  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    apollon77A
812 Beiträge 97 Kommentatoren 497.2k Aufrufe 83 Beobachtet
    @dicken
    sudo apt remove node*
    DickenD
    DickenD
    Dicken
    #113
    @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
    @dicken
    Jetzt hat es geklappt aber irgendwie hab ich trotzdem noch die alte Node Version:
    dicken@iobroker-produktiv:~$ curl -fsSL https://deb.nodesource.com/setup_12.x | sudo -E bash -
    ## Installing the NodeSource Node.js 12.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 https://deb.nodesource.com/node_12.x groovy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu groovy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu groovy-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu groovy-security InRelease
    Reading package lists... Done
    ## Confirming "groovy" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/groovy/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x groovy main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x groovy main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Hit:1 http://archive.ubuntu.com/ubuntu groovy InRelease
    Hit:2 https://deb.nodesource.com/node_12.x groovy InRelease
    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    dicken@iobroker-produktiv:~$ sudo apt-get install -y nodejs
    Building dependency tree
    nodejs is already the newest version (12.22.7-deb-1nodesource1).
    The following packages were automatically installed and are no longer required:
      gyp javascript-common libauthen-sasl-perl libc-ares2 libclone-perl
      libdata-dump-perl libencode-locale-perl libfile-basedir-perl
      libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl
      libfont-afm-perl libhtml-form-perl libhtml-format-perl libhtml-parser-perl
      libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
      libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
      libhttp-negotiate-perl libio-html-perl libio-socket-ssl-perl
      libio-stringy-perl libipc-system-simple-perl libjs-inherits
      libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer
      liblwp-mediatypes-perl liblwp-protocol-https-perl libmailtools-perl
      libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
      libssl-dev libtie-ixhash-perl libtimedate-perl libtry-tiny-perl liburi-perl
      libuv1-dev libwww-perl libwww-robotrules-perl libx11-protocol-perl
      libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
      perl-openssl-defaults xdg-utils
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    dicken@iobroker-produktiv:~$ node -v
     v12.20.0
    • DickenD Dicken
      @dicken
      + apt-get update
      + apt-get update
       v12.20.0
      Thomas BraunT
      Thomas BraunT
      #114
      @dicken sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
      sudo apt autoremove
      sudo apt update
      sudo apt policy nodejs
      DickenD 1 Antwort Letzte Antwort
        sudo apt autoremove
        sudo apt update
        DickenD
        DickenD
        Dicken
        #115
        sudo apt autoremove
        sudo apt update
        läuft alles wunderbar durch aber node -v sagt was von v12.20.0
        dicken@iobroker-produktiv:~$ sudo apt policy nodejs
        nodejs:
          Installed: (none)
          Candidate: 12.22.7-deb-1nodesource1
          Version table:
             12.22.7-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x groovy/main amd64 Packages
             12.18.2~dfsg-1ubuntu2 500
                500 http://archive.ubuntu.com/ubuntu groovy/universe amd64 Packages
        v12.20.0
        • DickenD Dicken
          sudo apt autoremove
          sudo apt update
          nodejs:
            Installed: (none)
            Version table:
          v12.20.0
          Thomas BraunT
          Thomas BraunT
          #116
          nodejs: Installed: (none)
          Das ist nicht installiert.
          sudo apt install nodejs
          Und du musst da auch noch von Hand dran rumgefrickelt haben.
          v12.20.0 kann nicht über ein Repo gekommen sein.
          Test:
          which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          DickenD 2 Antworten Letzte Antwort
            Test:
            DickenD
            DickenD
            Dicken
            #117
            Ja das mag sein, zu meinen Anfängen mit iobroker.
            dicken@iobroker-produktiv:~$ sudo apt install nodejs
            The following NEW packages will be installed:
              nodejs
            0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
            Need to get 0 B/18.0 MB of archives.
            After this operation, 93.6 MB of additional disk space will be used.
            Selecting previously unselected package nodejs.
            (Reading database ... 32341 files and directories currently installed.)
            Preparing to unpack .../nodejs_12.22.7-deb-1nodesource1_amd64.deb ...
            Unpacking nodejs (12.22.7-deb-1nodesource1) ...
            Setting up nodejs (12.22.7-deb-1nodesource1) ...
