    6.5k
  • M MCU
    @stephan1827
    // Beispiel um eine JSONtable zu erstellen
    // https://forum.iobroker.net/topic/30668/jarvis-v2-2-0-just-another-remarkable-vis/5637
    let pvDP ='0_userdata.0.jarvis.pv.json';
    let aktDP ='0_userdata.0.jarvis.pv.setJSON';
    let schedDP = '0_userdata.0.jarvis.pv.setSchedule';
    createState(pvDP, {read: true, write: true, name: "PV Daten", type: "string", role: "text", def: "" });
    createState(aktDP, {read: true, write: true, name: "Daten aktualisieren", type: "boolean", role: "text", def: false });
    createState(schedDP, {read: true, write: true, name: "Scheduler setzen", type: "boolean", role: "text", def: false });
    let arrDP =''; // ArrayDP für PV
    let schedulePattern = '*/1 * * * *'; // alle x Minuten aktualisieren
    var schedule1;
    if (getState(schedDP).val){
       // Direkt neue Pattern wirken lassen, aber nur wenn aktiviert
       (function () {if (schedule1) {clearSchedule(schedule1); schedule1 = null;}})();
       schedule1 = schedule(schedulePattern, async function () {
           tableJSONSet();
    on({id: schedDP, change: "any"}, function (obj) {
       let value = obj.state.val;
       if (value){
               tableJSONSet();
       }else{
    on({id: aktDP, change: "any"}, function (obj) {
       if (value){
           tableJSONSet();
           setTimeout(function(){
               setStateDelayed(aktDP,false,3000,false);
           },2000);
    function tableJSONSet(){
       let jsonArr=[];
       // 1.Reihe
       let json = {};
       json.Title ="Titel";
       json.Aktuell = "Aktuell";
       json.Tag = "Tag";
       json.Woche = "Woche";
       json.Monat = "Monat";
       json.Jahr = "Jahr";
       jsonArr.push(json);
       let json1= {};
       json1.Title ="Verbrauch";
       json1.Aktuell = getState('0_userdata.0.testwert').val;
       json1.Tag = "";
       json1.Woche = "";
       json1.Monat = "";
       json1.Jahr = "";
       jsonArr.push(json1);
       let json2 = {};
       json2.Title ="PV";
       json2.Aktuell = getState('0_userdata.0.testwert').val;
       json2.Tag = "";
       json2.Woche = "";
       json2.Monat = "";
       json2.Jahr = "";
       jsonArr.push(json2);
       let json3 = {};
       json3.Title ="Laden";
       json3.Aktuell = getState('0_userdata.0.testwert').val;
       json3.Tag = "";
       json3.Woche = "";
       json3.Monat = "";
       json3.Jahr = "";
       jsonArr.push(json3);
       let json4 = {};
       json4.Title ="Entladen";
       json4.Aktuell = getState('0_userdata.0.testwert').val;
       json4.Tag = "";
       json4.Woche = "";
       json4.Monat = "";
       json4.Jahr = "";
       jsonArr.push(json4);
       let json5 = {};
       json5.Title ="Zukauf";
       json5.Aktuell = getState('0_userdata.0.testwert').val;
       json5.Tag = "";
       json5.Woche = "";
       json5.Monat = "";
       json5.Jahr = "";
       jsonArr.push(json5);
       let json6 = {};
       json6.Title ="Verkauf";
       json6.Aktuell = getState('0_userdata.0.testwert').val;
       json6.Tag = "";
       json6.Woche = "";
       json6.Monat = "";
       json6.Jahr = "";
       jsonArr.push(json6);
       let json7 = {};
       json7.Title ="EURO";
       json7.Aktuell = getState('0_userdata.0.testwert').val;
       json7.Tag = "";
       json7.Woche = "";
       json7.Monat = "";
       json7.Jahr = "";
       jsonArr.push(json7);
       log(JSON.stringify(jsonArr));
       setState(pvDP,JSON.stringify(jsonArr),false);
    Du musst dann die einzelnen Felder mit Deinen Daten füllen.
    So wie in dem Beispiel-DP: getState('0_userdata.0.testwert').val;
    Melde Dich, sobald du damit fertig bist.
    Du kannst entweder jederzeit eine neue Tabelle erzeugen mit setJSON->true, oder einen Scheduler laufen lassen. Dieser ist momentan auf 1 Minute eingestellt.
