  4. Probleme mit dem HS100 Adapter
    6.4k
26 Beiträge 8 Kommentatoren 3.5k Aufrufe 8 Beobachtet
  • 1Topf1 1Topf
    der HS100-Adapter wurde mir heute auch zum Update auf 2.0.6 angeboten, das funzt aber nicht:
    $ ./iobroker url "https://github.com/arteck/ioBroker.hs100/tarball/master" hs100
    install arteck/ioBroker.hs100#master
    NPM version: 6.14.10
    npm install arteck/ioBroker.hs100#master --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    npm ERR! code ENOENTnpm ERR! syscall spawn gitnpm ERR! path gitnpm ERR! errno -2
    npm ERR! enoent Error while executing:npm ERR! enoent undefined ls-remote -h -t ssh://git@github.com/arteck/ioBroker.hs100.gitnpm ERR! enoent npm ERR! enoent npm ERR! enoent spawn git ENOENTnpm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2021-08-03T18_43_04_459Z-debug.log
    ERROR: host.iobroker Cannot install arteck/ioBroker.hs100#master: 254
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/local/bin/node',
    1 verbose cli   '/usr/local/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'arteck/ioBroker.hs100#master',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--unsafe-perm',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.10
    3 info using node@v14.15.4
    4 verbose npm-session 35a7ccf2209fc1aa
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 silly fetchPackageMetaData error for github:arteck/ioBroker.hs100#master Error while executing:
    7 silly fetchPackageMetaData undefined ls-remote -h -t ssh://git@github.com/arteck/ioBroker.hs100.git
    7 silly fetchPackageMetaData spawn git ENOENT
    8 timing stage:rollbackFailedOptional Completed in 4ms
    9 timing stage:runTopLevelLifecycles Completed in 15043ms
    10 verbose stack Error: spawn git ENOENT
    10 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:269:19)
    10 verbose stack     at onErrorNT (internal/child_process.js:465:16)
    10 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:80:21)
    11 verbose cwd /opt/iobroker
    12 verbose Linux 4.9.0-7-amd64
    13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "arteck/ioBroker.hs100#master" "--loglevel" "error" "--unsafe-perm" "--prefix" "/opt/iobroker"
    14 verbose node v14.15.4
    15 verbose npm  v6.14.10
    16 error code ENOENT
    17 error syscall spawn git
    18 error path git
    19 error errno -2
    20 error enoent Error while executing:
    20 error enoent undefined ls-remote -h -t ssh://git@github.com/arteck/ioBroker.hs100.git
    20 error enoent
    20 error enoent
    20 error enoent spawn git ENOENT
    21 error enoent This is related to npm not being able to find a file.
    22 verbose exit [ -2, true ]
    sigi234S Online
    sigi234S Online
    @1topf
    stoppe mal vor den Update den Adapter
    1Topf1 1 Antwort Letzte Antwort
    • 1Topf1 1Topf
      1 verbose cli [
      1 verbose cli ]
      18 error path git
      19 error errno -2
      20 error enoent
      20 error enoent
      @1topf
      usr/local/bin/node
      NodeJS ist falsch installiert. Schau in meiner Signatur wie es richtig geht.
      • sigi234S sigi234
        @1topf
        1Topf1 Offline
        1Topf1 Offline
        1Topf
        @sigi234 sagte in Probleme mit dem HS100 Adapter:
        @1topf
        Super, Danke für den Tip. Es ging. 👍
        • 1Topf1 1Topf
          @1topf
          @1topf Hast du die node-Installation angepackt? Da lauert ansonsten die nächste Stopperfalle.
            1Topf1 Offline
            1Topf1 Offline
            1Topf
            @thomas-braun sagte in Probleme mit dem HS100 Adapter:
            Nö, hab ich nicht. Das System läuft seit etwa 2 Jahren so. Update mach ich per
            sudo npm cache clean -f
            sudo npm install -g n
            sudo n stable
            10 Minuten später
            Hab ich jetzt doch gleich mal gemacht und bin nun auf 14.17.4.
            Darf wohl nicht in /local/ liegen? Worüber könnte ich denn da stolpern? ioBroker läuft alles super, mal abgesehen davon, daß das Zigbee-Update nicht funzt (siehe anderer Thread, zigbee gelb).
