  4. zigbee netzwerk fehler Code 205 (No network route)
    6.3k
zigbee-adapter
27 Beiträge 7 Kommentatoren 3.5k Aufrufe 6 Beobachtet
    Digi-Bit
    schrieb am zuletzt editiert von Digi-Bit
    Hallo
    mein zigbee adapter spint irgend wie rum
    nach einem reboot funktionieren die Lampen nicht mehr ;(
       2021-10-28 20:46:04.233	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:45:42.466	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:45:21.299	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:44:59.467	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:44:37.876	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:44:32.989	warn	Send command to 0x000b57fffe965947 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:44:16.145	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:44:01.058	warn	Send command to 0x000b57fffe965947 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:43:55.040	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:43:33.469	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:43:11.758	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:42:50.381	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:42:32.326	warn	Send command to 0x000b57fffe965947 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:42:29.040	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:42:10.486	warn	Send command to 0x000b57fffe965947 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:41:48.560	warn	Failed to ping 0x000b57fffe965947 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:47.609	warn	Send command to 0x000b57fffe965947 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:41:46.109	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:41:26.067	warn	Failed to ping 0x60a423fffef37ca6 RS 230 C
    zigbee.0
    2021-10-28 20:41:25.968	warn	Failed to ping 0x90fd9ffffe02d210 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:25.902	warn	Failed to ping 0x0017880103f49b55 LST002
    zigbee.0
    2021-10-28 20:41:25.875	warn	Failed to ping 0x000b57fffe964f3c TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:25.760	warn	Failed to ping 0x000b57fffeaf4bd2 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:25.740	warn	Send command to 0x000b57fffe965947 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:41:25.704	warn	Failed to ping 0xf0d1b80000139ebe PAR16 DIM Z3
    zigbee.0
    2021-10-28 20:41:25.695	warn	Failed to ping 0xf0d1b8000013a2f8 PAR16 DIM Z3
    zigbee.0
    2021-10-28 20:41:25.671	warn	Failed to ping 0x000b57fffeba0cfa TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:25.658	warn	Failed to ping 0xf0d1b80000145e6d PAR16 DIM Z3
    zigbee.0
    2021-10-28 20:41:25.649	warn	Failed to ping 0x60a423fffef1b2d3 RS 230 C
    zigbee.0
    2021-10-28 20:41:25.610	warn	Failed to ping 0xf0d1b80000127d57 PAR16 DIM Z3
    zigbee.0
    2021-10-28 20:41:25.228	warn	Failed to ping 0x90fd9ffffe710432 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:25.070	warn	Failed to ping 0x000b57fffea115ed TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:24.147	warn	Send command to 0x7cb03eaa00adf7c0 failed with: Code 205 (No network route)
    zigbee.0
    2021-10-28 20:41:19.652	warn	Failed to ping 0x000b57fffea0e589 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:18.500	warn	Failed to ping 0x000b57fffe9d34ef TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:17.413	warn	Failed to ping 0x000b57fffe9c7746 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:16.495	warn	Failed to ping 0x00158d0002ff234a RB 285 C
    zigbee.0
    2021-10-28 20:41:15.766	warn	Failed to ping 0x000b57fffe964291 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:14.814	warn	Failed to ping 0x00178801093db51d LCA001
    zigbee.0
    2021-10-28 20:41:13.878	warn	Failed to ping 0x000b57fffe9d1f73 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:13.003	warn	Failed to ping 0x000b57fffe8a419a TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:11.979	warn	Failed to ping 0x000b57fffe8a310c TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:11.126	warn	Failed to ping 0x000b57fffe966746 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:10.192	warn	Failed to ping 0x000b57fffe9c7adb TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:09.319	warn	Failed to ping 0x000b57fffe8b86e5 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:08.487	warn	Failed to ping 0x90fd9ffffe6e8e1f TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:07.594	warn	Failed to ping 0x000b57fffe8a165b TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:41:06.749	warn	Failed to ping 0x000b57fffe847553 TRADFRI bulb GU10 W 400lm
    zigbee.0
    2021-10-28 20:40:42.744	info	Zigbee started
    zigbee.0
    2021-10-28 20:40:42.743	info	0x00158d0001fe0258 (addr 30989): MLI-404011 - Müller Licht Tint remote control (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.742	info	0x0017880108f3878a (addr 16398): 324131092621 - Philips Hue dimmer switch (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.741	info	0x60a423fffef37ca6 (addr 64581): RS 230 C - Innr GU10 spot 350 lm, dimmable, RGBW (Router)
