  4. Probleme mit dem HS100 Adapter
    6.4k
26 Beiträge 8 Kommentatoren 3.5k Aufrufe 8 Beobachtet
  • S Speedy012
    So eben gerade war es wieder soweit...
    hs100.0	2021-06-16 20:39:00.264	warn	(32723) Terminated (UNCAUGHT_EXCEPTION): Without reason
    hs100.0	2021-06-16 20:39:00.264	info	(32723) terminating
    hs100.0	2021-06-16 20:39:00.263	info	(32723) cleaned everything up...
    hs100.0	2021-06-16 20:39:00.256	error	192.168.1.103:9999 {"emeter":{"get_monthstat":{"year":2021}}}
    hs100.0	2021-06-16 20:39:00.256	error	(32723) TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:39:00.255	error	at processTimers (internal/timers.js:497:7)
    hs100.0	2021-06-16 20:39:00.255	error	at listOnTimeout (internal/timers.js:554:17)
    hs100.0	2021-06-16 20:39:00.255	error	at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    hs100.0	2021-06-16 20:39:00.255	error	192.168.1.103:9999 {"emeter":{"get_monthstat":{"year":2021}}}
    hs100.0	2021-06-16 20:39:00.255	error	(32723) Error: TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:39:00.255	error	(32723) unhandled promise rejection: TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:39:00.255	error	(32723) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2021-06-16 20:30:19.508	info	(32723) Start with IP : 192.168.1.109
    hs100.0	2021-06-16 20:30:19.496	info	(32723) Start with IP : 192.168.1.107
    hs100.0	2021-06-16 20:30:18.116	info	(32723) Start with IP : 192.168.1.106
    hs100.0	2021-06-16 20:30:17.936	info	(32723) Start with IP : 192.168.1.105
    hs100.0	2021-06-16 20:30:17.873	info	(32723) Start with IP : 192.168.1.104
    hs100.0	2021-06-16 20:30:16.606	info	(32723) Start with IP : 192.168.1.103
    hs100.0	2021-06-16 20:30:16.545	info	(32723) Start with IP : 192.168.1.101
    hs100.0	2021-06-16 20:30:16.530	info	(32723) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.22.1, js-controller: 3.2.16
    hs100.0	2021-06-16 20:29:45.356	warn	(32356) Terminated (UNCAUGHT_EXCEPTION): Without reason
    hs100.0	2021-06-16 20:29:45.356	info	(32356) terminating
    hs100.0	2021-06-16 20:29:45.355	info	(32356) cleaned everything up...
    hs100.0	2021-06-16 20:29:45.348	error	192.168.1.103:9999 {"emeter":{"get_realtime":{}}}
    hs100.0	2021-06-16 20:29:45.348	error	(32356) TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:29:45.348	error	at processTimers (internal/timers.js:497:7)
    hs100.0	2021-06-16 20:29:45.348	error	at listOnTimeout (internal/timers.js:554:17)
    hs100.0	2021-06-16 20:29:45.348	error	at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    hs100.0	2021-06-16 20:29:45.348	error	(32356) Error: TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:29:45.348	error	(32356) unhandled promise rejection: TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:29:45.347	error	(32356) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2021-06-16 20:29:02.129	info	(32356) Start with IP : 192.168.1.109
    hs100.0	2021-06-16 20:29:02.116	info	(32356) Start with IP : 192.168.1.107
    hs100.0	2021-06-16 20:29:01.331	info	(32356) Start with IP : 192.168.1.106
    hs100.0	2021-06-16 20:29:01.110	info	(32356) Start with IP : 192.168.1.105
    hs100.0	2021-06-16 20:29:01.082	info	(32356) Start with IP : 192.168.1.104
    hs100.0	2021-06-16 20:29:00.857	info	(32356) Start with IP : 192.168.1.103
    hs100.0	2021-06-16 20:29:00.804	info	(32356) Start with IP : 192.168.1.101
    hs100.0	2021-06-16 20:29:00.792	info	(32356) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.22.1, js-controller: 3.2.16
    hs100.0	2021-06-16 20:28:29.587	warn	(31459) Terminated (UNCAUGHT_EXCEPTION): Without reason
    hs100.0	2021-06-16 20:28:29.586	info	(31459) terminating
    hs100.0	2021-06-16 20:28:29.586	info	(31459) cleaned everything up...
