  4. Tuya Thermostat (_TZE200_hue3yfsn)
62 Beiträge 8 Kommentatoren 18.0k Aufrufe 11 Beobachtet
  • D diti
    @asgothian
    Ich weiß, habe nur diese, rückgängig kann man auch machen habe ich schon probiert.
    ich habe im Github Forum externen Converter von kvazis gefunden die Data Points sind identisch, der Converter aber für HA gemacht. Ich habe da kleine Anpassungen gemacht , Temperatur einstellen funktioniert zwar aber Rückmeldung von TRV kommt nicht, was ist falsch ?
    /// Based on:
    // https://gist.github.com/basveeling/96ff0f16cd7185b0277a26c8d9305633
    // https://github.com/Koenkk/zigbee-herdsman-converters/issues/1803
    // https://github.com/Koenkk/zigbee-herdsman-converters/pull/2209
    //https://gist.github.com/serrj-sv/af142b25de2d7ac54c3a2eb2623d9a6d#file-moes_radiator_alt-js-L328
    //// Credits:
    // @serrj-sv, @wollo, @basveeling
    //// Usage:
    // zzonesmart_tvg01zg.js in the root of your zigbee2mqtt data folder (as stated in data_path, e.g. /config/zigbee2mqtt_data)
    // In your zigbee2mqtt hassio addon configuration, add the following two lines:
    // external_converters:
    //   - zzonesmart_tvg01zg.js
    const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
    const tz = require('zigbee-herdsman-converters/converters/toZigbee');
    const tuya = require('zigbee-herdsman-converters/lib/tuya');
    const exposes = require('zigbee-herdsman-converters/lib/exposes');
    const reporting = require('zigbee-herdsman-converters/lib/reporting');
    const e = exposes.presets;
    const ea = exposes.access;
    const tuyaLocal = {
    	dataPoints: {
        // ZONNSMART
        zsHeatingSetpoint: 16,
        zsFrostDetection: 10,
        zsWindowDetection: 8,
        zsChildLock: 40,
        zsTempCalibration: 27,
        zsLocalTemp: 24,
        zsBattery: 35,
        zsHeatingBoostCountdown: 101,
        zsComfortTemp: 104,
        zsEcoTemp: 105,
        zsAwayTemp: 32,
        zsErrorStatus: 45,
        zsMode: 2,
        zsHeatingStop: 107,
    const fzLocal = {
        zs_thermostat: {
            cluster: 'manuSpecificTuya',
            type: ['commandGetData', 'commandSetDataResponse'],
            convert: (model, msg, publish, options, meta) => {
                const dp = msg.data.dp;
                const value = tuya.getDataValue(msg.data.datatype, msg.data.data);
                // if (dp >= 101 && dp <=107) return; // handled by tuya_thermostat_weekly_schedule
                switch (dp) {
                case tuya.dataPoints.state: // on/off
                    return !value ? {system_mode: 'off'} : {};
                case tuyaLocal.dataPoints.zsChildLock:
                    return {child_lock: value ? 'LOCK' : 'UNLOCK'};
                case tuyaLocal.dataPoints.zsHeatingSetpoint:
                    return {current_heating_setpoint: (value / 10).toFixed(1)};
                case tuyaLocal.dataPoints.zsLocalTemp:
                    return {local_temperature: (value / 10).toFixed(1)};
                case tuyaLocal.dataPoints.zsBattery:
                     return {battery: value};
                case tuyaLocal.dataPoints.zsTempCalibration:
                    return {local_temperature_calibration: value > 55 ?