    stephan1827S Offline
    stephan1827
    #5648
    @mcu sagte in jarvis v2.2.0 - just another remarkable vis:
    // Beispiel um eine JSONtable zu erstellen // https://forum.iobroker.net/topic/30668/jarvis-v2-2-0-just-another-remarkable-vis/5637 // let pvDP ='0_userdata.0.jarvis.pv.json'; let aktDP ='0_userdata.0.jarvis.pv.setJSON'; let schedDP = '0_userdata.0.jarvis.pv.setSchedule'; createState(pvDP, {read: true, write: true, name: "PV Daten", type: "string", role: "text", def: "" }); createState(aktDP, {read: true, write: true, name: "Daten aktualisieren", type: "boolean", role: "text", def: false }); createState(schedDP, {read: true, write: true, name: "Scheduler setzen", type: "boolean", role: "text", def: false }); let arrDP =''; // ArrayDP für PV let schedulePattern = '*/1 * * * '; // alle x Minuten aktualisieren var schedule1; if (getState(schedDP).val){ // Direkt neue Pattern wirken lassen, aber nur wenn aktiviert (function () {if (schedule1) {clearSchedule(schedule1); schedule1 = null;}})(); schedule1 = schedule(schedulePattern, async function () { tableJSONSet(); }); } on({id: schedDP, change: "any"}, function (obj) { let value = obj.state.val; if (value){ (function () {if (schedule1) {clearSchedule(schedule1); schedule1 = null;}})(); schedule1 = schedule(schedulePattern, async function () { tableJSONSet(); }); }else{ (function () {if (schedule1) {clearSchedule(schedule1); schedule1 = null;}})(); } }); on({id: aktDP, change: "any"}, function (obj) { let value = obj.state.val; if (value){ tableJSONSet(); setTimeout(function(){ setStateDelayed(aktDP,false,3000,false); },2000); } }); function tableJSONSet(){ let jsonArr=[]; // 1.Reihe / let json = {}; json.Title ="Titel"; json.Aktuell = "Aktuell"; json.Tag = "Tag"; json.Woche = "Woche"; json.Monat = "Monat"; json.Jahr = "Jahr"; jsonArr.push(json); */ let json1= {}; json1.Title ="Verbrauch"; json1.Aktuell = getState('0_userdata.0.testwert').val; json1.Tag = ""; json1.Woche = ""; json1.Monat = ""; json1.Jahr = ""; jsonArr.push(json1); let json2 = {}; json2.Title ="PV"; json2.Aktuell = getState('0_userdata.0.testwert').val; json2.Tag = ""; json2.Woche = ""; json2.Monat = ""; json2.Jahr = ""; jsonArr.push(json2); let json3 = {}; json3.Title ="Laden"; json3.Aktuell = getState('0_userdata.0.testwert').val; json3.Tag = ""; json3.Woche = ""; json3.Monat = ""; json3.Jahr = ""; jsonArr.push(json3); let json4 = {}; json4.Title ="Entladen"; json4.Aktuell = getState('0_userdata.0.testwert').val; json4.Tag = ""; json4.Woche = ""; json4.Monat = ""; json4.Jahr = ""; jsonArr.push(json4); let json5 = {}; json5.Title ="Zukauf"; json5.Aktuell = getState('0_userdata.0.testwert').val; json5.Tag = ""; json5.Woche = ""; json5.Monat = ""; json5.Jahr = ""; jsonArr.push(json5); let json6 = {}; json6.Title ="Verkauf"; json6.Aktuell = getState('0_userdata.0.testwert').val; json6.Tag = ""; json6.Woche = ""; json6.Monat = ""; json6.Jahr = ""; jsonArr.push(json6); let json7 = {}; json7.Title ="EURO"; json7.Aktuell = getState('0_userdata.0.testwert').val; json7.Tag = ""; json7.Woche = ""; json7.Monat = ""; json7.Jahr = ""; jsonArr.push(json7); log(JSON.stringify(jsonArr)); setState(pvDP,JSON.stringify(jsonArr),false); }
    Danke, das bringt mich erstmal weiter
    stephan1827S 1 Antwort Letzte Antwort
    • stephan1827S stephan1827
      stephan1827
      schrieb am zuletzt editiert von stephan1827
      #5649
      Hier sind noch ein paar Fragen die heute beim Umbau meiner Solarseite aufgelaufen sind.
      Kann man bei dem Circle Chart die Zahl (81) ausblenden?
      Kann man die Farbe in Abhängigkeit von dem Wert ändern?
      Wie kann man die Reihenfolge der Widgets für das Reponsive Design ändern?
      Das hat irgendwie mit den Zahlen in den eckigen Klammern zu tun aber finder nirgends wo man die ändern kann.
        M Online
        M Online
        MCU
        #5650
        @stephan1827 sagte in jarvis v2.2.0 - just another remarkable vis:
        Ist in Planung.
        Wie kann man beim historischen Charts zwei Y- Achsen definieren?
        https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/historygraph
        Bzgl Circle Chart brauch ich eine Info:
        Zeig mir bitte das Widget mit den Eintragungen.
        Ich habe keine Möglichkeit gefunden, die Zahl im Circle zu beeinflussen.
        Im "Chart" fehlt eine Einstellungsmöglichkeit, wie im "HistoryGraph".
        Vielleicht kann/möchte @zefau eine Option einbauen: Show Value (on/off)
        stephan1827S 2 Antworten Letzte Antwort
        • M MCU
          Ist in Planung.
          stephan1827
          #5651
          Das Widget sieht so aus
          Man kann zwar die Legende ausblenden aber nicht den Zahlenwert in der Mitte
          M R 2 Antworten Letzte Antwort
            M Online
            M Online
            MCU
            #5652
            @stephan1827 Wie klappt es mit der Tabelle?
