  4. Probleme mit Zigbee und CC26X2R1
140 Beiträge 13 Kommentatoren 21.1k Aufrufe 14 Beobachtet
  • R reeze
    @arteck
    Hi, läuft immer noch nicht,
    hier das Log nach der installation von GIT:
    der zigbee.1 Adapter ist der mit dem CC26X2R1.
    zigbee.1
    	2021-08-17 15:04:01.298	error	Error herdsman start
    zigbee.1
    	2021-08-17 15:04:01.298	error	Failed to start Zigbee
    zigbee.1
    	2021-08-17 15:04:01.297	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.1
    	2021-08-17 15:04:01.175	info	Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee.1
    	2021-08-17 15:04:01.169	info	Starting Zigbee npm ...
    zigbee.1
    	2021-08-17 15:04:01.168	info	Try to reconnect. 1 attempts left
    zigbee.0
    	2021-08-17 15:03:55.335	warn	Failed to ping 0x0017880100f68e8d LCT001
    zigbee.1
    	2021-08-17 15:03:51.167	error	Error herdsman start
    zigbee.1
    	2021-08-17 15:03:51.167	error	Failed to start Zigbee
    zigbee.1
    	2021-08-17 15:03:51.167	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    	2021-08-17 15:03:33.520	info	Zigbee started
    zigbee.0
    	2021-08-17 15:03:33.519	info	0x0017880100f68e8d (addr 34870): 9290012573A - Philips Hue white and color ambiance E26/E27/E14 (Router)
    zigbee.0
    	2021-08-17 15:03:33.519	info	0xb4e3f9fffe5aa665 (addr 34124): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    zigbee.0
    	2021-08-17 15:03:33.519	info	0x84182600000ed1b0 (addr 37133): AB3257001NJ - OSRAM Smart+ plug (Router)
    zigbee.0
    	2021-08-17 15:03:33.519	info	0x00158d0006f98184 (addr 16495): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0
    	2021-08-17 15:03:33.518	info	0x8418260000098325 (addr 39924): AB3257001NJ - OSRAM Smart+ plug (Router)
    zigbee.0
    	2021-08-17 15:03:33.518	info	0xb4e3f9fffeaf0664 (addr 50161): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    zigbee.0
    	2021-08-17 15:03:33.518	info	0xb4e3f9fffeacb054 (addr 50946): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    zigbee.0
    	2021-08-17 15:03:33.518	info	0xb4e3f9fffe58c0f9 (addr 41079): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    zigbee.0
    	2021-08-17 15:03:33.517	info	0x84182600000ef735 (addr 33894): AB3257001NJ - OSRAM Smart+ plug (Router)
    zigbee.0
    	2021-08-17 15:03:33.509	info	Currently 9 devices are joined:
    zigbee.0
    	2021-08-17 15:03:33.497	info	--> transmitPower : normal
    zigbee.0
    	2021-08-17 15:03:33.491	info	Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
    zigbee.0
    	2021-08-17 15:03:33.203	warn	Extended PAN ID is reversed (expected=a076fb0f004b1200, actual=00124b000ffb76a0)
    zigbee.0
    	2021-08-17 15:03:31.613	info	Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee.1
    	2021-08-17 15:03:31.605	info	Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee.1
    	2021-08-17 15:03:31.480	info	Starting Zigbee npm ...
    zigbee.0
    	2021-08-17 15:03:31.433	info	Starting Zigbee npm ...
    zigbee.1
    	2021-08-17 15:03:31.453	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
    zigbee.0
    	2021-08-17 15:03:31.401	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
    host.ubuntiobroker
    	2021-08-17 15:03:30.605	info	instance system.adapter.zigbee.1 started with pid 1997
    host.ubuntiobroker
    	2021-08-17 15:03:30.590	info	instance system.adapter.zigbee.0 started with pid 1990
    host.ubuntiobroker
    	2021-08-17 15:03:28.589	info	iobroker exit 0
    host.ubuntiobroker
    	2021-08-17 15:03:28.540	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.ubuntiobroker
    	2021-08-17 15:03:28.199	info	instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0
    	2021-08-17 15:03:28.010	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    	2021-08-17 15:03:28.009	info	terminating
    host.ubuntiobroker
    	2021-08-17 15:03:27.584	info	stopInstance system.adapter.zigbee.1 send kill signal
    host.ubuntiobroker
    	2021-08-17 15:03:27.577	info	stopInstance system.adapter.zigbee.0 send kill signal
    zigbee.0
    	2021-08-17 15:03:27.536	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2021-08-17 15:03:27.535	info	cleaned everything up...
    zigbee.1
    	2021-08-17 15:03:27.553	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.1
    	2021-08-17 15:03:27.553	info	terminating
    zigbee.1
    	2021-08-17 15:03:27.552	warn	Failed to stop zigbee during startup
    zigbee.1
    	2021-08-17 15:03:27.537	info	Zigbee: disabling joining new devices.
    zigbee.1
    	2021-08-17 15:03:27.536	info	cleaned everything up...