    hs100.0	2021-06-16 20:28:29.580	error	192.168.1.103:9999 {"emeter":{"get_daystat":{"year":2021,"month":6}}}
    hs100.0	2021-06-16 20:28:29.580	error	(31459) TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:28:29.580	error	at processTimers (internal/timers.js:497:7)
    hs100.0	2021-06-16 20:28:29.580	error	at listOnTimeout (internal/timers.js:554:17)
    hs100.0	2021-06-16 20:28:29.580	error	at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    hs100.0	2021-06-16 20:28:29.580	error	(31459) Error: TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:28:29.580	error	(31459) unhandled promise rejection: TCP Timeout after 10000ms
    hs100.0	2021-06-16 20:28:29.580	error	(31459) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2021-06-16 20:23:37.357	warn	(31459) getDevice Socket connection Timeout ip: 192.168.1.103 please reconnect the Device
    arteckA Offline
    arteckA Offline
    arteck
    @speedy012 sagte in Probleme mit dem HS100 Adapter:
    das ist das was ich gesagt habe.. die Dose antwortet nicht und die lib knallt.aber der adapter sollte sich dann neu starten
    da kämpfe ich schon seid Monaten...
    • arteckA arteck
      stenmic
      wollte heute auf 2.0.6 updaten.
      Dann kam diese Fehlermeldung:
      Im Log steht:
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli   '/usr/bin/node',
      1 verbose cli   '/usr/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker.hs100@2.0.6',
      1 verbose cli   '--loglevel',
      1 verbose cli   'error',
      1 verbose cli   '--prefix',
      1 verbose cli   '/opt/iobroker'
      1 verbose cli ]
      2 info using npm@6.14.14
      3 info using node@v12.22.4
      4 verbose npm-session 8367084c06161604
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 http fetch GET 304 https://registry.npmjs.org/iobroker.hs100 214ms (from cache)
      8 silly registry:manifest no matching version for iobroker.hs100@2.0.6 in the cache. Forcing revalidation.
      9 http fetch GET 200 https://registry.npmjs.org/iobroker.hs100 86ms
      10 silly fetchPackageMetaData error for iobroker.hs100@2.0.6 No matching version found for iobroker.hs100@2.0.6.
      11 timing stage:rollbackFailedOptional Completed in 1ms
      12 timing stage:runTopLevelLifecycles Completed in 4215ms
      13 verbose type version
      14 verbose stack iobroker.hs100: No matching version found for iobroker.hs100@2.0.6.
      14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
      14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
      14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
      14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
      14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
      14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
      14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
      14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
      14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
      14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
      14 verbose stack     at processImmediate (internal/timers.js:461:21)
      15 verbose cwd /opt/iobroker
      16 verbose Linux 4.19.0-13-amd64
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.hs100@2.0.6" "--loglevel" "error" "--prefix" "/opt/iobroker"
      18 verbose node v12.22.4
      19 verbose npm  v6.14.14
      20 error code ETARGET
      21 error notarget No matching version found for iobroker.hs100@2.0.6.
      22 error notarget In most cases you or one of your dependencies are requesting
      22 error notarget a package version that doesn't exist.
      23 verbose exit [ 1, true ]
      jemand eine Idee?
      • S stenmic
        Im Log steht:
        1 verbose cli [
        1 verbose cli ]
        jemand eine Idee?
        @stenmic
        iobroker update
        iobroker upgrade
        Wow kommt denn die 2.0.6 her?
        github:	2.0.5
        latest:	2.0.5 for 29 days
        stable:	2.0.3 for 6 months
          @stenmic
          iobroker update
          iobroker upgrade
          github:	2.0.5
          stenmic
          schrieb am zuletzt editiert von stenmic
          @thomas-braun wird mir im stable-Kanal angezeigt.
          iobroker update...
