  4. Slave meldet sich nicht mehr
    6.3k
82 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • SMSS SMS
    @homoran @apollon77
    Slave kellerkind4GB:
      "system": {
        "memoryLimitMB": 0,
        "hostname": "",
        "statisticsInterval": 15000,
        "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
        "checkDiskInterval": 300000,
        "checkDiskIntervalComment": "Interval how often the disk size will be checked",
        "noChmod": false,
        "instanceStartInterval": 2000,
        "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
        "compact": false,
        "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in$
        "allowShellCommands": false,
        "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
        "memLimitWarn": 100,
        "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
        "memLimitError": 50,
        "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
      "multihostService": {
        "enabled": false,
        "secure": true
      "network": {
        "IPv4": true,
        "IPv6": true,
        "bindAddress": null
      "objects": {
        "type": "file",
        "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
        "host": "192.168.178.58",
        "port": 9001,
        "user": "",
        "pass": "",
        "noFileCache": false,
        "connectTimeout": 2000,
        "writeFileInterval": 5000,
        "options": {
          "auth_pass": null,
          "retry_max_delay": 5000
        "backup": {
          "disabled": false,
          "files": 24,
          "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
          "hours": 48,
          "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
          "period": 120,
          "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
          "path": "",
          "pathComment": "Absolute path to backup directory or empty to backup in data directory"
      "log": {
        "level": "info",
        "maxDays": 7,
        "noStdout": true,
        "transport": {
          "file1": {
            "type": "file",
            "enabled": true,
            "filename": "log/iobroker",
            "fileext": ".log",
            "maxSize": null,
            "maxFiles": null
          "syslog1": {
            "type": "syslog",
            "enabled": false,
            "host": "localhost",
            "hostComment": "The host running syslogd, defaults to localhost.",
            "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
            "protocol": "udp4",
            "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
            "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
            "facilityComment": "Syslog facility to use (Default: local0).",
            "localhost": "iobroker",
            "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
            "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
            "app_nameComment": "The name of the application (Default: process.title).",
            "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
      "dataDirComment": "Always relative to iobroker.js-controller/",
      "plugins": {},
      "dataDir": "../../iobroker-data/"
    @sms Wenn das das File vom anderen Slave ist und die IPs drin die vom master sind und hostname oben "leer" ist dann ja kannst DU so übernehemn auf den anderen Slave
    SMSS 1 Antwort Letzte Antwort
      Andersherum eher. Die Rechte können ja auch 'kaputt' gehen. Das könnte dann ein Hinweis auf ein sterbendes Dateisystem sein.
      dmesg -T | grep -i ext4
      auf dem Host 'MotionEye' bringt?
      Und
      getfacl /opt/iobroker/iobroker-data/iobroker.json
      bitte.
      SMSS Offline
      SMSS Offline
      SMS
      pi@MotionEye:~ $ dmesg -T | grep -i ext4
      [Mo Okt 25 16:13:24 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:E2:9D:54 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d666f4cc-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Mo Okt 25 16:13:27 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Mo Okt 25 16:13:27 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mo Okt 25 16:13:29 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      pi@MotionEye:~ $ getfacl /opt/iobroker/iobroker-data/iobroker.json
      getfacl: Entferne führende '/' von absoluten Pfadnamen
      # file: opt/iobroker/iobroker-data/iobroker.json
      # owner: iobroker
      # group: iobroker
      user::rw-
      group::r--
      group:iobroker:rwx
      mask::rwx
      other::r--
      • apollon77A apollon77
        SMSS Offline
        SMSS Offline
        SMS
        @apollon77
        Klappt auch nicht:
        • SMSS SMS
          @apollon77
          Klappt auch nicht:
          @sms
          Äh, Partition rappeldicht voll?
          df -h /
            @sms
            df -h /
            SMSS Offline
            SMSS Offline
            SMS
            @thomas-braun Seltsam: 🙁
            pi@MotionEye:/opt/iobroker/iobroker-data $ df -h
            Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
            /dev/root        15G     14G     0  100% /
            devtmpfs        3,7G       0  3,7G    0% /dev
            tmpfs           3,9G     16K  3,9G    1% /dev/shm
            tmpfs           3,9G    8,5M  3,9G    1% /run
            tmpfs           5,0M    4,0K  5,0M    1% /run/lock
            tmpfs           3,9G       0  3,9G    0% /sys/fs/cgroup
            /dev/mmcblk0p1  253M     49M  204M   20% /boot
            tmpfs           790M       0  790M    0% /run/user/1000
            • SMSS SMS
              @sms sagte in Slave meldet sich nicht mehr:
              Dicht.
