  4. [Gelöst] Upnp-Adapter: Überlauf an Meldungen
    5.6k
    1.5k
upnp adapter
12 Beiträge 6 Kommentatoren 831 Aufrufe 6 Watching
  • qqolliQ Offline
    qqolliQ Offline
    qqolli
    schrieb am zuletzt editiert von qqolli
    bekomme seit ein paar Tagen hunderte von Meldungen des upnp.0-Adapters (s. unten). Weiß jemand, warum das so ist und wie man es ggf. "abschalten" kann?
    upnp.0
    2021-08-17 10:53:27.530	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.IdleDisconnectTime" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:27.455	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.UpnpControlEnabled" has to be type "boolean" but received type "string"
    upnp.0
    2021-08-17 10:53:27.394	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.RoutedBridgedModeBoth" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:27.170	info	State value to set for "upnp.0.WANConnectionDevice_-_FRITZ!Box_7490.WANDevice.WANConnectionDevice.WANIPConnection.Uptime" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:27.061	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.Layer1UpstreamMaxBitRate" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:26.993	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.Layer1DownstreamMaxBitRate" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.792	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.ByteSendRate" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.771	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.ByteReceiveRate" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.704	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.PacketSendRate" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.680	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.PacketReceiveRate" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.620	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesSent" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.602	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesReceived" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.586	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.AutoDisconnectTime" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.523	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.IdleDisconnectTime" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:25.422	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.UpnpControlEnabled" has to be type "boolean" but received type "string"
    upnp.0
    2021-08-17 10:53:25.359	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.RoutedBridgedModeBoth" has to be type "number" but received type "string"
    upnp.0
    2021-08-17 10:53:11.767	info	Auto discover: true
    upnp.0
    2021-08-17 10:53:11.688	info	starting. Version 1.0.19 in /opt/iobroker/node_modules/iobroker.upnp, node: v12.22.5, js-controller: 3.3.15
    • qqolliQ qqolli
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      upnp.0
      @qqolli
      Adapter stoppen, Datenpunkte löschen, Adapter starten.
      Wenn es wieder kommt: Issue auf GitHub eröffnen.
      qqolliQ 1 Antwort Letzte Antwort
        @qqolli
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        Upnp-Instanz angehalten, aber die DP unter dem Reiter Objekte lassen sich nicht löschen:
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          Das Problem ist das die Objekte nicht so angelegt werden wie es der JS controller erwartet, deshalb kommen folgerichtig diese Meldungen.
          Da es aber bedingt durch den Aufbau des Adapters nicht möglich ist das zu ändern, bleibt das so.
          Eigentlich ist dafür ein Flag vorgesehen das gesetzt werden kann, was ich auch getan habe. Das scheint jedoch nicht zu funktionieren wenn die Meldungen immer noch kommen.
          @qqolli sagte in Upnp-Adapter: Überlauf an Meldungen:
          Das ist nicht gut. Kannst prüfen ob das auf alle Objekte zutrifft oder nur bestimmte die dann das Löschen verhindern.
          Also von oben her im Baum anfangen zu löschen und dann immer eine ebene tiefer gehen.
          Persönlicher Support
          Spenden -> paypal.me/J3YC33
          qqolliQ 2 Antworten Letzte Antwort
          • Jey CeeJ Jey Cee
            qqolliQ Offline
            qqolliQ Offline
            qqolli
            @jey-cee
            So, habe mal alles neu gestartet, den Browsercache gelöscht, etc. und nach dem stippen der Instanz konne ich auch alle DP löschen.
            Bevor ich den Adapter wieder starte, sind diese Einstellungen soweit ok?:
            • qqolliQ qqolli
              @jey-cee
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              @qqolli Ja
              • Jey CeeJ Jey Cee
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                @jey-cee
                Prima, genau das hat geholfen. Danke.
