  4. Adapter zur Steuerung von Projektoren (PJLink / PJLinkV2)
43 Beiträge 12 Kommentatoren 10.4k Aufrufe 10 Beobachtet
    derBonsaii
    @oberstel
    Hab alles frisch installiert, d.H. Polling Intervall etc. ist alles auf Standard.
    Hier die Logdaten:
    pjlink.0	2019-12-22 01:22:40.007	debug	idle
    pjlink.0	2019-12-22 01:22:40.007	debug	current device power state: 0
    pjlink.0	2019-12-22 01:22:30.027	debug	idle
    pjlink.0	2019-12-22 01:22:30.027	debug	current device power state: 0
    pjlink.0	2019-12-22 01:22:19.998	debug	idle
    pjlink.0	2019-12-22 01:22:19.997	debug	current device power state: 0
    pjlink.0	2019-12-22 01:22:10.138	debug	stateChange pjlink.0.av_mute {"val":"0","ack":true,"ts":1576974130137,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576969670986}
    pjlink.0	2019-12-22 01:22:10.093	debug	stateChange pjlink.0.inputSource {"val":"0","ack":true,"ts":1576974130091,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576974130091}
    pjlink.0	2019-12-22 01:22:10.091	debug	initial input source: 0
    pjlink.0	2019-12-22 01:22:10.090	debug	stateChange pjlink.0.power {"val":"0","ack":true,"ts":1576974130089,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576971351750}
    pjlink.0	2019-12-22 01:22:10.088	debug	initial power state: 0
    pjlink.0	2019-12-22 01:22:10.087	debug	stateChange pjlink.0.info.inputSources {"val":["0"],"ack":true,"ts":1576974130085,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576974130085}
    pjlink.0	2019-12-22 01:22:10.086	debug	inputSources: 0
    pjlink.0	2019-12-22 01:22:10.075	debug	stateChange pjlink.0.info.class {"val":"0","ack":true,"ts":1576974130073,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576974130073}
    pjlink.0	2019-12-22 01:22:10.074	debug	class: 0
    pjlink.0	2019-12-22 01:22:10.056	debug	stateChange pjlink.0.info.info {"val":"0","ack":true,"ts":1576974130051,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576974130051}
    pjlink.0	2019-12-22 01:22:10.051	debug	info: 0
    pjlink.0	2019-12-22 01:22:10.019	debug	stateChange pjlink.0.info.info2 {"val":"0","ack":true,"ts":1576974130016,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576970198408}
    pjlink.0	2019-12-22 01:22:10.019	debug	stateChange pjlink.0.info.info1 {"val":"0","ack":true,"ts":1576974130016,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576970198401}
    pjlink.0	2019-12-22 01:22:10.019	debug	stateChange pjlink.0.info.name {"val":"0","ack":true,"ts":1576974130016,"q":0,"from":"system.adapter.pjlink.0","user":"system.user.admin","lc":1576970198400}
    pjlink.0	2019-12-22 01:22:10.003	debug	info2: 0
    pjlink.0	2019-12-22 01:22:10.001	debug	info1: 0
    pjlink.0	2019-12-22 01:22:09.998	debug	name: 0
    pjlink.0	2019-12-22 01:22:09.988	info	config polltime: 10000
    pjlink.0	2019-12-22 01:22:09.988	info	config port: 4352
    pjlink.0	2019-12-22 01:22:09.988	info	config host: 192.168.0.0 (IP stimmt)
    pjlink.0	2019-12-22 01:22:09.988	info	PJlink Class#1
    pjlink.0	2019-12-22 01:22:09.988	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.pjlink, node: v8.16.0
    pjlink.0	2019-12-22 01:22:07.127	info	cleaned everything up...
    pjlink.0	2019-12-22 01:22:07.123	info	cleaned everything up...
    Danach wiederholt sich
    durchgehend ...
    ich bin leider nicht so bewandert, dass ich erkennen würde woran es liegen könnte ...
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • oberstelO oberstel
      @derBonsaii
      Das ist schon komisch. Hast Du das Polling Interval geändert? Eigentlich sollte er alle 10 Sekunden eine Abfrage machen... (Polling Interval = 10000).
      Stelle doch mal den Log Level auf Debug und gucke was er so ausspuckt.
      N Offline
      N Offline
      nickname
      @oberstel
      Ich habe das gleiche Problem beim Optoma UHD51.
      Im Log steht bei mir nur: Error: Device Not responding
      Und in allen Objekten von PjLink der Wert 0
      Die Verbindung zum Beamer steht und das Polling Intervall ist bei 10000.
      Versuche das ganze schon seit einiger Zeit zum Laufen zu bringen, also bin ich über jegliche Hinweise, oder Hilfe sehr dankbar.
      I 1 Antwort Letzte Antwort
      • N nickname
        @oberstel
        I Offline
        I Offline
        Ittykind
        @nickname
        Hallo Zusammen und ein frohes neues Jahr 🎆,
        Vielleicht hilft euch meine Info. Nachdem ich ebenso wie ihr ähnliche Probleme hatte, habe ich in der Konfiguration meines Epson den Passwortschutz in Pjlink deaktiviert und prompt funktionierte alles. Einzig der Beamer lies sich über Iobroker nicht wieder einschalten. Das lag natürlich daran, das der Beamer nach dem ausschalten ja auch die Netzwerkverbindung gekappt hat. Bei meinem Epson konnte ich in den erweiterten Einstellungen allerdings einstellen, daß bei ausgeschaltetem Gerät trotzdem die Kommunikation erhalten bleibt, danach funktionierte auch das einschalten.
        Bis bald und danke für das tolle Forum
        • I Ittykind
          @nickname
          derBonsaii
          @Ittykind Beim UHD51 kann leider das Adminpasswort nicht deaktiviert werden ... Passwort hab ich zwar hinterlegt, aber es funktioniert halt nicht :/
          @nickname Die Steuerung via Browser funktioniert ja grundsätzlich, gibt es evtl. ne Möglichkeit via Wireshark den Befehl abzufangen?
          Weil eigentlich wil ich nur, dass der Beamer beim Befehl angeht, die Leinwand runterfährt und die Vorhänge schliessen und danach alles alles in die andere Richtung ...
          Lampendauer etc wären mir nicht sooo wichtig =D
          • D derBonsaii
            Tach :)
            Hab zum Glück rausgefunden, dass mein Optoma UHD51 ebenfalls PJLink unterstützt, hab dann IP etc angepasst, allerdings werden die Daten nicht aktualisiert, d.H. steht immer alles auf 0.
            Fehlermeldung erhalte ich keine …
            Hat da wer ne Ahnung, woran das liegen könnte?
            f11hF Offline
            f11hF Offline
            f11h
            @derBonsaii Hab Deinem Ticket auf Github einen PullRequest mit Bugfix für Optoma Projektoren hinzugefügt. Mit meinem UHD380x läufts jetzt.
            Bis der PR gemergt ist, kann der Bugfix mit diesem Link installiert werden: https://github.com/f11h/ioBroker.pjlink/archive/OptomaProjectorBugfix.tar.gz
            • H Offline
              hansmeier
              Hallo ! Ich versuche diesen Adapter mit meinem Sony Beamer VW270ES zusammenzubringen. Leider gibt es keinen Connect: Error: Device not responding
              Im Sony Beamer kann man explizit den PJ Talk Service aktivieren. Vorgegeben ist der Port 53484. Auch eine Host Adresse kann man hier einrichten. Käme hier der ioBroker Host herein ?
              im Sony Beamer muss zumindest der Admin-User "root" mit PSW eingerichtet sein. Dieses PSW gebe ich im Adapter ein. Jedoch fehlt dort der User-Name ? In meinem Falle ist es ja root.
