  4. ZigBee neue Version 1.6.x
    6.3k
509 Beiträge 61 Kommentatoren 150.2k Aufrufe 62 Beobachtet
  • mickymM mickym
    @asgothian Gibt noch hin und wieder einen kompletten Absturz des Adapters - aber durch automatischen Neustart fängt sich das System wieder:
    2021-09-27 11:20:11.080 - error: zigbee.0 (23900) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-09-27 11:20:11.081 - error: zigbee.0 (23900) unhandled promise rejection: undefined
    2021-09-27 11:20:11.084 - info: zigbee.0 (23900) cleaned everything up...
    2021-09-27 11:20:11.169 - info: zigbee.0 (23900) Zigbee: disabling joining new devices.
    2021-09-27 11:20:11.423 - info: zigbee.0 (23900) terminating
    2021-09-27 11:20:11.427 - warn: zigbee.0 (23900) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-09-27 11:20:12.052 - error: host.MWHome Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2021-09-27 11:20:12.057 - error: host.MWHome Caught by controller[1]: undefined
    2021-09-27 11:20:12.058 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-09-27 11:20:12.058 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
    2021-09-27 11:20:42.155 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 6892
    2021-09-27 11:20:46.357 - info: zigbee.0 (6892) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
    2021-09-27 11:20:46.478 - info: zigbee.0 (6892) Starting Zigbee npm ...
    weiß nicht ob man das nachverfolgen will?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #71
    @mickym
    Poste doch mal die log Zeilen von vor dem Absturz.
    A.
    • AsgothianA Asgothian
      @mickym
      A.
      mickymM Offline
      mickymM Offline
      mickym
      #72
      @asgothian sagte in ZigBee neue Version 1.6.0:
      @mickym
      A.
      Ich glaub zwar nicht, dass das was bringt - ich hab den Adapter wieder auf Info Level gestellt und da ist nichts:
      2021-09-27 09:45:08.029 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 10:00:00.102 - info: host.MWHome instance system.adapter.dwd.0 started with pid 22353
      2021-09-27 10:00:02.972 - info: dwd.0 (22353) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 10:00:07.774 - info: dwd.0 (22353) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 10:00:08.320 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 10:07:28.753 - warn: zigbee.0 (23900) Failed to ping 0xccccccfffeb3e954 TRADFRI Signal Repeater
      2021-09-27 10:15:00.114 - info: host.MWHome instance system.adapter.dwd.0 started with pid 25506
      2021-09-27 10:15:04.932 - info: dwd.0 (25506) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 10:15:08.409 - info: dwd.0 (25506) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 10:15:08.947 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 10:30:00.153 - info: host.MWHome instance system.adapter.dwd.0 started with pid 28640
      2021-09-27 10:30:03.171 - info: dwd.0 (28640) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 10:30:07.556 - info: dwd.0 (28640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 10:30:08.108 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 10:45:00.163 - info: host.MWHome instance system.adapter.dwd.0 started with pid 31705
      2021-09-27 10:45:03.057 - info: dwd.0 (31705) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 10:45:06.804 - info: dwd.0 (31705) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 10:45:07.348 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 11:00:00.165 - info: host.MWHome instance system.adapter.dwd.0 started with pid 2458
      2021-09-27 11:00:03.185 - info: dwd.0 (2458) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 11:00:07.471 - info: dwd.0 (2458) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 11:00:08.007 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 11:15:00.141 - info: host.MWHome instance system.adapter.dwd.0 started with pid 5718
      2021-09-27 11:15:04.878 - info: dwd.0 (5718) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 11:15:07.486 - info: dwd.0 (5718) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 11:15:08.030 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 11:20:46.864 - info: zigbee.0 (6892) Installed Version: iobroker.zigbee@1.6.0
      2021-09-27 11:20:47.066 - info: zigbee.0 (6892) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
      2021-09-27 11:20:47.088 - info: zigbee.0 (6892) Unable to disable LED, unsupported function.
      2021-09-27 11:20:47.223 - info: zigbee.0 (6892) --> transmitPower : normal
      2021-09-27 11:20:47.334 - info: zigbee.0 (6892) Unable to set transmit power, unsupported function.