    zigbee.0
    2021-10-28 20:40:42.739	info	0x000b57fffe964f3c (addr 8069): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.738	info	0x60a423fffef1b2d3 (addr 13487): RS 230 C - Innr GU10 spot 350 lm, dimmable, RGBW (Router)
    zigbee.0
    2021-10-28 20:40:42.736	info	0xd0cf5efffe104afd (addr 14168): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.735	info	0xf0d1b80000145e6d (addr 29991): AC08560-DIM - OSRAM SMART+ LED PAR16 GU10 (Router)
    zigbee.0
    2021-10-28 20:40:42.733	info	0xf0d1b8000013a2f8 (addr 38367): AC08560-DIM - OSRAM SMART+ LED PAR16 GU10 (Router)
    zigbee.0
    2021-10-28 20:40:42.732	info	0xf0d1b80000139ebe (addr 53531): AC08560-DIM - OSRAM SMART+ LED PAR16 GU10 (Router)
    zigbee.0
    2021-10-28 20:40:42.730	info	0xf0d1b80000127d57 (addr 27610): AC08560-DIM - OSRAM SMART+ LED PAR16 GU10 (Router)
    zigbee.0
    2021-10-28 20:40:42.729	info	0x000b57fffeba0cfa (addr 55174): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.727	info	0x90fd9ffffe02d210 (addr 36831): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.724	info	0x90fd9ffffe710432 (addr 46277): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.722	info	0x7cb03eaa00adf7c0 (addr 61032): AC0363900NJ - OSRAM Smart+ mini gardenpole RGBW (Router)
    zigbee.0
    2021-10-28 20:40:42.721	info	0x0017880103e4f458 (addr 4642): 324131092621 - Philips Hue dimmer switch (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.719	info	0x14b457fffe3eb4d8 (addr 38405): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.717	info	0x0017880103f49b55 (addr 42607): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
    zigbee.0
    2021-10-28 20:40:42.716	info	0x14b457fffe79c856 (addr 23787): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.714	info	0x000b57fffeaf4bd2 (addr 4435): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.713	info	0x000b57fffea115ed (addr 14536): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.712	info	0x0017880104b55bb9 (addr 31321): 9290012607 - Philips Hue motion sensor (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.710	info	0x000b57fffea0e589 (addr 10067): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.709	info	0x000b57fffe9d34ef (addr 28554): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.707	info	0x00178801093db51d (addr 37289): 9290022166 - Philips Hue white and color ambiance E26/E27 (Router)
    zigbee.0
    2021-10-28 20:40:42.705	info	0x00178801032a3bac (addr 8270): 9290012607 - Philips Hue motion sensor (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.703	info	0x00158d0002ff234a (addr 63880): RB 285 C - Innr E27 bulb RGBW (Router)
    zigbee.0
    2021-10-28 20:40:42.702	info	0x000b57fffe9d1f73 (addr 60753): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.700	info	0x000b57fffe9c7adb (addr 6261): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.699	info	0x000b57fffe9c7746 (addr 19958): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.697	info	0x0017880106f67ccd (addr 24297): 9290012607 - Philips Hue motion sensor (EndDevice)
    zigbee.0
    2021-10-28 20:40:42.695	info	0x000b57fffe966746 (addr 10719): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.694	info	0x000b57fffe965947 (addr 22133): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.692	info	0x90fd9ffffe6e8e1f (addr 63250): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.691	info	0x000b57fffe964291 (addr 65207): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.690	info	0x000b57fffe8b86e5 (addr 17413): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.688	info	0x000b57fffe8a419a (addr 52089): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.686	info	0x000b57fffe8a310c (addr 36497): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.685	info	0x000b57fffe8a165b (addr 65163): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.681	info	0x000b57fffe847553 (addr 30890): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2021-10-28 20:40:42.624	info	Currently 39 devices are joined:
    zigbee.0
    2021-10-28 20:40:42.613	info	--> transmitPower : normal
    zigbee.0
    2021-10-28 20:40:42.605	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0
    2021-10-28 20:40:42.339	info	Installed Version: iobroker.zigbee
    zigbee.0
    2021-10-28 20:40:41.889	info	Starting Zigbee npm ...
    zigbee.0
    2021-10-28 20:40:41.788	info	starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
    host.raspberrypi4pi
    2021-10-28 20:40:38.476	info	instance system.adapter.zigbee.0 started with pid 6795
    host.raspberrypi4pi
    2021-10-28 20:40:36.300	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0
    2021-10-28 20:40:35.670	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    kann mir jemand sagen was der hat und wieso der nichtmehr das netzwerk aufbauen will ?