            Andi
            • 1Topf1 1Topf
              sudo n stable
              10 Minuten später
              Andi
              @1topf
              Wenn da was aus Debian-Ecke als Betriebssystem läuft macht man das über den Paketmanager, nicht am System vorbei.
                mike2712
                Hallo, ich habe auch Probleme mit dem Adapter, dieser wird aufgrund zu vieler Neustarts deaktiviert.
                Ich habe schon einen täglichen Neustart eingestellt, aber auch das hilft leider nicht.
                Gibt es weitere Ansätze dieses Problem zu lösen?
                System läuft unter Docker auf QNAP NAS.
                ioBroker 3.3.15
                Node.js v12.22.5 (Es gibt eine neuere Version: v12.22.7)
                NPM 6.14.14
                hs100.0
                2021-10-21 12:16:07.144	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:16:07.019	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:16:06.983	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:16:06.978	debug	Day value for Model : KP115(EU) Energy : 0.184 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:16:06.892	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:16:06.887	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:16:06.868	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:16:06.863	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:16:06.860	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:16:06.837	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:16:06.828	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:16:06.749	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:16:06.735	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:16:06.727	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:16:06.726	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:16:06.630	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                hs100.0
                2021-10-21 12:16:06.626	debug	Refresh Data HS110 172.16.22.38
                hs100.0
                2021-10-21 12:16:06.621	debug	Refresh Data HS110 172.16.22.32
                hs100.0
                2021-10-21 12:16:06.607	debug	Refresh Data HS110 172.16.22.35
                hs100.0
                2021-10-21 12:16:06.605	debug	Refresh Data HS110 172.16.22.33
                hs100.0
                2021-10-21 12:16:06.601	debug	Refresh Data HS110 172.16.22.31
                hs100.0
                2021-10-21 12:16:06.595	debug	Refresh Data HS110 172.16.22.34
                hs100.0
                2021-10-21 12:16:06.589	debug	Refresh Data HS110 172.16.22.36
                hs100.0
                2021-10-21 12:16:06.585	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:06.573	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:16:06.518	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:06.513	debug	Refresh Data HS110 172.16.22.37
                hs100.0
                2021-10-21 12:16:06.501	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:06.482	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:06.466	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:16:06.458	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:16:06.453	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.439	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.433	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.430	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.426	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.425	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.419	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.417	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:06.399	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.336	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:06.318	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:16:06
                hs100.0
                2021-10-21 12:16:06.281	debug	get Information
                hs100.0
                2021-10-21 12:16:02.048	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:16:01.984	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:16:01.917	debug	Day value for Model : KP115(EU) Energy : 0.184 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:16:01.886	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:16:01.868	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:16:01.859	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:16:01.796	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:16:01.782	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:16:01.780	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:16:01.771	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:16:01.762	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:16:01.758	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:16:01.671	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:16:01.655	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:16:01.642	debug	Refresh Data HS110 172.16.22.31
                hs100.0
                2021-10-21 12:16:01.638	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                hs100.0
                2021-10-21 12:16:01.630	debug	Refresh Data HS110 172.16.22.38
                hs100.0
                2021-10-21 12:16:01.626	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:16:01.621	debug	Refresh Data HS110 172.16.22.32
                hs100.0
                2021-10-21 12:16:01.587	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:01.571	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:01.533	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:01.531	debug	Refresh Data HS110 172.16.22.33
                hs100.0
                2021-10-21 12:16:01.527	debug	Refresh Data HS110 172.16.22.34
                hs100.0
                2021-10-21 12:16:01.520	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:16:01.515	debug	Refresh Data HS110 172.16.22.37
                hs100.0
                2021-10-21 12:16:01.499	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:01.477	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:01.457	debug	Refresh Data HS110 172.16.22.36
                hs100.0
                2021-10-21 12:16:01.448	debug	Refresh Data HS110 172.16.22.35
                hs100.0
                2021-10-21 12:16:01.443	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.440	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.435	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:16:01.428	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.424	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:16:01.410	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.406	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.397	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.366	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:16:01.331	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.326	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.316	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:16:01
                hs100.0
                2021-10-21 12:16:01.281	debug	get Information
                hs100.0
                2021-10-21 12:15:57.205	debug	Day value for Model : KP115(EU) Energy : 0.184 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:57.200	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:57.095	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:57.060	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:57.051	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:57.047	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:57.024	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:56.907	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:56.904	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:56.848	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:56.841	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:56.824	debug	Refresh Data HS110 172.16.22.38
