  4. node-red fenster nach update auf 2.4.0
    6.4k
85 Beiträge 5 Kommentatoren 4.6k Aufrufe 3 Beobachtet
  • F fournierrf5
    hab eben nochmal adapter deinstalliert/installiert - keine Besserung
    Hier der Installationslog, falss das hilft?
    $ iobroker add node-red 1 --host raspberrypi
    NPM version: 6.14.15
    npm install iobroker.node-red@2.4.0 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../src/bcrypt_node.cc:1:
    ../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2232:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
    In file included from ../node_modules/nan/nan.h:53,
    from ../src/bcrypt_node.cc:1:../src/bcrypt_node.cc: At global scope:/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/bcrypt_node.cc:378:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(bcrypt_lib, init); ^~~~~~~~~~~
    In file included from ../src/bcrypt_node.cc:1:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
    In file included from ../../nan/nan.h:54,
    from ../src/bcrypt_node.cc:1:../src/bcrypt_node.cc: At global scope:/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/bcrypt_node.cc:359:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(bcrypt_lib, init); ^~~~~~~~~~~
    host.raspberrypi install adapter node-red
    upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    host.raspberrypi object system.adapter.node-red created/updated
    host.raspberrypi create instance node-red
    host.raspberrypi object node-red.1 created
    host.raspberrypi object system.adapter.node-red.1.logLevel created
    host.raspberrypi object system.adapter.node-red.1.sigKill created
    host.raspberrypi object system.adapter.node-red.1.eventLoopLag created
    host.raspberrypi object system.adapter.node-red.1.outputCount created
    host.raspberrypi object system.adapter.node-red.1.inputCount created
    host.raspberrypi object system.adapter.node-red.1.uptime created
    host.raspberrypi object system.adapter.node-red.1.memRss created
    host.raspberrypi object system.adapter.node-red.1.memHeapTotal created
    host.raspberrypi object system.adapter.node-red.1.memHeapUsed created
    host.raspberrypi object system.adapter.node-red.1.cputime created
    host.raspberrypi object system.adapter.node-red.1.cpu created
    host.raspberrypi object system.adapter.node-red.1.compactMode created
    host.raspberrypi object system.adapter.node-red.1.connected created
    host.raspberrypi object system.adapter.node-red.1.alive created
    host.raspberrypi object system.adapter.node-red.1 created
    Process exited with code 0
    MOD-Edit: Code in code-tags gesetzt!
    fournierrf5
    @fournierrf5
    wie setzt man in code tags?
    • F fournierrf5
      @fournierrf5
      HomoranH Offline
      HomoranH Offline
      @fournierrf5 Text nach Anklicken des Icons </> statt der Worte code text einfügen
      F 1 Antwort Letzte Antwort
        @fournierrf5 sagte in node-red fenster nach update auf 2.4.0:
        Die Ausgabe von:
        @thomas-braun sagte in node-red fenster nach update auf 2.4.0:
        Wenn das System dann wieder läuft schau dir deinen ioBroker an:
        iobroker update -i
        würde mehr helfen
        EDIT:
        Wo kommt das log her?
        da scheinen Infos zu fehlen
        fournierrf5
        pi@raspberrypi:~ $ iobroker update -i
        Used repository: default
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 5.1.25   , installed 5.1.25
        Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
        Adapter    "discovery"     : 2.7.0    , installed 2.7.0
        Adapter    "harmony"       : 1.2.2    , installed 1.2.2
        Adapter    "info"          : 1.9.8    , installed 1.9.8
        Adapter    "javascript"    : 5.2.8    , installed 5.2.8
        Controller "js-controller" : 3.3.18   , installed 3.3.18
        Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
        Adapter    "node-red"      : 2.4.0    , installed 2.4.0
        Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
        pi@raspberrypi:~ $
        log was vom Installationsfenter im iobroker browser
        • F fournierrf5
          update done
          pi@raspberrypi:~ $
          HomoranH Offline
          HomoranH Offline
          mich wundert nur
          direkt am Anfang ohne zu sagen was da drin passiert sein soll
            fournierrf5
            statt der Worte?
