  4. ZigBee neue Version 1.6.x
    6.3k
509 Beiträge 61 Kommentatoren 150.2k Aufrufe 62 Beobachtet
  • BananaJoeB BananaJoe
    @rotamint keine Ahnung. Ich habe nur Geräte angelernt und nutze keine Gruppen/Bindíngs. Auch sind die ZigBee Geräte nicht untereinander gekoppelt.
    Ergo habe ich pro Gerät nur eine Zeile
    "ieeeAddr":"0x00212effff05b783"
    steht für das Gerät. Wo steht es denn bei den anderen
    rotamint
    @bananajoe
    z.B. id19 sieht so aus:
    {"id":19,"type":"EndDevice","ieeeAddr":"0x04cf8cdf3c7d9620","nwkAddr":23631,"manufId":4447,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.remote.b686opcn01","epList":[1,2,3,4,5],"endpoints":{"1":{"profId":260,"epId":1,"devId":261,"inClusterList":[0,3,1],"outClusterList":[3,6,8,768],"clusters":{"genBasic":{"attributes":{"modelId":"lumi.remote.b686opcn01","manufacturerName":"LUMI","powerSource":3,"zclVersion":3,"appVersion":17,"stackVersion":2,"hwVersion":1,"dateCode":"20190730","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"genMultistateInput":{"attributes":{"presentValue":1}},"aqaraOpple":{"attributes":{"247":{"type":"Buffer","data":[1,33,252,11,3,40,25,4,33,168,19,5,33,57,0,6,36,1,0,0,0,0,8,33,17,1,10,33,233,60,12,32,1,100,16,0]}}}},"binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff05b783","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00212effff05b783","endpointID":1},{"cluster":768,"type":"endpoint","deviceIeeeAddress":"0x00212effff05b783","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff05b783","endpointID":1}],"configuredReportings":[],"meta":{}},"2":{"epId":2,"inClusterList":[],"outClusterList":[],"clusters":{"genMultistateInput":{"attributes":{"presentValue":1}}},"binds":[],"configuredReportings":[],"meta":{}},"3":{"epId":3,"inClusterList":[],"outClusterList":[],"clusters":{"genMultistateInput":{"attributes":{"presentValue":1}}},"binds":[],"configuredReportings":[],"meta":{}},"4":{"epId":4,"inClusterList":[],"outClusterList":[],"clusters":{"genMultistateInput":{"attributes":{"presentValue":1}}},"binds":[],"configuredReportings":[],"meta":{}},"5":{"epId":5,"inClusterList":[],"outClusterList":[],"clusters":{"genMultistateInput":{"attributes":{"presentValue":1}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":17,"stackVersion":2,"hwVersion":1,"dateCode":"20190730","swBuildId":"2019\u0000www.","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1632230330161}
    JLegJ 1 Antwort Letzte Antwort
    • R rotamint
      @bananajoe
      JLegJ Offline
      JLegJ Offline
      JLeg
      @rotamint sieht doch aus wie eine Fernbedienung (evtl. Aqara 4fach-Schalter?) , die 4 "Knöpfe" für das "böse" Device definiert. Den Eintrag löschen, und es sind schonmal 4 Referenzen weg. Die FB muss dann vermutlich neu angelernt werden, falls später benötigt...
      • R rotamint
        @asgothian said in ZigBee neue Version 1.6.0:
        dabei darauf achten das das Format sauber bleibt.
        Danke für Deine Hilfe. Wie muss das "saubere" Format aussehen?
        LG Stefan.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @rotamint
        Das ist eigentlich ganz einfach. Um das device sind {} gesetzt. Sprich du musst zu der öffnenden { des devices die passende } finden, und dann beide {} samt Inhalt dazwischen löschen.
        A.
        • R Offline
          rotamint
          Ich komme hier nicht wirklich weiter. Nach dem Sichern der shepherd habe ich sie mal komplett gelöscht. Zigbee neu gestartet und die "neue" shepherd mal angeschaut... Und da ist es wieder das unbekannte Device :-(
          {"id":1,"type":"Coordinator","ieeeAddr":"0x00212effff05b783","nwkAddr":0,"manufId":4405,"epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterList":[0,10,25],"outClusterList":[1,32,1280],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":100,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"interviewCompleted":true,"meta":{},"lastSeen":null}
          • R rotamint
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @rotamint Einmal als Koordinator ist es ok. Mehrfach nicht.
            A.
            R 1 Antwort Letzte Antwort
            • AsgothianA Asgothian
              A.
              rotamint
              Danke an Alle, die mich hier bei der Fehlersuche unterstützt haben. Ganz besonders an Asgothian für seinen unermüdlichen Support!
              Es handelt sich um einen Bug, der in Verbindung mit Gruppen und dem Conbee II - Stick auftritt.
              Hier gehts zum issue auf Github.
              Einen schönen Abend!
              Stefan.
              • arteckA arteck
                @hukio du hast ein anderes Problem..
                da ist nicht alles installiert worden..
                stolly82S Offline
                stolly82S Offline
                stolly82
                Hey @arteck,
                leider finde ich keinen Thread mehr wo die neuen Geräte gepostet werden sollen, ich hoffe dieser hier ist der richtige.
                Wenn nicht,... sorry :-)
                Die neuen Schwaiger HAL 550 / ZBT-RGBWLight-GU100114 sind leider noch nicht eingebunden.
                Es währe super nett, wenn du das machen könntest.
                Vielen Dank!
                Jan
                https://www.ebay.de/itm/254781750443
                AsgothianA T 2 Antworten Letzte Antwort
                • stolly82S stolly82
                  Hey @arteck,
                  Vielen Dank!
                  Jan
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @stolly82 Es gibt den Thread nicht mehr da wir die Geräte Definition vollständig vom Herdsman übernehmen können - wenn das Gerät im Herdsman verfügbar ist sollte es automatisch im Zigbee Adapter gehen wenn der Herdsman aktualisiert wird.
                  A.
