  4. Backitup - Fehlermeldung Zigbee
    6.3k
backitup zigbee
44 Beiträge 5 Kommentatoren 4.2k Aufrufe 4 Beobachtet
    @andreas-s sagte in Backitup - Fehlermeldung Zigbee:
    zu I)
    Der user iobroker gehört in die Gruppe 'redis' rein.
    Ist der da drin?
    sudo -u iobroker groups
    zu II)
    Muss ich das Verzeichnis dann manuell erstellen?
    Würde ich machen.
    sudo -u iobroker mkdir /home/iobroker/javaskripte
    sollte passen.
    Andreas.S
    Vielen Dank. Das Verzeichnis habe ich angelegt. Der user iobroker war nicht in der Gruppe 'redis' . Ich habe mit Googles Hilfe folgendes versucht:
    pi@raspberrypi:~ $ sudo -u iobroker groups
    iobroker tty dialout audio video bluetooth gpio i2c
    pi@raspberrypi:~ $ sudo usermod -aG redis iobroker
    iobroker tty dialout audio video bluetooth redis gpio i2c
    Das Ergebnis sieht dann so aus
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //HAUSSERVER2/iobroker_backup/raspi_8GB /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 6986 states saved
    [DEBUG] [iobroker] - host.raspberrypi 8625 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_11_10-15_42_21_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [redis] - Start Redis Backup ...
    [DEBUG] [redis] - Try deleting the old redis tmp directory: "/opt/iobroker/backups/redistmp"
    [DEBUG] [redis] - old redis tmp directory "/opt/iobroker/backups/redistmp" cannot deleted
    [DEBUG] [redis] - detected redis file: dump.rdb | file type: rdb
    [ERROR] [redis] - Error: EACCES: permission denied, open '/var/lib/redis/dump.rdb'
    [ERROR] [redis] - [IGNORED] Error: EACCES: permission denied, open '/var/lib/redis/dump.rdb'
    [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_11_10-15_42_32_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    • Thomas BraunT Online
      Gleiches Spiel wie oben.
      Rechte an der Datei?
      getfacl /var/lib/redis/dump.rdb
        Andreas.S
        @thomas-braun said in Backitup - Fehlermeldung Zigbee:
        Hatte nicht der Befehl von oben den user iobroker in die Gruppe 'redis' aufgenommen?
        Damit sollte doch der Zugriff auf eine Datei die redis gehört erlaubt sein.
        pi@raspberrypi:~ $ getfacl /var/lib/redis/dump.rdb
        getfacl: Removing leading '/' from absolute path names
        # file: var/lib/redis/dump.rdb
        # owner: redis
        # group: redis
        user::rw-
        group::rw-
        other::---
        • A Andreas.S
          # owner: redis
          # group: redis
          user::rw-
          group::rw-
          other::---
          Doch, aber ggf. solltest du mal den Server neustarten. Erst dann werden die Gruppen neuzugewiesen. (Gibt auch noch andere Möglichkeiten, aber Neustart ist am einfachsten...)
          Ich bin gerade nicht sicher, kann aber sein, das da auch x noch als Recht gesetzt sein muss.
          Versuch aber erst mal den Neustart, wenn noch nicht getan.
            Andreas.S
            Nun ja nach dem Neustart habe ich ein anderes Problem :-(
            Ich hab den Adapter doch erst neu Aufgesetzt und bin noch immer am Geräte wieder anlernen. Bisher hatte er keine Probleme gemacht.
            zigbee.0 2021-11-10 20:02:47.120	info	Try to reconnect. 1 attempts left
            zigbee.0 2021-11-10 19:02:37.125	info	Installed Version: iobroker.zigbee@1.5.6
            zigbee.0 2021-11-10 19:02:37.120	error	Error herdsman start
            zigbee.0 2021-11-10 19:02:37.119	error	Failed to start Zigbee
            zigbee.0 2021-11-10 19:02:37.118	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            zigbee.0 2021-11-10 19:02:36.429	info	cleaned everything up...
            zigbee.0 2021-11-10 19:02:35.751	info	Starting Zigbee npm ...
            zigbee.0 2021-11-10 19:02:35.400	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
            Wenn ich in der Instanz die Einstellungen prüfen möchte kommt: You need save and run adapter before pairing!
