WICHTIGE Info für Nutzer des RWE-SmartHome Adapters (Innogy-SmartHome)!
Hallo PArt,
neue Version installiert. Die Vermutung des Zwangsdisconect liegt sehr nah. Da der disconect des Adapters bei mir immer um die Zeit kam. Hätte ich ja auch mal posten können :roll:
Nach dem Update kam:
! innogy-smarthome.0 2017-03-06 04:58:01.465 info OPEN
! innogy-smarthome.0 2017-03-06 04:57:57.316 info starting. Version 0.1.14 in C:/ioBroker/node_modules/iobroker.innogy-smarthome
! innogy-smarthome.0 2017-03-06 04:57:56.972 error no connection to objects DB
! host.POETNITZ15 2017-03-06 04:57:43.962 info instance system.adapter.innogy-smarthome.0 started with pid 6108
! host.POETNITZ15 2017-03-06 04:57:13.917 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
! host.POETNITZ15 2017-03-06 04:57:13.917 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
! innogy-smarthome.0 2017-03-06 04:57:13.869 info cleaned everything up…
! Error: 2017-03-06 04:57:13.869 error at Promise._settlePromises (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:700:14)
! Error: 2017-03-06 04:57:13.869 error at Promise._settlePromiseAt (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:582:21)
! Error: 2017-03-06 04:57:13.869 error at Promise.successAdapter (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\nodeify.js:23:30)
! Error: 2017-03-06 04:57:13.869 error at tryCatcher (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\util.js:26:23)
! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:43:17
! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\main.js:35:31
! Error: 2017-03-06 04:57:13.869 error at SmartHome.init (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:84:17)
! Error: 2017-03-06 04:57:13.869 error at SmartHome._initialize (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:293:12)
! Error: 2017-03-06 04:57:13.869 error at new Promise (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:77:14)
! Error: 2017-03-06 04:57:13.869 error at Promise._resolveFromExecutor (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:481:18)
! Error: 2017-03-06 04:57:13.869 error at Promise.cancellationExecute [as _execute] (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\debuggability.js:321:9)
! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:294:25
! Error: 2017-03-06 04:57:13.869 error at Requestor.call (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:42:17)
! Error: 2017-03-06 04:57:13.869 error at Requestor.doRequest (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:48:12)
! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:49:22
! Error: 2017-03-06 04:57:13.869 error at Object.getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:171:20)
! Error: 2017-03-06 04:57:13.869 error at getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:161:13)
! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:51:41
! Error: 2017-03-06 04:57:13.869 error at Object.startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:174:20)
! Error: 2017-03-06 04:57:13.869 error at startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:55:26)
! Error: 2017-03-06 04:57:13.869 error at Server.listen (net.js:1391:5)
! Error: 2017-03-06 04:57:13.869 error at listen (net.js:1295:10)
! Error: 2017-03-06 04:57:13.869 error at Server._listen2 (net.js:1259:14)
! Error: 2017-03-06 04:57:13.869 error at exports._exceptionWithHostPort (util.js:1045:20)
! Error: 2017-03-06 04:57:13.869 error at Object.exports._errnoException (util.js:1022:11)
! Error: 2017-03-06 04:57:13.869 error listen EADDRINUSE :::3000
! uncaught 2017-03-06 04:57:13.869 error exception: listen EADDRINUSE :::3000
! innogy-smarthome.0 2017-03-06 04:57:13.822 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
! innogy-smarthome.0 2017-03-06 04:53:44.096 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
! host.POETNITZ15 2017-03-06 04:53:23.629 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
! iobroker 2017-03-06 04:53:22.662 info exit 0
! iobroker 2017-03-06 04:53:22.475 info upload [0] innogy-smarthome.admin C:/ioBroker/node_modules/iobroker.innogy-smarthome/admin/index.html index.html text/html
! iobroker 2017-03-06 04:53:22.335 info upload [1] innogy-smarthome.admin C:/ioBroker/node_modules/iobroker.innogy-smarthome/admin/innogy-smarthome.png innogy-smarthome.png image/png
! iobroker 2017-03-06 04:53:22.288 info got C:/ioBroker/node_modules/iobroker.innogy-smarthome/admin
! iobroker 2017-03-06 04:52:09.934 info npm install https://github.com/PArns/ioBroker.innog … all/master --production --prefix "C:/ioBroker" (System call)
! iobroker 2017-03-06 04:52:09.357 info install https://github.com/PArns/ioBroker.innog ... all/master
! iobroker 2017-03-06 04:52:06.845 info url "https://github.com/PArns/ioBroker.innog ... all/master" innogy-smarthomeAber Adapter ist jetzt grün und alles gut! Mal sehen wie es morgen ausschaut!