                  • arteckA arteck
                    wit haben gestern abend eine neue Version des Adapter publiziert..
                    in der latest die ihr im Admin sieht ist die allgemeine Version die wir normalerweise auch preferieren.. hier sind alle Geräte auch gepflegt bzw. der converter immer akuell
                    ABER
                    sollte diese Version nicht funktionieren bitte diese aus dem GIT installieren
                    https://github.com/ioBroker/ioBroker.zigbee/tarball/old_herdsman
                    sollte der Adapter immer noch nicht starten
                    hierzu muss noch die nvbackup.json gelöscht werden
                    adapter stoppen
                    rm /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                    adapter starten
                    warum so ein hickmeck....
                    es betrifft nicht die conbee Sticks
                    es hängt mit der Firmware zusammen die auf den Sticks drauf ist. Vor allem auf den CC2538 + CC2592 hat sich die Firmware nach und nach weiter entwickelt und
                    NUR die CC2538 + CC2592 sind BETROFFEN
                    alle die eine Firmware 20201010 haben sollten keine Probleme bekommen. Diese Firmware unterstützt das sichern und zurückspielen der Zigbee Netz Parameter.
                    alles was älter ist kann laufen was eher unwarscheinlich ist.
                    darüberhinaus hat das Projekt zigbee2mqtt erst jetzt damit begonen das zu unterstützen und da wir drauf aufsetzten sind wir von abhängig
                    wo sehe ich meine Firmware :
                    in der Kachel
                    p.s: wenn ihr wollt kann ich euch meine Sticks auf die neue Firmware bringen. Bedenkt aber auch dass es ein komplettes neu anlernen der Geräte mit sich zieht.
                    hierzu PM an mich
                    mickymM Offline
                    mickymM Offline
                    mickym
                    So ich habe nun leider auch wieder mal ein Zigbee Problem und bin mit meiner Weisheit am Ende. :(
                    Mir ist nun der 2. CC2531 Stick abgeraucht (Lebensdauer scheint so bei ca. 1 Jahr zu sein) und hatte auf die Schnelle noch einen Conbee2 Stick zur Hand und es funktioniert sogar - auf den ersten Blick zumindest - alles wieder.
                    Da ich mit dem 1.5.6 Adapter den Fehler hatte, mit dem Problem wegen dem Link State hatte
                    2021-09-25 03:15:29.072 - warn: zigbee.0 (10450) State value to set for "zigbee.0.ccccccfffeb3e954.link_quality" has value "255" greater than max "254"
                    2021-09-25 03:15:32.128 - warn: zigbee.0 (10450) State value to set for "zigbee.0.ccccccfffeb3e954.link_quality" has value "255" greater than max "254"
                    2021-09-25 03:16:36.795 - warn: zigbee.0 (10450) State value to set for "zigbee.0.00158d000411b98e.link_quality" has value "255" greater than max "254"
                    2021-09-25 03:16:36.855 - warn: zigbee.0 (10450) State value to set for "zigbee.0.00158d000411b98e.link_quality" has value "255" greater than max "254"
                    habe ich also auf 1.6.0 aktualisiert.
                    Der Fehler ist nun auch weg, aber nun habe ich ein anderes Problem.
                    Der Zigbee Adapter schreibt mir nun das komplette Log mit folgender Fehlermeldung voll.
                    021-09-25 04:02:47.621 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:02:47.667 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:02:53.131 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:02:53.152 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:02:58.409 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:02:58.477 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:03:04.160 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    Darauf habe ich wie unten im Thread mal mein shepherd.db unter /opt/iobroker/iobroker-data/zigbee_0 geöffnet um zu sehen, was für ein Device das ist.
                    Ich hab dann das device gesucht und das Device mit dieser ieeeAddr ist der Coordinator selbst. Ich hab das Teil dann mal rausgeschmissen und wurde auch wieder neu in die Datei geschrieben. Der Fehler bleibt aber.
                      "id": 1,
                      "type": "Coordinator",
                      "ieeeAddr": "0x00212effff05d77f",
                      "nwkAddr": 0,
                      "manufId": 0,
                      "epList": [
                        1,
                        2,
                        3,
                        4,
                        5,
                        6,
                        8,
                        11,
                        12,
                        13,
                        47,
                        110,
                        242
                      "endpoints": {
                        "1": {
                          "profId": 260,
                          "epId": 1,
                          "devId": 5,
                          "inClusterList": [],
                          "outClusterList": [],
                          "clusters": {},
                          "binds": [],
                          "configuredReportings": [],
                          "meta": {}
                        "2": {
                          "profId": 257,
                          "epId": 2,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "3": {
                          "profId": 261,
                          "epId": 3,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "4": {
                          "profId": 263,
                          "epId": 4,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "5": {
                          "profId": 264,
                          "epId": 5,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "6": {
                          "profId": 265,
                          "epId": 6,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "8": {
                          "profId": 260,
                          "epId": 8,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "11": {
                          "profId": 260,
                          "epId": 11,
                          "devId": 1024,
                          "outClusterList": [
                            1280,
                            1282
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "12": {
                          "profId": 49246,
                          "epId": 12,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "13": {
                          "profId": 260,
                          "epId": 13,
                          "devId": 5,
                          "inClusterList": [
                            25
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "47": {
                          "profId": 260,
                          "epId": 47,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "110": {
                          "profId": 260,
                          "epId": 110,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                        "242": {
                          "profId": 41440,
                          "epId": 242,
                          "devId": 5,
                          "clusters": {},
                          "binds": [],
                          "meta": {}
                      "interviewCompleted": true,
                      "meta": {},
                      "lastSeen": 1632534126595
                    Das Format von dem Device sieht zumindest was JSON betrifft in Ordnung aus. Kann mir jemand helfen?
                    Ergänzung:
                    So ich hatte das Device aus der Sherpherd.db gelöscht und den Adapter neu gestartet. Dann wird das Device erneut in der shepherd.db angelegt aber die Fehlermeldung bleibt.
                    2021-09-25 04:34:03.597 - info: zigbee.0 (21251) cleaned everything up...
                    2021-09-25 04:34:03.600 - info: zigbee.0 (21251) Zigbee: disabling joining new devices.
                    2021-09-25 04:34:04.297 - info: zigbee.0 (21251) terminating
                    2021-09-25 04:34:04.299 - info: zigbee.0 (21251) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2021-09-25 04:34:04.305 - warn: zigbee.0 (21251) Got terminate signal. Checking desired PID: 3430 vs own PID 21251
                    2021-09-25 04:34:05.378 - error: host.MWHome instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                    2021-09-25 04:34:05.379 - info: host.MWHome Do not restart adapter system.adapter.zigbee.0 because desired by instance
                    2021-09-25 04:34:11.362 - info: zigbee.0 (3430) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
                    2021-09-25 04:34:11.597 - info: zigbee.0 (3430) Starting Zigbee npm ...