    den stick habe ich auch schon aus den USB rausgezogen und wieder reingesteckt, habe gelesen das dies auch ab und zu zu diesen fehler kommen kann :(
    mfg
    Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
    7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
    arteckA D 2 Antworten Letzte Antwort
    • D Digi-Bit
      Hallo
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.raspberrypi4pi
      host.raspberrypi4pi
      zigbee.0
      mfg
      arteckA Offline
      arteckA Offline
      arteck
      @digi-bit sagte in zigbee netzwerk fehler Code 205 (No network route):
      nach einem reboot
      das glaube ich dir so nicht..
      was hast du davor gemacht .. ?? und jetzt sag nicht NIX
      was ist das für ein coordinator ??
      • arteckA arteck
        nach einem reboot
        Digi-Bit
        @arteck sagte in zigbee netzwerk fehler Code 205 (No network route):
        nach einem reboot
        naja, eigentlich nix mit DIESER SSD !
        ich habe den IOB auf einer 500 GB SSD.
        Nun bin ich dabei mich ein zu fummeln das ganze für Img. Backups einzurichten.
        Und da ich das nicht mit meinem Original System machen will habe ich mir eine 128 GB SSD geholt.
        Also den IOB mit der ORG SSD
        iobroker stop
        sudo shutdown now
        Power off vom RP4 die SSD angezogen und die "neu" mit dem Linux img. ran.
        dann das übliche bei der neu Instalation mit den updates nodes und IOB instaliert Backup rein uns so weiter.
        mit dem img. back Sachen etwas rum gespielt und dann Schnauze voll für den tag
        also wieder das neue System
        iobroker stop
        sudo shutdown now
        Power off, die NEUE SSD abgezogen und das " alte " wieder ran, Eingeschaltet und gewartet bis das System wieder hoch gefahren ist und dann war das da oben los.
        Also eigentlich ja, nix gemacht mit dem " ALTEN " System, ausser mal aus und wieder eingeschaltet unterm strich. ( "Sauber" Runtergefahren und wieder gestartet )
        der coordinator ist ein CC1352P-2
        mfg
        • D Digi-Bit
          nach einem reboot
          iobroker stop
          sudo shutdown now
          iobroker stop
          sudo shutdown now
          mfg
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          Hast du
          • die SSD am USB3 ?
          • den gleichen USB - SSD Adapter benutzt wie zuvor als es lief (mit dem identischen Kabel) ?
          • den gleichen USB3 Port genutzt wie zuvor als es lief ?
          • das USB Kabel gleich verlegt ?
          hintergrund: USB3 Datenübertragung strahlt gerne im 2.4 gHz Frequenzband, und stört damit WLan und Zigbee. An der Stelle erzeugen dann schon kleine Anpassungen (anderes Kabel, anderer Adapter, andere Verlegung) ggf. signifikante Änderungen.
          A.
          • AsgothianA Asgothian
            Hast du
            • die SSD am USB3 ?
            A.
            Digi-Bit
            @asgothian sagte in zigbee netzwerk fehler Code 205 (No network route):
            Hast du
            • die SSD am USB3 ?
            ja
            Was für ein Adapter ?
            Die Kiste bootet von der SSD
              JA
            Das gleiche Kabel hab nur die SSD getauscht
            A.
            Ahhh... ok.... dan wäre es ja eigendlich besser von USB 2 die SSD zu Booten oder ?
            Sind ja 2 Ports drane , am einen SSD und dann am anderen die Zigbee kiste , wäre das dann besser ?
            Also ich habe unterm strich die SSD vom USB-C Stecker gezogen und die andere dran gesteckt am selben kabel und am selben USB3 port
            mfg
            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
            • D Digi-Bit
              Hast du
              • die SSD am USB3 ?
              ja
                JA
              A.
              mfg
              Und die Zigbee-Kiste per USB-Verlängerung einstöpseln.
              • D Digi-Bit
                Hast du
                • die SSD am USB3 ?
                ja
                  JA
                A.
                mfg
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                SSD's haben eigentlich nie nativ USB3. Das ist eigentlich immer NVME oder SATA, so das ein Adapter (chip) die Umsetzung SATA / NVME auf USB3 macht.
                Bei SSD's die direkt im USB Gehäuse kommen ist der eingebaut.
                Ich hatte dich so verstanden das du:
                • die 500 gb abgeklemmt
                • auf die 128 gb gespiegelt
                • dann wieder angeklemmt hast um davon zu booten.
                Stimmt das ?
                Wenn nein: ggf. stört dann die 128 gb SSD den Funkverkehr.