            Processing triggers for man-db (2.9.3-2) ...
            v12.20.0
            dicken@iobroker-produktiv:~$ ^C
            nodejs:
              Installed: 12.22.7-deb-1nodesource1
              Version table:
             *** 12.22.7-deb-1nodesource1 500
            v12.20.0
            Immernoch 12.20.0 😕
              Test:
              DickenD
              DickenD
              Dicken
              #118
              Test:
              dicken@iobroker-produktiv:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
              dicken@iobroker-produktiv:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              /usr/bin/nodejs
              /usr/local/bin/node
              /usr/local/bin/npm
              v12.22.7
              v12.20.0
              6.14.8
              Hit:2 http://archive.ubuntu.com/ubuntu groovy-updates InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu groovy-security InRelease
              Hit:4 https://deb.nodesource.com/node_12.x groovy InRelease
              All packages are up to date.
              Hit:3 https://deb.nodesource.com/node_12.x groovy InRelease
              nodejs:
                Version table:
              v12.20.0
              • DickenD Dicken
                  nodejs
                v12.20.0
                nodejs:
                  Version table:
                v12.20.0
                Immernoch 12.20.0 😕
                Thomas BraunT
                Thomas BraunT
                #119
                apt policy nodejs
                Hatte ich geschrieben, dass das mit sudo eingeleitet wird?
                Immernoch 12.20.0
                Falsche Pfade vom händischen Gefrickel.
                sudo rm /usr/local/bin/node
                sudo rm /usr/local/bin/npm
                sudo reboot
                • DickenD
                  DickenD
                  Dicken
                  schrieb am zuletzt editiert von Dicken
                  #120
                  ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                  Ok versteh ich, hab ich ja eben schon gemacht den Befehl aber der zweite geht nicht:
                  dicken@iobroker-produktiv:~$ sudo rm -/usr/local/bin/node
                  rm: invalid option -- '/'
                  Try 'rm --help' for more information.
                  vermutlich "sudo rm /usr/local/bin/node" ? (also ohne den Bindestrich?)
                  EDIT: Vielen Dank :) Jetzt klappt es :)
                  v12.22.7
                  • DickenD Dicken
                    v12.22.7
                    Thomas BraunT
                    Thomas BraunT
                    #121
                    @dicken
                    Ja, ohne Bindestrich. Da hatte ich überlegt mit einer Option zu arbeiten, dann aber doch wieder gelöscht und den Strich übersehen.
                    • DickenD Dicken
                      v12.22.7
                      Thomas BraunT
                      Thomas BraunT
                      #122
                      @dicken
                      Wie sieht
                      nun aus?
                        @dicken
                        Wie sieht
                        nun aus?
                        DickenD
                        DickenD
                        Dicken
                        #123
                        @dicken
                        Wie sieht
                        nun aus?
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v12.22.7
                        v12.22.7
                        6.14.15
                        Das sieht doch gut aus :)
                        • DickenD Dicken
                          @dicken
                          Wie sieht
                          nun aus?
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v12.22.7
                          v12.22.7
                          6.14.15
                          Thomas BraunT
                          Thomas BraunT
                          #124
                          @dicken
                          Vollständig posten. Alles. Inkl. Eingabezeile.
                            @dicken
                            DickenD
                            DickenD
                            Dicken
                            #125
                            @dicken
                            Hab den vorherigen Beitrag bearbeitet :)
                            • DickenD Dicken
                              @dicken
                              Thomas BraunT
                              Thomas BraunT
                              #126
                              @dicken
                              Da fehlt immer noch was.
                                @dicken
                                DickenD
                                DickenD
                                Dicken
                                #127
                                @dicken
                                Oh, hab nen Fehler in deinem Befehl gefunden, du hast zweimal hintereinander apt update gemacht, das zweite soll ja sicher apt upgrade sein, habs mal angepasst und nochmal durchlaufen lassen:
                                dicken@iobroker-produktiv:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt upgrade && apt policy nodejs
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v12.22.7
                                v12.22.7
                                6.14.15
                                [sudo] password for dicken:
                                Calculating upgrade... Done
                                nodejs:
                                  Version table:
                                • DickenD Dicken
                                  @dicken
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v12.22.7
                                  v12.22.7
                                  6.14.15
                                  nodejs:
                                    Version table:
                                  Thomas BraunT
                                  Thomas BraunT
                                  #128
                                  Nein, das ist bewusst doppelt.
                                  Aber passt schon.
                                  nodejs ist jetzt jedenfalls senkrecht in der richtigen Version im System.
                                    Aber passt schon.
                                    DickenD
                                    DickenD
                                    Dicken
                                    #129
                                    Aber passt schon.
                                    Ok, vielen vielen Dank für deine Hilfe :)
                                    • B
                                      B
                                      backfisch88
                                      schrieb am zuletzt editiert von backfisch88
                                      #130
                                      Hallo
                                      jedes mal (schon öfter probiert), wenn ich auf nodejs 14 upgrade läuft danach der mihome-vacuum Adapter nicht mehr.
