  4. Zigbee Adapter findet Stick nicht
    6.0k
65 Beiträge 8 Kommentatoren 15.2k Aufrufe 4 Beobachtet
  • D dondaik
    2021-11-06 15:17:11.148 - debug: zigbee.0 (3562) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2021-11-06 15:17:11.218 - debug: zigbee.0 (3562) Objects client ready ... initialize now
    2021-11-06 15:17:11.221 - debug: zigbee.0 (3562) Objects create System PubSub Client
    2021-11-06 15:17:11.223 - debug: zigbee.0 (3562) Objects create User PubSub Client
    2021-11-06 15:17:11.224 - debug: zigbee.0 (3562) Objects client initialize lua scripts
    2021-11-06 15:17:11.266 - debug: zigbee.0 (3562) Objects connected to redis: 0.0.0.0:9001
    2021-11-06 15:17:11.277 - debug: zigbee.0 (3562) objectDB connected
    2021-11-06 15:17:11.280 - debug: zigbee.0 (3562) Redis States: Use Redis connection: 0.0.0.0:9000
    2021-11-06 15:17:11.296 - debug: zigbee.0 (3562) States create System PubSub Client
    2021-11-06 15:17:11.298 - debug: zigbee.0 (3562) States create User PubSub Client
    2021-11-06 15:17:11.317 - debug: zigbee.0 (3562) States connected to redis: 0.0.0.0:9000
    2021-11-06 15:17:11.318 - debug: zigbee.0 (3562) statesDB connected
    2021-11-06 15:17:11.638 - info: zigbee.0 (3562) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
    2021-11-06 15:17:11.686 - debug: zigbee.0 (3562) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":" /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00","adapter":"zstack"}}
    2021-11-06 15:17:11.750 - info: zigbee.0 (3562) Starting Zigbee npm ...
    2021-11-06 15:17:11.752 - debug: zigbee.0 (3562) Starting zigbee-herdsman...
    2021-11-06 15:17:11.960 - error: zigbee.0 (3562) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00'"
    2021-11-06 15:17:11.961 - error: zigbee.0 (3562) Failed to start Zigbee
    2021-11-06 15:17:11.962 - error: zigbee.0 (3562) Error herdsman start
    2021-11-06 15:17:12.041 - info: zigbee.0 (3562) Installed Version: iobroker.zigbee@1.5.6
    2021-11-06 15:17:12.049 - debug: zigbee.0 (3562) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_06-15_17_11.tar.gz success
    2021-11-06 15:17:13.234 - info: mqtt.0 (1941) Client [8266 Terrasse] connection closed: timeout
    @dondaik
    Bitte CodeTags </> verwenden.
    • D dondaik
      @dondaik sagte in Zigbee Adapter findet Stick nicht:
      ls -la /dev/serial/by-id
        dondaik
        das device ist über ls -la /dev/serial/by-id kopiert , leerstellen: keine
        wer Schreibfehler findet darf sie behalten … :-(
        Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
        • D dondaik
          @dondaik
          Ich möchte die Ausgabe komplett und vollständig und ohne Kürzung und Nacherzählung aus dem Terminal kopiert, in CodeTags eingebettet, hier sehen.
            @dondaik
            dondaik
            hoffe so ok
            tinkerboard:~:# ls -la /dev/serial/by-id
            total 0
            drwxr-xr-x 2 root root 60 Nov  6 15:34 .
            drwxr-xr-x 4 root root 80 Nov  6 15:34 ..
            lrwxrwxrwx 1 root root 13 Nov  6 15:34 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00 -> ../../ttyACM0
            tinkerboard:~:#
            • D dondaik
              hoffe so ok
              total 0
              tinkerboard:~:#
              @dondaik
              Immer noch als root unterwegs.
              Ich bin dann auch raus.
              Viel Erfolg noch.
              • D dondaik
                hoffe so ok
                total 0
                tinkerboard:~:#
                @dondaik ich bin leider nicht fit in Linux, aber wenn @Thomas-Braun nicht ganz unbegründet aussteigt, will ich es mal versuchen dich auf den "wahren Pfad" zu leiten.
                Hast du einen anderen User als root?
                Sollte beim aktuellen armbian eigentlich angelegt werden müssen
                • R rettroo
                  leider erkennt mein Zigbee-Adapter meinen Stick nicht mehr. Ich hatte das vorab schon öfters , da half ein Reboot. Nun hilft aber auch das nicht mehr.
                  zigbee.0
                  2021-11-02 14:19:20.074	error	Error herdsman start
                  zigbee.0
                  2021-11-02 14:19:20.074	error	Failed to start Zigbee
                  zigbee.0
                  2021-11-02 14:19:20.074	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                  zigbee.0
                  2021-11-02 14:19:20.014	info	Installed Version: iobroker.zigbee@1.5.6
                  zigbee.0
                  2021-11-02 14:19:20.006	info	Starting Zigbee npm ...
                  zigbee.0
                  2021-11-02 14:19:20.005	info	Try to reconnect. 1 attempts left
                  zigbee.0
                  2021-11-02 14:19:10.004	error	Error herdsman start
                  zigbee.0
                  2021-11-02 14:19:10.004	error	Failed to start Zigbee
                  zigbee.0
                  2021-11-02 14:19:10.004	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                  zigbee.0
                  2021-11-02 14:19:10.003	error	Re-commissioning your network will require re-pairing of all devices!