              Kann hier jemand helfen ? Offensichtlich sind alle Parameter die ich in den Adapter Settings eingebe richtig und der Beamer ist auch PJ Kompatibel und der Dienst ist aktiv.
              Noch was am Rande: Der Sony VW270ES bietet neben PJ auch andere Dienste wie Crestron und ADCP. Gebe ich den Port für ADCP ein, bekomme ich eine Verbindung und die Instanz wird grün.
              LG Hans
              oberstelO 1 Antwort Letzte Antwort
                Kev0
                @oberstel Gibts eine Möglichkeit den adapter an admin 5 anzupassen.
                Nachdem der Beamer via Switch bei mit vom netzt genommen wird, hilf nur ein Adapter-Neustart. Bis admin 5 gings auch gut, nur wird der adapter jetzt wegen wiederhalter reboots gekillt und ich hab quasi keine Funktion bis manuell neu gestartet wird.
                Kevin
                M oberstelO 2 Antworten Letzte Antwort
                • K Kev0
                  Kevin
                  mpenno
                  ich würde mich auch freuen, wenn der Adapter noch einmal für Admin 5 und dem aktuellem js-controller angepasst werden könnte.
                  Zum einen kommen sehr viele Meldungen (wie bei anderen Adaptern auch):
                  2021-11-30 17:57:42.832 - info: pjlink.0 (22823) changed power to 1 3feae094
                  2021-11-30 17:57:42.834 - info: pjlink.0 (22823) State value to set for "pjlink.0.power" has to be type "number" but received type "string"
                  2021-11-30 17:57:52.830 - info: pjlink.0 (22823) State value to set for "pjlink.0.power" has to be type "number" but received type "string"
                  2021-11-30 17:57:52.835 - info: pjlink.0 (22823) changed power to 1 6840a85e
                  2021-11-30 17:57:52.837 - info: pjlink.0 (22823) State value to set for "pjlink.0.power" has to be type "number" but received type "string"
                  Der Kontakt zum Epson Beamer mit Benutzer+Passwort ging sofort, allerdings sind die Objekt-Werte bei mir noch codiert:
                  Ist es bei Euch auch so?
                  VG Michael
                  • M mpenno
                    VG Michael
                    oberstelO Offline
                    oberstelO Offline
                    oberstel
                    @mpenno Ich habe den Adapter komplett neu gebaut > "PJLinkV2".
                    Werde ihn die Tage mal auf GutHub stellen und gebe dann hier bescheid.
                      oberstelO Offline
                      oberstelO Offline
                      oberstel
                      schrieb am zuletzt editiert von oberstel
                      So, ich war dann mal etwas aktiv und habe auf GitHub eine neue Version (2.1.0) hochgeladen... wie angekündigt, gibt es jetzt die zweite Evolution des Adapters (V2), im neuen Adapter Design, mit besseren Error Handling, angepasst an Admin5 usw.
                      Bitte entfernt die alte Version (PJLink) manuell, falls vorhanden!
                      PJLinkV2: https://github.com/oberstel/ioBroker.PJLinkV2.git
                      Einige Sachen funktionieren noch nicht so dolle, ist alles im readme.md beschrieben.
                      Feedback zu dem Adapter gerne hier im Forum...
                      • K Kev0
                        Kevin
                        oberstelO Offline
                        oberstelO Offline
                        oberstel
                        @kev0 dieses Verhalten sollte mit der aktuellen Version nicht mehr vorkommen. Es wird jetzt immer erst geprüft ob das Gerät überhaupt da ist... bitte probiere das mal aus.
                        • H hansmeier
                          LG Hans
                          oberstelO Offline
                          oberstelO Offline
                          oberstel
                          @hansmeier Ich weiß, Dein Post ist schon etwas älter... sorry das ich erst jetzt antworte.
                          Bist Du dir sicher, dass der Projektor PJLink sprechen kann? Ich habe mal eben im Handbuch nachgeschaut und finde da nix zu PJLink (auch PJ Talk habe ich dort nicht gefunden).
                            mpenno
                            @oberstel
                            Hallo und vielen Dank.
                            Ich habe es gerade mal getestet.
                            Ich habe den alten Adapter gelöscht und neuinstalliert. Er startete gut und konnte auch gleich ein paar Werte auslesen:
                            (Nur zur Info, mein Beamer ist noch im Standby. Die Einstellung, dass eine Kommunikation im Standby Modus möglich sein soll, habe ich letztens im Beamer-Menü gemacht.)
                            Leider kam dann die Fehlermeldung:
                            Im Log steht was, dass mein Epson Beamer nicht "Class 2" unterstützen würde. Laut Anleitung schon:
                            Hier einmal das Log:
                            2021-12-10 18:05:13.540 - info: host.iobroker iobroker del pjlink
                            2021-12-10 18:05:14.928 - info: smartmeter.0 (535) Received 7 values, 3 updated
                            2021-12-10 18:05:15.345 - info: host.iobroker iobroker Delete adapter "pjlink"
                            2021-12-10 18:05:15.381 - info: host.iobroker iobroker host.iobroker Counted 1 meta of pjlink
                            2021-12-10 18:05:15.387 - info: host.iobroker iobroker host.iobroker Counted 1 adapter for pjlink
                            2021-12-10 18:05:15.526 - info: host.iobroker iobroker host.iobroker Counted 2 states (system.adapter.pjlink.*) from states
                            2021-12-10 18:05:16.635 - info: host.iobroker iobroker host.iobroker file pjlink.admin deleted
                            2021-12-10 18:05:16.642 - info: host.iobroker iobroker host.iobroker object pjlink deleted
                            2021-12-10 18:05:16.652 - info: host.iobroker iobroker host.iobroker object pjlink.admin deletedhost.iobroker Deleting 2 object(s).
                            2021-12-10 18:05:16.730 - info: host.iobroker iobroker host.iobroker Deleting 2 state(s).