      2021-09-27 11:20:47.342 - info: zigbee.0 (6892) Currently 21 devices are joined:
      2021-09-27 11:20:47.471 - info: zigbee.0 (6892) 0xec1bbdfffeebe96b (addr 21987): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
      2021-09-27 11:20:47.477 - info: zigbee.0 (6892) 0xec1bbdfffeeae2df (addr 37220): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
      2021-09-27 11:20:47.479 - info: zigbee.0 (6892) 0xec1bbdfffeeadb1a (addr 788): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
      2021-09-27 11:20:47.481 - info: zigbee.0 (6892) 0xccccccfffe021ec0 (addr 44672): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
      2021-09-27 11:20:47.484 - info: zigbee.0 (6892) 0x00158d000411b98e (addr 51704): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.486 - info: zigbee.0 (6892) 0x00158d00032c8aa8 (addr 7440): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      2021-09-27 11:20:47.488 - info: zigbee.0 (6892) 0x00158d000424453c (addr 15225): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.491 - info: zigbee.0 (6892) 0xccccccfffeb3e954 (addr 2130): E1746 - IKEA TRADFRI signal repeater (Router)
      2021-09-27 11:20:47.493 - info: zigbee.0 (6892) 0x00158d0004282104 (addr 51621): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.494 - info: zigbee.0 (6892) 0x00158d0004221522 (addr 31393): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.496 - info: zigbee.0 (6892) 0x00158d0003f4bf3e (addr 9840): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2021-09-27 11:20:47.498 - info: zigbee.0 (6892) 0x00158d0003f13adf (addr 9610): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2021-09-27 11:20:47.500 - info: zigbee.0 (6892) 0x00158d000451a514 (addr 54452): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.503 - info: zigbee.0 (6892) 0x00158d00042006e1 (addr 30835): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.505 - info: zigbee.0 (6892) 0x00158d0004201088 (addr 27465): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.508 - info: zigbee.0 (6892) 0x00158d0004281fd5 (addr 6494): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.510 - info: zigbee.0 (6892) 0x00158d00053fbc8c (addr 48940): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-09-27 11:20:47.513 - info: zigbee.0 (6892) 0x00158d00032c9cc7 (addr 57813): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      2021-09-27 11:20:47.515 - info: zigbee.0 (6892) 0x804b50fffee282e6 (addr 57512): ZS110050078 - Linkind Door/window Sensor (EndDevice)
      2021-09-27 11:20:47.517 - info: zigbee.0 (6892) 0x804b50fffee283c0 (addr 42570): ZS110050078 - Linkind Door/window Sensor (EndDevice)
      2021-09-27 11:20:47.519 - info: zigbee.0 (6892) 0x804b50fffee28475 (addr 54088): ZS110050078 - Linkind Door/window Sensor (EndDevice)
      2021-09-27 11:20:47.521 - info: zigbee.0 (6892) Zigbee started
      2021-09-27 11:30:00.148 - info: host.MWHome instance system.adapter.dwd.0 started with pid 8833
      2021-09-27 11:30:03.376 - info: dwd.0 (8833) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 11:30:07.558 - info: dwd.0 (8833) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 11:30:08.097 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 11:38:44.476 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone.active[iobroker/tr-064/0/devices/MWiPhone/active]
      2021-09-27 11:38:44.480 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone.lastInactive[iobroker/tr-064/0/devices/MWiPhone/lastInactive]
      2021-09-27 11:38:44.485 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone.lastInactive-ts[iobroker/tr-064/0/devices/MWiPhone/lastInactive-ts]
      2021-09-27 11:38:44.489 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone[iobroker/tr-064/0/devices/MWiPhone]
      2021-09-27 11:44:25.761 - info: mercedesme.0 (3201) State value to set for "mercedesme.0.W1K2384591F149129.history.tankLevelLast" has to be stringified but received type "number"
      2021-09-27 11:45:00.129 - info: host.MWHome instance system.adapter.dwd.0 started with pid 11874
      2021-09-27 11:45:03.309 - info: dwd.0 (11874) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 11:45:07.568 - info: dwd.0 (11874) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 11:45:08.116 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 12:00:00.140 - info: host.MWHome instance system.adapter.dwd.0 started with pid 14911