                        ((value - 0x100000000)/10).toFixed(1): (value/ 10).toFixed(1)};
                case tuyaLocal.dataPoints.zsHeatingBoostCountdown:
                    return {heating_boost_countdown: value};
                case tuyaLocal.dataPoints.zsWindowDetection:
                    return {window_detection: value ? 'ON' : 'OFF'};
                case tuyaLocal.dataPoints.zsComfortTemp:
                    return {comfort_temperature: (value / 10).toFixed(1)};
                case tuyaLocal.dataPoints.zsEcoTemp:
                    return {eco_temperature: (value / 10).toFixed(1)};
                case tuyaLocal.dataPoints.zsAwayTemp:
                    return {away_preset_temperature: (value / 10).toFixed(1)};
                case tuyaLocal.dataPoints.zsMode:
                    switch (value) {
                    case 1: // manual
                        return {system_mode: 'heat', away_mode: 'OFF', preset: 'manual'};
                    case 3: // away
                        return {system_mode: 'heat', away_mode: 'ON', preset: 'vacation'};
                    case 0: // auto
                        return {system_mode: 'auto', away_mode: 'OFF', preset: 'schedule'};
                    default:
                        meta.logger.warn('zigbee-herdsman-converters:zsThermostat: ' +
                            `preset ${value} is not recognized.`);
                        break;
                    break;
                case tuya.dataPoints.runningState:
                    return {running_state: value ? 'heat' : 'idle'};
                default:
                    meta.logger.warn(`zigbee-herdsman-converters:zsThermostat: Unrecognized DP #${
                        dp} with data ${JSON.stringify(msg.data)}`);
    const tzLocal = {
        zs_thermostat_child_lock: {
            key: ['child_lock'],
            convertSet: async (entity, key, value, meta) => {
                await tuya.sendDataPointBool(entity, tuyaLocal.dataPoints.zsChildLock, value === 'LOCK');
        zs_thermostat_window_detection: {
            key: ['window_detection'],
                await tuya.sendDataPointBool(entity, tuyaLocal.dataPoints.zsWindowDetection, value === 'ON');
        zs_thermostat_current_heating_setpoint: {
            key: ['current_heating_setpoint'],
                const temp = Math.round(value * 10);
                await tuya.sendDataPointValue(entity, tuyaLocal.dataPoints.zsHeatingSetpoint, temp);
        zs_thermostat_comfort_temp: {
            key: ['comfort_temp_preset'],
                await tuya.sendDataPointValue(entity, tuyaLocal.dataPoints.zsComfortTemp, temp);
        zs_thermostat_away_temp: {
            key: ['away_preset_temperature'],
                await tuya.sendDataPointValue(entity, tuyaLocal.dataPoints.zsAwayTemp, temp);
        zs_thermostat_eco_temp: {
            key: ['eco_temp_preset'],
                await tuya.sendDataPointValue(entity, tuyaLocal.dataPoints.zsEcoTemp, temp);
        zs_thermostat_system_mode_preset: {
            key: ['preset'],
                const lookup = {'schedule': 0, 'manual': 1, 'holiday': 3};
                await tuya.sendDataPointEnum(entity, tuyaLocal.dataPoints.zsMode, lookup[value]);
        zs_thermostat_local_temperature_calibration: {
            key: ['local_temperature_calibration'],
                if (value > 0) value = value*10;
                if (value < 0) value = value*10 + 0x100000000;
                await tuya.sendDataPointValue(entity, tuyaLocal.dataPoints.zsTempCalibration, value);
    const device = {
        // Moes Tuya Alt Thermostat
        zigbeeModel: ['TS601'],
        fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_e9ba97vf'}],
        model: 'TV01-ZG',
        vendor: 'ZONNSMART',
        description: 'Radiator valve with thermostat',
        fromZigbee: [
            fz.ignore_basic_report,
            fz.ignore_tuya_set_time,  // handled in onEvent
            fzLocal.zs_thermostat,
            // fz.tuya_data_point_dump,
        toZigbee: [
            tzLocal.zs_thermostat_current_heating_setpoint,
            tzLocal.zs_thermostat_child_lock,
            tzLocal.zs_thermostat_comfort_temp,
            tzLocal.zs_thermostat_eco_temp,
            tzLocal.zs_thermostat_system_mode_preset,
            tzLocal.zs_thermostat_local_temperature_calibration,
            tzLocal.zs_thermostat_away_temp,
            tzLocal.zs_thermostat_window_detection,
            tzLocal.zs_thermostat_heatingBoostCountdown,
            tz.tuya_data_point_test
        onEvent: tuya.onEventSetLocalTime,
        meta: {
            configureKey: 1,
        configure: async (device, coordinatorEndpoint, logger) => {
            const endpoint = device.getEndpoint(1);
            await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
        exposes: [
            e.battery(), e.window_detection(), e.child_lock(), e.comfort_temperature(), e.eco_temperature(), e.away_preset_temperature(),
            exposes.climate().withSetpoint('current_heating_setpoint', 0.5, 29.5, 0.5)
                             .withLocalTemperature()
                             .withLocalTemperatureCalibration()
                             .withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET) //system mode only: off, heat, auto
                             .withPreset(['schedule', 'manual', 'holiday']),
            exposes.numeric('heating_boost_countdown', ea.STATE)
    module.exports = device;
    @diti
    Thx. Konnte nun endlich mein Thermostat in Betrieb nehmen und bisher bin ich voll zufrieden und kann eigentlich nicht finden was nicht funktioniert. Nach dem Pairing ging alles "Out of the Box" mit Adapter 1.6.3.:
    An 2 Punkten habe ich noch Fragezeichen:
    • Wo liegt der Unterschied im Preset Mode "Manual" oder z.B. "Comfort"?
      In Beiden kann ich nur die Target Temperature setzen und nicht die Ventilstellung.
    • Wenn ich über den Preset Punkt "schedule" nachdenke ihn zu nutzen, gibt es die Möglichkeit die Programme/Einstellungen per Zigbee zu programmieren und auszulesen? Am Ventil dies einzustellen ist ja richtig fummelig.
