  4. Test Adapter BMW/Mini v4.x.x
    6.7k
1.1k Beiträge 103 Kommentatoren 377.0k Aufrufe 89 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #282
    Ha, das ist der Hammer.
    Habe eben mal den bmw Adapter neu gestartet. Und jetzt kommt der Fehler bei mir auch:
    bmw.0
    2021-11-17 21:16:15.669	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
    bmw.0
    2021-11-17 21:16:15.668	error	Error: Request failed with status code 400
    bmw.0
    2021-11-17 21:16:15.551	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
    Äußerst ärgerlich das ganze nun.
    Bitte prüfen.
    Nachtrag:
    Und der Adpater bleibt gelb.
    Danke.
    F bahnuhrB M 3 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      bmw.0
      bmw.0
      bmw.0
      Bitte prüfen.
      Nachtrag:
      fwT26
      #283
      @bahnuhr Ja genau, bei mir nach restart auch gelb
      iobroker auf synology docker, portainer, grafana, influxdb
      • bahnuhrB bahnuhr
        bmw.0
        bmw.0
        bmw.0
        Bitte prüfen.
        Nachtrag:
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #284
        Im debug kommt noch:
        bmw.0
        2021-11-17 21:25:27.234	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        bmw.0
        2021-11-17 21:25:27.233	error	Error: Request failed with status code 400
        bmw.0
        2021-11-17 21:25:27.188	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        bmw.0
        2021-11-17 21:25:27.119	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33xxxxxx&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cEG9eLAIi6Nv-aaCAniziE_B6FPoobva3qr5gukilYw&authorization=fX7MypPgrL_FKrljWXPvAQrJNUE.*AAJTSQACMDIAAlNLABxjQjRxd2RoQWkxRzRIWEkvxxxxxxxxxxxxxxxxxxIwMQ..*"}
        (debug code hab ich teilweise x eingefügt)
        Danke.
        • bahnuhrB bahnuhr
          bmw.0
          bmw.0
          bmw.0
          Bitte prüfen.
          Nachtrag:
          manny4566
          #285
          @bahnuhr
          Jo, hab es heute auch nach dem Neustart bemerkt. Da passt etwas nicht mehr. Meine VIS hat jetzt keine BMW Infos mehr -.- ... Weltuntergang :D
          • M manny4566
            @bahnuhr
            tombox
            #286
            @manny4566
            Mit v2.5.0 wurde der neue Loginprozess übernommen.
            Einfach via github installieren oder auf das Update warten
            M F bahnuhrB M S 6 Antworten Letzte Antwort
            • T tombox
              @manny4566
              Magoo
              #287
              @tombox
              Perfekt mit 2.5.0 läuft es wieder!!!
              Danke an alle für den schnellen Fix.
              • T tombox
                @manny4566
                fwT26
                #288
                @tombox
                Vielen Dank für das schnelle Update, mit 2.5.0 alles wieder OK !
                • T tombox
                  @manny4566
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #289
                  @tombox
                  Auch Bestätigung von mir. Läuft wieder.
                  Danke schön.
                  Jetzt kann ich die Standheizung wieder über VIS starten.
                  Danke.
                  • bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #290
                    @Magoo
                    @fwT26
                    Gebt @tombox doch einen Daumen nach oben.
                    War doch super Arbeit.
                    Danke.
                    • T tombox
                      @manny4566
                      manny4566
                      #291
                      @tombox
                      Klappt, super Danke
                      • J Offline
                        Jogi19
                        #292
                        @tombox
                        auch von mir ein Dankeschön für die schnelle Problemlösung.
                        • bahnuhrB bahnuhr
                          @tombox
                          Danke schön.
                          kkickingereder
                          #293
                          @bahnuhr triggerst du diese Datenpunkte?
                          Standheizung an dann einfach auf TRUE (1)
                          • K kkickingereder
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #294
                            @kkickingereder
                            ja, einfach auf true.
                            setState('bmw.0.WBA5D11010G293605.remotev2.climate-now_START', true);
                            Danke.
                            • J Offline
                              jm3west
                              schrieb am zuletzt editiert von jm3west
                              #295
                              Tach,
                              wo kann ich sehen/auslesen ob das Fahrzeug verriegelt oder entriegelt ist?