          Adapter    "hs100"         : 2.0.6    , installed 2.0.5 [Updateable]
          "iobroker upgrade" bringt die selben Fehler.
          • S stenmic
            iobroker update...
            @stenmic Dann muss das ganz frisch sein. Probier später nochmal.
            Denn:
            echad@chet:~ $ iobroker update
            Used repository: live-beta
            hash changed or no sources cached => force download of new sources
            update done
            Adapter    "admin"         : 5.1.19   , installed 5.1.19
            Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
            Adapter    "backitup"      : 2.1.13   , installed 2.1.13
            Adapter    "ble"           : 0.12.0   , installed 0.12.0
            Adapter    "cloud"         : 4.1.0    , installed 4.1.0
            Adapter    "devices"       : 1.0.9    , installed 1.0.9
            Adapter    "echarts"       : 1.0.3    , installed 1.0.3
            Adapter    "firetv"        : 1.0.0    , installed 1.0.0
            Adapter    "history"       : 1.9.13   , installed 1.9.13
            Adapter    "hs100"         : 2.0.5    , installed 2.0.5
            Adapter    "info"          : 1.9.7    , installed 1.9.7
            Adapter    "iot"           : 1.8.22   , installed 1.8.22
            Adapter    "javascript"    : 5.2.8    , installed 5.2.8
            Controller "js-controller" : 3.3.15   , installed 3.3.15
            Adapter    "mihome"        : 1.3.7    , installed 1.3.7
            Adapter    "mihome-vacuum" : 3.2.2    , installed 3.2.2
            Adapter    "miio"          : 0.0.13   , installed 0.0.13
            Adapter    "nuki-extended" : 2.3.1    , installed 2.3.1
            Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
            Adapter    "socketio"      : 3.1.4    , installed 3.1.4
            Adapter    "tado"          : 0.3.4    , installed 0.3.4
            Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
            Adapter    "tradfri"       : 3.0.1    , installed 3.0.1
            Adapter    "vofo-speedtest": 0.0.8    , installed 0.0.8
            Adapter    "web"           : 3.4.7    , installed 3.4.7
            Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
            Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
            echad@chet:~ $
              Denn:
              update done
              echad@chet:~ $
              stenmic
              @thomas-braun ok… aber verstehen du ichs nicht 😳
              • S stenmic
                @stenmic
                iobroker repo list
                Vermutlich ist das Repo noch nicht konsistent.
                • 1Topf1 Offline
                  1Topf1 Offline
                  1Topf
                  der HS100-Adapter wurde mir heute auch zum Update auf 2.0.6 angeboten, das funzt aber nicht:
                  $ ./iobroker url "https://github.com/arteck/ioBroker.hs100/tarball/master" hs100
                  install arteck/ioBroker.hs100#master
                  NPM version: 6.14.10
                  npm install arteck/ioBroker.hs100#master --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                  npm ERR! code ENOENTnpm ERR! syscall spawn gitnpm ERR! path gitnpm ERR! errno -2
                  npm ERR! enoent Error while executing:npm ERR! enoent undefined ls-remote -h -t ssh://git@github.com/arteck/ioBroker.hs100.gitnpm ERR! enoent npm ERR! enoent npm ERR! enoent spawn git ENOENTnpm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                  npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2021-08-03T18_43_04_459Z-debug.log
                  ERROR: host.iobroker Cannot install arteck/ioBroker.hs100#master: 254
                  1 verbose cli [
                  1 verbose cli   '/usr/local/bin/node',
                  1 verbose cli   '/usr/local/bin/npm',
                  1 verbose cli   'arteck/ioBroker.hs100#master',
                  1 verbose cli   '--unsafe-perm',
                  1 verbose cli ]
                  2 info using npm@6.14.10
                  3 info using node@v14.15.4
                  4 verbose npm-session 35a7ccf2209fc1aa
                  7 silly fetchPackageMetaData error for github:arteck/ioBroker.hs100#master Error while executing:
                  7 silly fetchPackageMetaData undefined ls-remote -h -t ssh://git@github.com/arteck/ioBroker.hs100.git
                  7 silly fetchPackageMetaData spawn git ENOENT
                  8 timing stage:rollbackFailedOptional Completed in 4ms
                  9 timing stage:runTopLevelLifecycles Completed in 15043ms
                  10 verbose stack Error: spawn git ENOENT
                  10 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:269:19)
                  10 verbose stack     at onErrorNT (internal/child_process.js:465:16)
                  10 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:80:21)
                  11 verbose cwd /opt/iobroker
                  12 verbose Linux 4.9.0-7-amd64
                  13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "arteck/ioBroker.hs100#master" "--loglevel" "error" "--unsafe-perm" "--prefix" "/opt/iobroker"
                  14 verbose node v14.15.4
                  15 verbose npm  v6.14.10
                  16 error code ENOENT
                  17 error syscall spawn git
                  18 error path git
                  19 error errno -2
                  20 error enoent Error while executing:
                  20 error enoent undefined ls-remote -h -t ssh://git@github.com/arteck/ioBroker.hs100.git
                  20 error enoent
                  20 error enoent
                  20 error enoent spawn git ENOENT
                  21 error enoent This is related to npm not being able to find a file.