    AsgothianA D 2 Antworten Letzte Antwort
      @diti
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @pete0815 sagte in Tuya Thermostat (_TZE200_hue3yfsn):
      Lies mal hier: https://github.com/ioBroker/ioBroker.zigbee/issues/1244
      Die genaue Syntax der Daten die du hin schickst must Du dir bei zigbee2mqtt.io anschauen.
      A,
      • AsgothianA Asgothian
        A,
        @asgothian
        Vielen Dank! Da kann ich mir viel abgucken. Da ich mir nichts "zerschießen" möchte und ich es noch nicht gemacht habe, wie schicke ich die Daten zum Gerät?
        Über das Developer Menü im Adapter und z.B. diese Daten dann im Experten-Modus bei JSON versenden?
        sendTo('zigbee.0', 'SendToDevice', {'device':'5c0272fffedc3017', 'payload':{
        "schedule": {
        "workdays": [
        "hour": 6,
        "minute": 0,
        "temperature": 19
        "hour": 8,
        "minute": 0,
        "temperature": 21
        "hour": 18,
        "minute": 0,
        "temperature": 21
        "hour": 20,
        "minute": 30,
        "temperature": 20
        "hour": 22,
        "minute": 0,
        "temperature": 19
        "hour": 23,
        "minute": 0,
        "temperature": 17
        }}, function(res) {
        if (res.success)
        console.log("success")
        else
        console.log(res.error);
          @asgothian
          "schedule": {
          "workdays": [
          "hour": 6,
          "minute": 0,
          "temperature": 19
          "hour": 8,
          "minute": 0,
          "temperature": 21
          "hour": 18,
          "minute": 0,
          "temperature": 21
          "hour": 20,
          "minute": 30,
          "temperature": 20
          "hour": 22,
          "minute": 0,
          "temperature": 19
          "hour": 23,
          "minute": 0,
          "temperature": 17
          }}, function(res) {
          if (res.success)
          else
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @asgothian
          Zerschiessen kannst du da nichts.
          Du musst den Code in ein JS Skript (oder dir ein entsprechendes Blockly Skript bauen) einbauen und das Skript einmal laufen lassen.
          Über den Entwickler Modus geht bei den TuYa wenig.
          A.
            @asgothian
            A.
            @asgothian
            Danke, da hätte ich noch lange an falscher Stelle gesucht 😂
              @diti
              diti
              bei mir geht die Ventilstellung-Steuerung auch nicht laut der Liste
              diese Thermostate haben kein Data Point ID um das zu steuern.
              Die Preset Mode ( 'manual', 'boost', 'complex', 'comfort', 'eco') benutze ich nicht, ich hab noch Werkeinstellungen. Ich hab bei mir einige Blockly Skripte laufen: ein Skript zum Beispiel in Interval 20 min. überprüft ob die Fenster geöffnet oder geschlossen sind, Uhrzeit und steuert entsprechend target_temperatur.
              Im Bild mit Device Information was du gepostet hast steht manufacturerName: '_TZE200_cwnjrr72 warum?
              Ich hab bei mir solche:5555.PNG
              Was hast du geändert oder ist das der originale Name von Thermostat?
              • D diti
                @diti said in Tuya Thermostat (_TZE200_hue3yfsn):
                ok
                Nutzen möchte ich das auch im Moment nicht. Da ich den Sinn noch nicht ganz verstehe dieser Presets, möchte ich wenigstens vermeiden, dass ich mit Blocklys gegen die interne Regelung des Ventils "ankämpfe".
                Das wurde orginal nach dem Pairing so gesetzt. Habe nichts verändert.
                  ok
                  diti
                  @pete0815
                  dann sind deine Thermostate in zigbee2mqtt eingepflegt, du musst gar nicht verändern, probier Mal die in Home Assistant da kannst du eventuell mehr Funktionen herausholen.
                  ? arteckA 2 Antworten Letzte Antwort
                  • D diti
                    @pete0815
                    @diti
                    bin aufm Sprung in den Urlaub und schaue ich danach mal.
                    Im Moment funktioniert aber eigentlich alles und eine Erklärung um die Programme per Zigbee zu setzen gab es nettwerweise auch. Im Prinzip fehlt mir nix :)
                    • D diti
                      @pete0815
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @diti sagte in Tuya Thermostat (_TZE200_hue3yfsn):
                      was willst du da mehr rausholen.. die greifen auch auf die gleiche Basis drauf.. z2m projekt
                      • B bluefish
                        Weiß jemand, wie man ein converter file (z.B. https://github.com/PeWu/tuya-valve-z2m/blob/main/tuya_radiator_valve.js) im iobroker hinzufügt?
                        bluefish
                        schrieb am zuletzt editiert von bluefish
                        Hier die Beantwortung meiner eigenen Frage, vielleicht hat ja noch jemand die Frage zur Einbindung von converter files im iobroker...