                            2021-12-10 18:05:16.745 - info: host.iobroker iobroker npm uninstall iobroker.pjlink --loglevel error --prefix "/opt/iobroker" (System call)
                            2021-12-10 18:06:31.607 - info: host.iobroker iobroker exit 0
                            2021-12-10 18:09:06.075 - info: host.iobroker iobroker url https://github.com/oberstel/ioBroker.PJLinkV2.git --host iobroker
                            2021-12-10 18:09:08.479 - info: host.iobroker iobroker install oberstel/ioBroker.PJLinkV2#49885907c804e024cbe1f5788ec18eee2cd0c36c
                            2021-12-10 18:09:08.969 - info: host.iobroker iobroker NPM version: 6.14.15
                            2021-12-10 18:09:08.971 - info: host.iobroker iobroker npm install oberstel/ioBroker.PJLinkV2#49885907c804e024cbe1f5788ec18eee2cd0c36c --loglevel error --prefix "/opt/iobroker" (System call)
                            2021-12-10 18:10:11.940 - error: host.iobroker iobroker host.iobroker Cannot install oberstel/ioBroker.PJLinkV2#49885907c804e024cbe1f5788ec18eee2cd0c36c: 0
                            2021-12-10 18:10:12.958 - info: host.iobroker iobroker exit 25
                            2021-12-10 18:10:16.620 - info: smartmeter.0 (535) Received 7 values, 3 updated
                            2021-12-10 18:10:33.672 - info: knx.0 (636) Value received on unknown GA : 10/0/21
                            2021-12-10 18:10:55.551 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                            2021-12-10 18:11:15.000 - info: host.iobroker iobroker add pjlinkv2 --host iobroker
                            2021-12-10 18:11:16.912 - info: host.iobroker iobroker host.iobroker install adapter pjlinkv2
                            2021-12-10 18:11:16.918 - info: host.iobroker iobroker npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.pjlinkv2"
                            2021-12-10 18:11:43.412 - info: host.iobroker iobroker upload [4] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/words.js words.js application/javascript
                            2021-12-10 18:11:43.509 - info: host.iobroker iobroker upload [3] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/style.css style.css text/css
                            2021-12-10 18:11:43.570 - info: host.iobroker iobroker upload [2] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/pjlink.png pjlink.png image/png
                            2021-12-10 18:11:43.631 - info: host.iobroker iobroker upload [1] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/index_m.html index_m.html text/html
                            2021-12-10 18:11:43.690 - info: host.iobroker iobroker upload [0] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/custom_m.html custom_m.html text/html
                            2021-12-10 18:11:43.837 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2 created/updated
                            2021-12-10 18:11:43.893 - info: host.iobroker iobroker host.iobroker create instance pjlinkv2
                            2021-12-10 18:11:43.907 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.logLevel created
                            2021-12-10 18:11:43.939 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.sigKill created
                            2021-12-10 18:11:43.972 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.eventLoopLag created
                            2021-12-10 18:11:44.004 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.outputCount created
                            2021-12-10 18:11:44.037 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.inputCount created
                            2021-12-10 18:11:44.070 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.uptime created
                            2021-12-10 18:11:44.103 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.memRss created
                            2021-12-10 18:11:44.135 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.memHeapTotal created
                            2021-12-10 18:11:44.168 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.memHeapUsed created
                            2021-12-10 18:11:44.204 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.cputime created
                            2021-12-10 18:11:44.235 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.cpu created
                            2021-12-10 18:11:44.269 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.compactMode created
                            2021-12-10 18:11:44.301 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.connected created
                            2021-12-10 18:11:44.333 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.alive created
                            2021-12-10 18:11:44.373 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0 created
                            2021-12-10 18:11:45.428 - info: host.iobroker iobroker exit 0
                            2021-12-10 18:11:47.499 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 986
                            2021-12-10 18:11:50.168 - info: pjlinkv2.0 (986) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                            2021-12-10 18:11:50.194 - info: pjlinkv2.0 (986) Starting PJLink V2 Adapter...
                            2021-12-10 18:12:42.518 - info: host.iobroker stopInstance system.adapter.pjlinkv2.0 (force=false, process=true)
                            2021-12-10 18:12:42.530 - info: pjlinkv2.0 (986) Got terminate signal TERMINATE_YOURSELF
                            2021-12-10 18:12:42.532 - info: pjlinkv2.0 (986) terminating
                            2021-12-10 18:12:42.533 - info: pjlinkv2.0 (986) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-12-10 18:12:42.566 - info: host.iobroker stopInstance system.adapter.pjlinkv2.0 send kill signal
                            2021-12-10 18:12:43.120 - info: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2021-12-10 18:12:45.645 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 1050
                            2021-12-10 18:12:47.068 - info: pjlinkv2.0 (1050) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                            2021-12-10 18:12:47.095 - info: pjlinkv2.0 (1050) Starting PJLink V2 Adapter...
                            2021-12-10 18:12:47.096 - info: pjlinkv2.0 (1050) Trying to connect to:10.0.0.44 on port:4352
                            2021-12-10 18:12:47.324 - warn: pjlinkv2.0 (1050) PJLink Class2 ist configured, but device supports Class1 55977a50. Consider changing your config.
                            2021-12-10 18:12:52.328 - error: pjlinkv2.0 (1050) uncaught exception: Cannot read property 'log' of undefined
                            2021-12-10 18:12:52.329 - error: pjlinkv2.0 (1050) TypeError: Cannot read property 'log' of undefined
                            at translateErrorState (/opt/iobroker/node_modules/iobroker.pjlinkv2/main.js:539:14)
                            at /opt/iobroker/node_modules/iobroker.pjlinkv2/main.js:326:64
                            at Socket. (/opt/iobroker/node_modules/iobroker.pjlinkv2/lib/pjlink.js:59:8)
                            at Socket.emit (events.js:314:20)
                            at addChunk (_stream_readable.js:297:12)
                            at readableAddChunk (_stream_readable.js:272:9)
                            at Socket.Readable.push (_stream_readable.js:213:10)
                            at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
                            2021-12-10 18:12:52.330 - error: pjlinkv2.0 (1050) Cannot read property 'log' of undefined
                            2021-12-10 18:12:52.335 - info: pjlinkv2.0 (1050) terminating
                            2021-12-10 18:12:52.338 - warn: pjlinkv2.0 (1050) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2021-12-10 18:12:52.912 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2021-12-10 18:12:52.914 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                            2021-12-10 18:13:22.934 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 1091
                            2021-12-10 18:13:24.430 - info: pjlinkv2.0 (1091) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                            2021-12-10 18:13:24.456 - info: pjlinkv2.0 (1091) Starting PJLink V2 Adapter...
                            2021-12-10 18:13:24.457 - info: pjlinkv2.0 (1091) Trying to connect to:10.0.0.44 on port:4352
                            2021-12-10 18:13:24.586 - warn: pjlinkv2.0 (1091) PJLink Class2 ist configured, but device supports Class1 697d3f42. Consider changing your config.
                            2021-12-10 18:13:29.589 - error: pjlinkv2.0 (1091) uncaught exception: Cannot read property 'log' of undefined
                            2021-12-10 18:13:29.591 - error: pjlinkv2.0 (1091) TypeError: Cannot read property 'log' of undefined
                            2021-12-10 18:13:29.592 - error: pjlinkv2.0 (1091) Cannot read property 'log' of undefined
                            2021-12-10 18:13:29.601 - info: pjlinkv2.0 (1091) terminating
                            2021-12-10 18:13:29.603 - warn: pjlinkv2.0 (1091) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2021-12-10 18:13:30.167 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2021-12-10 18:13:30.168 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                            2021-12-10 18:14:00.261 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 1142
                            2021-12-10 18:14:01.603 - info: pjlinkv2.0 (1142) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                            2021-12-10 18:14:01.632 - info: pjlinkv2.0 (1142) Starting PJLink V2 Adapter...
                            2021-12-10 18:14:01.633 - info: pjlinkv2.0 (1142) Trying to connect to:10.0.0.44 on port:4352
                            2021-12-10 18:14:01.710 - warn: pjlinkv2.0 (1142) PJLink Class2 ist configured, but device supports Class1 69d17afa. Consider changing your config.
                            2021-12-10 18:14:06.713 - error: pjlinkv2.0 (1142) uncaught exception: Cannot read property 'log' of undefined
                            2021-12-10 18:14:06.715 - error: pjlinkv2.0 (1142) TypeError: Cannot read property 'log' of undefined
                            2021-12-10 18:14:06.716 - error: pjlinkv2.0 (1142) Cannot read property 'log' of undefined
                            2021-12-10 18:14:06.721 - info: pjlinkv2.0 (1142) terminating
                            2021-12-10 18:14:06.722 - warn: pjlinkv2.0 (1142) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2021-12-10 18:14:07.288 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2021-12-10 18:14:07.289 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                            2021-12-10 18:14:07.289 - warn: host.iobroker Do not restart adapter system.adapter.pjlinkv2.0 because restart loop detected
                            2021-12-10 18:15:17.668 - info: smartmeter.0 (535) Received 7 values, 3 updated
                            Achja und stimmt. Bei der Installation des Adapters kommt der Error code 25. ;-)
                            Gerne probiere ich was, wenn Du magst.