                Dicht.
                SMSS Offline
                SMSS Offline
                SMS
                schrieb am zuletzt editiert von SMS
                @thomas-braun aber warum? Außer backups, welche doch auf dem Master abgelegt werden sollten, mache ich da nichts
                Oder kommt das von den Updates.
                • SMSS SMS
                  @sms
                  Dann musst du mal schauen was da so massiv Platz braucht.
                  MotionEye... Vermutlich die ganzen erfassten Videos.
                  • SMSS SMS
                    wie kommst du darauf?
                    wie machst du denn die Backups?
                      @sms
                      SMSS Offline
                      SMSS Offline
                      SMS
                      @thomas-braun nicht das ich wüsste. wie könnte ich das rausfinden ob da wo was abgelegt wurde?
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @homoran über den Adapter Backitup
                        • SMSS Offline
                          SMSS Offline
                          SMS
                          falscher Post
                          • SMSS SMS
                            Ich mach das mit
                            ncdu
                            kann aber sein, dass das bei dir nachinstalliert werden muss. Und ohne Platz schwierig.
                            • SMSS SMS
                              bitte vollständige Info!
                              ist der auf dem Slave installiert?
                                Ich mach das mit
                                ncdu
                                SMSS Offline
                                SMSS Offline
                                SMS
                                ncdu 1.13 ~ Use the arrow keys to navigate, press ? for help
                                --- /home/pi -----------------------------------------------------------------------------
                                   83,8 MiB [##########] /.npm
                                    6,9 MiB [          ] /.cache
                                  308,0 KiB [          ]  pi_buster_motion_4.2.2-1_armhf.deb
                                   24,0 KiB [          ] /.local
                                   16,0 KiB [          ] /.config
                                    8,0 KiB [          ] /.gnupg
                                    8,0 KiB [          ] /.iobroker
                                    4,0 KiB [          ]  .bash_history
                                    4,0 KiB [          ]  .bashrc
                                    4,0 KiB [          ]  .profile
                                    4,0 KiB [          ]  .bash_logout
                                    4,0 KiB [          ]  .npmrc
                                    0,0   B [          ]  .iobroker.json.swp
                                • SMSS SMS
                                      6,9 MiB [          ] /.cache
                                      8,0 KiB [          ] /.gnupg
                                      4,0 KiB [          ]  .bashrc
                                      4,0 KiB [          ]  .npmrc
                                  @sms Du musst aus /home/pi raus, die dicken Dinger liegen in anderen Ästen des Dateisystems.
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    @homoran nein auf dem Master
                                      SMSS Offline
                                      SMSS Offline
                                      SMS
                                      .  12,0 GiB [##########] /var
                                          1,4 GiB [#         ] /usr
                                      . 264,7 MiB [          ] /home
                                        245,6 MiB [          ] /opt
                                         48,1 MiB [          ] /boot
                                      .   8,4 MiB [          ] /run
                                      .   3,7 MiB [          ] /etc
                                        360,0 KiB [          ] /rpi-clone
                                      .  32,0 KiB [          ] /tmp
                                      !  16,0 KiB [          ] /lost+found
                                         12,0 KiB [          ] /mnt
                                      e   4,0 KiB [          ] /srv
                                      !   4,0 KiB [          ] /root
                                      e   4,0 KiB [          ] /media
                                      .   0,0   B [          ] /sys
                                      .   0,0   B [          ] /proc
                                          0,0   B [          ] /dev
                                      @   0,0   B [          ]  sbin
                                      @   0,0   B [          ]  lib
                                      @   0,0   B [          ]  bin
                                      • SMSS SMS
                                            1,4 GiB [#         ] /usr
                                          245,6 MiB [          ] /opt
                                           48,1 MiB [          ] /boot
                                        .   8,4 MiB [          ] /run
                                        .   3,7 MiB [          ] /etc
                                        .  32,0 KiB [          ] /tmp
                                           12,0 KiB [          ] /mnt
                                        e   4,0 KiB [          ] /srv
                                        !   4,0 KiB [          ] /root
                                        .   0,0   B [          ] /sys
                                        .   0,0   B [          ] /proc
                                            0,0   B [          ] /dev
                                        @   0,0   B [          ]  sbin
                                        @   0,0   B [          ]  lib
                                        @   0,0   B [          ]  bin
                                        Da ist der Hund begraben.
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          @thomas-braun Da finde ich das:
