  4. HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.
    6.3k
34 Beiträge 6 Kommentatoren 2.7k Aufrufe 5 Beobachtet
    dirkheider
    wollte de Adapter HomeMatic ReGaHSS 3.0.33 updaten. Irgandwie klappt es nicht so. Da ich noch Neuling bin, würde ich gerne hier mal Fragen. Danke Dirk
    Log sieht so aus:
    $ ./iobroker upgrade hm-rega
    Update hm-rega from @3.0.32 to @3.0.33
    NPM version: 8.1.2
    npm install iobroker.hm-rega@3.0.33 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.hm-rega@3.0.33.
    npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-11-04T12_49_36_871Z-debug.log
    upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
    Update "system.adapter.hm-rega.0"
    upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
    upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
    upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
    Adapter "hm-rega" updated
    process exited with code 0
    MOD-Edit: Code in code.tags gesetzt!
    HomoranH GlasfaserG 2 Antworten Letzte Antwort
    • D dirkheider
      Log sieht so aus:
      NPM version: 8.1.2
      @dirkheider sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
      wie?
      und warum diese Version?
      Die Meldung: notarget a package version that doesn't exist. sagt, dass es das Update nicht (über npm) gibt.
      Bitte ausgabe von
      iobroker update -i
      EDIT:
      laut Liste
      github:	3.0.32
      latest:	3.0.32 for 20 days
      stable:	3.0.31 for 84 days
      gibt es diese wirklich nicht
        wie?
        Bitte ausgabe von
        iobroker update -i
        EDIT:
        laut Liste
        github:	3.0.32
        dirkheider
        @homoran ahhh Okay
        Habe gedacht, weil der Admin Adapter mir dieses als Update anzeigt:-) Dann warte ich einfach etwas. Ich war irritiert, weil mir gestern (durch Rumbastelei) IOBroker abgeschmiert ist und ich es mit dem Backup wieder herstellen musste. Dachte es liegt vielleicht da dran.
        Danke für die Aufklärung
        Gruß Dirk
        • D dirkheider
          @homoran ahhh Okay
          Gruß Dirk
          hat er das?
          nochmals die Bitte
          @homoran sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
          Bitte ausgabe von
          iobroker update -i
          • D dirkheider
            Log sieht so aus:
            NPM version: 8.1.2
            GlasfaserG Offline
            GlasfaserG Offline
            NPM version: 8.1.2
            Nur mal so nebenbei ..... ist dein Node / NPM richtig denn NPM 8 ist nicht für ioBroker geeignet
            • BoronsbruderB Offline
              Boronsbruder
              Bei mir ist es dasselbe:
              Adapter    "hm-rega"       : 3.0.33   , installed 3.0.31 [Updateable]
              mit node
              v12.22.7
              und im Iobroker wird es auch als update angezeigt ;)
              • BoronsbruderB Boronsbruder
                mit node
                v12.22.7
                @boronsbruder sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                bitte komplette Ausgabe, nicht selektiv nur eine Zeile!
                mit node
                v12.22.7
                und npm -v
                BoronsbruderB 1 Antwort Letzte Antwort
                  mit node
                  v12.22.7
                  und npm -v
                  Boronsbruder
                  npm
                  6.14.15
                  /opt/iobroker$ iobroker update -i
                  Used repository: stable
                  hash unchanged, use cached sources
                  update done
                  Adapter    "admin"         : 5.1.25   , installed 5.1.25
                  Adapter    "backitup"      : 2.1.17   , installed 2.1.17
                  Adapter    "denon"         : 1.11.2   , installed 1.11.2
                  Adapter    "devices"       : 1.0.9    , installed 1.0.9
                  Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                  Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                  Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                  Adapter    "flot"          : 1.10.6   , installed 1.10.6
                  Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                  Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
                  Adapter    "ical"          : 1.11.4   , installed 1.11.4
                  Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                  Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
                  Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                  Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                  Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
                  Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                  Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                  Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                  Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                  Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
                  Adapter    "info"          : 1.9.8    , installed 1.9.8
                  Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                  Controller "js-controller" : 3.3.18   , installed 3.3.18
                  Adapter    "kodi"          : 2.0.5    , installed 2.0.7
                  Adapter    "logparser"     : 1.1.0    , installed 1.1.0
                  Adapter    "modbus"        : 3.4.14   , installed 3.4.14
                  Adapter    "moma"          : 1.2.9    , installed 1.2.9
                  Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                  Adapter    "nina"          : 0.0.25   , installed 0.0.25
                  Adapter    "node-red"      : 2.4.0    , installed 2.4.0
                  Adapter    "nut"           : 1.5.0    , installed 1.5.0
                  Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                  Adapter    "ping"          : 1.5.0    , installed 1.5.0
                  Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                  Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                  Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                  Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                  Adapter    "sql"           : 1.15.7   , installed 1.15.7
                  Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                  Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                  Adapter    "upnp"          : 1.0.19   , installed 1.0.19
                  Adapter    "vis"           : 1.4.4    , installed 1.4.4
                  Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                  Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                  Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                  Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                  Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                  Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                  Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                  Adapter    "vis-icontwo"   : 0.82.0   , installed 0.82.0
                  Adapter    "vis-inventwo"  : 3.2.0    , installed 3.2.0
                  Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                  Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                  Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                  Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                  Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                  Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                  Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                  Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                  Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                  Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                  Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
                  Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
                  Adapter    "web"           : 3.4.9    , installed 3.4.9
                    npm
                    6.14.15
                    update done
                    das wollte ich sehen!