                            (Ich gehe schon mal zum Beamer und schalte ihn an, vielleicht ändert sich was)
                            Viele Grüße
                            Michael
                            • M mpenno
                              @oberstel
                              Viele Grüße
                              Michael
                              mpenno
                              Nachtrag:
                              Ich habe den Beamer angeschaltet, änderte aber nichts am Verhalten.
                              Dann habe ich beim Adapter auf "Class 1" gestellt. Der Adapter ist dann auch wieder abgestürzt und brachte folgende Fehlermeldungen:
                              2021-12-10 18:20:19.525 - info: smartmeter.0 (535) Received 7 values, 3 updated
                              2021-12-10 18:25:21.473 - info: smartmeter.0 (535) Received 7 values, 3 updated
                              2021-12-10 18:25:33.528 - info: knx.0 (636) Value received on unknown GA : 10/0/21
                              2021-12-10 18:30:22.617 - info: smartmeter.0 (535) Received 7 values, 3 updated
                              2021-12-10 18:32:52.738 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 2079
                              2021-12-10 18:32:54.183 - info: pjlinkv2.0 (2079) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                              2021-12-10 18:32:54.213 - info: pjlinkv2.0 (2079) Starting PJLink V2 Adapter...
                              2021-12-10 18:32:54.214 - info: pjlinkv2.0 (2079) Trying to connect to:10.0.0.44 on port:4352
                              2021-12-10 18:32:54.364 - warn: pjlinkv2.0 (2079) PJLink Class2 ist configured, but device supports Class1 19af035a. Consider changing your config.
                              2021-12-10 18:32:59.368 - error: pjlinkv2.0 (2079) uncaught exception: Cannot read property 'log' of undefined
                              2021-12-10 18:32:59.370 - error: pjlinkv2.0 (2079) TypeError: Cannot read property 'log' of undefined
                              2021-12-10 18:32:59.371 - error: pjlinkv2.0 (2079) Cannot read property 'log' of undefined
                              2021-12-10 18:32:59.438 - info: pjlinkv2.0 (2079) terminating
                              2021-12-10 18:32:59.440 - warn: pjlinkv2.0 (2079) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-12-10 18:33:00.009 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-12-10 18:33:00.010 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                              2021-12-10 18:33:30.030 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 2131
                              2021-12-10 18:33:31.494 - info: pjlinkv2.0 (2131) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                              2021-12-10 18:33:31.522 - info: pjlinkv2.0 (2131) Starting PJLink V2 Adapter...
                              2021-12-10 18:33:31.524 - info: pjlinkv2.0 (2131) Trying to connect to:10.0.0.44 on port:4352
                              2021-12-10 18:33:31.600 - warn: pjlinkv2.0 (2131) PJLink Class2 ist configured, but device supports Class1 72401745. Consider changing your config.
                              2021-12-10 18:33:36.604 - error: pjlinkv2.0 (2131) uncaught exception: Cannot read property 'log' of undefined
                              2021-12-10 18:33:36.605 - error: pjlinkv2.0 (2131) TypeError: Cannot read property 'log' of undefined
                              2021-12-10 18:33:36.606 - error: pjlinkv2.0 (2131) Cannot read property 'log' of undefined
                              2021-12-10 18:33:36.612 - info: pjlinkv2.0 (2131) terminating
                              2021-12-10 18:33:36.613 - warn: pjlinkv2.0 (2131) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-12-10 18:33:37.177 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-12-10 18:33:37.178 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                              2021-12-10 18:34:07.202 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 2171
                              2021-12-10 18:34:08.584 - info: pjlinkv2.0 (2171) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                              2021-12-10 18:34:08.611 - info: pjlinkv2.0 (2171) Starting PJLink V2 Adapter...
                              2021-12-10 18:34:08.612 - info: pjlinkv2.0 (2171) Trying to connect to:10.0.0.44 on port:4352
                              2021-12-10 18:34:08.686 - warn: pjlinkv2.0 (2171) PJLink Class2 ist configured, but device supports Class1 5fbc2cf1. Consider changing your config.
                              2021-12-10 18:34:13.689 - error: pjlinkv2.0 (2171) uncaught exception: Cannot read property 'log' of undefined
                              2021-12-10 18:34:13.691 - error: pjlinkv2.0 (2171) TypeError: Cannot read property 'log' of undefined
                              2021-12-10 18:34:13.692 - error: pjlinkv2.0 (2171) Cannot read property 'log' of undefined
                              2021-12-10 18:34:13.697 - info: pjlinkv2.0 (2171) terminating
                              2021-12-10 18:34:13.699 - warn: pjlinkv2.0 (2171) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-12-10 18:34:14.264 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-12-10 18:34:14.266 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                              2021-12-10 18:34:14.266 - warn: host.iobroker Do not restart adapter system.adapter.pjlinkv2.0 because restart loop detected
                              2021-12-10 18:34:40.520 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 2210
                              2021-12-10 18:34:41.921 - info: pjlinkv2.0 (2210) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                              2021-12-10 18:34:41.948 - info: pjlinkv2.0 (2210) Starting PJLink V2 Adapter...
                              2021-12-10 18:34:41.949 - info: pjlinkv2.0 (2210) Trying to connect to:10.0.0.44 on port:4352
                              2021-12-10 18:34:42.029 - warn: pjlinkv2.0 (2210) PJLink Class1 ist configured, but device supports Class1 128c20c3. Consider changing your config.
                              2021-12-10 18:34:47.033 - error: pjlinkv2.0 (2210) uncaught exception: Cannot read property 'log' of undefined
                              2021-12-10 18:34:47.034 - error: pjlinkv2.0 (2210) TypeError: Cannot read property 'log' of undefined
                              2021-12-10 18:34:47.035 - error: pjlinkv2.0 (2210) Cannot read property 'log' of undefined
                              2021-12-10 18:34:47.040 - info: pjlinkv2.0 (2210) terminating
                              2021-12-10 18:34:47.042 - warn: pjlinkv2.0 (2210) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-12-10 18:34:47.612 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-12-10 18:34:47.613 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                              2021-12-10 18:35:17.635 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 2262
                              2021-12-10 18:35:19.023 - info: pjlinkv2.0 (2262) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                              2021-12-10 18:35:19.052 - info: pjlinkv2.0 (2262) Starting PJLink V2 Adapter...
                              2021-12-10 18:35:19.053 - info: pjlinkv2.0 (2262) Trying to connect to:10.0.0.44 on port:4352
                              2021-12-10 18:35:19.121 - warn: pjlinkv2.0 (2262) PJLink Class1 ist configured, but device supports Class1 2606895a. Consider changing your config.
                              2021-12-10 18:35:23.445 - info: smartmeter.0 (535) Received 7 values, 3 updated
                              2021-12-10 18:35:24.124 - error: pjlinkv2.0 (2262) uncaught exception: Cannot read property 'log' of undefined
                              2021-12-10 18:35:24.126 - error: pjlinkv2.0 (2262) TypeError: Cannot read property 'log' of undefined
                              2021-12-10 18:35:24.127 - error: pjlinkv2.0 (2262) Cannot read property 'log' of undefined
                              2021-12-10 18:35:24.131 - info: pjlinkv2.0 (2262) terminating
                              2021-12-10 18:35:24.133 - warn: pjlinkv2.0 (2262) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-12-10 18:35:24.698 - error: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-12-10 18:35:24.699 - info: host.iobroker Restart adapter system.adapter.pjlinkv2.0 because enabled
                              • M mpenno
                                Nachtrag:
                                oberstelO Offline
                                oberstelO Offline
                                oberstel
                                @mpenno sagte in Adapter zur Steuerung von Projektoren (PJLink / PJLinkV2):
                                18:34:08.686 - warn: pjlinkv2.0 (2171) PJLink Class2 ist configured, but device supports Class1 5fbc2cf1. Consider changing your config. 2021-12-10 18:34:13.689 - error: pjlinkv2.0 (2171) uncaught exception: Cannot read property 'log' of undefined
                                Laut Log hast Du anscheinend Class#2 in den Adapter Settings ausgewählt, allerdings kann der Adapter das noch gar nicht (habe ich noch nicht implementiert, da ich das nicht testen kann). Eigentlich sollte ein Class#2 kompatibler Projektor auch Class#1 unterstützen (abwärts kompatibel). Bitte probiere mal Class#1 auszuwählen und poste hier nochmal einen Auszug aus dem Log.