                  22 verbose exit [ -2, true ]
                  sigi234S Thomas BraunT 2 Antworten Letzte Antwort
                  • 1Topf1 1Topf
                    1 verbose cli [
                    1 verbose cli ]
                    18 error path git
                    19 error errno -2
                    20 error enoent
                    20 error enoent
                    sigi234S Online
                    sigi234S Online
                    @1topf
                    stoppe mal vor den Update den Adapter
                    1Topf1 1 Antwort Letzte Antwort
                    • 1Topf1 1Topf
                      1 verbose cli [
                      1 verbose cli ]
                      18 error path git
                      19 error errno -2
                      20 error enoent
                      20 error enoent
                      @1topf
                      usr/local/bin/node
                      NodeJS ist falsch installiert. Schau in meiner Signatur wie es richtig geht.
                      • sigi234S sigi234
                        @1topf
                        1Topf1 Offline
                        1Topf1 Offline
                        1Topf
                        @sigi234 sagte in Probleme mit dem HS100 Adapter:
                        @1topf
                        Super, Danke für den Tip. Es ging. 👍
                        • 1Topf1 1Topf
                          @1topf
                          @1topf Hast du die node-Installation angepackt? Da lauert ansonsten die nächste Stopperfalle.
                            1Topf1 Offline
                            1Topf1 Offline
                            1Topf
                            @thomas-braun sagte in Probleme mit dem HS100 Adapter:
                            Nö, hab ich nicht. Das System läuft seit etwa 2 Jahren so. Update mach ich per
                            sudo npm cache clean -f
                            sudo npm install -g n
                            sudo n stable
                            10 Minuten später
                            Hab ich jetzt doch gleich mal gemacht und bin nun auf 14.17.4.
                            Darf wohl nicht in /local/ liegen? Worüber könnte ich denn da stolpern? ioBroker läuft alles super, mal abgesehen davon, daß das Zigbee-Update nicht funzt (siehe anderer Thread, zigbee gelb).
                            Andi
                            • 1Topf1 1Topf
                              sudo n stable
                              10 Minuten später
                              Andi
                              @1topf
                              Wenn da was aus Debian-Ecke als Betriebssystem läuft macht man das über den Paketmanager, nicht am System vorbei.
                                mike2712
                                Hallo, ich habe auch Probleme mit dem Adapter, dieser wird aufgrund zu vieler Neustarts deaktiviert.
                                Ich habe schon einen täglichen Neustart eingestellt, aber auch das hilft leider nicht.
                                Gibt es weitere Ansätze dieses Problem zu lösen?
                                System läuft unter Docker auf QNAP NAS.