                    2021-09-25 04:34:12.533 - info: zigbee.0 (3430) Installed Version: iobroker.zigbee@1.6.0
                    2021-09-25 04:34:12.686 - info: zigbee.0 (3430) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                    2021-09-25 04:34:12.721 - info: zigbee.0 (3430) Unable to disable LED, unsupported function.
                    2021-09-25 04:34:12.957 - info: zigbee.0 (3430) --> transmitPower : normal
                    2021-09-25 04:34:13.197 - info: zigbee.0 (3430) Unable to set transmit power, unsupported function.
                    2021-09-25 04:34:13.205 - info: zigbee.0 (3430) Currently 21 devices are joined:
                    2021-09-25 04:34:13.401 - info: zigbee.0 (3430) 0xec1bbdfffeebe96b (addr 21987): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                    2021-09-25 04:34:13.407 - info: zigbee.0 (3430) 0xec1bbdfffeeae2df (addr 37220): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                    2021-09-25 04:34:13.410 - info: zigbee.0 (3430) 0xec1bbdfffeeadb1a (addr 788): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                    2021-09-25 04:34:13.414 - info: zigbee.0 (3430) 0xccccccfffe021ec0 (addr 44672): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
                    2021-09-25 04:34:13.417 - info: zigbee.0 (3430) 0x00158d000411b98e (addr 2879): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.419 - info: zigbee.0 (3430) 0x00158d00032c8aa8 (addr 7440): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                    2021-09-25 04:34:13.421 - info: zigbee.0 (3430) 0x00158d000424453c (addr 15225): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.424 - info: zigbee.0 (3430) 0xccccccfffeb3e954 (addr 2130): E1746 - IKEA TRADFRI signal repeater (Router)
                    2021-09-25 04:34:13.426 - info: zigbee.0 (3430) 0x00158d0004282104 (addr 51621): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.430 - info: zigbee.0 (3430) 0x00158d0004221522 (addr 31393): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.432 - info: zigbee.0 (3430) 0x00158d0003f4bf3e (addr 9840): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                    2021-09-25 04:34:13.434 - info: zigbee.0 (3430) 0x00158d0003f13adf (addr 9610): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                    2021-09-25 04:34:13.436 - info: zigbee.0 (3430) 0x00158d000451a514 (addr 54452): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.438 - info: zigbee.0 (3430) 0x00158d00042006e1 (addr 30835): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.446 - info: zigbee.0 (3430) 0x00158d0004201088 (addr 27465): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.450 - info: zigbee.0 (3430) 0x00158d0004281fd5 (addr 6494): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.452 - info: zigbee.0 (3430) 0x00158d00053fbc8c (addr 48940): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                    2021-09-25 04:34:13.454 - info: zigbee.0 (3430) 0x00158d00032c9cc7 (addr 57813): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                    2021-09-25 04:34:13.456 - info: zigbee.0 (3430) 0x804b50fffee282e6 (addr 37006): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                    2021-09-25 04:34:13.458 - info: zigbee.0 (3430) 0x804b50fffee283c0 (addr 5248): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                    2021-09-25 04:34:13.468 - info: zigbee.0 (3430) 0x804b50fffee28475 (addr 37252): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                    2021-09-25 04:34:13.470 - info: zigbee.0 (3430) Zigbee started
                    2021-09-25 04:34:31.366 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:34:31.374 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:35:41.929 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 04:35:41.944 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    Das hängt wohl mit allen Aktivitäten des Coordinators zusammen.
                    Leider kann man das Logging zwischenzeitlich nicht ganz abschalten - da ja auf der error Stufe geloggt wird.
                    Es handelt sich wie gesagt um einen conbee II - Stick.
                    Auch die Netzwerkkarte funktioniert mit dem Conbee nun (war glaube ich früher mal ein Problem)
                    also funktional schaut erst mal alles gut aus. Nur das Log läuft voll. 😧
                    Beim Durchblättern des Threads scheinen wohl alle mit dem ConBee2 dieses Problem zu haben (wie
                    @luie ==> https://forum.iobroker.net/topic/46927/zigbee-neue-version-1-6-0/49?_=1632532816757
                    @rotamint ==> https://forum.iobroker.net/topic/46927/zigbee-neue-version-1-6-0/20?_=1632532816757
                    Im Prinzip treten die Fehlermeldungen wohl bei allen Nachrichten auf. Es scheint, dass jede Aktivität von allen Geräten diese Einträge generieren. Also nicht ein spezielles Gerät.
                    Ich hab mal das LOG auf Debug gestellt und zwischen 2 Fehlermeldungen alles rein kopiert . Irgendwas steht da von wrong device. - Ich hoffe man kann damit was anfangen:
                    2021-09-25 05:15:58.826 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 05:15:58.834 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 05:15:58.843 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:15:58.844 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:15:58.845 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:15:59.473 - debug: zigbee.0 (17354) convert result {"state":{"state":"OFF"},"readAfterWriteTime":0}
                    2021-09-25 05:15:59.474 - debug: zigbee.0 (17354) entity: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539721177,"_linkquality":135},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"endpoint":{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0xccccccfffe021ec0"}
                    2021-09-25 05:15:59.475 - debug: zigbee.0 (17354) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"}
                    2021-09-25 05:15:59.558 - debug: zigbee.0 (17354) handleMessage. {"type":"readResponse","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":151,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":11,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                    2021-09-25 05:15:59.559 - debug: zigbee.0 (17354) Received Zigbee message from '0xccccccfffe021ec0', type 'readResponse', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
                    2021-09-25 05:15:59.560 - debug: zigbee.0 (17354) Type readResponse device {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"name":"0xccccccfffe021ec0"} incoming event: {"type":"readResponse","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":151,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":11,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                    2021-09-25 05:15:59.623 - debug: zigbee.0 (17354) Publish {"state":"OFF"} to "ccccccfffe021ec0"
                    2021-09-25 05:16:03.602 - debug: zigbee.0 (17354) User stateChange zigbee.0.ccccccfffe021ec0.state {"val":true,"ack":false,"ts":1632539763596,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1632539763596}