            Schon bei der ersten Installation war ich verblüfft, da ich an der PAN ID Einstellungen machen musste.
            Forum Eintrag
            Aber danach ging alles - naja bis jetzt
            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
            • A Andreas.S
              Forum Eintrag
              Auf welches device ist ist die Instanz eingestellt?
              Für gewöhnlich nimmt man da den Link aus /dev/serial/by-id
                Andreas.S
                Sorry das wollte ich natürlich im Screenshot mit erwischen
                /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F8V-if00
                Es ist ein CC2642R1
                • A Andreas.S
                  Forum Eintrag
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  zigbee.0 2021-11-10 20:02:47.120 info Try to reconnect. 1 attempts left zigbee.0 2021-11-10 19:02:37.125 info Installed Version: iobroker.zigbee@1.5.6
                  Die geposteten Log-Einträge stammen vom 2. von 3 Startversuchen des Adapters. Da du noch die Version 1.5.6 nutzt hat der dabei genutzte Herdsman noch nicht die Patches die dazu führen das die serielle Schnittstelle direkt wieder freigegeben wird. Du hast da also einen "Folgefehler" gepostet, nicht die Log Ausgaben der eigentlichen Ursache.
                  Bitte Poste die Log Einträge des ersten Startversuchs. Wenn du die nicht mehr hast:
                  • Zigbee Adapter anhalten
                  • 30 Sekunden warten
                  • Zigbee Adapter starten
                  Dann hast du sie wieder.
                  Ansonsten empfehle ich Dir auf 1.6.x zu aktualisieren.
                  A.
                  • AsgothianA Asgothian
                    A.
                    Andreas.S
                    schrieb am zuletzt editiert von Andreas.S
                    @asgothian
                    Da ich ohnehin grad neu aufsetzte würde ich die 1.6.3 installieren.
                    Vielen Dank
                    Andreas
                      A.
                      Andreas.S
                      @asgothian
                      Hier nun das Protokoll nach dem ersten start
                      zigbee.0 2021-11-11 08:31:02.406	info	terminating with timeout
                      zigbee.0 2021-11-11 08:30:58.920	error	Error herdsman start
                      zigbee.0 2021-11-11 08:30:58.919	error	Failed to start Zigbee
                      zigbee.0 2021-11-11 08:30:58.919	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      zigbee.0 2021-11-11 08:30:58.744	info	Installed Version: iobroker.zigbee@1.6.3
                      zigbee.0 2021-11-11 08:30:58.719	info	Starting Zigbee npm ...
                      zigbee.0 2021-11-11 08:30:58.718	info	Try to reconnect. 1 attempts left
                      zigbee.0 2021-11-11 08:30:56.622	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zigbee.0 2021-11-11 08:30:56.621	info	terminating
                      zigbee.0 2021-11-11 08:30:56.620	warn	Got terminate signal. Checking desired PID: 5858 vs own PID 1936
                      zigbee.0 2021-11-11 08:30:53.753	info	Zigbee: disabling joining new devices.
                      zigbee.0 2021-11-11 08:30:53.751	info	cleaned everything up...
                      zigbee.0 2021-11-11 08:30:53.749	warn	Got terminate signal. Checking desired PID: 0 vs own PID 1936
                      zigbee.0 2021-11-11 08:30:48.715	error	Error herdsman start
                      zigbee.0 2021-11-11 08:30:48.715	error	Failed to start Zigbee
                      zigbee.0 2021-11-11 08:30:48.714	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      zigbee.0 2021-11-11 08:30:48.636	info	Installed Version: iobroker.zigbee@1.6.3
                      zigbee.0 2021-11-11 08:30:48.095	info	Starting Zigbee npm ...
                      zigbee.0 2021-11-11 08:30:47.981	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
                      Danach steht noch
                      host.raspberrypi
                      2021-11-11 08:31:05.401	info	Do not restart adapter system.adapter.zigbee.0 because desired by instance
                      host.raspberrypi
                      2021-11-11 08:31:05.400	error	instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                      • A Andreas.S
                        @asgothian
                        Danach steht noch
                        host.raspberrypi
                        host.raspberrypi
                        @andreas-s
                        Deine Zeitzone ist falsch eingestellt.