                                ioBroker 3.3.15
                                Node.js v12.22.5 (Es gibt eine neuere Version: v12.22.7)
                                NPM 6.14.14
                                hs100.0
                                2021-10-21 12:16:07.144	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:16:07.019	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:16:06.983	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:16:06.978	debug	Day value for Model : KP115(EU) Energy : 0.184 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:16:06.892	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:16:06.887	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:16:06.868	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:16:06.863	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:16:06.860	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:16:06.837	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:16:06.828	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:16:06.749	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:16:06.735	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:16:06.727	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:16:06.726	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:16:06.630	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:16:06.626	debug	Refresh Data HS110 172.16.22.38
                                hs100.0
                                2021-10-21 12:16:06.621	debug	Refresh Data HS110 172.16.22.32
                                hs100.0
                                2021-10-21 12:16:06.607	debug	Refresh Data HS110 172.16.22.35
                                hs100.0
                                2021-10-21 12:16:06.605	debug	Refresh Data HS110 172.16.22.33
                                hs100.0
                                2021-10-21 12:16:06.601	debug	Refresh Data HS110 172.16.22.31
                                hs100.0
                                2021-10-21 12:16:06.595	debug	Refresh Data HS110 172.16.22.34
                                hs100.0
                                2021-10-21 12:16:06.589	debug	Refresh Data HS110 172.16.22.36
                                hs100.0
                                2021-10-21 12:16:06.585	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.573	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.518	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.513	debug	Refresh Data HS110 172.16.22.37
                                hs100.0
                                2021-10-21 12:16:06.501	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.482	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.466	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.458	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.453	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.439	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.433	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.430	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.426	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.425	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.419	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.417	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.399	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.336	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:06.318	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:16:06
                                hs100.0
                                2021-10-21 12:16:06.281	debug	get Information
                                hs100.0
                                2021-10-21 12:16:02.048	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:16:01.984	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:16:01.917	debug	Day value for Model : KP115(EU) Energy : 0.184 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:16:01.886	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:16:01.868	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:16:01.859	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:16:01.796	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:16:01.782	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:16:01.780	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:16:01.771	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:16:01.762	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:16:01.758	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:16:01.671	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:16:01.655	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:16:01.642	debug	Refresh Data HS110 172.16.22.31
                                hs100.0
                                2021-10-21 12:16:01.638	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:16:01.630	debug	Refresh Data HS110 172.16.22.38
                                hs100.0
                                2021-10-21 12:16:01.626	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:16:01.621	debug	Refresh Data HS110 172.16.22.32
                                hs100.0
                                2021-10-21 12:16:01.587	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.571	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.533	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.531	debug	Refresh Data HS110 172.16.22.33
                                hs100.0
                                2021-10-21 12:16:01.527	debug	Refresh Data HS110 172.16.22.34
                                hs100.0
                                2021-10-21 12:16:01.520	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.515	debug	Refresh Data HS110 172.16.22.37
                                hs100.0
                                2021-10-21 12:16:01.499	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.477	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.457	debug	Refresh Data HS110 172.16.22.36
                                hs100.0
                                2021-10-21 12:16:01.448	debug	Refresh Data HS110 172.16.22.35
                                hs100.0
                                2021-10-21 12:16:01.443	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.440	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.435	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.428	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.424	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.410	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.406	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.397	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.366	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:16:01.331	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.326	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.316	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:16:01
                                hs100.0
                                2021-10-21 12:16:01.281	debug	get Information
                                hs100.0