Grüße,
Torsten
als Neuling versuche ich auch meine RWE Geräte über ioBroker einzubinden.
Dieser läuft auf einem Raspberry.
Mein Problem ich bekomme im Cloud Adapter zwar die Räume angezeigt aber nicht die Funktionen dazu.
Unter smart Geräte befindet sich auch kein Eintrag.
Was mache ich falsch ?
Vielen dank vorab für eure Unterstützung.
Kunime
2310_icloud.png -
Hallo PArt,
Also Server Neustart habe ich durchgeführt, mal sehen wie er sich morgen früh verhält.
Schau unter "Objekte" dort wirst du die Objekte zum Adapter finden. Was willst du denn machen? Die Logik mußt du unter "Scripte" programmieren. Oder unter "Zustände" im Filter "ID" z.B. "inno" eingeben dann siehst du die Zustände deiner Geräte.
Falsch machst du nichts, nur kann man mit deinem Post wenig anfangen wenn man nicht weiß was du eigentlich vor hast.
Grüße,
Torsten
Hallo PArt,
es hängt mit dem Zwangsdisconnect zusammen. Ich habe diesen händisch durchgeführt und hier ist das Ergebnis–>
! host.POETNITZ15 2017-03-06 18:49:35.915 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
! host.POETNITZ15 2017-03-06 18:49:35.915 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
! innogy-smarthome.0 2017-03-06 18:49:35.837 info cleaned everything up…
! Error: 2017-03-06 18:49:35.837 error at Promise._settlePromises (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:700:14)
! Error: 2017-03-06 18:49:35.837 error at Promise._settlePromiseAt (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:582:21)
! Error: 2017-03-06 18:49:35.837 error at Promise.successAdapter (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\nodeify.js:23:30)
! Error: 2017-03-06 18:49:35.837 error at tryCatcher (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\util.js:26:23)
! Error: 2017-03-06 18:49:35.837 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:43:17
! Error: 2017-03-06 18:49:35.837 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\main.js:35:31
! Error: 2017-03-06 18:49:35.837 error at SmartHome.init (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:84:17)
! Error: 2017-03-06 18:49:35.837 error at SmartHome._initialize (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:304:12)
! Error: 2017-03-06 18:49:35.837 error at new Promise (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:79:10)
! Error: 2017-03-06 18:49:35.837 error at Promise._resolveFromExecutor (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:483:18)
! Error: 2017-03-06 18:49:35.837 error at Promise.cancellationExecute [as _execute] (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\debuggability.js:321:9)
! Error: 2017-03-06 18:49:35.837 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:305:25
! Error: 2017-03-06 18:49:35.837 error at Requestor.call (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:42:17)
! Error: 2017-03-06 18:49:35.837 error at Requestor.doRequest (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:48:12)
! Error: 2017-03-06 18:49:35.837 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:49:22
! Error: 2017-03-06 18:49:35.837 error at Object.getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:171:20)
! Error: 2017-03-06 18:49:35.837 error at getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:161:13)
! Error: 2017-03-06 18:49:35.837 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:51:41
! Error: 2017-03-06 18:49:35.837 error at Object.startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:174:20)
! Error: 2017-03-06 18:49:35.837 error at startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:55:26)
! Error: 2017-03-06 18:49:35.837 error at Server.listen (net.js:1391:5)
! Error: 2017-03-06 18:49:35.837 error at listen (net.js:1295:10)
! Error: 2017-03-06 18:49:35.837 error at Server._listen2 (net.js:1259:14)
! Error: 2017-03-06 18:49:35.837 error at exports._exceptionWithHostPort (util.js:1045:20)
! Error: 2017-03-06 18:49:35.837 error at Object.exports._errnoException (util.js:1022:11)
! Error: 2017-03-06 18:49:35.837 error listen EADDRINUSE :::3000
! uncaught 2017-03-06 18:49:35.837 error exception: listen EADDRINUSE :::3000
! innogy-smarthome.0 2017-03-06 18:49:35.822 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
! innogy-smarthome.0 2017-03-06 18:49:35.790 info CLOSE:{"code":1006}
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at processImmediate [as _immediateCallback] (timers.js:594:5)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at tryOnImmediate (timers.js:622:5)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at Immediate.Async.drainQueues (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\async.js:15:14)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at Async._drainQueues (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\async.js:133:10)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at Async._drainQueue (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\async.js:123:16)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at Promise._settlePromises (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:700:14)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at Promise._settlePromiseAt (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:582:21)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at Promise.successAdapter (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\nodeify.js:23:30)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at tryCatcher (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\util.js:26:23)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:43:17
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\main.js:35:31
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at SmartHome.init (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:82:10)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at SmartHome._finalize (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:164:24)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at WebSocketClient.close (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\websocketclient\index.js:70:19)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error at WebSocket.close (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\ws\lib\WebSocket.js:272:28)
! innogy-smarthome.0 2017-03-06 18:49:35.790 error STACK:Error: closed before the connection is established
! innogy-smarthome.0 2017-03-06 18:49:35.790 error GOT AN ERROR:{}
! innogy-smarthome.0 2017-03-06 18:49:33.170 warn Adapter is still not connected to the Innogy API, restarting!