                          Andreas.S
                          Wo muss ich das umstellen?
                          Vielen Dank
                            @andreas-s
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @thomas-braun sagte in Backitup - Fehlermeldung Zigbee:
                            @andreas-s
                            Du weisst schon das das nichts mit dem behandelten Problem zu tun hat ?
                            Herzlichen Glückwunsch für ein erfolgreiches 'ThreadDerailing'.
                            Bitte lass dass doch.
                            A.
                              @andreas-s
                              A.
                              @asgothian sagte in Backitup - Fehlermeldung Zigbee:
                              Natürlich.
                              Falsche Zeitzone sorgt aber an anderen Stellen für Komplikationen. Deswegen flugs umstellen, macht das Leben insgesamt leichter.
                                Natürlich.
                                Andreas.S
                                Nachdem ich im iobroker nix gefunden habe, wurde ich im "raspi-config" fündig.
                                Habe jetzt Europa-Berlin als Zeitzone hinterlegt.
                                • A Andreas.S
                                  @andreas-s
                                  Da ist es richtig. Hat ja nicht unmittelbar mit dem ioBroker zu tun, sonder ist eine Einstellung für die user. Wichtig ist es trotzdem.
                                  Wie sieht der device link jetzt aus?
                                  ls -la /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F8V-if00
                                    @andreas-s
                                    Andreas.S
                                    Ich denke die neue Adapterversion hat sich hach einem erneuten Neustart wohl entschieden :-)
                                    pi@raspberrypi:~ $ ls -la /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F8V-if00
                                    lrwxrwxrwx 1 root root 13 Nov 10 17:37 /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F8V-if00 -> ../../ttyACM0
                                    Damit bin ich zurück beim ursprünglichen Problemansatz. Wenn ich die Instanz von BackItUp aufrufe, kommt als erstes die Fehlermeldung: "Auf diesem Host wurde keine Zigbee - Instanz gefunden. Bitte überprüfen Sie Ihr System."
                                    Protokolleintrag von BackItUp nach manueller Sicherung
                                    [DEBUG] [iobroker] - host.raspberrypi 7021 states saved
                                    [DEBUG] [iobroker] - host.raspberrypi 8667 objects saved
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_11_11-13_51_59_backupiobroker.tar.gz
                                    [DEBUG] [redis] - Created redistmp directory
                                    [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_11_11-13_52_10_backupiobroker.tar.gz
                                    [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
                                    [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
                                    [DEBUG] [redis] - done
                                    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_11_11-13_52_11_backupiobroker.tar.gz
                                    [EXIT] 0
                                    • A Andreas.S
                                      [EXIT] 0
                                      @andreas-s
                                      iobroker list adapters
                                      iobroker list instances
                                      iobroker update -i
                                      iobroker upload all
                                        @andreas-s
                                        iobroker update -i
                                        iobroker upload all
                                        Andreas.S
                                        iobroker upload all
                                        pi@raspberrypi:~ $ iobroker list adapters
                                        system.adapter.admin                   : admin          - v5.1.25
                                        system.adapter.alexa2                  : alexa2         - v3.11.2
                                        system.adapter.alias-manager           : alias-manager  - v1.2.3
                                        system.adapter.backitup                : backitup       - v2.1.17
                                        system.adapter.broadlink2              : broadlink2     - v2.0.3
                                        system.adapter.cloud                   : cloud          - v4.1.0
                                        system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.4
                                        system.adapter.daswetter               : daswetter      - v3.0.7
                                        system.adapter.devices                 : devices        - v1.0.9
                                        system.adapter.discovery               : discovery      - v2.7.0
                                        system.adapter.fritzdect               : fritzdect      - v2.1.15
                                        system.adapter.fullybrowser            : fullybrowser   - v2.0.8
                                        system.adapter.hs100                   : hs100          - v2.0.6
                                        system.adapter.ical                    : ical           - v1.11.4
                                        system.adapter.javascript              : javascript     - v5.2.8
                                        system.adapter.node-red                : node-red       - v2.4.0
                                        system.adapter.openweathermap          : openweathermap - v0.1.0
                                        system.adapter.shelly                  : shelly         - v4.0.7
                                        system.adapter.sonoff                  : sonoff         - v2.4.5
                                        system.adapter.sql                     : sql            - v1.15.7
                                        system.adapter.telegram                : telegram       - v1.10.0