                hs100.0
                2021-10-21 12:15:56.792	debug	Refresh Data HS110 172.16.22.31
                hs100.0
                2021-10-21 12:15:56.789	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:56.788	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:56.779	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:56.727	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:56.699	debug	Refresh Data HS110 172.16.22.36
                hs100.0
                2021-10-21 12:15:56.652	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:56.604	debug	Refresh Data HS110 172.16.22.32
                hs100.0
                2021-10-21 12:15:56.571	debug	Refresh Data HS110 172.16.22.34
                hs100.0
                2021-10-21 12:15:56.567	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:56.554	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:56.546	debug	Refresh Data HS110 172.16.22.35
                hs100.0
                2021-10-21 12:15:56.531	debug	Refresh Data HS110 172.16.22.33
                hs100.0
                2021-10-21 12:15:56.514	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:56.512	debug	Refresh Data HS110 172.16.22.37
                hs100.0
                2021-10-21 12:15:56.501	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:56.487	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:56.476	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:56.452	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:56.448	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.440	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.434	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.419	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:56.417	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.413	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.409	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.406	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.396	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.357	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:56.334	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:56
                hs100.0
                2021-10-21 12:15:56.280	debug	get Information
                hs100.0
                2021-10-21 12:15:52.133	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:51.999	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:51.995	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:51.970	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:51.883	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:51.840	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:51.795	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:51.793	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:51.792	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:51.773	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:51.727	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:51.724	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:51.721	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:51.712	debug	Refresh Data HS110 172.16.22.38
                hs100.0
                2021-10-21 12:15:51.670	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:51.649	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:51.630	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:51.609	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:51.567	debug	Refresh Data HS110 172.16.22.36
                hs100.0
                2021-10-21 12:15:51.559	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:51.552	debug	Refresh Data HS110 172.16.22.31
                hs100.0
                2021-10-21 12:15:51.545	debug	Refresh Data HS110 172.16.22.33
                hs100.0
                2021-10-21 12:15:51.540	debug	Refresh Data HS110 172.16.22.32
                hs100.0
                2021-10-21 12:15:51.537	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.528	debug	Refresh Data HS110 172.16.22.34
                hs100.0
                2021-10-21 12:15:51.517	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:51.510	debug	Refresh Data HS110 172.16.22.37
                hs100.0
                2021-10-21 12:15:51.504	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:51.490	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:51.482	debug	Refresh Data HS110 172.16.22.35
                hs100.0
                2021-10-21 12:15:51.463	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:51.456	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.447	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:51.425	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:51.422	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.418	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.412	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.404	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.395	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.353	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.340	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:51.317	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:51
                hs100.0
                2021-10-21 12:15:51.279	debug	get Information
                hs100.0
                2021-10-21 12:15:47.172	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:47.139	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:47.134	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:47.115	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:47.044	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:46.973	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:46.972	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:46.919	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:46.880	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:46.865	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:46.841	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:46.836	debug	Refresh Data HS110 172.16.22.38
                hs100.0
                2021-10-21 12:15:46.831	debug	Refresh Data HS110 172.16.22.31
                hs100.0
                2021-10-21 12:15:46.821	debug	Refresh Data HS110 172.16.22.36
                hs100.0
                2021-10-21 12:15:46.764	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:46.760	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:46.727	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:46.668	debug	Refresh Data HS110 172.16.22.32
                hs100.0
                2021-10-21 12:15:46.648	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:46.646	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:46.643	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:46.630	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:46.610	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:46.549	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:46.541	debug	Refresh Data HS110 172.16.22.33
                hs100.0
                2021-10-21 12:15:46.534	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:46.528	debug	Refresh Data HS110 172.16.22.34
                hs100.0
                2021-10-21 12:15:46.525	debug	Refresh Data HS110 172.16.22.35
                hs100.0
                2021-10-21 12:15:46.519	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:46.507	debug	Refresh Data HS110 172.16.22.37
                hs100.0
