  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    apollon77A
812 Beiträge 97 Kommentatoren 514.7k Aufrufe 83 Beobachtet
    @dicken sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
    sudo apt --fix-broken install
    Dann nochmal wie oben.
    DickenD
    DickenD
    Dicken
    #111
    @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
    Das geht leider auch nich:
    dicken@iobroker-produktiv:~$ sudo apt --fix-broken install
    Reading package lists... Done
    Building dependency tree
    Correcting dependencies... Done
    The following packages were automatically installed and are no longer required:
      gyp javascript-common libauthen-sasl-perl libc-ares2 libclone-perl
      libdata-dump-perl libencode-locale-perl libfile-basedir-perl
      libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl
      libfont-afm-perl libhtml-form-perl libhtml-format-perl libhtml-parser-perl
      libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
      libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
      libhttp-negotiate-perl libio-html-perl libio-socket-ssl-perl
      libio-stringy-perl libipc-system-simple-perl libjs-inherits
      libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer
      liblwp-mediatypes-perl liblwp-protocol-https-perl libmailtools-perl
      libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
      libssl-dev libtie-ixhash-perl libtimedate-perl libtry-tiny-perl liburi-perl
      libuv1-dev libwww-perl libwww-robotrules-perl libx11-protocol-perl
      libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl node-abbrev
      node-ajv node-ansi node-ansi-align node-ansi-regex node-ansi-styles
      node-ansistyles node-aproba node-archy node-are-we-there-yet node-asap
      node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4
      node-balanced-match node-bcrypt-pbkdf node-bl node-bluebird node-boxen
      node-brace-expansion node-builtin-modules node-builtins node-cacache
      node-call-limit node-camelcase node-caseless node-chalk node-chownr
      node-ci-info node-cli-boxes node-cliui node-clone node-co node-color-convert
      node-color-name node-colors node-columnify node-combined-stream
      node-concat-map node-concat-stream node-config-chain node-configstore
      node-console-control-strings node-copy-concurrently node-core-util-is
      node-cross-spawn node-crypto-random-string node-cyclist node-dashdash
      node-debbundle-es-to-primitive node-debug node-decamelize
      node-decompress-response node-deep-extend node-defaults
      node-define-properties node-delayed-stream node-delegates node-detect-indent
      node-detect-newline node-dot-prop node-duplexer3 node-duplexify
      node-ecc-jsbn node-editor node-encoding node-end-of-stream node-err-code
      node-errno node-es6-promise node-escape-string-regexp node-execa node-extend
      node-extsprintf node-fast-deep-equal node-find-up node-flush-write-stream
      node-forever-agent node-form-data node-from2 node-fs-vacuum
      node-fs-write-stream-atomic node-fs.realpath node-function-bind node-gauge
      node-genfun node-get-caller-file node-get-stream node-getpass node-glob
      node-got node-graceful-fs node-har-schema node-har-validator node-has-flag
      node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode
      node-hosted-git-info node-http-signature node-iconv-lite node-iferr
      node-import-lazy node-imurmurhash node-inflight node-inherits node-ini
      node-invert-kv node-ip node-ip-regex node-is-npm node-is-obj node-is-object
      node-is-path-inside node-is-plain-obj node-is-retry-allowed node-is-stream
      node-is-typedarray node-isarray node-isexe node-isstream node-isurl
      node-jsbn node-json-parse-better-errors node-json-schema
      node-json-schema-traverse node-json-stable-stringify
      node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
      node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx
      node-locate-path node-lockfile node-lodash node-lodash-packages
      node-lowercase-keys node-lru-cache node-make-dir node-mem node-mime
      node-mime-types node-mimic-fn node-mimic-response node-minimatch
      node-minimist node-mississippi node-mkdirp node-move-concurrently node-ms
      node-mute-stream node-nopt node-normalize-package-data node-npm-bundled
      node-npm-package-arg node-npm-run-path node-npmlog node-number-is-nan
      node-oauth-sign node-object-assign node-once node-opener node-os-locale
      node-os-tmpdir node-osenv node-p-cancelable node-p-finally node-p-is-promise
      node-p-limit node-p-locate node-p-timeout node-package-json
      node-parallel-transform node-path-exists node-path-is-absolute
      node-path-is-inside node-performance-now node-pify node-prepend-http
      node-process-nextick-args node-promise-inflight node-promise-retry
      node-promzard node-proto-list node-prr node-pseudomap node-psl node-pump
      node-pumpify node-punycode node-qs node-qw node-rc node-read
      node-read-package-json node-readable-stream node-registry-auth-token
      node-registry-url node-request node-require-directory
      node-require-main-filename node-resolve node-resolve-from node-retry
      node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff
      node-set-blocking node-sha node-shebang-command node-shebang-regex
      node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
      node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids
      node-sshpk node-ssri node-stream-each node-stream-iterate node-stream-shift
      node-strict-uri-encode node-string-decoder node-string-width node-strip-ansi
      node-strip-eof node-strip-json-comments node-supports-color node-tar
      node-term-size node-text-table node-through node-through2 node-timed-out
      node-tough-cookie node-tunnel-agent node-tweetnacl node-typedarray
      node-typedarray-to-buffer node-uid-number node-unique-filename
      node-unique-string node-unpipe node-uri-js node-url-parse-lax
      node-url-to-options node-util-deprecate node-uuid
      node-validate-npm-package-license node-validate-npm-package-name node-verror
      node-wcwidth.js node-which node-which-module node-wide-align
      node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
      node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
      node-yargs-parser nodejs-doc perl-openssl-defaults xdg-utils
    Use 'sudo apt autoremove' to remove them.