! innogy-smarthome.0 2017-03-06 18:49:03.155 warn Adapter is not connected … Will recheck in 30 seconds!
! telegram.0 2017-03-06 18:48:49.677 info getMe (reconnect): {"id":243605586,"first_name":"IO_Broker_Poetnitz","username":"IO_Broker_Poetnitz_bot"}
! innogy-smarthome.0 2017-03-06 18:46:32.927 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
! innogy-smarthome.0 2017-03-06 18:44:37.534 info CLOSE:{"code":1006}
! innogy-smarthome.0 2017-03-06 18:44:07.488 info DEBUG EVENT {"type":"error_handler","data":{"name":"StatusCodeError","statusCode":403,"message":"403 - {"errorcode":2010,"description":"Remote access not allowed"}","error":{"errorcode":2010,"d
! innogy-smarthome.0 2017-03-06 18:44:07.347 info DEBUG EVENT {"type":"check_timer"}Wenn die Autorisierung steht kann ich den Adapter restarten und es wird grün und auch bei STOP-START wird er wieder grün. Nur bei Anforderung neuer IP oder Zwangsdisconnect haut es die Autorisierung weg.
Grüße,
Torsten
Hallo, ich möchte meine Innogy Geräte wie in der Anleitung beschrieben http://www.iobroker.net/?page_id=5859&lang=de einbinden.
Ab dem Punkt
"Einbindung von Geräten (aus der CCU oder auch sonstiger Adapter)
Automatische Übernahme aus der CCU"
komme ich nicht weiter.
Kunime
So, neue Version auf GitHub, ich habe den WebSocket sowie das reconnect handling komplett angepasst! Da war wirklich so einiges im argen. Leider bekommt der WebSocket nicht sauber mit, wenn die Internetverbindung abschmiert :(
Das sollte nun behoben sein, zumindest sollte der Adapter nun erkennen, wenn über den WebSocket keine Events mehr kommen (ACHTUNG! Die Erkennung erfolgt aus Performancegründen nur alle 5 Minuten, also beim testen bitte nicht wundern!)
Was Alexa angeht, bitte beschreibe uns ein wenig besser, wo genau du nicht weiter kommst! Du musst die Funktion (z.B. Licht) selbst den Schaltern/Steckdosen in der Objektansicht hinzufügen. Die Räume (sofern korrekt in der WebUI von Innogy zugeordnet) sollten selbst erkannt werden.
Hallo PArt,
Habe ihn wieder händisch ausgelöst (IP Aktualisierung).
! innogy-smarthome.0 2017-03-06 21:51:57.141 warn Adapter is not connected … Will recheck in 30 seconds!
! innogy-smarthome.0 2017-03-06 21:47:27.120 warn Adapter is still not connected to the Innogy API, restarting!
! innogy-smarthome.0 2017-03-06 21:46:57.106 warn Adapter is not connected ... Will recheck in 30 seconds!
! innogy-smarthome.0 2017-03-06 21:42:31.079 info CLOSE:{"code":1006}
! innogy-smarthome.0 2017-03-06 21:42:31.047 info CLOSE:{}
! innogy-smarthome.0 2017-03-06 21:42:01.033 info DEBUG EVENT {"type":"error_handler","data":{"name":"StatusCodeError","statusCode":403,"message":"403 - {"errorcode":2010,"description":"Remote access not allowed"}","error":{"errorcode":2010,"dLeider ein vergeblicher reconnect. Habe meine Login Daten eingegeben und den Adapter neu geladen dann ging der connect.