                A.
                  Stimmt das ?
                  A.
                  Digi-Bit
                  Stimmt das ?
                  A.
                  jep, genau so ist es
                  also ich aber an der 128 das zigbee nicht zum laufen bekommen habe und es schon späht war habe ich die 500 wieder ran geklempt und da war dann das Zigbee netz auch tot ....
                  was mich sehr gewundert habe den an der Hardware einstellung wurde ja nix geändert in bezug auf der 500 GB SSD
                  mfg
                  • D Digi-Bit
                    Stimmt das ?
                    A.
                    mfg
                    arteckA Offline
                    arteckA Offline
                    arteck
                    so wie "nur reboot" wie im Eingangspost ?? mal im ernst wie soll man dir helfen wenn du die hälfe der Informationen zurückhälts..
                    • arteckA arteck
                      Digi-Bit
                      ähm, ich weiss jetzt nicht genau was Sie meinen, ich habe doch genau geschildert was ich gemacht habe....
                      ich habe nach den rumtesten auf der 128 GB SSD das System mit
                      iobroker stop
                      sudo shutdown now
                      dann den Power OFF Schalter am RB4 aus geschaltet, die 128GB SSD vom USB-C Stecker Gezogen ( der USB3 Stecker blieb ja im RB4 USB3 Port) habe dann die 500 GB SSD an den USB-C Stecker angeschlossen und den Power on Knopf von RB4 wieder eingeschaltet, was ich ja oben schon gesagt habe.
                      Welche Informationen benötigen Sie den noch um mir zu helfen, worüber ich ja auch sehr dankbar bin !
                      mfg
                      • D Digi-Bit
                        iobroker stop
                        sudo shutdown now
                        mfg
                        crunchipC Abwesend
                        crunchipC Abwesend
                        sudo shutdown now
                        vllt zu kurz gewartet
                        aber erst im Nachgang
                          sudo shutdown now
                          Digi-Bit
                          @crunchip sagte in zigbee netzwerk fehler Code 205 (No network route):
                          sudo shutdown now
                          mm... waren bestimmt min. 2 min.
                          wie lange sollte man denn bei sowas min. warten ?
                          mmm vor 22 stunden war das
                          "ich habe den IOB auf einer 500 GB SSD.
                          iobroker stop
                          sudo shutdown now
                          Power off vom RP4 die SSD angezogen und die "neu" mit dem Linux img. ran."
                          war das DA noch nicht deutlich genug ?
                          aber wurst wurde ja jetzt erledigt !
                          mfg
                          • D Digi-Bit
                            sudo shutdown now
                            iobroker stop
                            sudo shutdown now
                            mfg
                            crunchipC Abwesend
                            crunchipC Abwesend
                            wurscht vor wievielen Stunden, im Eingangs Post, wie Arteck schon schrieb, war die Rede von einem reboot und das hat nichts mit Platte umstöpseln und sonst der gleichen zu tun, (nenne ich Eingriff in die Hardware) und die Information wurde zu Beginn "verschwiegen"
                            dann guck doch mal auf deinem System z.b. mit dmesg ob da was faul ist
                            • D Digi-Bit
                              Hallo
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              host.raspberrypi4pi
                              host.raspberrypi4pi
                              zigbee.0
                              mfg
                              Dragon
                              @digi-bit Ich habe genau diese Zigbee Meldung auch bekommen. Mei Gerät war nicht mehr erreichbar und musste nach dem Batteriewechsel ein mal neu angelernt werden.
                                Digi-Bit
                                Mmmm, also momentan rennt mein System auf der 128er SSD und ich habe da alle 34 Zigbee Geräte neu angelernt.
                                Und momentan rennt das System sehr gut ( aus meiner Sicht )
                                Nun habe ich natürlich etwas bedenken wenn ich da wieder rum fummel und die 500ter SSD anschliesse das ich das auch wieder machen muss wenn ich nach dem
                                rumtesten wieder von der 128er starten will.
                                Daher würde ich vorher mal gerne wissen, also grunssätzlich wäre es besser wenn der Zigbee auf USB 2 läuft und die SSD auch ?
                                momentan sieht das so aus
                                Der Zigbee ist am unteren USB 2 mit einem ca. 1.5 Meter USB Verlängerung angeschlossen, ( ist ja kein Stick in dem sine sondern schon so eine kleine Kiste)
                                Die SSD ist am unteren USB 3 Port angeschlossen, aber soll ja wehen welchen "Strahlungen" nicht so günstig sein.