    The following additional packages will be installed:
      nodejs
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/18.0 MB of archives.
    After this operation, 93.5 MB of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    (Reading database ... 39050 files and directories currently installed.)
    Preparing to unpack .../nodejs_12.22.7-deb-1nodesource1_amd64.deb ...
    Unpacking nodejs (12.22.7-deb-1nodesource1) over (12.18.2~dfsg-1ubuntu2) ...
    dpkg: error processing archive /var/cache/apt/archives/nodejs_12.22.7-deb-1nodesource1_amd64.deb (--unpack):
     trying to overwrite '/usr/share/doc/nodejs/api/tty.json.gz', which is also in package nodejs-doc 12.18.2~dfsg-1ubuntu2
    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    • DickenD Dicken
        nodejs
        nodejs
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #112
      @dicken
      sudo apt remove node*
      DickenD 1 Antwort Letzte Antwort
        @dicken
        DickenD
        DickenD
        Dicken
        #113
        @dicken
        Jetzt hat es geklappt aber irgendwie hab ich trotzdem noch die alte Node Version:
        dicken@iobroker-produktiv:~$ curl -fsSL https://deb.nodesource.com/setup_12.x | sudo -E bash -
        ## Installing the NodeSource Node.js 12.x repo...
        ## Populating apt-get cache...
        + apt-get update
        Hit:1 https://deb.nodesource.com/node_12.x groovy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu groovy InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu groovy-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu groovy-security InRelease
        ## Confirming "groovy" is supported...
        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/groovy/Release'
        ## Adding the NodeSource signing key to your keyring...
        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
        ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x groovy main' > /etc/apt/sources.list.d/nodesource.list
        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x groovy main' >> /etc/apt/sources.list.d/nodesource.list
        ## Running `apt-get update` for you...
        + apt-get update
        Hit:1 http://archive.ubuntu.com/ubuntu groovy InRelease
        Hit:2 https://deb.nodesource.com/node_12.x groovy InRelease
        ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
        ## You may also need development tools to build native addons:
             sudo apt-get install gcc g++ make
        ## To install the Yarn package manager, run:
             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
             sudo apt-get update && sudo apt-get install yarn
        dicken@iobroker-produktiv:~$ sudo apt-get install -y nodejs
        nodejs is already the newest version (12.22.7-deb-1nodesource1).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        dicken@iobroker-produktiv:~$ node -v
         v12.20.0
        • DickenD Dicken
          @dicken
          + apt-get update
          + apt-get update
           v12.20.0
          Thomas BraunT
          Thomas BraunT
          #114
          sudo apt autoremove
          sudo apt update
          sudo apt policy nodejs
            sudo apt autoremove
            sudo apt update
            DickenD
            DickenD
            Dicken
            #115
            sudo apt autoremove
            sudo apt update
            läuft alles wunderbar durch aber node -v sagt was von v12.20.0
            dicken@iobroker-produktiv:~$ sudo apt policy nodejs
            nodejs:
              Installed: (none)
              Candidate: 12.22.7-deb-1nodesource1
              Version table:
                 12.22.7-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x groovy/main amd64 Packages
                 12.18.2~dfsg-1ubuntu2 500
                    500 http://archive.ubuntu.com/ubuntu groovy/universe amd64 Packages
            v12.20.0
            • DickenD Dicken
              sudo apt autoremove
              sudo apt update
              nodejs:
                Installed: (none)
                Version table:
              v12.20.0
              Thomas BraunT
              Thomas BraunT
              #116
              nodejs: Installed: (none)
              Das ist nicht installiert.
              sudo apt install nodejs
              Und du musst da auch noch von Hand dran rumgefrickelt haben.
              v12.20.0 kann nicht über ein Repo gekommen sein.