                    2021-09-25 05:16:03.611 - debug: zigbee.0 (17354) Change state 'state' at device 0xccccccfffe021ec0 type 'LED1732G11'
                    2021-09-25 05:16:03.614 - debug: zigbee.0 (17354) entity: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xccccccfffe021ec0"}
                    2021-09-25 05:16:03.615 - debug: zigbee.0 (17354) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"}
                    2021-09-25 05:16:03.616 - debug: zigbee.0 (17354) convert state, "ON", {"state":"ON","transition_time":0}
                    2021-09-25 05:16:03.616 - debug: zigbee.0 (17354) target: {"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}
                    2021-09-25 05:16:03.703 - debug: zigbee.0 (17354) convert result {"state":{"state":"ON"},"readAfterWriteTime":0}
                    2021-09-25 05:16:06.143 - debug: zigbee.0 (17354) User stateChange zigbee.0.group_2.state {"val":true,"ack":false,"ts":1632539766135,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1632539766135}
                    2021-09-25 05:16:06.153 - debug: zigbee.0 (17354) User stateChange zigbee.0.ccccccfffe021ec0.state {"val":false,"ack":false,"ts":1632539766135,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1632539766135}
                    2021-09-25 05:16:06.173 - debug: zigbee.0 (17354) Change state 'state' at device 2 type 'group'
                    2021-09-25 05:16:06.175 - debug: zigbee.0 (17354) entity: {"type":"group","mapped":{"databaseID":6,"groupID":2,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"]},null],"model":"group"},"group":"[Circular]","name":"Group 2"}
                    2021-09-25 05:16:06.176 - debug: zigbee.0 (17354) Mapped Model: {"databaseID":6,"groupID":2,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"]},null],"model":"group"}
                    2021-09-25 05:16:06.177 - debug: zigbee.0 (17354) convert state, "ON", {"state":"ON"}
                    2021-09-25 05:16:06.178 - debug: zigbee.0 (17354) target: {"databaseID":6,"groupID":2,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"]},null],"model":"group"}
                    2021-09-25 05:16:06.188 - debug: zigbee.0 (17354) Change state 'state' at device 0xccccccfffe021ec0 type 'LED1732G11'
                    2021-09-25 05:16:06.191 - debug: zigbee.0 (17354) entity: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539763703,"_linkquality":151},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xccccccfffe021ec0"}
                    2021-09-25 05:16:06.192 - debug: zigbee.0 (17354) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"}
                    2021-09-25 05:16:06.196 - debug: zigbee.0 (17354) convert state, "OFF", {"state":"OFF","transition_time":0}
                    2021-09-25 05:16:06.197 - debug: zigbee.0 (17354) target: {"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}
                    2021-09-25 05:16:06.214 - debug: zigbee.0 (17354) handleMessage. {"type":"commandOn","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff05d77f","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1632539766213,"_linkquality":19},"endpoint":"[Circular]","data":{},"linkquality":19,"groupID":2,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":13,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                    2021-09-25 05:16:06.216 - debug: zigbee.0 (17354) Received Zigbee message from '0x00212effff05d77f', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 2
                    2021-09-25 05:16:06.219 - debug: zigbee.0 (17354) Type commandOn device {"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff05d77f","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1632539766213,"_linkquality":19},"mapped":null,"name":"Coordinator"} incoming event: {"type":"commandOn","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff05d77f","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1632539766213,"_linkquality":19},"endpoint":"[Circular]","data":{},"linkquality":19,"groupID":2,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":13,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                    2021-09-25 05:16:06.249 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 05:16:06.262 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                    2021-09-25 05:16:06.278 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:16:06.279 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:16:06.280 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:16:06.281 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                    2021-09-25 05:16:06.626 - debug: zigbee.0 (17354) convert result {"state":{"state":"OFF"},"readAfterWriteTime":0}
                    2021-09-25 05:16:06.858 - debug: zigbee.0 (17354) convert result {"state":{"state":"ON"},"readAfterWriteTime":0}
                    • mickymM mickym
                      So ich habe nun leider auch wieder mal ein Zigbee Problem und bin mit meiner Weisheit am Ende. :(
                      Mir ist nun der 2. CC2531 Stick abgeraucht (Lebensdauer scheint so bei ca. 1 Jahr zu sein) und hatte auf die Schnelle noch einen Conbee2 Stick zur Hand und es funktioniert sogar - auf den ersten Blick zumindest - alles wieder.
                      Da ich mit dem 1.5.6 Adapter den Fehler hatte, mit dem Problem wegen dem Link State hatte
                      2021-09-25 03:15:29.072 - warn: zigbee.0 (10450) State value to set for "zigbee.0.ccccccfffeb3e954.link_quality" has value "255" greater than max "254"
                      2021-09-25 03:15:32.128 - warn: zigbee.0 (10450) State value to set for "zigbee.0.ccccccfffeb3e954.link_quality" has value "255" greater than max "254"
                      2021-09-25 03:16:36.795 - warn: zigbee.0 (10450) State value to set for "zigbee.0.00158d000411b98e.link_quality" has value "255" greater than max "254"
                      2021-09-25 03:16:36.855 - warn: zigbee.0 (10450) State value to set for "zigbee.0.00158d000411b98e.link_quality" has value "255" greater than max "254"
                      habe ich also auf 1.6.0 aktualisiert.
                      Der Fehler ist nun auch weg, aber nun habe ich ein anderes Problem.
                      Der Zigbee Adapter schreibt mir nun das komplette Log mit folgender Fehlermeldung voll.
                      021-09-25 04:02:47.621 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:02:47.667 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:02:53.131 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:02:53.152 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:02:58.409 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:02:58.477 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:03:04.160 - error: zigbee.0 (21251) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      Darauf habe ich wie unten im Thread mal mein shepherd.db unter /opt/iobroker/iobroker-data/zigbee_0 geöffnet um zu sehen, was für ein Device das ist.
                      Ich hab dann das device gesucht und das Device mit dieser ieeeAddr ist der Coordinator selbst. Ich hab das Teil dann mal rausgeschmissen und wurde auch wieder neu in die Datei geschrieben. Der Fehler bleibt aber.