                                Ich würde dann die SSD am oberen USB2 Port anschließen und die da auch für die Zukunft betreiben, wäre dies dann eine "bessere" Konstellation ?
                                mfg
                                D crunchipC 2 Antworten Letzte Antwort
                                • D Digi-Bit
                                  mfg
                                  Digi-Bit
                                  habe das dmesg mal bei der 128er eingegeben.
                                  Siehts den hier "Normal" aus ?
                                  Sind einige sachen in ROT bei, rot ist nicht so gut denke ich mal ?
                                  mfg
                                  [    1.440790] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
                                  [    1.440821] usb usb2: SerialNumber: 0000:01:00.0
                                  [    1.441561] hub 2-0:1.0: USB hub found
                                  [    1.441650] hub 2-0:1.0: 4 ports detected
                                  [    1.443315] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                  [    1.443636] dwc_otg: FIQ enabled
                                  [    1.443651] dwc_otg: NAK holdoff enabled
                                  [    1.443666] dwc_otg: FIQ split-transaction FSM enabled
                                  [    1.443684] Module dwc_common_port init
                                  [    1.444149] usbcore: registered new interface driver uas
                                  [    1.444316] usbcore: registered new interface driver usb-storage
                                  [    1.444548] mousedev: PS/2 mouse device common for all mice
                                  [    1.446219] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                  [    1.449601] sdhci: Secure Digital Host Controller Interface driver
                                  [    1.449634] sdhci: Copyright(c) Pierre Ossman
                                  [    1.450367] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                                  [    1.450999] sdhci-pltfm: SDHCI platform and OF driver helper
                                  [    1.457927] ledtrig-cpu: registered to indicate activity on CPUs
                                  [    1.458296] hid: raw HID events driver (C) Jiri Kosina
                                  [    1.458520] usbcore: registered new interface driver usbhid
                                  [    1.458550] usbhid: USB HID core driver
                                  [    1.465135] Initializing XFRM netlink socket
                                  [    1.465905] NET: Registered protocol family 17
                                  [    1.466059] Key type dns_resolver registered
                                  [    1.466429] Registering SWP/SWPB emulation handler
                                  [    1.466643] registered taskstats version 1
                                  [    1.466697] Loading compiled-in X.509 certificates
                                  [    1.467570] Key type ._fscrypt registered
                                  [    1.467601] Key type .fscrypt registered
                                  [    1.467629] Key type fscrypt-provisioning registered
                                  [    1.479334] uart-pl011 fe201000.serial: there is not valid maps for state default
                                  [    1.479665] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                  [    1.479770] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                                  [    1.486523] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                  [    1.487609] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                  [    1.487642] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                  [    1.517993] of_cfs_init
                                  [    1.518287] of_cfs_init: OK
                                  [    1.538629] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                  [    1.540335] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    1.542044] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    1.545554] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                  [    1.547278] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    1.554846] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                                  [    1.555528] Waiting for root device PARTUUID=65b17d9d-02...
                                  [    1.614879] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                                  [    1.616188] mmc1: new high speed SDIO card at address 0001
                                  [    1.652008] usb 2-2: New USB device found, idVendor=0bda, idProduct=9210, bcdDevice=20.01
                                  [    1.652051] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  [    1.652084] usb 2-2: Product: RTL9210B-CG
                                  [    1.652113] usb 2-2: Manufacturer: Realtek
                                  [    1.652142] usb 2-2: SerialNumber: 012345678922
                                  [    1.656568] usb 2-2: Enable of device-initiated U1 failed.
                                  [    1.658006] usb 2-2: Enable of device-initiated U2 failed.
                                  [    1.682295] usb 2-2: Enable of device-initiated U1 failed.
                                  [    1.683683] usb 2-2: Enable of device-initiated U2 failed.
                                  [    1.701134] scsi host0: uas
                                  [    1.706153] scsi 0:0:0:0: Direct-Access     Inateck  FE202x Series    1.00 PQ: 0 ANSI: 6
                                  [    1.732706] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
                                  [    1.734683] sd 0:0:0:0: [sda] Write Protect is off
                                  [    1.734718] sd 0:0:0:0: [sda] Mode Sense: 37 00 00 08
                                  [    1.738716] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                                  [    1.742346] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
                                  [    1.767495]  sda: sda1 sda2
                                  [    1.793018] sd 0:0:0:0: [sda] Attached SCSI disk
                                  [    1.794301] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                  [    1.800861] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                  [    1.800973] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                  [    1.803253] devtmpfs: mounted
                                  [    1.813200] Freeing unused kernel memory: 2048K
                                  [    1.854576] Run /sbin/init as init process
                                  [    1.854605]   with arguments:
                                  [    1.854620]     /sbin/init
                                  [    1.854634]   with environment:
                                  [    1.854649]     HOME=/
                                  [    1.854663]     TERM=linux
                                  [    1.977476] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                  [    1.977648] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                  [    1.977682] usb 1-1: Product: USB2.0 Hub
                                  [    1.980061] hub 1-1:1.0: USB hub found
                                  [    1.982259] hub 1-1:1.0: 4 ports detected
                                  [    2.049891] systemd[1]: System time before build time, advancing clock.