      2021-09-27 12:00:03.352 - info: dwd.0 (14911) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 12:00:07.782 - info: dwd.0 (14911) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 12:00:08.320 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 12:15:00.092 - info: host.MWHome instance system.adapter.dwd.0 started with pid 17969
      2021-09-27 12:15:05.111 - info: dwd.0 (17969) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 12:15:07.672 - info: dwd.0 (17969) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 12:15:08.220 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-27 12:18:02.433 - info: mercedesme.0 (3201) State value to set for "mercedesme.0.W1K2384591F149129.history.tankLevelLast" has to be stringified but received type "number"
      2021-09-27 12:18:52.690 - warn: zigbee.0 (6892) Failed to ping 0xccccccfffe021ec0 TRADFRI bulb E27 WS opal 1000lm
      2021-09-27 12:30:00.090 - info: host.MWHome instance system.adapter.dwd.0 started with pid 20979
      2021-09-27 12:30:03.181 - info: dwd.0 (20979) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
      2021-09-27 12:30:07.677 - info: dwd.0 (20979) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-09-27 12:30:08.213 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Lediglich um 10:07 ist ein ping fehlgeschlagen - das passiert schon mal und sehe ich nicht in Zusammenhang mit dem Absturz um 11:20 - also über 1 Std. später
      Kann mich auch nicht an eine spezielle Situation erinnern - oder was geschaltet zu haben. Wie gesagt, wenn ich das nicht in dem LOG gefunden hätte, hätte ich es nicht bemerkt. Ich kann das zwar wieder auf debug umstellen, aber das bläht halt das LOG immens auf, wenn man nicht weiß nach was man suchen soll. Ich habs trotzdem mal gepostet, vielleicht ist ja sonst noch was bekannt?
      Thomas BraunT AsgothianA mickymM 3 Antworten Letzte Antwort
      • mickymM mickym
        @mickym
        A.
        #73
        @mickym
        Aktualisier mal die Firmware von dem Stick.
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          #74
          @thomas-braun Ja das ist mir auch schon durch den Kopf gegangen. Habe auch schon gelesen, wie es geht. Ich muss mich nur trauen. Aber Du hast schon Recht.
          • mickymM mickym
            #75
            @mickym Die ist so alt, die wird schon gar nicht mehr im changelog aufgeführt.
            Edit: Doch noch drin. Aber nur noch so gerade eben...
              mickymM Offline
              mickymM Offline
              mickym
              #76
              @thomas-braun So hab auf die neueste Version upgegraded - habe es geschafft ohne den Stick kaputt zu machen. ;)
              Also mal schauen, ob die Abstürze noch kommen. ;)
              • mickymM mickym
                mickymM Offline
                mickymM Offline
                mickym
                #77
                Ob das so eine gute Idee war - mit dem FW Upgrade weiß ich noch nicht und ein Device war nicht mehr ansprechbar. Das Koppeln ist eine Katastrophe. Es findet immer nur der 1. Teil des Interviews statt und der 2. Teil lässt auf sich warten. Hoffentlich klappt das irgendwann.
                Update: So bin eine Version zurückgegangen und damit klappt das Pairen wieder besser - und alle Geräte sind aktuell ansprechbar - auch das Ansprechverhalten scheint besser zu sein, als bei der letzten FW Version
                • mickymM mickym
                  @mickym
                  A.
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #78
                  @mickym sagte in ZigBee neue Version 1.6.0:
                  Es sind einige Effekte bekannt ohne das zu 100 % klar ist wo sie her kommen. Bisher ist ein Debugging dieser Effekte schwer da (meines Wissens) keiner der Entwickler sie bei sich nachstellen kann.
                  Setzt du Blitzwolf Zigbee Steckdosen ein ? Wenn Ja, kannst du diese mal für eine Zeit aus dem Zigbee Netz nehmen um zu verifizieren das das Problem in diesem Umfeld auftritt ?
                  A.
                    A.
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #79
                    @asgothian Nein diese Steckdosen sind bei mir nicht im Einsatz.
                    Im Moment verhält sich das System (mit der vorletzten FW Version) - mal von dem Gruppensteuerungs-Bug abgesehen - sehr stabil. (also die letzten 9 Stunden. :D ).