            • F fournierrf5
              statt der Worte?
              HomoranH Offline
              HomoranH Offline
              statt der Worte?
              Ja
                statt der Worte?
                Ja
                fournierrf5
                statt welcher Worte denn?? Ich versteh nicht, sorry
                Ausserdem hab ich die beiden zeichen leider nicht auf der kleinen Funktatstatur hier
                • F fournierrf5
                  HomoranH Offline
                  HomoranH Offline
                  @homoran sagte in node-red fenster nach update auf 2.4.0:
                  das befindet sich über dem Texteingabefeld, nix Tastatur
                  nach dem Anklicken werden die Code-Tags gesetzt und die Woert code text als Platzhalter dazwischen eingeblendet
                    fournierrf5
                    downgrade auf node-red 2.3,x auch ohne Besserung
                    Mit node.js 10.xx läuft dann wieder alles...
                    F Thomas BraunT mickymM 3 Antworten Letzte Antwort
                    • F fournierrf5
                      fournierrf5
                      Hab keine Ideen mehr
                      • F fournierrf5
                        HomoranH Offline
                        HomoranH Offline
                        @fournierrf5 ich hatte dir eine Meldung zitiert.
                        Mir sagt diese Meldung nichts. Könnte aber der vermutete extern geladene node sein.
                        Deswegen wollte ich mehr Infos.
                          fournierrf5
                          das ist nur meine Kopie vom log, das kam vom raspi
                          • F fournierrf5
                            @fournierrf5
                            @mickym sagte:
                            Das sieht mir so aus, als ob Du irgendwelche Nodes nachinstalliert hast, die Probleme mache.
                            Da hab ich aber keine Ahnung von. Mach mal das was Micky oben empfohlen hat.
                            Vielleicht müssen die neu gegen node12 kompiliert werden?
                            • F fournierrf5
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @fournierrf5 ggf. nach Adapter Deinstallation halt das ganze /opt/iobroker/iobroker-data/node-red Verzeichnis löschen, da sind dann auch alle nodes und npm module, die mitinstalliert wurden definitiv weg.
                              Allerdings hat das dann nichts mit dem Alexa Adapter zu tun - der geht ja auch nicht - deswegen glaube ich nicht, dass es nur was mit Node Red zu tun hat.
                              • F fournierrf5
                                HomoranH Offline
                                HomoranH Offline
                                das kam vom raspi
                                natürlich - woher denn sonst.
                                meine Kopie vom log
                                und das log sagt dir was faul ist.
                                und das steht nun mal drin
                                  das kam vom raspi
                                  meine Kopie vom log
                                  fournierrf5
                                  #66
                                  sagt aus das was faul ist?
                                  Kannst du mehr dazu sagen, bitte?
                                  • F fournierrf5
                                    HomoranH Offline
                                    HomoranH Offline
                                    #67
                                    leider nein, das wollte ich ja von dir hören.
                                    ich dachhte da an diese Aussage
                                    @mickym sagte in node-red fenster nach update auf 2.4.0:
                                      fournierrf5
                                      #68
                                      sagt mir leider nichts, kenn keine node des mamens oder so.
                                      jetzt kann ich den Adapter nicht mal mer deinstallieren:
                                      $ iobroker del node-red
                                      Delete adapter "node-red"
                                      host.raspberrypi object node-red deleted
                                      host.raspberrypi object node-red.admin deleted
                                      Error deleting adapter node-red from disk: Error: Cannot find module 'iobroker.node-red/io-package.json'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.jsYou might have to delete it yourself!
                                      • F fournierrf5
                                        #69
                                        /src/bcrypt_node.cc
                                        Dürfte source-code in C geschrieben sein. Da wird es beim recompile klemmen. Das wird wie gesagt gegen node12 neugebaut werden müssen, denke ich. Aber da ich von node-red keinen Schimmer habe...
                                        Ich bin raus!
                                          /src/bcrypt_node.cc
                                          Ich bin raus!
                                          fournierrf5
                                          #70
                                          Woher hast du node12 und was ist dasss?