                        "id": 1,
                        "type": "Coordinator",
                        "ieeeAddr": "0x00212effff05d77f",
                        "nwkAddr": 0,
                        "manufId": 0,
                        "epList": [
                          1,
                          2,
                          3,
                          4,
                          5,
                          6,
                          8,
                          11,
                          12,
                          13,
                          47,
                          110,
                          242
                        "endpoints": {
                          "1": {
                            "profId": 260,
                            "epId": 1,
                            "devId": 5,
                            "inClusterList": [],
                            "outClusterList": [],
                            "clusters": {},
                            "binds": [],
                            "configuredReportings": [],
                            "meta": {}
                          "2": {
                            "profId": 257,
                            "epId": 2,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "3": {
                            "profId": 261,
                            "epId": 3,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "4": {
                            "profId": 263,
                            "epId": 4,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "5": {
                            "profId": 264,
                            "epId": 5,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "6": {
                            "profId": 265,
                            "epId": 6,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "8": {
                            "profId": 260,
                            "epId": 8,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "11": {
                            "profId": 260,
                            "epId": 11,
                            "devId": 1024,
                            "outClusterList": [
                              1280,
                              1282
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "12": {
                            "profId": 49246,
                            "epId": 12,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "13": {
                            "profId": 260,
                            "epId": 13,
                            "devId": 5,
                            "inClusterList": [
                              25
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "47": {
                            "profId": 260,
                            "epId": 47,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "110": {
                            "profId": 260,
                            "epId": 110,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                          "242": {
                            "profId": 41440,
                            "epId": 242,
                            "devId": 5,
                            "clusters": {},
                            "binds": [],
                            "meta": {}
                        "interviewCompleted": true,
                        "meta": {},
                        "lastSeen": 1632534126595
                      Das Format von dem Device sieht zumindest was JSON betrifft in Ordnung aus. Kann mir jemand helfen?
                      Ergänzung:
                      So ich hatte das Device aus der Sherpherd.db gelöscht und den Adapter neu gestartet. Dann wird das Device erneut in der shepherd.db angelegt aber die Fehlermeldung bleibt.
                      2021-09-25 04:34:03.597 - info: zigbee.0 (21251) cleaned everything up...
                      2021-09-25 04:34:03.600 - info: zigbee.0 (21251) Zigbee: disabling joining new devices.
                      2021-09-25 04:34:04.297 - info: zigbee.0 (21251) terminating
                      2021-09-25 04:34:04.299 - info: zigbee.0 (21251) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2021-09-25 04:34:04.305 - warn: zigbee.0 (21251) Got terminate signal. Checking desired PID: 3430 vs own PID 21251
                      2021-09-25 04:34:05.378 - error: host.MWHome instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                      2021-09-25 04:34:05.379 - info: host.MWHome Do not restart adapter system.adapter.zigbee.0 because desired by instance
                      2021-09-25 04:34:11.362 - info: zigbee.0 (3430) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
                      2021-09-25 04:34:11.597 - info: zigbee.0 (3430) Starting Zigbee npm ...
                      2021-09-25 04:34:12.533 - info: zigbee.0 (3430) Installed Version: iobroker.zigbee@1.6.0
                      2021-09-25 04:34:12.686 - info: zigbee.0 (3430) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                      2021-09-25 04:34:12.721 - info: zigbee.0 (3430) Unable to disable LED, unsupported function.
                      2021-09-25 04:34:12.957 - info: zigbee.0 (3430) --> transmitPower : normal
                      2021-09-25 04:34:13.197 - info: zigbee.0 (3430) Unable to set transmit power, unsupported function.
                      2021-09-25 04:34:13.205 - info: zigbee.0 (3430) Currently 21 devices are joined:
                      2021-09-25 04:34:13.401 - info: zigbee.0 (3430) 0xec1bbdfffeebe96b (addr 21987): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                      2021-09-25 04:34:13.407 - info: zigbee.0 (3430) 0xec1bbdfffeeae2df (addr 37220): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                      2021-09-25 04:34:13.410 - info: zigbee.0 (3430) 0xec1bbdfffeeadb1a (addr 788): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                      2021-09-25 04:34:13.414 - info: zigbee.0 (3430) 0xccccccfffe021ec0 (addr 44672): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
                      2021-09-25 04:34:13.417 - info: zigbee.0 (3430) 0x00158d000411b98e (addr 2879): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.419 - info: zigbee.0 (3430) 0x00158d00032c8aa8 (addr 7440): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                      2021-09-25 04:34:13.421 - info: zigbee.0 (3430) 0x00158d000424453c (addr 15225): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.424 - info: zigbee.0 (3430) 0xccccccfffeb3e954 (addr 2130): E1746 - IKEA TRADFRI signal repeater (Router)
                      2021-09-25 04:34:13.426 - info: zigbee.0 (3430) 0x00158d0004282104 (addr 51621): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.430 - info: zigbee.0 (3430) 0x00158d0004221522 (addr 31393): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.432 - info: zigbee.0 (3430) 0x00158d0003f4bf3e (addr 9840): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      2021-09-25 04:34:13.434 - info: zigbee.0 (3430) 0x00158d0003f13adf (addr 9610): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      2021-09-25 04:34:13.436 - info: zigbee.0 (3430) 0x00158d000451a514 (addr 54452): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.438 - info: zigbee.0 (3430) 0x00158d00042006e1 (addr 30835): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.446 - info: zigbee.0 (3430) 0x00158d0004201088 (addr 27465): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.450 - info: zigbee.0 (3430) 0x00158d0004281fd5 (addr 6494): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.452 - info: zigbee.0 (3430) 0x00158d00053fbc8c (addr 48940): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                      2021-09-25 04:34:13.454 - info: zigbee.0 (3430) 0x00158d00032c9cc7 (addr 57813): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                      2021-09-25 04:34:13.456 - info: zigbee.0 (3430) 0x804b50fffee282e6 (addr 37006): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                      2021-09-25 04:34:13.458 - info: zigbee.0 (3430) 0x804b50fffee283c0 (addr 5248): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                      2021-09-25 04:34:13.468 - info: zigbee.0 (3430) 0x804b50fffee28475 (addr 37252): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                      2021-09-25 04:34:13.470 - info: zigbee.0 (3430) Zigbee started
                      2021-09-25 04:34:31.366 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:34:31.374 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:35:41.929 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 04:35:41.944 - error: zigbee.0 (3430) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      Das hängt wohl mit allen Aktivitäten des Coordinators zusammen.
                      Leider kann man das Logging zwischenzeitlich nicht ganz abschalten - da ja auf der error Stufe geloggt wird.
                      Es handelt sich wie gesagt um einen conbee II - Stick.
                      Auch die Netzwerkkarte funktioniert mit dem Conbee nun (war glaube ich früher mal ein Problem)
                      also funktional schaut erst mal alles gut aus. Nur das Log läuft voll. 😧
                      Beim Durchblättern des Threads scheinen wohl alle mit dem ConBee2 dieses Problem zu haben (wie
                      @luie ==> https://forum.iobroker.net/topic/46927/zigbee-neue-version-1-6-0/49?_=1632532816757
                      @rotamint ==> https://forum.iobroker.net/topic/46927/zigbee-neue-version-1-6-0/20?_=1632532816757
                      Im Prinzip treten die Fehlermeldungen wohl bei allen Nachrichten auf. Es scheint, dass jede Aktivität von allen Geräten diese Einträge generieren. Also nicht ein spezielles Gerät.