                    Ich hoffe mal, dass das Upgrade was zur Stabilität beigetragen hat.
                    Ansonsten finde ich es toll (weiß nicht warum da immer noch Experimentalstadium steht), dass der Adapter diesen Conbee2 Stick unterstützt. Das möchte ich gerne loswerden.
                    Im Vergleich zum CC2531 ist
                    • die Reichweite wesentlich besser
                    • kann man den Stick unter Windows mit dem GCFFlasher updaten ohne irgendwelche Kabel und Zusatzgeräte (einfach Stick an den USB Stick und FW aufspielen). Finde ich Klasse
                    • das mit dem Pairen und der letzten FW Version hat wie gesagt nicht so gut geklappt, aber mit der vorletzten Version ging das nun ganz gut. Gefunden hat das Ding die neue Hardware immer, aber den 2. Teil des Interviews hat nie statt gefunden.
                    • Der Stick wird quasi immer gefunden und hängt nun sogar über ein USB Hub am System, also nicht mehr direkt am Raspberry. Bei dem CC2531 war das nicht möglich, der wurde dann gar nicht mehr gefunden, wenn er nicht direkt am Raspberry angeschlossen war. Da wurde das Teil aber immer relativ heiß - was sich in meinen Augen dann eben auch negativ auf die Lebensdauer auswirkt.
                    • Ich habe nun nicht die Rieseninstallation (nur 21 Geräte), davon waren bis auf 4 alle sofort ansprechbar nach dem Stickwechsel und ich musste die nicht wieder neu pairen (nur in den Einstellungen auf Deconz umgestellt). Super !!!!
                    • beim CC2531 hat sich wohl im Vorfeld angekündigt, dass sich hier die HW bald verabschiedet - indem der Fehler, dass am seriellen Port nicht geöffnet werden kann, vermehrt aufgetreten ist. Als das dann plötzlich mitten im laufenden Betrieb passiert ist - wusste ich das die HW hinüber war. Das war ja schon der 2. Sticke (beide Haltbarkeit von ca. 1 Jahr). Vor 1 Jahr war aber der Adapter noch nicht soweit, dass der Deconz2 so gut unterstützt wurde - da habt ihr viel daran gemacht. Also Danke nochmals.
                    • mickymM mickym
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #80
                      das ist doch kein Vergleich..ist so als würest du einen Trabi mit Porsche vergleichen.. es sind beide Autos und bringen dich da wo du hin willst...
                      vergiss es..
                      • mickymM mickym
                        @mickym
                        A.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #81
                        @mickym So heute ist der Adapter plötzlich wieder abgestürzt und war in einer Endlosschleife.
                        Aus heiterem Himmel - habe zwar noch 15 Min vorher vom Log dran, aber das sagt nichts. Wenn das häufiger auftritt muss ich wohl doch mal debug einschalten:
                        Abhilfe brachte nur ein kompletter Neustart des Systems - Stick ziehen und wieder reinstecken hat nichts gebracht.
                        2021-09-30 20:00:00.122 - info: host.MWHome instance system.adapter.dwd.0 started with pid 21041
                        2021-09-30 20:00:03.541 - info: dwd.0 (21041) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                        2021-09-30 20:00:08.080 - info: dwd.0 (21041) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2021-09-30 20:00:08.619 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2021-09-30 20:12:15.078 - error: zigbee.0 (27949) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-09-30 20:12:15.080 - error: zigbee.0 (27949) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:12:15.180 - error: zigbee.0 (27949) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
                        at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                        at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
                        2021-09-30 20:12:15.180 - error: zigbee.0 (27949) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:12:15.192 - info: zigbee.0 (27949) cleaned everything up...
                        2021-09-30 20:12:15.195 - info: zigbee.0 (27949) Zigbee: disabling joining new devices.