                2021-10-21 12:15:46.497	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.494	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.490	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:46.476	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.421	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.415	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:46.410	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.408	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.404	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.393	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.338	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:46.314	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:46
                hs100.0
                2021-10-21 12:15:46.277	debug	get Information
                hs100.0
                2021-10-21 12:15:42.083	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:42.044	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:42.000	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:41.925	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:41.911	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:41.905	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:41.902	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:41.879	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:41.858	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:41.856	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:41.837	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:41.798	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:41.762	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:41.751	debug	Refresh Data HS110 172.16.22.38
                hs100.0
                2021-10-21 12:15:41.750	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:41.727	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:41.722	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:41.693	debug	Refresh Data HS110 172.16.22.31
                hs100.0
                2021-10-21 12:15:41.667	debug	Refresh Data HS110 172.16.22.36
                hs100.0
                2021-10-21 12:15:41.657	debug	Refresh Data HS110 172.16.22.32
                hs100.0
                2021-10-21 12:15:41.570	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:41.547	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:41.537	debug	Refresh Data HS110 172.16.22.33
                hs100.0
                2021-10-21 12:15:41.532	debug	Refresh Data HS110 172.16.22.34
                hs100.0
                2021-10-21 12:15:41.522	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:41.511	debug	Refresh Data HS110 172.16.22.37
                hs100.0
                2021-10-21 12:15:41.504	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:41.495	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.481	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:41.471	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:41.464	debug	Refresh Data HS110 172.16.22.35
                hs100.0
                2021-10-21 12:15:41.451	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.447	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.437	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.415	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:41.412	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.406	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.394	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.366	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:41.349	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:41.323	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.304	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:41
                hs100.0
                2021-10-21 12:15:41.276	debug	get Information
                hs100.0
                2021-10-21 12:15:37.092	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:36.996	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:36.980	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:36.977	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:36.976	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:36.975	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:36.971	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:36.940	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                hs100.0
                2021-10-21 12:15:36.898	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:36.897	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:36.897	debug	Day value for Model : KP115(EU) Energy : 0.151 IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:36.805	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:36.780	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                hs100.0
                2021-10-21 12:15:36.771	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                hs100.0
                2021-10-21 12:15:36.765	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:36.761	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:36.756	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:36.745	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                hs100.0
                2021-10-21 12:15:36.694	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                hs100.0
                2021-10-21 12:15:36.687	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                hs100.0
                2021-10-21 12:15:36.685	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                hs100.0
                2021-10-21 12:15:36.638	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                hs100.0
                2021-10-21 12:15:36.635	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                hs100.0
                2021-10-21 12:15:36.630	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                hs100.0
                2021-10-21 12:15:36.622	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
                • M mike2712
                  ioBroker 3.3.15
                  NPM 6.14.14
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  hs100.0
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @mike2712 was soll ich jetzt mit dem LOG anfangen.. da steht nur die Protokollierung der einzelnen Geräte..
                  welche adapter version hast du am laufen
                  • arteckA arteck
                    mike2712
                    @arteck
                    sorry, ich bekomme offensichtlich die einzelnen Meldungen nicht rausgefiltert, bzw. sind sie nicht da. Im aktuellen LOG taucht der Adapter HS100 nicht auf. Die Version ist v2.06.
                    Ich habe mal den kompletten LOG heruntergeladen und ausgefiltert, hoffe das ich jetzt die passende Stelle für den häufigen Ausfall gefunden habe.
                    2021-10-22 01:49:02.662  - warn: hs100.0 (31766) getDevice Socket connection Timeout ip: 172.16.22.34 please reconnect the Device
                    2021-10-22 01:49:07.657  - error: hs100.0 (31766) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2021-10-22 01:49:07.657  - error: hs100.0 (31766) unhandled promise rejection: TCP Timeout after 10000ms
                    172.16.22.34:9999 {"emeter":{"get_realtime":{}}}
                    2021-10-22 01:49:07.658  - error: hs100.0 (31766) Error: TCP Timeout after 10000ms
                        at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                        at listOnTimeout (internal/timers.js:554:17)
                        at processTimers (internal/timers.js:497:7)
                    2021-10-22 01:49:07.658  - error: hs100.0 (31766) TCP Timeout after 10000ms
                    2021-10-22 01:49:07.660  - warn: hs100.0 (31766) getDevice Socket connection Timeout ip: 172.16.22.34 please reconnect the Device
                    2021-10-22 01:49:07.664  - info: hs100.0 (31766) cleaned everything up...