                                      Es läuft alles Reibungslos, bis es ein Befehl von IOBroker kommt... nach einigen Minuten ist er wieder verbunden (manchmal auch länger) und das Spiel geht von vorne los
                                      mit node 12.X lief alles normal
                                      Auszug aus dem Log
                                      mihome-vacuum.0
                                      2021-11-18 13:32:51.245	info	Map selected create states...
                                      mihome-vacuum.0
                                      2021-11-18 13:32:50.686	info	settest next timer: not available
                                      mihome-vacuum.0
                                      2021-11-18 13:32:50.159	info	select standard vacuum protocol....
                                      mihome-vacuum.0
                                      2021-11-18 13:32:50.144	warn	No Answer for DeviceModel use model from Config
                                      mihome-vacuum.0
                                      2021-11-18 13:32:50.144	warn	No Answer for DeviceModel use old one
                                      mihome-vacuum.0
                                      2021-11-18 13:32:50.143	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                                      mihome-vacuum.0
                                      2021-11-18 13:32:40.089	info	IOT enabled, create state
                                      mihome-vacuum.0
                                      2021-11-18 13:32:39.827	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                      host.IOBroker
                                      2021-11-18 13:32:37.671	info	instance system.adapter.mihome-vacuum.0 started with pid 14078
                                      host.IOBroker
                                      2021-11-18 13:32:36.632	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                      host.IOBroker
                                      2021-11-18 13:32:36.631	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                      host.IOBroker
                                      2021-11-18 13:32:36.624	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGBUS
                                      mihome-vacuum.0
                                      2021-11-18 13:31:26.406	info	trigger cleaning segment 17
                                      mihome-vacuum.0
                                      2021-11-18 13:31:16.313	info	create state for carpet_mode
                                      mihome-vacuum.0
                                      2021-11-18 13:31:15.114	info	create states for mop
                                      mihome-vacuum.0
                                      2021-11-18 13:31:15.103	info	create states for water box
                                      mihome-vacuum.0
                                      2021-11-18 13:31:15.087	info	change states from State control.fan_power
                                      mihome-vacuum.0
                                      2021-11-18 13:31:15.068	info	Map selected create states...
                                      mihome-vacuum.0
                                      2021-11-18 13:31:14.463	info	settest next timer: not available
                                      mihome-vacuum.0
                                      2021-11-18 13:31:13.932	info	select standard vacuum protocol....
                                      mihome-vacuum.0
                                      2021-11-18 13:31:13.815	info	IOT enabled, create state
                                      mihome-vacuum.0
                                      2021-11-18 13:31:13.539	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                      mihome-vacuum.0 | 2021-11-18 12:49:49.814 | info | Map selected create states...
                                      mihome-vacuum.0 | 2021-11-18 12:49:49.125 | info | settest next timer: not available
                                      mihome-vacuum.0 | 2021-11-18 12:49:48.595 | info | select standard vacuum protocol....
                                      mihome-vacuum.0 | 2021-11-18 12:49:48.569 | warn | No Answer for DeviceModel use model from Config
                                      mihome-vacuum.0 | 2021-11-18 12:49:48.568 | warn | No Answer for DeviceModel use old one
                                      mihome-vacuum.0 | 2021-11-18 12:49:48.567 | warn | YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                                      mihome-vacuum.0 | 2021-11-18 12:49:38.508 | info | IOT enabled, create state
                                      mihome-vacuum.0 | 2021-11-18 12:49:38.255 | info | starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                      host.IOBroker | 2021-11-18 12:49:36.130 | info | instance system.adapter.mihome-vacuum.0 started with pid 6957
                                      host.IOBroker | 2021-11-18 12:49:35.072 | info | Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                      host.IOBroker | 2021-11-18 12:49:35.071 | info | instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                      host.IOBroker | 2021-11-18 12:49:35.070 | warn | instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                      host.IOBroker | 2021-11-18 12:49:35.063 | error | Caught by controller[0]: free(): invalid pointer
                                      mihome-vacuum.0 | 2021-11-18 12:49:15.488 | info | trigger cleaning segment 17
                                      mihome-vacuum.0 | 2021-11-18 12:49:00.086 | info | create state for carpet_mode
                                      mihome-vacuum.0 | 2021-11-18 12:48:58.907 | info | create states for mop
                                      mihome-vacuum.0 | 2021-11-18 12:48:58.904 | info | create states for water box
                                      mihome-vacuum.0 | 2021-11-18 12:48:58.872 | info | change states from State control.fan_power
                                      mihome-vacuum.0 | 2021-11-18 12:48:58.839 | info | Map selected create states..