                                Wenn Du Lust hast, könntest Du mir bei der Implementierung der Class#2 Fähigkeiten etwas helfen... Ich würde gerne die entspr. Funktionen einbauen und es wäre klasse, wenn Du das dann testen könntest?
                                • M mpenno
                                  @oberstel
                                  Viele Grüße
                                  Michael
                                  oberstelO Offline
                                  oberstelO Offline
                                  oberstel
                                  Das habe ich inzwischen gefixed. Mit der aktuellen Version 2.1.5 sollte der Fehler nicht mehr kommen.
                                    mpenno
                                    @oberstel Ja gerne mache ich mit.
                                    Ich habe gerade einmal die aktuelle Version (2.1.5) von Github installiert. Vorher habe ich manuell die Instanz und die alte Adapter-Version gelöscht.
                                    Der Error Code 25 kam leider trotzdem. Hätte ich noch den ioBroker neustarten sollen?
                                    Hier mal die Zustände, die als "Class1" ausgelesen werden können:
                                    Es aktualisiert sich nur der Error-Code. Da bin ich übrigens gespannt, ob da was dran ist, denn der Lüfter macht wirklich komische Geräusche. Aber ich bin der einzige in der Familie, dem es auffällt.
                                    Die anderen Statis egal, ob ich an-/ausschalte oder den HDMI Eingang wechsel, ändern sich nicht.
                                    2021-12-17 16:41:26.098 - info: host.iobroker iobroker del pjlinkv2.0
                                    2021-12-17 16:41:31.808 - info: host.iobroker iobroker Delete adapter "pjlinkv2.0"
                                    2021-12-17 16:41:31.825 - info: host.iobroker iobroker host.iobroker Counted 1 instances of pjlinkv2.0
                                    2021-12-17 16:41:31.874 - info: host.iobroker iobroker host.iobroker Counted 23 states of pjlinkv2.0
                                    2021-12-17 16:41:31.892 - info: host.iobroker iobroker host.iobroker Counted 14 states of system.adapter.pjlinkv2.0
                                    2021-12-17 16:41:31.902 - info: host.iobroker iobroker host.iobroker Counted 16 states (io.pjlinkv2.0.*) from states
                                    2021-12-17 16:41:31.920 - info: host.iobroker iobroker host.iobroker Counted 14 states (system.adapter.pjlinkv2.0.*) from states
                                    2021-12-17 16:41:32.919 - info: host.iobroker iobroker host.iobroker Deleting 38 object(s).
                                    2021-12-17 16:41:34.532 - info: host.iobroker object deleted system.adapter.pjlinkv2.0
                                    2021-12-17 16:41:34.594 - info: host.iobroker iobroker host.iobroker Deleting 30 state(s).
                                    2021-12-17 16:41:35.751 - info: host.iobroker iobroker exit 0
                                    2021-12-17 16:41:52.784 - info: host.iobroker iobroker del pjlinkv2
                                    2021-12-17 16:41:54.618 - info: host.iobroker iobroker Delete adapter "pjlinkv2"
                                    2021-12-17 16:41:54.670 - info: host.iobroker iobroker host.iobroker Counted 1 meta of pjlinkv2
                                    2021-12-17 16:41:54.677 - info: host.iobroker iobroker host.iobroker Counted 1 adapter for pjlinkv2
                                    2021-12-17 16:41:55.937 - info: host.iobroker iobroker host.iobroker file pjlinkv2.admin deleted
                                    2021-12-17 16:41:55.944 - info: host.iobroker iobroker host.iobroker object pjlinkv2 deleted
                                    2021-12-17 16:41:55.952 - info: host.iobroker iobroker host.iobroker object pjlinkv2.admin deleted
                                    2021-12-17 16:41:55.953 - info: host.iobroker iobroker host.iobroker Deleting 2 object(s).
                                    2021-12-17 16:41:56.066 - info: host.iobroker iobroker npm uninstall iobroker.pjlinkv2 --loglevel error --prefix "/opt/iobroker" (System call)
                                    2021-12-17 16:43:12.178 - info: host.iobroker iobroker exit 0
                                    2021-12-17 16:43:44.727 - info: smartmeter.0 (535) Received 7 values, 3 update
                                    2021-12-17 16:48:46.237 - info: smartmeter.0 (535) Received 7 values, 3 updated
                                    2021-12-17 16:50:14.113 - info: host.iobroker iobroker url https://github.com/oberstel/ioBroker.PJLinkV2.git --host iobroker
                                    2021-12-17 16:50:16.499 - info: host.iobroker iobroker install oberstel/ioBroker.PJLinkV2#229a72387901a2328ceb811a6d4ec5cb441dd2ef
                                    2021-12-17 16:50:17.008 - info: host.iobroker iobroker NPM version: 6.14.15
                                    2021-12-17 16:50:17.011 - info: host.iobroker iobroker npm install oberstel/ioBroker.PJLinkV2#229a72387901a2328ceb811a6d4ec5cb441dd2ef --loglevel error --prefix "/opt/iobroker" (System call)
                                    2021-12-17 16:51:24.399 - error: host.iobroker iobroker host.iobroker Cannot install oberstel/ioBroker.PJLinkV2#229a72387901a2328ceb811a6d4ec5cb441dd2ef: 0
                                    2021-12-17 16:51:25.424 - info: host.iobroker iobroker exit 25
                                    2021-12-17 16:52:25.296 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                    2021-12-17 16:52:46.025 - info: host.iobroker iobroker add pjlinkv2 auto --host iobroker
                                    2021-12-17 16:52:47.975 - info: host.iobroker iobroker host.iobroker install adapter pjlinkv2
                                    2021-12-17 16:52:47.980 - info: host.iobroker iobroker npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.pjlinkv2"
                                    2021-12-17 16:53:17.102 - info: host.iobroker iobroker upload [4] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/words.js words.js application/javascript
                                    2021-12-17 16:53:17.200 - info: host.iobroker iobroker upload [3] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/style.css style.css text/css
                                    2021-12-17 16:53:17.289 - info: host.iobroker iobroker upload [2] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/pjlink.png pjlink.png image/png
                                    2021-12-17 16:53:17.349 - info: host.iobroker iobroker upload [1] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/index_m.html index_m.html text/html
                                    2021-12-17 16:53:17.406 - info: host.iobroker iobroker upload [0] pjlinkv2.admin /opt/iobroker/node_modules/iobroker.pjlinkv2/admin/custom_m.html custom_m.html text/html
                                    2021-12-17 16:53:17.556 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2 created/updated
                                    2021-12-17 16:53:17.613 - info: host.iobroker iobroker host.iobroker create instance pjlinkv2
                                    2021-12-17 16:53:17.628 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.logLevel created
                                    2021-12-17 16:53:17.664 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.sigKill created
                                    2021-12-17 16:53:17.695 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.eventLoopLag created
                                    2021-12-17 16:53:17.727 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.outputCount created
                                    2021-12-17 16:53:17.762 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.inputCount created
                                    2021-12-17 16:53:17.795 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.uptime created
                                    2021-12-17 16:53:17.827 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.memRss created
                                    2021-12-17 16:53:17.863 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.memHeapTotal created
                                    2021-12-17 16:53:17.896 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.memHeapUsed created
                                    2021-12-17 16:53:17.932 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.cputime created
                                    2021-12-17 16:53:17.968 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.cpu created
                                    2021-12-17 16:53:17.999 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.compactMode created
                                    2021-12-17 16:53:18.030 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.connected created
                                    2021-12-17 16:53:18.061 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0.alive created
                                    2021-12-17 16:53:18.100 - info: host.iobroker iobroker host.iobroker object system.adapter.pjlinkv2.0 created
                                    2021-12-17 16:53:19.160 - info: host.iobroker iobroker exit 0
                                    2021-12-17 16:53:21.207 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 30938
                                    2021-12-17 16:53:22.827 - info: pjlinkv2.0 (30938) starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                                    2021-12-17 16:53:22.857 - info: pjlinkv2.0 (30938) Starting PJLink V2 Adapter...