Hier noch mal ein Durchlauf im DEBUG Modus
! inMem 2017-03-06 22:55:22.268 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wandleuchte.LastPressedButtonIndex val=0, ack=true, ts=1488837322175, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223214
! inMem 2017-03-06 22:55:22.268 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wandleuchte.LaskKeyPressCounter val=null, ack=true, ts=1488837322175, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223214
! inMem 2017-03-06 22:55:22.268 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wandleuchte.DimLevel val=100, ack=true, ts=1488837322175, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223214
! inMem 2017-03-06 22:55:22.253 debug message innogy-smarthome.0.* innogy-smarthome.0.Virtual.Urlaub.Value val=false, ack=true, ts=1488837322175, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223198
! inMem 2017-03-06 22:55:22.253 debug message innogy-smarthome.0.* innogy-smarthome.0.Virtual.Zuhause.Value val=true, ack=true, ts=1488837322175, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223198
! inMem 2017-03-06 22:55:22.253 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Raumklima.PointTemperature val=21, ack=true, ts=1488837322175, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223198
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Raumklima.Humidity val=41, ack=true, ts=1488837322159, q=0, from=system.adapter.innogy-smarthome.0, lc=1488835275264
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Raumklima.Temperature val=22, ack=true, ts=1488837322065, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836456326
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Raumklima.PointTemperature val=10, ack=true, ts=1488837322065, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223182
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Raumklima.Humidity val=46, ack=true, ts=1488837322065, q=0, from=system.adapter.innogy-smarthome.0, lc=1488835288087
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Raumklima.Temperature val=21, ack=true, ts=1488837322065, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322065
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Raumklima.PointTemperature val=16, ack=true, ts=1488837322065, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223182
! inMem 2017-03-06 22:55:22.237 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Raumklima.Humidity val=46, ack=true, ts=1488837322065, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836126511
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Raumklima.Temperature val=20.9, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322050
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Raumklima.PointTemperature val=16, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223167
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Raumklima.Humidity val=44, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223167
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Raumklima.Temperature val=21.1, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322050
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.OperationMode val=Auto, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223167
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.WindowReductionActive val=false, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=14888342231
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.PointTemperature val=21, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223151
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.FrostWarning val=false, ack=true, ts=1488837322050, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223026
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.Temperature val=22, ack=true, ts=1488837322034, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836456326
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.MoldWarning val=false, ack=true, ts=1488837322034, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223026
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Nikola.Heizkörpertemperatur-4.Humidity val=41, ack=true, ts=1488837322034, q=0, from=system.adapter.innogy-smarthome.0, lc=1488835275139
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.MoldWarning val=false, ack=true, ts=1488837322034, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223011
! inMem 2017-03-06 22:55:22.221 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.Humidity val=46, ack=true, ts=1488837322034, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322034
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.FrostWarning val=false, ack=true, ts=1488837322019, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223011
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.Temperature val=21, ack=true, ts=1488837322019, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322019
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.OperationMode val=Auto, ack=true, ts=1488837322019, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834223011
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.WindowReductionActive val=false, ack=true, ts=1488837322019, q=0, from=system.adapter.innogy-smarthome.0, lc=14888342229