                        2021-09-30 20:12:15.693 - info: zigbee.0 (27949) terminating
                        2021-09-30 20:12:15.695 - warn: zigbee.0 (27949) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2021-09-30 20:12:16.318 - error: host.MWHome Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2021-09-30 20:12:16.324 - error: host.MWHome Caught by controller[2]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:12:16.324 - error: host.MWHome Caught by controller[2]: at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
                        2021-09-30 20:12:16.325 - error: host.MWHome Caught by controller[2]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                        2021-09-30 20:12:16.325 - error: host.MWHome Caught by controller[2]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
                        2021-09-30 20:12:16.325 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2021-09-30 20:12:16.326 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                        2021-09-30 20:12:46.432 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 23639
                        2021-09-30 20:12:50.667 - info: zigbee.0 (23639) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
                        2021-09-30 20:12:50.788 - info: zigbee.0 (23639) Starting Zigbee npm ...
                        2021-09-30 20:12:51.459 - error: zigbee.0 (23639) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                        2021-09-30 20:12:51.460 - error: zigbee.0 (23639) Failed to start Zigbee
                        2021-09-30 20:12:51.461 - error: zigbee.0 (23639) Error herdsman start
                        2021-09-30 20:12:51.463 - info: zigbee.0 (23639) Installed Version: iobroker.zigbee@1.6.0
                        2021-09-30 20:13:01.464 - info: zigbee.0 (23639) Try to reconnect. 1 attempts left
                        2021-09-30 20:13:01.465 - info: zigbee.0 (23639) Starting Zigbee npm ...
                        2021-09-30 20:13:01.491 - info: zigbee.0 (23639) Installed Version: iobroker.zigbee@1.6.0
                        2021-09-30 20:13:01.734 - error: zigbee.0 (23639) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                        2021-09-30 20:13:01.735 - error: zigbee.0 (23639) Failed to start Zigbee
                        2021-09-30 20:13:01.735 - error: zigbee.0 (23639) Error herdsman start
                        2021-09-30 20:13:21.333 - error: zigbee.0 (23639) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-09-30 20:13:21.334 - error: zigbee.0 (23639) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:13:21.336 - error: zigbee.0 (23639) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:13:21.337 - error: zigbee.0 (23639) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:13:21.356 - info: zigbee.0 (23639) cleaned everything up...
                        2021-09-30 20:13:21.362 - info: zigbee.0 (23639) Zigbee: disabling joining new devices.
                        2021-09-30 20:13:21.569 - info: zigbee.0 (23639) terminating
                        2021-09-30 20:13:21.571 - warn: zigbee.0 (23639) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2021-09-30 20:13:22.203 - error: host.MWHome Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2021-09-30 20:13:22.204 - error: host.MWHome Caught by controller[2]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:13:22.204 - error: host.MWHome Caught by controller[2]: at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
                        2021-09-30 20:13:22.205 - error: host.MWHome Caught by controller[2]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                        2021-09-30 20:13:22.205 - error: host.MWHome Caught by controller[2]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
                        2021-09-30 20:13:22.206 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2021-09-30 20:13:22.207 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                        2021-09-30 20:13:52.282 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 23888
                        2021-09-30 20:13:56.700 - info: zigbee.0 (23888) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
                        2021-09-30 20:13:56.817 - info: zigbee.0 (23888) Starting Zigbee npm ...
                        2021-09-30 20:13:57.305 - info: zigbee.0 (23888) Installed Version: iobroker.zigbee@1.6.0
                        2021-09-30 20:13:57.441 - error: zigbee.0 (23888) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                        2021-09-30 20:13:57.442 - error: zigbee.0 (23888) Failed to start Zigbee
                        2021-09-30 20:13:57.443 - error: zigbee.0 (23888) Error herdsman start
                        2021-09-30 20:14:07.447 - info: zigbee.0 (23888) Try to reconnect. 1 attempts left
                        2021-09-30 20:14:07.450 - info: zigbee.0 (23888) Starting Zigbee npm ...
                        2021-09-30 20:14:07.524 - info: zigbee.0 (23888) Installed Version: iobroker.zigbee@1.6.0
                        2021-09-30 20:14:07.718 - error: zigbee.0 (23888) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                        2021-09-30 20:14:07.719 - error: zigbee.0 (23888) Failed to start Zigbee
                        2021-09-30 20:14:07.720 - error: zigbee.0 (23888) Error herdsman start
                        2021-09-30 20:14:27.311 - error: zigbee.0 (23888) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-09-30 20:14:27.314 - error: zigbee.0 (23888) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:14:27.318 - error: zigbee.0 (23888) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:14:27.319 - error: zigbee.0 (23888) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:14:27.356 - info: zigbee.0 (23888) cleaned everything up...