                                2021-10-21 12:15:57.205	debug	Day value for Model : KP115(EU) Energy : 0.184 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:57.200	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:57.095	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:57.060	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:57.051	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:57.047	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:57.024	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:56.907	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:56.904	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:56.848	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:56.841	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:56.824	debug	Refresh Data HS110 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:56.792	debug	Refresh Data HS110 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:56.789	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:56.788	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:56.779	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:56.727	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:56.699	debug	Refresh Data HS110 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:56.652	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:56.604	debug	Refresh Data HS110 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:56.571	debug	Refresh Data HS110 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:56.567	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.554	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.546	debug	Refresh Data HS110 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:56.531	debug	Refresh Data HS110 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:56.514	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.512	debug	Refresh Data HS110 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:56.501	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.487	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.476	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.452	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.448	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.440	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.434	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.419	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.417	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.413	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.409	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.406	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.396	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.357	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:56.334	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:56
                                hs100.0
                                2021-10-21 12:15:56.280	debug	get Information
                                hs100.0
                                2021-10-21 12:15:52.133	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:51.999	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:51.995	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:51.970	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:51.883	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:51.840	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:51.795	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:51.793	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:51.792	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:51.773	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:51.727	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:51.724	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:51.721	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:51.712	debug	Refresh Data HS110 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:51.670	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:51.649	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:51.630	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.609	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:51.567	debug	Refresh Data HS110 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:51.559	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.552	debug	Refresh Data HS110 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:51.545	debug	Refresh Data HS110 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:51.540	debug	Refresh Data HS110 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:51.537	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.528	debug	Refresh Data HS110 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:51.517	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.510	debug	Refresh Data HS110 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:51.504	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.490	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.482	debug	Refresh Data HS110 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:51.463	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.456	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.447	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.425	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.422	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.418	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.412	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.404	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.395	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.353	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.340	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:51.317	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:51
                                hs100.0
                                2021-10-21 12:15:51.279	debug	get Information
                                hs100.0
                                2021-10-21 12:15:47.172	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:47.139	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:47.134	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:47.115	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:47.044	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:46.973	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:46.972	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:46.919	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:46.880	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:46.865	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:46.841	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:46.836	debug	Refresh Data HS110 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:46.831	debug	Refresh Data HS110 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:46.821	debug	Refresh Data HS110 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:46.764	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:46.760	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:46.727	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:46.668	debug	Refresh Data HS110 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:46.648	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:46.646	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.643	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:46.630	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.610	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.549	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.541	debug	Refresh Data HS110 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:46.534	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.528	debug	Refresh Data HS110 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:46.525	debug	Refresh Data HS110 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:46.519	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.507	debug	Refresh Data HS110 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:46.497	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.494	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.490	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.476	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.421	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.415	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.410	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.408	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.404	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.393	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.338	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:46.314	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:46
                                hs100.0
                                2021-10-21 12:15:46.277	debug	get Information
                                hs100.0