                    2021-10-22 01:49:07.665  - info: hs100.0 (31766) terminating
                    2021-10-22 01:49:07.667  - warn: hs100.0 (31766) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2021-10-22 01:49:07.672  - warn: hs100.0 (31766) Info Message setDevice: Error: TCP Timeout after 10000ms
                    172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                    2021-10-22 01:49:08.441  - error: host.iobroker Caught by controller[1]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                    2021-10-22 01:49:08.447  - error: host.iobroker Caught by controller[1]: 172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                    2021-10-22 01:49:08.447  - error: host.iobroker Caught by controller[1]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    2021-10-22 01:49:08.448  - error: host.iobroker Caught by controller[1]:     at listOnTimeout (internal/timers.js:554:17)
                    2021-10-22 01:49:08.448  - error: host.iobroker Caught by controller[1]:     at processTimers (internal/timers.js:497:7)
                    2021-10-22 01:49:08.449  - error: host.iobroker Caught by controller[2]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                    2021-10-22 01:49:08.449  - error: host.iobroker Caught by controller[2]: 172.16.22.34:9999 {"emeter":{"get_realtime":{}}}
                    2021-10-22 01:49:08.450  - error: host.iobroker Caught by controller[2]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    2021-10-22 01:49:08.450  - error: host.iobroker Caught by controller[2]:     at listOnTimeout (internal/timers.js:554:17)
                    2021-10-22 01:49:08.451  - error: host.iobroker Caught by controller[2]:     at processTimers (internal/timers.js:497:7)
                    2021-10-22 01:49:08.451  - error: host.iobroker Caught by controller[3]: [TP-Link-Steckdose-34] device.send() Error: TCP Timeout after 10000ms
                    2021-10-22 01:49:08.452  - error: host.iobroker Caught by controller[3]: 172.16.22.34:9999 {"emeter":{"get_realtime":{}}}
                    2021-10-22 01:49:08.452  - error: host.iobroker Caught by controller[3]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    2021-10-22 01:49:08.453  - error: host.iobroker Caught by controller[3]:     at listOnTimeout (internal/timers.js:554:17)
                    2021-10-22 01:49:08.453  - error: host.iobroker Caught by controller[3]:     at processTimers (internal/timers.js:497:7)
                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]: 172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]:     at listOnTimeout (internal/timers.js:554:17)
                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[4]:     at processTimers (internal/timers.js:497:7)
                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[5]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[5]: 172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[5]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    2021-10-22 01:49:08.456  - error: host.iobroker Caught by controller[5]:     at listOnTimeout (internal/timers.js:554:17)
                    2021-10-22 01:49:08.456  - error: host.iobroker Caught by controller[5]:     at processTimers (internal/timers.js:497:7)
                    2021-10-22 01:49:08.457  - error: host.iobroker instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2021-10-22 01:49:08.457  - info: host.iobroker Restart adapter system.adapter.hs100.0 because enabled
                    2021-10-22 01:49:09.674  - info: host.iobroker instance system.adapter.hs100.0 started with pid 5181
                    2021-10-22 01:49:11.679  - info: hs100.0 (5181) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.22.5, js-controller: 3.3.15
                    2021-10-22 01:49:12.190  - info: hs100.0 (5181) Start with IP : 172.16.22.11
                    2021-10-22 01:49:12.297  - info: hs100.0 (5181) Start with IP : 172.16.22.31
                    2021-10-22 01:49:12.516  - info: hs100.0 (5181) Start with IP : 172.16.22.32
                    • M mike2712
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @mike2712 da wntwortet die Dose oder Dosen nicht im angegebenen zeitraum..
                      wie ist denn dein abfrage intervall?
                      • arteckA arteck
                        mike2712
                        @arteck Der Intervall ist auf 5 Sekunden eingestellt. Bin mir nicht sicher ob das die Standard Einstellung gewesen ist oder ich das aus einen Grund geändert hatte? Sollte ich die Zeit erhöhen?
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          @mike2712 ich hole meine daten alle 60 sec ab.. je kürzer das intervall desto schneller muss die dose die Daten liefern..
                          wenn du schlechtes WLAN hast dann kann die dose keine Daten abliefern.. und läuft auf ein timeout.. mehrere davon verursachen dass der Adapter neu startet
                          • arteckA arteck
                            mike2712
                            @arteck ok, vielen Dank, dann werde ich die Zeiten erhöhen und beobachten ob es besser wird.
