  4. (gelöst)zigbee Adapter kann ich nicht installieren
22 Beiträge 3 Kommentatoren 2.4k Aufrufe 1 Beobachtet
  • A Online
    A Online
    arnold
    schrieb am zuletzt editiert von arnold
    zigbee Adapter kann ich nicht installieren .
    ich habe zigbee Adapter gelöscht und jetzt kann ich nicht installieren.
    2021-11-23 00:00:26.932  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 8269
    2021-11-23 00:00:35.164  - error: host.raspberrypi4-iob Caught by controller[0]: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:56
    2021-11-23 00:00:35.164  - error: host.raspberrypi4-iob Caught by controller[0]:       throw err
    2021-11-23 00:00:35.164  - error: host.raspberrypi4-iob Caught by controller[0]:       ^
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at JSON.parse (<anonymous>)
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:52:17)
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:409:30)
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at new Zigbee (/opt/iobroker/node_modules/iobroker.zigbee/main.js:60:9)
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:807:5)
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-11-23 00:00:35.165  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-11-23 00:00:35.166  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-11-23 00:00:35.166  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-11-23 00:00:35.166  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    2021-11-23 00:00:35.166  - error: host.raspberrypi4-iob instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-11-23 00:00:35.166  - info: host.raspberrypi4-iob Restart adapter system.adapter.zigbee.0 because enabled
    2021-11-23 00:00:40.710  - warn: mihome-vacuum.0 (17564) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
    2021-11-23 00:01:00.829  - warn: mihome-vacuum.0 (17564) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
    2021-11-23 00:01:05.213  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 9422
    2021-11-23 00:01:09.871  - error: host.raspberrypi4-iob Caught by controller[0]: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:56
    2021-11-23 00:01:09.872  - error: host.raspberrypi4-iob Caught by controller[0]:       throw err
    • A arnold
      @arnold
      Wie installierst du das neu?
      Und ist nodeJS richtig installiert? Welche Versionen?
      npm cache Mal gelöscht?
      Und warum stimmt deine Uhrzeit nicht?
        @arnold
        A Online
        A Online
        arnold
        Verfügbare Version:1.5.6 installiere ich über
        pi@raspberrypi4-iob:~ $ which nodejs node npm && nodejs -v && node -v && npm -v        && sudo apt update && sudo apt update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v12.22.7
        v12.22.7
        6.14.15
        OK:1 http://archive.raspberrypi.org/debian buster InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:3 https://repos.influxdata.com/debian buster InRelease
        OK:4 https://deb.nodesource.com/node_12.x buster InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           12.22.7-deb-1nodesource1
          Installationskandidat: 12.22.7-deb-1nodesource1
          Versionstabelle:
         *** 12.22.7-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
             10.24.0~dfsg-1~deb10u1 500
        Habe neu installiert nodejs und iobroker fix , mindestens Uhrzeit stimmt schon wieder.
        Zigbee kann ich nicht installieren gleiche Fehler
        • A arnold
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.7
          v12.22.7
          6.14.15
          nodejs:
            Versionstabelle:
          @arnold
          iobroker update -i
          cd /opt/iobroker
          sudo -u iobroker npm cache clear --force
            @arnold
            iobroker update -i
            cd /opt/iobroker
            A Online
            A Online
            arnold
            @thomas-braun said in zigbee Adapter kann ich nicht installieren:
            gemacht , leider kommt bei Installation noch
            iobroker Uncaught Rejection: TypeError: Cannot read property 'common' of undefined at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:745:25) at Immediate.<anonymous>
            (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:859:29) at processImmediate (internal/timers.js:463:21)
            iobroker host.raspberrypi4-iob error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167
            • A arnold
              @arnold
              Bitte keine Screenshots von Texten. Kann und will ich nicht entziffern.
                @arnold
                A Online
                A Online
                arnold
                ich habe ausgeführt
                iobroker update -i
                cd /opt/iobroker
                dann Adapter installiert
                kommt Fehler
                $ iobroker add zigbee --host raspberrypi4-iob
                host.raspberrypi4-iob install adapter zigbee
                Uncaught Rejection: TypeError: Cannot read property 'common' of undefined at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:745:25) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:859:29) at processImmediate (internal/timers.js:463:21)
                ERROR: Process exited with code 27
                Andi19851985A 1 Antwort Letzte Antwort
                • A arnold
                  ich habe ausgeführt
                  iobroker update -i
                  cd /opt/iobroker
                  kommt Fehler
                  Andi19851985A Offline
                  Andi19851985
                  @arnold Problem gelöst?
                  Falls nicht dann versuche mal über die Katze folgenden link
                  https://github.com/ioBroker/ioBroker.zigbee
                  zu installieren und dann eine Instanz hinzuzufügen.
                  Andreas
                  • Andi19851985A Andi19851985
                    Andreas
                    A Online
                    A Online
                    arnold
                    @andi19851985 said in zigbee Adapter kann ich nicht installieren:
                    hallo
                    habe über Katze installiert jetzt ist zigbee Adapter gelb.
                    bei pairing
                    Einstellung in com steht
                    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001936DCEE-if00
                    pi@raspberrypi4-iob:~ $ lsusb
                    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                    Bus 001 Device 003: ID 0451:16a8 Texas Instruments, Inc.