                                2021-10-21 12:15:42.083	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:42.044	debug	Day value for Model : KP115(EU) Energy : 0.152 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:42.000	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:41.925	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:41.911	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:41.905	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:41.902	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:41.879	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:41.858	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:41.856	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:41.837	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:41.798	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:41.762	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:41.751	debug	Refresh Data HS110 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:41.750	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:41.727	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:41.722	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:41.693	debug	Refresh Data HS110 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:41.667	debug	Refresh Data HS110 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:41.657	debug	Refresh Data HS110 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:41.570	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.547	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.537	debug	Refresh Data HS110 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:41.532	debug	Refresh Data HS110 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:41.522	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.511	debug	Refresh Data HS110 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:41.504	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.495	debug	Refresh 172.16.22.32 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.481	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.471	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.464	debug	Refresh Data HS110 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:41.451	debug	Refresh 172.16.22.31 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.447	debug	Refresh 172.16.22.38 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.437	debug	Refresh 172.16.22.36 Model = KP115(EU) state = false update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.415	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.412	debug	Refresh 172.16.22.33 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.406	debug	Refresh 172.16.22.34 Model = KP115(EU) state = false update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.394	debug	Refresh 172.16.22.37 Model = KP115(EU) state = true update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.366	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.349	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:41.323	debug	Refresh 172.16.22.11 Model = HS100(EU) state = true update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.304	debug	Refresh 172.16.22.35 Model = KP115(EU) state = false update = 2021.10.21 12:15:41
                                hs100.0
                                2021-10-21 12:15:41.276	debug	get Information
                                hs100.0
                                2021-10-21 12:15:37.092	debug	Day value for Model : KP115(EU) Energy : 0.024 IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:36.996	debug	stateID hs100.0.172_16_22_32.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.980	debug	stateID hs100.0.172_16_22_38.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.977	debug	stateID hs100.0.172_16_22_31.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.976	debug	stateID hs100.0.172_16_22_36.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.975	debug	stateID hs100.0.172_16_22_35.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.971	debug	stateID hs100.0.172_16_22_33.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.940	debug	stateID hs100.0.172_16_22_34.state changed: false (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.898	debug	Day value for Model : KP115(EU) Energy : 0.016 IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:36.897	debug	Day value for Model : KP115(EU) Energy : 0.183 IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:36.897	debug	Day value for Model : KP115(EU) Energy : 0.151 IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:36.805	debug	stateID hs100.0.172_16_22_37.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.780	debug	stateID hs100.0.172_16_22_11.state changed: true (ack = true)
                                hs100.0
                                2021-10-21 12:15:36.771	debug	Month value Model : KP115(EU) IP : 172.16.22.32
                                hs100.0
                                2021-10-21 12:15:36.765	debug	Day value for Model : KP115(EU) Energy : 0.003 IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:36.761	debug	Day value for Model : KP115(EU) Energy : 0 IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:36.756	debug	Day value for Model : KP115(EU) Energy : 0.012 IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:36.745	debug	Day value for Model : KP115(EU) Energy : 0.074 IP : 172.16.22.37
                                hs100.0
                                2021-10-21 12:15:36.694	debug	Month value Model : KP115(EU) IP : 172.16.22.38
                                hs100.0
                                2021-10-21 12:15:36.687	debug	Month value Model : KP115(EU) IP : 172.16.22.31
                                hs100.0
                                2021-10-21 12:15:36.685	debug	Month value Model : KP115(EU) IP : 172.16.22.36
                                hs100.0
                                2021-10-21 12:15:36.638	debug	Month value Model : KP115(EU) IP : 172.16.22.35
                                hs100.0
                                2021-10-21 12:15:36.635	debug	Month value Model : KP115(EU) IP : 172.16.22.33
                                hs100.0
                                2021-10-21 12:15:36.630	debug	Month value Model : KP115(EU) IP : 172.16.22.34
                                hs100.0
                                2021-10-21 12:15:36.622	debug	Month value Model : KP115(EU) IP : 172.16.22.37
                                ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
                                • M mike2712
                                  ioBroker 3.3.15
                                  NPM 6.14.14
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  hs100.0
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @mike2712 was soll ich jetzt mit dem LOG anfangen.. da steht nur die Protokollierung der einzelnen Geräte..
                                  welche adapter version hast du am laufen
                                  • arteckA arteck
                                    mike2712
                                    @arteck
                                    sorry, ich bekomme offensichtlich die einzelnen Meldungen nicht rausgefiltert, bzw. sind sie nicht da. Im aktuellen LOG taucht der Adapter HS100 nicht auf. Die Version ist v2.06.
                                    Ich habe mal den kompletten LOG heruntergeladen und ausgefiltert, hoffe das ich jetzt die passende Stelle für den häufigen Ausfall gefunden habe.
                                    2021-10-22 01:49:02.662  - warn: hs100.0 (31766) getDevice Socket connection Timeout ip: 172.16.22.34 please reconnect the Device
                                    2021-10-22 01:49:07.657  - error: hs100.0 (31766) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2021-10-22 01:49:07.657  - error: hs100.0 (31766) unhandled promise rejection: TCP Timeout after 10000ms
                                    172.16.22.34:9999 {"emeter":{"get_realtime":{}}}
                                    2021-10-22 01:49:07.658  - error: hs100.0 (31766) Error: TCP Timeout after 10000ms
                                    2021-10-22 01:49:07.658  - error: hs100.0 (31766) TCP Timeout after 10000ms
                                    2021-10-22 01:49:07.660  - warn: hs100.0 (31766) getDevice Socket connection Timeout ip: 172.16.22.34 please reconnect the Device
                                    2021-10-22 01:49:07.664  - info: hs100.0 (31766) cleaned everything up...