    zigbee.0
    	2021-08-17 15:03:27.534	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.1
    	2021-08-17 15:03:27.535	info	Got terminate signal TERMINATE_YOURSELF
    host.ubuntiobroker
    	2021-08-17 15:03:27.533	info	stopInstance system.adapter.zigbee.1 (force=false, process=true)
    host.ubuntiobroker
    	2021-08-17 15:03:27.527	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    host.ubuntiobroker
    	2021-08-17 15:03:27.519	info	iobroker Update "system.adapter.zigbee.1"
    host.ubuntiobroker
    	2021-08-17 15:03:27.518	info	iobroker Update "system.adapter.zigbee.0"
    host.ubuntiobroker
    	2021-08-17 15:03:27.449	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    host.ubuntiobroker
    	2021-08-17 15:03:27.393	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
    host.ubuntiobroker
    	2021-08-17 15:03:27.341	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:27.288	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:27.233	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:27.180	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:27.110	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:27.055	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:27.002	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.950	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.897	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.844	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.791	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.738	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.685	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.633	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.580	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.526	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.473	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.420	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:26.368	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:25.836	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:25.303	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:24.772	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:24.242	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/crts0111.PNG img/crts0111.PNG image/png
    host.ubuntiobroker
    	2021-08-17 15:03:23.714	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:23.187	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e14_candle.png img/flair_viyu_e14_candle.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:22.657	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:22.114	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_6.png img/group_6.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:19.403	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lamp_01.png img/lamp_01.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:16.746	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_globe.png img/paulmann_rgbw_globe.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:14.069	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
    host.ubuntiobroker
    	2021-08-17 15:03:11.387	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
    host.ubuntiobroker
    	2021-08-17 15:03:06.991	info	iobroker node-aead-crypto not needed on this system, since all ciphers are natively supported
    host.ubuntiobroker
    	2021-08-17 15:02:48.927	info	iobroker npm install ioBroker/ioBroker.zigbee#master --loglevel error --prefix "/opt/iobroker" (System call)
    host.ubuntiobroker
    	2021-08-17 15:02:48.927	info	iobroker NPM version: 6.14.14
    host.ubuntiobroker
    	2021-08-17 15:02:48.812	info	iobroker install ioBroker/ioBroker.zigbee#master
    host.ubuntiobroker
    	2021-08-17 15:02:48.000	info	iobroker url https://github.com/ioBroker/ioBroker.zigbee/tarball/master --host ubuntiobroker
    Hier der Screenshot:
    Sehr viel mehr passiert nicht in dem Log
    Danke dir schon mal
    @reeze
    Und dann würde ich über den Pfad by-id zum Gerät gehen. Der passt immer.
    ls -l /dev/serial/by-id/
    insgesamt 0
    lrwxrwxrwx 1 root root 13 11. Aug 07:27 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff-if00-port0 -> ../../ttyUSB0
    R 1 Antwort Letzte Antwort
      @reeze
      insgesamt 0
      reeze
      danke, das hatte ich schon versucht leider ohne Erfolg
      zigbee.1
      	2021-08-17 15:17:10.943	error	Error herdsman start
      zigbee.1
      	2021-08-17 15:17:10.943	error	Failed to start Zigbee
      zigbee.1
      	2021-08-17 15:17:10.942	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.1
      	2021-08-17 15:17:10.871	info	Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.1
      	2021-08-17 15:17:10.865	info	Starting Zigbee npm ...
      zigbee.1
      	2021-08-17 15:17:10.864	info	Try to reconnect. 1 attempts left
      zigbee.1
      	2021-08-17 15:17:00.863	error	Error herdsman start
      zigbee.1
      	2021-08-17 15:17:00.863	error	Failed to start Zigbee
      zigbee.1
      	2021-08-17 15:17:00.862	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      zigbee.1
      	2021-08-17 15:16:41.346	info	Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.1
      	2021-08-17 15:16:41.232	info	Starting Zigbee npm ...
      zigbee.1
      	2021-08-17 15:16:41.207	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
      host.ubuntiobroker
      	2021-08-17 15:16:40.392	info	instance system.adapter.zigbee.1 started with pid 2038
      host.ubuntiobroker
      	2021-08-17 15:16:38.040	info	instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      reeze@ubuntiobroker:~$ ls -l /dev/serial/by-id
      total 0
      lrwxrwxrwx 1 root root 13 Aug 17 14:56 usb-1a86_USB2.0-Serial-if00-port0 -> ../../ttyUSB0
      lrwxrwxrwx 1 root root 13 Aug 17 14:56 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000FFB76A0-if00 -> ../../ttyACM0
      lrwxrwxrwx 1 root root 13 Aug 17 14:56 usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100MKG-if00 -> ../../ttyACM1
      lrwxrwxrwx 1 root root 13 Aug 17 14:56 usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100MKG-if03 -> ../../ttyACM2
      • R reeze
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        host.ubuntiobroker
        host.ubuntiobroker
        total 0
        @reeze
        Und welches der drei Geräte ist es?