                      Ich hab mal das LOG auf Debug gestellt und zwischen 2 Fehlermeldungen alles rein kopiert . Irgendwas steht da von wrong device. - Ich hoffe man kann damit was anfangen:
                      2021-09-25 05:15:58.826 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 05:15:58.834 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 05:15:58.843 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:15:58.844 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:15:58.845 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:15:59.473 - debug: zigbee.0 (17354) convert result {"state":{"state":"OFF"},"readAfterWriteTime":0}
                      2021-09-25 05:15:59.474 - debug: zigbee.0 (17354) entity: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539721177,"_linkquality":135},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"endpoint":{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0xccccccfffe021ec0"}
                      2021-09-25 05:15:59.475 - debug: zigbee.0 (17354) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"}
                      2021-09-25 05:15:59.558 - debug: zigbee.0 (17354) handleMessage. {"type":"readResponse","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":151,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":11,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                      2021-09-25 05:15:59.559 - debug: zigbee.0 (17354) Received Zigbee message from '0xccccccfffe021ec0', type 'readResponse', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
                      2021-09-25 05:15:59.560 - debug: zigbee.0 (17354) Type readResponse device {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"name":"0xccccccfffe021ec0"} incoming event: {"type":"readResponse","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":151,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":11,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                      2021-09-25 05:15:59.623 - debug: zigbee.0 (17354) Publish {"state":"OFF"} to "ccccccfffe021ec0"
                      2021-09-25 05:16:03.602 - debug: zigbee.0 (17354) User stateChange zigbee.0.ccccccfffe021ec0.state {"val":true,"ack":false,"ts":1632539763596,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1632539763596}
                      2021-09-25 05:16:03.611 - debug: zigbee.0 (17354) Change state 'state' at device 0xccccccfffe021ec0 type 'LED1732G11'
                      2021-09-25 05:16:03.614 - debug: zigbee.0 (17354) entity: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539759557,"_linkquality":151},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xccccccfffe021ec0"}
                      2021-09-25 05:16:03.615 - debug: zigbee.0 (17354) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"}
                      2021-09-25 05:16:03.616 - debug: zigbee.0 (17354) convert state, "ON", {"state":"ON","transition_time":0}
                      2021-09-25 05:16:03.616 - debug: zigbee.0 (17354) target: {"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}
                      2021-09-25 05:16:03.703 - debug: zigbee.0 (17354) convert result {"state":{"state":"ON"},"readAfterWriteTime":0}
                      2021-09-25 05:16:06.143 - debug: zigbee.0 (17354) User stateChange zigbee.0.group_2.state {"val":true,"ack":false,"ts":1632539766135,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1632539766135}
                      2021-09-25 05:16:06.153 - debug: zigbee.0 (17354) User stateChange zigbee.0.ccccccfffe021ec0.state {"val":false,"ack":false,"ts":1632539766135,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1632539766135}
                      2021-09-25 05:16:06.173 - debug: zigbee.0 (17354) Change state 'state' at device 2 type 'group'
                      2021-09-25 05:16:06.175 - debug: zigbee.0 (17354) entity: {"type":"group","mapped":{"databaseID":6,"groupID":2,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"]},null],"model":"group"},"group":"[Circular]","name":"Group 2"}
                      2021-09-25 05:16:06.176 - debug: zigbee.0 (17354) Mapped Model: {"databaseID":6,"groupID":2,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"]},null],"model":"group"}
                      2021-09-25 05:16:06.177 - debug: zigbee.0 (17354) convert state, "ON", {"state":"ON"}
                      2021-09-25 05:16:06.178 - debug: zigbee.0 (17354) target: {"databaseID":6,"groupID":2,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["color"]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"]},null],"model":"group"}
                      2021-09-25 05:16:06.188 - debug: zigbee.0 (17354) Change state 'state' at device 0xccccccfffe021ec0 type 'LED1732G11'
                      2021-09-25 05:16:06.191 - debug: zigbee.0 (17354) entity: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0xccccccfffe021ec0","_networkAddress":44672,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI bulb E27 WS opal 1000lm","_applicationVersion":32,"_stackVersion":98,"_zclVersion":2,"_hardwareVersion":1,"_dateCode":"20200312","_softwareBuildID":"2.0.029","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1632539763703,"_linkquality":151},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xccccccfffe021ec0"}
                      2021-09-25 05:16:06.192 - debug: zigbee.0 (17354) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","previous","on"],"description":"Controls the behavior when the device is powered on"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["power_on_behavior"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"ota":{},"zigbeeModel":["TRADFRI bulb E27 WS opal 1000lm","TRADFRI bulb E26 WS opal 1000lm"],"model":"LED1732G11","vendor":"IKEA","description":"TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white"}
                      2021-09-25 05:16:06.196 - debug: zigbee.0 (17354) convert state, "OFF", {"state":"OFF","transition_time":0}
                      2021-09-25 05:16:06.197 - debug: zigbee.0 (17354) target: {"ID":1,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096,64636],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":44672,"deviceIeeeAddress":"0xccccccfffe021ec0","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI bulb E27 WS opal 1000lm","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":2,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20200312","swBuildId":"2.0.029"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":152,"onOffTransitionTime":5,"startUpCurrentLevel":255}},"lightingColorCtrl":{"attributes":{"colorTemperature":350,"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"startUpColorTemperature":65535,"colorMode":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}
                      2021-09-25 05:16:06.214 - debug: zigbee.0 (17354) handleMessage. {"type":"commandOn","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff05d77f","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1632539766213,"_linkquality":19},"endpoint":"[Circular]","data":{},"linkquality":19,"groupID":2,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":13,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                      2021-09-25 05:16:06.216 - debug: zigbee.0 (17354) Received Zigbee message from '0x00212effff05d77f', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 2
                      2021-09-25 05:16:06.219 - debug: zigbee.0 (17354) Type commandOn device {"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff05d77f","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1632539766213,"_linkquality":19},"mapped":null,"name":"Coordinator"} incoming event: {"type":"commandOn","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff05d77f","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff05d77f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1632539766213,"_linkquality":19},"endpoint":"[Circular]","data":{},"linkquality":19,"groupID":2,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":13,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                      2021-09-25 05:16:06.249 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 05:16:06.262 - error: zigbee.0 (17354) Device 0x00212effff05d77f "undefined" not described in statesMapping.