                                    2021-12-17 16:53:47.043 - info: smartmeter.0 (535) Received 7 values, 3 updated
                                    2021-12-17 16:53:55.091 - info: host.iobroker stopInstance system.adapter.pjlinkv2.0 (force=false, process=true)
                                    2021-12-17 16:53:55.104 - info: pjlinkv2.0 (30938) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-17 16:53:55.106 - info: pjlinkv2.0 (30938) terminating
                                    2021-12-17 16:53:55.108 - info: pjlinkv2.0 (30938) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-17 16:53:55.165 - info: host.iobroker stopInstance system.adapter.pjlinkv2.0 send kill signal
                                    2021-12-17 16:53:55.731 - info: host.iobroker instance system.adapter.pjlinkv2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-12-17 16:53:58.247 - info: host.iobroker instance system.adapter.pjlinkv2.0 started with pid 30979
                                    2021-12-17 16:53:59.687 - info: pjlinkv2.0 (30979) starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.pjlinkv2, node: v12.22.6, js-controller: 3.3.21
                                    2021-12-17 16:53:59.713 - info: pjlinkv2.0 (30979) Starting PJLink V2 Adapter...
                                    2021-12-17 16:53:59.714 - info: pjlinkv2.0 (30979) Trying to connect to:10.0.0.44 on port:4352
                                    2021-12-17 16:54:00.068 - warn: pjlinkv2.0 (30979) PJLink Class1 ist configured, but device supports Class1 3fe8c71e. Consider changing your config.
                                    2021-12-17 16:54:05.088 - error: pjlinkv2.0 (30979) Power On result: 1 1adb9895
                                    2021-12-17 16:54:10.092 - error: pjlinkv2.0 (30979) Power On result: 1 485082a3
                                    2021-12-17 16:54:15.087 - error: pjlinkv2.0 (30979) Power On result: 1 21e75a12
                                    2021-12-17 16:54:20.083 - error: pjlinkv2.0 (30979) Power On result: 1 406cfee1
                                    2021-12-17 16:54:25.092 - error: pjlinkv2.0 (30979) Power On result: 1 49059f4c
                                    2021-12-17 16:54:30.081 - error: pjlinkv2.0 (30979) Power On result: 1 0affa59f
                                    2021-12-17 16:54:35.119 - error: pjlinkv2.0 (30979) Power On result: 1 14afd515
                                    2021-12-17 16:54:40.085 - error: pjlinkv2.0 (30979) Power On result: 1 18c761a2
                                    2021-12-17 16:54:45.096 - error: pjlinkv2.0 (30979) Power On result: 1 0ee78dec
                                    2021-12-17 16:54:50.080 - error: pjlinkv2.0 (30979) Power On result: 1 15f17e90
                                    2021-12-17 16:54:55.082 - error: pjlinkv2.0 (30979) Power On result: 1 44e81768
                                    2021-12-17 16:55:00.081 - error: pjlinkv2.0 (30979) Power On result: 1 10fbc2a3
                                    2021-12-17 16:55:05.089 - error: pjlinkv2.0 (30979) Power On result: 1 42bef50b
                                    2021-12-17 16:55:10.080 - error: pjlinkv2.0 (30979) Power On result: 1 414c9395
                                    2021-12-17 16:55:15.079 - error: pjlinkv2.0 (30979) Power On result: 1 06e4a1fe
                                    2021-12-17 16:55:20.083 - error: pjlinkv2.0 (30979) Power On result: 1 5b036457
                                    2021-12-17 16:55:25.082 - error: pjlinkv2.0 (30979) Power On result: 1 1f41e123
                                    2021-12-17 16:55:30.081 - error: pjlinkv2.0 (30979) Power On result: 1 7937fe6e
                                    2021-12-17 16:55:35.082 - error: pjlinkv2.0 (30979) Power On result: 1 291cf876
                                    2021-12-17 16:55:40.084 - error: pjlinkv2.0 (30979) Power On result: 1 5a31336f
                                    2021-12-17 16:55:45.080 - error: pjlinkv2.0 (30979) Power On result: 1 7ce70b5b
                                    2021-12-17 16:55:50.089 - error: pjlinkv2.0 (30979) Power On result: 1 220f9373
                                    2021-12-17 16:55:55.211 - error: pjlinkv2.0 (30979) Power On result: 1 02f61413
                                    2021-12-17 16:56:00.090 - error: pjlinkv2.0 (30979) Power On result: 1 541bc19a
                                    2021-12-17 16:56:05.086 - error: pjlinkv2.0 (30979) Power On result: 1 5cb953e6
                                    2021-12-17 16:56:10.085 - error: pjlinkv2.0 (30979) Power On result: 1 71b9c388
                                    2021-12-17 16:56:15.082 - error: pjlinkv2.0 (30979) Power On result: 1 38450652
                                    2021-12-17 16:56:20.082 - error: pjlinkv2.0 (30979) Power On result: 1 284b336b
                                    2021-12-17 16:56:25.093 - error: pjlinkv2.0 (30979) Power On result: 1 21ba8aba
                                    2021-12-17 16:56:30.099 - error: pjlinkv2.0 (30979) Power On result: 1 5f4e17ca
                                    2021-12-17 16:56:35.092 - error: pjlinkv2.0 (30979) Power On result: 1 4a210af9
                                    2021-12-17 16:56:40.083 - error: pjlinkv2.0 (30979) Power On result: 1 2cec9ae6
                                    2021-12-17 16:56:45.083 - error: pjlinkv2.0 (30979) Power On result: 1 419359b4
                                    2021-12-17 16:56:50.082 - error: pjlinkv2.0 (30979) Power On result: 1 3fd05a53
                                    2021-12-17 16:56:55.084 - error: pjlinkv2.0 (30979) Power On result: 1 512e6b45
                                    2021-12-17 16:57:00.083 - error: pjlinkv2.0 (30979) Power On result: 1 2e145161
                                    2021-12-17 16:57:05.082 - error: pjlinkv2.0 (30979) Power On result: 1 034e5d46
                                    2021-12-17 16:57:10.084 - error: pjlinkv2.0 (30979) Power On result: 1 2bb7ef75
                                    2021-12-17 16:57:15.083 - error: pjlinkv2.0 (30979) Power On result: 1 15fc08ec
                                    2021-12-17 16:57:20.083 - error: pjlinkv2.0 (30979) Power On result: 1 4f94e95a
                                    2021-12-17 16:57:25.082 - error: pjlinkv2.0 (30979) Power On result: 1 430389ec
                                    2021-12-17 16:57:30.083 - error: pjlinkv2.0 (30979) Power On result: 1 18fd3f06
                                    2021-12-17 16:57:35.085 - error: pjlinkv2.0 (30979) Power On result: 1 178f7847
                                    2021-12-17 16:57:40.084 - error: pjlinkv2.0 (30979) Power On result: 1 63c66be2
                                    2021-12-17 16:57:45.097 - error: pjlinkv2.0 (30979) Power On result: 1 59e454a0
                                    2021-12-17 16:57:50.083 - error: pjlinkv2.0 (30979) Power On result: 1 001778b3
                                    2021-12-17 16:57:53.001 - error: pjlinkv2.0 (30979) Power Off result: 1 53f79829
                                    2021-12-17 16:57:55.084 - error: pjlinkv2.0 (30979) Power On result: 1 584cf17e