                                  [    2.117290] NET: Registered protocol family 10
                                  [    2.118718] Segment Routing with IPv6
                                  [    2.153168] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                                  [    2.154007] systemd[1]: Detected architecture arm.
                                  [    2.241551] systemd[1]: Set hostname to <raspberrypi4-iob>.
                                  [    2.324324] usb 1-1.4: new high-speed USB device number 3 using xhci_hcd
                                  [    2.465038] usb 1-1.4: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
                                  [    2.465091] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  [    2.465129] usb 1-1.4: Product: XDS110 (03.00.00.15) Embed with CMSIS-DAP
                                  [    2.465162] usb 1-1.4: Manufacturer: Texas Instruments
                                  [    2.465193] usb 1-1.4: SerialNumber: L430047T
                                  [    2.478397] hid-generic 0003:0451:BEF3.0001: hiddev96,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.15) Embed with CMSIS-DAP] on usb-0000:01:00.0-1.4/input5
                                  [    2.811026] random: systemd: uninitialized urandom read (16 bytes read)
                                  [    2.822006] random: systemd: uninitialized urandom read (16 bytes read)
                                  [    2.822641] systemd[1]: Listening on Journal Audit Socket.
                                  [    2.823649] random: systemd: uninitialized urandom read (16 bytes read)
                                  [    2.824456] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                  [    2.825644] systemd[1]: Listening on udev Control Socket.
                                  [    2.826408] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                                  [    2.827434] systemd[1]: Listening on fsck to fsckd communication Socket.
                                  [    2.828210] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                                  [    2.829389] systemd[1]: Listening on Journal Socket.
                                  [    3.383737] EXT4-fs (sda2): re-mounted. Opts: (null)
                                  [    3.494920] systemd-journald[115]: Received request to flush runtime journal from PID 1
                                  [    4.061157] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                                  [    4.062175] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                                  [    4.065115] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                                  [    4.069448] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                                  [    4.167876] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.170604] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                  [    4.170634] [vc_sm_connected_init]: start
                                  [    4.175609] mc: Linux media interface: v0.10
                                  [    4.200363] [vc_sm_connected_init]: installed successfully
                                  [    4.208273] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.229547] videodev: Linux video capture interface: v2.00
                                  [    4.256440] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.258319] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.294877] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.297472] sd 0:0:0:0: Attached scsi generic sg0 type 0
                                  [    4.297887] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.311190] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                  [    4.311822] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                  [    4.311869] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                  [    4.312285] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                  [    4.312776] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                  [    4.313221] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                  [    4.313253] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                  [    4.313305] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                  [    4.313330] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                  [    4.313362] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                  [    4.313743] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                  [    4.322782] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                  [    4.322827] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                  [    4.334067] bcm2835_audio bcm2835_audio: card created with 8 channels
                                  [    4.336268] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.346031] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                  [    4.346094] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                  [    4.351035] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                                  [    4.351085] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                  [    4.367571] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                  [    4.465643] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                                  [    4.514175] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                  [    4.551065] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                  [    4.574874] brcmfmac: F1 signature read @0x18000000=0x15264345
                                  [    4.581764] cdc_acm 1-1.4:1.3: ttyACM1: USB ACM device
                                  [    4.613683] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  [    4.615810] usbcore: registered new interface driver brcmfmac
                                  [    4.683621] usbcore: registered new interface driver cdc_acm