                        2021-09-30 20:14:27.370 - info: zigbee.0 (23888) Zigbee: disabling joining new devices.
                        2021-09-30 20:14:27.559 - info: zigbee.0 (23888) terminating
                        2021-09-30 20:14:27.560 - warn: zigbee.0 (23888) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2021-09-30 20:14:28.212 - error: host.MWHome Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2021-09-30 20:14:28.213 - error: host.MWHome Caught by controller[2]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                        2021-09-30 20:14:28.214 - error: host.MWHome Caught by controller[2]: at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
                        2021-09-30 20:14:28.214 - error: host.MWHome Caught by controller[2]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                        2021-09-30 20:14:28.215 - error: host.MWHome Caught by controller[2]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
                        2021-09-30 20:14:28.215 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2021-09-30 20:14:28.216 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                        2021-09-30 20:14:28.217 - warn: host.MWHome Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                        2021-09-30 20:15:00.088 - info: host.MWHome instance system.adapter.dwd.0 started with pid 24126
                        2021-09-30 20:15:05.055 - info: dwd.0 (24126) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                        2021-09-30 20:15:07.510 - info: dwd.0 (24126) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2021-09-30 20:15:08.056 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        Nach Neustart nun alles wieder ruhig und normal
                        • mickymM mickym
                          #82
                          Hinterleg den Link 'by-id' im Adapter.
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #83
                            @thomas-braun Hab ich gemacht - mal schauen, ob das was bringt
                            • mickymM mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #84
                              Sporadisch immer noch Absturz - insofern haben FW Update und Umstellung auf ID nichts gebracht. Passiert vielleicht alle 3 Tage 1 Mal - aber irgendwas wird halt nicht richtig abgefangen.
                              2021-10-06 07:19:19.207 - error: zigbee.0 (10138) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-10-06 07:19:19.207 - error: zigbee.0 (10138) unhandled promise rejection: undefined
                              2021-10-06 07:19:19.209 - info: zigbee.0 (10138) cleaned everything up...
                              2021-10-06 07:19:19.300 - info: zigbee.0 (10138) Zigbee: disabling joining new devices.
                              2021-10-06 07:19:19.628 - info: zigbee.0 (10138) terminating
                              2021-10-06 07:19:19.630 - warn: zigbee.0 (10138) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-10-06 07:19:20.247 - error: host.MWHome Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                              2021-10-06 07:19:20.253 - error: host.MWHome Caught by controller[2]: undefined
                              2021-10-06 07:19:20.254 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-10-06 07:19:20.255 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                              2021-10-06 07:19:50.298 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 31577
                              2021-10-06 07:19:54.744 - info: zigbee.0 (31577) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.0, js-controller: 3.3.18
                              2021-10-06 07:19:54.866 - info: zigbee.0 (31577) Starting Zigbee npm ...
                              2021-10-06 07:19:55.286 - info: zigbee.0 (31577) Installed Version: iobroker.zigbee@1.6.0
                              2021-10-06 07:19:55.462 - info: zigbee.0 (31577) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":112,"maintrel":0,"revision":"0x26700700"}}
                              2021-10-06 07:19:55.486 - info: zigbee.0 (31577) Unable to disable LED, unsupported function.
                              2021-10-06 07:19:55.640 - info: zigbee.0 (31577) --> transmitPower : normal
                              2021-10-06 07:19:55.722 - info: zigbee.0 (31577) Unable to set transmit power, unsupported function.
                              2021-10-06 07:19:55.728 - info: zigbee.0 (31577) Currently 21 devices are joined:
                              Ich verfolge, dass aber erst mal nicht weiter, weil sonst bis auf die Gruppenfunktion mit dem Fehlern im Log alles funktioniert.
                              • mickymM mickym
                                #85
                                Version 1.6.0
                                In stable ist 1.5.6, in beta 1.6.3.