                • P Offline
                  Pahan
                  @jey-cee
                  ich hatte ebenfalls die DP gelöscht, anschließend den Adapter neu gestartet und die Geräte neu eingelesen. Die DP wurden vom Adapter neu angelegt, aber die Fehlermeldung kommt dennoch. Wobei nachvollziehen kann ich das nicht, denn die DP sind eigentlich vom Typ "number", sowie der Adapter dies auch erwartet:
                    "type": "state",
                    "common": {
                      "name": "ByteReceiveRate",
                      "type": "number",
                      "role": "state",
                      "read": true,
                      "write": true
                    "native": {
                      "sendEvents": "no",
                      "allowedValues": [],
                      "defaultValue": "0"
                    "from": "system.adapter.upnp.0",
                    "user": "system.user.admin",
                    "ts": 1635180021948,
                    "_id": "upnp.0.WANDevice_-_FRITZ!Box_6591_Cable_(lgi).WANDevice.WANCommonInterfaceConfig.ByteReceiveRate",
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                      "owner": "system.user.admin",
                  da bringt auch das manuelle Ändern nichts.
                  Gibt es noch etwas, was probieren könnte?
                  • P Pahan
                    @jey-cee
                      "type": "state",
                      "common": {
                        "type": "number",
                        "role": "state",
                        "read": true,
                        "write": true
                      "native": {
                        "sendEvents": "no",
                        "defaultValue": "0"
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    sigi234S Online
                    sigi234S Online
                    @pahan sagte in [Gelöst] Upnp-Adapter: Überlauf an Meldungen:
                    Adapter auf error stellen
                    P 1 Antwort Letzte Antwort
                    • sigi234S sigi234
                      Pahan
                      @sigi234 said in [Gelöst] Upnp-Adapter: Überlauf an Meldungen:
                      steht bereits auf Error, nur gelöst ist das Problem ja nicht, sondern nur "verstummt". Ich würde es gerne sauber lösen.
                      • P Pahan
                        sigi234S Online
                        sigi234S Online
                        Jupp, lösen kann das nur der Entwickler
                        • H Offline
                          hini2001
                          Guten Morgen und frohes neues Jahr. Seit dem Update auf JS-Controller 3.3.22 habe ich das selbe Problem u.a. beim UPNP Adapter. Ein Instanz stoppen. Löschen der DPs und Neustarten, sowie neu-anlegen der DPs hat das Problem nicht behoben. Zusätzlich wie oben beschrieben, stimmen die DP-Typen eigentlich mit dem geforderten überein. Irgendwer noch ne Idee? Bei GitHub gibt es ein geschlossenen Issue dazu (aber andere JS Controller Version). Da keiner dort ein Issue eröffnet hat, hat irgendwer ne Lösung? (Und ich meine nicht die LogStufe Error idee. :-D )
                          Vielen Dank und erneut ein FROHES NEUES!!!!
                          Beispiel Log Einträge:
                          upnp.0
                          2022-01-02 10:55:11.085	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.Layer1UpstreamMaxBitRate" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:11.024	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.Layer1DownstreamMaxBitRate" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.910	info	State value to set for "upnp.0.WANConnectionDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANConnectionDevice.WANIPConnection.Uptime" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.852	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.ByteSendRate" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.790	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.ByteReceiveRate" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.739	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.PacketSendRate" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.684	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.PacketReceiveRate" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.620	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.TotalBytesSent" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.560	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.TotalBytesReceived" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.509	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.AutoDisconnectTime" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.451	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.IdleDisconnectTime" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.359	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.UpnpControlEnabled" has to be type "boolean" but received type "string"
                          upnp.0
                          2022-01-02 10:55:10.307	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.RoutedBridgedModeBoth" has to be type "number" but received type "string"
                          upnp.0
                          2022-01-02 10:55:01.229	info	State value to set for "upnp.0.WANDevice_-_FRITZ!Box_6490_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.Layer1UpstreamMaxBitRate" has to be type "number" but received type "string"
                          32.7k
                          82.6k