              Test:
              which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              DickenD 2 Antworten Letzte Antwort
                Test:
                DickenD
                DickenD
                Dicken
                #117
                Ja das mag sein, zu meinen Anfängen mit iobroker.
                dicken@iobroker-produktiv:~$ sudo apt install nodejs
                The following NEW packages will be installed:
                  nodejs
                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                After this operation, 93.6 MB of additional disk space will be used.
                Selecting previously unselected package nodejs.
                (Reading database ... 32341 files and directories currently installed.)
                Unpacking nodejs (12.22.7-deb-1nodesource1) ...
                Setting up nodejs (12.22.7-deb-1nodesource1) ...
                Processing triggers for man-db (2.9.3-2) ...
                v12.20.0
                dicken@iobroker-produktiv:~$ ^C
                nodejs:
                  Installed: 12.22.7-deb-1nodesource1
                  Version table:
                 *** 12.22.7-deb-1nodesource1 500
                v12.20.0
                Immernoch 12.20.0 😕
                  Test:
                  DickenD
                  DickenD
                  Dicken
                  #118
                  Test:
                  dicken@iobroker-produktiv:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  dicken@iobroker-produktiv:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                  /usr/bin/nodejs
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  v12.22.7
                  v12.20.0
                  6.14.8
                  Hit:2 http://archive.ubuntu.com/ubuntu groovy-updates InRelease
                  Hit:3 http://archive.ubuntu.com/ubuntu groovy-security InRelease
                  Hit:4 https://deb.nodesource.com/node_12.x groovy InRelease
                  All packages are up to date.
                  Hit:3 https://deb.nodesource.com/node_12.x groovy InRelease
                  nodejs:
                    Version table:
                  v12.20.0
                  • DickenD Dicken
                      nodejs
                    v12.20.0
                    nodejs:
                      Version table:
                    v12.20.0
                    Immernoch 12.20.0 😕
                    Thomas BraunT
                    Thomas BraunT
                    #119
                    apt policy nodejs
                    Hatte ich geschrieben, dass das mit sudo eingeleitet wird?
                    Immernoch 12.20.0
                    Falsche Pfade vom händischen Gefrickel.
                    sudo rm /usr/local/bin/node
                    sudo rm /usr/local/bin/npm
                    sudo reboot
                    • DickenD
                      DickenD
                      Dicken
                      schrieb am zuletzt editiert von Dicken
                      #120
                      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                      Ok versteh ich, hab ich ja eben schon gemacht den Befehl aber der zweite geht nicht:
                      dicken@iobroker-produktiv:~$ sudo rm -/usr/local/bin/node
                      rm: invalid option -- '/'
                      Try 'rm --help' for more information.
                      vermutlich "sudo rm /usr/local/bin/node" ? (also ohne den Bindestrich?)
                      EDIT: Vielen Dank :) Jetzt klappt es :)
                      v12.22.7
                      • DickenD Dicken
                        v12.22.7
                        Thomas BraunT
                        Thomas BraunT
                        #121
                        @dicken
                        Ja, ohne Bindestrich. Da hatte ich überlegt mit einer Option zu arbeiten, dann aber doch wieder gelöscht und den Strich übersehen.
                        • DickenD Dicken
                          v12.22.7
                          Thomas BraunT
                          Thomas BraunT
                          #122
                          @dicken
                          Wie sieht
                          nun aus?
                            @dicken
                            Wie sieht
                            nun aus?
                            DickenD
                            DickenD
                            Dicken
                            #123
                            @dicken
                            Wie sieht
                            nun aus?
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.7
                            v12.22.7
                            6.14.15
                            Das sieht doch gut aus :)
                            • DickenD Dicken
                              @dicken
                              Wie sieht
                              nun aus?
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v12.22.7
                              v12.22.7
                              6.14.15
                              Thomas BraunT
                              Thomas BraunT
                              #124
                              @dicken
                              Vollständig posten. Alles. Inkl. Eingabezeile.
                                @dicken
                                DickenD
                                DickenD
                                Dicken
                                #125
                                @dicken
                                Hab den vorherigen Beitrag bearbeitet :)
                                • DickenD Dicken
                                  @dicken
                                  Thomas BraunT
                                  Thomas BraunT
                                  #126
                                  @dicken
                                  Da fehlt immer noch was.