                        1. Man besorgt sich ein converter file für das nicht unterstützte Gerät. Ich habe dieses gefunden: https://github.com/PeWu/tuya-valve-z2m/blob/main/tuya_radiator_valve.js
                          Funktioniert zwar nicht alles, aber setpoint, mode und child lock funktionieren, mehr hoffentlich bald
                        2. Man legt das converter file (tuya_radiator_valve.js) zum Beispiel mit ftp irgendwo auf dem Pi ab. Ich habe dies einfach mal ins Verzeichnis /opt/iobroker/iobroker-data/ gelegt.
                        3. Im iobroker Adapter gibt es unter dem Punkt Einstellungen eine Rubrik "External converters", ganz am Ende der Seite. Dort gibt man den Pfad zur .js Datei an.
                        4. Adapter neu starten und _TZE200_hue3yfsn neu pairen. Anschließend wird das Gerät gefunden und hinzugefügt:
                        M.M.n. die bessere Lösung gegenüber der Lösung von @diti mit der Modifikation von /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js und /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js
                          diti
                          @bluefish danke für deine Anleitung, leider wenn ich externen Converter benutze, bekomme ich von den Thermostaten keine Rückmeldung also keine locale Temperatur, ich hab verschiedene ausprobiert und mit immer gleichem Ergebnis. Auf Bildern von dir current Temperatur auch unbekannt, geht das?
                          Mittlerweile habe ich andere "Mitfahrgelegenheit" für Thermostat (_TZE200_hue3yfsn) gefunden, und zwar bei TV01-ZB von Moes. Alle Data Point ID sind mit unserem identisch und alle steuerbar, Rückmeldung von TRV ist auch vorhanden, das heißt man muss nicht in /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js Anpassungen machen sondern in /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/moes.js Thermostat-Name {modelID: 'TS0601', manufacturerName: '_TZE200_hue3yfsn'} einfügen.
                          fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_e9ba97vf'}, {modelID: 'TS0601', manufacturerName: '_TZE200_hue3yfsn'}],
                                  model: 'TV01-ZB',
                                  vendor: 'Moes',
                                  description: 'Thermostat radiator valve',
                                  fromZigbee: [fz.moes_thermostat_tv, fz.ignore_tuya_set_time],
                                  toZigbee: [tz.moes_thermostat_tv],
                          TV01-ZB ist frisch in zigbee4mqtt integriert, deswegen musst ihr Zigbee-Adapter oder zigbee-herdsmann-converters aktualisieren, bei mir steht nämlich v1.6.4.
                          Nicht vergessen alle gemachte Änderungen und Anpassungen in
                          /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js und in /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js wieder rückgängig machen, oder die werden mit Aktualisierung überschrieben.
                          • D diti
                                    model: 'TV01-ZB',
                                    vendor: 'Moes',
                            bluefish
                            @diti Danke für deinen Tipp mit dem Moes.
                            Damit lässt sich easy ein externer Converter basteln, der den Vorteil hat, dass man nicht in den node_modules herumwerkeln muss und es überlebt updates...
                            Hier ein bei mir funktionierender Code auf basis des Moes _TZE200_e9ba97vf Thermostats.
                            Abspeichern als z.B. tuya_radiator_valve.js, irgendwo auf den Pi speichern und Pfad+Dateiname in den iobroker Einstellungen hinterlegen.
                            const fz = {...require('zigbee-herdsman-converters/converters/fromZigbee'), legacy: require('zigbee-herdsman-converters/lib/legacy').fromZigbee};
                            const globalStore = require('zigbee-herdsman-converters/lib/store');
                            const device = {
                                fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_hue3yfsn'}],
                                model: 'TS0601',
                                vendor: 'Tuya',
                                exposes: [
                                    e.battery(),
                                    // e.child_lock(),
                                    // e.window_detection(),
                                    // exposes.binary('frost_detection', ea.STATE_SET, true, false).withDescription('Enables/disables frost detection on the device'),
                                    exposes.binary('heating_stop', ea.STATE_SET, true, false).withDescription('Stop heating'),
                                    exposes.numeric('holiday_temperature', ea.STATE_SET).withDescription('Holiday mode temperature'),
                                    exposes.numeric('comfort_temperature', ea.STATE_SET).withDescription('Comfort mode temperature'),
                                    exposes.numeric('eco_temperature', ea.STATE_SET).withDescription('Eco mode temperature'),
                                    exposes.numeric('open_window_temperature', ea.STATE_SET).withDescription('Open window mode temperature'),
                                    // exposes.numeric('boost_heating_countdown', ea.STATE).withDescription('Boost heating countdown'),
                                    // exposes.numeric('error_status', ea.STATE).withDescription('Error status'),
                                    // exposes.binary('boost_mode', ea.STATE_SET).withDescription('Enables/disables boost mode'),
                                    exposes.climate().withSetpoint('current_heating_setpoint', 5, 29.5, 1, ea.STATE_SET)
                                        .withLocalTemperature(ea.STATE).withLocalTemperatureCalibration(ea.STATE_SET)
                                        .withSystemMode(Object.values(tuya.tvThermostatMode), ea.STATE_SET)
                                        .withPreset(Object.values(tuya.tvThermostatPreset)),
                            Ergebnis:
                            Child_lock, window_detection, frost_detection, boost_mode und error_status funktionieren bei mir nicht, daher habe ich es auskommentiert. Sollten bei deiner Methode @diti eigentlich auch nicht funktionieren oder?