                                      jemand eine Idee?
                                      updated über
                                      curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                      iobroker fix
                                      zusätzlich:
                                      iobroker rebuild ioBroker.mihome-vacuum
                                      iobroker rebuild ioBroker.mihome-vacuum --install
                                      und ein rebuild in: opt/iobroker/
                                      und iobroker stop && sudo apt update && sudo apt upgrade -y && iobroker start
                                      und in github ein issue aufgemacht, wo ich hierhin verwiesen wurde :)
                                      und nochmal im DEBUG
                                      mihome-vacuum.0
                                      2021-11-18 13:39:10.415	debug	load Map creator... true
                                      mihome-vacuum.0
                                      2021-11-18 13:39:10.257	debug	Schedule restart: 0 0,1 * * *
                                      mihome-vacuum.0
                                      2021-11-18 13:39:10.172	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                      mihome-vacuum.0
                                      2021-11-18 13:39:09.903	debug	Plugin sentry Initialize Plugin (enabled=true)
                                      mihome-vacuum.0
                                      2021-11-18 13:39:06.008	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0
                                      2021-11-18 13:39:06.007	debug	Plugin sentry destroyed
                                      mihome-vacuum.0
                                      2021-11-18 13:39:06.006	info	terminating
                                      mihome-vacuum.0
                                      2021-11-18 13:39:06.005	error	Socket Close
                                      mihome-vacuum.0
                                      2021-11-18 13:39:05.799	error	undefined
                                      mihome-vacuum.0
                                      2021-11-18 13:39:05.798	error	unhandled promise rejection: undefined
                                      mihome-vacuum.0
                                      2021-11-18 13:39:05.798	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0
                                      2021-11-18 13:39:05.796	debug	MIIO Receive Timeout for "app_segment_clean" <<<
                                      mihome-vacuum.0
                                      2021-11-18 13:39:04.078	debug	Message= {"id":17,"method":"get_multi_maps_list"}
                                      mihome-vacuum.0
                                      2021-11-18 13:39:04.077	debug	ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                                      mihome-vacuum.0
                                      2021-11-18 13:39:04.076	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                      mihome-vacuum.0
                                      2021-11-18 13:39:03.794	debug	Message= {"id":16,"method":"app_segment_clean","params":[17]}
                                      mihome-vacuum.0
                                      2021-11-18 13:39:03.793	info	trigger cleaning segment 17
                                      mihome-vacuum.0
                                      2021-11-18 13:39:03.792	debug	start Cleaning: 18 MObj: {"command":"cleanSegments","message":"17","from":"system.adapter.mihome-vacuum.0","_id":62189570,"segments":[17],"channels":["mihome-vacuum.0.rooms.73001006380"]}
                                      mihome-vacuum.0
                                      2021-11-18 13:39:03.791	debug	We are in onMessage:{"command":"cleanSegments","message":{"segments":[17],"channels":["mihome-vacuum.0.rooms.73001006380"]},"from":"system.adapter.mihome-vacuum.0","_id":62189570}
                                      mihome-vacuum.0
                                      2021-11-18 13:39:03.784	debug	sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                      mihome-vacuum.0
                                      2021-11-18 13:39:03.779	debug	command: roomClean parent: 73001006380
                                      S apollon77A DiginixD 3 Antworten Letzte Antwort
                                      • B backfisch88
                                        Hallo
                                        Auszug aus dem Log
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        host.IOBroker
                                        host.IOBroker
                                        host.IOBroker
                                        host.IOBroker
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        jemand eine Idee?
                                        updated über
                                        iobroker fix
                                        zusätzlich:
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        mihome-vacuum.0
                                        S
                                        S
                                        SSW-mcor
                                        #131
                                        Hab grad auf meinen Windows-Systemen die empfohlene Version "v14.18.1" drauf - bis auf dass die Konsolen danach wie immer nicht mehr gingen, alles gut 😀
                                        • B backfisch88
                                          Hallo
                                          Auszug aus dem Log
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          host.IOBroker
                                          host.IOBroker
                                          host.IOBroker
                                          host.IOBroker
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          jemand eine Idee?
                                          updated über
                                          iobroker fix
                                          zusätzlich:
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          mihome-vacuum.0
                                          apollon77A
                                          apollon77A
                                          #132
                                          @backfisch88 Ich glaube der Fehler hier sieht jetzt eher aus wie https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/428
                                          83.9k
