  4. ioBroker auf dem Raspberry 4 B2
23 Beiträge 4 Kommentatoren 1.2k Aufrufe 3 Beobachtet
    @dr-pie
    Ja, das ist natürlich gemeint.
    Dr.PieD Offline
    Dr.PieD Offline
    Dr.Pie
    login as: pi
    pi@192.168.178.23's password:
    Linux raspberrypi 5.10.63-v7l+ #1459 SMP Wed Oct 6 16:41:57 BST 2021 armv7l
    permitted by applicable law.
    Last login: Mon Dec 13 09:26:45 2021 from 192.168.178.10
    SSH is enabled and the default password for the 'pi' user has not been changed.
    This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    pi@raspberrypi:~ $ iobroker status
    -bash: iobroker: command not found
    pi@raspberrypi:~ $ iokroker list instances
    -bash: iokroker: command not found
    pi@raspberrypi:~ $
    • Dr.PieD Dr.Pie
      login as: pi
      pi@raspberrypi:~ $
      @dr-pie
      So ähnlich...
      Der ioBroker ist offenbar noch nicht installiert.
      curl -sLf https://iobroker.net/install.sh | bash -
      fehlt noch.
      Das PW würde ich aber als erstes ändern:
      Ist das im Clip der YT-Unität nicht gemacht worden? Dann kannst du den Rest vermutlich auch vergessen.
      Dr.PieD 1 Antwort Letzte Antwort
        @dr-pie
        So ähnlich...
        fehlt noch.
        Dr.PieD Offline
        Dr.PieD Offline
        Dr.Pie
        Last login: Mon Dec 13 09:28:06 2021 from 192.168.178.10
        pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2021-08-05
            Welcome to the ioBroker installer!
            Installer version: 2021-11-18
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_12.x bullseye InRelease
        Reading package lists... Done
        Changing npm registry to https://registry.npmjs.org
        Installed gcc-c++
        Installed python-dev
            Creating ioBroker user and directory (2/4)
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
            Finalizing installation (4/4)
        Enabling autostart...
        Autostart enabled!
            ioBroker was installed successfully
            Open http://192.168.178.23:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        Objects type: file
        States  type: file
        pi@raspberrypi:~ $
        Soooo ... hab noch mal ganz frisch angefangen.
        ioBroker ist installiert und scheint auch zu laufen.
        Doch der Login klappt einfach nicht ... Seitenladefehler bei 192.168.178.23:8081
        • Dr.PieD Dr.Pie
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $
          @dr-pie sagte in ioBroker auf dem Raspberry 4 B2:
          mal den Browser refreshed? (STRG-F5)
          hattest du das vor dem iobroker status gemacht?
            Dr.PieD Offline
            Dr.PieD Offline
            Dr.Pie
            @Homoran
            ich habe die SD Karte formatiert und dann die Installation lt. der YT Anleitung durchgeführt.
            Ich kann
            iobroker status
            ja erst eingeben nachdem ich mich angemeldet habe.
            Thomas BraunT J HomoranH 3 Antworten Letzte Antwort
            • Dr.PieD Dr.Pie
              @Homoran
              Ich kann
              iobroker status
              @dr-pie
              sudo reboot
              Dann müsste das eigentlich von alleine gestartet werden.
              • Dr.PieD Dr.Pie
                @Homoran
                Ich kann
                iobroker status
                Jan1
                @dr-pie
                Das erste was mal machst, ist das YT Video vergessen.
                Installation des OS auf em PI und zwar richtig hier
                Dann IOBroker nach Doku drauf und es wird laufen ;)
                Node macht die IOBroker Installation mit, also den Punkt kannst auslassen.
                • Dr.PieD Dr.Pie
                  @Homoran
                  Ich kann
                  iobroker status
                  Ich kann
                  iobroker status
                  das war nicht die Frage!
                  Nach der Installation könntest du iobroker status sofort eingeben - darfst du aber nicht
                  und warum nicht nach der offiziellen Anleitung?
                  besteht nur aus einer Zeile und macht alles notwendige
                    Ich kann
                    iobroker status
                    Dr.PieD Offline
                    Dr.PieD Offline
                    Dr.Pie
                    Ich habe eine Anleitung gesucht die mich per Video Schritt für Schritt durch die Installation führt.
                    myNiKa's Videos habe mir schon sooo viel geholfen ... das war der Grund.
                    Ok .. dann also wieder auf 0 (Null) und neu angefangen ...
                    • Dr.PieD Dr.Pie
                      Jan1
                      Exakt die habe ich für den Pi gepostet und zwar ne aktuelle, nicht son YT Schrott mit viel Bla Bla.
                      Sobald sich was ändert, wird die Anleitung aktualisiert und die Links die man für die Tools brauch ebenfalls angepasst.
                      IOBroker Installation danach, ist exakt eine Befehlszeile.
                      Machs danach und es läuft, zumal da auch noch einiges andere klar wird.
                      Edit:
                      letzter Tipp noch, beim OS ist die simpelste Variante ohne Desktop Gedöns angesagt, bevor dich Thomas wegen dem Zeug noch belehrt ;)
                      • J Jan1
                        Edit:
                        Dr.PieD Offline
                        Dr.PieD Offline
                        Dr.Pie
                        Moin
                        soooo nach 7 Anläufen scheint es nun zu laufen.
                        Das Backup von der Synology hatte ich auf dem Pi eingespielt.
                        Leider wurden einige Sachen nicht mit gesichert und somit auf dem PI nicht mit übertragen ... haarerauf ...
                        Aber ich bin da dran ...
                        Ich Danke JEDEN der mir hier mit geholfen haben 👍 👍 👍 👍 👍
                        1000 Dank ALLEN 😊
                        • Dr.PieD Dr.Pie
                          Moin
                          1000 Dank ALLEN 😊
                          Jan1
                          und was genau fehlt?
                          • J Jan1
                            Dr.PieD Offline
                            Dr.PieD Offline
                            Dr.Pie
                            @jan1
                            Scripte und die Scenen waren nicht mit im Backup.
                            Mittlerweile habe ich sie kopiert und auf den Pi geschoben ... alles gut ...
                            • Dr.PieD Dr.Pie
                              @jan1
                              Jan1
                              @dr-pie
                              dann hast den Backitup Adapter nicht richtig konfiguriert. Hier sollten die Haken drin sein, was mit rein soll:
                              Bei den Scenen bin ich nicht sicher, da ich die nicht mehr verwende, waren mir zu umständlich ;)
                              • J Jan1
                                @dr-pie
                                @jan1 sagte in ioBroker auf dem Raspberry 4 B2:
                                scripte sind auch im Basisbackup mit drin.
                                Szenen eigentlich auch, hab ich aber auch schon lange nicht mehr.
                                  Jan1
                                  Dachte ich mir fast, da das Zigbee Zeug auch mit drin ist. Heißt die Haken sind dann nur dafür da, dass man noch mal separat sichern kann und somit eigentlich nicht nötig?
                                  • J Jan1
                                    Ja, wobei das bei den Scripten sogar "gefährlich" sein kann.
                                    du benötigst dann ein Spiegelverzeichnis, das gesichert wird.
                                    und das macht genau das wie es heisst.
                                    Es spiegelt bidirektional. Wenn du dann was im Verzeichnis löschst sind auch diese Skripte in ioBroker weg.
                                    Vielleicht ist dieses ja passiert:
                                    im Haupt-Backup waren sie noch drin, das Script Backup war leer, weil nicht korrekt eingerichtet.....