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Franka.Heizkörpertemperatur-3.PointTemperature val=10, ack=true, ts=1488837322019, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222995
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.MoldWarning val=false, ack=true, ts=1488837322019, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222995
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.Humidity val=46, ack=true, ts=1488837322003, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322003
! inMem 2017-03-06 22:55:22.206 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.FrostWarning val=false, ack=true, ts=1488837322003, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222995
! inMem 2017-03-06 22:55:22.190 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.Temperature val=20.9, ack=true, ts=1488837322003, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837322003
! inMem 2017-03-06 22:55:22.190 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.OperationMode val=Auto, ack=true, ts=1488837322003, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222980
! inMem 2017-03-06 22:55:22.190 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.WindowReductionActive val=false, ack=true, ts=1488837322003, q=0, from=system.adapter.innogy-smarthome.0, lc=148883422
! inMem 2017-03-06 22:55:22.159 debug message innogy-smarthome.0.* innogy-smarthome.0.Bad-Oben.Heizkörpertemperatur-2.PointTemperature val=16, ack=true, ts=1488837321987, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222980
! inMem 2017-03-06 22:55:22.159 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.OperationMode val=Auto, ack=true, ts=1488837321987, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222980
! inMem 2017-03-06 22:55:22.159 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.WindowReductionActive val=false, ack=true, ts=1488837321987, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834
! inMem 2017-03-06 22:55:22.159 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.PointTemperature val=16, ack=true, ts=1488837321987, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222964
! inMem 2017-03-06 22:55:22.143 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.FrostWarning val=false, ack=true, ts=1488837321987, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222964
! inMem 2017-03-06 22:55:22.143 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.Temperature val=21.1, ack=true, ts=1488837321972, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837321972
! inMem 2017-03-06 22:55:22.065 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.MoldWarning val=false, ack=true, ts=1488837321972, q=0, from=system.adapter.innogy-smarthome.0, lc=1488834222964
! inMem 2017-03-06 22:55:22.065 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Heizkörpertemperatur-1.Humidity val=44.5, ack=true, ts=1488837321816, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836495809
! inMem 2017-03-06 22:55:21.036 debug message innogy-smarthome.0.* innogy-smarthome.0.info.connection val=true, ack=true, ts=1488837321020, q=0, from=system.adapter.innogy-smarthome.0, lc=1488837321020
! innogy-smarthome.0 2017-03-06 22:55:21.020 info OPEN
! innogy-smarthome.0 2017-03-06 22:55:17.900 info starting. Version 0.1.15 in C:/ioBroker/node_modules/iobroker.innogy-smarthome
! innogy-smarthome.0 2017-03-06 22:55:17.791 debug statesDB connected
! innogy-smarthome.0 2017-03-06 22:55:17.775 debug objectDB connected
! innogy-smarthome.0 2017-03-06 22:55:17.541 error no connection to objects DB
! host.POETNITZ15 2017-03-06 22:55:09.835 info instance system.adapter.innogy-smarthome.0 started with pid 5880
! host.POETNITZ15 2017-03-06 22:55:07.323 info instance system.adapter.innogy-smarthome.0 terminated with code null ()
! host.POETNITZ15 2017-03-06 22:55:07.323 warn instance system.adapter.innogy-smarthome.0 terminated due to SIGTERM
! host.POETNITZ15 2017-03-06 22:55:07.277 info stopInstance system.adapter.innogy-smarthome.0 killing pid 8148
! host.POETNITZ15 2017-03-06 22:55:07.277 info object change system.adapter.innogy-smarthome.0
! inMem 2017-03-06 22:55:05.311 debug message .logging system.adapter.admin.0.logging val=false, ack=true, ts=1488837305295, q=0, from=system.adapter.admin.0, lc=1488837305295
! inMem 2017-03-06 22:55:02.799 debug message innogy-smarthome.0. innogy-smarthome.0.info.connection val=false, ack=true, ts=1488837302768, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836826031
! innogy-smarthome.0 2017-03-06 22:55:02.768 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
! innogy-smarthome.0 2017-03-06 22:54:46.560 debug sendTo "startAuth" to system.adapter.admin.0 from system.adapter.innogy-smarthome.0: {"uri":"https://iobroker-connect.patrick-arns.d … es-smartho
! inMem 2017-03-06 22:54:46.482 debug message messagebox.system.adapter.innogy-smarthome.0 messagebox.system.adapter.innogy-smarthome.0 command=startAuth, , from=system.adapter.admin.0, , id=97, ack=false, time=1488837286482, _id=169675
! inMem 2017-03-06 22:54:43.362 debug message .logging system.adapter.admin.0.logging val=true, ack=true, ts=1488837283346, q=0, from=system.adapter.admin.0, lc=1488837283346
! innogy-smarthome.0 2017-03-06 22:52:02.932 warn Adapter is still not connected to the Innogy API, restarting!
! innogy-smarthome.0 2017-03-06 22:51:32.917 warn Adapter is not connected ... Will recheck in 30 seconds!