                                    2021-12-17 16:58:00.085 - error: pjlinkv2.0 (30979) Power On result: 1 1a49c5c1
                                    2021-12-17 16:58:05.088 - error: pjlinkv2.0 (30979) Power On result: 1 06bef8f8
                                    2021-12-17 16:58:10.095 - error: pjlinkv2.0 (30979) Power On result: 1 2b343e41
                                    2021-12-17 16:58:15.101 - error: pjlinkv2.0 (30979) Power On result: 1 1c5a6686
                                    2021-12-17 16:58:20.091 - error: pjlinkv2.0 (30979) Power On result: 1 1a3fcf67
                                    2021-12-17 16:58:25.086 - error: pjlinkv2.0 (30979) Power On result: 1 7b34484e
                                    2021-12-17 16:58:30.087 - error: pjlinkv2.0 (30979) Power On result: 1 45ee9482
                                    2021-12-17 16:58:35.090 - error: pjlinkv2.0 (30979) Power On result: 1 3f00e794
                                    2021-12-17 16:58:40.088 - error: pjlinkv2.0 (30979) Power On result: 1 3b4667c8
                                    2021-12-17 16:58:45.085 - error: pjlinkv2.0 (30979) Power On result: 1 7b7c4263
                                    2021-12-17 16:58:48.421 - info: smartmeter.0 (535) Received 7 values, 3 updated
                                    2021-12-17 16:58:50.087 - error: pjlinkv2.0 (30979) Power On result: 1 32ef6edc
                                    2021-12-17 16:58:55.091 - error: pjlinkv2.0 (30979) Power On result: 1 480f7f38
                                    2021-12-17 16:59:00.090 - error: pjlinkv2.0 (30979) Power On result: 1 175ff6e4
                                    2021-12-17 16:59:05.088 - error: pjlinkv2.0 (30979) Power On result: 1 3b6b124e
                                    2021-12-17 16:59:10.087 - error: pjlinkv2.0 (30979) Power On result: 1 36adb706
                                    2021-12-17 16:59:15.088 - error: pjlinkv2.0 (30979) Power On result: 1 08c1806e
                                    2021-12-17 16:59:20.086 - error: pjlinkv2.0 (30979) Power On result: 1 03f826c8
                                    2021-12-17 16:59:25.085 - error: pjlinkv2.0 (30979) Power On result: 1 1111eba2
                                    2021-12-17 16:59:30.089 - error: pjlinkv2.0 (30979) Power On result: 1 489d2d6b
                                    2021-12-17 16:59:35.087 - error: pjlinkv2.0 (30979) Power On result: 1 6d2048f3
                                    2021-12-17 16:59:40.092 - error: pjlinkv2.0 (30979) Power On result: 1 0c593331
                                    2021-12-17 16:59:45.088 - error: pjlinkv2.0 (30979) Power On result: 1 4d6cf880
                                    2021-12-17 16:59:50.088 - error: pjlinkv2.0 (30979) Power On result: 1 418c1d6a
                                    2021-12-17 16:59:55.092 - error: pjlinkv2.0 (30979) Power On result: 1 693c5539
                                    2021-12-17 17:00:00.092 - error: pjlinkv2.0 (30979) Power On result: 1 459d719f
                                    2021-12-17 17:00:05.093 - error: pjlinkv2.0 (30979) Power On result: 1 48fdbb60
                                    2021-12-17 17:00:10.091 - error: pjlinkv2.0 (30979) Power On result: 1 5c5b3a20
                                    2021-12-17 17:00:15.086 - error: pjlinkv2.0 (30979) Power On result: 1 7c37cb1a
                                    2021-12-17 17:00:20.087 - error: pjlinkv2.0 (30979) Power On result: 1 0cf1bacc
                                    2021-12-17 17:00:25.091 - error: pjlinkv2.0 (30979) Power On result: 1 57d4c6da
                                    2021-12-17 17:00:30.117 - error: pjlinkv2.0 (30979) Power On result: 1 74164f86
                                    2021-12-17 17:00:35.092 - error: pjlinkv2.0 (30979) Power On result: 1 1de48b33
                                    2021-12-17 17:00:40.088 - error: pjlinkv2.0 (30979) Power On result: 1 05525c68
                                    2021-12-17 17:00:45.090 - error: pjlinkv2.0 (30979) Power On result: 1 43efd4c2
                                    2021-12-17 17:00:50.095 - error: pjlinkv2.0 (30979) Power On result: 1 4bea428d
                                    2021-12-17 17:00:55.093 - error: pjlinkv2.0 (30979) Power On result: 1 577d85bd
                                    2021-12-17 17:01:00.091 - error: pjlinkv2.0 (30979) Power On result: 1 0635abab
                                    2021-12-17 17:01:05.094 - error: pjlinkv2.0 (30979) Power On result: 1 0741823d
                                    2021-12-17 17:01:10.095 - error: pjlinkv2.0 (30979) Power On result: 1 3dc49285
                                    2021-12-17 17:01:15.093 - error: pjlinkv2.0 (30979) Power On result: 1 5f877e7a
                                    2021-12-17 17:01:20.094 - error: pjlinkv2.0 (30979) Power On result: 1 5c2fdcaf
                                    2021-12-17 17:01:25.095 - error: pjlinkv2.0 (30979) Power On result: 1 27da6380
                                    2021-12-17 17:01:30.097 - error: pjlinkv2.0 (30979) Power On result: 1 46b565a5
                                    2021-12-17 17:01:35.102 - error: pjlinkv2.0 (30979) Power On result: 1 722610e1
                                    2021-12-17 17:01:40.097 - error: pjlinkv2.0 (30979) Power On result: 1 2bb16e80
                                    2021-12-17 17:01:45.101 - error: pjlinkv2.0 (30979) Power On result: 1 52e5543b
                                    2021-12-17 17:01:50.101 - error: pjlinkv2.0 (30979) Power On result: 1 58b2ad5d
                                    2021-12-17 17:01:55.102 - error: pjlinkv2.0 (30979) Power On result: 1 5c9982ef
                                    2021-12-17 17:02:00.100 - error: pjlinkv2.0 (30979) Power On result: 1 4b63016a
                                    2021-12-17 17:02:05.101 - error: pjlinkv2.0 (30979) Power On result: 1 0ff00b96
                                    2021-12-17 17:02:10.128 - error: pjlinkv2.0 (30979) Power On result: 1 66be233b
                                    2021-12-17 17:02:15.108 - error: pjlinkv2.0 (30979) Power On result: 1 00ec2313
                                    2021-12-17 17:02:20.104 - error: pjlinkv2.0 (30979) Power On result: 1 0024151d
                                    2021-12-17 17:02:25.107 - error: pjlinkv2.0 (30979) Power On result: 1 5de67b89
                                    2021-12-17 17:02:30.104 - error: pjlinkv2.0 (30979) Power On result: 1 048e1f27
                                    2021-12-17 17:02:35.104 - error: pjlinkv2.0 (30979) Power On result: 1 726e8d7e
                                    2021-12-17 17:02:40.111 - error: pjlinkv2.0 (30979) Power On result: 1 58b3aaff
                                    2021-12-17 17:02:45.106 - error: pjlinkv2.0 (30979) Power On result: 1 3b36c02b
                                    2021-12-17 17:02:50.210 - error: pjlinkv2.0 (30979) Power On result: 1 0e24c0ff
                                    2021-12-17 17:02:55.107 - error: pjlinkv2.0 (30979) Power On result: 1 18be98db
                                    2021-12-17 17:03:00.107 - error: pjlinkv2.0 (30979) Power On result: 1 1d4dc75c