                                  [    4.683642] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                                  [    4.685545] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                                  [    4.685687] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                                  [    4.687676] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                  [    4.870953] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  [    4.871093] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  [    4.880260] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                                  [    6.974763] random: crng init done
                                  [    6.974785] random: 7 urandom warning(s) missed due to ratelimiting
                                  [    6.992117] uart-pl011 fe201000.serial: no DMA platform data
                                  [    7.009469] 8021q: 802.1Q VLAN Support v1.8
                                  [    7.214504] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                                  [    7.328916] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                                  [    7.550133] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                  [    7.550587] bcmgenet fd580000.ethernet eth0: Link is Down
                                  [   11.674495] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                  [   11.674551] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                  [   13.027963] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                                  [   13.790755] Bluetooth: Core ver 2.22
                                  [   13.790861] NET: Registered protocol family 31
                                  [   13.790878] Bluetooth: HCI device and connection manager initialized
                                  [   13.790906] Bluetooth: HCI socket layer initialized
                                  [   13.790929] Bluetooth: L2CAP socket layer initialized
                                  [   13.790964] Bluetooth: SCO socket layer initialized
                                  [   13.801678] Bluetooth: HCI UART driver ver 2.3
                                  [   13.801701] Bluetooth: HCI UART protocol H4 registered
                                  [   13.801808] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                  [   13.802123] Bluetooth: HCI UART protocol Broadcom registered
                                  [   13.952587] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                  [   13.952596] Bluetooth: BNEP filters: protocol multicast
                                  [   13.952609] Bluetooth: BNEP socket layer initialized
                                  [   31.834277] vcc-sd: disabling
                                  [   60.280577] FS-Cache: Netfs 'cifs' registered for caching
                                  [   60.289420] Key type cifs.spnego registered
                                  [   60.289436] Key type cifs.idmap registered
                                  [   60.290397] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [   60.290448] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [ 6137.700122] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [ 6137.700201] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [ 6430.865397] CIFS: Attempting to mount //192.168.1.164/ioBroker/raspberrypi-Backup
                                  [ 6430.865487] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
                                  [64073.059359] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [64073.059431] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [64073.059906] FS-Cache: Duplicate cookie detected
                                  [64073.059921] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [64073.059931] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [64073.059941] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [64073.060022] FS-Cache: N-cookie c=353ce6ff [p=1464acfa fl=2 nc=0 na=1]
                                  [64073.060032] FS-Cache: N-cookie d=d278e209 n=3ba76e09
                                  [64073.060041] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  [90325.368142] CIFS: VFS: \\192.168.1.164 has not responded in 180 seconds. Reconnecting...
                                  [90595.929452] CIFS: VFS: \\192.168.1.164 has not responded in 180 seconds. Reconnecting...
                                  [91527.779489] CIFS: reconnect tcon failed rc = -5
                                  [92852.336732] CIFS: Attempting to mount //192.168.1.164/ioBroker/raspberrypi-Backup
                                  [102312.477613] usb 1-1.4: USB disconnect, device number 3
                                  [102364.471753] usb 1-1.4: new high-speed USB device number 4 using xhci_hcd
                                  [102364.622396] usb 1-1.4: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
                                  [102364.622415] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  [102364.622431] usb 1-1.4: Product: XDS110 (03.00.00.15) Embed with CMSIS-DAP
                                  [102364.622447] usb 1-1.4: Manufacturer: Texas Instruments
                                  [102364.622462] usb 1-1.4: SerialNumber: L430047T
                                  [102364.630957] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                                  [102364.736561] cdc_acm 1-1.4:1.3: ttyACM1: USB ACM device
                                  [102364.839304] hid-generic 0003:0451:BEF3.0002: hiddev96,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.15) Embed with CMSIS-DAP] on usb-0000:01:00.0-1.4/input5
                                  [105736.388275] sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 5 inflight: IN
                                  [105736.388296] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 01 98 1c d8 00 04 00 00
                                  [105736.428200] scsi host0: uas_eh_device_reset_handler start
                                  [105736.579243] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                                  [105736.638521] usb 2-2: Enable of device-initiated U1 failed.
                                  [105736.639608] usb 2-2: Enable of device-initiated U2 failed.