                            Die local_temperature aktualisiert sich bei mir leider nicht von selbst, wenn man jedoch die local_temperature_calibration aktualisiert, wird auch die aktuelle local_temperature aktualisiert.
                            • B bluefish
                              const device = {
                                  model: 'TS0601',
                                  vendor: 'Tuya',
                                  exposes: [
                                      e.battery(),
                                      // e.child_lock(),
                              Ergebnis:
                              diti
                              schrieb am zuletzt editiert von diti
                              @bluefish bei mir funktioniert von allein die Child_lock, local_temperature, früher musste ich auch mit einem Skript local_temperature_calibration auf 0-Grad jedesmal setzen um die aktuelle Temperatur zu bekommen.
                              • D diti
                                diti
                                local_temperature funktioniert doch nicht, ich habe immer noch Skript aktiv gehabt. Wie kann man überprüfen ob Thermostat was sendet? Vielleicht mit zigbee.0.info.debugmessages?
                                • D diti
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @diti wenn du die addresse des thermostat in den State info.debugmessages einträgst bekommst du mit welche Nachricht der Adapter vom Herdsman weitergereicht bekommt.
                                  A.
                                  D ? 2 Antworten Letzte Antwort
                                    A.
                                    diti
                                    @asgothian ich bekomme folgende Meldungen wenn ich temperature_calibration an Thermostat sende
                                    v5.1.25
                                    012
                                    Log-Größe: 32.9 KB
                                    Zeit
                                    Nachricht
                                    zigbee.0
                                    	2021-11-04 00:26:03.916	debug	Non-pingable device 0x50325ffffe6314aa TS0601 was last seen '127.197' seconds ago.
                                    zigbee.0
                                    	2021-11-04 00:25:03.916	debug	Non-pingable device 0x50325ffffe6314aa TS0601 was last seen '67.197' seconds ago.
                                    zigbee.0
                                    	2021-11-03 23:24:03.915	debug	Non-pingable device 0x50325ffffe6314aa TS0601 was last seen '7.196' seconds ago.
                                    zigbee.0
                                    	2021-11-03 23:23:56.750	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.local_temperature_calibration:{"val":"0.0","ack":true,"ts":1635981836743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836743}
                                    zigbee.0
                                    	2021-11-03 23:23:56.748	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.msg_from_zigbee:{"val":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":7,\"dp\":27,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,0]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":50,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1635981836743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836743}
                                    zigbee.0
                                    	2021-11-03 23:23:56.746	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.link_quality:{"val":141,"ack":true,"ts":1635981836743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836640}
                                    zigbee.0
                                    	2021-11-03 23:23:56.742	info	State value to set for "zigbee.0.50325ffffe6314aa.local_temperature_calibration" has to be type "number" but received type "string"
                                    zigbee.0
                                    	2021-11-03 23:23:56.734	warn	ELEVATED publishToState: value generated '"0.0"' from device 50325ffffe6314aa for 'Offset to be used in the local_temperature'
                                    zigbee.0
                                    	2021-11-03 23:23:56.733	warn	ELEVATED publishToState: message received '{"local_temperature_calibration":"0.0"}' from device 50325ffffe6314aa type 'TV01-ZB'
                                    zigbee.0
                                    	2021-11-03 23:23:56.732	debug	Publish {"local_temperature_calibration":"0.0"} to "50325ffffe6314aa"
                                    zigbee.0
                                    	2021-11-03 23:23:56.732	warn	ELEVATED publishToState: value generated '"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":7,\"dp\":27,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,0]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":50,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 50325ffffe6314aa for 'Message from Zigbee'
                                    zigbee.0
                                    	2021-11-03 23:23:56.731	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":7,\"dp\":27,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,0]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":50,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 50325ffffe6314aa type 'TV01-ZB'
                                    zigbee.0
                                    	2021-11-03 23:23:56.731	warn	ELEVATED publishToState: value generated '141' from device 50325ffffe6314aa for 'Link quality'
                                    zigbee.0
                                    	2021-11-03 23:23:56.730	warn	ELEVATED publishToState: message received '{"linkquality":141}' from device 50325ffffe6314aa type 'TV01-ZB'
                                    zigbee.0