! telegram.0 2017-03-06 22:48:50.318 info getMe (reconnect): {"id":243605586,"first_name":"IO_Broker_Poetnitz","username":"IO_Broker_Poetnitz_bot"}
! inMem 2017-03-06 22:47:06.109 debug message innogy-smarthome.0. innogy-smarthome.0.info.connection val=false, ack=true, ts=1488836826094, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836826031
! innogy-smarthome.0 2017-03-06 22:47:06.093 info CLOSE:{"code":1006}
! inMem 2017-03-06 22:47:06.093 debug message innogy-smarthome.0.* innogy-smarthome.0.info.connection val=false, ack=true, ts=1488836826031, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836826031
! innogy-smarthome.0 2017-03-06 22:47:06.031 info CLOSE:{}
! inMem 2017-03-06 22:46:36.048 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-06T21:46:36.017Z, ack=true, ts=1488836796032, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836796032
! innogy-smarthome.0 2017-03-06 22:46:36.017 info DEBUG EVENT {"type":"error_handler","data":{"name":"StatusCodeError","statusCode":403,"message":"403 - {"errorcode":2010,"description":"Remote access not allowed"}","error":{"errorcode":2010,"d
! inMem 2017-03-06 22:46:35.876 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-06T21:46:35.829Z, ack=true, ts=1488836795830, q=0, from=system.adapter.innogy-smarthome.0, lc=1488836795830
! innogy-smarthome.0 2017-03-06 22:46:35.829 info DEBUG EVENT {"type":"check_timer"}
! cloud.0 2017-03-06 22:45:50.901 info Connection changed: CONNECTEDGrüße,
Torsten
> Was Alexa angeht, bitte beschreibe uns ein wenig besser, wo genau du nicht weiter kommst! Du musst die Funktion (z.B. Licht) selbst den Schaltern/Steckdosen in der Objektansicht hinzufügen. Die Räume (sofern korrekt in der WebUI von Innogy zugeordnet) sollten selbst erkannt werden.Guten Morgen,
genau an der Stelle komm ich nicht weiter.
Wie fügt man die Funktion den Geräten zu ?
Danke für eure Mühe
Kunime
@Throsten, kannst du dich mal an den Innogy Support wenden?
Wenn hier jedes mal kommt "Remote access not allowed", dann stimmt sicherlich irgend etwas mit deinem Konto nicht! Mir gehen langsam die Ideen aus :(
Das Verhalten habe ich bis jetzt nämlich noch nie gesehen! Das Problem ist, das hier ein Retry natürlich auch nichts bringt, wenn die API der festen Meinung ist, das du auf sie nicht zugreifen kannst… Die Logindaten kann ich leider im Adapter nicht selbst speichern und dich selbst anmelden, da eine Passwort-Auth von Innogy nicht zugelassen wird. Ich bemühe aber auch noch einmal meine Kontakte nach Innogy ... Kannst du mir ggf. per PN deinen Benutzernamen schicken? Dann kann ich den direkt mit anhängen (natürlich nur, wenn dir das recht ist!!)
Zu den Funktionen: Du kannst hinter den Objekten/Geräten in der Spalte Funktion einfach eine Funktion (z.B. Licht) eintragen ;)
Alternativ die Geräte einfach per Hand zuweisen indem du im ersten Tab auf Hinzufügen klickst
` > Zu den Funktionen: Du kannst hinter den Objekten/Geräten in der Spalte Funktion einfach eine Funktion (z.B. Licht) eintragen ;)
Alternativ die Geräte einfach per Hand zuweisen indem du im ersten Tab auf Hinzufügen klickst `
Hallo PArt,
ich kann unter Funktionen nicht eingeben.
Ich gelange in eine Auswahlliste wo nichts eingetragen ist.
Kunime
2310_funktion.png -
Hallo PArt,
ist es vllt möglich BN und PW über den Adapter an Innogy zu übergeben? Ohne Handeingabe? Vllt über MD5 verschlüsselt lokal ablegen und bei jedem Neustart des Adapters BN un PW abfragen.
Ich weiß nur noch nicht wie man es an Innogy übergeben könnte. Ist ja eine externe Seite aber villt über URL und php?
PS: Nur so ein Gedanke!
Grüße,
Torsten
Guten Morgen, gibt es zu dem Adapter etwas Neues? Ich habe die Fußbodenheizung und würde aus Kostengründen ungern wechseln.
heute habe ich erfahren das der "Reconnect" zum Sicherheitskonzept von Innogy gehört.Das heißt das ich mich jeden Tag neu verbinden muß. `
Wie machen die das denn dann mit dem innogy Skill für Alexa?Gruß,
Krissi
Hallo Krissi,
laut Aussage funktioniert der Reconnect nur bei der App und laut deiner Aussage beim Skill. Der Reconnect bei der Api geht "noch" nicht. Ein Wechsel ist mir auch zu teuer aber "ein Mann muß tun was ein Mann tun muß". es ist mit der Zeit einfach nur nervig sich jedesmal neu anzumelden!
Grüße,
Torsten