              RkcCorian
              schrieb am zuletzt editiert von RkcCorian
              #5653
              @stephan1827 Alternativ Grafana über iFrame einbinden. So mache ich es.
              Bpsw.
              Oder auch
              • M MCU
                @alex975 VPN nutzen. Bei der FritzBox gibt es z.B. die FritzApp mit der man direkt ein VPN starten kann.
                Alex975
                #5654
                @mcu vpn scheitern leider bei mir an einer nicht vorhandenen öffentlichen IP4 Adresse.. Deswegen nutze ich ja bereits den iobroker cloud pro Zugang um so z.b. das habpanel aufzurufen...
                I stephan1827S 2 Antworten Letzte Antwort
                • A Alex975
                  I Offline
                  I Offline
                  io_laurent
                  schrieb am zuletzt editiert von io_laurent
                  #5655
                  @alex975 Ich mache das auf einem iPhone mit der iobroker-app (gibts gratis im app-store). Dort bei Adapter-Name Jarvis eintragen, entsprechende ip vergeben und cloud-Zugangsdaten eintragen. Funktioniert.
                  Für Android gibts sowas sicher auch, kenn ich mich aber nicht aus.
                  • I io_laurent
                    M Online
                    M Online
                    MCU
                    #5656
                    @io_laurent Kannst du mal bitte ein paar Bilder der App reinstellen? Danke.
                    In Android finde ich nur die ioBroker.vis.
                    I 1 Antwort Letzte Antwort
                    • M MCU
                      stephan1827
                      #5657
                      @mcu Danke, funktioniert
                      Schriftgröße muss ich noch anpassen aber das finde ich schon...
                      • A Alex975
                        stephan1827
                        #5658
                        @alex975 Um eine feste Adresse zu bekommen gibt es mittlerweile viel Möglichkeiten. Worauf läuft denn Dein iobroker?
                          M Online
                          M Online
                          MCU
                          #5659
                          @stephan1827 In der Doku:
                          Nee, das war für die Historygraph.
                          • M MCU
                            I Offline
                            I Offline
                            io_laurent
                            #5660
                            @mcu Also hier die app: https://apps.apple.com/de/app/iobroker/id1449564305
                            Bilder aus der App wären Bilder von Jarvis ;-)
                            Ich kann aber Bilder der Einstellungen zeigen:
                            R 1 Antwort Letzte Antwort
                            • I io_laurent
                              RkcCorian
                              #5661
                              @io_laurent Hmmm.. sieht anders aus als die Android-App. Hab als Lösung aktuell Fully im Einsatz. Weiß man was ob das auch (jetzt oder später) bei der Android-App möglich sein wird?
                              • M MCU
                                stephan1827
                                #5662
                                @mcu Achso, ja der läuft auch, cool wäre natürlich wenn man auch die ganzen anderen Einstellungen über JSON beeinflussen könnte und nicht nur Y und X Achse. Grafana ist natürlich auch eine Option aber ich mache aktuell iframes mit Graphen und ich möchte das nativ mit Jarvis machen.
                                Stephan
                                  Stephan
                                  M Online
                                  M Online
                                  MCU
                                  #5663
                                  @stephan1827
                                  Zur Schriftgröße im jsonTable
                                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/jsontable/v3.x.x/parameter-style
                                  • M MCU
                                    @stephan1827
                                    stephan1827
                                    #5664
                                    @stephan1827
                                    Ich habe es so probiert aber das funktioniert nicht.
                                    .q-table tr {
                                            height:100px;
                                    	font-size: 22px;
                                    Bei der Titelzeile funktioniert height aber bei den Reihen anscheinend nicht
                                      @stephan1827
                                      .q-table tr {
                                              height:100px;
                                      	font-size: 22px;
                                      M Online
                                      M Online
                                      MCU
                                      #5665
                                      @stephan1827 Für die Zeilen musst du es in die Definition setzen.
                                      Es funktioniert mit CSS nur für den Header
                                      .q-table th {
                                        font-size: 22px;
                                      Tabellendefinition siehe Doku:
                                      [{"field":"Nr","label":"Nr","style":"font-size:20px"},{"label":"ZEIT"},{"label":"KANAL"},{"label":"TITEL"}]
                                      Doku funktioniert gerade nicht so richtig.
                                      Wichtig ist, dass zu jedem Feld, was man mit dem Style beeinflussen möchte, der "field"-Parameter gesetzt wird.
                                      Geht auch mit CSS:
                                      .q-table .q-td {
                                         font-size: 22px;
                                        Alex975
                                        #5666
                                        @stephan1827 der läuft auf nem nuc und proxmox
                                        • O OliWit82
                                          @zefau
                                          Das kommt da
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #5667
                                          @oliwit82 sagte in jarvis v2.2.0 - just another remarkable vis:
                                          Das kommt da
                                          Also im Backend hast du sql.0 gewählt, aber im Frontend ist es history.0. Kannst du mal im JSON schauen, was dort drin steht?
                                          Kannst du nochmal sql.0 auf etwas anderes umstellen, wieder zurückstellen und neu speichern?
                                          O 1 Antwort Letzte Antwort