                                    2021-10-22 01:49:07.665  - info: hs100.0 (31766) terminating
                                    2021-10-22 01:49:07.667  - warn: hs100.0 (31766) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2021-10-22 01:49:07.672  - warn: hs100.0 (31766) Info Message setDevice: Error: TCP Timeout after 10000ms
                                    172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                                    2021-10-22 01:49:08.441  - error: host.iobroker Caught by controller[1]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                                    2021-10-22 01:49:08.447  - error: host.iobroker Caught by controller[1]: 172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                                    2021-10-22 01:49:08.447  - error: host.iobroker Caught by controller[1]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                    2021-10-22 01:49:08.448  - error: host.iobroker Caught by controller[1]:     at listOnTimeout (internal/timers.js:554:17)
                                    2021-10-22 01:49:08.448  - error: host.iobroker Caught by controller[1]:     at processTimers (internal/timers.js:497:7)
                                    2021-10-22 01:49:08.449  - error: host.iobroker Caught by controller[2]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                                    2021-10-22 01:49:08.449  - error: host.iobroker Caught by controller[2]: 172.16.22.34:9999 {"emeter":{"get_realtime":{}}}
                                    2021-10-22 01:49:08.450  - error: host.iobroker Caught by controller[2]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                    2021-10-22 01:49:08.450  - error: host.iobroker Caught by controller[2]:     at listOnTimeout (internal/timers.js:554:17)
                                    2021-10-22 01:49:08.451  - error: host.iobroker Caught by controller[2]:     at processTimers (internal/timers.js:497:7)
                                    2021-10-22 01:49:08.451  - error: host.iobroker Caught by controller[3]: [TP-Link-Steckdose-34] device.send() Error: TCP Timeout after 10000ms
                                    2021-10-22 01:49:08.452  - error: host.iobroker Caught by controller[3]: 172.16.22.34:9999 {"emeter":{"get_realtime":{}}}
                                    2021-10-22 01:49:08.452  - error: host.iobroker Caught by controller[3]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                    2021-10-22 01:49:08.453  - error: host.iobroker Caught by controller[3]:     at listOnTimeout (internal/timers.js:554:17)
                                    2021-10-22 01:49:08.453  - error: host.iobroker Caught by controller[3]:     at processTimers (internal/timers.js:497:7)
                                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]: 172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                    2021-10-22 01:49:08.454  - error: host.iobroker Caught by controller[4]:     at listOnTimeout (internal/timers.js:554:17)
                                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[4]:     at processTimers (internal/timers.js:497:7)
                                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[5]: TCP 172.16.22.34:9999 Error: TCP Timeout after 10000ms
                                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[5]: 172.16.22.34:9999 {"system":{"get_sysinfo":{}}}
                                    2021-10-22 01:49:08.455  - error: host.iobroker Caught by controller[5]:     at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                    2021-10-22 01:49:08.456  - error: host.iobroker Caught by controller[5]:     at listOnTimeout (internal/timers.js:554:17)
                                    2021-10-22 01:49:08.456  - error: host.iobroker Caught by controller[5]:     at processTimers (internal/timers.js:497:7)
                                    2021-10-22 01:49:08.457  - error: host.iobroker instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2021-10-22 01:49:08.457  - info: host.iobroker Restart adapter system.adapter.hs100.0 because enabled
                                    2021-10-22 01:49:09.674  - info: host.iobroker instance system.adapter.hs100.0 started with pid 5181
                                    2021-10-22 01:49:11.679  - info: hs100.0 (5181) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.22.5, js-controller: 3.3.15
                                    2021-10-22 01:49:12.190  - info: hs100.0 (5181) Start with IP : 172.16.22.11
                                    2021-10-22 01:49:12.297  - info: hs100.0 (5181) Start with IP : 172.16.22.31
                                    2021-10-22 01:49:12.516  - info: hs100.0 (5181) Start with IP : 172.16.22.32
                                    • M mike2712
                                      @arteck
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @mike2712 da wntwortet die Dose oder Dosen nicht im angegebenen zeitraum..
                                      wie ist denn dein abfrage intervall?
                                      • arteckA arteck
                                        mike2712
                                        @arteck Der Intervall ist auf 5 Sekunden eingestellt. Bin mir nicht sicher ob das die Standard Einstellung gewesen ist oder ich das aus einen Grund geändert hatte? Sollte ich die Zeit erhöhen?
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @mike2712 ich hole meine daten alle 60 sec ab.. je kürzer das intervall desto schneller muss die dose die Daten liefern..
                                          wenn du schlechtes WLAN hast dann kann die dose keine Daten abliefern.. und läuft auf ein timeout.. mehrere davon verursachen dass der Adapter neu startet