                                    	2021-11-03 23:23:56.721	debug	Type commandGetData device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836719,"_linkquality":141},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_e9ba97vf"},{"modelID":"TS0601","manufacturerName":"_TZE200_hue3yfsn"}],"model":"TV01-ZB","vendor":"Moes","description":"Thermostat radiator valve","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandGetData","commandSetDataResponse","raw"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["system_mode","window_detection","frost_detection","child_lock","current_heating_setpoint","local_temperature_calibration","holiday_temperature","comfort_temperature","eco_temperature","boost_mode","open_window_temperature","heating_stop","preset"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":3,"value_on":"ON","value_off":"OFF","description":"Enables/disables window detection on the device","value_toggle":"TOGGLE"}]},{"type":"binary","name":"frost_detection","property":"frost_detection","access":3,"value_on":true,"value_off":false,"description":"Enables/disables frost detection on the device"},{"type":"binary","name":"heating_stop","property":"heating_stop","access":3,"value_on":true,"value_off":false,"description":"Stop heating"},{"type":"numeric","name":"holiday_temperature","property":"holiday_temperature","access":3,"description":"Holiday mode temperature"},{"type":"numeric","name":"comfort_temperature","property":"comfort_temperature","access":3,"description":"Comfort mode temperature"},{"type":"numeric","name":"eco_temperature","property":"eco_temperature","access":3,"description":"Eco mode temperature"},{"type":"numeric","name":"open_window_temperature","property":"open_window_temperature","access":3,"description":"Open window mode temperature"},{"type":"numeric","name":"boost_heating_countdown","property":"boost_heating_countdown","access":1,"description":"Boost heating countdown"},{"type":"numeric","name":"error_status","property":"error_status","access":1,"description":"Error status"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":3,"value_min":5,"value_max":29.5,"value_step":1,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":1,"unit":"°C","description":"Current temperature measured on the device"},{"type":"numeric","name":"local_temperature_calibration","property":"local_temperature_calibration","access":3,"unit":"°C","description":"Offset to be used in the local_temperature"},{"type":"enum","name":"system_mode","property":"system_mode","access":3,"values":["off","heat","auto"],"description":"Mode of this device"},{"type":"enum","name":"preset","property":"preset","access":3,"values":["auto","manual","holiday"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[]},"name":"0x50325ffffe6314aa"} incoming event: {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836719,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":7,"dp":27,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,0]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":50,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                    zigbee.0
                                    	2021-11-03 23:23:56.720	debug	Received Zigbee message from '0x50325ffffe6314aa', type 'commandGetData', cluster 'manuSpecificTuya', data '{"status":0,"transid":7,"dp":27,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,0]}}' from endpoint 1 with groupID 0
                                    zigbee.0
                                    	2021-11-03 23:23:56.719	debug	handleMessage. {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836719,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":7,"dp":27,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,0]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":50,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                    zigbee.0
                                    	2021-11-03 23:23:56.693	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.local_temperature:{"val":"21.3","ack":true,"ts":1635981836691,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836691}
                                    zigbee.0
                                    	2021-11-03 23:23:56.687	info	State value to set for "zigbee.0.50325ffffe6314aa.local_temperature" has to be type "number" but received type "string"
                                    zigbee.0
                                    	2021-11-03 23:23:56.649	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.msg_from_zigbee:{"val":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":6,\"dp\":24,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,213]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":49,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1635981836641,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836641}
                                    zigbee.0
                                    	2021-11-03 23:23:56.646	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.link_quality:{"val":141,"ack":true,"ts":1635981836640,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836640}
                                    zigbee.0
                                    	2021-11-03 23:23:56.623	warn	ELEVATED publishToState: value generated '"21.3"' from device 50325ffffe6314aa for 'Current temperature measured on the device'
                                    zigbee.0
                                    	2021-11-03 23:23:56.622	warn	ELEVATED publishToState: message received '{"local_temperature":"21.3"}' from device 50325ffffe6314aa type 'TV01-ZB'
                                    zigbee.0
                                    	2021-11-03 23:23:56.619	debug	Publish {"local_temperature":"21.3"} to "50325ffffe6314aa"
                                    zigbee.0
                                    	2021-11-03 23:23:56.618	warn	ELEVATED publishToState: value generated '"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":6,\"dp\":24,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,213]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":49,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 50325ffffe6314aa for 'Message from Zigbee'
                                    zigbee.0
                                    	2021-11-03 23:23:56.617	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":6,\"dp\":24,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,213]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":49,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 50325ffffe6314aa type 'TV01-ZB'
                                    zigbee.0
                                    	2021-11-03 23:23:56.616	warn	ELEVATED publishToState: value generated '141' from device 50325ffffe6314aa for 'Link quality'
                                    zigbee.0
                                    	2021-11-03 23:23:56.615	warn	ELEVATED publishToState: message received '{"linkquality":141}' from device 50325ffffe6314aa type 'TV01-ZB'
                                    zigbee.0