                    ist schon seltsam, in der Liste steht noch 3.0.31 für stable und 3.0.32 für latest/Github
                    Es gab hier allerdings Issues mit einer Version (die Nummer habe ich nicht im Kopf) möglich, dass die zurückgezogen wurde
                    EDIT: oder genau anders herum ;-)
                    der Fehler soll mit der 3.0.32 aufgetreten sein und nach Downgrade auf die 3.0.31 wieder verschwunden
                    dann könnte die 3.0.33 der Fix sein.
                    Aber ich finde nichts
                    auf Github liegt definitiv die
                      "common": {
                        "name": "hm-rega",
                        "version": "3.0.32",
                        "news": {
                          "3.0.32": {
                        "common": {
                          "name": "hm-rega",
                          "news": {
                            "3.0.32": {
                      sigi234S Online
                      sigi234S Online
                      Ich habe die V 3.0.32 als Beta
                      Denke stabel ist Falsch
                      • sigi234S sigi234
                        @sigi234 sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                        sehe ich auch so - aber wieso??
                          sigi234S Online
                          sigi234S Online
                          Was sagt @foxriver76 dazu?
                          • sigi234S sigi234
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            schrieb am zuletzt editiert von foxriver76
                            @sigi234 mein Fehler falsch in stable eingetragen. Gerade ausgebessert, wird etwas dauern
                            Videotutorials & mehr
                            • foxriver76F foxriver76
                              @foxriver76 DANKE!
                                mit node
                                v12.22.7
                                GlasfaserG Offline
                                GlasfaserG Offline
                                mit node
                                v12.22.7
                                Das war ein Hinweis nur für @dirkheider
                                @glasfaser sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                                NPM version: 8.1.2
                                  Alles wieder gut??
                                  @all
                                  @foxriver76
                                  nach refresh der Seite Adapter wird jetzt im stable die 3.0.32 zum update angeboten.
                                  war das nicht die Version, die bei Ventilstellung 0,23 statt 23% angegeben hatte?
                                    Alles wieder gut??
                                    @all
                                    @foxriver76
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    @homoran ich habe keine offenen issues auf GitHub diesbezüglich und .32 ist die neuste Version -> mir ist nichts bekannt
                                      @foxriver76 sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                                      Mist :-(
                                      z.B. hier:
                                      https://forum.iobroker.net/topic/48543/darstellung-des-level-wertes-der-ventilöffnung-fehlerhaft/34?_=1636051632901
                                        Mist :-(
                                        z.B. hier:
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        @homoran ja doch da ging es um .31 und dann am Ende des threads ein issue, dafür ist ein fix in .32. falls immer noch existent bitte melden
                                        foxriver76F sigi234S 2 Antworten Letzte Antwort
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          Also im Issue ging es darum, dass Rega den 100 fachen wert schreibt. Hm-rpc skaliert aktuell nur wenn die UniT im Paramset 100% ist, rega hat vorher auch bei % skaliert. Jetzt wurde es harmonisiert.
                                          Ich weiß, dass es da allgemein offene issues in hm-rpc gibt, da manche Werte so semantisch nicht sinnig sind, ist allerdings eigentlich ein CCU Problem, wie und ob das gefixt wird durch mich muss ich noch überlegen. Das Skalierungsproblem gibt es seit Jahren und jedes Mal kommt irgendein anderer Edge Case der dann nicht mehr passt, weil im Endeffekt die CCU Blödsinn liefert.
                                          Allerdings sollten Rega und RPC jetzt immer gleich skalieren, sollte da einer mal 0.8 schreiben und der andere 80 stimmt was nicht.