                              Mit dem doorGeneralState funktioniert dass nicht!
                              Ich habe mal den Datenpunkt mittels Debug > Wert von Objekt-ID ausgelesen ...
                              ... da steht ja "EntriegeltVerriegelt" drin
                              Deshalb funktioniert auch meine Bedingung nicht
                              • J jm3west
                                Tach,
                                Strobelix
                                #296
                                @jm3west unter properties „aredoorslocked“
                                Raspberrymatic, Homematic & Homematic IP Aktoren, ioBroker auf NUC i3, Nuki, Harmony Hub, Digitalstrom, Diverse Sonoff (Tasmota) und Shellies
                                • T tombox
                                  @manny4566
                                  S Nicht stören
                                  S Nicht stören
                                  stenmic
                                  #297
                                  @tombox hi,
                                  seit dem letzten Update der App wird bei mir der Reifendruck angezeigt.
                                  Kann der Adapter auch die Werte auslesen?
                                  • T tombox
                                    @jogi19 hast du dich bei der bmw App mal ausgeloggt und wieder eingeloggt ?
                                    MSPtrs
                                    schrieb am zuletzt editiert von MSPtrs
                                    #298
                                    @tombox
                                    Moin BMW Adapter Gemeinde, :D
                                    ich würde gerne den Ladestatus meines iX3 abfragen - das funktionier auch über diesen Adapter echt gut👍
                                    Ich lasse den Adapter automatisiert auch nur laufen, wenn das Auto angesteckt ist, aber trotz dessen wird etwa 18 Stunden am Tag alle 5 Minuten einmal der Ladestand abgefragt...
                                    Wäre das vielleicht möglich, per Blocky einen Datenpunkt oder so zu steuern, welcher das Abfrageintervall des Adapters reguliert? Wenn diese Funktion integriert ist, wäre das echt nett, wenn mir jemand diese zeigen würde, sodass ich nicht unnötig die BMW API belaste und somit mein Beitrag zur Nachhaltigkeit des Adapters beitrage✊
                                    Denn dann würde das Intervall nur auf 5 Min. stehen, wenn das Auto auch wirklich lädt und nicht nur eingesteckt ist.
                                    Schönen Advent
                                    • T tombox
                                      @manny4566
                                      lxs
                                      schrieb am zuletzt editiert von lxs
                                      #299
                                      @tombox
                                      Ich komme mir jetzt leider wie ein Spielverderber vor, aber bei mir ist der Fehler auch mit der 2.5.0 noch vorhanden:
                                      2021-12-20 09:20:00.783  - info: bmw.0 (4608) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.7, js-controller: 3.3.21
                                      2021-12-20 09:20:01.147  - debug: bmw.0 (4608) {"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=XXXXX48&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cwU-gIEXXXXXXUcL3KQ&authorization=EvXXXXXXnA.*AXXXXXXXXwMQ..*"}
                                      2021-12-20 09:20:05.359  - error: bmw.0 (4608) "400 Bad Request"
                                      2021-12-20 09:20:05.514  - error: bmw.0 (4608) Error: Request failed with status code 400
                                      2021-12-20 09:20:05.515  - error: bmw.0 (4608) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
                                      Ich habe ein paar XXX eingefügt.
                                      Habe den Adapter bereits einmal gelöscht und neu installiert, hat aber leider nicht geholfen 😧
                                      Viele Grüße,
                                      Alexander
                                      • L lxs
                                        @tombox
                                        Viele Grüße,
                                        Alexander
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #300
                                        @lxs bei mir waren heute keine Fehler in der Zeit. Also schon mal kein Problem mit dem BMW Server.
                                        Bei mir läuft auch BMW 2.5.0 und js-controller 3.3.21, aber mit node 14.18.2.
                                        Host: NUC8i3 mit Proxmox:
                                        • Slave: Pi4
                                        • ? Offline
                                          #301
                                          Hi, ich nutze den Adapter schon ne Weile. Echt klasse.
                                          Weiß jemand ob es einen Batteriestand gibt (nicht E-Auto sondern die klassische Batterie). Außerdem würd ich gern die Alarmanlage auslesen und als ne Art "Rauchmelder" in Homekit bringen.
                                          Zu beidem hab ich keinen DP gefunden