                                    	2021-11-03 23:23:56.596	debug	Type commandGetData device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836591,"_linkquality":141},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_e9ba97vf"},{"modelID":"TS0601","manufacturerName":"_TZE200_hue3yfsn"}],"model":"TV01-ZB","vendor":"Moes","description":"Thermostat radiator valve","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandGetData","commandSetDataResponse","raw"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["system_mode","window_detection","frost_detection","child_lock","current_heating_setpoint","local_temperature_calibration","holiday_temperature","comfort_temperature","eco_temperature","boost_mode","open_window_temperature","heating_stop","preset"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":3,"value_on":"ON","value_off":"OFF","description":"Enables/disables window detection on the device","value_toggle":"TOGGLE"}]},{"type":"binary","name":"frost_detection","property":"frost_detection","access":3,"value_on":true,"value_off":false,"description":"Enables/disables frost detection on the device"},{"type":"binary","name":"heating_stop","property":"heating_stop","access":3,"value_on":true,"value_off":false,"description":"Stop heating"},{"type":"numeric","name":"holiday_temperature","property":"holiday_temperature","access":3,"description":"Holiday mode temperature"},{"type":"numeric","name":"comfort_temperature","property":"comfort_temperature","access":3,"description":"Comfort mode temperature"},{"type":"numeric","name":"eco_temperature","property":"eco_temperature","access":3,"description":"Eco mode temperature"},{"type":"numeric","name":"open_window_temperature","property":"open_window_temperature","access":3,"description":"Open window mode temperature"},{"type":"numeric","name":"boost_heating_countdown","property":"boost_heating_countdown","access":1,"description":"Boost heating countdown"},{"type":"numeric","name":"error_status","property":"error_status","access":1,"description":"Error status"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":3,"value_min":5,"value_max":29.5,"value_step":1,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":1,"unit":"°C","description":"Current temperature measured on the device"},{"type":"numeric","name":"local_temperature_calibration","property":"local_temperature_calibration","access":3,"unit":"°C","description":"Offset to be used in the local_temperature"},{"type":"enum","name":"system_mode","property":"system_mode","access":3,"values":["off","heat","auto"],"description":"Mode of this device"},{"type":"enum","name":"preset","property":"preset","access":3,"values":["auto","manual","holiday"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[]},"name":"0x50325ffffe6314aa"} incoming event: {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836591,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":6,"dp":24,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,213]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":49,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                    zigbee.0
                                    	2021-11-03 23:23:56.595	debug	Received Zigbee message from '0x50325ffffe6314aa', type 'commandGetData', cluster 'manuSpecificTuya', data '{"status":0,"transid":6,"dp":24,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,213]}}' from endpoint 1 with groupID 0
                                    zigbee.0
                                    	2021-11-03 23:23:56.592	debug	handleMessage. {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836591,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":6,"dp":24,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,213]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":49,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                    zigbee.0
                                    	2021-11-03 23:23:55.384	debug	target: {"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}
                                      A.
                                      Hat sich gelöst.
                                      Wenn ich die Programmierung einzeln zum Ventil schicke funktioniert es:
                                      Definition Wochenprogramm:
                                      sendTo('zigbee.0', 'SendToDevice', {'device':'84fd27fffe8afa10', 'payload':{
                                      "schedule": {
                                      "week": "5+2"
                                      }}, function(res) {
                                      if (res.success)
                                      else
                                      Programmierung Workdays:
                                      "schedule": {
                                      "workdays": [
                                      "hour": 6,
                                      "minute": 0,
                                      "temperature": 18
                                      "hour": 8,
                                      "minute": 0,
                                      "temperature": 17
                                      "hour": 17,
                                      "minute": 0,
                                      "temperature": 19
                                      "hour": 20,
                                      "minute": 30,
                                      "temperature": 18
                                      "hour": 21,
                                      "minute": 30,
                                      "temperature": 17
                                      "hour": 23,
                                      "minute": 0,
                                      "temperature": 17
                                      }}, function(res) {
                                      if (res.success)
                                      else
                                      Programmierung Holidays=Wochenende:
                                      "schedule": {
                                      "holidays": [
        {"hour":6,"minute":0,"temperature":18},
        {"hour":10,"minute":0,"temperature":17},
        {"hour":18,"minute":0,"temperature":19},
        {"hour":22,"minute":0,"temperature":17},
                                      }}, function(res) {
                                      if (res.success)
                                      else
                                      P.S: Woher weiß das Thermostat eigentlich welchen Wochentag bzw. wie spät es ist?
                                        Hat sich gelöst.
