Test Adapter bluelink - Hyundai (Bluelink) oder KIA (UVO)
hab heute nochmal was aufgeräumt und paar Datenpunkte hinzugefügt. Bitte testet mal ob nun alles stabil funktioniert dann würde ich gerne die neusten Änderungen zur stable bringen.
Version 2.1 wurde veröffentlicht.
@newan Hi,
hab die 2.1.0 installiert, mir sind 2 Dinge aufgefallen:- nach dem installieren kamen folgende Warnings im Log:
2021-10-31 10:23:48.790 - info: bluelink.0 (3571905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-31 10:23:50.328 - info: host.VMC123-iobroker instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-31 10:23:50.545 - info: host.VMC123-iobroker iobroker upload [4] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/style.css style.css text/css 2021-10-31 10:23:50.603 - info: host.VMC123-iobroker iobroker upload [3] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/index_m.html index_m.html text/html 2021-10-31 10:23:50.659 - info: host.VMC123-iobroker iobroker upload [2] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink_old.png bluelink_old.png image/png 2021-10-31 10:23:50.718 - info: host.VMC123-iobroker iobroker upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png 2021-10-31 10:23:50.771 - info: host.VMC123-iobroker iobroker upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/admin.d.ts admin.d.ts video/mp2t 2021-10-31 10:23:50.822 - info: host.VMC123-iobroker iobroker Adapter "bluelink" updated 2021-10-31 10:23:52.658 - info: host.VMC123-iobroker instance system.adapter.bluelink.0 started with pid 861686 2021-10-31 10:23:57.947 - info: bluelink.0 (861686) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v14.18.1, js-controller: 3.3.18 2021-10-31 10:23:57.969 - info: bluelink.0 (861686) Login to api 2021-10-31 10:24:03.216 - info: bluelink.0 (861686) 1 Vehicles found 2021-10-31 10:24:19.847 - warn: bluelink.0 (861686) State "bluelink.0.vehicleStatus.doorLock" has no existing object, this might lead to an error in future versions 2021-10-31 10:24:19.852 - warn: bluelink.0 (861686) State "bluelink.0.vehicleStatus.trunkOpen" has no existing object, this might lead to an error in future versions 2021-10-31 10:24:19.856 - warn: bluelink.0 (861686) State "bluelink.0.vehicleStatus.hoodOpen" has no existing object, this might lead to an error in future versions- nach dem Update waren die Datenpunkte "Vehiclestatus/... " im Hauptverzeichnis, und nicht unter der FIN untergeordnet.
@newan Hi,
@ilovegym das hatte ich schon korrigiert lösche die states manuell und installiere nochmal neu
Hallo in die Runde, kann inzwischen Jemand die Frage beantworten ob man über den Adapter Zugriff hat obwohl man über die App eingeloggt ist?
Bei mir geht es noch immer nicht mit dem Adapter, und wenn es nicht parallel zur App geht dann wäre es für nicht nicht wirklich hilfreich.
Danke euch -
Danke euch@sonnenkind keine Probleme mit beidem.
@ilovegym sehr schön dann kann ich jetzt mal versuchen zu lösen warum ich immer noch diese dämliche Meldung im log habe und es daher keine Daten gibt, was ich aber irgendwie nicht verstehe ?
ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"928d5815-02b3-4b5a-9836-5ef9b3ea9b5f","errCode":"4003","errMsg":"Invalid values"} -
ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"928d5815-02b3-4b5a-9836-5ef9b3ea9b5f","errCode":"4003","errMsg":"Invalid values"}@sonnenkind installier die aktuell Version Via github da wurde nochmal am Login was geändert
ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"928d5815-02b3-4b5a-9836-5ef9b3ea9b5f","errCode":"4003","errMsg":"Invalid values"}@sonnenkind mach heute Abend noch eine 2.1.1 tombox hat gemeldet das ein update der verwendeten lib gibt.
danke , dir dann mach ich es morgen und installier es neu , bin gesannt.
Weiß jemand hier zufällig welchen Provider Hyundai verwendet um das Auto mit dem Hyundai server zu verbinden? -
Weiß jemand hier zufällig welchen Provider Hyundai verwendet um das Auto mit dem Hyundai server zu verbinden?Vodafone
Vodafone
@ilovegym das erklärt warum teilweise bei mir im Auto keine Sprachbefehle verfügbar sind und warum in meiner Garage auch keine Daten mehr vom Auto kommen, wir sind hier eher ländlich und da ist vf eher scheiße ,.... da wäre t mobil deutlich im Vorteil bin mir sicher da man das nicht ändern kann weil es von Hyundai geblockt wird, oder hat auch hier jemand ne Idee oder erfahrung, würde ja zur not noch selbst ne Karte für die Daten zahlen...
@sonnenkind musste mal bei deinem Haendler fragen, ob du die Karte tauschen kannst.. ob das ueberhaupt geht..
Und klar, Garage, Tiefgarage, etc sind sowieso tote Gebiete.
so hab jetzt die Version 211 installiert, leider gleiche Fehlermeldung, langsam verstehe ich es nicht mehr. wenn die Meldung was mit dem log in zu tun hat kann es nicht sein, die gleichen Parameter gebe ich in der App ein und es geht, ist auch die aktuelle App Version, auto ist erst 2 Wochen da und in der App geht alles ;-(( bin jetzt etwas ratlos
Also du hast Adapter V2.1.1 frisch von Git gezogen, dein System selbst ist auf Beta und aktuell, js-controller.. etc..?
Node und NPM Version?Du hast auch die aktuelle Bluelink App, nicht die alte?
Hier mal n Screenshot von meiner Config. Wenn bei dir alles auch so eingestellt ist, dann mal bitte ein komplettes Logfile vom starten des Adapters ...
Hallo, gibt es inzwischen etwas Neues zum Thema "mehrere Autos in einem Konto"? Wir haben zwei Konas und beide sind im gleichen Bluelink Konto erfasst.. Danke!
(sorry ich habe versucht den Bezug zu ilovegym wegzulöschen, geht aber irgendwie nicht) -
(sorry ich habe versucht den Bezug zu ilovegym wegzulöschen, geht aber irgendwie nicht)@christianf ja in der aktuellen github Version
@newan Bei mir tut alles soweit, habe einen Hyundai Ioniq Facelift.
Bin auch ein wenig am VIS bauen (gemeinsame Benutzung von bluelink.0 und easee.0)
@michaelnorge
Kannst du mir deine schöne VIS zur Verfügung stellen ? -
@ilovegym Hey, sorry für die späte Info,
meine Daten sind aktuell , System soweit ich sehe auch
NPM:6.14.15
Node JS .v12.22.6
js-controller' is 3.3.15Version von BL ist us Gh gezogen
v2.1.1
App ist die aktuelle, was ich im Kennwort habe ist ein"-" Zeichen, ob das eventuell noch ein Problem sein könnte?Die Config sieht aus wie Deine, also alles gleich,
