  4. HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.
    6.3k
34 Beiträge 6 Kommentatoren 2.7k Aufrufe 5 Beobachtet
    @boronsbruder sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
    Bei mir ist es dasselbe:
    Adapter "hm-rega" : 3.0.33 , installed 3.0.31 [Updateable]
    bitte komplette Ausgabe, nicht selektiv nur eine Zeile!
    mit node
    v12.22.7
    und npm -v
    BoronsbruderB Offline
    Boronsbruder
    npm
    6.14.15
    /opt/iobroker$ iobroker update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
    Adapter    "denon"         : 1.11.2   , installed 1.11.2
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
    Adapter    "flot"          : 1.10.6   , installed 1.10.6
    Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
    Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
    Controller "js-controller" : 3.3.18   , installed 3.3.18
    Adapter    "kodi"          : 2.0.5    , installed 2.0.7
    Adapter    "logparser"     : 1.1.0    , installed 1.1.0
    Adapter    "modbus"        : 3.4.14   , installed 3.4.14
    Adapter    "moma"          : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "nina"          : 0.0.25   , installed 0.0.25
    Adapter    "node-red"      : 2.4.0    , installed 2.4.0
    Adapter    "nut"           : 1.5.0    , installed 1.5.0
    Adapter    "openweathermap": 0.1.0    , installed 0.1.0
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "pushover"      : 2.0.5    , installed 2.0.5
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "snmp"          : 0.5.0    , installed 0.5.0
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "sql"           : 1.15.7   , installed 1.15.7
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
    Adapter    "upnp"          : 1.0.19   , installed 1.0.19
    Adapter    "vis"           : 1.4.4    , installed 1.4.4
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-icontwo"   : 0.82.0   , installed 0.82.0
    Adapter    "vis-inventwo"  : 3.2.0    , installed 3.2.0
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.9    , installed 3.4.9
    • BoronsbruderB Boronsbruder
      npm
      6.14.15
      update done
      das wollte ich sehen!
      ist schon seltsam, in der Liste steht noch 3.0.31 für stable und 3.0.32 für latest/Github
      Es gab hier allerdings Issues mit einer Version (die Nummer habe ich nicht im Kopf) möglich, dass die zurückgezogen wurde
      EDIT: oder genau anders herum ;-)
      der Fehler soll mit der 3.0.32 aufgetreten sein und nach Downgrade auf die 3.0.31 wieder verschwunden
      dann könnte die 3.0.33 der Fix sein.
      Aber ich finde nichts
      auf Github liegt definitiv die
        "common": {
          "name": "hm-rega",
          "version": "3.0.32",
          "news": {
            "3.0.32": {
          "common": {
            "name": "hm-rega",
            "news": {
              "3.0.32": {
        sigi234S Online
        sigi234S Online
        Ich habe die V 3.0.32 als Beta
        Denke stabel ist Falsch
        • sigi234S sigi234
          @sigi234 sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
          sehe ich auch so - aber wieso??
            sigi234S Online
            sigi234S Online
            @homoran sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
            Was sagt @foxriver76 dazu?
            • sigi234S sigi234
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              schrieb am zuletzt editiert von foxriver76
              @sigi234 mein Fehler falsch in stable eingetragen. Gerade ausgebessert, wird etwas dauern
              Videotutorials & mehr
              • foxriver76F foxriver76
                @foxriver76 DANKE!
                  mit node
                  v12.22.7
                  und im Iobroker wird es auch als update angezeigt ;)
                  GlasfaserG Offline
                  GlasfaserG Offline
                  mit node
                  v12.22.7
                  Das war ein Hinweis nur für @dirkheider
                  @glasfaser sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                  @dirkheider sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                  NPM version: 8.1.2
                  Nur mal so nebenbei ..... ist dein Node / NPM richtig denn NPM 8 ist nicht für ioBroker geeignet
                    Alles wieder gut??
                    @all
                    @foxriver76
                    nach refresh der Seite Adapter wird jetzt im stable die 3.0.32 zum update angeboten.
                    war das nicht die Version, die bei Ventilstellung 0,23 statt 23% angegeben hatte?
                      Alles wieder gut??
                      @all
                      @foxriver76
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      @homoran ich habe keine offenen issues auf GitHub diesbezüglich und .32 ist die neuste Version -> mir ist nichts bekannt
                        @foxriver76 sagte in HomeMatic ReGaHSS 3.0.33 lässt sich nicht updaten.:
                        Mist :-(
                        z.B. hier:
                        https://forum.iobroker.net/topic/48543/darstellung-des-level-wertes-der-ventilöffnung-fehlerhaft/34?_=1636051632901
                          Mist :-(
                          z.B. hier:
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          @homoran ja doch da ging es um .31 und dann am Ende des threads ein issue, dafür ist ein fix in .32. falls immer noch existent bitte melden
                          foxriver76F sigi234S 2 Antworten Letzte Antwort
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            Also im Issue ging es darum, dass Rega den 100 fachen wert schreibt. Hm-rpc skaliert aktuell nur wenn die UniT im Paramset 100% ist, rega hat vorher auch bei % skaliert. Jetzt wurde es harmonisiert.
                            Ich weiß, dass es da allgemein offene issues in hm-rpc gibt, da manche Werte so semantisch nicht sinnig sind, ist allerdings eigentlich ein CCU Problem, wie und ob das gefixt wird durch mich muss ich noch überlegen. Das Skalierungsproblem gibt es seit Jahren und jedes Mal kommt irgendein anderer Edge Case der dann nicht mehr passt, weil im Endeffekt die CCU Blödsinn liefert.
                            Allerdings sollten Rega und RPC jetzt immer gleich skalieren, sollte da einer mal 0.8 schreiben und der andere 80 stimmt was nicht.
                              und in der Meldung von der 32 waren es nur die Ventile die den 1/100 Wert schrieben, zurück auf 31 war es wieder gut
                              Scheint tatsächlich ein Problem der CCU zu sein, dass sogar einzelne Gerätelinien aus der Reihe tanzen.
                              Aber da war es eindeutig nach downgrade des hm-rega auf 31 behoben.
                              Ich hätte es nämlich auch auf den rpc schieben wollen
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                @homoran Frage hier was schreibt rpc im Vergleich?
                                  @foxriver76 Das ist ja der Witz.
                                  Das ist ein Datenpunkt vom rpc gewesen.
                                  Aber nach Downgrade ses rega war wieder gut
                                    sigi234S Online
                                    sigi234S Online
                                    Ja, habe ich in Issue ja erwähnt.
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      @homoran ja Rega schreibt bei Start doch alle rpc Punkte, schon klar dass es ein rpc Punkt ist. Mach doch mal history an für den dp und warte mal bis Rega und auch rpc den Punkt beschrieben haben und zeig mir das mal.
                                        @foxriver76 isch 'abe keine 'eizung!
                                        das müsste @sigi234 mal testen
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          Hoffe du hast genug Holz gekauft, wird kalt ;-)