                    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                    error Error herdsman start
                    error Failed to start Zigbee
                    error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    error Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                    error instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                    error getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                    error instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    error zigbee.0 already running
                    2021-11-27 19:57:43.540 error getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                    2error getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                    pi@raspberrypi4-iob:~ $ iobroker stop
                    pi@raspberrypi4-iob:~ $ cd /opt/iobroker/node_modules/iobroker.zigbee
                    pi@raspberrypi4-iob:/opt/iobroker/node_modules/iobroker.zigbee $ sudo npm rebuil        d --unsafe-perm
                    @iobroker/adapter-core@2.5.1 /opt/iobroker/node_modules/iobroker.zigbee/node_mod        ules/@iobroker/adapter-core
                    @types/iobroker@3.3.4 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@t        ypes/iobroker
                    pi@raspberrypi4-iob:/opt/iobroker/node_modules/iobroker.zigbee $ cd
                    pi@raspberrypi4-iob:~ $ iobroker start
                    • A arnold
                      hallo
                      bei pairing
                      @arnold sagte in zigbee Adapter kann ich nicht installieren:
                      sudo npm
                      Nicht mit sudo rummurksen...
                        sudo npm
                        A Online
                        A Online
                        arnold
                        habe jetzt ohne sudo gemacht
                        pi@raspberrypi4-iob:/opt/iobroker/node_modules/iobroker.zigbee $ npm rebuild --u        nsafe-perm
                        cc2531 wird gefunden
                        pi@raspberrypi4-iob:~ $ ls -la /dev/serial/by-id
                        insgesamt 0
                        drwxr-xr-x 2 root root 60 Nov 27 20:36 .
                        drwxr-xr-x 4 root root 80 Nov 27 20:36 ..
                        lrwxrwxrwx 1 root root 13 Nov 27 20:36 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001936DCEE-if00 -> ../../ttyACM0
                        • A arnold
                          insgesamt 0
                          @arnold
                          Die Extended PAN-Id auf eine 16stellige HEX-Zahl ändern.
                          Ein Neustart des Adapters sieht jetzt wie aus?
                            @arnold
                            A Online
                            A Online
                            arnold
                            kannst du mir ein Beispiel machen 16stellige HEX-Zahl
                            • A arnold
                              @arnold
                              Mach selber:
                              https://www.browserling.com/tools/random-hex
                                @arnold
                                Mach selber:
                                A Online
                                A Online
                                arnold
                                bekomme nicht 16 rein
                                • A arnold
                                  @arnold
                                  PAN-Id ist auch nicht die Extended PAN-Id / Erweiterte PAN-Id
                                    @arnold
                                    A Online
                                    A Online
                                    arnold
                                    Extended PAN-Id keine Ahnung ist mir zu hoch .
                                    CC2531 vielleicht Kaputt ,Diode geht aber an .
                                    kann ich das prüfen ?
                                    • A arnold
                                      Was ist denn da zu hoch? Das ist zwei Dinge:
                                      Wenns an Englisch hapert: Extended = Erweitert
                                      Ja, die Dinger sind 'defective by design'.
                                        A Online
                                        A Online
                                        arnold
                                        Extended PAN-Id geändert .
                                        jetzt im log
                                        2021-11-27 23:28:47.997  - warn: zigbee.0 (5429) Failed to stop zigbee during st        artup
                                        2021-11-27 23:28:47.998  - info: zigbee.0 (5429) terminating
                                        2021-11-27 23:28:48.000  - info: zigbee.0 (5429) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
                                        2021-11-27 23:28:48.858  - info: host.raspberrypi4-iob stopInstance system.adapt        er.zigbee.0 killing pid 5429
                                        2021-11-27 23:28:49.237  - warn: mihome-vacuum.0 (1181) State value to set for "        mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                        2021-11-27 23:28:49.586  - info: host.raspberrypi4-iob "system.adapter.zigbee.0"        enabled
                                        2021-11-27 23:28:49.628  - info: host.raspberrypi4-iob instance system.adapter.z        igbee.0 started with pid 28076
                                        2021-11-27 23:28:52.552  - error: zigbee.0 (28076) zigbee.0 already running
                                        2021-11-27 23:28:52.555  - warn: zigbee.0 (28076) Terminated (ADAPTER_ALREADY_RU        NNING): Without reason
                                        2021-11-27 23:28:53.461  - error: host.raspberrypi4-iob instance system.adapter.        zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2021-11-27 23:28:53.462  - info: host.raspberrypi4-iob Restart adapter system.ad        apter.zigbee.0 because enabled
                                        2021-11-27 23:29:09.274  - warn: mihome-vacuum.0 (1181) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                        2021-11-27 23:29:23.553  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 28961
                                        2021-11-27 23:29:24.550  - error: host.raspberrypi4-iob instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                        2021-11-27 23:29:24.553  - info: host.raspberrypi4-iob Do not restart adapter system.adapter.zigbee.0 because desired by instance
                                        2021-11-27 23:29:27.076  - info: zigbee.0 (28961) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.20
                                        2021-11-27 23:29:27.183  - info: zigbee.0 (28961) Starting Zigbee  npm ...
                                        2021-11-27 23:29:27.658  - info: zigbee.0 (28961) Installed Version: ioBroker/ioBroker.zigbee#ca9442058258080026170f14d74d1c4d56b47338
                                        Adapter noch gelb
                                        • A arnold
                                          jetzt im log
                                          Adapter noch gelb
                                          @arnold
                                          iobroker restart