                                    2021-12-17 17:03:05.107 - error: pjlinkv2.0 (30979) Power On result: 1 58ab726d
                                    2021-12-17 17:03:10.108 - error: pjlinkv2.0 (30979) Power On result: 1 22b6dde8
                                    2021-12-17 17:03:15.117 - error: pjlinkv2.0 (30979) Power On result: 1 5dc0d287
                                    2021-12-17 17:03:20.112 - error: pjlinkv2.0 (30979) Power On result: 1 4b3e336b
                                    2021-12-17 17:03:25.108 - error: pjlinkv2.0 (30979) Power On result: 1 2d7f8b7c
                                    2021-12-17 17:03:30.108 - error: pjlinkv2.0 (30979) Power On result: 1 64574b09
                                    2021-12-17 17:03:35.110 - error: pjlinkv2.0 (30979) Power On result: 1 490036ab
                                    2021-12-17 17:03:40.113 - error: pjlinkv2.0 (30979) Power On result: 1 656c9575
                                    2021-12-17 17:03:45.115 - error: pjlinkv2.0 (30979) Power On result: 1 2b10095f
                                    2021-12-17 17:03:49.597 - info: smartmeter.0 (535) Received 7 values, 3 updated
                                    2021-12-17 17:03:50.132 - error: pjlinkv2.0 (30979) Power On result: 1 5093c2e0
                                    2021-12-17 17:03:55.121 - error: pjlinkv2.0 (30979) Power On result: 1 69db2def
                                    2021-12-17 17:04:00.115 - error: pjlinkv2.0 (30979) Power On result: 1 17d3cb03
                                    2021-12-17 17:04:05.113 - error: pjlinkv2.0 (30979) Power On result: 1 35e2d6c2
                                    2021-12-17 17:04:10.122 - error: pjlinkv2.0 (30979) Power On result: 1 0178685c
                                    2021-12-17 17:04:15.118 - error: pjlinkv2.0 (30979) Power On result: 1 57070573
                                    2021-12-17 17:04:20.123 - error: pjlinkv2.0 (30979) Power On result: 1 6ac3e01f
                                    2021-12-17 17:04:25.117 - error: pjlinkv2.0 (30979) Power On result: 1 6401e306
                                    2021-12-17 17:04:30.115 - error: pjlinkv2.0 (30979) Power On result: 1 20faa963
                                    2021-12-17 17:04:35.122 - error: pjlinkv2.0 (30979) Power On result: 1 6503df9d
                                    2021-12-17 17:04:40.122 - error: pjlinkv2.0 (30979) Power On result: 1 3f046adc
                                    2021-12-17 17:04:45.120 - error: pjlinkv2.0 (30979) Power On result: 1 3d341a18
                                    2021-12-17 17:04:50.124 - error: pjlinkv2.0 (30979) Power On result: 1 1589e997
                                    2021-12-17 17:04:55.119 - error: pjlinkv2.0 (30979) Power On result: 1 46d9cc8b
                                    2021-12-17 17:05:00.120 - error: pjlinkv2.0 (30979) Power On result: 1 21962c94
                                    2021-12-17 17:05:05.121 - error: pjlinkv2.0 (30979) Power On result: 1 77868bff
                                    2021-12-17 17:05:10.197 - error: pjlinkv2.0 (30979) Power On result: 1 74b01c4a
                                    2021-12-17 17:05:15.127 - error: pjlinkv2.0 (30979) Power On result: 1 0e1121d4
                                    2021-12-17 17:05:20.123 - error: pjlinkv2.0 (30979) Power On result: 1 618d7aba
                                    2021-12-17 17:05:25.127 - error: pjlinkv2.0 (30979) Power On result: 1 70428690
                                    2021-12-17 17:05:30.126 - error: pjlinkv2.0 (30979) Power On result: 1 4786fdde
                                    2021-12-17 17:05:35.128 - error: pjlinkv2.0 (30979) Power On result: 1 11c3996d
                                    2021-12-17 17:05:40.130 - error: pjlinkv2.0 (30979) Power On result: 1 56491749
                                    2021-12-17 17:05:45.126 - error: pjlinkv2.0 (30979) Power On result: 1 656167bf
                                    2021-12-17 17:05:50.126 - error: pjlinkv2.0 (30979) Power On result: 1 2ab11bba
                                    2021-12-17 17:05:55.132 - error: pjlinkv2.0 (30979) Power On result: 1 1182f71b
                                    2021-12-17 17:06:00.126 - error: pjlinkv2.0 (30979) Power On result: 1 0b78c5c3
                                    2021-12-17 17:06:05.135 - error: pjlinkv2.0 (30979) Power On result: 1 6a2b4505
                                    2021-12-17 17:06:10.134 - error: pjlinkv2.0 (30979) Power On result: 1 723e594a
                                    2021-12-17 17:06:15.130 - error: pjlinkv2.0 (30979) Power On result: 1 5d4d367d
                                    2021-12-17 17:06:20.133 - error: pjlinkv2.0 (30979) Power On result: 1 2da08a8d
                                    2021-12-17 17:06:25.135 - error: pjlinkv2.0 (30979) Power On result: 1 441fb97f
                                    2021-12-17 17:06:30.133 - error: pjlinkv2.0 (30979) Power On result: 1 35d3b2ff
                                    2021-12-17 17:06:35.138 - error: pjlinkv2.0 (30979) Power On result: 1 5857459e
                                    2021-12-17 17:06:40.135 - error: pjlinkv2.0 (30979) Power On result: 1 47006c24
                                    Falls Du noch eine Idee hast, was ich probieren kann, gerne.
                                    • M mpenno
                                      oberstelO Offline
                                      oberstelO Offline
                                      oberstel
                                      @mpenno
                                      da stimmt was nicht… im Log sehe ich, dass die Antworten vom Projektor verschlüsselt zurückkommen. Das erkennst Du dan den 8 Bytes nach einem „Result“. So wie das hier:
                                      Eigentlich dürfte da nur „On result: 1“ stehen. Die 8 Byte dahinter (1adb9895) dürften da gar nicht stehen :-(
                                      Demnach sind alle Werte die dir angezeigt werden vermutlich einfach falsch.
                                      Kann es sein, dass bei dem Projektor für die Kommunikation via PJLink ein Passwort hinterlegt ist? Bitte schaue doch mal in den Einstellungen des Gerätes…
                                        @mpenno
                                        mpenno
                                        @oberstel Ja genau. Ich musste ein Passwort beim Beamer einstellen. Das gleiche Passwort habe ich im Adapter auch hinterlegt.
                                        • M mpenno
                                          oberstelO Offline
                                          oberstelO Offline
                                          oberstel
                                          Heißt das, der Projektor "will zwingend" ein Passwort?
                                          Sind in dem Passwort eventuell Sonderzeichen vorhanden? Kannst Du probieren ein einfaches kurzes Passwort zu nehmen (ohne goß / klein, ohne Sonderzeichen, max. 6 Stellen...)
                                          Oder kannst Du probieren das Passwort rauszunehmen?