                                  [105736.641040] scsi host0: uas_eh_device_reset_handler success
                                  [106462.774681] usb 1-1.4: USB disconnect, device number 4
                                  [106580.923387] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
                                  [106581.054003] usb 1-1.4: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
                                  [106581.054013] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  [106581.054020] usb 1-1.4: Product: XDS110 (03.00.00.15) Embed with CMSIS-DAP
                                  [106581.054028] usb 1-1.4: Manufacturer: Texas Instruments
                                  [106581.054035] usb 1-1.4: SerialNumber: L430047T
                                  [106581.061485] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                                  [106581.163651] cdc_acm 1-1.4:1.3: ttyACM1: USB ACM device
                                  [106581.267042] hid-generic 0003:0451:BEF3.0003: hiddev96,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.15) Embed with CMSIS-DAP] on usb-0000:01:00.0-1.4/input5
                                  [109084.363354] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [109084.363403] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [109084.363794] FS-Cache: Duplicate cookie detected
                                  [109084.363804] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [109084.363811] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [109084.363818] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [109084.363873] FS-Cache: N-cookie c=c7e80d46 [p=1464acfa fl=2 nc=0 na=1]
                                  [109084.363879] FS-Cache: N-cookie d=d278e209 n=3cded365
                                  [109084.363885] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  [120163.792281] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [120163.792331] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [120163.792753] FS-Cache: Duplicate cookie detected
                                  [120163.792763] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [120163.792771] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [120163.792777] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [120163.792832] FS-Cache: N-cookie c=ff14338a [p=1464acfa fl=2 nc=0 na=1]
                                  [120163.792838] FS-Cache: N-cookie d=d278e209 n=ac1a13b5
                                  [120163.792844] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  [150474.628234] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [150474.628284] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [150474.628621] FS-Cache: Duplicate cookie detected
                                  [150474.628632] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [150474.628639] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [150474.628645] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [150474.628700] FS-Cache: N-cookie c=353ce6ff [p=1464acfa fl=2 nc=0 na=1]
                                  [150474.628707] FS-Cache: N-cookie d=d278e209 n=9865688f
                                  [150474.628713] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  [240476.336313] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [240476.336390] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [240476.336915] FS-Cache: Duplicate cookie detected
                                  [240476.336933] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [240476.336944] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [240476.336955] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [240476.337046] FS-Cache: N-cookie c=ff14338a [p=1464acfa fl=2 nc=0 na=1]
                                  [240476.337057] FS-Cache: N-cookie d=d278e209 n=95d47fa8
                                  [240476.337067] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  [326877.931944] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [326877.931997] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [326877.932404] FS-Cache: Duplicate cookie detected
                                  [326877.932420] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [326877.932428] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [326877.932434] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [326877.932489] FS-Cache: N-cookie c=353ce6ff [p=1464acfa fl=2 nc=0 na=1]
                                  [326877.932496] FS-Cache: N-cookie d=d278e209 n=06d12806
                                  [326877.932502] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  [413279.586343] CIFS: Attempting to mount //192.168.1.164/ioBroker/ioB-Backup/standard/
                                  [413279.586392] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                  [413279.586791] FS-Cache: Duplicate cookie detected
                                  [413279.586802] FS-Cache: O-cookie c=43b5e22b [p=1464acfa fl=222 nc=1 na=1]
                                  [413279.586809] FS-Cache: O-cookie d=d278e209 n=7ec53405
                                  [413279.586816] FS-Cache: O-key=[8] '020001bdc0a801a4'
                                  [413279.586871] FS-Cache: N-cookie c=91c373d7 [p=1464acfa fl=2 nc=0 na=1]
                                  [413279.586878] FS-Cache: N-cookie d=d278e209 n=aa29f327
                                  [413279.586884] FS-Cache: N-key=[8] '020001bdc0a801a4'
                                  pi@raspberrypi4-iob:~ $
                                  • D Digi-Bit
                                    mfg
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    nicht fummeln, sondern 1:1 auf deine andere SSD spielen, dann sollte es auch von da aus starten
                                    ja
                                    D ? 2 Antworten Letzte Antwort
                                      ja
                                      Digi-Bit
                                      ja
                                      ok ^^
                                      Eigentlich hat sich der teil der frage eher auf den 2ten abschnitt des Satzes bezogen und zwar wegen der SSD an USB2 Port, Ob es besser wäre den2er oder 3er Port in Zukunft für die SSD zu benutzen.
                                      Ich gehe aber mal davon aus das der USB 2 Port besser wäre oder habe ich da aus den antworten jetzt was falsches rausgelesen ?
                                      mfg
                                      • D Digi-Bit
                                        ja
                                        ok ^^
                                        mfg
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        für Zigbee ja,
                                        die SSD an USB3, (macht ja keinen Sinn, ne schnelle SSD anzuschliessen, die per USB wieder ausgebremst wird)
                                          ja
                                          Ich Frage mich sowieso, warum man unbedingt für IOB eine 500GB SSD einsetzen will...
                                          Bei mir läuft IOB und Kodi schon seit Jahren auf einer 128 GB SSD, die man gerade zu 10% gefühlt ist und meine Platte hängt an USB3 unter dem Zigbee Stick...da kann ich rebooten was ich will, es wird immer der Stick gefunden und kein Netzwerk gestört.
                                          Übrigens, das blaue USB3 Kabel hängt am PC, für Full-Backups. Kurz umstecken Backup machen, wieder dran stecken Sytem hoch fahren und freuen.