                                  Version 1.6.0
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #86
                                  @thomas-braun Auf github vielleicht, aber in der normalen Beta ist immer noch 1.6.0
                                  Aber egal - solange es in der Häufigkeit passiert -stört mich das nicht und warte lieber bis das Gruppenproblem gelöst ist.
                                  • mickymM mickym
                                    #87
                                    @mickym
                                    Nope:
                                    zigbee
                                    github:	1.6.4
                                    latest:	1.6.3 for 8 days
                                    stable:	1.5.6 for 4 months
                                      @mickym
                                      Nope:
                                      zigbee
                                      github:	1.6.4
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #88
                                      Na nun hat es der Info Adapter gefunden - war aber keine gute Idee - da Installation fehlschlug und nun gar nichts mehr geht:
                                      $ ./iobroker upgrade zigbee
                                      Update zigbee from @1.6.0 to @1.6.3
                                      host.MWHome Adapter "system.adapter.zigbee.0" is stopped.
                                      NPM version: 6.14.15npm install iobroker.zigbee@1.6.3 --loglevel error --prefix "/opt/iobroker" (System call)
                                      make: g++: Datei oder Verzeichnis nicht gefunden
                                      make: *** [bindings.target.mk:112: Release/obj.target/bindings/src/serialport.o] Fehler 127gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:400:28)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.63-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! @serialport/bindings@9.2.3 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-10-06T14_10_43_237Z-debug.log
                                      ERROR: host.MWHome Cannot install iobroker.zigbee@1.6.3: 1
                                      Irgendwie fehlt wohl ein Kompiler.
                                      EDIT: Hat sich von selbst wieder repariert - und ist wieder auf 1.6.0 gesprungen!!!! -
                                      oder muss ich den C++ Compiler installieren???
                                      apt-get install g++
                                      EDIT2: OK nach Installation des Compilers hat Update auf 1.6.3 funktioniert. :)
                                      Die Gruppenfehler sind aber nach wie vor noch vorhanden - aber nun läuft 1.6.3
                                      2021-10-06 16:23:48.130 - info: host.MWHome iobroker Adapter "zigbee" updated
                                      2021-10-06 16:23:48.139 - info: host.MWHome iobroker host.MWHome Adapter "system.adapter.zigbee.0" is started
                                      2021-10-06 16:23:48.201 - info: host.MWHome "system.adapter.zigbee.0" enabled
                                      2021-10-06 16:23:48.359 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 13645
                                      2021-10-06 16:23:49.326 - info: host.MWHome iobroker exit 0
                                      2021-10-06 16:23:53.783 - info: zigbee.0 (13645) starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.0, js-controller: 3.3.18
                                      2021-10-06 16:23:53.957 - info: zigbee.0 (13645) Starting Zigbee npm ...
                                      2021-10-06 16:23:54.532 - info: zigbee.0 (13645) Installed Version: iobroker.zigbee@1.6.3
                                      2021-10-06 16:23:54.679 - info: zigbee.0 (13645) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":112,"maintrel":0,"revision":"0x26700700"}}
                                      2021-10-06 16:23:54.701 - info: zigbee.0 (13645) Unable to disable LED, unsupported function.
                                      2021-10-06 16:23:54.830 - info: zigbee.0 (13645) --> transmitPower : normal
                                      2021-10-06 16:23:54.925 - info: zigbee.0 (13645) Unable to set transmit power, unsupported function.
                                      2021-10-06 16:23:54.932 - info: zigbee.0 (13645) Currently 21 devices are joined
                                      • mickymM mickym
                                        npm ERR! errno 1
                                        apt-get install g++
                                        #89
                                        @mickym
                                        Ist das build-essential Paket installiert? Das sollte eigentlich alles mitschleppen.
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #90
                                          Anscheinend nicht?? - sonst müsste wahrscheinlich auch installiert in KLammern dahinter stehen?:
                                          apt list build-essential
                                          Auflistung… Fertig
                                          build-essential/stable 12.9 armhf
                                          aber wie gesagt - ich hab jetzt g++ noch installiert und dann lief auch das zigbee update.
                                          apt list g++
                                          Auflistung… Fertig
                                          g++/stable,now 4:10.2.1-1+rpi1 armhf  [installiert]