                                        system.adapter.trashschedule           : trashschedule  - v1.2.0
                                        system.adapter.vis                     : vis            - v1.4.4
                                        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
                                        system.adapter.vis-inventwo            : vis-inventwo   - v3.2.0
                                        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                        system.adapter.vis-weather             : vis-weather    - v2.5.3
                                        system.adapter.web                     : web            - v3.4.9
                                        system.adapter.zigbee                  : zigbee         - v1.6.3
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $ iobroker list instances
                                          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
                                        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                                          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              -  enabled
                                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                        + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
                                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                        + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                                          system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F8V-if00
                                        + system.adapter.zigbee.1                 : zigbee                : raspi-slave                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD50FC-if00
                                        + instance is alive
                                        pi@raspberrypi:~ $
                                        Bei update sollte nicht viel passieren ist ja erst neu aufgesetzt
                                        pi@raspberrypi:~ $ iobroker update -i
                                        Used repository: default
                                        hash changed or no sources cached => force download of new sources
                                        update done
                                        Adapter    "admin"         : 5.1.25   , installed 5.1.25
                                        Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                                        Adapter    "alias-manager" : 1.2.3    , installed 1.2.3
                                        Adapter    "backitup"      : 2.1.17   , installed 2.1.17
                                        Adapter    "broadlink2"    : 2.0.3    , installed 2.0.3
                                        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                                        Adapter    "coronavirus-statistics": 0.8.4   , installed 0.8.4
                                        Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                                        Adapter    "devices"       : 1.0.9    , installed 1.0.9
                                        Adapter    "discovery"     : 2.7.3    , installed 2.7.0 [Updateable]
                                        Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                                        Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
                                        Adapter    "hs100"         : 2.0.6    , installed 2.0.6
                                        Adapter    "ical"          : 1.11.4   , installed 1.11.4
                                        Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                                        Controller "js-controller" : 3.3.18   , installed 3.3.18
                                        Adapter    "node-red"      : 2.4.0    , installed 2.4.0
                                        Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                                        Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                                        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                                        Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                                        Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                                        Adapter    "sql"           : 1.15.7   , installed 1.15.7
                                        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                                        Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                                        Adapter    "vis"           : 1.4.4    , installed 1.4.4
                                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                                        Adapter    "vis-inventwo"  : 3.2.0    , installed 3.2.0
                                        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                                        Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
                                        Adapter    "web"           : 3.4.9    , installed 3.4.9
                                        Adapter    "zigbee"        : 1.5.6    , installed 1.6.3
                                        pi@raspberrypi:~ $
                                        iobroker upload all
                                        extrem viel wenn da relevantes steht würde ich das als ZIP packen
                                        • A Andreas.S
                                          iobroker upload all
                                          pi@raspberrypi:~ $
                                          + instance is alive
                                          pi@raspberrypi:~ $
                                          update done
                                          pi@raspberrypi:~ $
                                          iobroker upload all
                                          • system.adapter.zigbee.1 : zigbee : raspi-slave
                                          Das hier ein Master/Slave-Setup am Start ist lese ich aber auch zum ersten Mal.
                                          Nein, nicht notwendig. Und bitte nicht auf die Idee kommen logfiles in ZIPs zu packen. Das will keiner.