                      2021-09-25 05:16:06.278 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:16:06.279 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:16:06.280 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:16:06.281 - debug: zigbee.0 (17354) Wrong device 00212effff05d77f null
                      2021-09-25 05:16:06.626 - debug: zigbee.0 (17354) convert result {"state":{"state":"OFF"},"readAfterWriteTime":0}
                      2021-09-25 05:16:06.858 - debug: zigbee.0 (17354) convert result {"state":{"state":"ON"},"readAfterWriteTime":0}
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #66
                      @mickym So ich bin inzwischen etwas weiter gekommen. Es scheint nun doch so zu sein, dass die Fehlermeldungen in der Regel auftauchen, wenn man Geräte über die Gruppenfunktion schaltet. Bewegungsmelder, die den Fehler erzeugt haben, habe ich neu gepairt und da ist nun Ruhe. Es scheint also ein Problem mit der Gruppenfunktion zu geben.
                      • mickymM mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #67
                        @mickym UPDATE:
                        Geräte, die die Fehlermeldung erzeugt haben neu gepairt - aber Gruppenfunktion erzeugt diese Fehler. Wird nicht mit Gruppen gearbeitet funktioniert der deconz2 Stick mit dem Zigbee-Adapter durchaus zufriedenstellend. Einen einzigen Absturz hatte ich bislang.
                        Die neu gepairten Dev. werden zwar in der Netzwerkkarte nicht richtig (also ohne Verbindung dargestellt) - aber das Hauptproblem des Adapters in dieser Version mit dem deconz2 Stick scheint wohl die Gruppenfunktion zu sein.
                        • mickymM mickym
                          @mickym UPDATE:
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #68
                          @mickym Siehe Hier:
                          https://github.com/ioBroker/ioBroker.zigbee/issues/1219
                          • AsgothianA Asgothian
                            @mickym Siehe Hier:
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #69
                            @asgothian
                              @mickym Siehe Hier:
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #70
                              @asgothian Gibt noch hin und wieder einen kompletten Absturz des Adapters - aber durch automatischen Neustart fängt sich das System wieder:
                              2021-09-27 11:20:11.080 - error: zigbee.0 (23900) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-09-27 11:20:11.081 - error: zigbee.0 (23900) unhandled promise rejection: undefined
                              2021-09-27 11:20:11.084 - info: zigbee.0 (23900) cleaned everything up...
                              2021-09-27 11:20:11.169 - info: zigbee.0 (23900) Zigbee: disabling joining new devices.
                              2021-09-27 11:20:11.423 - info: zigbee.0 (23900) terminating
                              2021-09-27 11:20:11.427 - warn: zigbee.0 (23900) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-09-27 11:20:12.052 - error: host.MWHome Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                              2021-09-27 11:20:12.057 - error: host.MWHome Caught by controller[1]: undefined
                              2021-09-27 11:20:12.058 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2021-09-27 11:20:12.058 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                              2021-09-27 11:20:42.155 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 6892
                              2021-09-27 11:20:46.357 - info: zigbee.0 (6892) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
                              2021-09-27 11:20:46.478 - info: zigbee.0 (6892) Starting Zigbee npm ...
                              weiß nicht ob man das nachverfolgen will?
                              • mickymM mickym
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #71
                                @mickym
                                Poste doch mal die log Zeilen von vor dem Absturz.
                                A.
                                  @mickym
                                  A.
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #72
                                  @asgothian sagte in ZigBee neue Version 1.6.0:
                                  @mickym
                                  A.
                                  Ich glaub zwar nicht, dass das was bringt - ich hab den Adapter wieder auf Info Level gestellt und da ist nichts:
                                  2021-09-27 09:45:08.029 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 10:00:00.102 - info: host.MWHome instance system.adapter.dwd.0 started with pid 22353
                                  2021-09-27 10:00:02.972 - info: dwd.0 (22353) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 10:00:07.774 - info: dwd.0 (22353) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 10:00:08.320 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 10:07:28.753 - warn: zigbee.0 (23900) Failed to ping 0xccccccfffeb3e954 TRADFRI Signal Repeater
                                  2021-09-27 10:15:00.114 - info: host.MWHome instance system.adapter.dwd.0 started with pid 25506
                                  2021-09-27 10:15:04.932 - info: dwd.0 (25506) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 10:15:08.409 - info: dwd.0 (25506) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 10:15:08.947 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 10:30:00.153 - info: host.MWHome instance system.adapter.dwd.0 started with pid 28640
                                  2021-09-27 10:30:03.171 - info: dwd.0 (28640) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 10:30:07.556 - info: dwd.0 (28640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 10:30:08.108 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 10:45:00.163 - info: host.MWHome instance system.adapter.dwd.0 started with pid 31705
                                  2021-09-27 10:45:03.057 - info: dwd.0 (31705) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 10:45:06.804 - info: dwd.0 (31705) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 10:45:07.348 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 11:00:00.165 - info: host.MWHome instance system.adapter.dwd.0 started with pid 2458
                                  2021-09-27 11:00:03.185 - info: dwd.0 (2458) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 11:00:07.471 - info: dwd.0 (2458) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 11:00:08.007 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 11:15:00.141 - info: host.MWHome instance system.adapter.dwd.0 started with pid 5718
                                  2021-09-27 11:15:04.878 - info: dwd.0 (5718) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 11:15:07.486 - info: dwd.0 (5718) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 11:15:08.030 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 11:20:46.864 - info: zigbee.0 (6892) Installed Version: iobroker.zigbee@1.6.0
                                  2021-09-27 11:20:47.066 - info: zigbee.0 (6892) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":74,"maintrel":0,"revision":"0x264a0700"}}
                                  2021-09-27 11:20:47.088 - info: zigbee.0 (6892) Unable to disable LED, unsupported function.
                                  2021-09-27 11:20:47.223 - info: zigbee.0 (6892) --> transmitPower : normal
                                  2021-09-27 11:20:47.334 - info: zigbee.0 (6892) Unable to set transmit power, unsupported function.