                                    @dicken
                                    DickenD
                                    DickenD
                                    Dicken
                                    #127
                                    @dicken
                                    Oh, hab nen Fehler in deinem Befehl gefunden, du hast zweimal hintereinander apt update gemacht, das zweite soll ja sicher apt upgrade sein, habs mal angepasst und nochmal durchlaufen lassen:
                                    dicken@iobroker-produktiv:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt upgrade && apt policy nodejs
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v12.22.7
                                    v12.22.7
                                    6.14.15
                                    [sudo] password for dicken:
                                    Calculating upgrade... Done
                                    nodejs:
                                      Version table:
                                    • DickenD Dicken
                                      @dicken
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v12.22.7
                                      v12.22.7
                                      6.14.15
                                      nodejs:
                                        Version table:
                                      Thomas BraunT
                                      Thomas BraunT
                                      #128
                                      Nein, das ist bewusst doppelt.
                                      Aber passt schon.
                                      nodejs ist jetzt jedenfalls senkrecht in der richtigen Version im System.
                                        Aber passt schon.
                                        DickenD
                                        DickenD
                                        Dicken
                                        #129
                                        Aber passt schon.
                                        Ok, vielen vielen Dank für deine Hilfe :)
                                        • B
                                          B
                                          backfisch88
                                          schrieb am zuletzt editiert von backfisch88
                                          #130
                                          Hallo
                                          jedes mal (schon öfter probiert), wenn ich auf nodejs 14 upgrade läuft danach der mihome-vacuum Adapter nicht mehr.
                                          Es läuft alles Reibungslos, bis es ein Befehl von IOBroker kommt... nach einigen Minuten ist er wieder verbunden (manchmal auch länger) und das Spiel geht von vorne los
                                          mit node 12.X lief alles normal
                                          Auszug aus dem Log
                                          mihome-vacuum.0
                                          2021-11-18 13:32:51.245	info	Map selected create states...
                                          mihome-vacuum.0
                                          2021-11-18 13:32:50.686	info	settest next timer: not available
                                          mihome-vacuum.0
                                          2021-11-18 13:32:50.159	info	select standard vacuum protocol....
                                          mihome-vacuum.0
                                          2021-11-18 13:32:50.144	warn	No Answer for DeviceModel use model from Config
                                          mihome-vacuum.0
                                          2021-11-18 13:32:50.144	warn	No Answer for DeviceModel use old one
                                          mihome-vacuum.0
                                          2021-11-18 13:32:50.143	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                                          mihome-vacuum.0
                                          2021-11-18 13:32:40.089	info	IOT enabled, create state
                                          mihome-vacuum.0
                                          2021-11-18 13:32:39.827	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                          host.IOBroker
                                          2021-11-18 13:32:37.671	info	instance system.adapter.mihome-vacuum.0 started with pid 14078
                                          host.IOBroker
                                          2021-11-18 13:32:36.632	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          host.IOBroker
                                          2021-11-18 13:32:36.631	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                          host.IOBroker
                                          2021-11-18 13:32:36.624	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGBUS
                                          mihome-vacuum.0
                                          2021-11-18 13:31:26.406	info	trigger cleaning segment 17
                                          mihome-vacuum.0
                                          2021-11-18 13:31:16.313	info	create state for carpet_mode
                                          mihome-vacuum.0
                                          2021-11-18 13:31:15.114	info	create states for mop
                                          mihome-vacuum.0
                                          2021-11-18 13:31:15.103	info	create states for water box
                                          mihome-vacuum.0
                                          2021-11-18 13:31:15.087	info	change states from State control.fan_power
                                          mihome-vacuum.0
                                          2021-11-18 13:31:15.068	info	Map selected create states...
                                          mihome-vacuum.0
                                          2021-11-18 13:31:14.463	info	settest next timer: not available
                                          mihome-vacuum.0
                                          2021-11-18 13:31:13.932	info	select standard vacuum protocol....
                                          mihome-vacuum.0
                                          2021-11-18 13:31:13.815	info	IOT enabled, create state
                                          mihome-vacuum.0
                                          2021-11-18 13:31:13.539	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                          mihome-vacuum.0 | 2021-11-18 12:49:49.814 | info | Map selected create states...
                                          mihome-vacuum.0 | 2021-11-18 12:49:49.125 | info | settest next timer: not available
                                          mihome-vacuum.0 | 2021-11-18 12:49:48.595 | info | select standard vacuum protocol....