                  zigbee.0
                  2021-11-02 14:19:10.003	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                  zigbee.0
                  2021-11-02 14:19:10.003	error	Please update configuration to prevent further issues.
                  zigbee.0
                  2021-11-02 14:19:10.003	error	- Channel List: configured=26, adapter=26
                  zigbee.0
                  2021-11-02 14:19:10.003	error	- Network Key: configured=01030507090b0d0f00020406080a0c0a, adapter=01030507090b0d0f00020406080a0c0a
                  zigbee.0
                  2021-11-02 14:19:10.002	error	- Extended PAN ID: configured=dadddddddddddddd, adapter=00124b00060d9d28
                  zigbee.0
                  2021-11-02 14:19:10.002	error	- PAN ID: configured=6754, adapter=6754
                  zigbee.0
                  2021-11-02 14:19:10.002	error	Configuration is not consistent with adapter state/backup!
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @rettroo Auch wenn Dir das nicht wahrscheinlich nicht gefällt, aber erst mit mehrfachen Reboots und dann ging irgendwann gar nichts mehr, so haben sich meine CC2531 auch verabschiedet. Da hilft kein Adapter oder sonstiges. Ich hatte zum Glück noch einen conbee2 bei mir rumliegen und da brauchte ich nicht mal alles neu anlernen.
                  Bei mir war die Lebensdauer der CC2531 (2 Stück) alle ca. 1 Jahr.
                  MathiasJM 1 Antwort Letzte Antwort
                  • mickymM mickym
                    MathiasJM Offline
                    MathiasJM Offline
                    MathiasJ
                    @mickym
                    Gibt der defekte Stick über der Konsole was aus?
                    Wenn ich über der Konsole
                    ls -la /dev/serial/by-id eingebe, gibt er auch etwas aus.
                    IObroker auf dem NUC als VM.
                    • MathiasJM MathiasJ
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @mathiasj Ja ich glaube auf OS Ebene war alles noch in Ordnung - kann das aber nicht mehr mit Sicherheit sagen. Inzwischen habe ich das Teil entsorgt und kann es für Dich leider nicht mehr nachvollziehen oder mit Sicherheit sagen. Das war halt nur meine Erfahrung. Sorry.
                      • mickymM mickym
                        MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        @mickym
                        Der conbee 2 ist bestellt und kommt am Dienstag.
                        Mal sehen wie der läuft
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @mathiasj Also hatte zwar auch schon mal einen Abstürze - aber ansonsten bin ich sehr zufrieden. Insbesondere die Reichweite ist bei weitem besser. Und ich kann den Stick am Raspberry Pi4 auch an einem USB Hub betreiben, das war beim CC2531 nicht machbar und deswegen sterben die meines Erachtens früher oder später einen Hitzetod-
                          Lediglich mit der Gruppenfunktion gibts Fehlermeldungen im Log - obwohl sie eigentlich geht. Du brauchst aber mind. 1.6.3 bei dem Zigbee Adapter - sonst hagelt es Fehlermeldungen da drin.
                          • mickymM mickym
                            MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            @mickym
                            Danke für die Info!
                            Nein ich bin immer auf den neuesten Stand, was die Instanzen angeht.
                            Gruß und Dank,
                            Mathias
                              dondaik
                              egal ob user root oder norbert die antwort ist wie angegeben .....
                                dondaik
                                root oder norbert - die antwort ist gleich ....
                                • D dondaik
                                  das ist wahrscheinlich sogar korrekt.
                                  Aber iobroker läuft seit geraumer Zeit unter dem User iobroker.
                                  Wenn du da jetzt als root drin arbeitest kann es passieren, dass der user iobroker nicht mehr an die notwendigen Dateien darf.
                                  Deswegen solltest du nur noch mit dem User norbert arbeiten und notfalls mit sudo!
                                  Wenn du dich jetzt als norbert eingeloggt hast führe bitte aus:
                                  iobroker stop
                                  iobroker fix
                                  iobroker start
                                    iobroker stop
                                    iobroker fix
                                    iobroker start
                                    dondaik
                                    @homoran gemacht als norbert
                                    tinkerboard:~:% iobroker start
                                    tinkerboard:~:% ls -l /dev/serial/by-id/
                                    total 0
                                    tinkerboard:~:%
                                    total 0
                                    tinkerboard:~:%
                                    bleibt ... im  warndreick 2x grün dann:nicht verbunden mit dienst oder gerät
                                    und nun geht es zu schießen... danke, bis morgen
                                    • D dondaik
                                      total 0
                                      tinkerboard:~:%
                                      total 0
                                      tinkerboard:~:%
                                      dondaik
                                      schrieb am zuletzt editiert von dondaik
                                      dann kann ich meinen teil hier beenden - conbee 2 steckt und nun kann man wenigstens wieder schalten
                                      man dank!
                                      • D dondaik
                                        man dank!
                                        nur die netzkarte ist der meinung das verbindungslinien unnötig sind .... ggf gibt sich das ja mal.
                                        Das ist so bei Hardware von Dresden Electronic und dem zigbee-Adapter.
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @thomas-braun Inzwischen finde ich das nicht mehr - früher war es so, dass die Netzkarte mit dem conbee2 nie ein Ergebnis brachte - inzwischen läuft aber auch das zufriedenstellend. (zumindest bei meiner kleinen Umgebung)