                                  2021-09-27 11:20:47.342 - info: zigbee.0 (6892) Currently 21 devices are joined:
                                  2021-09-27 11:20:47.471 - info: zigbee.0 (6892) 0xec1bbdfffeebe96b (addr 21987): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                  2021-09-27 11:20:47.477 - info: zigbee.0 (6892) 0xec1bbdfffeeae2df (addr 37220): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                  2021-09-27 11:20:47.479 - info: zigbee.0 (6892) 0xec1bbdfffeeadb1a (addr 788): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                  2021-09-27 11:20:47.481 - info: zigbee.0 (6892) 0xccccccfffe021ec0 (addr 44672): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
                                  2021-09-27 11:20:47.484 - info: zigbee.0 (6892) 0x00158d000411b98e (addr 51704): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.486 - info: zigbee.0 (6892) 0x00158d00032c8aa8 (addr 7440): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                  2021-09-27 11:20:47.488 - info: zigbee.0 (6892) 0x00158d000424453c (addr 15225): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.491 - info: zigbee.0 (6892) 0xccccccfffeb3e954 (addr 2130): E1746 - IKEA TRADFRI signal repeater (Router)
                                  2021-09-27 11:20:47.493 - info: zigbee.0 (6892) 0x00158d0004282104 (addr 51621): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.494 - info: zigbee.0 (6892) 0x00158d0004221522 (addr 31393): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.496 - info: zigbee.0 (6892) 0x00158d0003f4bf3e (addr 9840): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2021-09-27 11:20:47.498 - info: zigbee.0 (6892) 0x00158d0003f13adf (addr 9610): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2021-09-27 11:20:47.500 - info: zigbee.0 (6892) 0x00158d000451a514 (addr 54452): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.503 - info: zigbee.0 (6892) 0x00158d00042006e1 (addr 30835): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.505 - info: zigbee.0 (6892) 0x00158d0004201088 (addr 27465): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.508 - info: zigbee.0 (6892) 0x00158d0004281fd5 (addr 6494): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.510 - info: zigbee.0 (6892) 0x00158d00053fbc8c (addr 48940): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                  2021-09-27 11:20:47.513 - info: zigbee.0 (6892) 0x00158d00032c9cc7 (addr 57813): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                  2021-09-27 11:20:47.515 - info: zigbee.0 (6892) 0x804b50fffee282e6 (addr 57512): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                                  2021-09-27 11:20:47.517 - info: zigbee.0 (6892) 0x804b50fffee283c0 (addr 42570): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                                  2021-09-27 11:20:47.519 - info: zigbee.0 (6892) 0x804b50fffee28475 (addr 54088): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                                  2021-09-27 11:20:47.521 - info: zigbee.0 (6892) Zigbee started
                                  2021-09-27 11:30:00.148 - info: host.MWHome instance system.adapter.dwd.0 started with pid 8833
                                  2021-09-27 11:30:03.376 - info: dwd.0 (8833) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 11:30:07.558 - info: dwd.0 (8833) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 11:30:08.097 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 11:38:44.476 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone.active[iobroker/tr-064/0/devices/MWiPhone/active]
                                  2021-09-27 11:38:44.480 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone.lastInactive[iobroker/tr-064/0/devices/MWiPhone/lastInactive]
                                  2021-09-27 11:38:44.485 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone.lastInactive-ts[iobroker/tr-064/0/devices/MWiPhone/lastInactive-ts]
                                  2021-09-27 11:38:44.489 - info: mqtt.2 (29397) send2Server tr-064.0.devices.MWiPhone[iobroker/tr-064/0/devices/MWiPhone]
                                  2021-09-27 11:44:25.761 - info: mercedesme.0 (3201) State value to set for "mercedesme.0.W1K2384591F149129.history.tankLevelLast" has to be stringified but received type "number"
                                  2021-09-27 11:45:00.129 - info: host.MWHome instance system.adapter.dwd.0 started with pid 11874
                                  2021-09-27 11:45:03.309 - info: dwd.0 (11874) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 11:45:07.568 - info: dwd.0 (11874) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 11:45:08.116 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 12:00:00.140 - info: host.MWHome instance system.adapter.dwd.0 started with pid 14911
                                  2021-09-27 12:00:03.352 - info: dwd.0 (14911) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 12:00:07.782 - info: dwd.0 (14911) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 12:00:08.320 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 12:15:00.092 - info: host.MWHome instance system.adapter.dwd.0 started with pid 17969
                                  2021-09-27 12:15:05.111 - info: dwd.0 (17969) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 12:15:07.672 - info: dwd.0 (17969) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 12:15:08.220 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-09-27 12:18:02.433 - info: mercedesme.0 (3201) State value to set for "mercedesme.0.W1K2384591F149129.history.tankLevelLast" has to be stringified but received type "number"
                                  2021-09-27 12:18:52.690 - warn: zigbee.0 (6892) Failed to ping 0xccccccfffe021ec0 TRADFRI bulb E27 WS opal 1000lm
                                  2021-09-27 12:30:00.090 - info: host.MWHome instance system.adapter.dwd.0 started with pid 20979
                                  2021-09-27 12:30:03.181 - info: dwd.0 (20979) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.17.6, js-controller: 3.3.18
                                  2021-09-27 12:30:07.677 - info: dwd.0 (20979) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-09-27 12:30:08.213 - info: host.MWHome instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  Lediglich um 10:07 ist ein ping fehlgeschlagen - das passiert schon mal und sehe ich nicht in Zusammenhang mit dem Absturz um 11:20 - also über 1 Std. später
                                  Kann mich auch nicht an eine spezielle Situation erinnern - oder was geschaltet zu haben. Wie gesagt, wenn ich das nicht in dem LOG gefunden hätte, hätte ich es nicht bemerkt. Ich kann das zwar wieder auf debug umstellen, aber das bläht halt das LOG immens auf, wenn man nicht weiß nach was man suchen soll. Ich habs trotzdem mal gepostet, vielleicht ist ja sonst noch was bekannt?
                                  Thomas BraunT AsgothianA mickymM 3 Antworten Letzte Antwort
                                  • mickymM mickym
                                    @mickym
                                    A.
                                    #73
                                    @mickym
                                    Aktualisier mal die Firmware von dem Stick.
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #74
                                      @thomas-braun Ja das ist mir auch schon durch den Kopf gegangen. Habe auch schon gelesen, wie es geht. Ich muss mich nur trauen. Aber Du hast schon Recht.
                                      • mickymM mickym
                                        #75
                                        @mickym Die ist so alt, die wird schon gar nicht mehr im changelog aufgeführt.
                                        Edit: Doch noch drin. Aber nur noch so gerade eben...
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #76
                                          @thomas-braun So hab auf die neueste Version upgegraded - habe es geschafft ohne den Stick kaputt zu machen. ;)
                                          Also mal schauen, ob die Abstürze noch kommen. ;)