                                        "schedule": {
                                        "week": "5+2"
                                        }}, function(res) {
                                        if (res.success)
                                        else
                                        "schedule": {
                                        "workdays": [
                                        "hour": 6,
                                        "minute": 0,
                                        "temperature": 18
                                        "hour": 8,
                                        "minute": 0,
                                        "temperature": 17
                                        "hour": 17,
                                        "minute": 0,
                                        "temperature": 19
                                        "hour": 20,
                                        "minute": 30,
                                        "temperature": 18
                                        "hour": 21,
                                        "minute": 30,
                                        "temperature": 17
                                        "hour": 23,
                                        "minute": 0,
                                        "temperature": 17
                                        }}, function(res) {
                                        if (res.success)
                                        else
                                        "schedule": {
                                        "holidays": [
                                        }}, function(res) {
                                        if (res.success)
                                        else
                                        @diti @bluefish @Asgothian
                                        Etwas verwirrend da hier im Beitrag wohl mehrere Typen besprochen wurden.
                                        Ich hatte bisher geglaubt hier über dieses Ventil (z.B.: TS0601_thermostat) zu sprechen, worauf sich meine Erfahrung etc bezieht:
                                        Habe nun aber zusätzlich so ein Ventil im Einsatz, was wohl dem (_TZE200_hue3yfsn entspricht):
                                        Aus der Zigbee2Mqtt Supportliste bin ich hierbei von der Bezeichnung TS0601_thermostat_1 ausgegangen, was aber nicht mit dem aktuellen IObroker Adapter übereinstimmt (TV02-Zigbee für das TS0601 _TZE200_hue3yfsn).
                                        Nacheiner kreisrunden Suche bin ich nun wieder hier gelandet und denke ihr nutzt genau das Ventil aber mit Euren Lösungen (modifizierte Files oder Converter). Oder gibt es hier evtl. Neuigkeiten? Im aktuellen Zigbee Adapter(1.6.7) wird wie festgestellt das Thermostat direkt als TV02-Zigbee unterstützt.
                                        Leider fehlt dort die Ventilposition, aber auch ist dort nur die einmalige Synchronierung der lokalen Temperatur drin.
                                        Nach etwas weiterer Suche vermute ich den Ursprung dieser Unterstützung hier, der sich bis in den IObroker Adapter fortgesetzt hat: https://github.com/Koenkk/zigbee-herdsman-converters/issues/3142
                                        Dort ist die Rede davon die Aktualisierung der lokalen Temperatur "anders" gelöst zu haben, aber wie? Eine manuelle (oder per skript) Aktualisierung der Temperatur-Kalibrierung funktioniert bei mir nicht.
                                        Wie ist hier Euer Verständis zu dieser Funktion?
                                          diti
                                          @pete0815
                                          ich gehe davon aus dass, der Ventil nie die lokale Temperatur einfach so rum sendet. Die wird bekannt gegeben,wenn der Ventil von Smart Life, Tuya Smart angesprochen wird (auf welche Weise weiß ich nicht), oder wenn er ein Signal für Temperatur-Kalibrierung bekommt, hier muss er logisch Ergebnisse der Kalibrierung zeigen. Warum das bei dir nicht geht, weiß ich nicht. Aktualisierung der lokalen Temperatur mache ich mit einfachen Blockly-Skript
                                          Was es um die Ventilposition geht, der Thermostat hat ja kein Data Point ID um das von extern zu steuern, oder?
                                          Danke für Info über Einpflegung in Zigbee2MQTT, jetzt läuft´s bei mir direkt ohne Umwege.
                                          Das einzige Problem was ich habe nur diese Meldungen, die ständig auftreten
                                          2021-11-22 18:07:29.191 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:07:29.314 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:12:20.998 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314f1.current_heating_setpoint" has to be type "number" but received type "string"
                                          2021-11-22 18:12:21.024 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314aa.current_heating_setpoint" has to be type "number" but received type "string"
                                          2021-11-22 18:12:21.191 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe631473.current_heating_setpoint" has to be type "number" but received type "string"
                                          2021-11-22 18:12:22.051 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.current_heating_setpoint" has to be type "number" but received type "string"
                                          2021-11-22 18:12:27.416 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314f1.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:12:27.514 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314aa.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:12:27.537 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314f1.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:12:27.630 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314aa.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:12:27.703 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe631473.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:12:27.809 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe631473.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:12:28.524 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:12:28.633 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:17:27.398 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:17:27.490 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe631473.local_temperature" has to be type "number" but received type "string"
                                          2021-11-22 18:17:27.527 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314cb.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:17:27.621 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe631473.local_temperature_calibration" has to be type "number" but received type "string"
                                          2021-11-22 18:17:28.355 - info: zigbee.0 (8262) State value to set for "zigbee.0.50325ffffe6314f1.local_temperature" has to be type "number" but received type "string"
                                          ich glaube das hat mit dem neuen Zigbee Adapter 1.6.7 zu tun hat.
                                          AsgothianA ? 2 Antworten Letzte Antwort