          @reeze
          reeze
          Interface 00 (if00) ist der richtige. Der taucht immer als 2 auf
          • R reeze
            arteckA Offline
            arteckA Offline
            arteck
            @reeze sind die einstellungen vom zigbee.0 die gleichen ?
            ist das ein multihost ??
            hast du ein USB hub da dran ??
            • arteckA arteck
              reeze
              @arteck
              1: nein
              2: nein
              3: nein (auch bewusst an USB 2.0 angeschlossen)
              Nach etwas Recherche habe ich mir die Revision vom Board angesehen, es ist wie benötigt ein Rev. E Board.
              schmitzkatzeS arteckA 2 Antworten Letzte Antwort
              • R reeze
                @arteck
                1: nein
                2: nein
                schmitzkatzeS Offline
                schmitzkatze
                @reeze ich habe das gleiche Problem mit dem Zigbee cc26x2r1 weiß nicht mehr was ich noch machen kann
                • R reeze
                  @arteck
                  1: nein
                  2: nein
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @reeze läuft es wenn du das zigbee.0 abschaltest ?
                  schmitzkatzeS 1 Antwort Letzte Antwort
                  • arteckA arteck
                    schmitzkatze
                    @arteck habe ich noch nicht getestet. Wie schalte ich das aus ?
                    • schmitzkatzeS schmitzkatze
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @schmitzkatze na adapter stopen
                      • arteckA arteck
                        schmitzkatze
                        @arteck ich glaube das ich mich falsch ausgedrückt habe.
                        Es ist so das ich den Adapter nicht grün bekomme.
                        Hatte die Schwierigkeiten schon bei meiner erst Installation, ich glaube der CC26 verträgt sich nicht so gut mit NUC u. ioBroker. Aber das Problem müssen doch mehrere habe?
                        Ich muß da ruhe und mehr #Zeit für haben, mal eben auf die Schnelle hat das keinen Zweck.
                        opossumO 1 Antwort Letzte Antwort
                          opossumO Offline
                          opossumO Offline
                          opossum
                          schrieb am zuletzt editiert von opossum
                          Hallo, @schmitzkatze,
                          ich habe die Konstellation Intel NUC->Proxmox->VM(iobroker) und habe den CC26X2R1 durchgereicht an die VM. Bei mir sieht das so aus:
                          Hatte auch die Probleme, dass der Adapter nicht grün wurde. Habe dann alles gelöscht und den Adapter neu installiert. Allerdings zeigt mein iobroker als Version 1.5.6 an. Bei mir läuft das jetzt aber ohne Probleme. Habe jetzt mal die Sendeleistung auf "high" umgesetzt, auch dann wird der Adapter wieder grün.
                          Firmwarestand des CC26x2R1:
                          https://www.schlepper-petersdorf.de
                          schmitzkatzeS 2 Antworten Letzte Antwort
                          • opossumO opossum
                            schmitzkatze
                            @opossum ja das ist bei mir genau so, würde ich sagen.? Könnt ja mal drüber schauen.Bildschirmfoto 2021-11-24 um 19.06.29.png Bildschirmfoto 2021-11-24 um 19.04.38.png Bildschirmfoto 2021-11-24 um 18.54.56.png Bildschirmfoto 2021-11-24 um 18.24.59.png
                            schmitzkatzeS Thomas BraunT 2 Antworten Letzte Antwort
                              schmitzkatze
                                @schmitzkatze
                                Erweiterte PAN-Id setzen, nicht als root rumhampeln.
                                  @schmitzkatze
                                  schmitzkatze
                                  @thomas-braun kann Dir nicht folgen. Was meinst Du damit ?
                                    schmitzkatze
                                    @schmitzkatze vielleicht muß ich dabei sagen, das der schon mal an dem NUC funktioniert hat. Habe da irgend welchen Mist verzapft und dann gib er nicht mehr! 🤢
                                    Hat das Auswirkungen beim Anmelden?
                                    • opossumO opossum
                                      schmitzkatze
                                      @opossum ich überlege gerade das TI Board noch mal neu zu flashen, finde aber bei GitHup nicht das richtige "bin" für das CC26X2R1 ? Kann mir da vielleicht einer auf die Sprünge helfen?
                                      opossumO arteckA 2 Antworten Letzte Antwort
                                        opossumO Offline
                                        opossumO Offline
                                        opossum
                                        habe gestern einiges an Updates durchgeführt. Danach wollte der ZigBee nicht grün werden. Habe dann auf der Konsole folgendes gemacht:
                                        Wechsel in das Verzeichnis /opt/iobroker/node_modules/@serialport/bindings und dort den Befehl npm install --production ausgeführt. Dann war auch der ZigBee wieder grün. Kannst das gern mal ausprobieren. Ist ein Tipp aus diesem Post. Vielleicht hilft es ja auch bei Dir.
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @schmitzkatze https://github.com/Koenkk/Z-Stack-firmware
                                          F schmitzkatzeS 2 Antworten Letzte Antwort
