unpack .../grafana_7.0.0_armhf.deb ...
      Unpacking grafana (7.0.0) ...
      Setting up grafana (7.0.0) ...
      Installing new version of config file /etc/default/grafana-server ...
      Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
      ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
       sudo /bin/systemctl daemon-reload
       sudo /bin/systemctl enable grafana-server
      ### You can start grafana-server by executing
       sudo /bin/systemctl start grafana-server
      Processing triggers for systemd (241-7~deb10u8+rpi1) ...
      pi@iobroker-pi:~ $
      • F fraso
          grafana-enterprise
        OK
          grafana
        pi@iobroker-pi:~ $
        fraso
        @fraso so richtig gemacht?
        • F fraso
          fraso
          @fraso sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
          mmm... jetzt hab ich beide drauf :(
          • F fraso
            fraso
            ... ich habe dann PURGE gemacht:
            • Thomas BraunT Online
              @fraso
              sudo apt update
              apt policy grafana grafana-enterprise
                @fraso
                sudo apt update
                fraso
                @thomas-braun danke. habe nur noch die 7.0.0 drauf. nehme an das ist die oss. jetzt lese ich mich gerade durch das stretch->buster zeug durch.
                • F fraso
                  fraso
                  @fraso und das hat alles mit Alexa2 zu tun das das nicht geht?
                  • F fraso
                    @fraso
                    Nein. Hab ich doch schon geschrieben. Ist aber dennoch falsch und kann an anderer Stelle für Probleme sorgen.
                    Die OSS-Version ist übrigens 8.3.3 Stand heute.
                      @fraso
                      fraso
                      @thomas-braun BUSTER - korrekt?
                      pi@iobroker-pi:~ $ cat /etc/os-release
                      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                      NAME="Raspbian GNU/Linux"
                      VERSION_ID="10"
                      VERSION="10 (buster)"
                      VERSION_CODENAME=buster
                      ID=raspbian
                      ID_LIKE=debian
                      HOME_URL="http://www.raspbian.org/"
                      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                      pi@iobroker-pi:~ $
                      • F fraso
                        VERSION_ID="10"
                        ID=raspbian
                        ID_LIKE=debian
                        pi@iobroker-pi:~ $
                        @fraso
                        Ja. Deswegen sollst du ja auch das Repository von stretch auf buster umstellen.
                        Grafana ist jetzt umgestellt?
                          @fraso
                          fraso
                          @thomas-braun ich arbeitet dran.. noch keine Ahnung wie. aber google ist mein freund.
                          • F fraso
                            @fraso
                            Vergoogle dich nur nicht...
                            apt policy grafana
                            apt policy grafana-enterprise
                            sagt?
                              @fraso
                              apt policy grafana
                              sagt?
                              fraso
                              @thomas-braun sagte in Alexa2 startet alle 5 Sek. Do not restart adapter alexa2.0:
                              apt policy grafana
                              gerade fertig geworden:
                              pi@iobroker-pi:~ $ apt policy grafana
                              grafana:
                                Installed: 8.3.3
                                Candidate: 8.3.3
                                Version table:
                               *** 8.3.3 100
                                   7.0.0 500
                                      500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages
                              pi@iobroker-pi:~ $ apt policy grafana-enterprise
                              grafana-enterprise:
                                Installed: (none)
                                Candidate: 8.3.3
                                Version table:
                                   8.3.3 500
                              • F fraso
                                apt policy grafana
                                grafana:
                                  Installed: 8.3.3
                                  Candidate: 8.3.3
                                  Version table:
                                 *** 8.3.3 100
                                     7.0.0 500
                                grafana-enterprise:
                                  Installed: (none)
                                  Candidate: 8.3.3
                                  Version table:
                                     8.3.3 500
                                @fraso
                                Da stimmt noch irgendwas nicht.
                                sudo apt update
                                  @fraso
                                  sudo apt update
                                  fraso
                                  sudo apt update
                                  pi@iobroker-pi:~ $ sudo apt update
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                  All packages are up to date.
                                  pi@iobroker-pi:~ $
                                  • F fraso
                                    sudo apt update
                                    pi@iobroker-pi:~ $
                                    @fraso
                                    ist falsch.
                                    Das muss
                                    https://packages.grafana.com/oss/deb
                                    heißen. Pass die Datei
                                    /etc/apt/sources.list.d/grafana.list an
                                    • F fraso
                                      sudo apt update
                                      pi@iobroker-pi:~ $
                                      @fraso
                                      Analog die
                                      auf buster anpassen.
                                        @fraso
                                        Analog die
                                        fraso
                                        grafana-enterprise:
                                         Installed: (none)
                                         Candidate: 7.0.0
                                         Version table:
                                            7.0.0 500
                                               500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                                        pi@iobroker-pi:~ $
                                        grafana:
                                         Installed: 8.3.3
                                         Candidate: 8.3.3
                                         Version table:
                                        *** 8.3.3 500
                                            8.3.2 500
                                            8.3.1 500
                                            8.3.0 500
                                            8.2.7 500
                                        • F fraso
                                          grafana-enterprise:
                                           Installed: (none)
                                           Candidate: 7.0.0
                                           Version table:
                                              7.0.0 500
                                          pi@iobroker-pi:~ $
                                          grafana:
                                           Installed: 8.3.3
                                           Candidate: 8.3.3
                                           Version table:
                                          *** 8.3.3 500
                                              8.3.2 500
                                              8.3.1 500
                                              8.3.0 500
                                              8.2.7 500
                                          @fraso
                                          Ja, jetzt ist es wohl sauber.
                                          sudo apt update
                                          apt policy influxdb
                                          F 2 Antworten Letzte Antwort