                                          mihome-vacuum.0 | 2021-11-18 12:49:48.569 | warn | No Answer for DeviceModel use model from Config
                                          mihome-vacuum.0 | 2021-11-18 12:49:48.568 | warn | No Answer for DeviceModel use old one
                                          mihome-vacuum.0 | 2021-11-18 12:49:48.567 | warn | YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                                          mihome-vacuum.0 | 2021-11-18 12:49:38.508 | info | IOT enabled, create state
                                          mihome-vacuum.0 | 2021-11-18 12:49:38.255 | info | starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                          host.IOBroker | 2021-11-18 12:49:36.130 | info | instance system.adapter.mihome-vacuum.0 started with pid 6957
                                          host.IOBroker | 2021-11-18 12:49:35.072 | info | Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          host.IOBroker | 2021-11-18 12:49:35.071 | info | instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                          host.IOBroker | 2021-11-18 12:49:35.070 | warn | instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                          host.IOBroker | 2021-11-18 12:49:35.063 | error | Caught by controller[0]: free(): invalid pointer
                                          mihome-vacuum.0 | 2021-11-18 12:49:15.488 | info | trigger cleaning segment 17
                                          mihome-vacuum.0 | 2021-11-18 12:49:00.086 | info | create state for carpet_mode
                                          mihome-vacuum.0 | 2021-11-18 12:48:58.907 | info | create states for mop
                                          mihome-vacuum.0 | 2021-11-18 12:48:58.904 | info | create states for water box
                                          mihome-vacuum.0 | 2021-11-18 12:48:58.872 | info | change states from State control.fan_power
                                          mihome-vacuum.0 | 2021-11-18 12:48:58.839 | info | Map selected create states..
                                          jemand eine Idee?
                                          updated über
                                          curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                          iobroker fix
                                          zusätzlich:
                                          iobroker rebuild ioBroker.mihome-vacuum
                                          iobroker rebuild ioBroker.mihome-vacuum --install
                                          und ein rebuild in: opt/iobroker/
                                          und iobroker stop && sudo apt update && sudo apt upgrade -y && iobroker start
                                          und in github ein issue aufgemacht, wo ich hierhin verwiesen wurde :)
                                          und nochmal im DEBUG
                                          mihome-vacuum.0
                                          2021-11-18 13:39:10.415	debug	load Map creator... true
                                          mihome-vacuum.0
                                          2021-11-18 13:39:10.257	debug	Schedule restart: 0 0,1 * * *
                                          mihome-vacuum.0
                                          2021-11-18 13:39:10.172	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
                                          mihome-vacuum.0
                                          2021-11-18 13:39:09.903	debug	Plugin sentry Initialize Plugin (enabled=true)
                                          mihome-vacuum.0
                                          2021-11-18 13:39:06.008	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          mihome-vacuum.0
                                          2021-11-18 13:39:06.007	debug	Plugin sentry destroyed
                                          mihome-vacuum.0
                                          2021-11-18 13:39:06.006	info	terminating
                                          mihome-vacuum.0
                                          2021-11-18 13:39:06.005	error	Socket Close
                                          mihome-vacuum.0
                                          2021-11-18 13:39:05.799	error	undefined
                                          mihome-vacuum.0
                                          2021-11-18 13:39:05.798	error	unhandled promise rejection: undefined
                                          mihome-vacuum.0
                                          2021-11-18 13:39:05.798	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          mihome-vacuum.0
                                          2021-11-18 13:39:05.796	debug	MIIO Receive Timeout for "app_segment_clean" <<<
                                          mihome-vacuum.0
                                          2021-11-18 13:39:04.078	debug	Message= {"id":17,"method":"get_multi_maps_list"}
                                          mihome-vacuum.0
                                          2021-11-18 13:39:04.077	debug	ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                                          mihome-vacuum.0
                                          2021-11-18 13:39:04.076	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                          mihome-vacuum.0
                                          2021-11-18 13:39:03.794	debug	Message= {"id":16,"method":"app_segment_clean","params":[17]}
                                          mihome-vacuum.0
                                          2021-11-18 13:39:03.793	info	trigger cleaning segment 17
                                          mihome-vacuum.0
                                          2021-11-18 13:39:03.792	debug	start Cleaning: 18 MObj: {"command":"cleanSegments","message":"17","from":"system.adapter.mihome-vacuum.0","_id":62189570,"segments":[17],"channels":["mihome-vacuum.0.rooms.73001006380"]}
                                          mihome-vacuum.0
                                          2021-11-18 13:39:03.791	debug	We are in onMessage:{"command":"cleanSegments","message":{"segments":[17],"channels":["mihome-vacuum.0.rooms.73001006380"]},"from":"system.adapter.mihome-vacuum.0","_id":62189570}
                                          mihome-vacuum.0
                                          2021-11-18 13:39:03.784	debug	sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0
                                          2021-11-18 13:39:03.779	debug	command: roomClean parent: 73001006380
                                          S apollon77A DiginixD 3 Antworten Letzte Antwort
                                          84.0k
